[U-Boot] [PATCH v3 1/4] arm: add missing writes{bwql}, reads{bwql}.
ARM arch defines __raw_writes[bwql], __raw_reads[bwql] in io.h but not writes[bwql], reads[bwql] as required by some drivers. Some of the drivers are defining writes{bwlq} or reads{bwlq} as wrapper of their "__raw" version. To avoid that lets add the wrapper in arch itself.
Signed-off-by: Purna Chandra Mandal purna.mandal@microchip.com ---
arch/arm/include/asm/io.h | 7 +++++++ 1 file changed, 7 insertions(+)
diff --git a/arch/arm/include/asm/io.h b/arch/arm/include/asm/io.h index 75773bd..9d185a6 100644 --- a/arch/arm/include/asm/io.h +++ b/arch/arm/include/asm/io.h @@ -284,6 +284,13 @@ static inline void __raw_readsl(unsigned long addr, void *data, int longlen) #define insw_p(port,to,len) insw(port,to,len) #define insl_p(port,to,len) insl(port,to,len)
+#define writesl(a, d, s) __raw_writesl((unsigned long)a, d, s) +#define readsl(a, d, s) __raw_readsl((unsigned long)a, d, s) +#define writesw(a, d, s) __raw_writesw((unsigned long)a, d, s) +#define readsw(a, d, s) __raw_readsw((unsigned long)a, d, s) +#define writesb(a, d, s) __raw_writesb((unsigned long)a, d, s) +#define readsb(a, d, s) __raw_readsb((unsigned long)a, d, s) + /* * ioremap and friends. *
Moved definition of writes{bwlq} and reads{bwlq} into arch. There is no need of having arch specific wrapper in driver.
drivers/usb/musb-new/linux-compat.h | 7 ------- 1 file changed, 7 deletions(-)
diff --git a/drivers/usb/musb-new/linux-compat.h b/drivers/usb/musb-new/linux-compat.h index 46f83d9..526f4f2 100644 --- a/drivers/usb/musb-new/linux-compat.h +++ b/drivers/usb/musb-new/linux-compat.h @@ -13,13 +13,6 @@ printf(fmt, ##args); \ ret_warn; })
-#define writesl(a, d, s) __raw_writesl((unsigned long)a, d, s) -#define readsl(a, d, s) __raw_readsl((unsigned long)a, d, s) -#define writesw(a, d, s) __raw_writesw((unsigned long)a, d, s) -#define readsw(a, d, s) __raw_readsw((unsigned long)a, d, s) -#define writesb(a, d, s) __raw_writesb((unsigned long)a, d, s) -#define readsb(a, d, s) __raw_readsb((unsigned long)a, d, s) - #define device_init_wakeup(dev, a) do {} while (0)
#define platform_data device_data
And so the patch does ... what exactly ? I cannot figure it out just by reading the commit message, sorry.
The patch itself is fine of course, but please fix the commit message.
I hope new commit message will do. "Definition of writes{bwlq}, reads{bwlq} are now added into arch specific asm/io.h. So removing them from driver to fix re-definition error. "
Yes please :)
This driver adds support of PIC32 MUSB OTG controller as dual role device. It implements platform specific glue to reuse musb core.
Signed-off-by: Cristian Birsan cristian.birsan@microchip.com Signed-off-by: Purna Chandra Mandal purna.mandal@microchip.com ---
drivers/usb/musb-new/Kconfig | 7 + drivers/usb/musb-new/Makefile | 1 + drivers/usb/musb-new/musb_core.c | 2 +- drivers/usb/musb-new/pic32.c | 294 +++++++++++++++++++++++++++++++++++++++ 4 files changed, 303 insertions(+), 1 deletion(-) create mode 100644 drivers/usb/musb-new/pic32.c
diff --git a/drivers/usb/musb-new/Kconfig b/drivers/usb/musb-new/Kconfig index 6a6cb93..4e8a543 100644 --- a/drivers/usb/musb-new/Kconfig +++ b/drivers/usb/musb-new/Kconfig @@ -15,6 +15,13 @@ config USB_MUSB_GADGET
if USB_MUSB_HOST || USB_MUSB_GADGET
+config USB_MUSB_PIC32 + bool "Enable Microchip PIC32 DRC USB controller" + depends on DM_USB && MACH_PIC32 + help + Say y to enable PIC32 USB DRC controller support + if it is available on your Microchip PIC32 platform. + config USB_MUSB_SUNXI bool "Enable sunxi OTG / DRC USB controller" depends on ARCH_SUNXI diff --git a/drivers/usb/musb-new/Makefile b/drivers/usb/musb-new/Makefile index 072d516..df1c3c8 100644 --- a/drivers/usb/musb-new/Makefile +++ b/drivers/usb/musb-new/Makefile @@ -10,6 +10,7 @@ obj-$(CONFIG_USB_MUSB_HOST) += musb_host.o musb_core.o musb_uboot.o obj-$(CONFIG_USB_MUSB_DSPS) += musb_dsps.o obj-$(CONFIG_USB_MUSB_AM35X) += am35x.o obj-$(CONFIG_USB_MUSB_OMAP2PLUS) += omap2430.o +obj-$(CONFIG_USB_MUSB_PIC32) += pic32.o obj-$(CONFIG_USB_MUSB_SUNXI) += sunxi.o
ccflags-y := $(call cc-option,-Wno-unused-variable) \ diff --git a/drivers/usb/musb-new/musb_core.c b/drivers/usb/musb-new/musb_core.c index a6d6af6..dd0443c 100644 --- a/drivers/usb/musb-new/musb_core.c +++ b/drivers/usb/musb-new/musb_core.c @@ -259,7 +259,7 @@ void musb_write_fifo(struct musb_hw_ep *hw_ep, u16 len, const u8 *src) } }
-#if !defined(CONFIG_USB_MUSB_AM35X) +#if !defined(CONFIG_USB_MUSB_AM35X) && !defined(CONFIG_USB_MUSB_PIC32) /* * Unload an endpoint's FIFO */ diff --git a/drivers/usb/musb-new/pic32.c b/drivers/usb/musb-new/pic32.c new file mode 100644 index 0000000..980a971 --- /dev/null +++ b/drivers/usb/musb-new/pic32.c @@ -0,0 +1,294 @@ +/* + * Microchip PIC32 MUSB "glue layer" + * + * Copyright (C) 2015, Microchip Technology Inc. + * Cristian Birsan cristian.birsan@microchip.com + * Purna Chandra Mandal purna.mandal@microchip.com + * + * SPDX-License-Identifier: GPL-2.0+ + * + * Based on the dsps "glue layer" code. + */ + +#include <common.h> +#include <linux/usb/musb.h> +#include "linux-compat.h" +#include "musb_core.h" +#include "musb_uboot.h" + +DECLARE_GLOBAL_DATA_PTR; + +#define PIC32_TX_EP_MASK 0x0f /* EP0 + 7 Tx EPs */ +#define PIC32_RX_EP_MASK 0x0e /* 7 Rx EPs */ + +#define MUSB_SOFTRST 0x7f +#define MUSB_SOFTRST_NRST BIT(0) +#define MUSB_SOFTRST_NRSTX BIT(1) + +#define USBCRCON 0 +#define USBCRCON_USBWKUPEN BIT(0) /* Enable Wakeup Interrupt */ +#define USBCRCON_USBRIE BIT(1) /* Enable Remote resume Interrupt */ +#define USBCRCON_USBIE BIT(2) /* Enable USB General interrupt */ +#define USBCRCON_SENDMONEN BIT(3) /* Enable Session End VBUS monitoring */ +#define USBCRCON_BSVALMONEN BIT(4) /* Enable B-Device VBUS monitoring */ +#define USBCRCON_ASVALMONEN BIT(5) /* Enable A-Device VBUS monitoring */ +#define USBCRCON_VBUSMONEN BIT(6) /* Enable VBUS monitoring */ +#define USBCRCON_PHYIDEN BIT(7) /* PHY ID monitoring enable */ +#define USBCRCON_USBIDVAL BIT(8) /* USB ID value */ +#define USBCRCON_USBIDOVEN BIT(9) /* USB ID override enable */ +#define USBCRCON_USBWK BIT(24) /* USB Wakeup Status */ +#define USBCRCON_USBRF BIT(25) /* USB Resume Status */ +#define USBCRCON_USBIF BIT(26) /* USB General Interrupt Status */ + +static void __iomem *musb_glue; + +/* pic32_musb_disable - disable HDRC */ +static void pic32_musb_disable(struct musb *musb) +{ +} + +/* pic32_musb_enable - enable HDRC */ +static int pic32_musb_enable(struct musb *musb) +{ + /* soft reset by NRSTx */ + musb_writeb(musb->mregs, MUSB_SOFTRST, MUSB_SOFTRST_NRSTX); + /* set mode */ + musb_platform_set_mode(musb, musb->board_mode); + + return 0; +} + +static irqreturn_t pic32_interrupt(int irq, void *hci) +{ + struct musb *musb = hci; + irqreturn_t ret = IRQ_NONE; + u32 epintr, usbintr; + + /* Get usb core interrupts */ + musb->int_usb = musb_readb(musb->mregs, MUSB_INTRUSB); + if (musb->int_usb) + musb_writeb(musb->mregs, MUSB_INTRUSB, musb->int_usb); + + /* Get endpoint interrupts */ + musb->int_rx = musb_readw(musb->mregs, MUSB_INTRRX) & PIC32_RX_EP_MASK; + if (musb->int_rx) + musb_writew(musb->mregs, MUSB_INTRRX, musb->int_rx); + + musb->int_tx = musb_readw(musb->mregs, MUSB_INTRTX) & PIC32_TX_EP_MASK; + if (musb->int_tx) + musb_writew(musb->mregs, MUSB_INTRTX, musb->int_tx); + + /* Drop spurious RX and TX if device is disconnected */ + if (musb->int_usb & MUSB_INTR_DISCONNECT) { + musb->int_tx = 0; + musb->int_rx = 0; + } + + if (musb->int_tx || musb->int_rx || musb->int_usb) + ret |= musb_interrupt(musb); + + return ret; +} + +static int pic32_musb_set_mode(struct musb *musb, u8 mode) +{ + struct device *dev = musb->controller; + + switch (mode) { + case MUSB_HOST: + clrsetbits_le32(musb_glue + USBCRCON, + USBCRCON_USBIDVAL, USBCRCON_USBIDOVEN); + break; + case MUSB_PERIPHERAL: + setbits_le32(musb_glue + USBCRCON, + USBCRCON_USBIDVAL | USBCRCON_USBIDOVEN); + break; + case MUSB_OTG: + dev_err(dev, "MUSB OTG mode enabled\n"); + break; + default: + dev_err(dev, "unsupported mode %d\n", mode); + return -EINVAL; + } + + return 0; +} + +static int pic32_musb_init(struct musb *musb) +{ + u32 ctrl, hwvers; + u8 power; + + /* Returns zero if not clocked */ + hwvers = musb_read_hwvers(musb->mregs); + if (!hwvers) + return -ENODEV; + + /* Reset the musb */ + power = musb_readb(musb->mregs, MUSB_POWER); + power = power | MUSB_POWER_RESET; + musb_writeb(musb->mregs, MUSB_POWER, power); + mdelay(100); + + /* Start the on-chip PHY and its PLL. */ + power = power & ~MUSB_POWER_RESET; + musb_writeb(musb->mregs, MUSB_POWER, power); + + musb->isr = pic32_interrupt; + + ctrl = USBCRCON_USBIF | USBCRCON_USBRF | + USBCRCON_USBWK | USBCRCON_USBIDOVEN | + USBCRCON_PHYIDEN | USBCRCON_USBIE | + USBCRCON_USBRIE | USBCRCON_USBWKUPEN | + USBCRCON_VBUSMONEN; + writel(ctrl, musb_glue + USBCRCON); + + return 0; +} + +/* PIC32 supports only 32bit read operation */ +void musb_read_fifo(struct musb_hw_ep *hw_ep, u16 len, u8 *dst) +{ + void __iomem *fifo = hw_ep->fifo; + u32 val; + int i; + + /* Read for 32bit-aligned destination address */ + if (likely((0x03 & (unsigned long)dst) == 0) && len >= 4) { + readsl(fifo, dst, len / 4); + dst += len & ~0x03; + len &= 0x03; + } + + /* + * Now read the remaining 1 to 3 byte or complete length if + * unaligned address. + */ + if (len > 4) { + for (i = 0; i < (len / 4); i++) { + *(u32 *)dst = musb_readl(fifo, 0); + dst += 4; + } + len &= 0x03; + } + + if (len > 0) { + val = musb_readl(fifo, 0); + memcpy(dst, &val, len); + } +} + +const struct musb_platform_ops pic32_musb_ops = { + .init = pic32_musb_init, + .set_mode = pic32_musb_set_mode, + .disable = pic32_musb_disable, + .enable = pic32_musb_enable, +}; + +/* PIC32 default FIFO config - fits in 8KB */ +static struct musb_fifo_cfg pic32_musb_fifo_config[] = { + { .hw_ep_num = 1, .style = FIFO_TX, .maxpacket = 512, }, + { .hw_ep_num = 1, .style = FIFO_RX, .maxpacket = 512, }, + { .hw_ep_num = 2, .style = FIFO_TX, .maxpacket = 512, }, + { .hw_ep_num = 2, .style = FIFO_RX, .maxpacket = 512, }, + { .hw_ep_num = 3, .style = FIFO_TX, .maxpacket = 512, }, + { .hw_ep_num = 3, .style = FIFO_RX, .maxpacket = 512, }, + { .hw_ep_num = 4, .style = FIFO_TX, .maxpacket = 512, }, + { .hw_ep_num = 4, .style = FIFO_RX, .maxpacket = 512, }, + { .hw_ep_num = 5, .style = FIFO_TX, .maxpacket = 512, }, + { .hw_ep_num = 5, .style = FIFO_RX, .maxpacket = 512, }, + { .hw_ep_num = 6, .style = FIFO_TX, .maxpacket = 512, }, + { .hw_ep_num = 6, .style = FIFO_RX, .maxpacket = 512, }, + { .hw_ep_num = 7, .style = FIFO_TX, .maxpacket = 512, }, + { .hw_ep_num = 7, .style = FIFO_RX, .maxpacket = 512, }, +}; + +static struct musb_hdrc_config pic32_musb_config = { + .fifo_cfg = pic32_musb_fifo_config, + .fifo_cfg_size = ARRAY_SIZE(pic32_musb_fifo_config), + .multipoint = 1, + .dyn_fifo = 1, + .num_eps = 8, + .ram_bits = 11, +}; + +/* PIC32 has one MUSB controller which can be host or gadget */ +static struct musb_hdrc_platform_data pic32_musb_plat = { + .mode = MUSB_HOST, + .config = &pic32_musb_config, + .power = 250, /* 500mA */ + .platform_ops = &pic32_musb_ops, +}; + +static int musb_usb_probe(struct udevice *dev) +{ + struct usb_bus_priv *priv = dev_get_uclass_priv(dev); + struct musb_host_data *mdata = dev_get_priv(dev); + struct fdt_resource mc, glue; + void *fdt = (void *)gd->fdt_blob; + int node = dev->of_offset; + void __iomem *mregs; + int ret; + + priv->desc_before_addr = true; + + ret = fdt_get_named_resource(fdt, node, "reg", "reg-names", + "mc", &mc); + if (ret < 0) { + printf("pic32-musb: resource "mc" not found\n"); + return ret; + } + + ret = fdt_get_named_resource(fdt, node, "reg", "reg-names", + "control", &glue); + if (ret < 0) { + printf("pic32-musb: resource "control" not found\n"); + return ret; + } + + mregs = ioremap(mc.start, fdt_resource_size(&mc)); + musb_glue = ioremap(glue.start, fdt_resource_size(&glue)); + +#ifdef CONFIG_USB_MUSB_HOST + /* init controller */ + mdata->host = musb_init_controller(&pic32_musb_plat, NULL, mregs); + if (!mdata->host) + return -EIO; + + ret = musb_lowlevel_init(mdata); +#else + pic32_musb_plat.mode = MUSB_PERIPHERAL; + ret = musb_register(&pic32_musb_plat, NULL, mregs); +#endif + if (ret == 0) + printf("PIC32 MUSB OTG\n"); + + return ret; +} + +static int musb_usb_remove(struct udevice *dev) +{ + struct musb_host_data *mdata = dev_get_priv(dev); + + musb_stop(mdata->host); + + return 0; +} + +static const struct udevice_id pic32_musb_ids[] = { + { .compatible = "microchip,pic32mzda-usb" }, + { } +}; + +U_BOOT_DRIVER(usb_musb) = { + .name = "pic32-musb", + .id = UCLASS_USB, + .of_match = pic32_musb_ids, + .probe = musb_usb_probe, + .remove = musb_usb_remove, +#ifdef CONFIG_USB_MUSB_HOST + .ops = &musb_usb_ops, +#endif + .platdata_auto_alloc_size = sizeof(struct usb_platdata), + .priv_auto_alloc_size = sizeof(struct musb_host_data), +};
- Microchip PIC32 MUSB "glue layer"
- Copyright (C) 2015, Microchip Technology Inc.
- Cristian Birsan cristian.birsan@microchip.com
- Purna Chandra Mandal purna.mandal@microchip.com
- Based on the dsps "glue layer" code.
What would happen once you make a chip with two MUSB controllers ?
Is there no way to shut down the MUSB on the PIC32 ?
- /* soft reset by NRSTx */
- musb_writeb(musb->mregs, MUSB_SOFTRST, MUSB_SOFTRST_NRSTX);
- /* set mode */
- musb_platform_set_mode(musb, musb->board_mode);
- struct musb *musb = hci;
- irqreturn_t ret = IRQ_NONE;
- u32 epintr, usbintr;
- /* Get usb core interrupts */
You mean "get" or "ack" here ?
- musb->int_usb = musb_readb(musb->mregs, MUSB_INTRUSB);
- if (musb->int_usb)
- /* Get endpoint interrupts */
DTTO
- musb->int_rx = musb_readw(musb->mregs, MUSB_INTRRX) & PIC32_RX_EP_MASK;
- if (musb->int_rx)
Same here
- musb->int_tx = musb_readw(musb->mregs, MUSB_INTRTX) & PIC32_TX_EP_MASK;
- if (musb->int_tx)
- /* Drop spurious RX and TX if device is disconnected */
- if (musb->int_usb & MUSB_INTR_DISCONNECT) {
musb->int_tx = 0;
musb->int_rx = 0;
- if (musb->int_tx || musb->int_rx || musb->int_usb)
- return ret;
- struct device *dev = musb->controller;
- switch (mode) {
- case MUSB_HOST:
break;
- case MUSB_PERIPHERAL:
break;
- case MUSB_OTG:
So having the core in OTG mode is an error ? Why ?
break;
- default:
return -EINVAL;
- u32 ctrl, hwvers;
- u8 power;
- /* Returns zero if not clocked */
- hwvers = musb_read_hwvers(musb->mregs);
- if (!hwvers)
return -ENODEV;
- /* Reset the musb */
- power = musb_readb(musb->mregs, MUSB_POWER);
- power = power | MUSB_POWER_RESET;
- musb_writeb(musb->mregs, MUSB_POWER, power);
- mdelay(100);
- /* Start the on-chip PHY and its PLL. */
- power = power & ~MUSB_POWER_RESET;
- musb->isr = pic32_interrupt;
- ctrl = USBCRCON_USBIF | USBCRCON_USBRF |
USBCRCON_VBUSMONEN;
- writel(ctrl, musb_glue + USBCRCON);
- void __iomem *fifo = hw_ep->fifo;
- u32 val;
- int i;
This could become: bulk_len = len / 4; bulk_rem = len % 4; readsl(fifo, dst, bulk_len); if (rem) { dst += len & ~0x3; tmp = readl(fifo); copy the remaining bytes according to endianness }
This is 10 LoC , not 50 ;-)
- /* Read for 32bit-aligned destination address */
- if (likely((0x03 & (unsigned long)dst) == 0) && len >= 4) {
dst += len & ~0x03;
len &= 0x03;
- if (len > 4) {
dst += 4;
len &= 0x03;
- if (len > 0) {
Currently PIC32 has only one MUSB controller and only one glue reg-space. Don't know how the reg-map will be in future when PIC32 will have multiple MUSB controllers. Assuming that glue address map will be separate for each controller we can add logic to support multiple MUSB controller.
IMO, better if we don't assume something of the future and bloat logic.
There is no way to disable MUSB.
- /* set mode */
I meant read-and-ack. Will update comment.
DTTO
- if (musb->int_rx)
Same here
- if (musb->int_tx)
musb->int_tx = 0;
musb->int_rx = 0;
- return ret;
- switch (mode) {
- case MUSB_HOST:
break;
break;
- case MUSB_OTG:
In PIC32 we haven't tested OTG. We use the controller as dual-role not as OTG. In future we might enable that.
break;
- default:
return -EINVAL;
- u32 ctrl, hwvers;
- u8 power;
- if (!hwvers)
return -ENODEV;
- mdelay(100);
USBCRCON_VBUSMONEN;
- u32 val;
- int i;
May be comments in my code are not very clear :)
All the extra code is for handling (4-byte-word) alignment of destination buffer. Writing word to unaligned address will generate exception in MIPS which is not handled in U-Boot software. Note MIPS can't handle unaligned access in h/w unless specific unaligned instructions are used.
dst += len & ~0x03;
len &= 0x03;
- if (len > 4) {
dst += 4;
len &= 0x03;
- if (len > 0) {
If you switch this to driver model, you will need to weed out all the static global variables anyway. Better do it now.
Yet another broken chip design. Can't you put the controller into reset and gate the clock for it ?
- /* set mode */
Thanks
DTTO
- if (musb->int_rx)
Same here
- if (musb->int_tx)
musb->int_tx = 0;
musb->int_rx = 0;
- return ret;
- switch (mode) {
- case MUSB_HOST:
break;
break;
- case MUSB_OTG:
Then you might want to say "support for OTG is unimplemented" ?
break;
- default:
return -EINVAL;
- u32 ctrl, hwvers;
- u8 power;
- if (!hwvers)
return -ENODEV;
- mdelay(100);
USBCRCON_VBUSMONEN;
- u32 val;
- int i;
Ouch, did you ever see unaligned access here ?
dst += len & ~0x03;
len &= 0x03;
- if (len > 4) {
dst += 4;
len &= 0x03;
- if (len > 0) {
Thanks. Will do.
USB clock can't be gated! USB controller clock is derived from peripheral bus clock(PBCLK5) which is shared with other modules and USB Phy clock derived from UPLL can;t be gated at all.
- /* set mode */
Thanks
DTTO
- if (musb->int_rx)
Same here
- if (musb->int_tx)
musb->int_tx = 0;
musb->int_rx = 0;
- return ret;
- switch (mode) {
- case MUSB_HOST:
break;
break;
- case MUSB_OTG:
Will update.
break;
- default:
return -EINVAL;
- u32 ctrl, hwvers;
- u8 power;
- if (!hwvers)
return -ENODEV;
- mdelay(100);
USBCRCON_VBUSMONEN;
- u32 val;
- int i;
Not seen unaligned access here but not sure of! Char array can be starting from any arbitrary address unless it is malloc()'d or special care is taken to make it aligned at word boundary.
I will take your logic as I'm not facing real problem.
dst += len & ~0x03;
len &= 0x03;
- if (len > 4) {
dst += 4;
len &= 0x03;
- if (len > 0) {
Thanks. Will do.
Thanks!
I see, oh well, then it cannot be helped.
- /* set mode */
Thanks
DTTO
- if (musb->int_rx)
Same here
- if (musb->int_tx)
musb->int_tx = 0;
musb->int_rx = 0;
- return ret;
- switch (mode) {
- case MUSB_HOST:
break;
break;
- case MUSB_OTG:
Will update.
Thanks
break;
- default:
return -EINVAL;
- u32 ctrl, hwvers;
- u8 power;
- if (!hwvers)
return -ENODEV;
- mdelay(100);
USBCRCON_VBUSMONEN;
- u32 val;
- int i;
The USB stack should be using only aligned buffers, so what you can try to do here is trap unaligned accesses and warn about them. Maybe factor out the unaligned access code and trigger it only if unaligned access really happens.
dst += len & ~0x03;
len &= 0x03;
- if (len > 4) {
dst += 4;
len &= 0x03;
- if (len > 0) {
Enable MUSB host and USB storage support for Microchip PIC32MZ[DA] Starter Kit.
Changes in v3: - add arch specific reads{bwlq}, writes{bwlq} in respective arch io.h - remove reads{bwlq}, writes{bwlq} in musb-new driver
Changes in v2: - compilation fix in drivers/usb/musb-new/linux-compat.h seperated - compilation fix in drivers/gadget/f_mass_storage.c seperated
arch/mips/dts/pic32mzda.dtsi | 10 ++++++++++ arch/mips/dts/pic32mzda_sk.dts | 4 ++++ configs/pic32mzdask_defconfig | 6 +++++- include/configs/pic32mzdask.h | 7 +++++++ 4 files changed, 26 insertions(+), 1 deletion(-)
diff --git a/arch/mips/dts/pic32mzda.dtsi b/arch/mips/dts/pic32mzda.dtsi index 7d180d9..57e4500 100644 --- a/arch/mips/dts/pic32mzda.dtsi +++ b/arch/mips/dts/pic32mzda.dtsi @@ -171,4 +171,14 @@ #address-cells = <1>; #size-cells = <0>; }; + + usb: musb@1f8e3000 { + compatible = "microchip,pic32mzda-usb"; + reg = <0x1f8e3000 0x1000>, + <0x1f884000 0x1000>; + reg-names = "mc", "control"; + interrupts = <132 IRQ_TYPE_EDGE_RISING>, + <133 IRQ_TYPE_LEVEL_HIGH>; + status = "disabled"; + }; }; diff --git a/arch/mips/dts/pic32mzda_sk.dts b/arch/mips/dts/pic32mzda_sk.dts index e5ce0bd..0a7847e 100644 --- a/arch/mips/dts/pic32mzda_sk.dts +++ b/arch/mips/dts/pic32mzda_sk.dts @@ -52,4 +52,8 @@ ethernet_phy: lan8740_phy@0 { reg = <0>; }; +}; + +&usb { + status = "okay"; }; \ No newline at end of file diff --git a/configs/pic32mzdask_defconfig b/configs/pic32mzdask_defconfig index 1dbe1b5..544112f 100644 --- a/configs/pic32mzdask_defconfig +++ b/configs/pic32mzdask_defconfig @@ -12,6 +12,7 @@ CONFIG_SYS_PROMPT="dask # " CONFIG_LOOPW=y CONFIG_CMD_MEMTEST=y CONFIG_CMD_MEMINFO=y +CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_GPIO=y CONFIG_CMD_RARP=y @@ -28,6 +29,9 @@ CONFIG_DM_ETH=y CONFIG_PIC32_ETH=y CONFIG_PINCTRL=y # CONFIG_PINCTRL_FULL is not set -CONFIG_SYS_VSNPRINTF=y +CONFIG_USB=y +CONFIG_DM_USB=y +CONFIG_USB_MUSB_HOST=y +CONFIG_USB_STORAGE=y CONFIG_USE_TINY_PRINTF=y CONFIG_CMD_DHRYSTONE=y diff --git a/include/configs/pic32mzdask.h b/include/configs/pic32mzdask.h index 2d35a0b..1d5be2b 100644 --- a/include/configs/pic32mzdask.h +++ b/include/configs/pic32mzdask.h @@ -117,6 +117,12 @@ #define CONFIG_GENERIC_MMC #define CONFIG_CMD_MMC
+/*-------------------------------------------------- + * USB Configuration + */ +#define CONFIG_USB_MUSB_PIO_ONLY +#define CONFIG_SYS_CACHELINE_SIZE 16 + /*----------------------------------------------------------------------- * File System Configuration */ @@ -167,6 +173,7 @@
#define BOOT_TARGET_DEVICES(func) \ func(MMC, mmc, 0) \ + func(USB, usb, 0) \ func(DHCP, dhcp, na)
#include <config_distro_bootcmd.h>
Am 15.03.2016 um 13:44 schrieb Purna Chandra Mandal:
Changes in v3:
Changes in v2:
- usb: musb@1f8e3000 {
+&usb {
- status = "okay";
- USB Configuration
I see CONFIG_SYS_CACHELINE_SIZE is used in drivers/usb/ in various memalign() calls. Actually we have ARCH_DMA_MINALIGN for this case. At least for MIPS I want to get rid of CONFIG_SYS_CACHELINE_SIZE in the future becasue we have auto-detection for that.
If possible I'd like to see a patch which replaces CONFIG_SYS_CACHELINE_SIZE with ARCH_DMA_MINALIGN in drivers/user/. Marek what do you think?
- File System Configuration
- func(USB, usb, 0) \ func(DHCP, dhcp, na)
Changes in v3:
Changes in v2:
+&usb {
- status = "okay";
- USB Configuration
I think that makes sense.
Daniel Schwierzeck
