[PATCH] xilinx: Sync DTs with Linux kernel
There are several changes which happen in mainline kernel which should get also to U-Boot. Here is the list of patches from the kernel:
- ARM: zynq: Fix leds subnode name for zc702/zybo-z7 - arm64: dts: zynqmp: Fix leds subnode name for zcu100/ultra96 v1 - arm64: dts: zynqmp: Fix u48 si5382 chip on zcu111 - arm64: dts: zynqmp: Wire up the DisplayPort subsystem - arm64: dts: zynqmp: Add DisplayPort subsystem - arm64: dts: zynqmp: Add DPDMA node - arm64: dts: zynqmp: Enable phy driver for Sata on zcu102/zcu104/zcu106 - arm64: dts: zynqmp: Enable si5341 driver for zcu102/106/111 - arm64: dts: zynqmp: Add DT description for si5328 for zcu102/zcu106 - arm64: dts: zynqmp-zcu100-revC: correct interrupt flags - arm64: dts: xilinx: align GPIO hog names with dtschema - arm64: zynqmp: Add Xilinx AES node - dt: bindings: dma: xilinx: dpdma: DT bindings for Xilinx DPDMA
but also some other changes have been done. - Using only one compatible string for adxl345 on zturn - Remove Xilinx internal DP bindings - Remove USB3.0 serdes configurations - Remove SATA serdes configuration for zc1232 - Resort nvmem_firmware - Update nand compatible string - Aling power-domains property for sd0/1
arch/arm/dts/zynq-zc702.dts | 2 +- arch/arm/dts/zynq-zturn-common.dtsi | 2 +- arch/arm/dts/zynq-zybo-z7.dts | 2 +- arch/arm/dts/zynqmp-clk-ccf.dtsi | 16 +- arch/arm/dts/zynqmp-g-a2197-00-revA.dts | 3 - arch/arm/dts/zynqmp-m-a2197-01-revA.dts | 3 - arch/arm/dts/zynqmp-zc1232-revA.dts | 2 - arch/arm/dts/zynqmp-zc1751-xm015-dc1.dts | 19 +-- arch/arm/dts/zynqmp-zc1751-xm018-dc4.dts | 2 +- arch/arm/dts/zynqmp-zcu100-revC.dts | 48 ++++-- arch/arm/dts/zynqmp-zcu102-revA.dts | 106 ++++++++++---- arch/arm/dts/zynqmp-zcu104-revA.dts | 44 +++++- arch/arm/dts/zynqmp-zcu104-revC.dts | 44 +++++- arch/arm/dts/zynqmp-zcu106-revA.dts | 96 ++++++++++-- arch/arm/dts/zynqmp-zcu111-revA.dts | 78 ++++++++-- arch/arm/dts/zynqmp-zcu208-revA.dts | 58 ++++++-- arch/arm/dts/zynqmp-zcu216-revA.dts | 58 ++++++-- arch/arm/dts/zynqmp.dtsi | 154 +++++--------------- include/dt-bindings/dma/xlnx-zynqmp-dpdma.h | 16 ++ 19 files changed, 498 insertions(+), 255 deletions(-) create mode 100644 include/dt-bindings/dma/xlnx-zynqmp-dpdma.h
diff --git a/arch/arm/dts/zynq-zc702.dts b/arch/arm/dts/zynq-zc702.dts index b043d341d680..e45eba3d90b3 100644 --- a/arch/arm/dts/zynq-zc702.dts +++ b/arch/arm/dts/zynq-zc702.dts @@ -51,7 +51,7 @@ leds { compatible = "gpio-leds";
- ds23 { + led-ds23 { label = "ds23"; gpios = <&gpio0 10 0>; linux,default-trigger = "heartbeat"; diff --git a/arch/arm/dts/zynq-zturn-common.dtsi b/arch/arm/dts/zynq-zturn-common.dtsi index 1d7af02893dc..486b6fa2e1b8 100644 --- a/arch/arm/dts/zynq-zturn-common.dtsi +++ b/arch/arm/dts/zynq-zturn-common.dtsi @@ -112,7 +112,7 @@ };
accelerometer@53 { - compatible = "adi,adxl345", "adxl345", "adi,adxl34x", "adxl34x"; + compatible = "adi,adxl345"; reg = <0x53>; interrupt-parent = <&intc>; interrupts = <0x0 0x1e 0x4>; diff --git a/arch/arm/dts/zynq-zybo-z7.dts b/arch/arm/dts/zynq-zybo-z7.dts index 3f8a3bfa0ff7..116958ec97aa 100644 --- a/arch/arm/dts/zynq-zybo-z7.dts +++ b/arch/arm/dts/zynq-zybo-z7.dts @@ -31,7 +31,7 @@ gpio-leds { compatible = "gpio-leds";
- ld4 { + led-ld4 { label = "zynq-zybo-z7:green:ld4"; gpios = <&gpio0 7 GPIO_ACTIVE_HIGH>; }; diff --git a/arch/arm/dts/zynqmp-clk-ccf.dtsi b/arch/arm/dts/zynqmp-clk-ccf.dtsi index b02ef22abd20..987792e5c511 100644 --- a/arch/arm/dts/zynqmp-clk-ccf.dtsi +++ b/arch/arm/dts/zynqmp-clk-ccf.dtsi @@ -284,18 +284,16 @@ clocks = <&zynqmp_clk AMS_REF>; };
-&zynqmp_dpsub { - clocks = <&dp_aclk>, <&zynqmp_clk DP_AUDIO_REF>, <&zynqmp_clk DP_VIDEO_REF>; +&zynqmp_pcap { + clocks = <&zynqmp_clk PCAP>; };
-&xlnx_dpdma { +&zynqmp_dpdma { clocks = <&zynqmp_clk DPDMA_REF>; };
-&zynqmp_dp_snd_codec0 { - clocks = <&zynqmp_clk DP_AUDIO_REF>; -}; - -&zynqmp_pcap { - clocks = <&zynqmp_clk PCAP>; +&zynqmp_dpsub { + clocks = <&zynqmp_clk TOPSW_LSBUS>, + <&zynqmp_clk DP_AUDIO_REF>, + <&zynqmp_clk DP_VIDEO_REF>; }; diff --git a/arch/arm/dts/zynqmp-g-a2197-00-revA.dts b/arch/arm/dts/zynqmp-g-a2197-00-revA.dts index 9468dc574fd8..f94b797d1a24 100644 --- a/arch/arm/dts/zynqmp-g-a2197-00-revA.dts +++ b/arch/arm/dts/zynqmp-g-a2197-00-revA.dts @@ -88,9 +88,6 @@ reset-gpios = <&gpio 42 GPIO_ACTIVE_LOW>; /* xlnx,phy-type = <PHY_TYPE_SGMII>; */ }; -/* phy-names = "..."; - phys = <&lane0 PHY_TYPE_SGMII ... > - Note: lane0 sgmii/lane1 usb3 */ };
&gpio { diff --git a/arch/arm/dts/zynqmp-m-a2197-01-revA.dts b/arch/arm/dts/zynqmp-m-a2197-01-revA.dts index 66ea02e5be7f..19e1ebdb1d6a 100644 --- a/arch/arm/dts/zynqmp-m-a2197-01-revA.dts +++ b/arch/arm/dts/zynqmp-m-a2197-01-revA.dts @@ -118,9 +118,6 @@ reg = <0>; /* xlnx,phy-type = <PHY_TYPE_SGMII>; */ }; -/* phy-names = "..."; - phys = <&lane0 PHY_TYPE_SGMII ... > - Note: lane0 sgmii/lane1 usb3 */ };
&gpio { diff --git a/arch/arm/dts/zynqmp-zc1232-revA.dts b/arch/arm/dts/zynqmp-zc1232-revA.dts index afb3e96520b8..ef7cf0a36b21 100644 --- a/arch/arm/dts/zynqmp-zc1232-revA.dts +++ b/arch/arm/dts/zynqmp-zc1232-revA.dts @@ -78,8 +78,6 @@ ceva,p1-comwake-params = /bits/ 8 <0x06 0x14 0x08 0x0E>; ceva,p1-burst-params = /bits/ 8 <0x13 0x08 0x4A 0x06>; ceva,p1-retry-params = /bits/ 16 <0x96A4 0x3FFC>; - phy-names = "sata-phy"; - phys = <&lane0 PHY_TYPE_SATA 0 0 125000000>, <&lane1 PHY_TYPE_SATA 1 1 125000000>; };
&uart0 { diff --git a/arch/arm/dts/zynqmp-zc1751-xm015-dc1.dts b/arch/arm/dts/zynqmp-zc1751-xm015-dc1.dts index e2428ec974a3..b8c5efb6a914 100644 --- a/arch/arm/dts/zynqmp-zc1751-xm015-dc1.dts +++ b/arch/arm/dts/zynqmp-zc1751-xm015-dc1.dts @@ -175,26 +175,11 @@ dr_mode = "host"; };
-&zynqmp_dpsub { - status = "okay"; -}; - -&zynqmp_dp_snd_pcm0 { - status = "okay"; -}; - -&zynqmp_dp_snd_pcm1 { +&zynqmp_dpdma { status = "okay"; };
-&zynqmp_dp_snd_card0 { - status = "okay"; -}; - -&zynqmp_dp_snd_codec0 { +&zynqmp_dpsub { status = "okay"; };
-&xlnx_dpdma { - status = "okay"; -}; diff --git a/arch/arm/dts/zynqmp-zc1751-xm018-dc4.dts b/arch/arm/dts/zynqmp-zc1751-xm018-dc4.dts index 9b38b8b919e2..aadda179c323 100644 --- a/arch/arm/dts/zynqmp-zc1751-xm018-dc4.dts +++ b/arch/arm/dts/zynqmp-zc1751-xm018-dc4.dts @@ -119,7 +119,7 @@ status = "okay"; };
-&xlnx_dpdma { +&zynqmp_dpdma { status = "okay"; };
diff --git a/arch/arm/dts/zynqmp-zcu100-revC.dts b/arch/arm/dts/zynqmp-zcu100-revC.dts index d6c914c917f5..bbcc69c79673 100644 --- a/arch/arm/dts/zynqmp-zcu100-revC.dts +++ b/arch/arm/dts/zynqmp-zcu100-revC.dts @@ -69,27 +69,27 @@
leds { compatible = "gpio-leds"; - ds2 { + led-ds2 { label = "ds2"; gpios = <&gpio 20 GPIO_ACTIVE_HIGH>; linux,default-trigger = "heartbeat"; };
- ds3 { + led-ds3 { label = "ds3"; gpios = <&gpio 19 GPIO_ACTIVE_HIGH>; linux,default-trigger = "phy0tx"; /* WLAN tx */ default-state = "off"; };
- ds4 { + led-ds4 { label = "ds4"; gpios = <&gpio 18 GPIO_ACTIVE_HIGH>; linux,default-trigger = "phy0rx"; /* WLAN rx */ default-state = "off"; };
- ds5 { + led-ds5 { label = "ds5"; gpios = <&gpio 17 GPIO_ACTIVE_HIGH>; linux,default-trigger = "bluetooth-power"; @@ -130,6 +130,18 @@ compatible = "iio-hwmon"; io-channels = <&u35 0>, <&u35 1>, <&u35 2>, <&u35 3>; }; + + si5335a_0: clk26 { + compatible = "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <26000000>; + }; + + si5335a_1: clk27 { + compatible = "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <27000000>; + }; };
&dcc { @@ -212,7 +224,7 @@ compatible = "ti,tps65086"; reg = <0x5e>; interrupt-parent = <&gpio>; - interrupts = <77 GPIO_ACTIVE_LOW>; + interrupts = <77 IRQ_TYPE_LEVEL_LOW>; #gpio-cells = <2>; gpio-controller; }; @@ -250,6 +262,13 @@ }; };
+&psgtr { + status = "okay"; + /* usb3, dps */ + clocks = <&si5335a_0>, <&si5335a_1>; + clock-names = "ref0", "ref1"; +}; + &rtc { status = "okay"; }; @@ -281,10 +300,6 @@ }; };
-&serdes { - status = "okay"; -}; - &spi0 { /* Low Speed connector */ status = "okay"; label = "LS-SPI0"; @@ -318,8 +333,6 @@ &dwc3_0 { status = "okay"; dr_mode = "peripheral"; - phy-names = "usb3-phy"; - phys = <&lane2 PHY_TYPE_USB3 0 0 26000000>; maximum-speed = "super-speed"; };
@@ -331,8 +344,6 @@ &dwc3_1 { status = "okay"; dr_mode = "host"; - phy-names = "usb3-phy"; - phys = <&lane3 PHY_TYPE_USB3 1 0 26000000>; maximum-speed = "super-speed"; };
@@ -347,3 +358,14 @@ &ams_ps { status = "okay"; }; + +&zynqmp_dpdma { + status = "okay"; +}; + +&zynqmp_dpsub { + status = "okay"; + phy-names = "dp-phy0", "dp-phy1"; + phys = <&psgtr 1 PHY_TYPE_DP 0 1>, + <&psgtr 0 PHY_TYPE_DP 1 1>; +}; diff --git a/arch/arm/dts/zynqmp-zcu102-revA.dts b/arch/arm/dts/zynqmp-zcu102-revA.dts index ed036e68f5e3..9323b8d64d56 100644 --- a/arch/arm/dts/zynqmp-zcu102-revA.dts +++ b/arch/arm/dts/zynqmp-zcu102-revA.dts @@ -137,6 +137,19 @@ compatible = "iio-hwmon"; io-channels = <&u75 0>, <&u75 1>, <&u75 2>, <&u75 3>; }; + + /* 48MHz reference crystal */ + ref48: ref48M { + compatible = "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <48000000>; + }; + + refhdmi: refhdmi { + compatible = "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <114285000>; + }; };
&can1 { @@ -213,25 +226,25 @@ gpio-line-names = "PS_GTR_LAN_SEL0", "PS_GTR_LAN_SEL1", "PS_GTR_LAN_SEL2", "PS_GTR_LAN_SEL3", "PCI_CLK_DIR_SEL", "IIC_MUX_RESET_B", "GEM3_EXP_RESET_B", "", "", "", "", "", "", "", "", ""; - gtr-sel0 { + gtr-sel0-hog { gpio-hog; gpios = <0 0>; output-low; /* PCIE = 0, DP = 1 */ line-name = "sel0"; }; - gtr-sel1 { + gtr-sel1-hog { gpio-hog; gpios = <1 0>; output-high; /* PCIE = 0, DP = 1 */ line-name = "sel1"; }; - gtr-sel2 { + gtr-sel2-hog { gpio-hog; gpios = <2 0>; output-high; /* PCIE = 0, USB0 = 1 */ line-name = "sel2"; }; - gtr-sel3 { + gtr-sel3-hog { gpio-hog; gpios = <3 0>; output-high; /* PCIE = 0, SATA = 1 */ @@ -494,8 +507,54 @@ si5341: clock-generator@36 { /* SI5341 - u69 */ compatible = "silabs,si5341"; reg = <0x36>; + #clock-cells = <2>; + #address-cells = <1>; + #size-cells = <0>; + clocks = <&ref48>; + clock-names = "xtal"; + clock-output-names = "si5341"; + + si5341_0: out@0 { + /* refclk0 for PS-GT, used for DP */ + reg = <0>; + always-on; + }; + si5341_2: out@2 { + /* refclk2 for PS-GT, used for USB3 */ + reg = <2>; + always-on; + }; + si5341_3: out@3 { + /* refclk3 for PS-GT, used for SATA */ + reg = <3>; + always-on; + }; + si5341_4: out@4 { + /* refclk4 for PS-GT, used for PCIE slot */ + reg = <4>; + always-on; + }; + si5341_5: out@5 { + /* refclk5 for PS-GT, used for PCIE */ + reg = <5>; + always-on; + }; + si5341_6: out@6 { + /* refclk6 PL CLK125 */ + reg = <6>; + always-on; + }; + si5341_7: out@7 { + /* refclk7 PL CLK74 */ + reg = <7>; + always-on; + }; + si5341_9: out@9 { + /* refclk9 used for PS_REF_CLK 33.3 MHz */ + reg = <9>; + always-on; + }; }; - }; i2c@2 { #address-cells = <1>; @@ -603,6 +662,13 @@ status = "okay"; };
+&psgtr { + status = "okay"; + /* pcie, sata, usb3, dp */ + clocks = <&si5341 0 5>, <&si5341 0 3>, <&si5341 0 2>, <&si5341 0 0>; + clock-names = "ref0", "ref1", "ref2", "ref3"; +}; + &qspi { status = "okay"; is-dual = <1>; @@ -649,7 +715,7 @@ ceva,p1-burst-params = /bits/ 8 <0x13 0x08 0x4A 0x06>; ceva,p1-retry-params = /bits/ 16 <0x96A4 0x3FFC>; phy-names = "sata-phy"; - phys = <&lane3 PHY_TYPE_SATA 1 1 125000000>; + phys = <&psgtr 3 PHY_TYPE_SATA 1 1>; };
/* SD1 with level shifter */ @@ -663,10 +729,6 @@ xlnx,mio-bank = <1>; };
-&serdes { - status = "okay"; -}; - &uart0 { status = "okay"; }; @@ -684,8 +746,6 @@ status = "okay"; dr_mode = "host"; snps,usb3_lpm_capable; - phy-names = "usb3-phy"; - phys = <&lane2 PHY_TYPE_USB3 0 2 26000000>; maximum-speed = "super-speed"; };
@@ -705,26 +765,12 @@ status = "okay"; };
-&zynqmp_dpsub { +&zynqmp_dpdma { status = "okay"; };
-&zynqmp_dp_snd_codec0 { - status = "okay"; -}; - -&zynqmp_dp_snd_pcm0 { - status = "okay"; -}; - -&zynqmp_dp_snd_pcm1 { - status = "okay"; -}; - -&zynqmp_dp_snd_card0 { - status = "okay"; -}; - -&xlnx_dpdma { +&zynqmp_dpsub { status = "okay"; + phy-names = "dp-phy0"; + phys = <&psgtr 1 PHY_TYPE_DP 0 3>; }; diff --git a/arch/arm/dts/zynqmp-zcu104-revA.dts b/arch/arm/dts/zynqmp-zcu104-revA.dts index cb8ffdff9771..a95bd4922a62 100644 --- a/arch/arm/dts/zynqmp-zcu104-revA.dts +++ b/arch/arm/dts/zynqmp-zcu104-revA.dts @@ -40,6 +40,24 @@ device_type = "memory"; reg = <0x0 0x0 0x0 0x80000000>; }; + + clock_8t49n287_5: clk125 { + compatible = "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <125000000>; + }; + + clock_8t49n287_2: clk26 { + compatible = "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <26000000>; + }; + + clock_8t49n287_3: clk27 { + compatible = "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <27000000>; + }; };
&can1 { @@ -226,6 +244,13 @@ }; };
+&psgtr { + status = "okay"; + /* nc, sata, usb3, dp */ + clocks = <&clock_8t49n287_5>, <&clock_8t49n287_2>, <&clock_8t49n287_3>; + clock-names = "ref1", "ref2", "ref3"; +}; + &rtc { status = "okay"; }; @@ -242,7 +267,7 @@ ceva,p1-burst-params = /bits/ 8 <0x13 0x08 0x4A 0x06>; ceva,p1-retry-params = /bits/ 16 <0x96A4 0x3FFC>; phy-names = "sata-phy"; - phys = <&lane3 PHY_TYPE_SATA 1 1 125000000>; + phys = <&psgtr 3 PHY_TYPE_SATA 1 1>; };
/* SD1 with level shifter */ @@ -253,10 +278,6 @@ disable-wp; };
-&serdes { - status = "okay"; -}; - &uart0 { status = "okay"; }; @@ -274,8 +295,6 @@ status = "okay"; dr_mode = "host"; snps,usb3_lpm_capable; - phy-names = "usb3-phy"; - phys = <&lane2 PHY_TYPE_USB3 0 2 26000000>; maximum-speed = "super-speed"; };
@@ -294,3 +313,14 @@ &ams_pl { status = "okay"; }; + +&zynqmp_dpdma { + status = "okay"; +}; + +&zynqmp_dpsub { + status = "okay"; + phy-names = "dp-phy0", "dp-phy1"; + phys = <&psgtr 1 PHY_TYPE_DP 0 3>, + <&psgtr 0 PHY_TYPE_DP 1 3>; +}; diff --git a/arch/arm/dts/zynqmp-zcu104-revC.dts b/arch/arm/dts/zynqmp-zcu104-revC.dts index e203280f0eca..8f30a2883e27 100644 --- a/arch/arm/dts/zynqmp-zcu104-revC.dts +++ b/arch/arm/dts/zynqmp-zcu104-revC.dts @@ -46,6 +46,24 @@ compatible = "iio-hwmon"; io-channels = <&u183 0>, <&u183 1>, <&u183 2>, <&u183 3>; }; + + clock_8t49n287_5: clk125 { + compatible = "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <125000000>; + }; + + clock_8t49n287_2: clk26 { + compatible = "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <26000000>; + }; + + clock_8t49n287_3: clk27 { + compatible = "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <27000000>; + }; };
&can1 { @@ -243,6 +261,13 @@ status = "okay"; };
+&psgtr { + status = "okay"; + /* nc, sata, usb3, dp */ + clocks = <&clock_8t49n287_5>, <&clock_8t49n287_2>, <&clock_8t49n287_3>; + clock-names = "ref1", "ref2", "ref3"; +}; + &sata { status = "okay"; /* SATA OOB timing settings */ @@ -255,7 +280,7 @@ ceva,p1-burst-params = /bits/ 8 <0x13 0x08 0x4A 0x06>; ceva,p1-retry-params = /bits/ 16 <0x96A4 0x3FFC>; phy-names = "sata-phy"; - phys = <&lane3 PHY_TYPE_SATA 1 1 125000000>; + phys = <&psgtr 3 PHY_TYPE_SATA 1 1>; };
/* SD1 with level shifter */ @@ -266,10 +291,6 @@ disable-wp; };
-&serdes { - status = "okay"; -}; - &uart0 { status = "okay"; }; @@ -287,8 +308,6 @@ status = "okay"; dr_mode = "host"; snps,usb3_lpm_capable; - phy-names = "usb3-phy"; - phys = <&lane2 PHY_TYPE_USB3 0 2 26000000>; maximum-speed = "super-speed"; };
@@ -307,3 +326,14 @@ &ams_pl { status = "okay"; }; + +&zynqmp_dpdma { + status = "okay"; +}; + +&zynqmp_dpsub { + status = "okay"; + phy-names = "dp-phy0", "dp-phy1"; + phys = <&psgtr 1 PHY_TYPE_DP 0 3>, + <&psgtr 0 PHY_TYPE_DP 1 3>; +}; diff --git a/arch/arm/dts/zynqmp-zcu106-revA.dts b/arch/arm/dts/zynqmp-zcu106-revA.dts index 1dff845ceeb6..971f76f1cabe 100644 --- a/arch/arm/dts/zynqmp-zcu106-revA.dts +++ b/arch/arm/dts/zynqmp-zcu106-revA.dts @@ -137,6 +137,19 @@ compatible = "iio-hwmon"; io-channels = <&u75 0>, <&u75 1>, <&u75 2>, <&u75 3>; }; + + /* 48MHz reference crystal */ + ref48: ref48M { + compatible = "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <48000000>; + }; + + refhdmi: refhdmi { + compatible = "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <114285000>; + }; };
&can1 { @@ -147,6 +160,18 @@ status = "okay"; };
+&zynqmp_dpdma { + status = "okay"; +}; + +&zynqmp_dpsub { + status = "okay"; + phy-names = "dp-phy0", "dp-phy1"; + phys = <&psgtr 1 PHY_TYPE_DP 0 3>, + <&psgtr 0 PHY_TYPE_DP 1 3>; +}; + +/* fpd_dma clk 667MHz, lpd_dma 500MHz */ &fpd_dma_chan1 { status = "okay"; }; @@ -490,8 +515,45 @@ #size-cells = <0>; reg = <1>; si5341: clock-generator@36 { /* SI5341 - u69 */ - compatible = "si5341"; + compatible = "silabs,si5341"; reg = <0x36>; + #clock-cells = <2>; + #address-cells = <1>; + #size-cells = <0>; + clocks = <&ref48>; + clock-names = "xtal"; + clock-output-names = "si5341"; + + si5341_0: out@0 { + /* refclk0 for PS-GT, used for DP */ + reg = <0>; + always-on; + }; + si5341_2: out@2 { + /* refclk2 for PS-GT, used for USB3 */ + reg = <2>; + always-on; + }; + si5341_3: out@3 { + /* refclk3 for PS-GT, used for SATA */ + reg = <3>; + always-on; + }; + si5341_6: out@6 { + /* refclk6 PL CLK125 */ + reg = <6>; + always-on; + }; + si5341_7: out@7 { + /* refclk7 PL CLK74 */ + reg = <7>; + always-on; + }; + si5341_9: out@9 { + /* refclk9 used for PS_REF_CLK 33.3 MHz */ + reg = <9>; + always-on; + }; };
}; @@ -528,8 +590,23 @@ #size-cells = <0>; reg = <4>; si5328: clock-generator@69 {/* SI5328 - u20 */ - compatible = "silabs,si5328"; reg = <0x69>; + /* + * Chip has interrupt present connected to PL + * interrupt-parent = <&>; + * interrupts = <>; + */ + #address-cells = <1>; + #size-cells = <0>; + #clock-cells = <1>; + clocks = <&refhdmi>; + clock-names = "xtal"; + clock-output-names = "si5328"; + + si5328_clk: clk0@0 { + reg = <0>; + clock-frequency = <27000000>; + }; }; }; i2c@5 { @@ -601,6 +678,13 @@ }; };
+&psgtr { + status = "okay"; + /* nc, sata, usb3, dp */ + clocks = <&si5341 0 3>, <&si5341 0 2>, <&si5341 0 0>; + clock-names = "ref1", "ref2", "ref3"; +}; + &qspi { status = "okay"; is-dual = <1>; @@ -647,7 +731,7 @@ ceva,p1-burst-params = /bits/ 8 <0x13 0x08 0x4A 0x06>; ceva,p1-retry-params = /bits/ 16 <0x96A4 0x3FFC>; phy-names = "sata-phy"; - phys = <&lane3 PHY_TYPE_SATA 1 1 125000000>; + phys = <&psgtr 3 PHY_TYPE_SATA 1 1>; };
/* SD1 with level shifter */ @@ -660,10 +744,6 @@ xlnx,mio-bank = <1>; };
-&serdes { - status = "okay"; -}; - &uart0 { status = "okay"; }; @@ -681,8 +761,6 @@ status = "okay"; dr_mode = "host"; snps,usb3_lpm_capable; - phy-names = "usb3-phy"; - phys = <&lane2 PHY_TYPE_USB3 0 2 26000000>; };
&watchdog0 { diff --git a/arch/arm/dts/zynqmp-zcu111-revA.dts b/arch/arm/dts/zynqmp-zcu111-revA.dts index 82e6c8d3cdfd..9e47008542ae 100644 --- a/arch/arm/dts/zynqmp-zcu111-revA.dts +++ b/arch/arm/dts/zynqmp-zcu111-revA.dts @@ -121,6 +121,13 @@ compatible = "iio-hwmon"; io-channels = <&u79 0>, <&u79 1>, <&u79 2>, <&u79 3>; }; + + /* 48MHz reference crystal */ + ref48: ref48M { + compatible = "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <48000000>; + }; };
&dcc { @@ -386,10 +393,46 @@ #size-cells = <0>; reg = <1>; si5341: clock-generator@36 { /* SI5341 - u46 */ - compatible = "si5341"; + compatible = "silabs,si5341"; reg = <0x36>; + #clock-cells = <2>; + #address-cells = <1>; + #size-cells = <0>; + clocks = <&ref48>; + clock-names = "xtal"; + clock-output-names = "si5341"; + + si5341_0: out@0 { + /* refclk0 for PS-GT, used for DP */ + reg = <0>; + always-on; + }; + si5341_2: out@2 { + /* refclk2 for PS-GT, used for USB3 */ + reg = <2>; + always-on; + }; + si5341_3: out@3 { + /* refclk3 for PS-GT, used for SATA */ + reg = <3>; + always-on; + }; + si5341_5: out@5 { + /* refclk5 PL CLK100 */ + reg = <5>; + always-on; + }; + si5341_6: out@6 { + /* refclk6 PL CLK125 */ + reg = <6>; + always-on; + }; + si5341_9: out@9 { + /* refclk9 used for PS_REF_CLK 33.3 MHz */ + reg = <9>; + always-on; + }; }; - }; i2c@2 { #address-cells = <1>; @@ -423,8 +466,8 @@ #address-cells = <1>; #size-cells = <0>; reg = <4>; - si5328: clock-generator@69 { /* SI5328 - u48 */ - compatible = "silabs,si5328"; + si5382: clock-generator@69 { /* SI5382 - u48 */ + compatible = "silabs,si5382"; reg = <0x69>; }; }; @@ -511,6 +554,13 @@ }; };
+&psgtr { + status = "okay"; + /* nc, sata, usb3, dp */ + clocks = <&si5341 0 3>, <&si5341 0 2>, <&si5341 0 0>; + clock-names = "ref1", "ref2", "ref3"; +}; + &qspi { status = "okay"; is-dual = <1>; @@ -557,7 +607,7 @@ ceva,p1-burst-params = /bits/ 8 <0x13 0x08 0x4A 0x06>; ceva,p1-retry-params = /bits/ 16 <0x96A4 0x3FFC>; phy-names = "sata-phy"; - phys = <&lane3 PHY_TYPE_SATA 1 3 125000000>; + phys = <&psgtr 3 PHY_TYPE_SATA 1 1>; };
/* SD1 with level shifter */ @@ -571,10 +621,6 @@ xlnx,mio-bank = <1>; };
-&serdes { - status = "okay"; -}; - &uart0 { status = "okay"; }; @@ -582,12 +628,16 @@ /* ULPI SMSC USB3320 */ &usb0 { status = "okay"; + dr_mode = "host"; };
-&dwc3_0 { +&zynqmp_dpdma { status = "okay"; - dr_mode = "host"; - snps,usb3_lpm_capable; - phy-names = "usb3-phy"; - phys = <&lane2 PHY_TYPE_USB3 0 2 26000000>; +}; + +&zynqmp_dpsub { + status = "okay"; + phy-names = "dp-phy0", "dp-phy1"; + phys = <&psgtr 1 PHY_TYPE_DP 0 1>, + <&psgtr 0 PHY_TYPE_DP 1 1>; }; diff --git a/arch/arm/dts/zynqmp-zcu208-revA.dts b/arch/arm/dts/zynqmp-zcu208-revA.dts index 268e368b7657..0e114cdacb1a 100644 --- a/arch/arm/dts/zynqmp-zcu208-revA.dts +++ b/arch/arm/dts/zynqmp-zcu208-revA.dts @@ -120,6 +120,13 @@ compatible = "iio-hwmon"; io-channels = <&dac_avcc 0>, <&dac_avcc 1>, <&dac_avcc 2>, <&dac_avcc 3>; }; + + /* 48MHz reference crystal */ + ref48: ref48M { + compatible = "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <48000000>; + }; };
&dcc { @@ -404,10 +411,41 @@ #size-cells = <0>; reg = <1>; si5341: clock-generator@36 { /* SI5341 - u43 */ - compatible = "si5341"; + compatible = "silabs,si5341"; reg = <0x36>; + #clock-cells = <2>; + #address-cells = <1>; + #size-cells = <0>; + clocks = <&ref48>; + clock-names = "xtal"; + clock-output-names = "si5341"; + + si5341_2: out@2 { + /* refclk2 for PS-GT, used for USB3 */ + reg = <2>; + always-on; /* assigned-clocks does not enable, so do it here */ + }; + si5341_3: out@3 { + /* refclk3 for PS-GT, used for SATA */ + reg = <3>; + always-on; /* assigned-clocks does not enable, so do it here */ + }; + si5341_5: out@5 { + /* refclk5 PL CLK100 */ + reg = <5>; + always-on; /* assigned-clocks does not enable, so do it here */ + }; + si5341_6: out@6 { + /* refclk6 PL CLK125 */ + reg = <6>; + always-on; /* assigned-clocks does not enable, so do it here */ + }; + si5341_9: out@9 { + /* refclk9 used for PS_REF_CLK 33.3 MHz */ + reg = <9>; + always-on; /* assigned-clocks does not enable, so do it here */ + }; }; - }; i2c_si570_user_c0: i2c@2 { #address-cells = <1>; @@ -541,6 +579,13 @@ }; };
+&psgtr { + status = "okay"; + /* pcie, sata, usb3, dp */ + clocks = <&si5341 0 5>, <&si5341 0 3>, <&si5341 0 2>, <&si5341 0 0>; + clock-names = "ref0", "ref1", "ref2", "ref3"; +}; + &rtc { status = "okay"; }; @@ -556,8 +601,7 @@ ceva,p1-comwake-params = /bits/ 8 <0x06 0x14 0x08 0x0E>; ceva,p1-burst-params = /bits/ 8 <0x13 0x08 0x4A 0x06>; ceva,p1-retry-params = /bits/ 16 <0x96A4 0x3FFC>; - phy-names = "sata-phy"; - phys = <&lane3 PHY_TYPE_SATA 1 3 125000000>; + phys = <&psgtr 3 PHY_TYPE_SATA 1 3>; };
/* SD1 with level shifter */ @@ -571,10 +615,6 @@ xlnx,mio-bank = <1>; };
-&serdes { - status = "okay"; -}; - &uart0 { status = "okay"; }; @@ -588,6 +628,4 @@ status = "okay"; dr_mode = "host"; snps,usb3_lpm_capable; - phy-names = "usb3-phy"; - phys = <&lane2 PHY_TYPE_USB3 0 2 26000000>; }; diff --git a/arch/arm/dts/zynqmp-zcu216-revA.dts b/arch/arm/dts/zynqmp-zcu216-revA.dts index 847e689c155f..2302b07c4825 100644 --- a/arch/arm/dts/zynqmp-zcu216-revA.dts +++ b/arch/arm/dts/zynqmp-zcu216-revA.dts @@ -120,6 +120,20 @@ compatible = "iio-hwmon"; io-channels = <&dac_avcc 0>, <&dac_avcc 1>, <&dac_avcc 2>, <&dac_avcc 3>; }; + + /* 48MHz reference crystal */ + ref48: ref48M { + compatible = "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <48000000>; + }; +}; + +&psgtr { + status = "okay"; + /* pcie, sata, usb3, dp */ + clocks = <&si5341 0 5>, <&si5341 0 3>, <&si5341 0 2>, <&si5341 0 0>; + clock-names = "ref0", "ref1", "ref2", "ref3"; };
&dcc { @@ -408,10 +422,41 @@ #size-cells = <0>; reg = <1>; si5341: clock-generator@36 { /* SI5341 - u43 */ - compatible = "si5341"; + compatible = "silabs,si5341"; reg = <0x36>; + #clock-cells = <2>; + #address-cells = <1>; + #size-cells = <0>; + clocks = <&ref48>; + clock-names = "xtal"; + clock-output-names = "si5341"; + + si5341_2: out@2 { + /* refclk2 for PS-GT, used for USB3 */ + reg = <2>; + always-on; /* assigned-clocks does not enable, so do it here */ + }; + si5341_3: out@3 { + /* refclk3 for PS-GT, used for SATA */ + reg = <3>; + always-on; /* assigned-clocks does not enable, so do it here */ + }; + si5341_5: out@5 { + /* refclk5 PL CLK100 */ + reg = <5>; + always-on; /* assigned-clocks does not enable, so do it here */ + }; + si5341_6: out@6 { + /* refclk6 PL CLK125 */ + reg = <6>; + always-on; /* assigned-clocks does not enable, so do it here */ + }; + si5341_9: out@9 { + /* refclk9 used for PS_REF_CLK 33.3 MHz */ + reg = <9>; + always-on; /* assigned-clocks does not enable, so do it here */ + }; }; - }; i2c_si570_user_c0: i2c@2 { #address-cells = <1>; @@ -560,8 +605,7 @@ ceva,p1-comwake-params = /bits/ 8 <0x06 0x14 0x08 0x0E>; ceva,p1-burst-params = /bits/ 8 <0x13 0x08 0x4A 0x06>; ceva,p1-retry-params = /bits/ 16 <0x96A4 0x3FFC>; - phy-names = "sata-phy"; - phys = <&lane3 PHY_TYPE_SATA 1 3 125000000>; + phys = <&psgtr 3 PHY_TYPE_SATA 1 3>; };
/* SD1 with level shifter */ @@ -575,10 +619,6 @@ xlnx,mio-bank = <1>; };
-&serdes { - status = "okay"; -}; - &uart0 { status = "okay"; }; @@ -592,6 +632,4 @@ status = "okay"; dr_mode = "host"; snps,usb3_lpm_capable; - phy-names = "usb3-phy"; - phys = <&lane2 PHY_TYPE_USB3 0 2 26000000>; }; diff --git a/arch/arm/dts/zynqmp.dtsi b/arch/arm/dts/zynqmp.dtsi index 2917a956eb3d..84d9770225aa 100644 --- a/arch/arm/dts/zynqmp.dtsi +++ b/arch/arm/dts/zynqmp.dtsi @@ -12,6 +12,7 @@ * the License, or (at your option) any later version. */
+#include <dt-bindings/dma/xlnx-zynqmp-dpdma.h> #include <dt-bindings/power/xlnx-zynqmp-power.h> #include <dt-bindings/reset/xlnx-zynqmp-resets.h>
@@ -160,11 +161,25 @@ mbox-names = "tx", "rx"; };
+ nvmem_firmware { + compatible = "xlnx,zynqmp-nvmem-fw"; + #address-cells = <1>; + #size-cells = <1>; + + soc_revision: soc_revision@0 { + reg = <0x0 0x4>; + }; + }; + zynqmp_pcap: pcap { compatible = "xlnx,zynqmp-pcap-fpga"; clock-names = "ref_clk"; };
+ xlnx_aes: zynqmp-aes { + compatible = "xlnx,zynqmp-aes"; + }; + zynqmp_reset: reset-controller { compatible = "xlnx,zynqmp-reset"; #reset-cells = <1>; @@ -198,16 +213,6 @@ ranges; };
- nvmem_firmware { - compatible = "xlnx,zynqmp-nvmem-fw"; - #address-cells = <1>; - #size-cells = <1>; - - soc_revision: soc_revision@0 { - reg = <0x0 0x4>; - }; - }; - amba: axi { compatible = "simple-bus"; u-boot,dm-pre-reloc; @@ -501,8 +506,8 @@ interrupts = <0 112 4>; };
- nand0: nand@ff100000 { - compatible = "arasan,nfc-v3p10"; + nand0: nand-controller@ff100000 { + compatible = "xlnx,zynqmp-nand-controller", "arasan,nfc-v3p10"; status = "disabled"; reg = <0x0 0xff100000 0x0 0x1000>; clock-names = "controller", "bus"; @@ -667,6 +672,15 @@ power-domains = <&zynqmp_firmware PD_QSPI>; };
+ psgtr: phy@fd400000 { + compatible = "xlnx,zynqmp-psgtr-v1.1"; + status = "disabled"; + reg = <0x0 0xfd400000 0x0 0x40000>, + <0x0 0xfd3d0000 0x0 0x1000>; + reg-names = "serdes", "siou"; + #phy-cells = <4>; + }; + rtc: rtc@ffa60000 { compatible = "xlnx,zynqmp-rtc"; status = "disabled"; @@ -677,45 +691,6 @@ calibration = <0x8000>; };
- serdes: zynqmp_phy@fd400000 { - compatible = "xlnx,zynqmp-psgtr"; - status = "disabled"; - reg = <0x0 0xfd400000 0x0 0x40000>, - <0x0 0xfd3d0000 0x0 0x1000>, - <0x0 0xff5e0000 0x0 0x1000>; - reg-names = "serdes", "siou", "lpd"; - nvmem-cells = <&soc_revision>; - nvmem-cell-names = "soc_revision"; - resets = <&zynqmp_reset ZYNQMP_RESET_SATA>, - <&zynqmp_reset ZYNQMP_RESET_USB0_CORERESET>, - <&zynqmp_reset ZYNQMP_RESET_USB1_CORERESET>, - <&zynqmp_reset ZYNQMP_RESET_USB0_HIBERRESET>, - <&zynqmp_reset ZYNQMP_RESET_USB1_HIBERRESET>, - <&zynqmp_reset ZYNQMP_RESET_USB0_APB>, - <&zynqmp_reset ZYNQMP_RESET_USB1_APB>, - <&zynqmp_reset ZYNQMP_RESET_DP>, - <&zynqmp_reset ZYNQMP_RESET_GEM0>, - <&zynqmp_reset ZYNQMP_RESET_GEM1>, - <&zynqmp_reset ZYNQMP_RESET_GEM2>, - <&zynqmp_reset ZYNQMP_RESET_GEM3>; - reset-names = "sata_rst", "usb0_crst", "usb1_crst", - "usb0_hibrst", "usb1_hibrst", "usb0_apbrst", - "usb1_apbrst", "dp_rst", "gem0_rst", - "gem1_rst", "gem2_rst", "gem3_rst"; - lane0: lane0 { - #phy-cells = <4>; - }; - lane1: lane1 { - #phy-cells = <4>; - }; - lane2: lane2 { - #phy-cells = <4>; - }; - lane3: lane3 { - #phy-cells = <4>; - }; - }; - sata: ahci@fd0c0000 { compatible = "ceva,ahci-1v84"; status = "disabled"; @@ -740,11 +715,11 @@ xlnx,device_id = <0>; #stream-id-cells = <1>; iommus = <&smmu 0x870>; - power-domains = <&zynqmp_firmware PD_SD_0>; nvmem-cells = <&soc_revision>; nvmem-cell-names = "soc_revision"; #clock-cells = <1>; clock-output-names = "clk_out_sd0", "clk_in_sd0"; + power-domains = <&zynqmp_firmware PD_SD_0>; };
sdhci1: mmc@ff170000 { @@ -758,11 +733,11 @@ xlnx,device_id = <1>; #stream-id-cells = <1>; iommus = <&smmu 0x871>; - power-domains = <&zynqmp_firmware PD_SD_1>; nvmem-cells = <&soc_revision>; nvmem-cell-names = "soc_revision"; #clock-cells = <1>; clock-output-names = "clk_out_sd1", "clk_in_sd1"; + power-domains = <&zynqmp_firmware PD_SD_1>; };
smmu: iommu@fd800000 { @@ -962,37 +937,18 @@ }; };
- xlnx_dpdma: dma@fd4c0000 { - compatible = "xlnx,dpdma"; + zynqmp_dpdma: dma-controller@fd4c0000 { + compatible = "xlnx,zynqmp-dpdma"; status = "disabled"; reg = <0x0 0xfd4c0000 0x0 0x1000>; interrupts = <0 122 4>; interrupt-parent = <&gic>; clock-names = "axi_clk"; power-domains = <&zynqmp_firmware PD_DP>; - dma-channels = <6>; #dma-cells = <1>; - dma-video0channel { - compatible = "xlnx,video0"; - }; - dma-video1channel { - compatible = "xlnx,video1"; - }; - dma-video2channel { - compatible = "xlnx,video2"; - }; - dma-graphicschannel { - compatible = "xlnx,graphics"; - }; - dma-audio0channel { - compatible = "xlnx,audio0"; - }; - dma-audio1channel { - compatible = "xlnx,audio1"; - }; };
- zynqmp_dpsub: zynqmp-display@fd4a0000 { + zynqmp_dpsub: display@fd4a0000 { compatible = "xlnx,zynqmp-dpsub-1.7"; status = "disabled"; reg = <0x0 0xfd4a0000 0x0 0x1000>, @@ -1002,51 +958,15 @@ reg-names = "dp", "blend", "av_buf", "aud"; interrupts = <0 119 4>; interrupt-parent = <&gic>; - clock-names = "dp_apb_clk", "dp_aud_clk", "dp_vtc_pixel_clk_in"; - power-domains = <&zynqmp_firmware PD_DP>; - - vid-layer { - dma-names = "vid0", "vid1", "vid2"; - dmas = <&xlnx_dpdma 0>, - <&xlnx_dpdma 1>, - <&xlnx_dpdma 2>; - }; - - gfx-layer { - dma-names = "gfx0"; - dmas = <&xlnx_dpdma 3>; - }; - - /* dummy node to indicate there's no child i2c device */ - i2c-bus { - }; - - zynqmp_dp_snd_codec0: zynqmp_dp_snd_codec0 { - compatible = "xlnx,dp-snd-codec"; - clock-names = "aud_clk"; - }; - - zynqmp_dp_snd_pcm0: zynqmp_dp_snd_pcm0 { - compatible = "xlnx,dp-snd-pcm"; - dmas = <&xlnx_dpdma 4>; - dma-names = "tx"; - }; - - zynqmp_dp_snd_pcm1: zynqmp_dp_snd_pcm1 { - compatible = "xlnx,dp-snd-pcm"; - dmas = <&xlnx_dpdma 5>; - dma-names = "tx"; - }; - - zynqmp_dp_snd_card0: zynqmp_dp_snd_card { - compatible = "xlnx,dp-snd-card"; - xlnx,dp-snd-pcm = <&zynqmp_dp_snd_pcm0>, - <&zynqmp_dp_snd_pcm1>; - xlnx,dp-snd-codec = <&zynqmp_dp_snd_codec0>; - }; + resets = <&zynqmp_reset ZYNQMP_RESET_DP>; + dma-names = "vid0", "vid1", "vid2", "gfx0"; + dmas = <&zynqmp_dpdma ZYNQMP_DPDMA_VIDEO0>, + <&zynqmp_dpdma ZYNQMP_DPDMA_VIDEO1>, + <&zynqmp_dpdma ZYNQMP_DPDMA_VIDEO2>, + <&zynqmp_dpdma ZYNQMP_DPDMA_GRAPHICS>; }; }; }; diff --git a/include/dt-bindings/dma/xlnx-zynqmp-dpdma.h b/include/dt-bindings/dma/xlnx-zynqmp-dpdma.h new file mode 100644 index 000000000000..3719cda5679d --- /dev/null +++ b/include/dt-bindings/dma/xlnx-zynqmp-dpdma.h @@ -0,0 +1,16 @@ +/* SPDX-License-Identifier: (GPL-2.0 OR MIT) */ +/* + * Copyright 2019 Laurent Pinchart laurent.pinchart@ideasonboard.com + */ + +#ifndef __DT_BINDINGS_DMA_XLNX_ZYNQMP_DPDMA_H__ +#define __DT_BINDINGS_DMA_XLNX_ZYNQMP_DPDMA_H__ + +#define ZYNQMP_DPDMA_VIDEO0 0 +#define ZYNQMP_DPDMA_VIDEO1 1 +#define ZYNQMP_DPDMA_VIDEO2 2 +#define ZYNQMP_DPDMA_GRAPHICS 3 +#define ZYNQMP_DPDMA_AUDIO0 4 +#define ZYNQMP_DPDMA_AUDIO1 5 + +#endif /* __DT_BINDINGS_DMA_XLNX_ZYNQMP_DPDMA_H__ */
st 10. 3. 2021 v 14:11 odesÃlatel Michal Simek michal.simek@xilinx.com napsal:
ds23 {
accelerometer@53 {
ld4 {
-&zynqmp_dpsub {
+&zynqmp_pcap {
-&zynqmp_pcap {
+&zynqmp_dpsub {
-&zynqmp_dpsub {
status = "okay";
status = "okay";
status = "okay";
-&xlnx_dpdma {
status = "okay";
ds2 {
ds3 {
ds4 {
ds5 {
si5335a_0: clk26 {
#clock-cells = <0>;
si5335a_1: clk27 {
#clock-cells = <0>;
+&psgtr {
status = "okay";
/* usb3, dps */
-&serdes {
status = "okay";
+&zynqmp_dpdma {
status = "okay";
+&zynqmp_dpsub {
status = "okay";
ref48: ref48M {
#clock-cells = <0>;
refhdmi: refhdmi {
#clock-cells = <0>;
gtr-sel0 {
gtr-sel1 {
gtr-sel2 {
gtr-sel3 {
#clock-cells = <2>;
#size-cells = <0>;
clocks = <&ref48>;
si5341_0: out@0 {
reg = <0>;
always-on;
si5341_2: out@2 {
reg = <2>;
always-on;
si5341_3: out@3 {
reg = <3>;
always-on;
si5341_4: out@4 {
reg = <4>;
always-on;
si5341_5: out@5 {
reg = <5>;
always-on;
si5341_6: out@6 {
reg = <6>;
always-on;
si5341_7: out@7 {
reg = <7>;
always-on;
si5341_9: out@9 {
reg = <9>;
always-on;
+&psgtr {
status = "okay";
-&serdes {
status = "okay";
status = "okay";
status = "okay";
status = "okay";
status = "okay";
#clock-cells = <0>;
#clock-cells = <0>;
#clock-cells = <0>;
+&psgtr {
status = "okay";
-&serdes {
status = "okay";
+&zynqmp_dpdma {
status = "okay";
+&zynqmp_dpsub {
status = "okay";
#clock-cells = <0>;
#clock-cells = <0>;
#clock-cells = <0>;
+&psgtr {
status = "okay";
-&serdes {
status = "okay";
+&zynqmp_dpdma {
status = "okay";
+&zynqmp_dpsub {
status = "okay";
ref48: ref48M {
#clock-cells = <0>;
refhdmi: refhdmi {
#clock-cells = <0>;
+&zynqmp_dpdma {
status = "okay";
+&zynqmp_dpsub {
status = "okay";
#clock-cells = <2>;
#size-cells = <0>;
clocks = <&ref48>;
si5341_0: out@0 {
reg = <0>;
always-on;
si5341_2: out@2 {
reg = <2>;
always-on;
si5341_3: out@3 {
reg = <3>;
always-on;
si5341_6: out@6 {
reg = <6>;
always-on;
si5341_7: out@7 {
reg = <7>;
always-on;
si5341_9: out@9 {
reg = <9>;
always-on;
* interrupts = <>;
#size-cells = <0>;
#clock-cells = <1>;
reg = <0>;
}; }; }; i2c@5 {
+&psgtr {
status = "okay";
-&serdes {
status = "okay";
ref48: ref48M {
#clock-cells = <0>;
#clock-cells = <2>;
#size-cells = <0>;
clocks = <&ref48>;
si5341_0: out@0 {
reg = <0>;
always-on;
si5341_2: out@2 {
reg = <2>;
always-on;
si5341_3: out@3 {
reg = <3>;
always-on;
si5341_5: out@5 {
reg = <5>;
always-on;
si5341_6: out@6 {
reg = <6>;
always-on;
si5341_9: out@9 {
reg = <9>;
always-on;
+&psgtr {
status = "okay";
-&serdes {
status = "okay";
dr_mode = "host";
dr_mode = "host";
+&zynqmp_dpsub {
status = "okay";
ref48: ref48M {
#clock-cells = <0>;
#clock-cells = <2>;
#size-cells = <0>;
clocks = <&ref48>;
si5341_2: out@2 {
reg = <2>;
si5341_3: out@3 {
reg = <3>;
si5341_5: out@5 {
reg = <5>;
si5341_6: out@6 {
reg = <6>;
si5341_9: out@9 {
reg = <9>;
+&psgtr {
status = "okay";
-&serdes {
status = "okay";
ref48: ref48M {
#clock-cells = <0>;
+&psgtr {
status = "okay";
#clock-cells = <2>;
#size-cells = <0>;
clocks = <&ref48>;
si5341_2: out@2 {
reg = <2>;
si5341_3: out@3 {
reg = <3>;
si5341_5: out@5 {
reg = <5>;
si5341_6: out@6 {
reg = <6>;
si5341_9: out@9 {
reg = <9>;
-&serdes {
status = "okay";
nvmem_firmware {
#size-cells = <1>;
reg = <0x0 0x4>;
nvmem_firmware {
#size-cells = <1>;
reg = <0x0 0x4>;
#phy-cells = <4>;
lane0: lane0 {
#phy-cells = <4>;
lane1: lane1 {
#phy-cells = <4>;
lane2: lane2 {
#phy-cells = <4>;
lane3: lane3 {
#phy-cells = <4>;
power-domains = <&zynqmp_firmware PD_SD_0>; }; sdhci1: mmc@ff170000 {
power-domains = <&zynqmp_firmware PD_SD_1>; }; smmu: iommu@fd800000 {
dma-video0channel {
dma-video1channel {
dma-video2channel {
dma-audio0channel {
dma-audio1channel {
vid-layer {
<&xlnx_dpdma 1>,
<&xlnx_dpdma 2>;
gfx-layer {
dma-names = "gfx0";
i2c-bus {
dma-names = "tx";
dma-names = "tx";
- Copyright 2019 Laurent Pinchart laurent.pinchart@ideasonboard.com
2.30.1
Applied. M
Michal Simek
Michal Simek
