[U-Boot] [PATCH] ti: am335x/am437x/omap5 devices: Unify network environment variables
Across several devices network environment variables are duplicated. Move these variables to a common include file which insures the environment variables are reused and insures devices across product lines share the same values.
Signed-off-by: Franklin S Cooper Jr fcooper@ti.com --- include/configs/am335x_evm.h | 17 +---------------- include/configs/am43xx_evm.h | 1 + include/configs/ti_armv7_common.h | 25 +++++++++++++++++++++++++ include/configs/ti_omap5_common.h | 13 +------------ 4 files changed, 28 insertions(+), 28 deletions(-)
diff --git a/include/configs/am335x_evm.h b/include/configs/am335x_evm.h index a87059c..8da3325 100644 --- a/include/configs/am335x_evm.h +++ b/include/configs/am335x_evm.h @@ -83,10 +83,6 @@ "mmcdev=0\0" \ "mmcroot=/dev/mmcblk0p2 ro\0" \ "mmcrootfstype=ext4 rootwait\0" \ - "rootpath=/export/rootfs\0" \ - "nfsopts=nolock\0" \ - "static_ip=${ipaddr}:${serverip}:${gatewayip}:${netmask}:${hostname}" \ - "::off\0" \ "ramroot=/dev/ram0 rw\0" \ "ramrootfstype=ext2\0" \ "mmcargs=setenv bootargs console=${console} " \ @@ -102,11 +98,6 @@ "${optargs} " \ "root=${spiroot} " \ "rootfstype=${spirootfstype}\0" \ - "netargs=setenv bootargs console=${console} " \ - "${optargs} " \ - "root=/dev/nfs " \ - "nfsroot=${serverip}:${rootpath},${nfsopts} rw " \ - "ip=dhcp\0" \ "bootenv=uEnv.txt\0" \ "loadbootscript=load mmc ${mmcdev} ${loadaddr} boot.scr\0" \ "bootscript=echo Running bootscript from mmc${mmcdev} ...; " \ @@ -159,13 +150,6 @@ "sf probe ${spibusno}:0; " \ "sf read ${loadaddr} ${spisrcaddr} ${spiimgsize}; " \ "bootz ${loadaddr}\0" \ - "netboot=echo Booting from network ...; " \ - "setenv autoload no; " \ - "dhcp; " \ - "tftp ${loadaddr} ${bootfile}; " \ - "tftp ${fdtaddr} ${fdtfile}; " \ - "run netargs; " \ - "bootz ${loadaddr} - ${fdtaddr}\0" \ "ramboot=echo Booting from ramdisk ...; " \ "run ramargs; " \ "bootz ${loadaddr} ${rdaddr} ${fdtaddr}\0" \ @@ -181,6 +165,7 @@ "if test $fdtfile = undefined; then " \ "echo WARNING: Could not determine device tree to use; fi; \0" \ NANDARGS \ + NETARGS \ DFUARGS #endif
diff --git a/include/configs/am43xx_evm.h b/include/configs/am43xx_evm.h index 6eb31e2..331fdac 100644 --- a/include/configs/am43xx_evm.h +++ b/include/configs/am43xx_evm.h @@ -295,6 +295,7 @@ "setenv fdtfile am437x-idk-evm.dtb; fi; " \ "if test $fdtfile = undefined; then " \ "echo WARNING: Could not determine device tree; fi; \0" \ + NETARGS \ DFUARGS \
#define CONFIG_BOOTCOMMAND \ diff --git a/include/configs/ti_armv7_common.h b/include/configs/ti_armv7_common.h index 110a4f8..f882942 100644 --- a/include/configs/ti_armv7_common.h +++ b/include/configs/ti_armv7_common.h @@ -279,4 +279,29 @@ #endif #endif /* !CONFIG_NOR_BOOT */
+/* Generic Environment Variables */ + +#ifdef CONFIG_CMD_NET +#define NETARGS \ + "static_ip=${ipaddr}:${serverip}:${gatewayip}:${netmask}:${hostname}" \ + "::off\0" \ + "nfsopts=nolock\0" \ + "rootpath=/export/rootfs\0" \ + "netloadimage=tftp ${loadaddr} ${bootfile}\0" \ + "netloadfdt=tftp ${fdtaddr} ${fdtfile}\0" \ + "netargs=setenv bootargs console=${console} " \ + "${optargs} " \ + "root=/dev/nfs " \ + "nfsroot=${serverip}:${rootpath},${nfsopts} rw " \ + "ip=dhcp\0" \ + "netboot=echo Booting from network ...; " \ + "setenv autoload no; " \ + "dhcp; " \ + "run netloadimage; " \ + "run netloadfdt; " \ + "run netargs; " \ + "bootz ${loadaddr} - ${fdtaddr}\0" + +#endif + #endif /* __CONFIG_TI_ARMV7_COMMON_H__ */ diff --git a/include/configs/ti_omap5_common.h b/include/configs/ti_omap5_common.h index 7957a73..791eade 100644 --- a/include/configs/ti_omap5_common.h +++ b/include/configs/ti_omap5_common.h @@ -92,11 +92,6 @@ "vram=${vram} " \ "root=${mmcroot} " \ "rootfstype=${mmcrootfstype}\0" \ - "netargs=setenv bootargs console=${console} " \ - "${optargs} " \ - "root=/dev/nfs " \ - "nfsroot=${serverip}:${rootpath},${nfsopts} rw " \ - "ip=dhcp\0" \ "loadbootscript=fatload mmc ${mmcdev} ${loadaddr} boot.scr\0" \ "bootscript=echo Running bootscript from mmc${mmcdev} ...; " \ "source ${loadaddr}\0" \ @@ -123,13 +118,6 @@ "bootz ${loadaddr} - ${fdtaddr}; " \ "fi;" \ "fi;\0" \ - "netboot=echo Booting from network ...; " \ - "set env autoload no; " \ - "dhcp; " \ - "tftp ${loadaddr} ${bootfile}; " \ - "tftp ${fdtaddr} ${fdtfile}; " \ - "run netargs; " \ - "bootz ${loadaddr} - ${fdtaddr}\0" \ "findfdt="\ "if test $board_name = omap5_uevm; then " \ "setenv fdtfile omap5-uevm.dtb; fi; " \ @@ -143,6 +131,7 @@ "echo WARNING: Could not determine device tree to use; fi; \0" \ "loadfdt=load mmc ${bootpart} ${fdtaddr} ${bootdir}/${fdtfile};\0" \ DFUARGS \ + NETARGS \
#define CONFIG_BOOTCOMMAND \ "run findfdt; " \
Signed-off-by: Franklin S Cooper Jr fcooper@ti.com Reviewed-by: Tom Rini trini@konsulko.com
