[bug] timer: orion-timer: static variable patch breaks armada-388-clearfog boot
Commit 5387b093 was a fix for early_init_done causing issues on Pogo v4 [1]. The fix breaks armada-388-clearfog because the boot hangs indefinitely.
It appears that the cause is an infinite loop in __udelay due to get_ticks() always returning 0. After adding some printf statements it became apparent that the timer was never getting initialised.
git-blame identified the "timer: orion-timer: Fix problem with early static variable" patch as a likely issue. Reverting the commit restores boot for armada-388-clearfog.
Patching the issue is a bit beyond me without understanding the Pogo v4 issue, but I'm happy to test any patches that are developed.
Regards
Martin
[1] https://lore.kernel.org/u-boot/20221221091849.1018783-1-sr@denx.de/
Hi Martin,
Did you build this clearfog board as is? i.e. did you make any change in the clearfog_defconfig?
Thanks, Tony
Tony
Regards
Martin
Tony,
clearfog_defconfig with: CONFIG_MVEBU_SPL_BOOT_DEVICE_SATA=y CONFIG_SPL_SATA=y
Plus a dts patch to sdhci@d8000 to make it work for eMMC (swap cd-gpios for non-removable) Plus a workaround that's not yet merged for a build failure with SATA from [1]
Shouldn't be anything that affects the timer, but I can try a fully clean build with the defconfig if you need it.
Regards
Martin
[1] https://lore.kernel.org/u-boot/20230110161946.3816866-8-trini@konsulko.com/
Hi Martin,
On 1/16/23 06:20, Martin Rowe wrote:
Tony,
No need for this.
Could you please test with this attached patch, if this fixes this issue on your clearfog?
Thanks, Stefan
Martin Rowe
Stefan Roese
Tony Dinh
