[U-Boot] [PATCH 0/2] misc: i2c_eeprom: Add compatibles
Add the compatibles to support the I2C EEPROM 24AA02E48 and AT24MAC402 respectively. - microchip,24aa02e48 - atmel,24mac402
Wenyou Yang (2): misc: i2c_eeprom: Add compatible for 24AA02E48 misc: i2c_eeprom: Add compatible for AT24MAC402
drivers/misc/i2c_eeprom.c | 2 ++ 1 file changed, 2 insertions(+)
Add the new compatible "microchip,24aa02e48" to accommodate 24AA02E48, the 24AA02E48 is a 2K I2C Serial EEPROM with pre-programmed globally unique, 48-bit node address, and 8-byte page size.
Signed-off-by: Wenyou Yang wenyou.yang@microchip.com ---
drivers/misc/i2c_eeprom.c | 1 + 1 file changed, 1 insertion(+)
diff --git a/drivers/misc/i2c_eeprom.c b/drivers/misc/i2c_eeprom.c index a14e83225b..b2de3dffc6 100644 --- a/drivers/misc/i2c_eeprom.c +++ b/drivers/misc/i2c_eeprom.c @@ -66,6 +66,7 @@ static int i2c_eeprom_std_probe(struct udevice *dev)
static const struct udevice_id i2c_eeprom_std_ids[] = { { .compatible = "i2c-eeprom", .data = 0 }, + { .compatible = "microchip,24aa02e48", .data = 3 }, { .compatible = "atmel,24c01a", .data = 3 }, { .compatible = "atmel,24c02", .data = 3 }, { .compatible = "atmel,24c04", .data = 4 },
Add the new compatible "atmel,24mac402" to accommodate AT24MAC402. The AT24MAC402 is a 2K Serial EEPROM and the 2-Kbit memory array is internally organized as 16 pages of 16 bytes of EEPROM each. The 48-bit EUI address in the AT24MAC402 are located in the extended memory block.
diff --git a/drivers/misc/i2c_eeprom.c b/drivers/misc/i2c_eeprom.c index b2de3dffc6..9a77c6e164 100644 --- a/drivers/misc/i2c_eeprom.c +++ b/drivers/misc/i2c_eeprom.c @@ -72,6 +72,7 @@ static const struct udevice_id i2c_eeprom_std_ids[] = { { .compatible = "atmel,24c04", .data = 4 }, { .compatible = "atmel,24c08a", .data = 4 }, { .compatible = "atmel,24c16a", .data = 4 }, + { .compatible = "atmel,24mac402", .data = 4 }, { .compatible = "atmel,24c32", .data = 5 }, { .compatible = "atmel,24c64", .data = 5 }, { .compatible = "atmel,24c128", .data = 6 },
- atmel,24mac402
How does this work in the kernel? Grepping around on what we list currently even, I see that Documentation/devicetree/bindings/eeprom/eeprom.txt lists some of the ones we have in drivers/misc/i2c_eeprom.c as an example but nothing catching on the compatible string. Does the kernel have some smart logic to match these compatibles? If so, could we mirror that? Thanks!
Can be accepted?
- atmel,24mac402
Best Regards, Wenyou Yang
Wenyou Yang
Yang, Wenyou
