Revert "ARM: socfpga: Remove socfpga_sdram_apply_static_cfg()
This reverts commit c5f4b805755912a3d2fe20f014b6b6ab0473bd73.
Conflicts: arch/arm/mach-socfpga/misc_gen5.c
Without socfpga_sdram_apply_static_cfg(), the system hangs when Linux calls altvipfb2_start_hw() of the Intel Video and Image Processing(VIP) Frame Buffer II driver (drivers/video/fbdev/altvipfb2.c), but only after a power cycle (cold boot). The issue does not show up after a soft reset (warm boot) and with v2018.11.
Signed-off-by: Wolfgang Grandegger wg@aries-embedded.de CC: Marek Vasut marex@denx.de CC: Simon Goldschmidt simon.k.r.goldschmidt@gmail.com --- arch/arm/mach-socfpga/misc_gen5.c | 31 +++++++++++++++++++++++++++++++ 1 file changed, 31 insertions(+)
diff --git a/arch/arm/mach-socfpga/misc_gen5.c b/arch/arm/mach-socfpga/misc_gen5.c index 7209e8d..c1ecd92 100644 --- a/arch/arm/mach-socfpga/misc_gen5.c +++ b/arch/arm/mach-socfpga/misc_gen5.c @@ -216,6 +216,35 @@ int arch_early_init_r(void) static struct socfpga_sdr_ctrl *sdr_ctrl = (struct socfpga_sdr_ctrl *)SDR_CTRLGRP_ADDRESS;
+static void socfpga_sdram_apply_static_cfg(void) +{ + const u32 applymask = 0x8; + u32 val = readl(&sdr_ctrl->static_cfg) | applymask; + + /* + * SDRAM staticcfg register specific: + * When applying the register setting, the CPU must not access + * SDRAM. Luckily for us, we can abuse i-cache here to help us + * circumvent the SDRAM access issue. The idea is to make sure + * that the code is in one full i-cache line by branching past + * it and back. Once it is in the i-cache, we execute the core + * of the code and apply the register settings. + * + * The code below uses 7 instructions, while the Cortex-A9 has + * 32-byte cachelines, thus the limit is 8 instructions total. + */ + asm volatile( + ".align 5 \n" + " b 2f \n" + "1: str %0, [%1] \n" + " dsb \n" + " isb \n" + " b 3f \n" + "2: b 1b \n" + "3: nop \n" + : : "r"(val), "r"(&sdr_ctrl->static_cfg) : "memory", "cc"); +} + void do_bridge_reset(int enable, unsigned int mask) { int i; @@ -233,6 +262,7 @@ void do_bridge_reset(int enable, unsigned int mask) writel(iswgrp_handoff[2], socfpga_get_sysmgr_addr() + SYSMGR_GEN5_FPGAINFGRP_MODULE); + socfpga_sdram_apply_static_cfg(); writel(iswgrp_handoff[3], &sdr_ctrl->fpgaport_rst); writel(iswgrp_handoff[0], socfpga_get_rstmgr_addr() + RSTMGR_GEN5_BRGMODRST); @@ -245,6 +275,7 @@ void do_bridge_reset(int enable, unsigned int mask) writel(0, socfpga_get_sysmgr_addr() + SYSMGR_GEN5_FPGAINFGRP_MODULE); writel(0, &sdr_ctrl->fpgaport_rst); + socfpga_sdram_apply_static_cfg(); writel(0x7, socfpga_get_rstmgr_addr() + RSTMGR_GEN5_BRGMODRST); writel(1, &nic301_regs->remap); }
There is no such driver in mainline U-Boot or Linux.
See the commit message of the patch this is reverting, I believe there is a deeper issue with the static config register. Can you investigate?
Am 06.08.20 um 13:04 schrieb Marek Vasut:
It's a simple frame buffer driver from linux-socfpga for the IP core Intel Video and Image Processing(VIP) Frame Buffer II. It actually hangs here when the streaming starts:
https://github.com/altera-opensource/linux-socfpga/blob/socfpga-5.4.44-lts/d...
I can also hang the system if I setup and start the FB with just a few U-Boot commands. I think the system hangs when the IP core starts reading the FB data from the system memory.
I read the commit message, but well, I can't follow all the details :(. On the other hand, it seems also not clear why the fix was added. Any idea what to investigate.
Wolfgang
I am CCing Dinh , I recall there was some discussion about hangs on CycloneV and it was fixed recently.
The system was repeatedly rebooted in a loop, the FPGA was loaded before Linux booted. After hundreds of reboots, the system got stuck on setting up the static cfg register. I think there was even another email exchange where the suggestion was to make this apply_static_cfg optional and only use it when the DRAM port is enabled in the quartus design. Maybe that is the way out of this ?
Am 06.08.20 um 14:50 schrieb Marek Vasut:
I rebooted Linux on my MCVEVP more than 100 times with and without loading the FPGA in U-Boot. The system never hang!
Yep.
Wolfgang
It could very well be bitstream related, wait for Simon to chime in. Do you load the bitstream in U-Boot or in Linux ?
Yep.
Am 07.08.20 um 13:12 schrieb Marek Vasut:
I load it in U-Boot. And I repeated the test more than 1000 times (100 above is a typo)! OK, let's wait for more input.
Yep.
Wolfgang
On 8/6/20 12:53 PM, Wolfgang Grandegger wrote: > This reverts commit c5f4b805755912a3d2fe20f014b6b6ab0473bd73. > > Conflicts: > arch/arm/mach-socfpga/misc_gen5.c > > Without socfpga_sdram_apply_static_cfg(), the system hangs when Linux > calls altvipfb2_start_hw() of the Intel Video and Image Processing(VIP) > Frame Buffer II driver (drivers/video/fbdev/altvipfb2.c)
> , but only > after a power cycle (cold boot). The issue does not show up after a > soft reset (warm boot) and with v2018.11.
Sorry for pushing back on this, the issue keeps coming back and until we get to the bottom of this, I don't want to see applying and reverting a patch back and forth. And getting to the real bottom of this seems to be particularly difficult task.
Does your bitstream use the DRAM bridge (F2S) ? I think it does. The one I used didn't as far as I remember. So maybe the way forward is to only apply static cfg if the bridge is enabled.
-----Original Message----- From: Marek Vasut marex@denx.de Sent: Friday, August 7, 2020 7:53 PM To: Wolfgang Grandegger wg@aries-embedded.de; U-Boot Mailing List u-boot@lists.denx.de Cc: Simon Goldschmidt simon.k.r.goldschmidt@gmail.com; Nguyen, Dinh dinh.nguyen@intel.com; Tan, Ley Foon ley.foon.tan@intel.com Subject: Re: Revert "ARM: socfpga: Remove socfpga_sdram_apply_static_cfg()
Am 06.08.20 um 13:04 schrieb Marek Vasut: > On 8/6/20 12:53 PM, Wolfgang Grandegger wrote: >> This reverts commit
>> >> Conflicts: >> arch/arm/mach-socfpga/misc_gen5.c >> >> Without socfpga_sdram_apply_static_cfg(), the system hangs when >> Linux calls altvipfb2_start_hw() of the Intel Video and Image >> Processing(VIP) Frame Buffer II driver >> (drivers/video/fbdev/altvipfb2.c) > > There is no such driver in mainline U-Boot or Linux.
https://github.com/altera-opensource/linux-socfpga/blob/socfpga-5. 4.44-lts/drivers/video/fbdev/altvipfb2.c#L69
>> , but only >> after a power cycle (cold boot). The issue does not show up >> after a soft reset (warm boot) and with v2018.11. > > See the commit message of the patch this is reverting, I believe > there is a deeper issue with the static config register. Can you
investigate?
We have another email thread before about restore back socfpga_sdram_apply_static_cfg() function. Yes, we talked about only apply static cfg bit if the F2S port is enabled. But, no final decision previously. I can re-submit the patches if you are okay with this approach.
Wolfgang, I have downstream patches for checking F2S port before apply static cfg bit. Can you try these 2 patches on your side if they solve your issue? I can't reproduce the issue on my side. https://github.com/altera-opensource/u-boot-socfpga/commit/ca64e19e40224091b... https://github.com/altera-opensource/u-boot-socfpga/commit/11ff7b9ce3abc5e61...
Regards Ley Foon
Hello Ley Foon,
Am 10.08.20 um 10:30 schrieb Tan, Ley Foon:
On 8/6/20 2:36 PM, Wolfgang Grandegger wrote: > Am 06.08.20 um 13:04 schrieb Marek Vasut: >> On 8/6/20 12:53 PM, Wolfgang Grandegger wrote: >>> This reverts commit
>>> >>> Conflicts: >>> arch/arm/mach-socfpga/misc_gen5.c >>> >>> Without socfpga_sdram_apply_static_cfg(), the system hangs when >>> Linux calls altvipfb2_start_hw() of the Intel Video and Image >>> Processing(VIP) Frame Buffer II driver >>> (drivers/video/fbdev/altvipfb2.c) >> >> There is no such driver in mainline U-Boot or Linux. > > It's a simple frame buffer driver from linux-socfpga for the IP > core Intel Video and Image Processing(VIP) Frame Buffer II. It > actually hangs here when the streaming starts: > > https://github.com/altera-opensource/linux-socfpga/blob/socfpga-5. > 4.44-lts/drivers/video/fbdev/altvipfb2.c#L69 > > I can also hang the system if I setup and start the FB with just a > few U-Boot commands. I think the system hangs when the IP core > starts reading the FB data from the system memory.
>>> , but only >>> after a power cycle (cold boot). The issue does not show up >>> after a soft reset (warm boot) and with v2018.11. >> >> See the commit message of the patch this is reverting, I believe >> there is a deeper issue with the static config register. Can you
investigate?
> > I read the commit message, but well, I can't follow all the details :(. > On the other hand, it seems also not clear why the fix was added. > Any idea what to investigate.
No, this does not fix the problem with my hardware because handoff[3] is zero:
do_bridge_reset: handoff[0..5]: 0x0 0x19 0x0 0x0 0xf 0x0
Wolfgang
CC Hean Loong:
Can you elaborate what you mean here? You are starting the Frame Buffer driver with U-Boot?
Dinh
Am 07.08.20 um 17:05 schrieb Dinh Nguyen:
CC Hean Loong:
Yes, the FPGA image provides the Intel Video and Image Processing(VIP) Frame Buffer II IP core and it is loaded with "> fpga load ..." in U-Boot before Linux starts. And yes, this IP core does use the DRAM bridge (F2S).
The systems hangs, if I start the framebuffer in U-Boot or Linux, but only after a power-cycle. It works fine after a soft-reset.
Wolfgang
Hello,
reading you question again...
Am 07.08.20 um 17:49 schrieb Wolfgang Grandegger:
CC Hean Loong:
You ask how to start the frame-buffer in U-Boot. Here are the commands:
=> fpga load 0 ${loadaddr} ${filesize} => bridge enable => mw.l 0xffc25080 0x00003fff => mw.l 0xffc2508c 0x00000000 => mw.l 0xffc25090 0x00000000 => mw.b 0xbef00000 0xff 0x5dc00 => mw.b 0xbef5dc00 0x00 0x5dc00 => mw.b 0xbefbb800 0x80 0x5dc00 => mw.l 0xff280214 0x006401e0 => mw.l 0xff280218 0xbef00000 => mw.l 0xff280200 1
It fills the framebuffer at 0xbef00000 and starts the streaming with the last command.
Wolfgang
Hi Wolfgang et al.,
Just a note that I am seeing the same problem, also on Cyclone V, but with a different IP block in the FPGA. I'm using the Altera/Intel triple speed Ethernet, which is supported by drivers/net/altera_tse.c driver.
With earlier u-boot (tested 2018.03) it worked fine. But with 2020.04 and 2020.07 the system hangs as soon as I do "ifconfig eth0 up". This only happens on cold boot; on warm reboot the eth0 port works fine.
Reverting c5f4b805755912a3d2fe20 fixes the problem.
Regards, Ralph
On 8/19/20 8:35 PM, Ralph Siemsen wrote:
Hi Wolfgang et al.,
With earlier u-boot (tested 2018.03) it worked fine. But with 2020.04 and 2020.07 the system hangs as soon as I do "ifconfig eth0 up". This only happens on cold boot; on warm reboot the eth0 port works fine. Reverting c5f4b805755912a3d2fe20 fixes the problem.
Is the F2SDRAM port enabled in your case ?
Hello,
Am 19.08.20 um 21:54 schrieb Ralph Siemsen:
Is there a way I can check this via software? Unfortunately I do not have access to Quartus/Qsys files, nor the person who did the design.
Looking to the U-Boot driver "drivers/net/altera_tse.c" tells me, that it maps system memory for the SGDMA controller in its probe function. I found the Altera SoC Triple Speed Ethernet Design Example at [1]. And yes, it seems to use F2SDRAM as well.
[1] https://rocketboards.org/foswiki/Projects/AlteraSoCTripleSpeedEthernetDesign...
Wolfgang
participants (5)
Dinh Nguyen
Ralph Siemsen
Tan, Ley Foon
Wolfgang Grandegger
