[U-Boot] [PATCH v5 1/3] power: add FAN53555 family support
This adds a driver for the FAN53555 family of regulators and wraps it in a PMIC implementation.
While these devices support a 'normal' and 'suspend' mode (controlled via an external pin) to switch between two programmable voltages, this incarnation of the driver assumes that the device is always operating in 'normal' mode.
Only setting/reading the programmed voltage is supported at this time and the following device functionality remains unsupported: - switching the selected voltage (via a GPIO) - disabling the voltage output via software-control This matches the functionality of the Linux driver.
Tested on a RK3399-Q7 (with 'option 5' devices): setting voltages from the U-Boot shell and verifying output voltages on the board.
Signed-off-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com Tested-by: Klaus Goger klaus.goger@theobroma-systems.com
Changes in v5: - introduced a PMIC (as requested by SJG) to wrap the single regulator
Changes in v4: - fix issues introduced when updating for review comments (sorry for this: my submit-branch had diverged from the WIP-branch I used for testing and I didn't notice)
Changes in v3: - update for review comments
Changes in v2: - adapted documentation on the device-tree binding from Linux
doc/device-tree-bindings/regulator/fan53555.txt | 23 +++ drivers/power/pmic/Kconfig | 14 ++ drivers/power/pmic/Makefile | 1 + drivers/power/pmic/fan53555.c | 82 +++++++++ drivers/power/regulator/Kconfig | 16 ++ drivers/power/regulator/Makefile | 1 + drivers/power/regulator/fan53555.c | 222 ++++++++++++++++++++++++ 7 files changed, 359 insertions(+) create mode 100644 doc/device-tree-bindings/regulator/fan53555.txt create mode 100644 drivers/power/pmic/fan53555.c create mode 100644 drivers/power/regulator/fan53555.c
diff --git a/doc/device-tree-bindings/regulator/fan53555.txt b/doc/device-tree-bindings/regulator/fan53555.txt new file mode 100644 index 0000000..b183738 --- /dev/null +++ b/doc/device-tree-bindings/regulator/fan53555.txt @@ -0,0 +1,23 @@ +Binding for Fairchild FAN53555 regulators + +Required properties: + - compatible: "fcs,fan53555" + - reg: I2C address + +Optional properties: + - fcs,suspend-voltage-selector: declare which of the two available + voltage selector registers should be used for the suspend + voltage. The other one is used for the runtime voltage setting + Possible values are either <0> or <1> + - vin-supply: regulator supplying the vin pin + +Example: + + regulator@40 { + compatible = "fcs,fan53555"; + regulator-name = "fan53555"; + regulator-min-microvolt = <1000000>; + regulator-max-microvolt = <1800000>; + vin-supply = <&parent_reg>; + fcs,suspend-voltage-selector = <1>; + }; diff --git a/drivers/power/pmic/Kconfig b/drivers/power/pmic/Kconfig index cba48e1..8cf60eb 100644 --- a/drivers/power/pmic/Kconfig +++ b/drivers/power/pmic/Kconfig @@ -48,6 +48,20 @@ config PMIC_AS3722 interface and is designs to cover most of the power managementment required for a tablets or laptop.
+config DM_PMIC_FAN53555 + bool "Enable support for OnSemi FAN53555" + depends on DM_PMIC && DM_REGULATOR && DM_I2C + select DM_REGULATOR_FAN53555 + help + This config enables implementation of driver-model PMIC + uclass features for the FAN53555 regulator. The FAN53555 is + a (family of) single-output regulators that supports + transitioning between two different output voltages based on + an voltage selection pin. + + The driver implements read/write operations for use with the FAN53555 + regulator driver and binds the regulator driver to its node. + config DM_PMIC_PFUZE100 bool "Enable Driver Model for PMIC PFUZE100" depends on DM_PMIC diff --git a/drivers/power/pmic/Makefile b/drivers/power/pmic/Makefile index 29ca442..637352a 100644 --- a/drivers/power/pmic/Makefile +++ b/drivers/power/pmic/Makefile @@ -4,6 +4,7 @@ # Lukasz Majewski l.majewski@samsung.com
obj-$(CONFIG_DM_PMIC) += pmic-uclass.o +obj-$(CONFIG_DM_PMIC_FAN53555) += fan53555.o obj-$(CONFIG_DM_PMIC_MAX77686) += max77686.o obj-$(CONFIG_DM_PMIC_MAX8998) += max8998.o obj-$(CONFIG_DM_PMIC_MC34708) += mc34708.o diff --git a/drivers/power/pmic/fan53555.c b/drivers/power/pmic/fan53555.c new file mode 100644 index 0000000..1ca59c5 --- /dev/null +++ b/drivers/power/pmic/fan53555.c @@ -0,0 +1,82 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * (C) 2018 Theobroma Systems Design und Consulting GmbH + */ + +#include <common.h> +#include <dm.h> +#include <dm/device-internal.h> +#include <dm/lists.h> +#include <i2c.h> +#include <power/pmic.h> +#include <power/regulator.h> + +static int pmic_fan53555_reg_count(struct udevice *dev) +{ + return 1; +}; + +static int pmic_fan53555_read(struct udevice *dev, uint reg, + u8 *buff, int len) +{ + if (dm_i2c_read(dev, reg, buff, len)) { + pr_err("%s: read error for register: %#x!", dev->name, reg); + return -EIO; + } + + return 0; +} + +static int pmic_fan53555_write(struct udevice *dev, uint reg, + const u8 *buff, int len) +{ + if (dm_i2c_write(dev, reg, buff, len)) { + pr_err("%s: write error for register: %#x!", dev->name, reg); + return -EIO; + } + + return 0; +} + +static int pmic_fan53555_bind(struct udevice *dev) +{ + /* + * The FAN53555 has only a single regulator and therefore doesn't + * have a subnode. So we have to rebind a child device (the one + * regulator) here. + */ + + const char *regulator_driver_name = "fan53555_regulator"; + struct udevice *child; + struct driver *drv; + + debug("%s\n", __func__); + + drv = lists_driver_lookup_name(regulator_driver_name); + if (!drv) { + dev_err(dev, "no driver '%s'\n", regulator_driver_name); + return -ENOENT; + } + + return device_bind_with_driver_data(dev, drv, "SW", 0, + dev_ofnode(dev), &child); +}; + +static struct dm_pmic_ops pmic_fan53555_ops = { + .reg_count = pmic_fan53555_reg_count, + .read = pmic_fan53555_read, + .write = pmic_fan53555_write, +}; + +static const struct udevice_id pmic_fan53555_match[] = { + { .compatible = "fcs,fan53555" }, + { }, +}; + +U_BOOT_DRIVER(pmic_fan53555) = { + .name = "pmic_fan53555", + .id = UCLASS_PMIC, + .of_match = pmic_fan53555_match, + .bind = pmic_fan53555_bind, + .ops = &pmic_fan53555_ops, +}; diff --git a/drivers/power/regulator/Kconfig b/drivers/power/regulator/Kconfig index 2561a8a..09b311d 100644 --- a/drivers/power/regulator/Kconfig +++ b/drivers/power/regulator/Kconfig @@ -69,6 +69,22 @@ config DM_REGULATOR_MAX77686 features for REGULATOR MAX77686. The driver implements get/set api for: value, enable and mode.
+config DM_REGULATOR_FAN53555 + bool "Enable Driver Model for REGULATOR FAN53555" + depends on DM_PMIC_FAN53555 + help + This config enables implementation of driver-model regulator + uclass features for the FAN53555 regulator. The FAN53555 is + a (family of) single-output regulators that supports + transitioning between two different output voltages based on + an voltage selection pin. + + The driver implements a get/set api for the voltage of the + 'normal mode' voltage only. Switching to 'suspend mode' + (i.e. the alternate voltage), disabling output via software, + or switching the mode is not supported by this driver (at + this time). + config DM_REGULATOR_FIXED bool "Enable Driver Model for REGULATOR Fixed value" depends on DM_REGULATOR diff --git a/drivers/power/regulator/Makefile b/drivers/power/regulator/Makefile index a5f5683..8017045 100644 --- a/drivers/power/regulator/Makefile +++ b/drivers/power/regulator/Makefile @@ -10,6 +10,7 @@ obj-$(CONFIG_REGULATOR_AS3722) += as3722_regulator.o obj-$(CONFIG_DM_REGULATOR_MAX77686) += max77686.o obj-$(CONFIG_$(SPL_)DM_PMIC_PFUZE100) += pfuze100.o obj-$(CONFIG_REGULATOR_PWM) += pwm_regulator.o +obj-$(CONFIG_$(SPL_)DM_REGULATOR_FAN53555) += fan53555.o obj-$(CONFIG_$(SPL_)DM_REGULATOR_FIXED) += fixed.o obj-$(CONFIG_$(SPL_)DM_REGULATOR_GPIO) += gpio-regulator.o obj-$(CONFIG_REGULATOR_RK8XX) += rk8xx.o diff --git a/drivers/power/regulator/fan53555.c b/drivers/power/regulator/fan53555.c new file mode 100644 index 0000000..dbd5502 --- /dev/null +++ b/drivers/power/regulator/fan53555.c @@ -0,0 +1,222 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * (C) 2018 Theobroma Systems Design und Consulting GmbH + */ + +#include <common.h> +#include <bitfield.h> +#include <errno.h> +#include <dm.h> +#include <fdtdec.h> +#include <i2c.h> +#include <asm/gpio.h> +#include <power/pmic.h> +#include <power/regulator.h> + +/** + * struct ic_types - definition of fan53555-family devices + * + * @die_id: Identifies the DIE_ID (lower nibble of the ID1 register) + * @die_rev: Identifies the DIE_REV (lower nibble of the ID2 register) + * @vsel_min: starting voltage (step 0) in uV + * @vsel_step: increment of the voltage in uV + * + * The voltage ramp (i.e. minimum voltage and step) is selected from the + * combination of 2 nibbles: DIE_ID and DIE_REV. + * + * See http://www.onsemi.com/pub/Collateral/FAN53555-D.pdf for details. + */ +static const struct { + u8 die_id; + u8 die_rev; + u32 vsel_min; + u32 vsel_step; +} ic_types[] = { + { 0x0, 0x3, 600000, 10000 }, /* Option 00 */ + { 0x0, 0xf, 800000, 10000 }, /* Option 13 */ + { 0x0, 0xc, 600000, 12500 }, /* Option 23 */ + { 0x1, 0x3, 600000, 10000 }, /* Option 01 */ + { 0x3, 0x3, 600000, 10000 }, /* Option 03 */ + { 0x4, 0xf, 603000, 12826 }, /* Option 04 */ + { 0x5, 0x3, 600000, 10000 }, /* Option 05 */ + { 0x8, 0x1, 600000, 10000 }, /* Option 08 */ + { 0x8, 0xf, 600000, 10000 }, /* Option 08 */ + { 0xc, 0xf, 603000, 12826 }, /* Option 09 */ +}; + +/* I2C-accessible byte-sized registers */ +enum { + /* Voltage setting */ + FAN53555_VSEL0 = 0x00, + FAN53555_VSEL1, + /* Control register */ + FAN53555_CONTROL, + /* IC Type */ + FAN53555_ID1, + /* IC mask version */ + FAN53555_ID2, + /* Monitor register */ + FAN53555_MONITOR, +}; + +struct fan53555_platdata { + /* Voltage setting register */ + unsigned int vol_reg; + unsigned int sleep_reg; + +}; + +struct fan53555_priv { + /* IC Vendor */ + unsigned int vendor; + /* IC Type and Rev */ + unsigned int die_id; + unsigned int die_rev; + /* Voltage range and step(linear) */ + unsigned int vsel_min; + unsigned int vsel_step; + /* Voltage slew rate limiting */ + unsigned int slew_rate; + /* Sleep voltage cache */ + unsigned int sleep_vol_cache; +}; + +static int fan53555_regulator_ofdata_to_platdata(struct udevice *dev) +{ + struct fan53555_platdata *dev_pdata = dev_get_platdata(dev); + struct dm_regulator_uclass_platdata *uc_pdata = + dev_get_uclass_platdata(dev); + u32 sleep_vsel; + + /* This is a buck regulator */ + uc_pdata->type = REGULATOR_TYPE_BUCK; + + sleep_vsel = dev_read_u32_default(dev, "fcs,suspend-voltage-selector", + FAN53555_VSEL1); + + /* + * Depending on the device-tree settings, the 'normal mode' + * voltage is either controlled by VSEL0 or VSEL1. + */ + switch (sleep_vsel) { + case FAN53555_VSEL0: + dev_pdata->sleep_reg = FAN53555_VSEL0; + dev_pdata->vol_reg = FAN53555_VSEL1; + break; + case FAN53555_VSEL1: + dev_pdata->sleep_reg = FAN53555_VSEL1; + dev_pdata->vol_reg = FAN53555_VSEL0; + break; + default: + pr_err("%s: invalid vsel id %d\n", dev->name, sleep_vsel); + return -EINVAL; + } + + return 0; +} + +static int fan53555_regulator_get_value(struct udevice *dev) +{ + struct fan53555_platdata *pdata = dev_get_platdata(dev); + struct fan53555_priv *priv = dev_get_priv(dev); + int reg; + int voltage; + + /* We only support a single voltage selector (i.e. 'normal' mode). */ + reg = pmic_reg_read(dev->parent, pdata->vol_reg); + if (reg < 0) + return reg; + voltage = priv->vsel_min + (reg & 0x3f) * priv->vsel_step; + + debug("%s: %d uV\n", __func__, voltage); + return voltage; +} + +static int fan53555_regulator_set_value(struct udevice *dev, int uV) +{ + struct fan53555_platdata *pdata = dev_get_platdata(dev); + struct fan53555_priv *priv = dev_get_priv(dev); + u8 vol; + + vol = (uV - priv->vsel_min) / priv->vsel_step; + debug("%s: uV=%d; writing volume %d: %02x\n", + __func__, uV, pdata->vol_reg, vol); + + return pmic_clrsetbits(dev, pdata->vol_reg, GENMASK(6, 0), vol); +} + +static int fan53555_voltages_setup(struct udevice *dev) +{ + struct fan53555_priv *priv = dev_get_priv(dev); + int i; + + /* Init voltage range and step */ + for (i = 0; i < ARRAY_SIZE(ic_types); ++i) { + if (ic_types[i].die_id != priv->die_id) + continue; + + if (ic_types[i].die_rev != priv->die_rev) + continue; + + priv->vsel_min = ic_types[i].vsel_min; + priv->vsel_step = ic_types[i].vsel_step; + + return 0; + } + + pr_err("%s: %s: die id %d rev %d not supported!\n", + dev->name, __func__, priv->die_id, priv->die_rev); + return -EINVAL; +} + +enum { + DIE_ID_SHIFT = 0, + DIE_ID_WIDTH = 4, + DIE_REV_SHIFT = 0, + DIE_REV_WIDTH = 4, +}; + +static int fan53555_probe(struct udevice *dev) +{ + struct fan53555_priv *priv = dev_get_priv(dev); + int ID1, ID2; + + debug("%s\n", __func__); + + /* read chip ID1 and ID2 (two registers, starting at ID1) */ + ID1 = pmic_reg_read(dev->parent, FAN53555_ID1); + if (ID1 < 0) + return ID1; + + ID2 = pmic_reg_read(dev->parent, FAN53555_ID2); + if (ID2 < 0) + return ID2; + + /* extract vendor, die_id and die_rev */ + priv->vendor = bitfield_extract(ID1, 5, 3); + priv->die_id = ID1 & GENMASK(3, 0); + priv->die_rev = ID2 & GENMASK(3, 0); + + if (fan53555_voltages_setup(dev) < 0) + return -ENODATA; + + debug("%s: FAN53555 option %d rev %d detected\n", + __func__, priv->die_id, priv->die_rev); + + return 0; +} + +static const struct dm_regulator_ops fan53555_regulator_ops = { + .get_value = fan53555_regulator_get_value, + .set_value = fan53555_regulator_set_value, +}; + +U_BOOT_DRIVER(fan53555_regulator) = { + .name = "fan53555_regulator", + .id = UCLASS_REGULATOR, + .ops = &fan53555_regulator_ops, + .ofdata_to_platdata = fan53555_regulator_ofdata_to_platdata, + .platdata_auto_alloc_size = sizeof(struct fan53555_platdata), + .priv_auto_alloc_size = sizeof(struct fan53555_priv), + .probe = fan53555_probe, +};
With a driver for the FAN53555 regulator family available, let's enable it for the RK3399-Q7 (which has two of these devices on-module).
We enable this for the full U-Boot stage only, as these regulators provide a suitable default voltage and supply non-critical (i.e. for booting up) power rails only.
Signed-off-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com ---
Changes in v5: None Changes in v4: None Changes in v3: None Changes in v2: None
configs/puma-rk3399_defconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/configs/puma-rk3399_defconfig b/configs/puma-rk3399_defconfig index bec03c7..e83a616 100644 --- a/configs/puma-rk3399_defconfig +++ b/configs/puma-rk3399_defconfig @@ -77,6 +77,7 @@ CONFIG_PINCTRL=y CONFIG_SPL_PINCTRL=y CONFIG_PINCTRL_ROCKCHIP_RK3399=y CONFIG_DM_PMIC=y +CONFIG_DM_PMIC_FAN53555=y CONFIG_PMIC_RK8XX=y CONFIG_SPL_DM_REGULATOR=y CONFIG_DM_REGULATOR_FIXED=y
Applied to u-boot-rockchip, thanks!
Now that we have FAN53555 support, we can enable the regulators in our DTS. To make these easier to identify on the U-Boot commandline, we rename them to the names of the voltage rails they control.
arch/arm/dts/rk3399-puma.dtsi | 6 ++++-- 1 file changed, 4 insertions(+), 2 deletions(-)
diff --git a/arch/arm/dts/rk3399-puma.dtsi b/arch/arm/dts/rk3399-puma.dtsi index 11ffcb7..ba9bb4c 100644 --- a/arch/arm/dts/rk3399-puma.dtsi +++ b/arch/arm/dts/rk3399-puma.dtsi @@ -218,7 +218,8 @@ i2c-scl-falling-time-ns = <4>; clock-frequency = <400000>;
- vdd_gpu: fan535555@60 { + vdd_gpu: vdd_gpu { + status = "okay"; compatible = "fcs,fan53555"; reg = <0x60>; vsel-gpios = <&gpio1 RK_PB6 GPIO_ACTIVE_HIGH>; @@ -420,7 +421,8 @@ status = "okay"; clock-frequency = <400000>;
- vdd_cpu_b: fan53555@60 { + vdd_cpu_b: vdd_cpu_b { + status = "okay"; compatible = "fcs,fan53555"; reg = <0x60>; vsel-gpios = <&gpio1 RK_PA4 GPIO_ACTIVE_HIGH>;
Changes in v5:
Changes in v4:
Changes in v3:
Changes in v2:
Philipp Tomsich
