[U-Boot] [PATCH V2] buildman: make board selector argument a regex
A common use-case is to build all boards for a particular SoC. This can be achieved by:
./tools/buildman/buildman -b mainline_dev tegra20
However, when the SoC is a member of a family of SoCs, and each SoC has a different name, it would be even more useful to build all boards for every SoC in that family. This currently isn't possible since buildman's board selection command-line arguments are compared to board definitions using pure string equality.
To enable this, compare using a regex match instead. This matches MAKEALL's handling of command-line arguments. This enables:
(all Tegra) ./tools/buildman/buildman -b mainline_dev tegra
(all Tegra) ./tools/buildman/buildman -b mainline_dev '^tegra.*$'
(all Tegra20, Tegra30 boards, but not Tegra114) ./tools/buildman/buildman -b mainline_dev 'tegra[23]'
Signed-off-by: Stephen Warren swarren@nvidia.com --- v2: Update README to mention new regex matching support. Remove -n from command-line examples in the commit description. --- tools/buildman/README | 14 ++++++++++---- tools/buildman/board.py | 12 +++++++++++- 2 files changed, 21 insertions(+), 5 deletions(-)
diff --git a/tools/buildman/README b/tools/buildman/README index f63f278..8bf907e 100644 --- a/tools/buildman/README +++ b/tools/buildman/README @@ -89,10 +89,16 @@ a few commits or boards, it will be pretty slow. As a tip, if you don't plan to use your machine for anything else, you can use -T to increase the number of threads beyond the default.
-Buildman lets you build all boards, or a subset. Specify the subset using -the board name, architecture name, SOC name, or anything else in the -boards.cfg file. So 'at91' will build all AT91 boards (arm), powerpc will -build all PowerPC boards. +Buildman lets you build all boards, or a subset. Specify the subset by passing +command-line arguments that list the desired board name, architecture name, +SOC name, or anything else in the boards.cfg file. Multiple arguments are +allowed. Each argument will be interpreted as a regular expression, so +behaviour is a superset of exact or substring matching. Examples are: + +* 'tegra20' All boards with a Tegra20 SoC +* 'tegra' All boards with any Tegra Soc (Tegra20, Tegra30, Tegra114...) +* '^tegra[23]0$' All boards with either Tegra20 or Tegra30 SoC +* 'powerpc' All PowerPC boards
Buildman does not store intermediate object files. It optionally copies the binary output into a directory when a build is successful. Size diff --git a/tools/buildman/board.py b/tools/buildman/board.py index 1d3db20..5172a47 100644 --- a/tools/buildman/board.py +++ b/tools/buildman/board.py @@ -3,6 +3,8 @@ # SPDX-License-Identifier: GPL-2.0+ #
+import re + class Board: """A particular board that we can build""" def __init__(self, status, arch, cpu, soc, vendor, board_name, target, options): @@ -135,14 +137,22 @@ class Boards: due to each argument, arranged by argument. """ result = {} + argres = {} for arg in args: result[arg] = 0 + argres[arg] = re.compile(arg) result['all'] = 0
for board in self._boards: if args: for arg in args: - if arg in board.props: + argre = argres[arg] + match = False + for prop in board.props: + match = argre.match(prop) + if match: + break + if match: if not board.build_it: board.build_it = True result[arg] += 1
On Thu, Oct 10, 2013 at 10:00 AM, Stephen Warren swarren@wwwdotorg.org wrote:
Nice README, thanks.
Applied to u-boot-x86 branch buildpatman, thank you.
Stephen Warren
