[U-Boot] [PATCH v2] driver: net: ldpaa: Update priv->phydev after free()
From: Prabhakar Kushwaha prabhakar.kushwaha@nxp.com
Even after memory free of phydev, priv is still pointing to the obsolete address. So update priv->phydev as NULL after memory free.
Signed-off-by: Prabhakar Kushwaha prabhakar.kushwaha@nxp.com Signed-off-by: Ashish Kumar Ashish.Kumar@nxp.com --- v2: Add signoff
drivers/net/ldpaa_eth/ldpaa_eth.c | 4 +++- 1 file changed, 3 insertions(+), 1 deletion(-)
diff --git a/drivers/net/ldpaa_eth/ldpaa_eth.c b/drivers/net/ldpaa_eth/ldpaa_eth.c index 4e61700..f235b62 100644 --- a/drivers/net/ldpaa_eth/ldpaa_eth.c +++ b/drivers/net/ldpaa_eth/ldpaa_eth.c @@ -587,8 +587,10 @@ static void ldpaa_eth_stop(struct eth_device *net_dev) #ifdef CONFIG_PHYLIB if (priv->phydev && bus != NULL) phy_shutdown(priv->phydev); - else + else { free(priv->phydev); + priv->phydev = NULL; + } #endif
ldpaa_dpbp_free();
Please always Cc me on network changes.
v2: Add signoff
else
This is strange. Why not just drop the free? It seems bad to delete the phydev just because the mdio interface is not there, especially in stop().
#endif
ldpaa_dpbp_free();
-- 1.9.1
Hello Joe,
Please see inline.
Regards Ashish
-----Original Message----- From: Joe Hershberger [mailto:joe.hershberger@gmail.com] Sent: Thursday, February 16, 2017 5:22 AM To: Ashish Kumar ashish.kumar@nxp.com Cc: u-boot u-boot@lists.denx.de Subject: Re: [U-Boot] [PATCH v2] driver: net: ldpaa: Update priv->phydev after free()
v2: Add signoff
else
This is strange. Why not just drop the free? It seems bad to delete the phydev just because the mdio interface is not there, especially in stop(). [Ashish Kumar] To keep the flow consistent of XFI(which is phy-less) to other phy based interface, in ldpaa_eth_open there are some dummy allocation, which is freed in the end in stop(). if ((bus == NULL) && (enet_if == PHY_INTERFACE_MODE_XGMII)) { printf("%s %s %d\n",__FILE__, __func__, __LINE__); priv->phydev = (struct phy_device *) malloc(sizeof(struct phy_device)); memset(priv->phydev, 0, sizeof(struct phy_device));
priv->phydev->speed = SPEED_10000; priv->phydev->link = 1; priv->phydev->duplex = DUPLEX_FULL; }
#endif
ldpaa_dpbp_free();
-- 1.9.1
Hi Guys,
I want to understand cpu release command of u-boot and its implementation.
When we do cpu release <Cpu no> the satndalone application (may be kernel or so) starts running on particular processor. How does it happens ? Can anyone pls let me know this logic and point me in U -boot code for this function ?
BR/Krish
On Tue, Feb 21, 2017 at 1:17 PM, Ashish Kumar ashish.kumar@nxp.com wrote:
Hello Joe,
Please see inline.
Regards Ashish
v2: Add signoff
else
#endif
ldpaa_dpbp_free();
-- 1.9.1
On Tue, Feb 21, 2017 at 7:09 AM, Er Krishna erkrishna@gmail.com wrote:
Hi Guys,
Please dispense with the top-posting and the thread hijacking.
-Joe
BR/Krish
Hello Joe,
Please see inline.
Regards Ashish
Hello Joe,
Could you please ack if there are no further queries.
Regards Ashish -----Original Message----- From: U-Boot [mailto:u-boot-bounces@lists.denx.de] On Behalf Of Ashish Kumar Sent: Tuesday, February 21, 2017 1:17 PM To: Joe Hershberger joe.hershberger@gmail.com Cc: u-boot u-boot@lists.denx.de Subject: Re: [U-Boot] [PATCH v2] driver: net: ldpaa: Update priv->phydev after free()
Hello Joe,
Please see inline.
Regards Ashish
v2: Add signoff
else
#endif
ldpaa_dpbp_free();
-- 1.9.1
_______________________________________________ U-Boot mailing list U-Boot@lists.denx.de http://lists.denx.de/mailman/listinfo/u-boot
On Tue, Feb 21, 2017 at 1:47 AM, Ashish Kumar ashish.kumar@nxp.com wrote:
Hello Joe,
Please see inline.
Regards Ashish
v2: Add signoff
else
It just seems strange to spread the logic out like that. Why not just check for this condition and avoid the initial allocation?
if ((bus == NULL) && (enet_if == PHY_INTERFACE_MODE_XGMII)) { printf("%s %s %d\n",__FILE__, __func__, __LINE__); priv->phydev = (struct phy_device *) malloc(sizeof(struct phy_device)); memset(priv->phydev, 0, sizeof(struct phy_device)); priv->phydev->speed = SPEED_10000; priv->phydev->link = 1; priv->phydev->duplex = DUPLEX_FULL; }
#endif
ldpaa_dpbp_free();
-- 1.9.1
Hello Joe,
Sorry for late response, please see inline.
Regards Ashish
-----Original Message----- From: Joe Hershberger [mailto:joe.hershberger@gmail.com] Sent: Tuesday, March 07, 2017 3:39 AM To: Ashish Kumar ashish.kumar@nxp.com Cc: u-boot u-boot@lists.denx.de; Prabhakar Kushwaha prabhakar.kushwaha@nxp.com Subject: Re: [U-Boot] [PATCH v2] driver: net: ldpaa: Update priv->phydev after free()
Hello Joe,
Please see inline.
Regards Ashish
v2: Add signoff
else
It just seems strange to spread the logic out like that. Why not just check for this condition and avoid the initial allocation? [Ashish Kumar] In that case, I have to add flag all over the code as to first check if it is XFI, then skip the usage of structure (phydev)'s member.
#endif
ldpaa_dpbp_free();
-- 1.9.1
Hi Ashish,
https://patchwork.ozlabs.org/patch/728259/ was applied to http://git.denx.de/?p=u-boot/u-boot-net.git
Thanks! -Joe
participants (5)
Ashish Kumar
Ashish Kumar
Er Krishna
Joe Hershberger
Joe Hershberger
