[PATCH u-boot-mvebu] arm: mvebu: Cleanup get_boot_device() code
Show correct information in debug() output and use correct names for variables.
No functional change.
Signed-off-by: Pali Rohár pali@kernel.org --- arch/arm/mach-mvebu/cpu.c | 13 ++++++++----- 1 file changed, 8 insertions(+), 5 deletions(-)
diff --git a/arch/arm/mach-mvebu/cpu.c b/arch/arm/mach-mvebu/cpu.c index 97154aaa2a7e..018a3614d4dd 100644 --- a/arch/arm/mach-mvebu/cpu.c +++ b/arch/arm/mach-mvebu/cpu.c @@ -67,6 +67,8 @@ u32 get_boot_device(void) { u32 val; u32 boot_device; + u32 boot_err_mode; + u32 boot_err_code;
/* * First check, if UART boot-mode is active. This can only @@ -74,9 +76,9 @@ u32 get_boot_device(void) * MSB marks if the UART mode is active. */ val = readl(BOOTROM_ERR_REG); - boot_device = (val & BOOTROM_ERR_MODE_MASK) >> BOOTROM_ERR_MODE_OFFS; - debug("BOOTROM_REG=0x%08x boot_device=0x%x\n", val, boot_device); - if (boot_device == BOOTROM_ERR_MODE_UART) + boot_err_mode = (val & BOOTROM_ERR_MODE_MASK) >> BOOTROM_ERR_MODE_OFFS; + debug("BOOTROM_ERR_REG=0x%08x boot_err_mode=0x%x\n", val, boot_err_mode); + if (boot_err_mode == BOOTROM_ERR_MODE_UART) return BOOT_DEVICE_UART;
#ifdef CONFIG_ARMADA_38X @@ -84,8 +86,9 @@ u32 get_boot_device(void) * If the bootrom error code contains any other than zeros it's an * error condition and the bootROM has fallen back to UART boot */ - boot_device = (val & BOOTROM_ERR_CODE_MASK) >> BOOTROM_ERR_CODE_OFFS; - if (boot_device) + boot_err_code = (val & BOOTROM_ERR_CODE_MASK) >> BOOTROM_ERR_CODE_OFFS; + debug("boot_err_code=0x%x\n", boot_err_code); + if (boot_err_code) return BOOT_DEVICE_UART; #endif
Hi Pali,
u32 boot_err_mode;
u32 boot_err_code;
- First check, if UART boot-mode is active. This can only
- if (boot_device)
- boot_err_code = (val & BOOTROM_ERR_CODE_MASK) >> BOOTROM_ERR_CODE_OFFS;
- debug("boot_err_code=0x%x\n", boot_err_code);
- if (boot_err_code) return BOOT_DEVICE_UART; #endif
This leads to the following compile warnings, e.g. for maxbcm_defconfig:
[stefan@zen4 u-boot-marvell (next)]$ make -sj arch/arm/mach-mvebu/cpu.c: In function 'get_boot_device': arch/arm/mach-mvebu/cpu.c:71:13: warning: unused variable 'boot_err_code' [-Wunused-variable] 71 | u32 boot_err_code; | ^~~~~~~~~~~~~ arch/arm/mach-mvebu/cpu.c: In function 'get_boot_device': arch/arm/mach-mvebu/cpu.c:71:13: warning: unused variable 'boot_err_code' [-Wunused-variable] 71 | u32 boot_err_code; | ^~~~~~~~~~~~~
Could you please take a look?
Thanks, Stefan
On Friday 24 March 2023 11:24:07 Stefan Roese wrote:
Hi Pali,
- u32 boot_err_mode;
- u32 boot_err_code; /*
- boot_err_mode = (val & BOOTROM_ERR_MODE_MASK) >> BOOTROM_ERR_MODE_OFFS;
- debug("BOOTROM_ERR_REG=0x%08x boot_err_mode=0x%x\n", val, boot_err_mode);
- if (boot_err_mode == BOOTROM_ERR_MODE_UART) return BOOT_DEVICE_UART; #ifdef CONFIG_ARMADA_38X
- if (boot_device)
Thanks, Stefan
It looks like you need to add #ifdef CONFIG_ARMADA_38X guard around declaration of boot_err_code variable (at the beginning the function) because this variable is unused on non-a38x platforms.
Hi Pali,
Hi Pali,
- if (boot_device)
Thanks, Stefan
Yes, I'm sure I could fix this myself. But could you please send a v2 (based on latest next) so that I can apply it easier?
Thanks, Stefan
Signed-off-by: Pali Rohár pali@kernel.org --- arch/arm/mach-mvebu/cpu.c | 15 ++++++++++----- 1 file changed, 10 insertions(+), 5 deletions(-)
diff --git a/arch/arm/mach-mvebu/cpu.c b/arch/arm/mach-mvebu/cpu.c index 56999f608a38..8b91e174c4c1 100644 --- a/arch/arm/mach-mvebu/cpu.c +++ b/arch/arm/mach-mvebu/cpu.c @@ -67,6 +67,10 @@ u32 get_boot_device(void) { u32 val; u32 boot_device; + u32 boot_err_mode; +#ifdef CONFIG_ARMADA_38X + u32 boot_err_code; +#endif
/* * First check, if UART boot-mode is active. This can only @@ -74,9 +78,9 @@ u32 get_boot_device(void) * MSB marks if the UART mode is active. */ val = readl(BOOTROM_ERR_REG); - boot_device = (val & BOOTROM_ERR_MODE_MASK) >> BOOTROM_ERR_MODE_OFFS; - debug("BOOTROM_REG=0x%08x boot_device=0x%x\n", val, boot_device); - if (boot_device == BOOTROM_ERR_MODE_UART) + boot_err_mode = (val & BOOTROM_ERR_MODE_MASK) >> BOOTROM_ERR_MODE_OFFS; + debug("BOOTROM_ERR_REG=0x%08x boot_err_mode=0x%x\n", val, boot_err_mode); + if (boot_err_mode == BOOTROM_ERR_MODE_UART) return BOOT_DEVICE_UART;
#ifdef CONFIG_ARMADA_38X @@ -84,8 +88,9 @@ u32 get_boot_device(void) * If the bootrom error code contains any other than zeros it's an * error condition and the bootROM has fallen back to UART boot */ - boot_device = (val & BOOTROM_ERR_CODE_MASK) >> BOOTROM_ERR_CODE_OFFS; - if (boot_device) + boot_err_code = (val & BOOTROM_ERR_CODE_MASK) >> BOOTROM_ERR_CODE_OFFS; + debug("boot_err_code=0x%x\n", boot_err_code); + if (boot_err_code) return BOOT_DEVICE_UART; #endif
Thanks, Stefan
- if (boot_device)
Viele Grüße, Stefan Roese
Applied to u-boot-marvell/next
Thanks, Stefan
- if (boot_device)
Pali Rohár
Stefan Roese
