[U-Boot] [Fwd: Kernel bring Up fail in NOR boot for custom board]
Dear Scott Wood,
1. Board Bring Up(u-boot and kernel) in Nand Flash With the setting of cpu = 533MHz,ddr = 533MHz and lbc = 66.66MHz. we can able to make u-boot up and kernel with all drivers modules are up and prompt is appeared.
2. Board Bring Up(u-boot and kernel) in Nor Flash With the setting of cpu = 533MHz,ddr = 533MHz and lbc = 16.66MHz. we can able to make u-boot up and kernel is not up. i.e, the drivers in kernel are unevenly initialized and getting into kernel panic state. I have attached the file that shows above mentioned behavio1 please find the attachments.
If the cpu frequency is reduced to 266Mhz and DDR with 533.33MHz. kernel initialize further but result is same as above(kernel panic).
NOTE: we have observed that if same kernel image is put in the Reference Design Board(P1021RDB-PC) it is working fine.
From u-boot we have tried changing OR & BR values along with LAW and
TLB values..Are we missing something??
As our Deveopment is stuck please reply ASAP
Regards
Shrimanth
