[U-Boot] [PATCHv2] omap3evm: Update ethernet reset sequence for Rev.G board
The GPIO pin used for resetting the external LAN chip has changed for Rev.G board.
The patch uses generic gpio API instead of direct access to corresponding registers.
Signed-off-by: Sriramakrishnan srk@ti.com Signed-off-by: Sanjeev Premi premi@ti.com ---
Changes since v1: * Use of gpio API instead of direct register access.
Tested basic ethernet operations - dhcp and tftpboot - on the OMAP3EVM Rev G to load kernel and ramdisk images.
board/ti/evm/evm.c | 35 ++++++++++++++++++++++++++--------- 1 files changed, 26 insertions(+), 9 deletions(-)
diff --git a/board/ti/evm/evm.c b/board/ti/evm/evm.c index 8f9f141..2c95fae 100644 --- a/board/ti/evm/evm.c +++ b/board/ti/evm/evm.c @@ -33,10 +33,14 @@ #include <asm/arch/mem.h> #include <asm/arch/mux.h> #include <asm/arch/sys_proto.h> +#include <asm/arch/gpio.h> #include <i2c.h> #include <asm/mach-types.h> #include "evm.h"
+#define OMAP3EVM_GPIO_ETH_RST_GEN1 64 +#define OMAP3EVM_GPIO_ETH_RST_GEN2 7 + DECLARE_GLOBAL_DATA_PTR;
static u32 omap3_evm_version; @@ -181,17 +185,30 @@ static void setup_net_chip(void) */ static void reset_net_chip(void) { - struct gpio *gpio3_base = (struct gpio *)OMAP34XX_GPIO3_BASE; - - /* Make GPIO 64 as output pin */ - writel(readl(&gpio3_base->oe) & ~(GPIO0), &gpio3_base->oe); - - /* Now send a pulse on the GPIO pin */ - writel(GPIO0, &gpio3_base->setdataout); + int ret; + int rst_gpio; + + if (get_omap3_evm_rev() == OMAP3EVM_BOARD_GEN_1) { + rst_gpio = OMAP3EVM_GPIO_ETH_RST_GEN1; + } else { + rst_gpio = OMAP3EVM_GPIO_ETH_RST_GEN2; + } + + ret = omap_request_gpio(rst_gpio); + if (ret < 0) { + printf("Unable to get GPIO %d\n", rst_gpio); + return ; + } + + /* Configure as output */ + omap_set_gpio_direction(rst_gpio, 0); + + /* Send a pulse on the GPIO pin */ + omap_set_gpio_dataout(rst_gpio, 1); udelay(1); - writel(GPIO0, &gpio3_base->cleardataout); + omap_set_gpio_dataout(rst_gpio, 0); udelay(1); - writel(GPIO0, &gpio3_base->setdataout); + omap_set_gpio_dataout(rst_gpio, 1); }
int board_eth_init(bd_t *bis)
Sanjeev Premi
