[U-Boot] [PATCH v6] cmd: usb: ignore blk, emulation devices in usb tree/info display
usb tree/info commands iterate over all usb uclass devices recursively. blk uclass child devices are created for mass storage, treating these as usb uclass devices and referencing usb config interface descriptors cause crash. To fix, ignore blk and usb_emul uclass devices(sandbox) in usb_show_info and usb_tree_graph. also avoid addition of preamble for blk uclass child devices, otherwise tree dump gets messed up.
Signed-off-by: Suneel Garapati suneelglinux@gmail.com Reviewed-by: Bin Meng bmeng.cn@gmail.com Tested-by: Bin Meng bmeng.cn@gmail.com Reviewed-by: Simon Glass sjg@chromium.org --- Changes v6: - re-write commit message with detail Changes v5: - add usb_emul to ignore list in usb_show_info - modify description Changes v4: - do not set preamble if child is block device for mass storage Changes v3: - remove 'check on parent uclass' in description Changes v2: - remove check on parent uclass Changes v1: - add separate check on blk uclass - modify description - add separate check on parent uclass as usb
cmd/usb.c | 22 +++++++++++++++++++--- 1 file changed, 19 insertions(+), 3 deletions(-)
diff --git a/cmd/usb.c b/cmd/usb.c index d95bcf5..907debe 100644 --- a/cmd/usb.c +++ b/cmd/usb.c @@ -349,6 +349,16 @@ static void usb_show_tree_graph(struct usb_device *dev, char *pre) printf(" %s", pre); #ifdef CONFIG_DM_USB has_child = device_has_active_children(dev->dev); + if (device_get_uclass_id(dev->dev) == UCLASS_MASS_STORAGE) { + struct udevice *child; + + for (device_find_first_child(dev->dev, &child); + child; + device_find_next_child(&child)) { + if (device_get_uclass_id(child) == UCLASS_BLK) + has_child = 0; + } + } #else /* check if the device has connected children */ int i; @@ -414,8 +424,12 @@ static void usb_show_tree_graph(struct usb_device *dev, char *pre)
udev = dev_get_parent_priv(child);
- /* Ignore emulators, we only want real devices */ - if (device_get_uclass_id(child) != UCLASS_USB_EMUL) { + /* + * Ignore emulators and block child devices, we only want + * real devices + */ + if ((device_get_uclass_id(child) != UCLASS_USB_EMUL) && + (device_get_uclass_id(child) != UCLASS_BLK)) { usb_show_tree_graph(udev, pre); pre[index] = 0; } @@ -605,7 +619,9 @@ static void usb_show_info(struct usb_device *udev) for (device_find_first_child(udev->dev, &child); child; device_find_next_child(&child)) { - if (device_active(child)) { + if (device_active(child) && + (device_get_uclass_id(child) != UCLASS_USB_EMUL) && + (device_get_uclass_id(child) != UCLASS_BLK)) { udev = dev_get_parent_priv(child); usb_show_info(udev); }
^^^^^^^ what's this about ? USB_EMUL devices can be enables elsewhere too, right ?
Anyway, shouldn't you rather filter for positive matches (usb uclass devices etc) , rather than filtering out a few negative matches (blk etc) which might break in the future ?
Also, sentences start with capital letter. This should be in a separate patch if it's a separate change ...
Changes v6:
Changes v5:
Changes v4:
Changes v3:
Changes v2:
Changes v1:
- if (device_get_uclass_id(dev->dev) == UCLASS_MASS_STORAGE) {
child;
has_child = 0;
* real devices
}(device_get_uclass_id(child) != UCLASS_BLK)) { usb_show_tree_graph(udev, pre); pre[index] = 0;
}(device_get_uclass_id(child) != UCLASS_BLK)) { udev = dev_get_parent_priv(child); usb_show_info(udev);
Only disabled during the tree/info dump.
usb_for_each_root_dev does that but we dont have uclass_find_first_child_device to call on UCLASS_USB like uclass_find_first_device. So, device_find_first_child and check on uclass id is performed.
Ignoring preamble and device should go together, hence cannot be separate change.
Regards, Suneel
Changes v6:
Changes v5:
Changes v4:
Changes v3:
Changes v2:
Changes v1:
child;
has_child = 0;
* real devices
-- Best regards, Marek Vasut
I don't understand this answer. Can USB_EMUL devices be enabled on any other machine than sandbox or not ? I presume it can ...
I mean, rather than doing (device_get_uclass_id(child) != UCLASS_USB_xxx && device_get_uclass_id(child) != UCLASS_USB_yyy) dump
do
(device_get_uclass_id(child) == UCLASS_USB_nnn) dump
for nnn being only the relevant USB classes for which we actually want to dump.
Does that work ?
Regards, Suneel
Changes v6:
Changes v5:
Changes v4:
Changes v3:
Changes v2:
Changes v1:
child;
has_child = 0;
* real devices
drivers/usb/emul/Kconfig - usb_emul depends on sandbox. I dont see any machine config using it. I believe USB_EMUL devices were being ignored before this patch, not sure if the expectation has changed now. Anyway, with the change to call only usb_xxx classes this should go away in description.
do
Does that work ?
May work, I will test and send v7
Regards, Suneel
Regards, Suneel
Changes v6:
Changes v5:
Changes v4:
Changes v3:
Changes v2:
Changes v1:
child;
has_child = 0;
* real devices
Hi Marek,
No, it cannot.
do
Does that work ?
No, I don't think you can enumerate all USB devices here. It can be any uclass device.
[snip]
Regards, Bin
On 10/19/2017 10:37 AM, Bin Meng wrote:
Hi Marek,
No, it cannot.
Why ? Because of the Kconfig thing ? That can easily change and then this breaks ...
do
Does that work ?
And only the blk one breaks things ?
[snip]
Regards, Bin
Hi Marek,
Hi Marek,
No, it cannot.
Yes, it's currently on on Sandbox. But whether it's on Sandbox or not does not matter. These devices are should be filtered out as they are not supposed to be on the USB topology.
do
Does that work ?
Yes, blk devices are not "struct usb_device" declared, as they are not USB devices. However their parent is.
Regards, Bin
On 10/19/2017 10:56 AM, Bin Meng wrote:
Hi Marek,
Hi Marek,
On 10/19/2017 03:22 AM, Suneel Garapati wrote: > usb tree/info commands iterate over all usb uclass devices > recursively. blk uclass child devices are created for mass storage, > treating these as usb uclass devices and referencing usb config > interface descriptors cause crash. To fix, ignore blk and usb_emul > uclass devices(sandbox) ^^^^^^^ what's this about ? USB_EMUL devices can be enables elsewhere too, right ?
No, it cannot.
I agree with that, I was just commenting on this "(sandbox)" in the description, which IMO is not precise.
do
Does that work ?
In which case, _that_ should be in the commit message.
Anyway, is there any chance something else will come in, ie. net device for USB ethernet devices ?
Hi Marek,
Hi Marek,
Hi Marek,
On Wed, Oct 18, 2017 at 6:39 PM, Marek Vasut marex@denx.de wrote: > On 10/19/2017 03:22 AM, Suneel Garapati wrote: >> usb tree/info commands iterate over all usb uclass devices >> recursively. blk uclass child devices are created for mass storage, >> treating these as usb uclass devices and referencing usb config >> interface descriptors cause crash. To fix, ignore blk and usb_emul >> uclass devices(sandbox) > ^^^^^^^ what's this about ? USB_EMUL devices can be > enables elsewhere too, right ? Only disabled during the tree/info dump.
No, it cannot.
> Anyway, shouldn't you rather filter for positive matches (usb uclass > devices etc) , rather than filtering out a few negative matches (blk > etc) which might break in the future ? usb_for_each_root_dev does that but we dont have uclass_find_first_child_device to call on UCLASS_USB like uclass_find_first_device. So, device_find_first_child and check on uclass id is performed.
do
Does that work ?
No problem with any USB devices that end up in the leaf node in the DM tree.
Regards, Bin
On 10/19/2017 11:52 AM, Bin Meng wrote:
Hi Marek,
Hi Marek,
Hi Marek,
On 10/19/2017 05:24 AM, Suneel Garapati wrote: > On Wed, Oct 18, 2017 at 6:39 PM, Marek Vasut marex@denx.de wrote: >> On 10/19/2017 03:22 AM, Suneel Garapati wrote: >>> usb tree/info commands iterate over all usb uclass devices >>> recursively. blk uclass child devices are created for mass storage, >>> treating these as usb uclass devices and referencing usb config >>> interface descriptors cause crash. To fix, ignore blk and usb_emul >>> uclass devices(sandbox) >> ^^^^^^^ what's this about ? USB_EMUL devices can be >> enables elsewhere too, right ? > Only disabled during the tree/info dump.
No, it cannot.
>> Anyway, shouldn't you rather filter for positive matches (usb uclass >> devices etc) , rather than filtering out a few negative matches (blk >> etc) which might break in the future ? > usb_for_each_root_dev does that but we dont have uclass_find_first_child_device > to call on UCLASS_USB like uclass_find_first_device. > So, device_find_first_child and check on uclass id is performed.
do
Does that work ?
So what triggers this issue are partitions and co. then ?
Regards, Bin
Bin Meng
Suneel Garapati
