[PATCH v2 00/14] toradex: imx: fixes and updates for v2020.10
This is the common combined patch-series, which superseeds [1], [2], [3].
Includes: 1. Fixes for splash screen logo drawing in Colibri iMX7/iMX6ULL. 2. Support for EEPROM as a storage for the main Toradex config block and additional config blocks on extra EEPROM chips (on carrier board or video adapters). 3. DDRC size fixes in A7-M4 mapping table for bootaux command.
v2: - Сombine [1], [2], [3] into one patch-series. - Correct strings for carrier board names/adapters. - Fix display timings, sync with downstream Toradex Linux.
[1]: https://patchwork.ozlabs.org/project/uboot/list/?series=185024 [2]: https://patchwork.ozlabs.org/project/uboot/list/?series=185100 [3]: https://patchwork.ozlabs.org/project/uboot/list/?series=185354
Igor Opaniuk (14): imx: mx7: fix DDRC size in A7-M4 mapping table toradex: tdx-cfg-block: add EEPROM read/store wrappers toradex: tdx-cfg-block: add carrier boards and display adapters toradex: tdx-cfg-block: add support for EEPROM toradex: tdx-cfg-clock: add migration routine from PID8 toradex: tdx-cfg-block: add carrier board info printing ARM: dts: imx8mm-verdin: eeprom nodes adjustments verdin-imx8mm: add EEPROM support for carrier board ARM: dts: imx6ull-colibri: move u-boot specific node toradex: common: show boot logo ARM: dts: imx7-colibri: multiple node updates colibri-imx6ull: show boot logo colibri-imx6ull: fix splash screen logo drawing colibri-imx7: fix splash logo drawing
arch/arm/dts/imx6ull-colibri-u-boot.dtsi | 45 ++ arch/arm/dts/imx6ull-colibri.dtsi | 43 -- arch/arm/dts/imx7-colibri-emmc.dts | 2 +- arch/arm/dts/imx7-colibri-rawnand.dts | 10 +- arch/arm/dts/imx7-colibri-u-boot.dtsi | 39 ++ arch/arm/dts/imx7-colibri.dtsi | 65 ++- arch/arm/dts/imx8mm-verdin.dts | 22 +- arch/arm/mach-imx/mx7/soc.c | 2 +- .../toradex/colibri-imx6ull/colibri-imx6ull.c | 40 +- board/toradex/colibri_imx7/MAINTAINERS | 1 + board/toradex/colibri_imx7/colibri_imx7.c | 44 +- board/toradex/common/Kconfig | 18 + board/toradex/common/Makefile | 1 + board/toradex/common/tdx-cfg-block.c | 402 ++++++++++++++++-- board/toradex/common/tdx-cfg-block.h | 16 + board/toradex/common/tdx-common.c | 54 +++ board/toradex/common/tdx-common.h | 4 + board/toradex/common/tdx-eeprom.c | 90 ++++ board/toradex/common/tdx-eeprom.h | 14 + board/toradex/verdin-imx8mm/Kconfig | 6 + configs/colibri-imx6ull_defconfig | 1 + configs/colibri_imx7_defconfig | 2 + configs/colibri_imx7_emmc_defconfig | 2 + configs/verdin-imx8mm_defconfig | 1 + 24 files changed, 730 insertions(+), 194 deletions(-) create mode 100644 arch/arm/dts/imx7-colibri-u-boot.dtsi create mode 100644 board/toradex/common/tdx-eeprom.c create mode 100644 board/toradex/common/tdx-eeprom.h
According to i.MX 7Solo Applications Processor Reference Manual, 2.1.3 Cortex-M4 Memory Map, M4 can address only 1536MB of DDRC (Start Address: 0x8000_0000; End Address: 0xDFFF_FFFF). Correct DDRC size to 0x60000000.
Fixes: c0f037f6("mach-imx: bootaux: elf firmware support") Signed-off-by: Igor Opaniuk igor.opaniuk@toradex.com ---
(no changes since v1)
arch/arm/mach-imx/mx7/soc.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/arm/mach-imx/mx7/soc.c b/arch/arm/mach-imx/mx7/soc.c index 798fe74a3d..9cb61f5c34 100644 --- a/arch/arm/mach-imx/mx7/soc.c +++ b/arch/arm/mach-imx/mx7/soc.c @@ -218,7 +218,7 @@ const struct rproc_att hostmap[] = { { 0x00940000, 0x00940000, 0x20000 }, /* OCRAM_PXP */ { 0x20240000, 0x00940000, 0x20000 }, /* OCRAM_PXP */ { 0x10000000, 0x80000000, 0x0fff0000 }, /* DDR Code alias */ - { 0x80000000, 0x80000000, 0xe0000000 }, /* DDRC */ + { 0x80000000, 0x80000000, 0x60000000 }, /* DDRC */ { /* sentinel */ } }; #endif
From: Igor Opaniuk igor.opaniuk@toradex.com According to i.MX 7Solo Applications Processor Reference Manual, 2.1.3 Cortex-M4 Memory Map, M4 can address only 1536MB of DDRC (Start Address: 0x8000_0000; End Address: 0xDFFF_FFFF). Correct DDRC size to 0x60000000. Fixes: c0f037f6("mach-imx: bootaux: elf firmware support") Signed-off-by: Igor Opaniuk igor.opaniuk@toradex.com
Best regards, Stefano Babic
These functions wrap functionality for storing config blocks in EEPROM.
board/toradex/common/Makefile | 1 + board/toradex/common/tdx-eeprom.c | 90 +++++++++++++++++++++++++++++++ board/toradex/common/tdx-eeprom.h | 14 +++++ 3 files changed, 105 insertions(+) create mode 100644 board/toradex/common/tdx-eeprom.c create mode 100644 board/toradex/common/tdx-eeprom.h
diff --git a/board/toradex/common/Makefile b/board/toradex/common/Makefile index 6b9fccb6b9..7b19b6e4c8 100644 --- a/board/toradex/common/Makefile +++ b/board/toradex/common/Makefile @@ -8,4 +8,5 @@ obj- := __dummy__.o else obj-$(CONFIG_TDX_CFG_BLOCK) += tdx-cfg-block.o obj-y += tdx-common.o +obj-y += tdx-eeprom.o endif diff --git a/board/toradex/common/tdx-eeprom.c b/board/toradex/common/tdx-eeprom.c new file mode 100644 index 0000000000..fbc267dab6 --- /dev/null +++ b/board/toradex/common/tdx-eeprom.c @@ -0,0 +1,90 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (c) 2020 Toradex + */ + +#include <dm.h> +#include <i2c_eeprom.h> +#include <linux/errno.h> + +DECLARE_GLOBAL_DATA_PTR; + +static int get_tdx_eeprom(u32 eeprom_id, struct udevice **devp) +{ + int ret = 0; + int node; + ofnode eeprom; + char eeprom_str[16]; + const char *path; + + if (!gd->fdt_blob) { + printf("%s: don't have a valid gd->fdt_blob!\n", __func__); + return -EFAULT; + } + + node = fdt_path_offset(gd->fdt_blob, "/aliases"); + if (node < 0) + return -ENODEV; + + sprintf(eeprom_str, "eeprom%d", eeprom_id); + + path = fdt_getprop(gd->fdt_blob, node, eeprom_str, NULL); + if (!path) { + printf("%s: no alias for %s\n", __func__, eeprom_str); + return -ENODEV; + } + + eeprom = ofnode_path(path); + if (!ofnode_valid(eeprom)) { + printf("%s: invalid hardware path to EEPROM\n", __func__); + return -ENODEV; + } + + ret = uclass_get_device_by_ofnode(UCLASS_I2C_EEPROM, eeprom, devp); + if (ret) { + printf("%s: cannot find EEPROM by node\n", __func__); + return ret; + } + + return ret; +} + +int read_tdx_eeprom_data(u32 eeprom_id, int offset, u8 *buf, + int size) +{ + struct udevice *dev; + int ret; + + ret = get_tdx_eeprom(eeprom_id, &dev); + if (ret) + return ret; + + ret = i2c_eeprom_read(dev, 0x0, buf, size); + if (ret) { + printf("%s: error reading data from EEPROM id: %d!, ret = %d\n", + __func__, eeprom_id, ret); + return ret; + } + + return ret; +} + +int write_tdx_eeprom_data(u32 eeprom_id, int offset, u8 *buf, + int size) +{ + struct udevice *dev; + int ret; + + ret = get_tdx_eeprom(eeprom_id, &dev); + if (ret) + return ret; + + ret = i2c_eeprom_write(dev, 0x0, buf, size); + if (ret) { + printf("%s: error writing data to EEPROM id: %d, ret = %d\n", + __func__, eeprom_id, ret); + return ret; + } + + return ret; +} diff --git a/board/toradex/common/tdx-eeprom.h b/board/toradex/common/tdx-eeprom.h new file mode 100644 index 0000000000..a6772d2f3f --- /dev/null +++ b/board/toradex/common/tdx-eeprom.h @@ -0,0 +1,14 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright (c) 2020 Toradex + */ + +#ifndef _TDX_EEPROM_H +#define _TDX_EEPROM_H + +#include <i2c_eeprom.h> + +int read_tdx_eeprom_data(u32 eeprom_id, int offset, uint8_t *buf, int size); +int write_tdx_eeprom_data(u32 eeprom_id, int offset, uint8_t *buf, int size); + +#endif /* _TDX_EEPROM_H */
Hi Igor,
This breaks one of your (obsolete ?) board, colibri_pxa270
Reason is a side-effect in dm/read.h:
arm: + colibri_pxa270 +In file included from include/dm.h:12, + from board/toradex/common/tdx-eeprom.c:6: +include/dm/read.h: In function 'dev_read_alias_seq': +include/dm/read.h:932:10: error: 'ENOTSUPP' undeclared (first use in this function) + 932 | return -ENOTSUPP; + | ^~~~~~~~ +include/dm/read.h:932:10: note: each undeclared identifier is reported only once for each function it appears in +make[2]: *** [scripts/Makefile.build:266: board/toradex/common/tdx-eeprom.o] Error 1 +make[1]: *** [Makefile:1793: board/toradex/common] Error 2 +make: *** [Makefile:167: sub-make] Error 2
Adding the include to dm/read.h, issue is solved:
diff --git a/include/dm/read.h b/include/dm/read.h index f02ec95954..cc4ab22f65 100644 --- a/include/dm/read.h +++ b/include/dm/read.h @@ -12,6 +12,7 @@ #include <dm/fdtaddr.h> #include <dm/ofnode.h> #include <dm/uclass.h> +#include <linux/errno.h>
struct resource;
I could add it myself if there is a general agreement, but the usual way is to repost it.
- Copyright (c) 2020 Toradex
- int ret = 0;
- int node;
- ofnode eeprom;
- char eeprom_str[16];
- const char *path;
- if (!gd->fdt_blob) {
return -EFAULT;
- node = fdt_path_offset(gd->fdt_blob, "/aliases");
- if (node < 0)
return -ENODEV;
- sprintf(eeprom_str, "eeprom%d", eeprom_id);
- path = fdt_getprop(gd->fdt_blob, node, eeprom_str, NULL);
- if (!path) {
return -ENODEV;
- eeprom = ofnode_path(path);
- if (!ofnode_valid(eeprom)) {
return -ENODEV;
- ret = uclass_get_device_by_ofnode(UCLASS_I2C_EEPROM, eeprom, devp);
- if (ret) {
return ret;
- return ret;
int size)
- struct udevice *dev;
- int ret;
- ret = get_tdx_eeprom(eeprom_id, &dev);
- if (ret)
return ret;
- ret = i2c_eeprom_read(dev, 0x0, buf, size);
- if (ret) {
return ret;
- return ret;
int size)
- int ret;
- if (ret)
return ret;
- ret = i2c_eeprom_write(dev, 0x0, buf, size);
- if (ret) {
return ret;
- return ret;
On Mon, Jul 27, 2020 at 02:49:30PM +0200, Stefano Babic wrote:
Hi Igor,
- 932 | return -ENOTSUPP;
struct resource;
This is also fixed by: http://patchwork.ozlabs.org/project/uboot/patch/20200723120138.10625-1-dmurp... as Dan also ran in to this problem. I assigned it to Simon but if you want to take it as part of being able to pick up Igor's series now I'm sure that's fine. Thanks!
Hi Igor,
struct resource;
Fine, thanks ! I pick up Dan's.
Stefano
From: Igor Opaniuk igor.opaniuk@toradex.com These functions wrap functionality for storing config blocks in EEPROM. Signed-off-by: Igor Opaniuk igor.opaniuk@toradex.com
Add defines for supported carrier boards and display adapters.
board/toradex/common/tdx-cfg-block.c | 12 ++++++++++++ board/toradex/common/tdx-cfg-block.h | 11 +++++++++++ 2 files changed, 23 insertions(+)
diff --git a/board/toradex/common/tdx-cfg-block.c b/board/toradex/common/tdx-cfg-block.c index 75216ecf6d..adf67216c6 100644 --- a/board/toradex/common/tdx-cfg-block.c +++ b/board/toradex/common/tdx-cfg-block.c @@ -124,6 +124,18 @@ const char * const toradex_modules[] = { [57] = "Verdin iMX8M Mini DualLite 1GB", };
+const char * const toradex_carrier_boards[] = { + [0] = "UNKNOWN CARRIER BOARD", + [155] = "Dahlia", + [156] = "Verdin Development Board", +}; + +const char * const toradex_display_adapters[] = { + [0] = "UNKNOWN DISPLAY ADAPTER", + [157] = "Verdin DSI to HDMI Adapter", + [159] = "Verdin DSI to LVDS Adapter", +}; + #ifdef CONFIG_TDX_CFG_BLOCK_IS_IN_MMC static int tdx_cfg_block_mmc_storage(u8 *config_block, int write) { diff --git a/board/toradex/common/tdx-cfg-block.h b/board/toradex/common/tdx-cfg-block.h index d8f3941f26..d58be23abb 100644 --- a/board/toradex/common/tdx-cfg-block.h +++ b/board/toradex/common/tdx-cfg-block.h @@ -80,7 +80,18 @@ enum { VERDIN_IMX8MMDL, };
+enum { + DAHLIA = 155, + VERDIN_DEVELOPMENT_BOARD = 156, +}; + +enum { + VERDIN_DSI_TO_HDMI_ADAPTER = 157, + VERDIN_DSI_TO_LVDS_ADAPTER = 159, +}; + extern const char * const toradex_modules[]; +extern const char * const toradex_carrier_boards[]; extern bool valid_cfgblock; extern struct toradex_hw tdx_hw_tag; extern struct toradex_eth_addr tdx_eth_addr;
From: Igor Opaniuk igor.opaniuk@toradex.com Add defines for supported carrier boards and display adapters. Signed-off-by: Igor Opaniuk igor.opaniuk@toradex.com
This introduces support for EEPROM as a storage for the main Toradex config block and additional config blocks on extra EEPROM chips (on carrier board or video adapters).
To enable EEPROM as a storage for the main config block: TDX_HAVE_EEPROM=y.
For additional EEPROMs please enable this Kconfig symbol: TDX_CFG_BLOCK_EXTRA=y.
Information about existing EEPROM chips is provided via Device Tree using aliases.
You can also write configuration for the carrier board using create_carrier subcommand for cfgblock. Example:
Verdin iMX8MM # cfgblock create_carrier Supported carrier boards: UNKNOWN CARRIER = [0] Verdin Carrier Board = [1] Choose your carrier board (provide ID): 1 Enter carrier board version (e.g. V1.1B): V1.0A Enter carrier board serial number: 10622780
Also with barcode: Verdin iMX8MM # cfgblock create carrier -y 0156100010622780
board/toradex/common/Kconfig | 18 ++ board/toradex/common/tdx-cfg-block.c | 312 +++++++++++++++++++++++---- board/toradex/common/tdx-cfg-block.h | 3 + 3 files changed, 294 insertions(+), 39 deletions(-)
diff --git a/board/toradex/common/Kconfig b/board/toradex/common/Kconfig index 11f4aab359..36068d2e3b 100644 --- a/board/toradex/common/Kconfig +++ b/board/toradex/common/Kconfig @@ -20,6 +20,12 @@ config TDX_HAVE_NAND config TDX_HAVE_NOR bool
+config TDX_HAVE_EEPROM + bool + +config TDX_HAVE_EEPROM_EXTRA + bool + if TDX_CFG_BLOCK
config TDX_CFG_BLOCK_IS_IN_MMC @@ -37,6 +43,11 @@ config TDX_CFG_BLOCK_IS_IN_NOR depends on TDX_HAVE_NOR default y
+config TDX_CFG_BLOCK_IS_IN_EEPROM + bool + depends on TDX_HAVE_EEPROM + default y + config TDX_CFG_BLOCK_DEV int "Toradex config block eMMC device ID" depends on TDX_CFG_BLOCK_IS_IN_MMC @@ -66,4 +77,11 @@ config TDX_CFG_BLOCK_2ND_ETHADDR Ethernet carrier boards. This options enables the code to set the second Ethernet address as environment variable (eth1addr).
+config TDX_CFG_BLOCK_EXTRA + bool "Support for additional EEPROMs (carrier board, display adapter)" + depends on TDX_HAVE_EEPROM_EXTRA + help + Enables fetching auxilary config blocks from carrier board/display + adapter EEPROMs. + endif diff --git a/board/toradex/common/tdx-cfg-block.c b/board/toradex/common/tdx-cfg-block.c index adf67216c6..5162ed48b8 100644 --- a/board/toradex/common/tdx-cfg-block.c +++ b/board/toradex/common/tdx-cfg-block.c @@ -5,6 +5,8 @@
#include <common.h> #include "tdx-cfg-block.h" +#include "tdx-eeprom.h" + #include <command.h> #include <asm/cache.h>
@@ -37,21 +39,31 @@ DECLARE_GLOBAL_DATA_PTR;
#define TAG_VALID 0xcf01 #define TAG_MAC 0x0000 +#define TAG_CAR_SERIAL 0x0021 #define TAG_HW 0x0008 #define TAG_INVALID 0xffff
#define TAG_FLAG_VALID 0x1
+#define TDX_EEPROM_ID_MODULE 0 +#define TDX_EEPROM_ID_CARRIER 1 + #if defined(CONFIG_TDX_CFG_BLOCK_IS_IN_MMC) #define TDX_CFG_BLOCK_MAX_SIZE 512 #elif defined(CONFIG_TDX_CFG_BLOCK_IS_IN_NAND) #define TDX_CFG_BLOCK_MAX_SIZE 64 #elif defined(CONFIG_TDX_CFG_BLOCK_IS_IN_NOR) #define TDX_CFG_BLOCK_MAX_SIZE 64 +#elif defined(CONFIG_TDX_CFG_BLOCK_IS_IN_EEPROM) +#define TDX_CFG_BLOCK_MAX_SIZE 64 #else #error Toradex config block location not set #endif
+#ifdef CONFIG_TDX_CFG_BLOCK_EXTRA +#define TDX_CFG_BLOCK_EXTRA_MAX_SIZE 64 +#endif + struct toradex_tag { u32 len:14; u32 flags:2; @@ -62,6 +74,11 @@ bool valid_cfgblock; struct toradex_hw tdx_hw_tag; struct toradex_eth_addr tdx_eth_addr; u32 tdx_serial; +#ifdef CONFIG_TDX_CFG_BLOCK_EXTRA +u32 tdx_car_serial; +bool valid_cfgblock_carrier; +struct toradex_hw tdx_car_hw_tag; +#endif
const char * const toradex_modules[] = { [0] = "UNKNOWN MODULE", @@ -236,6 +253,20 @@ static int write_tdx_cfg_block_to_nor(unsigned char *config_block) } #endif
+#ifdef CONFIG_TDX_CFG_BLOCK_IS_IN_EEPROM +static int read_tdx_cfg_block_from_eeprom(unsigned char *config_block) +{ + return read_tdx_eeprom_data(TDX_EEPROM_ID_MODULE, 0x0, config_block, + TDX_CFG_BLOCK_MAX_SIZE); +} + +static int write_tdx_cfg_block_to_eeprom(unsigned char *config_block) +{ + return write_tdx_eeprom_data(TDX_EEPROM_ID_MODULE, 0x0, config_block, + TDX_CFG_BLOCK_MAX_SIZE); +} +#endif + int read_tdx_cfg_block(void) { int ret = 0; @@ -259,6 +290,8 @@ int read_tdx_cfg_block(void) ret = read_tdx_cfg_block_from_nand(config_block); #elif defined(CONFIG_TDX_CFG_BLOCK_IS_IN_NOR) ret = read_tdx_cfg_block_from_nor(config_block); +#elif defined(CONFIG_TDX_CFG_BLOCK_IS_IN_EEPROM) + ret = read_tdx_cfg_block_from_eeprom(config_block); #else ret = -EINVAL; #endif @@ -275,7 +308,12 @@ int read_tdx_cfg_block(void) valid_cfgblock = true; offset = 4;
- while (offset < TDX_CFG_BLOCK_MAX_SIZE) { + /* + * check if there is enough space for storing tag and value of the + * biggest element + */ + while (offset + sizeof(struct toradex_tag) + + sizeof(struct toradex_hw) < TDX_CFG_BLOCK_MAX_SIZE) { tag = (struct toradex_tag *)(config_block + offset); offset += 4; if (tag->id == TAG_INVALID) @@ -334,7 +372,6 @@ static int get_cfgblock_interactive(void) it = 'y'; #endif
- #if defined(CONFIG_TARGET_APALIS_IMX8) || \ defined(CONFIG_TARGET_APALIS_IMX8X) || \ defined(CONFIG_TARGET_COLIBRI_IMX6ULL) || \ @@ -505,7 +542,8 @@ static int get_cfgblock_interactive(void) return 0; }
-static int get_cfgblock_barcode(char *barcode) +static int get_cfgblock_barcode(char *barcode, struct toradex_hw *tag, + u32 *serial) { if (strlen(barcode) < 16) { printf("Argument too short, barcode is 16 chars long\n"); @@ -513,31 +551,154 @@ static int get_cfgblock_barcode(char *barcode) }
/* Get hardware information from the first 8 digits */ - tdx_hw_tag.ver_major = barcode[4] - '0'; - tdx_hw_tag.ver_minor = barcode[5] - '0'; - tdx_hw_tag.ver_assembly = barcode[7] - '0'; + tag->ver_major = barcode[4] - '0'; + tag->ver_minor = barcode[5] - '0'; + tag->ver_assembly = barcode[7] - '0';
barcode[4] = '\0'; - tdx_hw_tag.prodid = simple_strtoul(barcode, NULL, 10); + tag->prodid = simple_strtoul(barcode, NULL, 10);
/* Parse second part of the barcode (serial number */ barcode += 8; - tdx_serial = simple_strtoul(barcode, NULL, 10); + *serial = simple_strtoul(barcode, NULL, 10);
return 0; }
-static int do_cfgblock_create(struct cmd_tbl *cmdtp, int flag, int argc, - char *const argv[]) +static int write_tag(u8 *config_block, int *offset, int tag_id, + u8 *tag_data, size_t tag_data_size) { - u8 *config_block; struct toradex_tag *tag; - size_t size = TDX_CFG_BLOCK_MAX_SIZE; + + if (!offset || !config_block) + return -EINVAL; + + tag = (struct toradex_tag *)(config_block + *offset); + tag->id = tag_id; + tag->flags = TAG_FLAG_VALID; + /* len is provided as number of 32bit values after the tag */ + tag->len = (tag_data_size + sizeof(u32) - 1) / sizeof(u32); + *offset += sizeof(struct toradex_tag); + if (tag_data && tag_data_size) { + memcpy(config_block + *offset, tag_data, + tag_data_size); + *offset += tag_data_size; + } + + return 0; +} + +#ifdef CONFIG_TDX_CFG_BLOCK_EXTRA +int read_tdx_cfg_block_carrier(void) +{ + int ret = 0; + u8 *config_block = NULL; + struct toradex_tag *tag; + size_t size = TDX_CFG_BLOCK_EXTRA_MAX_SIZE; + int offset; + + /* Allocate RAM area for carrier config block */ + config_block = memalign(ARCH_DMA_MINALIGN, size); + if (!config_block) { + printf("Not enough malloc space available!\n"); + return -ENOMEM; + } + + memset(config_block, 0, size); + + ret = read_tdx_eeprom_data(TDX_EEPROM_ID_CARRIER, 0x0, config_block, + size); + if (ret) + return ret; + + /* Expect a valid tag first */ + tag = (struct toradex_tag *)config_block; + if (tag->flags != TAG_FLAG_VALID || tag->id != TAG_VALID) { + valid_cfgblock_carrier = false; + ret = -EINVAL; + goto out; + } + valid_cfgblock_carrier = true; + offset = 4; + + while (offset + sizeof(struct toradex_tag) + + sizeof(struct toradex_hw) < TDX_CFG_BLOCK_MAX_SIZE) { + tag = (struct toradex_tag *)(config_block + offset); + offset += 4; + if (tag->id == TAG_INVALID) + break; + + if (tag->flags == TAG_FLAG_VALID) { + switch (tag->id) { + case TAG_CAR_SERIAL: + memcpy(&tdx_car_serial, config_block + offset, + sizeof(tdx_car_serial)); + break; + case TAG_HW: + memcpy(&tdx_car_hw_tag, config_block + + offset, 8); + break; + } + } + + /* Get to next tag according to current tags length */ + offset += tag->len * 4; + } +out: + free(config_block); + return ret; +} + +static int get_cfgblock_carrier_interactive(void) +{ + char message[CONFIG_SYS_CBSIZE]; + int len; + + printf("Supported carrier boards:\n"); + printf("CARRIER BOARD NAME\t\t [ID]\n"); + for (int i = 0; i < sizeof(toradex_carrier_boards) / + sizeof(toradex_carrier_boards[0]); i++) + if (toradex_carrier_boards[i]) + printf("%s \t\t [%d]\n", toradex_carrier_boards[i], i); + + sprintf(message, "Choose your carrier board (provide ID): "); + len = cli_readline(message); + tdx_car_hw_tag.prodid = simple_strtoul(console_buffer, NULL, 10); + + do { + sprintf(message, "Enter carrier board version (e.g. V1.1B): V"); + len = cli_readline(message); + } while (len < 4); + + tdx_car_hw_tag.ver_major = console_buffer[0] - '0'; + tdx_car_hw_tag.ver_minor = console_buffer[2] - '0'; + tdx_car_hw_tag.ver_assembly = console_buffer[3] - 'A'; + + while (len < 8) { + sprintf(message, "Enter carrier board serial number: "); + len = cli_readline(message); + } + + tdx_car_serial = simple_strtoul(console_buffer, NULL, 10); + + return 0; +} + +static int do_cfgblock_carrier_create(struct cmd_tbl *cmdtp, int flag, int argc, + char * const argv[]) +{ + u8 *config_block; + size_t size = TDX_CFG_BLOCK_EXTRA_MAX_SIZE; int offset = 0; int ret = CMD_RET_SUCCESS; int err; int force_overwrite = 0;
+ if (argc >= 3) { + if (argv[2][0] == '-' && argv[2][1] == 'y') + force_overwrite = 1; + } + /* Allocate RAM area for config block */ config_block = memalign(ARCH_DMA_MINALIGN, size); if (!config_block) { @@ -546,12 +707,95 @@ static int do_cfgblock_create(struct cmd_tbl *cmdtp, int flag, int argc, }
memset(config_block, 0xff, size); + read_tdx_cfg_block_carrier(); + if (valid_cfgblock_carrier && !force_overwrite) { + char message[CONFIG_SYS_CBSIZE]; + + sprintf(message, "A valid Toradex Carrier config block is present, still recreate? [y/N] "); + + if (!cli_readline(message)) + goto out; + + if (console_buffer[0] != 'y' && + console_buffer[0] != 'Y') + goto out; + } + + if (argc < 3 || (force_overwrite && argc < 4)) { + err = get_cfgblock_carrier_interactive(); + } else { + if (force_overwrite) + err = get_cfgblock_barcode(argv[3], &tdx_car_hw_tag, + &tdx_car_serial); + else + err = get_cfgblock_barcode(argv[2], &tdx_car_hw_tag, + &tdx_car_serial); + } + + if (err) { + ret = CMD_RET_FAILURE; + goto out; + } + + /* Valid Tag */ + write_tag(config_block, &offset, TAG_VALID, NULL, 0); + + /* Product Tag */ + write_tag(config_block, &offset, TAG_HW, (u8 *)&tdx_car_hw_tag, + sizeof(tdx_car_hw_tag)); + + /* Serial Tag */ + write_tag(config_block, &offset, TAG_CAR_SERIAL, (u8 *)&tdx_car_serial, + sizeof(tdx_car_serial)); + + memset(config_block + offset, 0, 32 - offset); + err = write_tdx_eeprom_data(TDX_EEPROM_ID_CARRIER, 0x0, config_block, + size); + if (err) { + printf("Failed to write Toradex Extra config block: %d\n", + ret); + ret = CMD_RET_FAILURE; + goto out; + } + + printf("Toradex Extra config block successfully written\n"); + +out: + free(config_block); + return ret; +} + +#endif /* CONFIG_TDX_CFG_BLOCK_EXTRA */ + +static int do_cfgblock_create(struct cmd_tbl *cmdtp, int flag, int argc, + char * const argv[]) +{ + u8 *config_block; + size_t size = TDX_CFG_BLOCK_MAX_SIZE; + int offset = 0; + int ret = CMD_RET_SUCCESS; + int err; + int force_overwrite = 0;
if (argc >= 3) { +#ifdef CONFIG_TDX_CFG_BLOCK_EXTRA + if (!strcmp(argv[2], "carrier")) + return do_cfgblock_carrier_create(cmdtp, flag, + --argc, ++argv); +#endif /* CONFIG_TDX_CFG_BLOCK_EXTRA */ if (argv[2][0] == '-' && argv[2][1] == 'y') force_overwrite = 1; }
+ /* Allocate RAM area for config block */ + config_block = memalign(ARCH_DMA_MINALIGN, size); + if (!config_block) { + printf("Not enough malloc space available!\n"); + return CMD_RET_FAILURE; + } + + memset(config_block, 0xff, size); + read_tdx_cfg_block(); if (valid_cfgblock) { #if defined(CONFIG_TDX_CFG_BLOCK_IS_IN_NAND) @@ -593,9 +837,11 @@ static int do_cfgblock_create(struct cmd_tbl *cmdtp, int flag, int argc, err = get_cfgblock_interactive(); } else { if (force_overwrite) - err = get_cfgblock_barcode(argv[3]); + err = get_cfgblock_barcode(argv[3], &tdx_hw_tag, + &tdx_serial); else - err = get_cfgblock_barcode(argv[2]); + err = get_cfgblock_barcode(argv[2], &tdx_hw_tag, + &tdx_serial); } if (err) { ret = CMD_RET_FAILURE; @@ -607,39 +853,25 @@ static int do_cfgblock_create(struct cmd_tbl *cmdtp, int flag, int argc, tdx_eth_addr.nic = htonl(tdx_serial << 8);
/* Valid Tag */ - tag = (struct toradex_tag *)config_block; - tag->id = TAG_VALID; - tag->flags = TAG_FLAG_VALID; - tag->len = 0; - offset += 4; + write_tag(config_block, &offset, TAG_VALID, NULL, 0);
/* Product Tag */ - tag = (struct toradex_tag *)(config_block + offset); - tag->id = TAG_HW; - tag->flags = TAG_FLAG_VALID; - tag->len = 2; - offset += 4; - - memcpy(config_block + offset, &tdx_hw_tag, 8); - offset += 8; + write_tag(config_block, &offset, TAG_HW, (u8 *)&tdx_hw_tag, + sizeof(tdx_hw_tag));
/* MAC Tag */ - tag = (struct toradex_tag *)(config_block + offset); - tag->id = TAG_MAC; - tag->flags = TAG_FLAG_VALID; - tag->len = 2; - offset += 4; + write_tag(config_block, &offset, TAG_MAC, (u8 *)&tdx_eth_addr, + sizeof(tdx_eth_addr));
- memcpy(config_block + offset, &tdx_eth_addr, 6); - offset += 6; memset(config_block + offset, 0, 32 - offset); - #if defined(CONFIG_TDX_CFG_BLOCK_IS_IN_MMC) err = tdx_cfg_block_mmc_storage(config_block, 1); #elif defined(CONFIG_TDX_CFG_BLOCK_IS_IN_NAND) err = write_tdx_cfg_block_to_nand(config_block); #elif defined(CONFIG_TDX_CFG_BLOCK_IS_IN_NOR) err = write_tdx_cfg_block_to_nor(config_block); +#elif defined(CONFIG_TDX_CFG_BLOCK_IS_IN_EEPROM) + err = write_tdx_cfg_block_to_eeprom(config_block); #else err = -EINVAL; #endif @@ -679,8 +911,10 @@ static int do_cfgblock(struct cmd_tbl *cmdtp, int flag, int argc, return CMD_RET_USAGE; }
-U_BOOT_CMD(cfgblock, 4, 0, do_cfgblock, - "Toradex config block handling commands", - "create [-y] [barcode] - (Re-)create Toradex config block\n" - "cfgblock reload - Reload Toradex config block from flash" +U_BOOT_CMD( + cfgblock, 5, 0, do_cfgblock, + "Toradex config block handling commands", + "create [-y] [barcode] - (Re-)create Toradex config block\n" + "create carrier [-y] [barcode] - (Re-)create Toradex Carrier config block\n" + "cfgblock reload - Reload Toradex config block from flash" ); diff --git a/board/toradex/common/tdx-cfg-block.h b/board/toradex/common/tdx-cfg-block.h index d58be23abb..e18da3370e 100644 --- a/board/toradex/common/tdx-cfg-block.h +++ b/board/toradex/common/tdx-cfg-block.h @@ -94,9 +94,12 @@ extern const char * const toradex_modules[]; extern const char * const toradex_carrier_boards[]; extern bool valid_cfgblock; extern struct toradex_hw tdx_hw_tag; +extern struct toradex_hw tdx_car_hw_tag; extern struct toradex_eth_addr tdx_eth_addr; extern u32 tdx_serial; +extern u32 tdx_car_serial;
int read_tdx_cfg_block(void); +int read_tdx_cfg_block_carrier(void);
#endif /* _TDX_CFG_BLOCK_H */
From: Igor Opaniuk igor.opaniuk@toradex.com This introduces support for EEPROM as a storage for the main Toradex config block and additional config blocks on extra EEPROM chips (on carrier board or video adapters). To enable EEPROM as a storage for the main config block: TDX_HAVE_EEPROM=y. For additional EEPROMs please enable this Kconfig symbol: TDX_CFG_BLOCK_EXTRA=y. Information about existing EEPROM chips is provided via Device Tree using aliases. You can also write configuration for the carrier board using create_carrier subcommand for cfgblock. Example: Verdin iMX8MM # cfgblock create_carrier Supported carrier boards: UNKNOWN CARRIER = [0] Verdin Carrier Board = [1] Choose your carrier board (provide ID): 1 Enter carrier board version (e.g. V1.1B): V1.0A Enter carrier board serial number: 10622780 Also with barcode: Verdin iMX8MM # cfgblock create carrier -y 0156100010622780 Signed-off-by: Igor Opaniuk igor.opaniuk@toradex.com
Add migration routine from PID8 pre-stored values on EEPROM (including sane value checks).
board/toradex/common/tdx-cfg-block.c | 78 ++++++++++++++++++++++++++++ board/toradex/common/tdx-cfg-block.h | 2 + 2 files changed, 80 insertions(+)
diff --git a/board/toradex/common/tdx-cfg-block.c b/board/toradex/common/tdx-cfg-block.c index 5162ed48b8..bf27b2fa66 100644 --- a/board/toradex/common/tdx-cfg-block.c +++ b/board/toradex/common/tdx-cfg-block.c @@ -649,6 +649,84 @@ out: return ret; }
+int check_pid8_sanity(char *pid8) +{ + char s_carrierid_verdin_dev[5]; + char s_carrierid_dahlia[5]; + + sprintf(s_carrierid_verdin_dev, "0%d", VERDIN_DEVELOPMENT_BOARD); + sprintf(s_carrierid_dahlia, "0%d", DAHLIA); + + /* sane value check, first 4 chars which represent carrier id */ + if (!strncmp(pid8, s_carrierid_verdin_dev, 4)) + return 0; + + if (!strncmp(pid8, s_carrierid_dahlia, 4)) + return 0; + + return -EINVAL; +} + +int try_migrate_tdx_cfg_block_carrier(void) +{ + char pid8[8]; + int offset = 0; + int ret = CMD_RET_SUCCESS; + size_t size = TDX_CFG_BLOCK_EXTRA_MAX_SIZE; + u8 *config_block; + + memset(pid8, 0x0, 8); + ret = read_tdx_eeprom_data(TDX_EEPROM_ID_CARRIER, 0x0, (u8 *)pid8, 8); + if (ret) + return ret; + + if (check_pid8_sanity(pid8)) + return -EINVAL; + + /* Allocate RAM area for config block */ + config_block = memalign(ARCH_DMA_MINALIGN, size); + if (!config_block) { + printf("Not enough malloc space available!\n"); + return CMD_RET_FAILURE; + } + + memset(config_block, 0xff, size); + /* we try parse PID8 concatenating zeroed serial number */ + tdx_car_hw_tag.ver_major = pid8[4] - '0'; + tdx_car_hw_tag.ver_minor = pid8[5] - '0'; + tdx_car_hw_tag.ver_assembly = pid8[7] - '0'; + + pid8[4] = '\0'; + tdx_car_hw_tag.prodid = simple_strtoul(pid8, NULL, 10); + + /* Valid Tag */ + write_tag(config_block, &offset, TAG_VALID, NULL, 0); + + /* Product Tag */ + write_tag(config_block, &offset, TAG_HW, (u8 *)&tdx_car_hw_tag, + sizeof(tdx_car_hw_tag)); + + /* Serial Tag */ + write_tag(config_block, &offset, TAG_CAR_SERIAL, (u8 *)&tdx_car_serial, + sizeof(tdx_car_serial)); + + memset(config_block + offset, 0, 32 - offset); + ret = write_tdx_eeprom_data(TDX_EEPROM_ID_CARRIER, 0x0, config_block, + size); + if (ret) { + printf("Failed to write Toradex Extra config block: %d\n", + ret); + ret = CMD_RET_FAILURE; + goto out; + } + + printf("Successfully migrated to Toradex Config Block from PID8\n"); + +out: + free(config_block); + return ret; +} + static int get_cfgblock_carrier_interactive(void) { char message[CONFIG_SYS_CBSIZE]; diff --git a/board/toradex/common/tdx-cfg-block.h b/board/toradex/common/tdx-cfg-block.h index e18da3370e..8f91d9aec6 100644 --- a/board/toradex/common/tdx-cfg-block.h +++ b/board/toradex/common/tdx-cfg-block.h @@ -102,4 +102,6 @@ extern u32 tdx_car_serial; int read_tdx_cfg_block(void); int read_tdx_cfg_block_carrier(void);
+int try_migrate_tdx_cfg_block_carrier(void); + #endif /* _TDX_CFG_BLOCK_H */
From: Igor Opaniuk igor.opaniuk@toradex.com Add migration routine from PID8 pre-stored values on EEPROM (including sane value checks). Signed-off-by: Igor Opaniuk igor.opaniuk@toradex.com
Add carrier board info printing during boot time:
U-Boot 2020.07-rc4-02435-g1756e05 (Jun 22 2020 - 22:43:59 +0300)
CPU: Freescale i.MX8MMQ rev1.0 at 1200 MHz .... Carrier: Toradex Verdin Development Board V1.0A, Serial# 10622780 Verdin iMX8MM #
board/toradex/common/tdx-common.c | 28 ++++++++++++++++++++++++++++ 1 file changed, 28 insertions(+)
diff --git a/board/toradex/common/tdx-common.c b/board/toradex/common/tdx-common.c index e8de923f3e..7e353b4fd9 100644 --- a/board/toradex/common/tdx-common.c +++ b/board/toradex/common/tdx-common.c @@ -19,6 +19,12 @@ static char tdx_serial_str[9]; static char tdx_board_rev_str[6];
+#ifdef CONFIG_TDX_CFG_BLOCK_EXTRA +static char tdx_car_serial_str[9]; +static char tdx_car_rev_str[6]; +static char *tdx_carrier_board_name; +#endif + #ifdef CONFIG_REVISION_TAG u32 get_board_rev(void) { @@ -88,6 +94,28 @@ int show_board_info(void) toradex_modules[tdx_hw_tag.prodid], tdx_board_rev_str, tdx_serial_str); +#ifdef CONFIG_TDX_CFG_BLOCK_EXTRA + if (read_tdx_cfg_block_carrier()) { + printf("MISSING TORADEX CARRIER CONFIG BLOCKS\n"); + try_migrate_tdx_cfg_block_carrier(); + } else { + tdx_carrier_board_name = (char *) + toradex_carrier_boards[tdx_car_hw_tag.prodid]; + + sprintf(tdx_car_serial_str, "%08u", tdx_car_serial); + sprintf(tdx_car_rev_str, "V%1d.%1d%c", + tdx_car_hw_tag.ver_major, + tdx_car_hw_tag.ver_minor, + (char)tdx_car_hw_tag.ver_assembly + + 'A'); + + env_set("carrier_serial#", tdx_car_serial_str); + printf("Carrier: Toradex %s %s, Serial# %s\n", + tdx_carrier_board_name, + tdx_car_rev_str, + tdx_car_serial_str); + } +#endif }
From: Igor Opaniuk igor.opaniuk@toradex.com Add carrier board info printing during boot time: U-Boot 2020.07-rc4-02435-g1756e05 (Jun 22 2020 - 22:43:59 +0300) CPU: Freescale i.MX8MMQ rev1.0 at 1200 MHz .... Carrier: Toradex Verdin Development Board V1.0A, Serial# 10622780 Verdin iMX8MM # Signed-off-by: Igor Opaniuk igor.opaniuk@toradex.com
Rename EEPROM nodes. Create aliases for EEPROM to unify their order: eeprom0 - on-module EEPROM eeprom1 - carrier-board EEPROM eeprom2 - MIPI-DSI to HDMI adapter EEPROM
arch/arm/dts/imx8mm-verdin.dts | 22 ++++++++++++++-------- 1 file changed, 14 insertions(+), 8 deletions(-)
diff --git a/arch/arm/dts/imx8mm-verdin.dts b/arch/arm/dts/imx8mm-verdin.dts index b86f46e03e..1c67c08c88 100644 --- a/arch/arm/dts/imx8mm-verdin.dts +++ b/arch/arm/dts/imx8mm-verdin.dts @@ -16,6 +16,12 @@ stdout-path = &uart1; };
+ aliases { + eeprom0 = &eeprom_module; + eeprom1 = &eeprom_carrier_board; + eeprom2 = &eeprom_display_adapter; + }; + /* fixed clock dedicated to SPI CAN controller */ clk20m: oscillator { compatible = "fixed-clock"; @@ -321,8 +327,8 @@ vcc-supply = <&ldo5_reg>; };
- eeprom@50 { - compatible = "st,24c02"; + eeprom_module: eeprom@50 { + compatible = "st,24c02", "atmel,24c02", "i2c-eeprom"; pagesize = <16>; reg = <0x50>; }; @@ -377,16 +383,16 @@ status = "okay"; };
- /* EEPROM on MIPI-DSI to HDMI adapter */ - eeprom_50: eeprom@50 { - compatible = "st,24c02"; + /* EEPROM on display adapter (MIPI DSI Display Adapter) */ + eeprom_display_adapter: eeprom@50 { + compatible = "st,24c02", "atmel,24c02", "i2c-eeprom"; pagesize = <16>; reg = <0x50>; };
- /* EEPROM on Verdin Development board */ - eeprom_57: eeprom@57 { - compatible = "st,24c02"; + /* EEPROM on carrier board */ + eeprom_carrier_board: eeprom@57 { + compatible = "st,24c02", "atmel,24c02", "i2c-eeprom"; pagesize = <16>; reg = <0x57>; };
From: Igor Opaniuk igor.opaniuk@toradex.com Rename EEPROM nodes. Create aliases for EEPROM to unify their order: eeprom0 - on-module EEPROM eeprom1 - carrier-board EEPROM eeprom2 - MIPI-DSI to HDMI adapter EEPROM Signed-off-by: Igor Opaniuk igor.opaniuk@toradex.com
Enable these Kconfig symbols: TDX_CFG_BLOCK_EXTRA=y TDX_HAVE_EEPROM_EXTRA=y
board/toradex/verdin-imx8mm/Kconfig | 6 ++++++ configs/verdin-imx8mm_defconfig | 1 + 2 files changed, 7 insertions(+)
diff --git a/board/toradex/verdin-imx8mm/Kconfig b/board/toradex/verdin-imx8mm/Kconfig index 8a2fe98682..149aed6da7 100644 --- a/board/toradex/verdin-imx8mm/Kconfig +++ b/board/toradex/verdin-imx8mm/Kconfig @@ -12,9 +12,15 @@ config SYS_CONFIG_NAME config TDX_CFG_BLOCK default y
+config TDX_CFG_BLOCK_EXTRA + default y + config TDX_HAVE_MMC default y
+config TDX_HAVE_EEPROM_EXTRA + default y + config TDX_CFG_BLOCK_DEV default "0"
diff --git a/configs/verdin-imx8mm_defconfig b/configs/verdin-imx8mm_defconfig index 302345f17a..d1c951f122 100644 --- a/configs/verdin-imx8mm_defconfig +++ b/configs/verdin-imx8mm_defconfig @@ -74,6 +74,7 @@ CONFIG_MXC_GPIO=y CONFIG_DM_I2C=y CONFIG_SYS_I2C_MXC=y CONFIG_MISC=y +CONFIG_I2C_EEPROM=y CONFIG_DM_MMC=y CONFIG_SUPPORT_EMMC_BOOT=y CONFIG_FSL_ESDHC_IMX=y
From: Igor Opaniuk igor.opaniuk@toradex.com Enable these Kconfig symbols: TDX_CFG_BLOCK_EXTRA=y TDX_HAVE_EEPROM_EXTRA=y Signed-off-by: Igor Opaniuk igor.opaniuk@toradex.com
1. Move aliases and legacy lcdif node to the u-boot specific dts include. 2. Provide proper display timings, as in the downstream Toradex kernel [1].
[1]: https://git.toradex.com/cgit/linux-toradex.git/tree/arch/arm/boot/dts/imx6ul... Signed-off-by: Igor Opaniuk igor.opaniuk@toradex.com ---
arch/arm/dts/imx6ull-colibri-u-boot.dtsi | 45 ++++++++++++++++++++++++ arch/arm/dts/imx6ull-colibri.dtsi | 43 ---------------------- 2 files changed, 45 insertions(+), 43 deletions(-)
diff --git a/arch/arm/dts/imx6ull-colibri-u-boot.dtsi b/arch/arm/dts/imx6ull-colibri-u-boot.dtsi index 531cdcc4da..afdb0f43cf 100644 --- a/arch/arm/dts/imx6ull-colibri-u-boot.dtsi +++ b/arch/arm/dts/imx6ull-colibri-u-boot.dtsi @@ -3,6 +3,15 @@ * Copyright 2019 Toradex AG */
+/ { + aliases { + u-boot,dm-pre-reloc; + mmc0 = &usdhc1; + usb0 = &usbotg1; /* required for ums */ + display0 = &lcdif; + }; +}; + &pinctrl_uart1 { u-boot,dm-pre-reloc; }; @@ -10,3 +19,39 @@ &pinctrl_uart1_ctrl1 { u-boot,dm-pre-reloc; }; + +&lcdif { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_lcdif_dat + &pinctrl_lcdif_ctrl>; + status = "okay"; + display = <&display0>; + u-boot,dm-pre-reloc; + + display0: display0 { + bits-per-pixel = <18>; + bus-width = <24>; + status = "okay"; + + display-timings { + native-mode = <&timing_vga>; + timing_vga: 640x480 { + u-boot,dm-pre-reloc; + clock-frequency = <25175000>; + hactive = <640>; + vactive = <480>; + hback-porch = <40>; + hfront-porch = <24>; + vback-porch = <32>; + vfront-porch = <11>; + hsync-len = <96>; + vsync-len = <2>; + + de-active = <1>; + hsync-active = <0>; + vsync-active = <0>; + pixelclk-active = <0>; + }; + }; + }; +}; diff --git a/arch/arm/dts/imx6ull-colibri.dtsi b/arch/arm/dts/imx6ull-colibri.dtsi index fca53119fe..b7bf79f28c 100644 --- a/arch/arm/dts/imx6ull-colibri.dtsi +++ b/arch/arm/dts/imx6ull-colibri.dtsi @@ -8,13 +8,6 @@ #include "imx6ull.dtsi"
/ { - aliases { - u-boot,dm-pre-reloc; - mmc0 = &usdhc1; - usb0 = &usbotg1; /* required for ums */ - display0 = &lcdif; - }; - chosen { stdout-path = &uart1; }; @@ -151,42 +144,6 @@ }; };
-&lcdif { - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_lcdif_dat - &pinctrl_lcdif_ctrl>; - status = "okay"; - display = <&display0>; - u-boot,dm-pre-reloc; - - display0: display0 { - bits-per-pixel = <18>; - bus-width = <24>; - status = "okay"; - - display-timings { - native-mode = <&timing_vga>; - timing_vga: 640x480 { - u-boot,dm-pre-reloc; - clock-frequency = <25175000>; - hactive = <640>; - vactive = <480>; - hback-porch = <48>; - hfront-porch = <16>; - vback-porch = <33>; - vfront-porch = <10>; - hsync-len = <96>; - vsync-len = <2>; - - de-active = <1>; - hsync-active = <0>; - vsync-active = <0>; - pixelclk-active = <0>; - }; - }; - }; -}; - /* PWM <A> */ &pwm4 { pinctrl-names = "default";
- Move aliases and legacy lcdif node to the u-boot specific dts include.
- Provide proper display timings, as in the downstream Toradex kernel
[1]. [1]: https://git.toradex.com/cgit/linux-toradex.git/tree/arch/arm/boot/dts/imx6ul... Signed-off-by: Igor Opaniuk igor.opaniuk@toradex.com
Add function for showing boot logo, embed into u-boot blob.
board/toradex/common/tdx-common.c | 26 ++++++++++++++++++++++++++ board/toradex/common/tdx-common.h | 4 ++++ 2 files changed, 30 insertions(+)
diff --git a/board/toradex/common/tdx-common.c b/board/toradex/common/tdx-common.c index 7e353b4fd9..ae6489667f 100644 --- a/board/toradex/common/tdx-common.c +++ b/board/toradex/common/tdx-common.c @@ -9,6 +9,13 @@ #include <init.h> #include <linux/libfdt.h>
+#ifdef CONFIG_DM_VIDEO +#include <bmp_logo.h> +#include <dm.h> +#include <splash.h> +#include <video.h> +#endif + #include "tdx-cfg-block.h" #include <asm/setup.h> #include "tdx-common.h" @@ -196,3 +203,22 @@ int ft_common_board_setup(void *blob, bd_t *bd) }
#endif /* CONFIG_TDX_CFG_BLOCK */ + +#if defined(CONFIG_DM_VIDEO) +int show_boot_logo(void) +{ + struct udevice *dev; + int ret; + int xpos, ypos; + + splash_get_pos(&xpos, &ypos); + + ret = uclass_get_device(UCLASS_VIDEO, 0, &dev); + if (ret) + return ret; + + ret = video_bmp_display(dev, (ulong)bmp_logo_bitmap, xpos, ypos, true); + + return ret; +} +#endif /* CONFIG_DM_VIDEO */ diff --git a/board/toradex/common/tdx-common.h b/board/toradex/common/tdx-common.h index c537dca71e..63614c8671 100644 --- a/board/toradex/common/tdx-common.h +++ b/board/toradex/common/tdx-common.h @@ -11,4 +11,8 @@
int ft_common_board_setup(void *blob, bd_t *bd);
+#if defined(CONFIG_DM_VIDEO) +int show_boot_logo(void); +#endif + #endif /* _TDX_COMMON_H */
From: Igor Opaniuk igor.opaniuk@toradex.com Add function for showing boot logo, embed into u-boot blob. Signed-off-by: Igor Opaniuk igor.opaniuk@toradex.com
1. Move u-boot specific nodes to u-boot dts include: legacy lcdif node and aliases. 2. Add iomux configuration for LCD. 3. Drop un-needed u-boot,dm-pre-reloc for alias node. 4. Fix display-timings, use the one from Toradex downstream kernel [1]
[1]: https://git.toradex.com/cgit/linux-toradex.git/tree/arch/arm/boot/dts/imx7-c... Signed-off-by: Igor Opaniuk igor.opaniuk@toradex.com ---
arch/arm/dts/imx7-colibri-emmc.dts | 2 +- arch/arm/dts/imx7-colibri-rawnand.dts | 10 ++-- arch/arm/dts/imx7-colibri-u-boot.dtsi | 39 ++++++++++++++++ arch/arm/dts/imx7-colibri.dtsi | 65 +++++++++++++------------- board/toradex/colibri_imx7/MAINTAINERS | 1 + 5 files changed, 79 insertions(+), 38 deletions(-) create mode 100644 arch/arm/dts/imx7-colibri-u-boot.dtsi
diff --git a/arch/arm/dts/imx7-colibri-emmc.dts b/arch/arm/dts/imx7-colibri-emmc.dts index bc0d10c716..8545498275 100644 --- a/arch/arm/dts/imx7-colibri-emmc.dts +++ b/arch/arm/dts/imx7-colibri-emmc.dts @@ -5,13 +5,13 @@
/dts-v1/; #include "imx7-colibri.dtsi" +#include "imx7-colibri-u-boot.dtsi"
/ { model = "Toradex Colibri iMX7D 1GB (eMMC)"; compatible = "toradex,imx7d-colibri-emmc", "fsl,imx7d";
aliases { - u-boot,dm-pre-reloc; mmc0 = &usdhc3; mmc1 = &usdhc1; display1 = &lcdif; diff --git a/arch/arm/dts/imx7-colibri-rawnand.dts b/arch/arm/dts/imx7-colibri-rawnand.dts index 5f12a2ac2a..5211fb1f44 100644 --- a/arch/arm/dts/imx7-colibri-rawnand.dts +++ b/arch/arm/dts/imx7-colibri-rawnand.dts @@ -5,19 +5,21 @@
/ { model = "Toradex Colibri iMX7S/D"; compatible = "toradex,imx7-colibri", "fsl,imx7";
- chosen { - stdout-path = &uart1; - }; - aliases { + display1 = &lcdif; usb0 = &usbotg1; /* required for ums */ };
+ chosen { + stdout-path = &uart1; + }; + reg_5v0: regulator-5v0 { compatible = "regulator-fixed"; regulator-name = "5V"; diff --git a/arch/arm/dts/imx7-colibri-u-boot.dtsi b/arch/arm/dts/imx7-colibri-u-boot.dtsi new file mode 100644 index 0000000000..91386476d5 --- /dev/null +++ b/arch/arm/dts/imx7-colibri-u-boot.dtsi @@ -0,0 +1,39 @@ +// SPDX-License-Identifier: GPL-2.0+ OR MIT +/* + * Copyright 2020 Toradex + */ + +&lcdif { + status = "okay"; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_lcdif_dat + &pinctrl_lcdif_ctrl>; + display = <&display0>; + u-boot,dm-pre-reloc; + + display0: display0 { + bits-per-pixel = <18>; + bus-width = <18>; + status = "okay"; + + display-timings { + native-mode = <&timing_vga>; + timing_vga: 640x480 { + clock-frequency = <25175000>; + hactive = <640>; + vactive = <480>; + hback-porch = <40>; + hfront-porch = <24>; + vback-porch = <32>; + vfront-porch = <11>; + hsync-len = <96>; + vsync-len = <2>; + + de-active = <1>; + hsync-active = <0>; + vsync-active = <0>; + pixelclk-active = <0>; + }; + }; + }; +}; diff --git a/arch/arm/dts/imx7-colibri.dtsi b/arch/arm/dts/imx7-colibri.dtsi index ec95f22a0c..b352036e30 100644 --- a/arch/arm/dts/imx7-colibri.dtsi +++ b/arch/arm/dts/imx7-colibri.dtsi @@ -172,6 +172,38 @@ >; };
+ pinctrl_lcdif_dat: lcdif-dat-grp { + fsl,pins = < + MX7D_PAD_LCD_DATA00__LCD_DATA0 0x79 + MX7D_PAD_LCD_DATA01__LCD_DATA1 0x79 + MX7D_PAD_LCD_DATA02__LCD_DATA2 0x79 + MX7D_PAD_LCD_DATA03__LCD_DATA3 0x79 + MX7D_PAD_LCD_DATA04__LCD_DATA4 0x79 + MX7D_PAD_LCD_DATA05__LCD_DATA5 0x79 + MX7D_PAD_LCD_DATA06__LCD_DATA6 0x79 + MX7D_PAD_LCD_DATA07__LCD_DATA7 0x79 + MX7D_PAD_LCD_DATA08__LCD_DATA8 0x79 + MX7D_PAD_LCD_DATA09__LCD_DATA9 0x79 + MX7D_PAD_LCD_DATA10__LCD_DATA10 0x79 + MX7D_PAD_LCD_DATA11__LCD_DATA11 0x79 + MX7D_PAD_LCD_DATA12__LCD_DATA12 0x79 + MX7D_PAD_LCD_DATA13__LCD_DATA13 0x79 + MX7D_PAD_LCD_DATA14__LCD_DATA14 0x79 + MX7D_PAD_LCD_DATA15__LCD_DATA15 0x79 + MX7D_PAD_LCD_DATA16__LCD_DATA16 0x79 + MX7D_PAD_LCD_DATA17__LCD_DATA17 0x79 + >; + }; + + pinctrl_lcdif_ctrl: lcdif-ctrl-grp { + fsl,pins = < + MX7D_PAD_LCD_CLK__LCD_CLK 0x79 + MX7D_PAD_LCD_ENABLE__LCD_ENABLE 0x79 + MX7D_PAD_LCD_VSYNC__LCD_VSYNC 0x79 + MX7D_PAD_LCD_HSYNC__LCD_HSYNC 0x79 + >; + }; + pinctrl_enet1: enet1grp { fsl,pins = < MX7D_PAD_ENET1_CRS__GPIO7_IO14 0x14 @@ -227,36 +259,3 @@ >; }; }; - -&lcdif { - status = "okay"; - display = <&display0>; - u-boot,dm-pre-reloc; - - display0: display0 { - bits-per-pixel = <18>; - bus-width = <24>; - status = "okay"; - - display-timings { - native-mode = <&timing_vga>; - timing_vga: 640x480 { - u-boot,dm-pre-reloc; - clock-frequency = <25175000>; - hactive = <640>; - vactive = <480>; - hback-porch = <48>; - hfront-porch = <16>; - vback-porch = <33>; - vfront-porch = <10>; - hsync-len = <96>; - vsync-len = <2>; - - de-active = <1>; - hsync-active = <0>; - vsync-active = <0>; - pixelclk-active = <0>; - }; - }; - }; -}; diff --git a/board/toradex/colibri_imx7/MAINTAINERS b/board/toradex/colibri_imx7/MAINTAINERS index 82246be160..61a504487a 100644 --- a/board/toradex/colibri_imx7/MAINTAINERS +++ b/board/toradex/colibri_imx7/MAINTAINERS @@ -9,5 +9,6 @@ F: include/configs/colibri_imx7.h F: configs/colibri_imx7_defconfig F: configs/colibri_imx7_emmc_defconfig F: arch/arm/dts/imx7-colibri.dtsi +F: arch/arm/dts/imx7-colibri-u-boot.dtsi F: arch/arm/dts/imx7-colibri-emmc.dts F: arch/arm/dts/imx7-colibri-rawnand.dts
- Move u-boot specific nodes to u-boot dts include: legacy lcdif
node and aliases. 2. Add iomux configuration for LCD. 3. Drop un-needed u-boot,dm-pre-reloc for alias node. 4. Fix display-timings, use the one from Toradex downstream kernel [1] [1]: https://git.toradex.com/cgit/linux-toradex.git/tree/arch/arm/boot/dts/imx7-c... Signed-off-by: Igor Opaniuk igor.opaniuk@toradex.com
1. Show boot logo embed in U-Boot blob. 2. Drop iomux configration for LCD, and use the one provided in device tree.
.../toradex/colibri-imx6ull/colibri-imx6ull.c | 40 ++++--------------- 1 file changed, 7 insertions(+), 33 deletions(-)
diff --git a/board/toradex/colibri-imx6ull/colibri-imx6ull.c b/board/toradex/colibri-imx6ull/colibri-imx6ull.c index c67d02f7c2..8a34872cab 100644 --- a/board/toradex/colibri-imx6ull/colibri-imx6ull.c +++ b/board/toradex/colibri-imx6ull/colibri-imx6ull.c @@ -57,32 +57,7 @@ static void setup_gpmi_nand(void) } #endif /* CONFIG_NAND_MXS */
-#ifdef CONFIG_VIDEO_MXS -static iomux_v3_cfg_t const lcd_pads[] = { - MX6_PAD_LCD_CLK__LCDIF_CLK | MUX_PAD_CTRL(LCD_PAD_CTRL), - MX6_PAD_LCD_ENABLE__LCDIF_ENABLE | MUX_PAD_CTRL(LCD_PAD_CTRL), - MX6_PAD_LCD_HSYNC__LCDIF_HSYNC | MUX_PAD_CTRL(LCD_PAD_CTRL), - MX6_PAD_LCD_CLK__LCDIF_CLK | MUX_PAD_CTRL(LCD_PAD_CTRL), - MX6_PAD_LCD_DATA00__LCDIF_DATA00 | MUX_PAD_CTRL(LCD_PAD_CTRL), - MX6_PAD_LCD_DATA01__LCDIF_DATA01 | MUX_PAD_CTRL(LCD_PAD_CTRL), - MX6_PAD_LCD_DATA02__LCDIF_DATA02 | MUX_PAD_CTRL(LCD_PAD_CTRL), - MX6_PAD_LCD_DATA03__LCDIF_DATA03 | MUX_PAD_CTRL(LCD_PAD_CTRL), - MX6_PAD_LCD_DATA04__LCDIF_DATA04 | MUX_PAD_CTRL(LCD_PAD_CTRL), - MX6_PAD_LCD_DATA05__LCDIF_DATA05 | MUX_PAD_CTRL(LCD_PAD_CTRL), - MX6_PAD_LCD_DATA06__LCDIF_DATA06 | MUX_PAD_CTRL(LCD_PAD_CTRL), - MX6_PAD_LCD_DATA07__LCDIF_DATA07 | MUX_PAD_CTRL(LCD_PAD_CTRL), - MX6_PAD_LCD_DATA08__LCDIF_DATA08 | MUX_PAD_CTRL(LCD_PAD_CTRL), - MX6_PAD_LCD_DATA09__LCDIF_DATA09 | MUX_PAD_CTRL(LCD_PAD_CTRL), - MX6_PAD_LCD_DATA10__LCDIF_DATA10 | MUX_PAD_CTRL(LCD_PAD_CTRL), - MX6_PAD_LCD_DATA11__LCDIF_DATA11 | MUX_PAD_CTRL(LCD_PAD_CTRL), - MX6_PAD_LCD_DATA12__LCDIF_DATA12 | MUX_PAD_CTRL(LCD_PAD_CTRL), - MX6_PAD_LCD_DATA13__LCDIF_DATA13 | MUX_PAD_CTRL(LCD_PAD_CTRL), - MX6_PAD_LCD_DATA14__LCDIF_DATA14 | MUX_PAD_CTRL(LCD_PAD_CTRL), - MX6_PAD_LCD_DATA15__LCDIF_DATA15 | MUX_PAD_CTRL(LCD_PAD_CTRL), - MX6_PAD_LCD_DATA16__LCDIF_DATA16 | MUX_PAD_CTRL(LCD_PAD_CTRL), - MX6_PAD_LCD_DATA17__LCDIF_DATA17 | MUX_PAD_CTRL(LCD_PAD_CTRL), -}; - +#ifdef CONFIG_DM_VIDEO static iomux_v3_cfg_t const backlight_pads[] = { /* Backlight On */ MX6_PAD_JTAG_TMS__GPIO1_IO11 | MUX_PAD_CTRL(NO_PAD_CTRL), @@ -95,8 +70,6 @@ static iomux_v3_cfg_t const backlight_pads[] = {
static int setup_lcd(void) { - imx_iomux_v3_setup_multiple_pads(lcd_pads, ARRAY_SIZE(lcd_pads)); - imx_iomux_v3_setup_multiple_pads(backlight_pads, ARRAY_SIZE(backlight_pads));
/* Set BL_ON */ @@ -153,11 +126,6 @@ int board_init(void) #ifdef CONFIG_NAND_MXS setup_gpmi_nand(); #endif - -#ifdef CONFIG_VIDEO_MXS - setup_lcd(); -#endif - return 0; }
@@ -203,6 +171,12 @@ int board_late_init(void) } #endif /* CONFIG_CMD_USB_SDP */
+#if defined(CONFIG_DM_VIDEO) + setup_lcd(); + + show_boot_logo(); +#endif + return 0; }
- Show boot logo embed in U-Boot blob.
- Drop iomux configration for LCD, and use the one provided in device
tree. Signed-off-by: Igor Opaniuk igor.opaniuk@toradex.com
Configure white on black for video console.
configs/colibri-imx6ull_defconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/configs/colibri-imx6ull_defconfig b/configs/colibri-imx6ull_defconfig index ce145cd24f..3292fcc85d 100644 --- a/configs/colibri-imx6ull_defconfig +++ b/configs/colibri-imx6ull_defconfig @@ -91,3 +91,4 @@ CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_DM_VIDEO=y CONFIG_OF_LIBFDT_OVERLAY=y CONFIG_FDT_FIXUP_PARTITIONS=y +CONFIG_SYS_WHITE_ON_BLACK=y
From: Igor Opaniuk igor.opaniuk@toradex.com Configure white on black for video console. Signed-off-by: Igor Opaniuk igor.opaniuk@toradex.com
1. Configure white on black for video console. 2. Enable printing bmp logo during late board init stage. 3. Use iomux configuration from device tree.
board/toradex/colibri_imx7/colibri_imx7.c | 44 +++++++---------------- configs/colibri_imx7_defconfig | 2 ++ configs/colibri_imx7_emmc_defconfig | 2 ++ 3 files changed, 16 insertions(+), 32 deletions(-)
diff --git a/board/toradex/colibri_imx7/colibri_imx7.c b/board/toradex/colibri_imx7/colibri_imx7.c index 8df925dacf..f585260586 100644 --- a/board/toradex/colibri_imx7/colibri_imx7.c +++ b/board/toradex/colibri_imx7/colibri_imx7.c @@ -100,32 +100,7 @@ static void setup_gpmi_nand(void) } #endif
-#ifdef CONFIG_VIDEO_MXS -static iomux_v3_cfg_t const lcd_pads[] = { - MX7D_PAD_LCD_CLK__LCD_CLK | MUX_PAD_CTRL(LCD_PAD_CTRL), - MX7D_PAD_LCD_ENABLE__LCD_ENABLE | MUX_PAD_CTRL(LCD_PAD_CTRL), - MX7D_PAD_LCD_HSYNC__LCD_HSYNC | MUX_PAD_CTRL(LCD_PAD_CTRL), - MX7D_PAD_LCD_VSYNC__LCD_VSYNC | MUX_PAD_CTRL(LCD_PAD_CTRL), - MX7D_PAD_LCD_DATA00__LCD_DATA0 | MUX_PAD_CTRL(LCD_PAD_CTRL), - MX7D_PAD_LCD_DATA01__LCD_DATA1 | MUX_PAD_CTRL(LCD_PAD_CTRL), - MX7D_PAD_LCD_DATA02__LCD_DATA2 | MUX_PAD_CTRL(LCD_PAD_CTRL), - MX7D_PAD_LCD_DATA03__LCD_DATA3 | MUX_PAD_CTRL(LCD_PAD_CTRL), - MX7D_PAD_LCD_DATA04__LCD_DATA4 | MUX_PAD_CTRL(LCD_PAD_CTRL), - MX7D_PAD_LCD_DATA05__LCD_DATA5 | MUX_PAD_CTRL(LCD_PAD_CTRL), - MX7D_PAD_LCD_DATA06__LCD_DATA6 | MUX_PAD_CTRL(LCD_PAD_CTRL), - MX7D_PAD_LCD_DATA07__LCD_DATA7 | MUX_PAD_CTRL(LCD_PAD_CTRL), - MX7D_PAD_LCD_DATA08__LCD_DATA8 | MUX_PAD_CTRL(LCD_PAD_CTRL), - MX7D_PAD_LCD_DATA09__LCD_DATA9 | MUX_PAD_CTRL(LCD_PAD_CTRL), - MX7D_PAD_LCD_DATA10__LCD_DATA10 | MUX_PAD_CTRL(LCD_PAD_CTRL), - MX7D_PAD_LCD_DATA11__LCD_DATA11 | MUX_PAD_CTRL(LCD_PAD_CTRL), - MX7D_PAD_LCD_DATA12__LCD_DATA12 | MUX_PAD_CTRL(LCD_PAD_CTRL), - MX7D_PAD_LCD_DATA13__LCD_DATA13 | MUX_PAD_CTRL(LCD_PAD_CTRL), - MX7D_PAD_LCD_DATA14__LCD_DATA14 | MUX_PAD_CTRL(LCD_PAD_CTRL), - MX7D_PAD_LCD_DATA15__LCD_DATA15 | MUX_PAD_CTRL(LCD_PAD_CTRL), - MX7D_PAD_LCD_DATA16__LCD_DATA16 | MUX_PAD_CTRL(LCD_PAD_CTRL), - MX7D_PAD_LCD_DATA17__LCD_DATA17 | MUX_PAD_CTRL(LCD_PAD_CTRL), -}; - +#ifdef CONFIG_DM_VIDEO static iomux_v3_cfg_t const backlight_pads[] = { /* Backlight On */ MX7D_PAD_SD1_WP__GPIO5_IO1 | MUX_PAD_CTRL(NO_PAD_CTRL), @@ -139,8 +114,6 @@ static iomux_v3_cfg_t const backlight_pads[] = {
/* Set BL_ON */ @@ -215,10 +188,6 @@ int board_init(void) setup_gpmi_nand(); #endif
-#ifdef CONFIG_VIDEO_MXS - setup_lcd(); -#endif - #ifdef CONFIG_USB_EHCI_MX7 imx_iomux_v3_setup_multiple_pads(usb_cdet_pads, ARRAY_SIZE(usb_cdet_pads)); gpio_request(USB_CDET_GPIO, "usb-cdet-gpio"); @@ -382,4 +351,15 @@ int board_usb_phy_mode(int port) return USB_INIT_HOST; } } + +int board_late_init(void) +{ +#if defined(CONFIG_DM_VIDEO) + setup_lcd(); + + show_boot_logo(); +#endif + return 0; +} + #endif diff --git a/configs/colibri_imx7_defconfig b/configs/colibri_imx7_defconfig index 3c49d70260..73015ed825 100644 --- a/configs/colibri_imx7_defconfig +++ b/configs/colibri_imx7_defconfig @@ -89,3 +89,5 @@ CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_DM_VIDEO=y CONFIG_OF_LIBFDT_OVERLAY=y CONFIG_FDT_FIXUP_PARTITIONS=y +CONFIG_BOARD_LATE_INIT=y +CONFIG_SYS_WHITE_ON_BLACK=y diff --git a/configs/colibri_imx7_emmc_defconfig b/configs/colibri_imx7_emmc_defconfig index c7bcb87ddd..8ba03a2b38 100644 --- a/configs/colibri_imx7_emmc_defconfig +++ b/configs/colibri_imx7_emmc_defconfig @@ -84,3 +84,5 @@ CONFIG_CI_UDC=y CONFIG_DM_VIDEO=y CONFIG_FAT_WRITE=y CONFIG_OF_LIBFDT_OVERLAY=y +CONFIG_BOARD_LATE_INIT=y +CONFIG_SYS_WHITE_ON_BLACK=y
- Configure white on black for video console.
- Enable printing bmp logo during late board init stage.
- Use iomux configuration from device tree.
Hi Stefano,
Includes:
- Fixes for splash screen logo drawing in Colibri iMX7/iMX6ULL.
- Support for EEPROM as a storage for the main Toradex
v2:
-- 2.17.1
Any chance to get it merged?
Thanks -- Best regards - Freundliche Grüsse - Meilleures salutations
Igor Opaniuk
mailto: igor.opaniuk@gmail.com skype: igor.opanyuk +380 (93) 836 40 67 http://ua.linkedin.com/in/iopaniuk
Hi Igor,
On 23.07.20 17:03, Igor Opaniuk wrote:
Hi Stefano,
Includes:
v2:
-- 2.17.1
Yes, sorry, I saw patches, most of patches (see EEprom, etc) are very specific to Toradex, and I cannot say a lot. I do not see any isse and I will merge them. They will be part of my next PR to Tom.
Regards, Stefano
Igor Opaniuk
sbabic@denx.de
Stefano Babic
