[U-Boot] [v3, 3/4] mmc: fsl_esdhc: rename fsl_esdhc_init to fsl_esdhc_get_cfg
For non-DM code, below functions had similar names. - fsl_esdhc_initialize - fsl_esdhc_mmc_init - fsl_esdhc_init
However fsl_esdhc_init was mainly used to get cfg. So rename it to fsl_esdhc_get_cfg. Fix up bus-width capability handling, and drop controller initialization because it will be re-initialized in later esdhc_init_common for DM or esdhc_init for non-DM when use it.
Signed-off-by: Yangbo Lu yangbo.lu@nxp.com --- Changes for v2: - Rebased. Changes for v3: - None. --- drivers/mmc/fsl_esdhc.c | 68 ++++++++----------------------------------------- 1 file changed, 11 insertions(+), 57 deletions(-)
diff --git a/drivers/mmc/fsl_esdhc.c b/drivers/mmc/fsl_esdhc.c index 3b079f1..03a7e89 100644 --- a/drivers/mmc/fsl_esdhc.c +++ b/drivers/mmc/fsl_esdhc.c @@ -25,14 +25,6 @@
DECLARE_GLOBAL_DATA_PTR;
-#define ESDHC_IRQ_EN_BITS (IRQSTATEN_CC | IRQSTATEN_TC | \ - IRQSTATEN_DINT | IRQSTATEN_BWR | \ - IRQSTATEN_BRR | IRQSTATEN_CINT | \ - IRQSTATEN_CTOE | IRQSTATEN_CCE | \ - IRQSTATEN_CEBE | IRQSTATEN_CIE | \ - IRQSTATEN_DTOE | IRQSTATEN_DCE | \ - IRQSTATEN_DEBE) - struct fsl_esdhc { uint dsaddr; /* SDMA system address register */ uint blkattr; /* Block attributes register */ @@ -651,57 +643,25 @@ static int esdhc_getcd_common(struct fsl_esdhc_priv *priv) return timeout > 0; }
-static int esdhc_reset(struct fsl_esdhc *regs) -{ - ulong start; - - /* reset the controller */ - esdhc_setbits32(®s->sysctl, SYSCTL_RSTA); - - /* hardware clears the bit when it is done */ - start = get_timer(0); - while ((esdhc_read32(®s->sysctl) & SYSCTL_RSTA)) { - if (get_timer(start) > 100) { - printf("MMC/SD: Reset never completed.\n"); - return -ETIMEDOUT; - } - } - - return 0; -} - #if !CONFIG_IS_ENABLED(DM_MMC) static const struct mmc_ops esdhc_ops; #endif
-static int fsl_esdhc_init(struct fsl_esdhc_priv *priv, - struct fsl_esdhc_plat *plat) +static int fsl_esdhc_get_cfg(struct fsl_esdhc_priv *priv, + struct fsl_esdhc_plat *plat) { + struct fsl_esdhc *regs = priv->esdhc_regs; + u32 caps, voltage_caps = 0; struct mmc_config *cfg; - struct fsl_esdhc *regs; - u32 caps, voltage_caps; - int ret;
if (!priv) return -EINVAL;
- regs = priv->esdhc_regs; - - /* First reset the eSDHC controller */ - ret = esdhc_reset(regs); - if (ret) - return ret; - - esdhc_setbits32(®s->sysctl, SYSCTL_PEREN | SYSCTL_HCKEN | - SYSCTL_IPGEN | SYSCTL_CKEN); - - writel(ESDHC_IRQ_EN_BITS, ®s->irqstaten); cfg = &plat->cfg; #ifndef CONFIG_DM_MMC memset(cfg, '\0', sizeof(*cfg)); #endif
- voltage_caps = 0; caps = esdhc_read32(®s->hostcapblt);
#ifdef CONFIG_SYS_FSL_ERRATUM_ESDHC135 @@ -739,18 +699,10 @@ static int fsl_esdhc_init(struct fsl_esdhc_priv *priv, else if (priv->bus_width == 4) cfg->host_caps = MMC_MODE_4BIT;
- cfg->host_caps = MMC_MODE_4BIT | MMC_MODE_8BIT; #ifdef CONFIG_SYS_FSL_ESDHC_HAS_DDR_MODE cfg->host_caps |= MMC_MODE_DDR_52MHz; #endif
- if (priv->bus_width > 0) { - if (priv->bus_width < 8) - cfg->host_caps &= ~MMC_MODE_8BIT; - if (priv->bus_width < 4) - cfg->host_caps &= ~MMC_MODE_4BIT; - } - if (caps & HOSTCAPBLT2_HSS) cfg->host_caps |= MMC_MODE_HS_52MHz | MMC_MODE_HS;
@@ -761,7 +713,6 @@ static int fsl_esdhc_init(struct fsl_esdhc_priv *priv,
cfg->f_min = 400000; cfg->f_max = min(priv->sdhc_clk, (u32)200000000); - cfg->b_max = CONFIG_SYS_MMC_MAX_BLK_COUNT;
return 0; @@ -884,7 +835,10 @@ static int fsl_esdhc_cfg_to_priv(struct fsl_esdhc_cfg *cfg, return -EINVAL;
priv->esdhc_regs = (struct fsl_esdhc *)(unsigned long)(cfg->esdhc_base); - priv->bus_width = cfg->max_bus_width; + if (cfg->max_bus_width) + priv->bus_width = cfg->max_bus_width; + else + priv->bus_width = 4; priv->sdhc_clk = cfg->sdhc_clk; priv->wp_enable = cfg->wp_enable;
@@ -919,7 +873,7 @@ int fsl_esdhc_initialize(bd_t *bis, struct fsl_esdhc_cfg *cfg) return ret; }
- ret = fsl_esdhc_init(priv, plat); + ret = fsl_esdhc_get_cfg(priv, plat); if (ret) { debug("%s init failure\n", __func__); free(plat); @@ -1014,9 +968,9 @@ static int fsl_esdhc_probe(struct udevice *dev) } }
- ret = fsl_esdhc_init(priv, plat); + ret = fsl_esdhc_get_cfg(priv, plat); if (ret) { - dev_err(dev, "fsl_esdhc_init failure\n"); + dev_err(dev, "fsl_esdhc_get_cfg failure\n"); return ret; }
Yangbo Lu
