[U-Boot] [PATCH] configs/legoev3: define CONFIG_SKIP_LOWLEVEL_INIT
This adds a define for CONFIG_SKIP_LOWLEVEL_INIT in the legoev3 config. On the EV3, U-Boot is loaded into RAM by another bootloader, so we don't need the lowlevel init in U-Boot.
Signed-off-by: David Lechner david@lechnology.com --- include/configs/legoev3.h | 1 + 1 file changed, 1 insertion(+)
diff --git a/include/configs/legoev3.h b/include/configs/legoev3.h index 1e239ecadd..36ca3b201e 100644 --- a/include/configs/legoev3.h +++ b/include/configs/legoev3.h @@ -22,6 +22,7 @@ #define CONFIG_SYS_OSCIN_FREQ 24000000 #define CONFIG_SYS_TIMERBASE DAVINCI_TIMER0_BASE #define CONFIG_SYS_HZ_CLOCK clk_get(DAVINCI_AUXCLK_CLKID) +#define CONFIG_SKIP_LOWLEVEL_INIT
/* * Memory Info
If that's the case, does this mean that the NAK'd patch from Bartosz removing the dead code can be accepted?
adam
- Memory Info
-- 2.17.1
Probably
Probably
I will resend the two patches in a single series to avoid confusion.
Bart
Adam Ford
Bartosz Golaszewski
David Lechner
