[U-Boot] [PATCH v3 1/3] mmc: meson: update Meson GXBB / Odroid-C2 DT with latest Linux version
As a prerequisite for adding a Meson GX MMC driver update the Meson GXBB / Odroid-C2 device tree in Uboot with the latest version from Linux.
Signed-off-by: Heiner Kallweit hkallweit1@gmail.com --- arch/arm/dts/meson-gx.dtsi | 447 ++++++++++++++++++++ arch/arm/dts/meson-gxbb-odroidc2.dts | 147 ++++++- arch/arm/dts/meson-gxbb.dtsi | 718 ++++++++++++++++++++------------ include/dt-bindings/clock/gxbb-aoclkc.h | 66 +++ include/dt-bindings/clock/gxbb-clkc.h | 34 ++ include/dt-bindings/reset/gxbb-aoclkc.h | 66 +++ 6 files changed, 1203 insertions(+), 275 deletions(-) create mode 100644 arch/arm/dts/meson-gx.dtsi create mode 100644 include/dt-bindings/clock/gxbb-aoclkc.h create mode 100644 include/dt-bindings/clock/gxbb-clkc.h create mode 100644 include/dt-bindings/reset/gxbb-aoclkc.h
diff --git a/arch/arm/dts/meson-gx.dtsi b/arch/arm/dts/meson-gx.dtsi new file mode 100644 index 0000000..c129100 --- /dev/null +++ b/arch/arm/dts/meson-gx.dtsi @@ -0,0 +1,447 @@ +/* + * Copyright (c) 2016 Andreas Färber + * + * Copyright (c) 2016 BayLibre, SAS. + * Author: Neil Armstrong narmstrong@baylibre.com + * + * Copyright (c) 2016 Endless Computers, Inc. + * Author: Carlo Caione carlo@endlessm.com + * + * This file is dual-licensed: you can use it either under the terms + * of the GPL or the X11 license, at your option. Note that this dual + * licensing only applies to this file, and not this project as a + * whole. + * + * a) This library is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of the + * License, or (at your option) any later version. + * + * This library is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * Or, alternatively, + * + * b) Permission is hereby granted, free of charge, to any person + * obtaining a copy of this software and associated documentation + * files (the "Software"), to deal in the Software without + * restriction, including without limitation the rights to use, + * copy, modify, merge, publish, distribute, sublicense, and/or + * sell copies of the Software, and to permit persons to whom the + * Software is furnished to do so, subject to the following + * conditions: + * + * The above copyright notice and this permission notice shall be + * included in all copies or substantial portions of the Software. + * + * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, + * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES + * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND + * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT + * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, + * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING + * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR + * OTHER DEALINGS IN THE SOFTWARE. + */ + +#include <dt-bindings/gpio/gpio.h> +#include <dt-bindings/interrupt-controller/irq.h> +#include <dt-bindings/interrupt-controller/arm-gic.h> + +/ { + interrupt-parent = <&gic>; + #address-cells = <2>; + #size-cells = <2>; + + reserved-memory { + #address-cells = <2>; + #size-cells = <2>; + ranges; + + /* 16 MiB reserved for Hardware ROM Firmware */ + hwrom_reserved: hwrom@0 { + reg = <0x0 0x0 0x0 0x1000000>; + no-map; + }; + + /* 2 MiB reserved for ARM Trusted Firmware (BL31) */ + secmon_reserved: secmon@10000000 { + reg = <0x0 0x10000000 0x0 0x200000>; + no-map; + }; + }; + + cpus { + #address-cells = <0x2>; + #size-cells = <0x0>; + + cpu0: cpu@0 { + device_type = "cpu"; + compatible = "arm,cortex-a53", "arm,armv8"; + reg = <0x0 0x0>; + enable-method = "psci"; + next-level-cache = <&l2>; + clocks = <&scpi_dvfs 0>; + }; + + cpu1: cpu@1 { + device_type = "cpu"; + compatible = "arm,cortex-a53", "arm,armv8"; + reg = <0x0 0x1>; + enable-method = "psci"; + next-level-cache = <&l2>; + clocks = <&scpi_dvfs 0>; + }; + + cpu2: cpu@2 { + device_type = "cpu"; + compatible = "arm,cortex-a53", "arm,armv8"; + reg = <0x0 0x2>; + enable-method = "psci"; + next-level-cache = <&l2>; + clocks = <&scpi_dvfs 0>; + }; + + cpu3: cpu@3 { + device_type = "cpu"; + compatible = "arm,cortex-a53", "arm,armv8"; + reg = <0x0 0x3>; + enable-method = "psci"; + next-level-cache = <&l2>; + clocks = <&scpi_dvfs 0>; + }; + + l2: l2-cache0 { + compatible = "cache"; + }; + }; + + arm-pmu { + compatible = "arm,cortex-a53-pmu"; + interrupts = <GIC_SPI 137 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 138 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 153 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 154 IRQ_TYPE_LEVEL_HIGH>; + interrupt-affinity = <&cpu0>, <&cpu1>, <&cpu2>, <&cpu3>; + }; + + psci { + compatible = "arm,psci-0.2"; + method = "smc"; + }; + + timer { + compatible = "arm,armv8-timer"; + interrupts = <GIC_PPI 13 + (GIC_CPU_MASK_RAW(0xff) | IRQ_TYPE_LEVEL_LOW)>, + <GIC_PPI 14 + (GIC_CPU_MASK_RAW(0xff) | IRQ_TYPE_LEVEL_LOW)>, + <GIC_PPI 11 + (GIC_CPU_MASK_RAW(0xff) | IRQ_TYPE_LEVEL_LOW)>, + <GIC_PPI 10 + (GIC_CPU_MASK_RAW(0xff) | IRQ_TYPE_LEVEL_LOW)>; + }; + + xtal: xtal-clk { + compatible = "fixed-clock"; + clock-frequency = <24000000>; + clock-output-names = "xtal"; + #clock-cells = <0>; + }; + + firmware { + sm: secure-monitor { + compatible = "amlogic,meson-gx-sm", "amlogic,meson-gxbb-sm"; + }; + }; + + efuse: efuse { + compatible = "amlogic,meson-gx-efuse", "amlogic,meson-gxbb-efuse"; + #address-cells = <1>; + #size-cells = <1>; + + sn: sn@14 { + reg = <0x14 0x10>; + }; + + eth_mac: eth_mac@34 { + reg = <0x34 0x10>; + }; + + bid: bid@46 { + reg = <0x46 0x30>; + }; + }; + + scpi { + compatible = "amlogic,meson-gxbb-scpi", "arm,scpi-pre-1.0"; + mboxes = <&mailbox 1 &mailbox 2>; + shmem = <&cpu_scp_lpri &cpu_scp_hpri>; + + scpi_clocks: clocks { + compatible = "arm,scpi-clocks"; + + scpi_dvfs: scpi_clocks@0 { + compatible = "arm,scpi-dvfs-clocks"; + #clock-cells = <1>; + clock-indices = <0>; + clock-output-names = "vcpu"; + }; + }; + + scpi_sensors: sensors { + compatible = "arm,scpi-sensors"; + #thermal-sensor-cells = <1>; + }; + }; + + soc { + compatible = "simple-bus"; + #address-cells = <2>; + #size-cells = <2>; + ranges; + + cbus: cbus@c1100000 { + compatible = "simple-bus"; + reg = <0x0 0xc1100000 0x0 0x100000>; + #address-cells = <2>; + #size-cells = <2>; + ranges = <0x0 0x0 0x0 0xc1100000 0x0 0x100000>; + + reset: reset-controller@4404 { + compatible = "amlogic,meson-gx-reset", "amlogic,meson-gxbb-reset"; + reg = <0x0 0x04404 0x0 0x20>; + #reset-cells = <1>; + }; + + uart_A: serial@84c0 { + compatible = "amlogic,meson-uart"; + reg = <0x0 0x84c0 0x0 0x14>; + interrupts = <GIC_SPI 26 IRQ_TYPE_EDGE_RISING>; + clocks = <&xtal>; + status = "disabled"; + }; + + uart_B: serial@84dc { + compatible = "amlogic,meson-uart"; + reg = <0x0 0x84dc 0x0 0x14>; + interrupts = <GIC_SPI 75 IRQ_TYPE_EDGE_RISING>; + clocks = <&xtal>; + status = "disabled"; + }; + + i2c_A: i2c@8500 { + compatible = "amlogic,meson-gxbb-i2c"; + reg = <0x0 0x08500 0x0 0x20>; + interrupts = <GIC_SPI 21 IRQ_TYPE_EDGE_RISING>; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + }; + + pwm_ab: pwm@8550 { + compatible = "amlogic,meson-gx-pwm", "amlogic,meson-gxbb-pwm"; + reg = <0x0 0x08550 0x0 0x10>; + #pwm-cells = <3>; + status = "disabled"; + }; + + pwm_cd: pwm@8650 { + compatible = "amlogic,meson-gx-pwm", "amlogic,meson-gxbb-pwm"; + reg = <0x0 0x08650 0x0 0x10>; + #pwm-cells = <3>; + status = "disabled"; + }; + + pwm_ef: pwm@86c0 { + compatible = "amlogic,meson-gx-pwm", "amlogic,meson-gxbb-pwm"; + reg = <0x0 0x086c0 0x0 0x10>; + #pwm-cells = <3>; + status = "disabled"; + }; + + uart_C: serial@8700 { + compatible = "amlogic,meson-uart"; + reg = <0x0 0x8700 0x0 0x14>; + interrupts = <GIC_SPI 93 IRQ_TYPE_EDGE_RISING>; + clocks = <&xtal>; + status = "disabled"; + }; + + i2c_B: i2c@87c0 { + compatible = "amlogic,meson-gxbb-i2c"; + reg = <0x0 0x087c0 0x0 0x20>; + interrupts = <GIC_SPI 214 IRQ_TYPE_EDGE_RISING>; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + }; + + i2c_C: i2c@87e0 { + compatible = "amlogic,meson-gxbb-i2c"; + reg = <0x0 0x087e0 0x0 0x20>; + interrupts = <GIC_SPI 215 IRQ_TYPE_EDGE_RISING>; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + }; + + watchdog@98d0 { + compatible = "amlogic,meson-gx-wdt", "amlogic,meson-gxbb-wdt"; + reg = <0x0 0x098d0 0x0 0x10>; + clocks = <&xtal>; + }; + }; + + gic: interrupt-controller@c4301000 { + compatible = "arm,gic-400"; + reg = <0x0 0xc4301000 0 0x1000>, + <0x0 0xc4302000 0 0x2000>, + <0x0 0xc4304000 0 0x2000>, + <0x0 0xc4306000 0 0x2000>; + interrupt-controller; + interrupts = <GIC_PPI 9 + (GIC_CPU_MASK_SIMPLE(8) | IRQ_TYPE_LEVEL_HIGH)>; + #interrupt-cells = <3>; + #address-cells = <0>; + }; + + sram: sram@c8000000 { + compatible = "amlogic,meson-gxbb-sram", "mmio-sram"; + reg = <0x0 0xc8000000 0x0 0x14000>; + + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 0x0 0xc8000000 0x14000>; + + cpu_scp_lpri: scp-shmem@0 { + compatible = "amlogic,meson-gxbb-scp-shmem"; + reg = <0x13000 0x400>; + }; + + cpu_scp_hpri: scp-shmem@200 { + compatible = "amlogic,meson-gxbb-scp-shmem"; + reg = <0x13400 0x400>; + }; + }; + + aobus: aobus@c8100000 { + compatible = "simple-bus"; + reg = <0x0 0xc8100000 0x0 0x100000>; + #address-cells = <2>; + #size-cells = <2>; + ranges = <0x0 0x0 0x0 0xc8100000 0x0 0x100000>; + + uart_AO: serial@4c0 { + compatible = "amlogic,meson-uart"; + reg = <0x0 0x004c0 0x0 0x14>; + interrupts = <GIC_SPI 193 IRQ_TYPE_EDGE_RISING>; + clocks = <&xtal>; + status = "disabled"; + }; + + uart_AO_B: serial@4e0 { + compatible = "amlogic,meson-uart"; + reg = <0x0 0x004e0 0x0 0x14>; + interrupts = <GIC_SPI 197 IRQ_TYPE_EDGE_RISING>; + clocks = <&xtal>; + status = "disabled"; + }; + + ir: ir@580 { + compatible = "amlogic,meson-gxbb-ir"; + reg = <0x0 0x00580 0x0 0x40>; + interrupts = <GIC_SPI 196 IRQ_TYPE_EDGE_RISING>; + status = "disabled"; + }; + }; + + periphs: periphs@c8834000 { + compatible = "simple-bus"; + reg = <0x0 0xc8834000 0x0 0x2000>; + #address-cells = <2>; + #size-cells = <2>; + ranges = <0x0 0x0 0x0 0xc8834000 0x0 0x2000>; + + rng { + compatible = "amlogic,meson-rng"; + reg = <0x0 0x0 0x0 0x4>; + }; + }; + + + hiubus: hiubus@c883c000 { + compatible = "simple-bus"; + reg = <0x0 0xc883c000 0x0 0x2000>; + #address-cells = <2>; + #size-cells = <2>; + ranges = <0x0 0x0 0x0 0xc883c000 0x0 0x2000>; + + mailbox: mailbox@404 { + compatible = "amlogic,meson-gx-mhu", "amlogic,meson-gxbb-mhu"; + reg = <0 0x404 0 0x4c>; + interrupts = <0 208 IRQ_TYPE_EDGE_RISING>, + <0 209 IRQ_TYPE_EDGE_RISING>, + <0 210 IRQ_TYPE_EDGE_RISING>; + #mbox-cells = <1>; + }; + }; + + ethmac: ethernet@c9410000 { + compatible = "amlogic,meson-gx-dwmac", "amlogic,meson-gxbb-dwmac", "snps,dwmac"; + reg = <0x0 0xc9410000 0x0 0x10000 + 0x0 0xc8834540 0x0 0x4>; + interrupts = <0 8 1>; + interrupt-names = "macirq"; + phy-mode = "rgmii"; + status = "disabled"; + }; + + apb: apb@d0000000 { + compatible = "simple-bus"; + reg = <0x0 0xd0000000 0x0 0x200000>; + #address-cells = <2>; + #size-cells = <2>; + ranges = <0x0 0x0 0x0 0xd0000000 0x0 0x200000>; + + sd_emmc_a: mmc@70000 { + compatible = "amlogic,meson-gx-mmc", "amlogic,meson-gxbb-mmc"; + reg = <0x0 0x70000 0x0 0x2000>; + interrupts = <GIC_SPI 216 IRQ_TYPE_EDGE_RISING>; + status = "disabled"; + }; + + sd_emmc_b: mmc@72000 { + compatible = "amlogic,meson-gx-mmc", "amlogic,meson-gxbb-mmc"; + reg = <0x0 0x72000 0x0 0x2000>; + interrupts = <GIC_SPI 217 IRQ_TYPE_EDGE_RISING>; + status = "disabled"; + }; + + sd_emmc_c: mmc@74000 { + compatible = "amlogic,meson-gx-mmc", "amlogic,meson-gxbb-mmc"; + reg = <0x0 0x74000 0x0 0x2000>; + interrupts = <GIC_SPI 218 IRQ_TYPE_EDGE_RISING>; + status = "disabled"; + }; + }; + + vpu: vpu@d0100000 { + compatible = "amlogic,meson-gx-vpu"; + reg = <0x0 0xd0100000 0x0 0x100000>, + <0x0 0xc883c000 0x0 0x1000>, + <0x0 0xc8838000 0x0 0x1000>; + reg-names = "vpu", "hhi", "dmc"; + interrupts = <GIC_SPI 3 IRQ_TYPE_EDGE_RISING>; + #address-cells = <1>; + #size-cells = <0>; + + /* CVBS VDAC output port */ + cvbs_vdac_port: port@0 { + reg = <0>; + }; + }; + }; +}; diff --git a/arch/arm/dts/meson-gxbb-odroidc2.dts b/arch/arm/dts/meson-gxbb-odroidc2.dts index 79bee64..c737183 100644 --- a/arch/arm/dts/meson-gxbb-odroidc2.dts +++ b/arch/arm/dts/meson-gxbb-odroidc2.dts @@ -64,6 +64,18 @@ reg = <0x0 0x0 0x0 0x80000000>; };
+ usb_otg_pwr: regulator-usb-pwrs { + compatible = "regulator-fixed"; + + regulator-name = "USB_OTG_PWR"; + + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + + gpio = <&gpio_ao GPIOAO_5 GPIO_ACTIVE_HIGH>; + enable-active-high; + }; + leds { compatible = "gpio-leds"; blue { @@ -73,6 +85,60 @@ default-state = "off"; }; }; + + tflash_vdd: regulator-tflash_vdd { + /* + * signal name from schematics: TFLASH_VDD_EN + */ + compatible = "regulator-fixed"; + + regulator-name = "TFLASH_VDD"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + + gpio = <&gpio_ao GPIOAO_12 GPIO_ACTIVE_HIGH>; + enable-active-high; + }; + + tf_io: gpio-regulator-tf_io { + compatible = "regulator-gpio"; + + regulator-name = "TF_IO"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <3300000>; + + /* + * signal name from schematics: TF_3V3N_1V8_EN + */ + gpios = <&gpio_ao GPIOAO_3 GPIO_ACTIVE_HIGH>; + gpios-states = <0>; + + states = <3300000 0 + 1800000 1>; + }; + + vcc1v8: regulator-vcc1v8 { + compatible = "regulator-fixed"; + regulator-name = "VCC1V8"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + }; + + vcc3v3: regulator-vcc3v3 { + compatible = "regulator-fixed"; + regulator-name = "VCC3V3"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + }; + + emmc_pwrseq: emmc-pwrseq { + compatible = "mmc-pwrseq-emmc"; + reset-gpios = <&gpio BOOT_9 GPIO_ACTIVE_LOW>; + }; +}; + +&scpi_clocks { + status = "disabled"; };
&uart_AO { @@ -83,6 +149,85 @@
ðmac { status = "okay"; - pinctrl-0 = <ð_pins>; + pinctrl-0 = <ð_rgmii_pins>; + pinctrl-names = "default"; + phy-handle = <ð_phy0>; + + mdio { + compatible = "snps,dwmac-mdio"; + #address-cells = <1>; + #size-cells = <0>; + + eth_phy0: ethernet-phy@0 { + reg = <0>; + eee-broken-1000t; + }; + }; +}; + +&ir { + status = "okay"; + pinctrl-0 = <&remote_input_ao_pins>; pinctrl-names = "default"; }; + +&i2c_A { + status = "okay"; + pinctrl-0 = <&i2c_a_pins>; + pinctrl-names = "default"; +}; + +&usb0_phy { + status = "okay"; + phy-supply = <&usb_otg_pwr>; +}; + +&usb1_phy { + status = "okay"; +}; + +&usb0 { + status = "okay"; +}; + +&usb1 { + status = "okay"; +}; + +/* SD */ +&sd_emmc_b { + status = "okay"; + pinctrl-0 = <&sdcard_pins>; + pinctrl-names = "default"; + + bus-width = <4>; + cap-sd-highspeed; + max-frequency = <100000000>; + disable-wp; + + cd-gpios = <&gpio CARD_6 GPIO_ACTIVE_HIGH>; + cd-inverted; + + vmmc-supply = <&tflash_vdd>; + vqmmc-supply = <&tf_io>; +}; + +/* eMMC */ +&sd_emmc_c { + status = "okay"; + pinctrl-0 = <&emmc_pins>; + pinctrl-names = "default"; + + bus-width = <8>; + cap-sd-highspeed; + max-frequency = <200000000>; + non-removable; + disable-wp; + cap-mmc-highspeed; + mmc-ddr-1_8v; + mmc-hs200-1_8v; + + mmc-pwrseq = <&emmc_pwrseq>; + vmmc-supply = <&vcc3v3>; + vqmmc-supply = <&vcc1v8>; +}; diff --git a/arch/arm/dts/meson-gxbb.dtsi b/arch/arm/dts/meson-gxbb.dtsi index e502c24..39a774a 100644 --- a/arch/arm/dts/meson-gxbb.dtsi +++ b/arch/arm/dts/meson-gxbb.dtsi @@ -40,307 +40,477 @@ * OTHER DEALINGS IN THE SOFTWARE. */
-#include <dt-bindings/gpio/gpio.h> -#include <dt-bindings/interrupt-controller/irq.h> -#include <dt-bindings/interrupt-controller/arm-gic.h> +#include "meson-gx.dtsi" #include <dt-bindings/gpio/meson-gxbb-gpio.h> #include <dt-bindings/reset/amlogic,meson-gxbb-reset.h> +#include <dt-bindings/clock/gxbb-clkc.h> +#include <dt-bindings/clock/gxbb-aoclkc.h> +#include <dt-bindings/reset/gxbb-aoclkc.h>
/ { compatible = "amlogic,meson-gxbb"; - interrupt-parent = <&gic>; - #address-cells = <2>; - #size-cells = <2>;
- cpus { - #address-cells = <0x2>; - #size-cells = <0x0>; - - cpu0: cpu@0 { - device_type = "cpu"; - compatible = "arm,cortex-a53", "arm,armv8"; - reg = <0x0 0x0>; - enable-method = "psci"; + soc { + usb0_phy: phy@c0000000 { + compatible = "amlogic,meson-gxbb-usb2-phy"; + #phy-cells = <0>; + reg = <0x0 0xc0000000 0x0 0x20>; + resets = <&reset RESET_USB_OTG>; + clocks = <&clkc CLKID_USB>, <&clkc CLKID_USB0>; + clock-names = "usb_general", "usb"; + status = "disabled"; };
- cpu1: cpu@1 { - device_type = "cpu"; - compatible = "arm,cortex-a53", "arm,armv8"; - reg = <0x0 0x1>; - enable-method = "psci"; + usb1_phy: phy@c0000020 { + compatible = "amlogic,meson-gxbb-usb2-phy"; + #phy-cells = <0>; + reg = <0x0 0xc0000020 0x0 0x20>; + resets = <&reset RESET_USB_OTG>; + clocks = <&clkc CLKID_USB>, <&clkc CLKID_USB1>; + clock-names = "usb_general", "usb"; + status = "disabled"; };
- cpu2: cpu@2 { - device_type = "cpu"; - compatible = "arm,cortex-a53", "arm,armv8"; - reg = <0x0 0x2>; - enable-method = "psci"; + usb0: usb@c9000000 { + compatible = "amlogic,meson-gxbb-usb", "snps,dwc2"; + reg = <0x0 0xc9000000 0x0 0x40000>; + interrupts = <GIC_SPI 30 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clkc CLKID_USB0_DDR_BRIDGE>; + clock-names = "otg"; + phys = <&usb0_phy>; + phy-names = "usb2-phy"; + dr_mode = "host"; + status = "disabled"; };
- cpu3: cpu@3 { - device_type = "cpu"; - compatible = "arm,cortex-a53", "arm,armv8"; - reg = <0x0 0x3>; - enable-method = "psci"; + usb1: usb@c9100000 { + compatible = "amlogic,meson-gxbb-usb", "snps,dwc2"; + reg = <0x0 0xc9100000 0x0 0x40000>; + interrupts = <GIC_SPI 31 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clkc CLKID_USB1_DDR_BRIDGE>; + clock-names = "otg"; + phys = <&usb1_phy>; + phy-names = "usb2-phy"; + dr_mode = "host"; + status = "disabled"; }; }; +};
- arm-pmu { - compatible = "arm,cortex-a53-pmu"; - interrupts = <GIC_SPI 137 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 138 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 153 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 154 IRQ_TYPE_LEVEL_HIGH>; - interrupt-affinity = <&cpu0>, <&cpu1>, <&cpu2>, <&cpu3>; +&cbus { + spifc: spi@8c80 { + compatible = "amlogic,meson-gxbb-spifc"; + reg = <0x0 0x08c80 0x0 0x80>; + #address-cells = <1>; + #size-cells = <0>; + clocks = <&clkc CLKID_SPI>; + status = "disabled"; }; +}; + +ðmac { + clocks = <&clkc CLKID_ETH>, + <&clkc CLKID_FCLK_DIV2>, + <&clkc CLKID_MPLL2>; + clock-names = "stmmaceth", "clkin0", "clkin1"; +}; + +&aobus { + pinctrl_aobus: pinctrl@14 { + compatible = "amlogic,meson-gxbb-aobus-pinctrl"; + #address-cells = <2>; + #size-cells = <2>; + ranges; + + gpio_ao: bank@14 { + reg = <0x0 0x00014 0x0 0x8>, + <0x0 0x0002c 0x0 0x4>, + <0x0 0x00024 0x0 0x8>; + reg-names = "mux", "pull", "gpio"; + gpio-controller; + #gpio-cells = <2>; + }; + + uart_ao_a_pins: uart_ao_a { + mux { + groups = "uart_tx_ao_a", "uart_rx_ao_a"; + function = "uart_ao"; + }; + }; + + uart_ao_a_cts_rts_pins: uart_ao_a_cts_rts { + mux { + groups = "uart_cts_ao_a", + "uart_rts_ao_a"; + function = "uart_ao"; + }; + }; + + uart_ao_b_pins: uart_ao_b { + mux { + groups = "uart_tx_ao_b", "uart_rx_ao_b"; + function = "uart_ao_b"; + }; + }; + + uart_ao_b_cts_rts_pins: uart_ao_b_cts_rts { + mux { + groups = "uart_cts_ao_b", + "uart_rts_ao_b"; + function = "uart_ao_b"; + }; + };
- psci { - compatible = "arm,psci-0.2"; - method = "smc"; + remote_input_ao_pins: remote_input_ao { + mux { + groups = "remote_input_ao"; + function = "remote_input_ao"; + }; + }; + + i2c_ao_pins: i2c_ao { + mux { + groups = "i2c_sck_ao", + "i2c_sda_ao"; + function = "i2c_ao"; + }; + }; + + pwm_ao_a_3_pins: pwm_ao_a_3 { + mux { + groups = "pwm_ao_a_3"; + function = "pwm_ao_a_3"; + }; + }; + + pwm_ao_a_6_pins: pwm_ao_a_6 { + mux { + groups = "pwm_ao_a_6"; + function = "pwm_ao_a_6"; + }; + }; + + pwm_ao_a_12_pins: pwm_ao_a_12 { + mux { + groups = "pwm_ao_a_12"; + function = "pwm_ao_a_12"; + }; + }; + + pwm_ao_b_pins: pwm_ao_b { + mux { + groups = "pwm_ao_b"; + function = "pwm_ao_b"; + }; + }; };
- timer { - compatible = "arm,armv8-timer"; - interrupts = <GIC_PPI 13 - (GIC_CPU_MASK_RAW(0xff) | IRQ_TYPE_EDGE_RISING)>, - <GIC_PPI 14 - (GIC_CPU_MASK_RAW(0xff) | IRQ_TYPE_EDGE_RISING)>, - <GIC_PPI 11 - (GIC_CPU_MASK_RAW(0xff) | IRQ_TYPE_EDGE_RISING)>, - <GIC_PPI 10 - (GIC_CPU_MASK_RAW(0xff) | IRQ_TYPE_EDGE_RISING)>; + clkc_AO: clock-controller@040 { + compatible = "amlogic,gxbb-aoclkc"; + reg = <0x0 0x00040 0x0 0x4>; + #clock-cells = <1>; + #reset-cells = <1>; };
- xtal: xtal-clk { - compatible = "fixed-clock"; - clock-frequency = <24000000>; - clock-output-names = "xtal"; - #clock-cells = <0>; + pwm_ab_AO: pwm@550 { + compatible = "amlogic,meson-gxbb-pwm"; + reg = <0x0 0x0550 0x0 0x10>; + #pwm-cells = <3>; + status = "disabled"; };
- soc { - compatible = "simple-bus"; + i2c_AO: i2c@500 { + compatible = "amlogic,meson-gxbb-i2c"; + reg = <0x0 0x500 0x0 0x20>; + interrupts = <GIC_SPI 195 IRQ_TYPE_EDGE_RISING>; + clocks = <&clkc CLKID_AO_I2C>; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + }; +}; + +&periphs { + pinctrl_periphs: pinctrl@4b0 { + compatible = "amlogic,meson-gxbb-periphs-pinctrl"; #address-cells = <2>; #size-cells = <2>; ranges;
- cbus: cbus@c1100000 { - compatible = "simple-bus"; - reg = <0x0 0xc1100000 0x0 0x100000>; - #address-cells = <2>; - #size-cells = <2>; - ranges = <0x0 0x0 0x0 0xc1100000 0x0 0x100000>; - - reset: reset-controller@4404 { - compatible = "amlogic,meson-gxbb-reset"; - reg = <0x0 0x04404 0x0 0x20>; - #reset-cells = <1>; - }; - - uart_A: serial@84c0 { - compatible = "amlogic,meson-uart"; - reg = <0x0 0x84c0 0x0 0x14>; - interrupts = <GIC_SPI 26 IRQ_TYPE_EDGE_RISING>; - clocks = <&xtal>; - status = "disabled"; - }; - - uart_B: serial@84dc { - compatible = "amlogic,meson-uart"; - reg = <0x0 0x84dc 0x0 0x14>; - interrupts = <GIC_SPI 75 IRQ_TYPE_EDGE_RISING>; - clocks = <&xtal>; - status = "disabled"; - }; - - uart_C: serial@8700 { - compatible = "amlogic,meson-uart"; - reg = <0x0 0x8700 0x0 0x14>; - interrupts = <GIC_SPI 93 IRQ_TYPE_EDGE_RISING>; - clocks = <&xtal>; - status = "disabled"; - }; - }; - - gic: interrupt-controller@c4301000 { - compatible = "arm,gic-400"; - reg = <0x0 0xc4301000 0 0x1000>, - <0x0 0xc4302000 0 0x2000>, - <0x0 0xc4304000 0 0x2000>, - <0x0 0xc4306000 0 0x2000>; - interrupt-controller; - interrupts = <GIC_PPI 9 - (GIC_CPU_MASK_SIMPLE(8) | IRQ_TYPE_LEVEL_HIGH)>; - #interrupt-cells = <3>; - #address-cells = <0>; - }; - - aobus: aobus@c8100000 { - compatible = "simple-bus"; - reg = <0x0 0xc8100000 0x0 0x100000>; - #address-cells = <2>; - #size-cells = <2>; - ranges = <0x0 0x0 0x0 0xc8100000 0x0 0x100000>; - - pinctrl_aobus: pinctrl@14 { - compatible = "amlogic,meson-gxbb-aobus-pinctrl"; - #address-cells = <2>; - #size-cells = <2>; - ranges; - - gpio_ao: bank@14 { - reg = <0x0 0x00014 0x0 0x8>, - <0x0 0x0002c 0x0 0x4>, - <0x0 0x00024 0x0 0x8>; - reg-names = "mux", "pull", "gpio"; - gpio-controller; - #gpio-cells = <2>; - }; - - uart_ao_a_pins: uart_ao_a { - mux { - groups = "uart_tx_ao_a", "uart_rx_ao_a"; - function = "uart_ao"; - }; - }; - }; - - uart_AO: serial@4c0 { - compatible = "amlogic,meson-uart"; - reg = <0x0 0x004c0 0x0 0x14>; - interrupts = <GIC_SPI 193 IRQ_TYPE_EDGE_RISING>; - clocks = <&xtal>; - status = "disabled"; - }; - }; - - periphs: periphs@c8834000 { - compatible = "simple-bus"; - reg = <0x0 0xc8834000 0x0 0x2000>; - #address-cells = <2>; - #size-cells = <2>; - ranges = <0x0 0x0 0x0 0xc8834000 0x0 0x2000>; - - rng { - compatible = "amlogic,meson-rng"; - reg = <0x0 0x0 0x0 0x4>; - }; - - pinctrl_periphs: pinctrl@4b0 { - compatible = "amlogic,meson-gxbb-periphs-pinctrl"; - #address-cells = <2>; - #size-cells = <2>; - ranges; - - gpio: bank@4b0 { - reg = <0x0 0x004b0 0x0 0x28>, - <0x0 0x004e8 0x0 0x14>, - <0x0 0x00120 0x0 0x14>, - <0x0 0x00430 0x0 0x40>; - reg-names = "mux", "pull", "pull-enable", "gpio"; - gpio-controller; - #gpio-cells = <2>; - }; - - emmc_pins: emmc { - mux { - groups = "emmc_nand_d07", - "emmc_cmd", - "emmc_clk"; - function = "emmc"; - }; - }; - - sdcard_pins: sdcard { - mux { - groups = "sdcard_d0", - "sdcard_d1", - "sdcard_d2", - "sdcard_d3", - "sdcard_cmd", - "sdcard_clk"; - function = "sdcard"; - }; - }; - - uart_a_pins: uart_a { - mux { - groups = "uart_tx_a", - "uart_rx_a"; - function = "uart_a"; - }; - }; - - uart_b_pins: uart_b { - mux { - groups = "uart_tx_b", - "uart_rx_b"; - function = "uart_b"; - }; - }; - - uart_c_pins: uart_c { - mux { - groups = "uart_tx_c", - "uart_rx_c"; - function = "uart_c"; - }; - }; - - eth_pins: eth_c { - mux { - groups = "eth_mdio", - "eth_mdc", - "eth_clk_rx_clk", - "eth_rx_dv", - "eth_rxd0", - "eth_rxd1", - "eth_rxd2", - "eth_rxd3", - "eth_rgmii_tx_clk", - "eth_tx_en", - "eth_txd0", - "eth_txd1", - "eth_txd2", - "eth_txd3"; - function = "eth"; - }; - }; - }; - }; - - hiubus: hiubus@c883c000 { - compatible = "simple-bus"; - reg = <0x0 0xc883c000 0x0 0x2000>; - #address-cells = <2>; - #size-cells = <2>; - ranges = <0x0 0x0 0x0 0xc883c000 0x0 0x2000>; - - clkc: clock-controller@0 { - compatible = "amlogic,gxbb-clkc"; - #clock-cells = <1>; - reg = <0x0 0x0 0x0 0x3db>; - }; - }; - - apb: apb@d0000000 { - compatible = "simple-bus"; - reg = <0x0 0xd0000000 0x0 0x200000>; - #address-cells = <2>; - #size-cells = <2>; - ranges = <0x0 0x0 0x0 0xd0000000 0x0 0x200000>; - }; - - ethmac: ethernet@c9410000 { - compatible = "amlogic,meson6-dwmac", "snps,dwmac"; - reg = <0x0 0xc9410000 0x0 0x10000 - 0x0 0xc8834540 0x0 0x4>; - interrupts = <0 8 1>; - interrupt-names = "macirq"; - clocks = <&xtal>; - clock-names = "stmmaceth"; - phy-mode = "rgmii"; - status = "disabled"; + gpio: bank@4b0 { + reg = <0x0 0x004b0 0x0 0x28>, + <0x0 0x004e8 0x0 0x14>, + <0x0 0x00120 0x0 0x14>, + <0x0 0x00430 0x0 0x40>; + reg-names = "mux", "pull", "pull-enable", "gpio"; + gpio-controller; + #gpio-cells = <2>; + }; + + emmc_pins: emmc { + mux { + groups = "emmc_nand_d07", + "emmc_cmd", + "emmc_clk", + "emmc_ds"; + function = "emmc"; + }; + }; + + nor_pins: nor { + mux { + groups = "nor_d", + "nor_q", + "nor_c", + "nor_cs"; + function = "nor"; + }; + }; + + sdcard_pins: sdcard { + mux { + groups = "sdcard_d0", + "sdcard_d1", + "sdcard_d2", + "sdcard_d3", + "sdcard_cmd", + "sdcard_clk"; + function = "sdcard"; + }; + }; + + sdio_pins: sdio { + mux { + groups = "sdio_d0", + "sdio_d1", + "sdio_d2", + "sdio_d3", + "sdio_cmd", + "sdio_clk"; + function = "sdio"; + }; + }; + + sdio_irq_pins: sdio_irq { + mux { + groups = "sdio_irq"; + function = "sdio"; + }; + }; + + uart_a_pins: uart_a { + mux { + groups = "uart_tx_a", + "uart_rx_a"; + function = "uart_a"; + }; + }; + + uart_a_cts_rts_pins: uart_a_cts_rts { + mux { + groups = "uart_cts_a", + "uart_rts_a"; + function = "uart_a"; + }; + }; + + uart_b_pins: uart_b { + mux { + groups = "uart_tx_b", + "uart_rx_b"; + function = "uart_b"; + }; + }; + + uart_b_cts_rts_pins: uart_b_cts_rts { + mux { + groups = "uart_cts_b", + "uart_rts_b"; + function = "uart_b"; + }; + }; + + uart_c_pins: uart_c { + mux { + groups = "uart_tx_c", + "uart_rx_c"; + function = "uart_c"; + }; + }; + + uart_c_cts_rts_pins: uart_c_cts_rts { + mux { + groups = "uart_cts_c", + "uart_rts_c"; + function = "uart_c"; + }; + }; + + i2c_a_pins: i2c_a { + mux { + groups = "i2c_sck_a", + "i2c_sda_a"; + function = "i2c_a"; + }; + }; + + i2c_b_pins: i2c_b { + mux { + groups = "i2c_sck_b", + "i2c_sda_b"; + function = "i2c_b"; + }; + }; + + i2c_c_pins: i2c_c { + mux { + groups = "i2c_sck_c", + "i2c_sda_c"; + function = "i2c_c"; + }; + }; + + eth_rgmii_pins: eth-rgmii { + mux { + groups = "eth_mdio", + "eth_mdc", + "eth_clk_rx_clk", + "eth_rx_dv", + "eth_rxd0", + "eth_rxd1", + "eth_rxd2", + "eth_rxd3", + "eth_rgmii_tx_clk", + "eth_tx_en", + "eth_txd0", + "eth_txd1", + "eth_txd2", + "eth_txd3"; + function = "eth"; + }; + }; + + eth_rmii_pins: eth-rmii { + mux { + groups = "eth_mdio", + "eth_mdc", + "eth_clk_rx_clk", + "eth_rx_dv", + "eth_rxd0", + "eth_rxd1", + "eth_tx_en", + "eth_txd0", + "eth_txd1"; + function = "eth"; + }; + }; + + pwm_a_x_pins: pwm_a_x { + mux { + groups = "pwm_a_x"; + function = "pwm_a_x"; + }; + }; + + pwm_a_y_pins: pwm_a_y { + mux { + groups = "pwm_a_y"; + function = "pwm_a_y"; + }; + }; + + pwm_b_pins: pwm_b { + mux { + groups = "pwm_b"; + function = "pwm_b"; + }; + }; + + pwm_d_pins: pwm_d { + mux { + groups = "pwm_d"; + function = "pwm_d"; + }; + }; + + pwm_e_pins: pwm_e { + mux { + groups = "pwm_e"; + function = "pwm_e"; + }; + }; + + pwm_f_x_pins: pwm_f_x { + mux { + groups = "pwm_f_x"; + function = "pwm_f_x"; + }; + }; + + pwm_f_y_pins: pwm_f_y { + mux { + groups = "pwm_f_y"; + function = "pwm_f_y"; + }; + }; + + hdmi_hpd_pins: hdmi_hpd { + mux { + groups = "hdmi_hpd"; + function = "hdmi_hpd"; + }; + }; + + hdmi_i2c_pins: hdmi_i2c { + mux { + groups = "hdmi_sda", "hdmi_scl"; + function = "hdmi_i2c"; + }; }; }; }; + +&hiubus { + clkc: clock-controller@0 { + compatible = "amlogic,gxbb-clkc"; + #clock-cells = <1>; + reg = <0x0 0x0 0x0 0x3db>; + }; +}; + +&i2c_A { + clocks = <&clkc CLKID_I2C>; +}; + +&i2c_B { + clocks = <&clkc CLKID_I2C>; +}; + +&i2c_C { + clocks = <&clkc CLKID_I2C>; +}; + +&sd_emmc_a { + clocks = <&clkc CLKID_SD_EMMC_A>, + <&xtal>, + <&clkc CLKID_FCLK_DIV2>; + clock-names = "core", "clkin0", "clkin1"; +}; + +&sd_emmc_b { + clocks = <&clkc CLKID_SD_EMMC_B>, + <&xtal>, + <&clkc CLKID_FCLK_DIV2>; + clock-names = "core", "clkin0", "clkin1"; +}; + +&sd_emmc_c { + clocks = <&clkc CLKID_SD_EMMC_C>, + <&xtal>, + <&clkc CLKID_FCLK_DIV2>; + clock-names = "core", "clkin0", "clkin1"; +}; + +&vpu { + compatible = "amlogic,meson-gxbb-vpu", "amlogic,meson-gx-vpu"; +}; diff --git a/include/dt-bindings/clock/gxbb-aoclkc.h b/include/dt-bindings/clock/gxbb-aoclkc.h new file mode 100644 index 0000000..3175148 --- /dev/null +++ b/include/dt-bindings/clock/gxbb-aoclkc.h @@ -0,0 +1,66 @@ +/* + * This file is provided under a dual BSD/GPLv2 license. When using or + * redistributing this file, you may do so under either license. + * + * GPL LICENSE SUMMARY + * + * Copyright (c) 2016 BayLibre, SAS. + * Author: Neil Armstrong narmstrong@baylibre.com + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of version 2 of the GNU General Public License as + * published by the Free Software Foundation. + * + * This program is distributed in the hope that it will be useful, but + * WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU + * General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, see http://www.gnu.org/licenses/. + * The full GNU General Public License is included in this distribution + * in the file called COPYING. + * + * BSD LICENSE + * + * Copyright (c) 2016 BayLibre, SAS. + * Author: Neil Armstrong narmstrong@baylibre.com + * + * Redistribution and use in source and binary forms, with or without + * modification, are permitted provided that the following conditions + * are met: + * + * * Redistributions of source code must retain the above copyright + * notice, this list of conditions and the following disclaimer. + * * Redistributions in binary form must reproduce the above copyright + * notice, this list of conditions and the following disclaimer in + * the documentation and/or other materials provided with the + * distribution. + * * Neither the name of Intel Corporation nor the names of its + * contributors may be used to endorse or promote products derived + * from this software without specific prior written permission. + * + * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS + * "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT + * LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR + * A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT + * OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, + * SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT + * LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, + * DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY + * THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT + * (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE + * OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. + */ + +#ifndef DT_BINDINGS_CLOCK_AMLOGIC_MESON_GXBB_AOCLK +#define DT_BINDINGS_CLOCK_AMLOGIC_MESON_GXBB_AOCLK + +#define CLKID_AO_REMOTE 0 +#define CLKID_AO_I2C_MASTER 1 +#define CLKID_AO_I2C_SLAVE 2 +#define CLKID_AO_UART1 3 +#define CLKID_AO_UART2 4 +#define CLKID_AO_IR_BLASTER 5 + +#endif diff --git a/include/dt-bindings/clock/gxbb-clkc.h b/include/dt-bindings/clock/gxbb-clkc.h new file mode 100644 index 0000000..692846c --- /dev/null +++ b/include/dt-bindings/clock/gxbb-clkc.h @@ -0,0 +1,34 @@ +/* + * GXBB clock tree IDs + */ + +#ifndef __GXBB_CLKC_H +#define __GXBB_CLKC_H + +#define CLKID_CPUCLK 1 +#define CLKID_HDMI_PLL 2 +#define CLKID_FCLK_DIV2 4 +#define CLKID_FCLK_DIV3 5 +#define CLKID_FCLK_DIV4 6 +#define CLKID_CLK81 12 +#define CLKID_MPLL2 15 +#define CLKID_SPI 34 +#define CLKID_I2C 22 +#define CLKID_SAR_ADC 23 +#define CLKID_ETH 36 +#define CLKID_USB0 50 +#define CLKID_USB1 51 +#define CLKID_USB 55 +#define CLKID_HDMI_PCLK 63 +#define CLKID_USB1_DDR_BRIDGE 64 +#define CLKID_USB0_DDR_BRIDGE 65 +#define CLKID_SANA 69 +#define CLKID_GCLK_VENCI_INT0 77 +#define CLKID_AO_I2C 93 +#define CLKID_SD_EMMC_A 94 +#define CLKID_SD_EMMC_B 95 +#define CLKID_SD_EMMC_C 96 +#define CLKID_SAR_ADC_CLK 97 +#define CLKID_SAR_ADC_SEL 98 + +#endif /* __GXBB_CLKC_H */ diff --git a/include/dt-bindings/reset/gxbb-aoclkc.h b/include/dt-bindings/reset/gxbb-aoclkc.h new file mode 100644 index 0000000..9e3fd60 --- /dev/null +++ b/include/dt-bindings/reset/gxbb-aoclkc.h @@ -0,0 +1,66 @@ +/* + * This file is provided under a dual BSD/GPLv2 license. When using or + * redistributing this file, you may do so under either license. + * + * GPL LICENSE SUMMARY + * + * Copyright (c) 2016 BayLibre, SAS. + * Author: Neil Armstrong narmstrong@baylibre.com + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of version 2 of the GNU General Public License as + * published by the Free Software Foundation. + * + * This program is distributed in the hope that it will be useful, but + * WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU + * General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, see http://www.gnu.org/licenses/. + * The full GNU General Public License is included in this distribution + * in the file called COPYING. + * + * BSD LICENSE + * + * Copyright (c) 2016 BayLibre, SAS. + * Author: Neil Armstrong narmstrong@baylibre.com + * + * Redistribution and use in source and binary forms, with or without + * modification, are permitted provided that the following conditions + * are met: + * + * * Redistributions of source code must retain the above copyright + * notice, this list of conditions and the following disclaimer. + * * Redistributions in binary form must reproduce the above copyright + * notice, this list of conditions and the following disclaimer in + * the documentation and/or other materials provided with the + * distribution. + * * Neither the name of Intel Corporation nor the names of its + * contributors may be used to endorse or promote products derived + * from this software without specific prior written permission. + * + * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS + * "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT + * LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR + * A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT + * OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, + * SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT + * LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, + * DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY + * THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT + * (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE + * OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. + */ + +#ifndef DT_BINDINGS_RESET_AMLOGIC_MESON_GXBB_AOCLK +#define DT_BINDINGS_RESET_AMLOGIC_MESON_GXBB_AOCLK + +#define RESET_AO_REMOTE 0 +#define RESET_AO_I2C_MASTER 1 +#define RESET_AO_I2C_SLAVE 2 +#define RESET_AO_UART1 3 +#define RESET_AO_UART2 4 +#define RESET_AO_IR_BLASTER 5 + +#endif
Hmm..There are Neil, Carlo and Andreas as Authors in each files. Why don't you add their signed-off tags?
- Copyright (c) 2016 Andreas Färber
- Copyright (c) 2016 BayLibre, SAS.
- Author: Neil Armstrong narmstrong@baylibre.com
- Copyright (c) 2016 Endless Computers, Inc.
- Author: Carlo Caione carlo@endlessm.com
- This file is dual-licensed: you can use it either under the terms
- of the GPL or the X11 license, at your option. Note that this dual
- licensing only applies to this file, and not this project as a
- whole.
- a) This library is free software; you can redistribute it and/or
- Or, alternatively,
- b) Permission is hereby granted, free of charge, to any person
conditions:
Refer to License/README
- reserved-memory {
#size-cells = <2>;
ranges;
no-map;
no-map;
- cpus {
cpu0: cpu@0 {
reg = <0x0 0x0>;
cpu1: cpu@1 {
reg = <0x0 0x1>;
cpu2: cpu@2 {
reg = <0x0 0x2>;
cpu3: cpu@3 {
reg = <0x0 0x3>;
l2: l2-cache0 {
- arm-pmu {
- psci {
method = "smc";
- timer {
<GIC_PPI 14
<GIC_PPI 11
<GIC_PPI 10
- xtal: xtal-clk {
#clock-cells = <0>;
- firmware {
- efuse: efuse {
#size-cells = <1>;
sn: sn@14 {
reg = <0x14 0x10>;
reg = <0x34 0x10>;
bid: bid@46 {
reg = <0x46 0x30>;
- scpi {
#clock-cells = <1>;
- soc {
#size-cells = <2>;
ranges;
#size-cells = <2>;
#reset-cells = <1>;
clocks = <&xtal>;
clocks = <&xtal>;
i2c_A: i2c@8500 {
#size-cells = <0>;
pwm_ab: pwm@8550 {
#pwm-cells = <3>;
pwm_cd: pwm@8650 {
#pwm-cells = <3>;
pwm_ef: pwm@86c0 {
#pwm-cells = <3>;
clocks = <&xtal>;
i2c_B: i2c@87c0 {
#size-cells = <0>;
i2c_C: i2c@87e0 {
#size-cells = <0>;
watchdog@98d0 {
clocks = <&xtal>;
#size-cells = <1>;
#size-cells = <2>;
clocks = <&xtal>;
clocks = <&xtal>;
ir: ir@580 {
#size-cells = <2>;
rng {
#size-cells = <2>;
#mbox-cells = <1>;
phy-mode = "rgmii";
apb: apb@d0000000 {
#size-cells = <2>;
vpu: vpu@d0100000 {
#size-cells = <0>;
reg = <0>;
- usb_otg_pwr: regulator-usb-pwrs {
enable-active-high;
- leds { compatible = "gpio-leds"; blue {
- tflash_vdd: regulator-tflash_vdd {
enable-active-high;
- tf_io: gpio-regulator-tf_io {
gpios-states = <0>;
states = <3300000 0
1800000 1>;
- vcc1v8: regulator-vcc1v8 {
- vcc3v3: regulator-vcc3v3 {
- emmc_pwrseq: emmc-pwrseq {
+&scpi_clocks {
- pinctrl-0 = <ð_rgmii_pins>;
- pinctrl-names = "default";
- phy-handle = <ð_phy0>;
- mdio {
#size-cells = <0>;
reg = <0>;
eee-broken-1000t;
+&ir {
- status = "okay";
- pinctrl-0 = <&remote_input_ao_pins>; pinctrl-names = "default";
+&i2c_A {
- status = "okay";
- pinctrl-0 = <&i2c_a_pins>;
+&usb0_phy {
- status = "okay";
- phy-supply = <&usb_otg_pwr>;
+&usb1_phy {
- status = "okay";
+&usb0 {
- status = "okay";
+&usb1 {
- status = "okay";
- status = "okay";
- pinctrl-0 = <&sdcard_pins>;
- bus-width = <4>;
- cap-sd-highspeed;
- max-frequency = <100000000>;
- disable-wp;
- cd-gpios = <&gpio CARD_6 GPIO_ACTIVE_HIGH>;
- cd-inverted;
- vmmc-supply = <&tflash_vdd>;
- vqmmc-supply = <&tf_io>;
- status = "okay";
- pinctrl-0 = <&emmc_pins>;
- bus-width = <8>;
- cap-sd-highspeed;
- max-frequency = <200000000>;
- non-removable;
- disable-wp;
- cap-mmc-highspeed;
- mmc-ddr-1_8v;
- mmc-hs200-1_8v;
- mmc-pwrseq = <&emmc_pwrseq>;
- vmmc-supply = <&vcc3v3>;
- vqmmc-supply = <&vcc1v8>;
#size-cells = <2>;
cpus {
cpu0: cpu@0 {
reg = <0x0 0x0>;
- soc {
#phy-cells = <0>;
};status = "disabled";
cpu1: cpu@1 {
reg = <0x0 0x1>;
#phy-cells = <0>;
cpu2: cpu@2 {
reg = <0x0 0x2>;
phys = <&usb0_phy>;
dr_mode = "host";
cpu3: cpu@3 {
reg = <0x0 0x3>;
phys = <&usb1_phy>;
dr_mode = "host";
}; };status = "disabled";
- arm-pmu {
+&cbus {
- spifc: spi@8c80 {
#size-cells = <0>;
+ðmac {
- clocks = <&clkc CLKID_ETH>,
- clock-names = "stmmaceth", "clkin0", "clkin1";
+&aobus {
#size-cells = <2>;
ranges;
gpio_ao: bank@14 {
gpio-controller;
#gpio-cells = <2>;
mux {
mux {
"uart_rts_ao_a";
mux {
mux {
"uart_rts_ao_b";
- psci {
method = "smc";
mux {
mux {
"i2c_sda_ao";
mux {
mux {
mux {
mux {
- timer {
<GIC_PPI 14
<GIC_PPI 11
<GIC_PPI 10
- clkc_AO: clock-controller@040 {
#clock-cells = <1>;
};#reset-cells = <1>;
- xtal: xtal-clk {
#clock-cells = <0>;
- pwm_ab_AO: pwm@550 {
#pwm-cells = <3>;
- soc {
- i2c_AO: i2c@500 {
#size-cells = <0>;
+&periphs {
#address-cells = <2>; #size-cells = <2>; ranges;compatible = "amlogic,meson-gxbb-periphs-pinctrl";
#size-cells = <2>;
#reset-cells = <1>;
clocks = <&xtal>;
clocks = <&xtal>;
clocks = <&xtal>;
#size-cells = <2>;
#size-cells = <2>;
ranges;
gpio_ao: bank@14 {
gpio-controller;
#gpio-cells = <2>;
mux {
clocks = <&xtal>;
#size-cells = <2>;
rng {
#size-cells = <2>;
ranges;
gpio: bank@4b0 {
gpio-controller;
#gpio-cells = <2>;
emmc_pins: emmc {
mux {
"emmc_cmd",
"emmc_clk";
function = "emmc";
mux {
"sdcard_d1",
"sdcard_d2",
"sdcard_d3",
"sdcard_cmd",
"sdcard_clk";
mux {
"uart_rx_a";
mux {
"uart_rx_b";
mux {
"uart_rx_c";
eth_pins: eth_c {
mux {
"eth_mdc",
"eth_clk_rx_clk",
"eth_rx_dv",
"eth_rxd0",
"eth_rxd1",
"eth_rxd2",
"eth_rxd3",
"eth_rgmii_tx_clk",
"eth_tx_en",
"eth_txd0",
"eth_txd1",
"eth_txd2",
"eth_txd3";
function = "eth";
#size-cells = <2>;
#clock-cells = <1>;
apb: apb@d0000000 {
#size-cells = <2>;
clocks = <&xtal>;
phy-mode = "rgmii";
gpio: bank@4b0 {
gpio-controller;
#gpio-cells = <2>;
emmc_pins: emmc {
mux {
"emmc_cmd",
"emmc_clk",
"emmc_ds";
function = "emmc";
nor_pins: nor {
mux {
groups = "nor_d",
"nor_q",
"nor_c",
"nor_cs";
function = "nor";
mux {
"sdcard_d1",
"sdcard_d2",
"sdcard_d3",
"sdcard_cmd",
"sdcard_clk";
sdio_pins: sdio {
mux {
groups = "sdio_d0",
"sdio_d1",
"sdio_d2",
"sdio_d3",
"sdio_cmd",
"sdio_clk";
function = "sdio";
mux {
function = "sdio";
mux {
"uart_rx_a";
mux {
"uart_rts_a";
mux {
"uart_rx_b";
mux {
"uart_rts_b";
mux {
"uart_rx_c";
mux {
"uart_rts_c";
i2c_a_pins: i2c_a {
mux {
"i2c_sda_a";
function = "i2c_a";
i2c_b_pins: i2c_b {
mux {
"i2c_sda_b";
function = "i2c_b";
i2c_c_pins: i2c_c {
mux {
"i2c_sda_c";
function = "i2c_c";
mux {
"eth_mdc",
"eth_clk_rx_clk",
"eth_rx_dv",
"eth_rxd0",
"eth_rxd1",
"eth_rxd2",
"eth_rxd3",
"eth_rgmii_tx_clk",
"eth_tx_en",
"eth_txd0",
"eth_txd1",
"eth_txd2",
"eth_txd3";
function = "eth";
mux {
"eth_mdc",
"eth_clk_rx_clk",
"eth_rx_dv",
"eth_rxd0",
"eth_rxd1",
"eth_tx_en",
"eth_txd0",
"eth_txd1";
function = "eth";
mux {
groups = "pwm_a_x";
mux {
groups = "pwm_a_y";
pwm_b_pins: pwm_b {
mux {
groups = "pwm_b";
function = "pwm_b";
pwm_d_pins: pwm_d {
mux {
groups = "pwm_d";
function = "pwm_d";
pwm_e_pins: pwm_e {
mux {
groups = "pwm_e";
function = "pwm_e";
mux {
groups = "pwm_f_x";
mux {
groups = "pwm_f_y";
mux {
mux {
+&hiubus {
#clock-cells = <1>;
+&i2c_A {
- clocks = <&clkc CLKID_I2C>;
+&i2c_B {
+&i2c_C {
+&sd_emmc_a {
- clocks = <&clkc CLKID_SD_EMMC_A>,
<&xtal>,
- clock-names = "core", "clkin0", "clkin1";
+&sd_emmc_b {
- clocks = <&clkc CLKID_SD_EMMC_B>,
<&xtal>,
+&sd_emmc_c {
- clocks = <&clkc CLKID_SD_EMMC_C>,
<&xtal>,
+&vpu {
- compatible = "amlogic,meson-gxbb-vpu", "amlogic,meson-gx-vpu";
- This file is provided under a dual BSD/GPLv2 license. When using or
- redistributing this file, you may do so under either license.
- GPL LICENSE SUMMARY
- This program is free software; you can redistribute it and/or modify
- it under the terms of version 2 of the GNU General Public License as
- published by the Free Software Foundation.
- This program is distributed in the hope that it will be useful, but
- WITHOUT ANY WARRANTY; without even the implied warranty of
- MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
- General Public License for more details.
- along with this program; if not, see http://www.gnu.org/licenses/.
- The full GNU General Public License is included in this distribution
- in the file called COPYING.
- BSD LICENSE
- Redistribution and use in source and binary forms, with or without
- modification, are permitted provided that the following conditions
- are met:
- Redistributions of source code must retain the above copyright
- Redistributions in binary form must reproduce the above copyright
distribution.
- Neither the name of Intel Corporation nor the names of its
- THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
- "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
- LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
- A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
- OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
- SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
- LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
- DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
- THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
- (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
- OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
- GXBB clock tree IDs
- BSD LICENSE
- are met:
distribution.
Heiner Kallweit
Jaehoon Chung
