[U-Boot] [RFC] bootm: fix passing argc to standalone apps
This bug appears in b6396403 which makes u-boot unable to pass arguments via bootm to a standalone application without this patch.
Steps to reproduce.
Compile a u-boot. Use mkimage to package the standalone hello_world.bin file.
e.g. For the MIPS Boston platform
mkimage -n "hello" -A mips -O u-boot -C none -T standalone \ -a 0xffffffff80200000 -d hello_world.bin \ -ep 0xffffffff80200000 hello_out
Then tftp hello_out and run it using
boston # dhcp 192.168.154.45:hello_out ... boston # bootm $loadaddr 123 321
Without the patch the following output is observed.
Example expects ABI version 8 Actual U-Boot ABI version 8 Hello World argc = 0 argv[0] = "0xffffffff88000000"
With the patch, you see the following.
boston # bootm $loadaddr 123 321 Image Name: hello Image Type: MIPS U-Boot Standalone Program (uncompressed) Data Size: 1240 Bytes = 1.2 KiB Load Address: 80200000 Entry Point: 80200000 Verifying Checksum ... OK Loading Standalone Program ... OK Example expects ABI version 8 Actual U-Boot ABI version 8 Hello World argc = 0 argv[0] = "0xffffffff88000000" Hit any key to exit ...
The go command at the entry point seems to work.
boston # go 0xffffffff80200000 123 321 Example expects ABI version 8 Actual U-Boot ABI version 8 Hello World argc = 3 argv[0] = "0xffffffff80200000" argv[1] = "123" argv[2] = "321" argv[3] = "<NULL>" Hit any key to exit ...
Signed-off-by: Zubair Lutfullah Kakakhel Zubair.Kakakhel@imgtec.com
Tested on the MIPS Boston platform. --- common/bootm.c | 4 +--- 1 file changed, 1 insertion(+), 3 deletions(-)
diff --git a/common/bootm.c b/common/bootm.c index a4d22a6..b2c0912 100644 --- a/common/bootm.c +++ b/common/bootm.c @@ -619,10 +619,8 @@ int do_bootm_states(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[], if (!ret && (states & BOOTM_STATE_FINDOS)) ret = bootm_find_os(cmdtp, flag, argc, argv);
- if (!ret && (states & BOOTM_STATE_FINDOTHER)) { + if (!ret && (states & BOOTM_STATE_FINDOTHER)) ret = bootm_find_other(cmdtp, flag, argc, argv); - argc = 0; /* consume the args */ - }
/* Load the OS */ if (!ret && (states & BOOTM_STATE_LOADOS)) {
Steps to reproduce.
argc = 3
argv[1] = 123 argv[2] = 321
Copy paste fluke in the git log. Sorry. The above appears in reality
Regards, ZubairLK
- if (!ret && (states & BOOTM_STATE_FINDOTHER)) ret = bootm_find_other(cmdtp, flag, argc, argv);
Steps to reproduce.
argc = 3
Regards, ZubairLK
Can you re-send with a corrected commit log? Thanks.
