[U-Boot] [PATCH] powerpc/mpc85xx: explicit cast the SDRAM size to type phys_size_t
To avoid sign extension problem, use explicit casting to cast the SDRAM size to type phys_size_t, or else, if the SDRAM size is 2G(0x80000000), it will be extended to 0xffffffff80000000 when phys_size_t is type 'unsigned long long'.
Signed-off-by: Mingkai Hu Mingkai.Hu@freescale.com ---
Based on master branch of git://git.denx.de/u-boot.git Also can apply direcly to git://www.denx.de/git/u-boot-mpc85xx.git
arch/powerpc/cpu/mpc85xx/cpu.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/powerpc/cpu/mpc85xx/cpu.c b/arch/powerpc/cpu/mpc85xx/cpu.c index df2ab6d..ee6fac3 100644 --- a/arch/powerpc/cpu/mpc85xx/cpu.c +++ b/arch/powerpc/cpu/mpc85xx/cpu.c @@ -339,7 +339,7 @@ phys_size_t initdram(int board_type) #if defined(CONFIG_SPD_EEPROM) || defined(CONFIG_DDR_SPD) return fsl_ddr_sdram_size(); #else - return CONFIG_SYS_SDRAM_SIZE * 1024 * 1024; + return (phys_size_t)CONFIG_SYS_SDRAM_SIZE * 1024 * 1024; #endif } #else /* CONFIG_SYS_RAMBOOT */
Applied, thanks!
Andy
Andy Fleming
Mingkai Hu
