[U-Boot] [PATCH 1/2] dm: i2c: Add a flag that not call i2c_setup_offset
Usually the i2c bus needs to write the address of the register before reading the internal register data of the device (ignoring the transmission of the slave address).
Generally, the stop signal is not needed before the register is read, but there is a special chip that needs this stop signal (such as pcf2127). However, in the current i2c general code, the dm_i2c_read api encapsulates two messages, the first time is to set the register address message, the second time is a message to read the register data, so that no stop signal is generated.
This patch uses the DM_I2C_CHIP_RD_NO_I2C_SETUP_OFFSET flag for specific i2c chips, so if the i2c slave requires a stop signal, chips driver can set this flag, then call the dm_i2c_write to set the register address (a stop signal is generated after this API call), then call dm_i2c_read to read the register data.
Signed-off-by: Chuanhua Han chuanhua.han@nxp.com --- Changes in v3: - Use the new flag DM_I2C_CHIP_RD_NO_I2C_SETUP_OFFSET
Changes in v2: - Split the original patch into 3 patches - Add detailed description information for each patch
drivers/i2c/i2c-uclass.c | 6 ++++-- include/i2c.h | 1 + 2 files changed, 5 insertions(+), 2 deletions(-)
diff --git a/drivers/i2c/i2c-uclass.c b/drivers/i2c/i2c-uclass.c index e47abf1833..9804b5e8c7 100644 --- a/drivers/i2c/i2c-uclass.c +++ b/drivers/i2c/i2c-uclass.c @@ -135,8 +135,10 @@ int dm_i2c_read(struct udevice *dev, uint offset, uint8_t *buffer, int len) if (chip->flags & DM_I2C_CHIP_RD_ADDRESS) return i2c_read_bytewise(dev, offset, buffer, len); ptr = msg; - if (!i2c_setup_offset(chip, offset, offset_buf, ptr)) - ptr++; + if (!(chip->flags & DM_I2C_CHIP_RD_NO_I2C_SETUP_OFFSET)) { + if (!i2c_setup_offset(chip, offset, offset_buf, ptr)) + ptr++; + }
if (len) { ptr->addr = chip->chip_addr; diff --git a/include/i2c.h b/include/i2c.h index a5c760c711..3123cbf280 100644 --- a/include/i2c.h +++ b/include/i2c.h @@ -28,6 +28,7 @@ enum dm_i2c_chip_flags { DM_I2C_CHIP_10BIT = 1 << 0, /* Use 10-bit addressing */ DM_I2C_CHIP_RD_ADDRESS = 1 << 1, /* Send address for each read byte */ DM_I2C_CHIP_WR_ADDRESS = 1 << 2, /* Send address for each write byte */ + DM_I2C_CHIP_RD_NO_I2C_SETUP_OFFSET = 1 << 3, /* No i2c_setup_offset*/ };
struct udevice;
The previous pcf2127 RTC chip could not read and set the correct time. When reading the data of internal registers, the read address was the value of register plus 1. This is because this chip requires the host to send a stop signal after setting the register address and before reading the register data.
This patch sets the DM_I2C_CHIP_RD_NO_I2C_SETUP_OFFSET flag in order to generate a stop signal and fixes the bug of the original read and write time.
Signed-off-by: Biwen Li biwen.li@nxp.com Signed-off-by: Chuanhua Han chuanhua.han@nxp.com --- Changes in v3: - When the rtc time is obtained, the address of the set register is separated from the read data.
drivers/rtc/pcf2127.c | 20 ++++++++++++++------ 1 file changed, 14 insertions(+), 6 deletions(-)
diff --git a/drivers/rtc/pcf2127.c b/drivers/rtc/pcf2127.c index dcf0340b4d..65794b98e6 100644 --- a/drivers/rtc/pcf2127.c +++ b/drivers/rtc/pcf2127.c @@ -24,12 +24,9 @@
static int pcf2127_rtc_set(struct udevice *dev, const struct rtc_time *tm) { - uchar buf[8]; + uchar buf[7] = {0}; int i = 0, ret;
- /* start register address */ - buf[i++] = PCF2127_REG_SC; - /* hours, minutes and seconds */ buf[i++] = bin2bcd(tm->tm_sec); buf[i++] = bin2bcd(tm->tm_min); @@ -44,7 +41,7 @@ static int pcf2127_rtc_set(struct udevice *dev, const struct rtc_time *tm) buf[i++] = bin2bcd(tm->tm_year % 100);
/* write register's data */ - ret = dm_i2c_write(dev, PCF2127_REG_CTRL1, buf, sizeof(buf)); + ret = dm_i2c_write(dev, PCF2127_REG_SC, buf, i);
return ret; } @@ -54,9 +51,12 @@ static int pcf2127_rtc_get(struct udevice *dev, struct rtc_time *tm) int ret = 0; uchar buf[10] = { PCF2127_REG_CTRL1 };
- ret = dm_i2c_write(dev, PCF2127_REG_CTRL1, buf, 1); + /* Set the address of the start register to be read */ + ret = dm_i2c_write(dev, PCF2127_REG_CTRL1, NULL, 0); if (ret < 0) return ret; + + /* Read register's data */ ret = dm_i2c_read(dev, PCF2127_REG_CTRL1, buf, sizeof(buf)); if (ret < 0) return ret; @@ -90,6 +90,13 @@ static int pcf2127_rtc_reset(struct udevice *dev) return 0; }
+static int pcf2127_probe(struct udevice *dev) +{ + i2c_set_chip_flags(dev, DM_I2C_CHIP_RD_NO_I2C_SETUP_OFFSET); + + return 0; +} + static const struct rtc_ops pcf2127_rtc_ops = { .get = pcf2127_rtc_get, .set = pcf2127_rtc_set, @@ -104,6 +111,7 @@ static const struct udevice_id pcf2127_rtc_ids[] = { U_BOOT_DRIVER(rtc_pcf2127) = { .name = "rtc-pcf2127", .id = UCLASS_RTC, + .probe = pcf2127_probe, .of_match = pcf2127_rtc_ids, .ops = &pcf2127_rtc_ops, };
Changes in v3:
ptr++;
ptr++;
Aren't those two above flags describe exactly what you need? They send address for each read/written byte. (or do you need to send more than a single byte)?
struct udevice;
Lukasz Majewski
DENX Software Engineering GmbH, Managing Director: Wolfgang Denk HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-59 Fax: (+49)-8142-66989-80 Email: lukma@denx.de
-----Original Message----- From: Lukasz Majewski lukma@denx.de Sent: 2019年6月4日 6:08 To: Chuanhua Han chuanhua.han@nxp.com Cc: hs@denx.de; u-boot@lists.denx.de; Biwen Li biwen.li@nxp.com Subject: [EXT] Re: [U-Boot] [PATCH 1/2] dm: i2c: Add a flag that not call i2c_setup_offset
Changes in v3:
ptr++;
ptr++;
This is not what I need. I need to generate a stop signal after setting the register address, so I need the following flag.
struct udevice;
Lukasz Majewski
Changes in v3:
ptr++;
- if (!(chip->flags & DM_I2C_CHIP_RD_NO_I2C_SETUP_OFFSET))
ptr))
ptr++;
Please correct me if I'm wrong, but the above flag says that you need to send the I2C stop after you send one byte?
Would it be possible to send address with I2C stop and then read data (single byte) with I2C stop?
I do find this name as a bit misleading - is the RD_NO_I2C_SETUP_OFFSET name reflecting the purpose (to send I2C stop after sending address)?
Maybe there would be a better name?
struct udevice;
Lukasz Majewski
Lukasz Majewski
-----Original Message----- From: Lukasz Majewski lukma@denx.de Sent: 2019年6月4日 14:46 To: Chuanhua Han chuanhua.han@nxp.com Cc: hs@denx.de; u-boot@lists.denx.de; Biwen Li biwen.li@nxp.com Subject: Re: [EXT] Re: [U-Boot] [PATCH 1/2] dm: i2c: Add a flag that not call i2c_setup_offset
Changes in v3:
ptr++;
ptr))
ptr++;
The purpose is to send a stop signal after setting the slave register address.
struct udevice;
Lukasz Majewski
Lukasz Majewski
Hi lukasz,chuanhua,
1. This means that pcf2127(rtc) do not need send slave register address when calling dm_i2c_read,because pcf2127(rtc) has send slave register address when calling dm_i2c_write in drivers/rtc/pcf2127.c 2. pcf2127's timings of reading registers,you can look at the attached file. 2.1 i2c write register address 2.2 i2c read registers(do not need send register address again,because it has send register address in 2.1)
-----Original Message----- From: Chuanhua Han Sent: 2019年6月4日 14:49 To: Lukasz Majewski lukma@denx.de Cc: hs@denx.de; u-boot@lists.denx.de; Biwen Li biwen.li@nxp.com Subject: RE: [EXT] Re: [U-Boot] [PATCH 1/2] dm: i2c: Add a flag that not call i2c_setup_offset
Changes in v3:
ptr++;
ptr))
ptr++;
struct udevice;
Lukasz Majewski
Lukasz Majewski
Changes in v3:
ptr++;
offset_buf, ptr))
ptr++;
What I'm trying to point out is that the above description doesn't match the flag name. Maybe there is a better, more descriptive name?
Also - what is byte length of send address to this device? One byte ?
struct udevice;
Lukasz Majewski
Lukasz Majewski
Lukasz Majewski
-----Original Message----- From: Lukasz Majewski lukma@denx.de Sent: 2019年6月4日 15:56 To: Chuanhua Han chuanhua.han@nxp.com Cc: hs@denx.de; u-boot@lists.denx.de; Biwen Li biwen.li@nxp.com Subject: Re: [EXT] Re: [U-Boot] [PATCH 1/2] dm: i2c: Add a flag that not call i2c_setup_offset
Changes in v3:
ptr++;
offset_buf, ptr))
ptr++;
Because the stop signal is generated by not calling the i2c_setup_offset function, this flag is used.
Yes,one byte
struct udevice;
Lukasz Majewski
Lukasz Majewski
Lukasz Majewski
> Usually the i2c bus needs to write the address of the > register before reading the internal register data of the > device (ignoring the transmission of the slave address). > > Generally, the stop signal is not needed before the > register is read, but there is a special chip that needs > this stop signal (such as pcf2127). However, in the > current i2c general code, the dm_i2c_read api > encapsulates two messages, the first time is to set the > register address message, the second time is a message to > read the register data, so that no stop signal is > generated. > > This patch uses the DM_I2C_CHIP_RD_NO_I2C_SETUP_OFFSET > flag for specific i2c chips, so if the i2c slave requires > a stop signal, chips driver can set this flag, then call > the dm_i2c_write to set the register address (a stop > signal is generated after this API call), then call > dm_i2c_read to read the register data. > > Signed-off-by: Chuanhua Han chuanhua.han@nxp.com > --- > Changes in v3: > - Use the new flag > DM_I2C_CHIP_RD_NO_I2C_SETUP_OFFSET > > Changes in v2: > - Split the original patch into 3 patches > - Add detailed description information for each > patch > > drivers/i2c/i2c-uclass.c | 6 ++++-- > include/i2c.h | 1 + > 2 files changed, 5 insertions(+), 2 deletions(-) > > diff --git a/drivers/i2c/i2c-uclass.c > b/drivers/i2c/i2c-uclass.c index e47abf1833..9804b5e8c7 > 100644 --- a/drivers/i2c/i2c-uclass.c > +++ b/drivers/i2c/i2c-uclass.c > @@ -135,8 +135,10 @@ int dm_i2c_read(struct udevice *dev, > uint offset, uint8_t *buffer, int len) if (chip->flags & > DM_I2C_CHIP_RD_ADDRESS) return i2c_read_bytewise(dev, > offset, buffer, len); ptr = msg; > - if (!i2c_setup_offset(chip, offset, offset_buf, > ptr)) > - ptr++; > + if (!(chip->flags & > DM_I2C_CHIP_RD_NO_I2C_SETUP_OFFSET)) { > + if (!i2c_setup_offset(chip, offset, > offset_buf, ptr)) > + ptr++; > + } > > if (len) { > ptr->addr = chip->chip_addr; diff --git > a/include/i2c.h b/include/i2c.h index > a5c760c711..3123cbf280 100644 > --- a/include/i2c.h > +++ b/include/i2c.h > @@ -28,6 +28,7 @@ enum dm_i2c_chip_flags { > DM_I2C_CHIP_10BIT = 1 << 0, > /* Use 10-bit addressing */ > DM_I2C_CHIP_RD_ADDRESS = 1 << 1, > /* Send address for each read byte */ > DM_I2C_CHIP_WR_ADDRESS = 1 << 2, > /* Send address for each write byte */
But the name of the flag shall be not based on particular function name. It shall be a generic description - like presented above:
With such generic names - there is no problem if we refactor the code and change the function name.
I've looked closer into those two flags: git grep -n "DM_I2C_CHIP_WR_ADDRESS"
drivers/rtc/ds1307.c:319: drivers/rtc/isl1208.c:173: drivers/rtc/rv3029.c:469:
It looks like those above rtc devices use it - so maybe the issue described for pcf2127 is also present on those devices (so those flags have been introduced) ?
Yes,one byte
> /* No i2c_setup_offset*/ }; > > struct udevice;
Lukasz Majewski
Lukasz Majewski
Lukasz Majewski
Lukasz Majewski
-----Original Message----- From: Lukasz Majewski lukma@denx.de Sent: 2019年6月4日 16:19 To: Chuanhua Han chuanhua.han@nxp.com Cc: hs@denx.de; u-boot@lists.denx.de; Biwen Li biwen.li@nxp.com Subject: Re: [EXT] Re: [U-Boot] [PATCH 1/2] dm: i2c: Add a flag that not call i2c_setup_offset
> -----Original Message----- > From: Lukasz Majewski lukma@denx.de > Sent: 2019年6月4日 6:08 > To: Chuanhua Han chuanhua.han@nxp.com > Cc: hs@denx.de; u-boot@lists.denx.de; Biwen Li > biwen.li@nxp.com Subject: [EXT] Re: [U-Boot] [PATCH 1/2] > dm: i2c: Add a flag that not call i2c_setup_offset > > On Thu, 30 May 2019 18:31:48 +0800 Chuanhua Han > chuanhua.han@nxp.com wrote: > > > Usually the i2c bus needs to write the address of the > > register before reading the internal register data of the > > device (ignoring the transmission of the slave address). > > > > Generally, the stop signal is not needed before the > > register is read, but there is a special chip that needs > > this stop signal (such as pcf2127). However, in the > > current i2c general code, the dm_i2c_read api encapsulates > > two messages, the first time is to set the register > > address message, the second time is a message to read the > > register data, so that no stop signal is generated. > > > > This patch uses the DM_I2C_CHIP_RD_NO_I2C_SETUP_OFFSET > > flag for specific i2c chips, so if the i2c slave requires > > a stop signal, chips driver can set this flag, then call > > the dm_i2c_write to set the register address (a stop > > signal is generated after this API call), then call > > dm_i2c_read to read the register data. > > > > Signed-off-by: Chuanhua Han chuanhua.han@nxp.com > > --- > > Changes in v3: > > - Use the new flag > > DM_I2C_CHIP_RD_NO_I2C_SETUP_OFFSET > > > > Changes in v2: > > - Split the original patch into 3 patches > > - Add detailed description information for each > > patch > > > > drivers/i2c/i2c-uclass.c | 6 ++++-- > > include/i2c.h | 1 + > > 2 files changed, 5 insertions(+), 2 deletions(-) > > > > diff --git a/drivers/i2c/i2c-uclass.c > > b/drivers/i2c/i2c-uclass.c index e47abf1833..9804b5e8c7 > > 100644 --- a/drivers/i2c/i2c-uclass.c > > +++ b/drivers/i2c/i2c-uclass.c > > @@ -135,8 +135,10 @@ int dm_i2c_read(struct udevice *dev, > > uint offset, uint8_t *buffer, int len) if (chip->flags & > > DM_I2C_CHIP_RD_ADDRESS) return i2c_read_bytewise(dev, > > offset, buffer, len); ptr = msg; > > - if (!i2c_setup_offset(chip, offset, offset_buf, > > ptr)) > > - ptr++; > > + if (!(chip->flags & > > DM_I2C_CHIP_RD_NO_I2C_SETUP_OFFSET)) { > > + if (!i2c_setup_offset(chip, offset, > > offset_buf, ptr)) > > + ptr++; > > + } > > > > if (len) { > > ptr->addr = chip->chip_addr; diff --git a/include/i2c.h > > b/include/i2c.h index > > a5c760c711..3123cbf280 100644 > > --- a/include/i2c.h > > +++ b/include/i2c.h > > @@ -28,6 +28,7 @@ enum dm_i2c_chip_flags { > > DM_I2C_CHIP_10BIT = 1 << 0, > > /* Use 10-bit addressing */ > > DM_I2C_CHIP_RD_ADDRESS = 1 << 1, > > /* Send address for each read byte */ > > DM_I2C_CHIP_WR_ADDRESS = 1 << 2, > > /* Send address for each write byte */ > > Aren't those two above flags describe exactly what you need? > They send address for each read/written byte. (or do you > need to send more than a single byte)? This is not what I need. I need to generate a stop signal after setting the register address,
so I need the following flag. > > > DM_I2C_CHIP_RD_NO_I2C_SETUP_OFFSET = 1 << 3,
In this way, although each byte will send the slave address, this does not correspond to the timing of pcf2127. Also, there is no stop signal after setting the register address. The chip also doesn't work.
Yes,one byte
> > /* No i2c_setup_offset*/ }; > > > > struct udevice; > > > > > Best regards, > > Lukasz Majewski > > -- > > DENX Software Engineering GmbH, Managing Director: > Wolfgang Denk HRB 165235 Munich, Office: Kirchenstr.5, > D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-59 Fax: > (+49)-8142-66989-80 Email: lukma@denx.de
Lukasz Majewski
Lukasz Majewski
Lukasz Majewski
Hi Chuanhua,
> > -----Original Message----- > > From: Lukasz Majewski lukma@denx.de > > Sent: 2019年6月4日 6:08 > > To: Chuanhua Han chuanhua.han@nxp.com > > Cc: hs@denx.de; u-boot@lists.denx.de; Biwen Li > > biwen.li@nxp.com Subject: [EXT] Re: [U-Boot] [PATCH > > 1/2] dm: i2c: Add a flag that not call i2c_setup_offset > > > > On Thu, 30 May 2019 18:31:48 +0800 Chuanhua Han > > chuanhua.han@nxp.com wrote: > > > > > Usually the i2c bus needs to write the address of the > > > register before reading the internal register data of > > > the device (ignoring the transmission of the slave > > > address). > > > > > > Generally, the stop signal is not needed before the > > > register is read, but there is a special chip that > > > needs this stop signal (such as pcf2127). However, in > > > the current i2c general code, the dm_i2c_read api > > > encapsulates two messages, the first time is to set > > > the register address message, the second time is a > > > message to read the register data, so that no stop > > > signal is generated. > > > > > > This patch uses the DM_I2C_CHIP_RD_NO_I2C_SETUP_OFFSET > > > flag for specific i2c chips, so if the i2c slave > > > requires a stop signal, chips driver can set this > > > flag, then call the dm_i2c_write to set the register > > > address (a stop signal is generated after this API > > > call), then call dm_i2c_read to read the register > > > data. > > > > > > Signed-off-by: Chuanhua Han chuanhua.han@nxp.com > > > --- > > > Changes in v3: > > > - Use the new flag > > > DM_I2C_CHIP_RD_NO_I2C_SETUP_OFFSET > > > > > > Changes in v2: > > > - Split the original patch into 3 patches > > > - Add detailed description information for > > > each patch > > > > > > drivers/i2c/i2c-uclass.c | 6 ++++-- > > > include/i2c.h | 1 + > > > 2 files changed, 5 insertions(+), 2 deletions(-) > > > > > > diff --git a/drivers/i2c/i2c-uclass.c > > > b/drivers/i2c/i2c-uclass.c index > > > e47abf1833..9804b5e8c7 100644 --- > > > a/drivers/i2c/i2c-uclass.c +++ > > > b/drivers/i2c/i2c-uclass.c @@ -135,8 +135,10 @@ int > > > dm_i2c_read(struct udevice *dev, uint offset, uint8_t > > > *buffer, int len) if (chip->flags & > > > DM_I2C_CHIP_RD_ADDRESS) return i2c_read_bytewise(dev, > > > offset, buffer, len); ptr = msg; > > > - if (!i2c_setup_offset(chip, offset, > > > offset_buf, ptr)) > > > - ptr++; > > > + if (!(chip->flags & > > > DM_I2C_CHIP_RD_NO_I2C_SETUP_OFFSET)) { > > > + if (!i2c_setup_offset(chip, offset, > > > offset_buf, ptr)) > > > + ptr++; > > > + } > > > > > > if (len) { > > > ptr->addr = chip->chip_addr; diff > > > --git a/include/i2c.h b/include/i2c.h index > > > a5c760c711..3123cbf280 100644 > > > --- a/include/i2c.h > > > +++ b/include/i2c.h > > > @@ -28,6 +28,7 @@ enum dm_i2c_chip_flags { > > > DM_I2C_CHIP_10BIT = 1 << 0, > > > /* Use 10-bit addressing */ > > > DM_I2C_CHIP_RD_ADDRESS = 1 << 1, > > > /* Send address for each read byte */ > > > DM_I2C_CHIP_WR_ADDRESS = 1 << 2, > > > /* Send address for each write byte */ > > > > Aren't those two above flags describe exactly what you > > need? They send address for each read/written byte. (or > > do you need to send more than a single byte)? > This is not what I need. I need to generate a stop signal > after setting the register address,
> so I need the following flag. > > > > > DM_I2C_CHIP_RD_NO_I2C_SETUP_OFFSET = 1 << 3,
I don't mind to add new flag - It is OK.
Please only name it properly - like DM_I2C_CHIP_ADDR_STOP - to be generic enough so other IC's with similar issue can re-use it.
Yes,one byte
> > > /* No i2c_setup_offset*/ }; > > > > > > struct udevice; > > > > > > > > > > Best regards, > > > > Lukasz Majewski > > > > -- > > > > DENX Software Engineering GmbH, Managing Director: > > Wolfgang Denk HRB 165235 Munich, Office: Kirchenstr.5, > > D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-59 > > Fax: (+49)-8142-66989-80 Email: lukma@denx.de
Lukasz Majewski
Lukasz Majewski
Lukasz Majewski
Lukasz Majewski
Yes,one byte
Lukasz Majewski
Lukasz Majewski
Lukasz Majewski
Hi, I have already replied to your question, are there any other questions? I look forward to your reply, please review! Thank you
Biwen Li
Chuanhua Han
Lukasz Majewski
