[U-Boot-Users] [PATCH 01/15 v2] rtc: Add M41T62 support
This patch add support for the STM M41T62 RTC. It is used and tested on the AMCC Canyonlands 406EX platform.
Signed-off-by: Stefan Roese sr@denx.de --- drivers/rtc/Makefile | 1 + drivers/rtc/m41t62.c | 135 ++++++++++++++++++++++++++++++++++++++++++++++++++ 2 files changed, 136 insertions(+), 0 deletions(-) create mode 100644 drivers/rtc/m41t62.c
diff --git a/drivers/rtc/Makefile b/drivers/rtc/Makefile index 2af2bf4..17c0f86 100644 --- a/drivers/rtc/Makefile +++ b/drivers/rtc/Makefile @@ -41,6 +41,7 @@ COBJS-y += ds174x.o COBJS-y += ds3231.o COBJS-y += m41t11.o COBJS-y += m41t60.o +COBJS-$(CONFIG_RTC_M41T62) += m41t62.o COBJS-y += max6900.o COBJS-y += m48t35ax.o COBJS-y += mc146818.o diff --git a/drivers/rtc/m41t62.c b/drivers/rtc/m41t62.c new file mode 100644 index 0000000..002ebba --- /dev/null +++ b/drivers/rtc/m41t62.c @@ -0,0 +1,135 @@ +/* + * (C) Copyright 2008 + * Stefan Roese, DENX Software Engineering, sr@denx.de. + * + * based on a the Linux rtc-m41t80.c driver which is: + * Alexander Bigga ab@mycable.de, 2006 (c) mycable GmbH + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +/* + * Date & Time support for STMicroelectronics M41T62 + */ + +/* #define DEBUG */ + +#include <common.h> +#include <command.h> +#include <rtc.h> +#include <i2c.h> +#include <bcd.h> + +#if defined(CONFIG_CMD_DATE) + +#define M41T62_REG_SSEC 0 +#define M41T62_REG_SEC 1 +#define M41T62_REG_MIN 2 +#define M41T62_REG_HOUR 3 +#define M41T62_REG_WDAY 4 +#define M41T62_REG_DAY 5 +#define M41T62_REG_MON 6 +#define M41T62_REG_YEAR 7 +#define M41T62_REG_ALARM_MON 0xa +#define M41T62_REG_ALARM_DAY 0xb +#define M41T62_REG_ALARM_HOUR 0xc +#define M41T62_REG_ALARM_MIN 0xd +#define M41T62_REG_ALARM_SEC 0xe +#define M41T62_REG_FLAGS 0xf + +#define M41T62_DATETIME_REG_SIZE (M41T62_REG_YEAR + 1) +#define M41T62_ALARM_REG_SIZE \ + (M41T62_REG_ALARM_SEC + 1 - M41T62_REG_ALARM_MON) + +#define M41T62_SEC_ST (1 << 7) /* ST: Stop Bit */ +#define M41T62_ALMON_AFE (1 << 7) /* AFE: AF Enable Bit */ +#define M41T62_ALMON_SQWE (1 << 6) /* SQWE: SQW Enable Bit */ +#define M41T62_ALHOUR_HT (1 << 6) /* HT: Halt Update Bit */ +#define M41T62_FLAGS_AF (1 << 6) /* AF: Alarm Flag Bit */ +#define M41T62_FLAGS_BATT_LOW (1 << 4) /* BL: Battery Low Bit */ + +#define M41T62_FEATURE_HT (1 << 0) +#define M41T62_FEATURE_BL (1 << 1) + +void rtc_get(struct rtc_time *tm) +{ + u8 buf[M41T62_DATETIME_REG_SIZE]; + + i2c_read(CFG_I2C_RTC_ADDR, 0, 1, buf, M41T62_DATETIME_REG_SIZE); + + debug("%s: raw read data - sec=%02x, min=%02x, hr=%02x, " + "mday=%02x, mon=%02x, year=%02x, wday=%02x, y2k=%02x\n", + __FUNCTION__, + buf[0], buf[1], buf[2], buf[3], + buf[4], buf[5], buf[6], buf[7]); + + tm->tm_sec = BCD2BIN(buf[M41T62_REG_SEC] & 0x7f); + tm->tm_min = BCD2BIN(buf[M41T62_REG_MIN] & 0x7f); + tm->tm_hour = BCD2BIN(buf[M41T62_REG_HOUR] & 0x3f); + tm->tm_mday = BCD2BIN(buf[M41T62_REG_DAY] & 0x3f); + tm->tm_wday = buf[M41T62_REG_WDAY] & 0x07; + tm->tm_mon = BCD2BIN(buf[M41T62_REG_MON] & 0x1f) - 1; + + /* assume 20YY not 19YY, and ignore the Century Bit */ + /* U-Boot needs to add 1900 here */ + tm->tm_year = BCD2BIN(buf[M41T62_REG_YEAR]) + 100 + 1900; + + debug("%s: tm is secs=%d, mins=%d, hours=%d, " + "mday=%d, mon=%d, year=%d, wday=%d\n", + __FUNCTION__, + tm->tm_sec, tm->tm_min, tm->tm_hour, + tm->tm_mday, tm->tm_mon, tm->tm_year, tm->tm_wday); +} + +void rtc_set(struct rtc_time *tm) +{ + u8 buf[M41T62_DATETIME_REG_SIZE]; + + debug("Set DATE: %4d-%02d-%02d (wday=%d) TIME: %2d:%02d:%02d\n", + tm->tm_year, tm->tm_mon, tm->tm_mday, tm->tm_wday, + tm->tm_hour, tm->tm_min, tm->tm_sec); + + i2c_read(CFG_I2C_RTC_ADDR, 0, 1, buf, M41T62_DATETIME_REG_SIZE); + + /* Merge time-data and register flags into buf[0..7] */ + buf[M41T62_REG_SSEC] = 0; + buf[M41T62_REG_SEC] = + BIN2BCD(tm->tm_sec) | (buf[M41T62_REG_SEC] & ~0x7f); + buf[M41T62_REG_MIN] = + BIN2BCD(tm->tm_min) | (buf[M41T62_REG_MIN] & ~0x7f); + buf[M41T62_REG_HOUR] = + BIN2BCD(tm->tm_hour) | (buf[M41T62_REG_HOUR] & ~0x3f) ; + buf[M41T62_REG_WDAY] = + (tm->tm_wday & 0x07) | (buf[M41T62_REG_WDAY] & ~0x07); + buf[M41T62_REG_DAY] = + BIN2BCD(tm->tm_mday) | (buf[M41T62_REG_DAY] & ~0x3f); + buf[M41T62_REG_MON] = + BIN2BCD(tm->tm_mon + 1) | (buf[M41T62_REG_MON] & ~0x1f); + /* assume 20YY not 19YY */ + buf[M41T62_REG_YEAR] = BIN2BCD(tm->tm_year % 100); + + if (i2c_write(CFG_I2C_RTC_ADDR, 0, 1, buf, M41T62_DATETIME_REG_SIZE)) + printf("I2C write failed in %s()\n", __func__); +} + +void rtc_reset(void) +{ + /* + * Nothing to do + */ +} + +#endif
While adding the 460EX/GT support I reworked the 4xx miiphy code. It badly neede some cleanup.
Signed-off-by: Stefan Roese sr@denx.de --- cpu/ppc4xx/miiphy.c | 196 +++++++++++++++++++++------------------------------ 1 files changed, 80 insertions(+), 116 deletions(-)
diff --git a/cpu/ppc4xx/miiphy.c b/cpu/ppc4xx/miiphy.c index 3978773..c882720 100644 --- a/cpu/ppc4xx/miiphy.c +++ b/cpu/ppc4xx/miiphy.c @@ -29,6 +29,11 @@ | +-----------------------------------------------------------------------------*/
+/* define DEBUG for debugging output (obviously ;-)) */ +#if 0 +#define DEBUG +#endif + #include <common.h> #include <asm/processor.h> #include <asm/io.h> @@ -38,7 +43,10 @@ #include <405_mal.h> #include <miiphy.h>
-#undef ET_DEBUG +#if !defined(CONFIG_PHY_CLK_FREQ) +#define CONFIG_PHY_CLK_FREQ 0 +#endif + /***********************************************************/ /* Dump out to the screen PHY regs */ /***********************************************************/ @@ -164,9 +172,21 @@ int phy_setup_aneg (char *devname, unsigned char addr) /***********************************************************/ /* read a phy reg and return the value with a rc */ /***********************************************************/ +/* AMCC_TODO: + * Find out of the choice for the emac for MDIO is from the bridges, + * i.e. ZMII or RGMII as approporiate. If the bridges are not used + * to determine the emac for MDIO, then is the SDR0_ETH_CFG[MDIO_SEL] + * used? If so, then this routine below does not apply to the 460EX/GT. + * + * sr: Currently on 460EX only EMAC0 works with MDIO, so we always + * return EMAC0 offset here + */ unsigned int miiphy_getemac_offset (void) { -#if (defined(CONFIG_440) && !defined(CONFIG_440SP) && !defined(CONFIG_440SPE)) && defined(CONFIG_NET_MULTI) +#if (defined(CONFIG_440) && \ + !defined(CONFIG_440SP) && !defined(CONFIG_440SPE) && \ + !defined(CONFIG_460EX) && !defined(CONFIG_460GT)) && \ + defined(CONFIG_NET_MULTI) unsigned long zmii; unsigned long eoffset;
@@ -217,153 +237,97 @@ unsigned int miiphy_getemac_offset (void) #endif }
-int emac4xx_miiphy_read (char *devname, unsigned char addr, unsigned char reg, - unsigned short *value) +static int emac_miiphy_wait(u32 emac_reg) { - unsigned long sta_reg; /* STA scratch area */ - unsigned long i; - unsigned long emac_reg; + u32 sta_reg; + int i;
- emac_reg = miiphy_getemac_offset (); - /* see if it is ready for 1000 nsec */ + /* wait for completion */ i = 0; - - /* see if it is ready for sec */ - while ((in_be32((void *)EMAC_STACR + emac_reg) & EMAC_STACR_OC) == - EMAC_STACR_OC_MASK) { - udelay (7); - if (i > 5) { -#ifdef ET_DEBUG - sta_reg = in_be32((void *)EMAC_STACR + emac_reg); - printf ("read : EMAC_STACR=0x%0x\n", sta_reg); /* test-only */ - printf ("read err 1\n"); -#endif + do { + sta_reg = in_be32((void *)EMAC_STACR + emac_reg); + if (i++ > 5) { + debug("%s [%d]: Timeout! EMAC_STACR=0x%0x\n", __func__, + __LINE__, sta_reg); return -1; } - i++; - } + udelay(10); + } while ((sta_reg & EMAC_STACR_OC) == EMAC_STACR_OC_MASK); + + return 0; +} + +static int emac_miiphy_command(u8 addr, u8 reg, int cmd, u16 value) +{ + u32 emac_reg; + u32 sta_reg; + + emac_reg = miiphy_getemac_offset(); + + /* wait for completion */ + if (emac_miiphy_wait(emac_reg) != 0) + return -1; + sta_reg = reg; /* reg address */ + /* set clock (50Mhz) and read flags */ #if defined(CONFIG_440GX) || defined(CONFIG_440SPE) || \ defined(CONFIG_440EPX) || defined(CONFIG_440GRX) || \ + defined(CONFIG_460EX) || defined(CONFIG_460GT) || \ defined(CONFIG_405EX) #if defined(CONFIG_IBM_EMAC4_V4) /* EMAC4 V4 changed bit setting */ - sta_reg = (sta_reg & ~EMAC_STACR_OP_MASK) | EMAC_STACR_READ; + sta_reg = (sta_reg & ~EMAC_STACR_OP_MASK) | cmd; #else - sta_reg |= EMAC_STACR_READ; + sta_reg |= cmd; #endif #else - sta_reg = (sta_reg | EMAC_STACR_READ) & ~EMAC_STACR_CLK_100MHZ; + sta_reg = (sta_reg | cmd) & ~EMAC_STACR_CLK_100MHZ; #endif
-#if defined(CONFIG_PHY_CLK_FREQ) && !defined(CONFIG_440GX) && \ - !defined(CONFIG_440SP) && !defined(CONFIG_440SPE) && \ - !defined(CONFIG_440EPX) && !defined(CONFIG_440GRX) && \ - !defined(CONFIG_405EX) + /* Some boards (mainly 405EP based) define the PHY clock freqency fixed */ sta_reg = sta_reg | CONFIG_PHY_CLK_FREQ; -#endif - sta_reg = sta_reg | (addr << 5); /* Phy address */ + sta_reg = sta_reg | ((u32)addr << 5); /* Phy address */ sta_reg = sta_reg | EMAC_STACR_OC_MASK; /* new IBM emac v4 */ + if (cmd == EMAC_STACR_WRITE) + memcpy(&sta_reg, &value, 2); /* put in data */ + out_be32((void *)EMAC_STACR + emac_reg, sta_reg); -#ifdef ET_DEBUG - printf ("a2: write: EMAC_STACR=0x%0x\n", sta_reg); /* test-only */ -#endif + debug("%s [%d]: sta_reg=%08x\n", __func__, __LINE__, sta_reg);
- sta_reg = in_be32((void *)EMAC_STACR + emac_reg); -#ifdef ET_DEBUG - printf ("a21: read : EMAC_STACR=0x%0x\n", sta_reg); /* test-only */ -#endif - i = 0; - while ((sta_reg & EMAC_STACR_OC) == EMAC_STACR_OC_MASK) { - udelay (7); - if (i > 5) - return -1; + /* wait for completion */ + if (emac_miiphy_wait(emac_reg) != 0) + return -1;
- i++; - sta_reg = in_be32((void *)EMAC_STACR + emac_reg); -#ifdef ET_DEBUG - printf ("a22: read : EMAC_STACR=0x%0x\n", sta_reg); /* test-only */ -#endif - } + debug("%s [%d]: sta_reg=%08x\n", __func__, __LINE__, sta_reg); if ((sta_reg & EMAC_STACR_PHYE) != 0) return -1;
- *value = *(short *)(&sta_reg); return 0; +}
-} /* phy_read */ - -/***********************************************************/ -/* write a phy reg and return the value with a rc */ -/***********************************************************/ - -int emac4xx_miiphy_write (char *devname, unsigned char addr, unsigned char reg, - unsigned short value) +int emac4xx_miiphy_read (char *devname, unsigned char addr, unsigned char reg, + unsigned short *value) { - unsigned long sta_reg; /* STA scratch area */ - unsigned long i; + unsigned long sta_reg; unsigned long emac_reg;
emac_reg = miiphy_getemac_offset (); - /* see if it is ready for 1000 nsec */ - i = 0; - - while ((in_be32((void *)EMAC_STACR + emac_reg) & EMAC_STACR_OC) == - EMAC_STACR_OC_MASK) { - if (i > 5) - return -1; - - udelay (7); - i++; - } - sta_reg = 0; - sta_reg = reg; /* reg address */ - /* set clock (50Mhz) and read flags */ -#if defined(CONFIG_440GX) || defined(CONFIG_440SPE) || \ - defined(CONFIG_440EPX) || defined(CONFIG_440GRX) || \ - defined(CONFIG_405EX) -#if defined(CONFIG_IBM_EMAC4_V4) /* EMAC4 V4 changed bit setting */ - sta_reg = (sta_reg & ~EMAC_STACR_OP_MASK) | EMAC_STACR_WRITE; -#else - sta_reg |= EMAC_STACR_WRITE; -#endif -#else - sta_reg = (sta_reg | EMAC_STACR_WRITE) & ~EMAC_STACR_CLK_100MHZ; -#endif - -#if defined(CONFIG_PHY_CLK_FREQ) && !defined(CONFIG_440GX) && \ - !defined(CONFIG_440SP) && !defined(CONFIG_440SPE) && \ - !defined(CONFIG_440EPX) && !defined(CONFIG_440GRX) && \ - !defined(CONFIG_405EX) - sta_reg = sta_reg | CONFIG_PHY_CLK_FREQ; /* Set clock frequency (PLB freq. dependend) */ -#endif - sta_reg = sta_reg | ((unsigned long)addr << 5); /* Phy address */ - sta_reg = sta_reg | EMAC_STACR_OC_MASK; /* new IBM emac v4 */ - memcpy (&sta_reg, &value, 2); /* put in data */
- out_be32((void *)EMAC_STACR + emac_reg, sta_reg); + if (emac_miiphy_command(addr, reg, EMAC_STACR_READ, 0) != 0) + return -1;
- /* wait for completion */ - i = 0; sta_reg = in_be32((void *)EMAC_STACR + emac_reg); -#ifdef ET_DEBUG - printf ("a31: read : EMAC_STACR=0x%0x\n", sta_reg); /* test-only */ -#endif - while ((sta_reg & EMAC_STACR_OC) == EMAC_STACR_OC_MASK) { - udelay (7); - if (i > 5) - return -1; - - i++; - sta_reg = in_be32((void *)EMAC_STACR + emac_reg); -#ifdef ET_DEBUG - printf ("a32: read : EMAC_STACR=0x%0x\n", sta_reg); /* test-only */ -#endif - } - - if ((sta_reg & EMAC_STACR_PHYE) != 0) - return -1; + *value = *(u16 *)(&sta_reg);
return 0; +}
-} /* phy_write */ +/***********************************************************/ +/* write a phy reg and return the value with a rc */ +/***********************************************************/ + +int emac4xx_miiphy_write (char *devname, unsigned char addr, unsigned char reg, + unsigned short value) +{ + return emac_miiphy_command(addr, reg, EMAC_STACR_WRITE, value); +}
This patch changes the physical addess parameter from 32bit to 64bit. This is needed for 36bit 4xx platforms to access areas located beyond the 4GB border, like SoC peripherals (EBC etc.).
Signed-off-by: Stefan Roese sr@denx.de --- board/netstal/hcu5/sdram.c | 2 -- cpu/ppc4xx/tlb.c | 27 ++++++++++++++------------- include/asm-ppc/mmu.h | 18 +++++++++--------- post/cpu/ppc4xx/cache.c | 2 -- 4 files changed, 23 insertions(+), 26 deletions(-)
diff --git a/board/netstal/hcu5/sdram.c b/board/netstal/hcu5/sdram.c index d3c2233..0b16b50 100644 --- a/board/netstal/hcu5/sdram.c +++ b/board/netstal/hcu5/sdram.c @@ -70,8 +70,6 @@ void dflush(void); #define MY_TLB_WORD2_I_ENABLE TLB_WORD2_I_ENABLE /* disable caching on DDR2 */
-void program_tlb(u32 phys_addr, u32 virt_addr, u32 size, u32 tlb_word2_i_value); - void board_add_ram_info(int use_default) { PPC4xx_SYS_INFO board_cfg; diff --git a/cpu/ppc4xx/tlb.c b/cpu/ppc4xx/tlb.c index ed493f1..2bfcba1 100644 --- a/cpu/ppc4xx/tlb.c +++ b/cpu/ppc4xx/tlb.c @@ -31,9 +31,9 @@ #include <asm/mmu.h>
typedef struct region { - unsigned long base; - unsigned long size; - unsigned long tlb_word2_i_value; + u64 base; + u32 size; + u32 tlb_word2_i_value; } region_t;
void remove_tlb(u32 vaddr, u32 size) @@ -182,10 +182,10 @@ void change_tlb(u32 vaddr, u32 size, u32 tlb_word2_i_value) asm("isync"); }
-static int add_tlb_entry(unsigned long phys_addr, - unsigned long virt_addr, - unsigned long tlb_word0_size_value, - unsigned long tlb_word2_i_value) +static int add_tlb_entry(u64 phys_addr, + u32 virt_addr, + u32 tlb_word0_size_value, + u32 tlb_word2_i_value) { int i; unsigned long tlb_word0_value; @@ -204,7 +204,8 @@ static int add_tlb_entry(unsigned long phys_addr, /* Second, create the TLB entry */ tlb_word0_value = TLB_WORD0_EPN_ENCODE(virt_addr) | TLB_WORD0_V_ENABLE | TLB_WORD0_TS_0 | tlb_word0_size_value; - tlb_word1_value = TLB_WORD1_RPN_ENCODE(phys_addr) | TLB_WORD1_ERPN_ENCODE(0); + tlb_word1_value = TLB_WORD1_RPN_ENCODE((u32)phys_addr) | + TLB_WORD1_ERPN_ENCODE(phys_addr >> 32); tlb_word2_value = TLB_WORD2_U0_DISABLE | TLB_WORD2_U1_DISABLE | TLB_WORD2_U2_DISABLE | TLB_WORD2_U3_DISABLE | TLB_WORD2_W_DISABLE | tlb_word2_i_value | @@ -228,10 +229,10 @@ static int add_tlb_entry(unsigned long phys_addr, return 0; }
-static void program_tlb_addr(unsigned long phys_addr, - unsigned long virt_addr, - unsigned long mem_size, - unsigned long tlb_word2_i_value) +static void program_tlb_addr(u64 phys_addr, + u32 virt_addr, + u32 mem_size, + u32 tlb_word2_i_value) { int rc; int tlb_i; @@ -331,7 +332,7 @@ static void program_tlb_addr(unsigned long phys_addr, * Common usage for boards with SDRAM DIMM modules to dynamically * configure the TLB's for the SDRAM */ -void program_tlb(u32 phys_addr, u32 virt_addr, u32 size, u32 tlb_word2_i_value) +void program_tlb(u64 phys_addr, u32 virt_addr, u32 size, u32 tlb_word2_i_value) { region_t region_array;
diff --git a/include/asm-ppc/mmu.h b/include/asm-ppc/mmu.h index 5af22af..49d6860 100644 --- a/include/asm-ppc/mmu.h +++ b/include/asm-ppc/mmu.h @@ -549,14 +549,14 @@ extern int num_tlb_entries; /*----------------------------------------------------------------------------+ | TLB specific defines. +----------------------------------------------------------------------------*/ -#define TLB_256MB_ALIGN_MASK 0xF0000000 -#define TLB_16MB_ALIGN_MASK 0xFF000000 -#define TLB_1MB_ALIGN_MASK 0xFFF00000 -#define TLB_256KB_ALIGN_MASK 0xFFFC0000 -#define TLB_64KB_ALIGN_MASK 0xFFFF0000 -#define TLB_16KB_ALIGN_MASK 0xFFFFC000 -#define TLB_4KB_ALIGN_MASK 0xFFFFF000 -#define TLB_1KB_ALIGN_MASK 0xFFFFFC00 +#define TLB_256MB_ALIGN_MASK 0xFF0000000ULL +#define TLB_16MB_ALIGN_MASK 0xFFF000000ULL +#define TLB_1MB_ALIGN_MASK 0xFFFF00000ULL +#define TLB_256KB_ALIGN_MASK 0xFFFFC0000ULL +#define TLB_64KB_ALIGN_MASK 0xFFFFF0000ULL +#define TLB_16KB_ALIGN_MASK 0xFFFFFC000ULL +#define TLB_4KB_ALIGN_MASK 0xFFFFFF000ULL +#define TLB_1KB_ALIGN_MASK 0xFFFFFFC00ULL #define TLB_256MB_SIZE 0x10000000 #define TLB_16MB_SIZE 0x01000000 #define TLB_1MB_SIZE 0x00100000 @@ -697,7 +697,7 @@ unsigned long mftlb1(unsigned long index); unsigned long mftlb2(unsigned long index); unsigned long mftlb3(unsigned long index);
-void program_tlb(u32 phys_addr, u32 virt_addr, u32 size, u32 tlb_word2_i_value); +void program_tlb(u64 phys_addr, u32 virt_addr, u32 size, u32 tlb_word2_i_value); void remove_tlb(u32 vaddr, u32 size); void change_tlb(u32 vaddr, u32 size, u32 tlb_word2_i_value); #endif /* __ASSEMBLY__ */ diff --git a/post/cpu/ppc4xx/cache.c b/post/cpu/ppc4xx/cache.c index c86a150..466ca92 100644 --- a/post/cpu/ppc4xx/cache.c +++ b/post/cpu/ppc4xx/cache.c @@ -42,8 +42,6 @@
#define CACHE_POST_SIZE 1024
-void program_tlb(u32 phys_addr, u32 virt_addr, u32 size, u32 tlb_word2_i_value); - int cache_post_test1 (int tlb, void *p, int size); int cache_post_test2 (int tlb, void *p, int size); int cache_post_test3 (int tlb, void *p, int size);
This patch is a rework of the 4xx interrupt handling done while adding the 460EX/GT support. Interrupts are needed on 4xx for the EMAC driver.
Signed-off-by: Stefan Roese sr@denx.de --- cpu/ppc4xx/interrupts.c | 589 +++++++++++----------------------------------- 1 files changed, 141 insertions(+), 448 deletions(-)
diff --git a/cpu/ppc4xx/interrupts.c b/cpu/ppc4xx/interrupts.c index 2f3dc32..698bcb5 100644 --- a/cpu/ppc4xx/interrupts.c +++ b/cpu/ppc4xx/interrupts.c @@ -38,7 +38,22 @@
DECLARE_GLOBAL_DATA_PTR;
-/****************************************************************************/ +/* + * Define the number of UIC's + */ +#if defined(CONFIG_440SPE) || \ + defined(CONFIG_460EX) || defined(CONFIG_460GT) +#define UIC_MAX 4 +#elif defined(CONFIG_440GX) || \ + defined(CONFIG_440EPX) || defined(CONFIG_440GRX) || \ + defined(CONFIG_405EX) +#define UIC_MAX 3 +#elif defined(CONFIG_440GP) || defined(CONFIG_440SP) || \ + defined(CONFIG_440EP) || defined(CONFIG_440GR) +#define UIC_MAX 2 +#else +#define UIC_MAX 1 +#endif
/* * CPM interrupt vector functions. @@ -49,28 +64,15 @@ struct irq_action { int count; };
-static struct irq_action irq_vecs[32]; -void uic0_interrupt( void * parms); /* UIC0 handler */ +static struct irq_action irq_vecs[UIC_MAX * 32];
-#if defined(CONFIG_440) || defined(CONFIG_405EX) -static struct irq_action irq_vecs1[32]; /* For UIC1 */ +u32 get_dcr(u16); +void set_dcr(u16, u32);
-void uic1_interrupt( void * parms); /* UIC1 handler */ - -#if defined(CONFIG_440GX) || defined(CONFIG_440SPE) || \ - defined(CONFIG_440EPX) || defined(CONFIG_440GRX) -static struct irq_action irq_vecs2[32]; /* For UIC2 */ -void uic2_interrupt( void * parms); /* UIC2 handler */ -#endif /* CONFIG_440GX CONFIG_440SPE */ - -#if defined(CONFIG_440SPE) || defined(CONFIG_440EPX) || defined(CONFIG_440GRX) -static struct irq_action irq_vecs3[32]; /* For UIC3 */ -void uic3_interrupt( void * parms); /* UIC3 handler */ -#endif /* CONFIG_440SPE */ - -#endif /* CONFIG_440 */ +#if (UIC_MAX > 1) && !defined(CONFIG_440GX) +static void uic_cascade_interrupt(void *para); +#endif
-/****************************************************************************/ #if defined(CONFIG_440)
/* SPRN changed in 440 */ @@ -99,8 +101,6 @@ static __inline__ void set_evpr(unsigned long val) } #endif /* defined(CONFIG_440 */
-/****************************************************************************/ - int interrupt_init_cpu (unsigned *decrementer_count) { int vec; @@ -112,26 +112,10 @@ int interrupt_init_cpu (unsigned *decrementer_count) /* * Mark all irqs as free */ - for (vec=0; vec<32; vec++) { + for (vec = 0; vec < (UIC_MAX * 32); vec++) { irq_vecs[vec].handler = NULL; irq_vecs[vec].arg = NULL; irq_vecs[vec].count = 0; -#if defined(CONFIG_440) || defined(CONFIG_405EX) - irq_vecs1[vec].handler = NULL; - irq_vecs1[vec].arg = NULL; - irq_vecs1[vec].count = 0; -#if defined(CONFIG_440GX) || defined(CONFIG_440SPE) || \ - defined(CONFIG_440EPX) || defined(CONFIG_440GRX) - irq_vecs2[vec].handler = NULL; - irq_vecs2[vec].arg = NULL; - irq_vecs2[vec].count = 0; -#endif /* CONFIG_440GX */ -#if defined(CONFIG_440SPE) || defined(CONFIG_440EPX) || defined(CONFIG_440GRX) - irq_vecs3[vec].handler = NULL; - irq_vecs3[vec].arg = NULL; - irq_vecs3[vec].count = 0; -#endif /* CONFIG_440SPE */ -#endif }
#ifdef CONFIG_4xx @@ -172,15 +156,21 @@ int interrupt_init_cpu (unsigned *decrementer_count) */ set_evpr(0x00000000);
-#if defined(CONFIG_440) || defined(CONFIG_405EX) #if !defined(CONFIG_440GX) +#if (UIC_MAX > 1) /* Install the UIC1 handlers */ - irq_install_handler(VECNUM_UIC1NC, uic1_interrupt, 0); - irq_install_handler(VECNUM_UIC1C, uic1_interrupt, 0); + irq_install_handler(VECNUM_UIC1NC, uic_cascade_interrupt, 0); + irq_install_handler(VECNUM_UIC1C, uic_cascade_interrupt, 0); #endif +#if (UIC_MAX > 2) + irq_install_handler(VECNUM_UIC2NC, uic_cascade_interrupt, 0); + irq_install_handler(VECNUM_UIC2C, uic_cascade_interrupt, 0); #endif - -#if defined(CONFIG_440GX) +#if (UIC_MAX > 3) + irq_install_handler(VECNUM_UIC3NC, uic_cascade_interrupt, 0); + irq_install_handler(VECNUM_UIC3C, uic_cascade_interrupt, 0); +#endif +#else /* !defined(CONFIG_440GX) */ /* Take the GX out of compatibility mode * Travis Sawyer, 9 Mar 2004 * NOTE: 440gx user manual inconsistency here @@ -196,110 +186,24 @@ int interrupt_init_cpu (unsigned *decrementer_count) mtdcr(uicb0er, 0x54000000); /* None are critical */ mtdcr(uicb0cr, 0); -#endif +#endif /* !defined(CONFIG_440GX) */
return (0); }
-/****************************************************************************/ - -/* - * Handle external interrupts - */ -#if defined(CONFIG_440GX) -void external_interrupt(struct pt_regs *regs) +/* Handler for UIC interrupt */ +static void uic_interrupt(u32 uic_base, int vec_base) { - ulong uic_msr; - - /* - * Read masked interrupt status register to determine interrupt source - */ - /* 440 GX uses base uic register */ - uic_msr = mfdcr(uicb0msr); - - if ( (UICB0_UIC0CI & uic_msr) || (UICB0_UIC0NCI & uic_msr) ) - uic0_interrupt(0); - - if ( (UICB0_UIC1CI & uic_msr) || (UICB0_UIC1NCI & uic_msr) ) - uic1_interrupt(0); - - if ( (UICB0_UIC2CI & uic_msr) || (UICB0_UIC2NCI & uic_msr) ) - uic2_interrupt(0); - - mtdcr(uicb0sr, uic_msr); - - return; - -} /* external_interrupt CONFIG_440GX */ - -#elif defined(CONFIG_440EPX) || defined(CONFIG_440GRX) -void external_interrupt(struct pt_regs *regs) -{ - ulong uic_msr; - - /* - * Read masked interrupt status register to determine interrupt source - */ - /* 440 SPe uses base uic register */ - uic_msr = mfdcr(uic0msr); - - if ( (UICB0_UIC1CI & uic_msr) || (UICB0_UIC1NCI & uic_msr) ) - uic1_interrupt(0); - - if ( (UICB0_UIC2CI & uic_msr) || (UICB0_UIC2NCI & uic_msr) ) - uic2_interrupt(0); - - if (uic_msr & ~(UICB0_ALL)) - uic0_interrupt(0); - - mtdcr(uic0sr, uic_msr); - - return; - -} /* external_interrupt CONFIG_440EPX & CONFIG_440GRX */ - -#elif defined(CONFIG_440SPE) -void external_interrupt(struct pt_regs *regs) -{ - ulong uic_msr; - - /* - * Read masked interrupt status register to determine interrupt source - */ - /* 440 SPe uses base uic register */ - uic_msr = mfdcr(uic0msr); - - if ( (UICB0_UIC1CI & uic_msr) || (UICB0_UIC1NCI & uic_msr) ) - uic1_interrupt(0); - - if ( (UICB0_UIC2CI & uic_msr) || (UICB0_UIC2NCI & uic_msr) ) - uic2_interrupt(0); - - if ( (UICB0_UIC3CI & uic_msr) || (UICB0_UIC3NCI & uic_msr) ) - uic3_interrupt(0); - - if (uic_msr & ~(UICB0_ALL)) - uic0_interrupt(0); - - mtdcr(uic0sr, uic_msr); - - return; -} /* external_interrupt CONFIG_440SPE */ - -#else - -void external_interrupt(struct pt_regs *regs) -{ - ulong uic_msr; - ulong msr_shift; + u32 uic_msr; + u32 msr_shift; int vec;
/* * Read masked interrupt status register to determine interrupt source */ - uic_msr = mfdcr(uicmsr); + uic_msr = get_dcr(uic_base + UIC_MSR); msr_shift = uic_msr; - vec = 0; + vec = vec_base;
while (msr_shift != 0) { if (msr_shift & 0x80000000) { @@ -312,14 +216,17 @@ void external_interrupt(struct pt_regs *regs) /* call isr */ (*irq_vecs[vec].handler)(irq_vecs[vec].arg); } else { - mtdcr(uicer, mfdcr(uicer) & ~(0x80000000 >> vec)); - printf ("Masking bogus interrupt vector 0x%x\n", vec); + set_dcr(uic_base + UIC_ER, + get_dcr(uic_base + UIC_ER) & + ~(0x80000000 >> vec)); + printf("Masking bogus interrupt vector %d" + " (UIC_BASE=0x%x)\n", vec, uic_base); }
/* * After servicing the interrupt, we have to remove the status indicator. */ - mtdcr(uicsr, (0x80000000 >> vec)); + set_dcr(uic_base + UIC_SR, (0x80000000 >> vec)); }
/* @@ -329,324 +236,150 @@ void external_interrupt(struct pt_regs *regs) vec++; } } -#endif
-#if defined(CONFIG_440GX) || defined(CONFIG_440SPE) || \ - defined(CONFIG_440EPX) || defined(CONFIG_440GRX) -/* Handler for UIC0 interrupt */ -void uic0_interrupt( void * parms) +#if (UIC_MAX > 1) && !defined(CONFIG_440GX) +static void uic_cascade_interrupt(void *para) { - ulong uic_msr; - ulong msr_shift; - int vec; - - /* - * Read masked interrupt status register to determine interrupt source - */ - uic_msr = mfdcr(uicmsr); - msr_shift = uic_msr; - vec = 0; - - while (msr_shift != 0) { - if (msr_shift & 0x80000000) { - /* - * Increment irq counter (for debug purpose only) - */ - irq_vecs[vec].count++; - - if (irq_vecs[vec].handler != NULL) { - /* call isr */ - (*irq_vecs[vec].handler)(irq_vecs[vec].arg); - } else { - mtdcr(uicer, mfdcr(uicer) & ~(0x80000000 >> vec)); - printf ("Masking bogus interrupt vector (uic0) 0x%x\n", vec); - } - - /* - * After servicing the interrupt, we have to remove the status indicator. - */ - mtdcr(uicsr, (0x80000000 >> vec)); - } - - /* - * Shift msr to next position and increment vector - */ - msr_shift <<= 1; - vec++; - } + external_interrupt(para); } +#endif
-#endif /* CONFIG_440GX */ - -#if defined(CONFIG_440) || defined(CONFIG_405EX) -/* Handler for UIC1 interrupt */ -void uic1_interrupt( void * parms) -{ - ulong uic1_msr; - ulong msr_shift; - int vec; - - /* - * Read masked interrupt status register to determine interrupt source - */ - uic1_msr = mfdcr(uic1msr); - msr_shift = uic1_msr; - vec = 0; - - while (msr_shift != 0) { - if (msr_shift & 0x80000000) { - /* - * Increment irq counter (for debug purpose only) - */ - irq_vecs1[vec].count++; - - if (irq_vecs1[vec].handler != NULL) { - /* call isr */ - (*irq_vecs1[vec].handler)(irq_vecs1[vec].arg); - } else { - mtdcr(uic1er, mfdcr(uic1er) & ~(0x80000000 >> vec)); - printf ("Masking bogus interrupt vector (uic1) 0x%x\n", vec); - } - - /* - * After servicing the interrupt, we have to remove the status indicator. - */ - mtdcr(uic1sr, (0x80000000 >> vec)); - } - - /* - * Shift msr to next position and increment vector - */ - msr_shift <<= 1; - vec++; - } -} -#endif /* defined(CONFIG_440) */ +#if defined(CONFIG_440) +#if defined(CONFIG_440GX) +/* 440GX uses base uic register */ +#define UIC_BMSR uicb0msr +#define UIC_BSR uicb0sr +#else +#define UIC_BMSR uic0msr +#define UIC_BSR uic0sr +#endif +#else /* CONFIG_440 */ +#define UIC_BMSR uicmsr +#define UIC_BSR uicsr +#endif /* CONFIG_440 */
-#if defined(CONFIG_440GX) || defined(CONFIG_440SPE) || \ - defined(CONFIG_440EPX) || defined(CONFIG_440GRX) -/* Handler for UIC2 interrupt */ -void uic2_interrupt( void * parms) +/* + * Handle external interrupts + */ +void external_interrupt(struct pt_regs *regs) { - ulong uic2_msr; - ulong msr_shift; - int vec; + u32 uic_msr;
/* * Read masked interrupt status register to determine interrupt source */ - uic2_msr = mfdcr(uic2msr); - msr_shift = uic2_msr; - vec = 0; + uic_msr = mfdcr(UIC_BMSR);
- while (msr_shift != 0) { - if (msr_shift & 0x80000000) { - /* - * Increment irq counter (for debug purpose only) - */ - irq_vecs2[vec].count++; - - if (irq_vecs2[vec].handler != NULL) { - /* call isr */ - (*irq_vecs2[vec].handler)(irq_vecs2[vec].arg); - } else { - mtdcr(uic2er, mfdcr(uic2er) & ~(0x80000000 >> vec)); - printf ("Masking bogus interrupt vector (uic2) 0x%x\n", vec); - } - - /* - * After servicing the interrupt, we have to remove the status indicator. - */ - mtdcr(uic2sr, (0x80000000 >> vec)); - } - - /* - * Shift msr to next position and increment vector - */ - msr_shift <<= 1; - vec++; - } -} -#endif /* defined(CONFIG_440GX) */ - -#if defined(CONFIG_440SPE) -/* Handler for UIC3 interrupt */ -void uic3_interrupt( void * parms) -{ - ulong uic3_msr; - ulong msr_shift; - int vec; +#if (UIC_MAX > 1) + if ((UICB0_UIC1CI & uic_msr) || (UICB0_UIC1NCI & uic_msr)) + uic_interrupt(UIC1_DCR_BASE, 32); +#endif
- /* - * Read masked interrupt status register to determine interrupt source - */ - uic3_msr = mfdcr(uic3msr); - msr_shift = uic3_msr; - vec = 0; +#if (UIC_MAX > 2) + if ((UICB0_UIC2CI & uic_msr) || (UICB0_UIC2NCI & uic_msr)) + uic_interrupt(UIC2_DCR_BASE, 64); +#endif
- while (msr_shift != 0) { - if (msr_shift & 0x80000000) { - /* - * Increment irq counter (for debug purpose only) - */ - irq_vecs3[vec].count++; +#if (UIC_MAX > 3) + if ((UICB0_UIC3CI & uic_msr) || (UICB0_UIC3NCI & uic_msr)) + uic_interrupt(UIC3_DCR_BASE, 96); +#endif
- if (irq_vecs3[vec].handler != NULL) { - /* call isr */ - (*irq_vecs3[vec].handler)(irq_vecs3[vec].arg); - } else { - mtdcr(uic3er, mfdcr(uic3er) & ~(0x80000000 >> vec)); - printf ("Masking bogus interrupt vector (uic3) 0x%x\n", vec); - } +#if defined(CONFIG_440) +#if !defined(CONFIG_440GX) + if (uic_msr & ~(UICB0_ALL)) + uic_interrupt(UIC0_DCR_BASE, 0); +#else + if ((UICB0_UIC0CI & uic_msr) || (UICB0_UIC0NCI & uic_msr)) + uic_interrupt(UIC0_DCR_BASE, 0); +#endif +#else /* CONFIG_440 */ + uic_interrupt(UIC0_DCR_BASE, 0); +#endif /* CONFIG_440 */
- /* - * After servicing the interrupt, we have to remove the status indicator. - */ - mtdcr(uic3sr, (0x80000000 >> vec)); - } + mtdcr(UIC_BSR, uic_msr);
- /* - * Shift msr to next position and increment vector - */ - msr_shift <<= 1; - vec++; - } + return; } -#endif /* defined(CONFIG_440SPE) */ - -/****************************************************************************/
/* * Install and free a interrupt handler. */ - -void irq_install_handler (int vec, interrupt_handler_t * handler, void *arg) +void irq_install_handler(int vec, interrupt_handler_t * handler, void *arg) { - struct irq_action *irqa = irq_vecs; - int i = vec; - -#if defined(CONFIG_440) || defined(CONFIG_405EX) -#if defined(CONFIG_440GX) || defined(CONFIG_440SPE) || \ - defined(CONFIG_440EPX) || defined(CONFIG_440GRX) - if ((vec > 31) && (vec < 64)) { - i = vec - 32; - irqa = irq_vecs1; - } else if (vec > 63) { - i = vec - 64; - irqa = irq_vecs2; - } -#else /* CONFIG_440GX */ - if (vec > 31) { - i = vec - 32; - irqa = irq_vecs1; - } -#endif /* CONFIG_440GX */ -#endif /* CONFIG_440 */ + int i;
/* - * print warning when replacing with a different irq vector + * Print warning when replacing with a different irq vector */ - if ((irqa[i].handler != NULL) && (irqa[i].handler != handler)) { - printf ("Interrupt vector %d: handler 0x%x replacing 0x%x\n", - vec, (uint) handler, (uint) irqa[i].handler); + if ((irq_vecs[vec].handler != NULL) && (irq_vecs[vec].handler != handler)) { + printf("Interrupt vector %d: handler 0x%x replacing 0x%x\n", + vec, (uint) handler, (uint) irq_vecs[vec].handler); } - irqa[i].handler = handler; - irqa[i].arg = arg; - -#if defined(CONFIG_440) || defined(CONFIG_405EX) -#if defined(CONFIG_440GX) || defined(CONFIG_440SPE) || \ - defined(CONFIG_440EPX) || defined(CONFIG_440GRX) - if ((vec > 31) && (vec < 64)) - mtdcr (uic1er, mfdcr (uic1er) | (0x80000000 >> i)); - else if (vec > 63) - mtdcr (uic2er, mfdcr (uic2er) | (0x80000000 >> i)); - else -#endif /* CONFIG_440GX */ - if (vec > 31) - mtdcr (uic1er, mfdcr (uic1er) | (0x80000000 >> i)); - else + irq_vecs[vec].handler = handler; + irq_vecs[vec].arg = arg; + + i = vec & 0x1f; + if ((vec >= 0) && (vec < 32)) + mtdcr(uicer, mfdcr(uicer) | (0x80000000 >> i)); +#if (UIC_MAX > 1) + else if ((vec >= 32) && (vec < 64)) + mtdcr(uic1er, mfdcr(uic1er) | (0x80000000 >> i)); +#endif +#if (UIC_MAX > 2) + else if ((vec >= 64) && (vec < 96)) + mtdcr(uic2er, mfdcr(uic2er) | (0x80000000 >> i)); #endif - mtdcr (uicer, mfdcr (uicer) | (0x80000000 >> i)); -#if 0 - printf ("Install interrupt for vector %d ==> %p\n", vec, handler); +#if (UIC_MAX > 3) + else if (vec >= 96) + mtdcr(uic3er, mfdcr(uic3er) | (0x80000000 >> i)); #endif + + debug("Install interrupt for vector %d ==> %p\n", vec, handler); }
void irq_free_handler (int vec) { - struct irq_action *irqa = irq_vecs; - int i = vec; - -#if defined(CONFIG_440) || defined(CONFIG_405EX) -#if defined(CONFIG_440GX) || defined(CONFIG_440SPE) || \ - defined(CONFIG_440EPX) || defined(CONFIG_440GRX) - if ((vec > 31) && (vec < 64)) { - irqa = irq_vecs1; - i = vec - 32; - } else if (vec > 63) { - irqa = irq_vecs2; - i = vec - 64; - } -#endif /* CONFIG_440GX */ - if (vec > 31) { - irqa = irq_vecs1; - i = vec - 32; - } -#endif + int i;
-#if 0 - printf ("Free interrupt for vector %d ==> %p\n", - vec, irq_vecs[vec].handler); -#endif + debug("Free interrupt for vector %d ==> %p\n", + vec, irq_vecs[vec].handler);
-#if defined(CONFIG_440) || defined(CONFIG_405EX) -#if defined(CONFIG_440GX) || defined(CONFIG_440SPE) || \ - defined(CONFIG_440EPX) || defined(CONFIG_440GRX) - if ((vec > 31) && (vec < 64)) - mtdcr (uic1er, mfdcr (uic1er) & ~(0x80000000 >> i)); - else if (vec > 63) - mtdcr (uic2er, mfdcr (uic2er) & ~(0x80000000 >> i)); - else -#endif /* CONFIG_440GX */ - if (vec > 31) - mtdcr (uic1er, mfdcr (uic1er) & ~(0x80000000 >> i)); - else + i = vec & 0x1f; + if ((vec >= 0) && (vec < 32)) + mtdcr(uicer, mfdcr(uicer) & ~(0x80000000 >> i)); +#if (UIC_MAX > 1) + else if ((vec >= 32) && (vec < 64)) + mtdcr(uic1er, mfdcr(uic1er) & ~(0x80000000 >> i)); +#endif +#if (UIC_MAX > 2) + else if ((vec >= 64) && (vec < 96)) + mtdcr(uic2er, mfdcr(uic2er) & ~(0x80000000 >> i)); +#endif +#if (UIC_MAX > 3) + else if (vec >= 96) + mtdcr(uic3er, mfdcr(uic3er) & ~(0x80000000 >> i)); #endif - mtdcr (uicer, mfdcr (uicer) & ~(0x80000000 >> i));
- irqa[i].handler = NULL; - irqa[i].arg = NULL; + irq_vecs[vec].handler = NULL; + irq_vecs[vec].arg = NULL; }
-/****************************************************************************/ - void timer_interrupt_cpu (struct pt_regs *regs) { /* nothing to do here */ return; }
-/****************************************************************************/ - #if defined(CONFIG_CMD_IRQ) - -/******************************************************************************* - * - * irqinfo - print information about PCI devices - * - */ -int -do_irqinfo(cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) +int do_irqinfo(cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) { int vec;
- printf ("\nInterrupt-Information:\n"); -#if defined(CONFIG_440) || defined(CONFIG_405EX) - printf ("\nUIC 0\n"); -#endif + printf ("Interrupt-Information:\n"); printf ("Nr Routine Arg Count\n");
- for (vec=0; vec<32; vec++) { + for (vec = 0; vec < (UIC_MAX * 32); vec++) { if (irq_vecs[vec].handler != NULL) { printf ("%02d %08lx %08lx %d\n", vec, @@ -656,46 +389,6 @@ do_irqinfo(cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) } }
-#if defined(CONFIG_440) || defined(CONFIG_405EX) - printf ("\nUIC 1\n"); - printf ("Nr Routine Arg Count\n"); - - for (vec=0; vec<32; vec++) { - if (irq_vecs1[vec].handler != NULL) - printf ("%02d %08lx %08lx %d\n", - vec+31, (ulong)irq_vecs1[vec].handler, - (ulong)irq_vecs1[vec].arg, irq_vecs1[vec].count); - } - printf("\n"); -#endif - -#if defined(CONFIG_440GX) || defined(CONFIG_440SPE) || \ - defined(CONFIG_440EPX) || defined(CONFIG_440GRX) - printf ("\nUIC 2\n"); - printf ("Nr Routine Arg Count\n"); - - for (vec=0; vec<32; vec++) { - if (irq_vecs2[vec].handler != NULL) - printf ("%02d %08lx %08lx %d\n", - vec+63, (ulong)irq_vecs2[vec].handler, - (ulong)irq_vecs2[vec].arg, irq_vecs2[vec].count); - } - printf("\n"); -#endif - -#if defined(CONFIG_440SPE) - printf ("\nUIC 3\n"); - printf ("Nr Routine Arg Count\n"); - - for (vec=0; vec<32; vec++) { - if (irq_vecs3[vec].handler != NULL) - printf ("%02d %08lx %08lx %d\n", - vec+63, (ulong)irq_vecs3[vec].handler, - (ulong)irq_vecs3[vec].arg, irq_vecs3[vec].count); - } - printf("\n"); -#endif - return 0; } #endif
This patch adds basic support for the AMCC 460EX/460GT PPC's.
Signed-off-by: Stefan Roese sr@denx.de --- cpu/ppc4xx/44x_spd_ddr2.c | 41 +++++- cpu/ppc4xx/4xx_enet.c | 369 ++++++++++++++++++++++++++++++++++++--------- cpu/ppc4xx/4xx_pci.c | 9 +- cpu/ppc4xx/4xx_pcie.c | 203 ++++++++++++++++++++++++- cpu/ppc4xx/4xx_uart.c | 24 ++- 5 files changed, 553 insertions(+), 93 deletions(-)
diff --git a/cpu/ppc4xx/44x_spd_ddr2.c b/cpu/ppc4xx/44x_spd_ddr2.c index 3bafea3..9e722b9 100644 --- a/cpu/ppc4xx/44x_spd_ddr2.c +++ b/cpu/ppc4xx/44x_spd_ddr2.c @@ -42,7 +42,8 @@ #include <asm/mmu.h>
#if defined(CONFIG_SPD_EEPROM) && \ - (defined(CONFIG_440SP) || defined(CONFIG_440SPE)) + (defined(CONFIG_440SP) || defined(CONFIG_440SPE) || \ + defined(CONFIG_460EX) || defined(CONFIG_460GT))
/*-----------------------------------------------------------------------------+ * Defines @@ -579,6 +580,13 @@ long int initdram(int board_type)
ppc440sp_sdram_register_dump();
+ /* + * Clear potential errors resulting from auto-calibration. + * If not done, then we could get an interrupt later on when + * exceptions are enabled. + */ + set_mcsr(get_mcsr()); + return dram_size; }
@@ -2125,6 +2133,7 @@ static void program_memory_queue(unsigned long *dimm_populated, unsigned long baseadd_size; unsigned long i; unsigned long bank_0_populated = 0; + unsigned long total_size = 0;
/*------------------------------------------------------------------ * Reset the rank_base_address. @@ -2147,28 +2156,38 @@ static void program_memory_queue(unsigned long *dimm_populated, * Set the sizes *-----------------------------------------------------------------*/ baseadd_size = 0; - rank_size_bytes = 4 * 1024 * 1024 * rank_size_id; switch (rank_size_id) { + case 0x01: + baseadd_size |= SDRAM_RXBAS_SDSZ_1024; + total_size = 1024; + break; case 0x02: - baseadd_size |= SDRAM_RXBAS_SDSZ_8; + baseadd_size |= SDRAM_RXBAS_SDSZ_2048; + total_size = 2048; break; case 0x04: - baseadd_size |= SDRAM_RXBAS_SDSZ_16; + baseadd_size |= SDRAM_RXBAS_SDSZ_4096; + total_size = 4096; break; case 0x08: baseadd_size |= SDRAM_RXBAS_SDSZ_32; + total_size = 32; break; case 0x10: baseadd_size |= SDRAM_RXBAS_SDSZ_64; + total_size = 64; break; case 0x20: baseadd_size |= SDRAM_RXBAS_SDSZ_128; + total_size = 128; break; case 0x40: baseadd_size |= SDRAM_RXBAS_SDSZ_256; + total_size = 256; break; case 0x80: baseadd_size |= SDRAM_RXBAS_SDSZ_512; + total_size = 512; break; default: printf("DDR-SDRAM: DIMM %d memory queue configuration.\n", @@ -2178,6 +2197,7 @@ static void program_memory_queue(unsigned long *dimm_populated, printf("Replace the DIMM module with a supported DIMM.\n\n"); spd_ddr_init_hang (); } + rank_size_bytes = total_size << 20;
if ((dimm_populated[dimm_num] != SDRAM_NONE) && (dimm_num == 1)) bank_0_populated = 1; @@ -2190,6 +2210,19 @@ static void program_memory_queue(unsigned long *dimm_populated, } } } + +#if defined(CONFIG_460EX) || defined(CONFIG_460GT) + /* + * Enable high bandwidth access on 460EX/GT. + * This should/could probably be done on other + * PPC's too, like 440SPe. + * This is currently not used, but with this setup + * it is possible to use it later on in e.g. the Linux + * EMAC driver for performance gain. + */ + mtdcr(SDRAM_PLBADDULL, 0x00000000); /* MQ0_BAUL */ + mtdcr(SDRAM_PLBADDUHB, 0x00000008); /* MQ0_BAUH */ +#endif }
/*-----------------------------------------------------------------------------+ diff --git a/cpu/ppc4xx/4xx_enet.c b/cpu/ppc4xx/4xx_enet.c index 599f5ce..d990250 100644 --- a/cpu/ppc4xx/4xx_enet.c +++ b/cpu/ppc4xx/4xx_enet.c @@ -137,17 +137,32 @@ #define BI_PHYMODE_RTBI 4 #define BI_PHYMODE_TBI 5 #if defined(CONFIG_440EPX) || defined(CONFIG_440GRX) || \ + defined(CONFIG_460EX) || defined(CONFIG_460GT) || \ defined(CONFIG_405EX) #define BI_PHYMODE_SMII 6 #define BI_PHYMODE_MII 7 +#if defined(CONFIG_460EX) || defined(CONFIG_460GT) +#define BI_PHYMODE_RMII 8 +#endif #endif
#if defined(CONFIG_440SP) || defined(CONFIG_440SPE) || \ defined(CONFIG_440EPX) || defined(CONFIG_440GRX) || \ + defined(CONFIG_460EX) || defined(CONFIG_460GT) || \ defined(CONFIG_405EX) #define SDR0_MFR_ETH_CLK_SEL_V(n) ((0x01<<27) / (n+1)) #endif
+#if defined(CONFIG_460EX) || defined(CONFIG_460GT) +#define SDR0_ETH_CFG_CLK_SEL_V(n) (0x01 << (8 + n)) +#endif + +#if defined(CONFIG_460EX) || defined(CONFIG_460GT) +#define MAL_RX_CHAN_MUL 8 /* 460EX/GT uses MAL channel 8 for EMAC1 */ +#else +#define MAL_RX_CHAN_MUL 1 +#endif + /*-----------------------------------------------------------------------------+ * Global variables. TX and RX descriptors and buffers. *-----------------------------------------------------------------------------*/ @@ -214,6 +229,44 @@ extern int emac4xx_miiphy_write (char *devname, unsigned char addr,
int board_emac_count(void);
+static void emac_loopback_enable(EMAC_4XX_HW_PST hw_p) +{ +#if defined(CONFIG_440SPE) || \ + defined(CONFIG_440EPX) || defined(CONFIG_440GRX) || \ + defined(CONFIG_405EX) + u32 val; + + mfsdr(sdr_mfr, val); + val |= SDR0_MFR_ETH_CLK_SEL_V(hw_p->devnum); + mtsdr(sdr_mfr, val); +#elif defined(CONFIG_460EX) || defined(CONFIG_460GT) + u32 val; + + mfsdr(SDR0_ETH_CFG, val); + val |= SDR0_ETH_CFG_CLK_SEL_V(hw_p->devnum); + mtsdr(SDR0_ETH_CFG, val); +#endif +} + +static void emac_loopback_disable(EMAC_4XX_HW_PST hw_p) +{ +#if defined(CONFIG_440SPE) || \ + defined(CONFIG_440EPX) || defined(CONFIG_440GRX) || \ + defined(CONFIG_405EX) + u32 val; + + mfsdr(sdr_mfr, val); + val &= ~SDR0_MFR_ETH_CLK_SEL_V(hw_p->devnum); + mtsdr(sdr_mfr, val); +#elif defined(CONFIG_460EX) || defined(CONFIG_460GT) + u32 val; + + mfsdr(SDR0_ETH_CFG, val); + val &= ~SDR0_ETH_CFG_CLK_SEL_V(hw_p->devnum); + mtsdr(SDR0_ETH_CFG, val); +#endif +} + /*-----------------------------------------------------------------------------+ | ppc_4xx_eth_halt | Disable MAL channel, and EMACn @@ -222,11 +275,6 @@ static void ppc_4xx_eth_halt (struct eth_device *dev) { EMAC_4XX_HW_PST hw_p = dev->priv; uint32_t failsafe = 10000; -#if defined(CONFIG_440SPE) || \ - defined(CONFIG_440EPX) || defined(CONFIG_440GRX) || \ - defined(CONFIG_405EX) - unsigned long mfr; -#endif
out_be32((void *)EMAC_IER + hw_p->hw_addr, 0x00000000); /* disable emac interrupts */
@@ -247,27 +295,14 @@ static void ppc_4xx_eth_halt (struct eth_device *dev) break; }
- /* EMAC RESET */ -#if defined(CONFIG_440SPE) || \ - defined(CONFIG_440EPX) || defined(CONFIG_440GRX) || \ - defined(CONFIG_405EX) /* provide clocks for EMAC internal loopback */ - mfsdr (sdr_mfr, mfr); - mfr |= SDR0_MFR_ETH_CLK_SEL_V(hw_p->devnum); - mtsdr(sdr_mfr, mfr); -#endif + emac_loopback_enable(hw_p);
+ /* EMAC RESET */ out_be32((void *)EMAC_M0 + hw_p->hw_addr, EMAC_M0_SRST);
-#if defined(CONFIG_440SPE) || \ - defined(CONFIG_440EPX) || defined(CONFIG_440GRX) || \ - defined(CONFIG_405EX) /* remove clocks for EMAC internal loopback */ - mfsdr (sdr_mfr, mfr); - mfr &= ~SDR0_MFR_ETH_CLK_SEL_V(hw_p->devnum); - mtsdr(sdr_mfr, mfr); -#endif - + emac_loopback_disable(hw_p);
#ifndef CONFIG_NETCONSOLE hw_p->print_speed = 1; /* print speed message again next time */ @@ -452,6 +487,187 @@ int ppc_4xx_eth_setup_bridge(int devnum, bd_t * bis) } #endif /* CONFIG_405EX */
+#if defined(CONFIG_460EX) || defined(CONFIG_460GT) +int ppc_4xx_eth_setup_bridge(int devnum, bd_t * bis) +{ + u32 eth_cfg; + u32 zmiifer; /* ZMII0_FER reg. */ + u32 rmiifer; /* RGMII0_FER reg. Bridge 0 */ + u32 rmiifer1; /* RGMII0_FER reg. Bridge 1 */ + + zmiifer = 0; + rmiifer = 0; + rmiifer1 = 0; + + /* TODO: + * NOTE: 460GT has 2 RGMII bridge cores: + * emac0 ------ RGMII0_BASE + * | + * emac1 -----+ + * + * emac2 ------ RGMII1_BASE + * | + * emac3 -----+ + * + * 460EX has 1 RGMII bridge core: + * and RGMII1_BASE is disabled + * emac0 ------ RGMII0_BASE + * | + * emac1 -----+ + */ + + /* + * Right now only 2*RGMII is supported. Please extend when needed. + * sr - 2008-02-19 + */ + switch (9) { + case 1: + /* 1 MII - 460EX */ + /* GMC0 EMAC4_0, ZMII Bridge */ + zmiifer |= ZMII_FER_MII << ZMII_FER_V(0); + bis->bi_phymode[0] = BI_PHYMODE_MII; + bis->bi_phymode[1] = BI_PHYMODE_NONE; + bis->bi_phymode[2] = BI_PHYMODE_NONE; + bis->bi_phymode[3] = BI_PHYMODE_NONE; + break; + case 2: + /* 2 MII - 460GT */ + /* GMC0 EMAC4_0, GMC1 EMAC4_2, ZMII Bridge */ + zmiifer |= ZMII_FER_MII << ZMII_FER_V(0); + zmiifer |= ZMII_FER_MII << ZMII_FER_V(2); + bis->bi_phymode[0] = BI_PHYMODE_MII; + bis->bi_phymode[1] = BI_PHYMODE_NONE; + bis->bi_phymode[2] = BI_PHYMODE_MII; + bis->bi_phymode[3] = BI_PHYMODE_NONE; + break; + case 3: + /* 2 RMII - 460EX */ + /* GMC0 EMAC4_0, GMC0 EMAC4_1, ZMII Bridge */ + zmiifer |= ZMII_FER_RMII << ZMII_FER_V(0); + zmiifer |= ZMII_FER_RMII << ZMII_FER_V(1); + bis->bi_phymode[0] = BI_PHYMODE_RMII; + bis->bi_phymode[1] = BI_PHYMODE_RMII; + bis->bi_phymode[2] = BI_PHYMODE_NONE; + bis->bi_phymode[3] = BI_PHYMODE_NONE; + break; + case 4: + /* 4 RMII - 460GT */ + /* GMC0 EMAC4_0, GMC0 EMAC4_1, GMC1 EMAC4_2, GMC1, EMAC4_3 */ + /* ZMII Bridge */ + zmiifer |= ZMII_FER_RMII << ZMII_FER_V(0); + zmiifer |= ZMII_FER_RMII << ZMII_FER_V(1); + zmiifer |= ZMII_FER_RMII << ZMII_FER_V(2); + zmiifer |= ZMII_FER_RMII << ZMII_FER_V(3); + bis->bi_phymode[0] = BI_PHYMODE_RMII; + bis->bi_phymode[1] = BI_PHYMODE_RMII; + bis->bi_phymode[2] = BI_PHYMODE_RMII; + bis->bi_phymode[3] = BI_PHYMODE_RMII; + break; + case 5: + /* 2 SMII - 460EX */ + /* GMC0 EMAC4_0, GMC0 EMAC4_1, ZMII Bridge */ + zmiifer |= ZMII_FER_SMII << ZMII_FER_V(0); + zmiifer |= ZMII_FER_SMII << ZMII_FER_V(1); + bis->bi_phymode[0] = BI_PHYMODE_SMII; + bis->bi_phymode[1] = BI_PHYMODE_SMII; + bis->bi_phymode[2] = BI_PHYMODE_NONE; + bis->bi_phymode[3] = BI_PHYMODE_NONE; + break; + case 6: + /* 4 SMII - 460GT */ + /* GMC0 EMAC4_0, GMC0 EMAC4_1, GMC0 EMAC4_3, GMC0 EMAC4_3 */ + /* ZMII Bridge */ + zmiifer |= ZMII_FER_SMII << ZMII_FER_V(0); + zmiifer |= ZMII_FER_SMII << ZMII_FER_V(1); + zmiifer |= ZMII_FER_SMII << ZMII_FER_V(2); + zmiifer |= ZMII_FER_SMII << ZMII_FER_V(3); + bis->bi_phymode[0] = BI_PHYMODE_SMII; + bis->bi_phymode[1] = BI_PHYMODE_SMII; + bis->bi_phymode[2] = BI_PHYMODE_SMII; + bis->bi_phymode[3] = BI_PHYMODE_SMII; + break; + case 7: + /* This is the default mode that we want for board bringup - Maple */ + /* 1 GMII - 460EX */ + /* GMC0 EMAC4_0, RGMII Bridge 0 */ + rmiifer |= RGMII_FER_MDIO(0); + + if (devnum == 0) { + rmiifer |= RGMII_FER_GMII << RGMII_FER_V(2); /* CH0CFG - EMAC0 */ + bis->bi_phymode[0] = BI_PHYMODE_GMII; + bis->bi_phymode[1] = BI_PHYMODE_NONE; + bis->bi_phymode[2] = BI_PHYMODE_NONE; + bis->bi_phymode[3] = BI_PHYMODE_NONE; + } else { + rmiifer |= RGMII_FER_GMII << RGMII_FER_V(3); /* CH1CFG - EMAC1 */ + bis->bi_phymode[0] = BI_PHYMODE_NONE; + bis->bi_phymode[1] = BI_PHYMODE_GMII; + bis->bi_phymode[2] = BI_PHYMODE_NONE; + bis->bi_phymode[3] = BI_PHYMODE_NONE; + } + break; + case 8: + /* 2 GMII - 460GT */ + /* GMC0 EMAC4_0, RGMII Bridge 0 */ + /* GMC1 EMAC4_2, RGMII Bridge 1 */ + rmiifer |= RGMII_FER_GMII << RGMII_FER_V(2); /* CH0CFG - EMAC0 */ + rmiifer1 |= RGMII_FER_GMII << RGMII_FER_V(2); /* CH0CFG - EMAC2 */ + rmiifer |= RGMII_FER_MDIO(0); /* enable MDIO - EMAC0 */ + rmiifer1 |= RGMII_FER_MDIO(0); /* enable MDIO - EMAC2 */ + + bis->bi_phymode[0] = BI_PHYMODE_GMII; + bis->bi_phymode[1] = BI_PHYMODE_NONE; + bis->bi_phymode[2] = BI_PHYMODE_GMII; + bis->bi_phymode[3] = BI_PHYMODE_NONE; + break; + case 9: + /* 2 RGMII - 460EX */ + /* GMC0 EMAC4_0, GMC0 EMAC4_1, RGMII Bridge 0 */ + rmiifer |= RGMII_FER_RGMII << RGMII_FER_V(2); + rmiifer |= RGMII_FER_RGMII << RGMII_FER_V(3); + rmiifer |= RGMII_FER_MDIO(0); /* enable MDIO - EMAC0 */ + + bis->bi_phymode[0] = BI_PHYMODE_RGMII; + bis->bi_phymode[1] = BI_PHYMODE_RGMII; + bis->bi_phymode[2] = BI_PHYMODE_NONE; + bis->bi_phymode[3] = BI_PHYMODE_NONE; + break; + case 10: + /* 4 RGMII - 460GT */ + /* GMC0 EMAC4_0, GMC0 EMAC4_1, RGMII Bridge 0 */ + /* GMC1 EMAC4_2, GMC1 EMAC4_3, RGMII Bridge 1 */ + rmiifer |= RGMII_FER_RGMII << RGMII_FER_V(2); + rmiifer |= RGMII_FER_RGMII << RGMII_FER_V(3); + rmiifer1 |= RGMII_FER_RGMII << RGMII_FER_V(2); + rmiifer1 |= RGMII_FER_RGMII << RGMII_FER_V(3); + bis->bi_phymode[0] = BI_PHYMODE_RGMII; + bis->bi_phymode[1] = BI_PHYMODE_RGMII; + bis->bi_phymode[2] = BI_PHYMODE_RGMII; + bis->bi_phymode[3] = BI_PHYMODE_RGMII; + break; + default: + break; + } + + /* Set EMAC for MDIO */ + mfsdr(SDR0_ETH_CFG, eth_cfg); + eth_cfg |= SDR0_ETH_CFG_MDIO_SEL_EMAC0; + mtsdr(SDR0_ETH_CFG, eth_cfg); + + out_be32((void *)RGMII_FER, rmiifer); +#if defined(CONFIG_460GT) + out_be32((void *)RGMII_FER + RGMII1_BASE_OFFSET, rmiifer1); +#endif + + /* bypass the TAHOE0/TAHOE1 cores for U-Boot */ + mfsdr(SDR0_ETH_CFG, eth_cfg); + eth_cfg |= (SDR0_ETH_CFG_TAHOE0_BYPASS | SDR0_ETH_CFG_TAHOE1_BYPASS); + mtsdr(SDR0_ETH_CFG, eth_cfg); + + return 0; +} +#endif /* CONFIG_460EX || CONFIG_460GT */ + static inline void *malloc_aligned(u32 size, u32 align) { return (void *)(((u32)malloc(size + align) + align - 1) & @@ -472,19 +688,16 @@ static int ppc_4xx_eth_init (struct eth_device *dev, bd_t * bis) #if defined(CONFIG_440GX) || \ defined(CONFIG_440EPX) || defined(CONFIG_440GRX) || \ defined(CONFIG_440SP) || defined(CONFIG_440SPE) || \ + defined(CONFIG_460EX) || defined(CONFIG_460GT) || \ defined(CONFIG_405EX) sys_info_t sysinfo; #if defined(CONFIG_440GX) || defined(CONFIG_440SPE) || \ defined(CONFIG_440EPX) || defined(CONFIG_440GRX) || \ + defined(CONFIG_460EX) || defined(CONFIG_460GT) || \ defined(CONFIG_405EX) int ethgroup = -1; #endif #endif -#if defined(CONFIG_440EPX) || defined(CONFIG_440GRX) || \ - defined(CONFIG_440SP) || defined(CONFIG_440SPE) || \ - defined(CONFIG_405EX) - unsigned long mfr; -#endif u32 bd_cached; u32 bd_uncached = 0; #ifdef CONFIG_4xx_DCACHE @@ -503,6 +716,7 @@ static int ppc_4xx_eth_init (struct eth_device *dev, bd_t * bis) #if defined(CONFIG_440GX) || \ defined(CONFIG_440EPX) || defined(CONFIG_440GRX) || \ defined(CONFIG_440SP) || defined(CONFIG_440SPE) || \ + defined(CONFIG_460EX) || defined(CONFIG_460GT) || \ defined(CONFIG_405EX) /* Need to get the OPB frequency so we can access the PHY */ get_sys_info (&sysinfo); @@ -556,21 +770,12 @@ static int ppc_4xx_eth_init (struct eth_device *dev, bd_t * bis) out_be32((void *)ZMII_FER, 0); udelay (100);
-#if defined(CONFIG_440EP) || defined(CONFIG_440GR) +#if defined(CONFIG_440GP) || defined(CONFIG_440EP) || defined(CONFIG_440GR) out_be32((void *)ZMII_FER, (ZMII_FER_RMII | ZMII_FER_MDI) << ZMII_FER_V (devnum)); -#elif defined(CONFIG_440GX) || defined(CONFIG_440EPX) || defined(CONFIG_440GRX) +#elif defined(CONFIG_440GX) || \ + defined(CONFIG_440EPX) || defined(CONFIG_440GRX) || \ + defined(CONFIG_460EX) || defined(CONFIG_460GT) ethgroup = ppc_4xx_eth_setup_bridge(devnum, bis); -#elif defined(CONFIG_440GP) - /* set RMII mode */ - out_be32((void *)ZMII_FER, ZMII_RMII | ZMII_MDI0); -#else - if ((devnum == 0) || (devnum == 1)) { - out_be32((void *)ZMII_FER, (ZMII_FER_SMII | ZMII_FER_MDI) << ZMII_FER_V (devnum)); - } else { /* ((devnum == 2) || (devnum == 3)) */ - out_be32((void *)ZMII_FER, ZMII_FER_MDI << ZMII_FER_V (devnum)); - out_be32((void *)RGMII_FER, ((RGMII_FER_RGMII << RGMII_FER_V (2)) | - (RGMII_FER_RGMII << RGMII_FER_V (3)))); - } #endif
out_be32((void *)ZMII_SSR, ZMII_SSR_SP << ZMII_SSR_V(devnum)); @@ -579,20 +784,17 @@ static int ppc_4xx_eth_init (struct eth_device *dev, bd_t * bis) ethgroup = ppc_4xx_eth_setup_bridge(devnum, bis); #endif
- __asm__ volatile ("eieio"); + sync();
- /* reset emac so we have access to the phy */ -#if defined(CONFIG_440SP) || defined(CONFIG_440SPE) || \ - defined(CONFIG_440EPX) || defined(CONFIG_440GRX) || \ - defined(CONFIG_405EX) /* provide clocks for EMAC internal loopback */ - mfsdr (sdr_mfr, mfr); - mfr |= SDR0_MFR_ETH_CLK_SEL_V(devnum); - mtsdr(sdr_mfr, mfr); -#endif + emac_loopback_enable(hw_p);
+ /* remove clocks for EMAC internal loopback */ + emac_loopback_disable(hw_p); + failsafe = 1000; while ((in_be32((void *)EMAC_M0 + hw_p->hw_addr) & (EMAC_M0_SRST)) && failsafe) { udelay (1000); @@ -601,18 +803,10 @@ static int ppc_4xx_eth_init (struct eth_device *dev, bd_t * bis) if (failsafe <= 0) printf("\nProblem resetting EMAC!\n");
-#if defined(CONFIG_440SP) || defined(CONFIG_440SPE) || \ - defined(CONFIG_440EPX) || defined(CONFIG_440GRX) || \ - defined(CONFIG_405EX) - /* remove clocks for EMAC internal loopback */ - mfsdr (sdr_mfr, mfr); - mfr &= ~SDR0_MFR_ETH_CLK_SEL_V(devnum); - mtsdr(sdr_mfr, mfr); -#endif - #if defined(CONFIG_440GX) || \ defined(CONFIG_440EPX) || defined(CONFIG_440GRX) || \ defined(CONFIG_440SP) || defined(CONFIG_440SPE) || \ + defined(CONFIG_460EX) || defined(CONFIG_460GT) || \ defined(CONFIG_405EX) /* Whack the M1 register */ mode_reg = 0x0; @@ -674,6 +868,7 @@ static int ppc_4xx_eth_init (struct eth_device *dev, bd_t * bis) #if defined(CONFIG_440GX) || \ defined(CONFIG_440EPX) || defined(CONFIG_440GRX) || \ defined(CONFIG_440SP) || defined(CONFIG_440SPE) || \ + defined(CONFIG_460EX) || defined(CONFIG_460GT) || \ defined(CONFIG_405EX)
#if defined(CONFIG_CIS8201_PHY) @@ -772,8 +967,10 @@ static int ppc_4xx_eth_init (struct eth_device *dev, bd_t * bis) hw_p->devnum); }
-#if defined(CONFIG_440) && !defined(CONFIG_440SP) && !defined(CONFIG_440SPE) && \ - !defined(CONFIG_440EPX) && !defined(CONFIG_440GRX) +#if defined(CONFIG_440) && \ + !defined(CONFIG_440SP) && !defined(CONFIG_440SPE) && \ + !defined(CONFIG_440EPX) && !defined(CONFIG_440GRX) && \ + !defined(CONFIG_460EX) && !defined(CONFIG_460GT) #if defined(CONFIG_440EP) || defined(CONFIG_440GR) mfsdr(sdr_mfr, reg); if (speed == 100) { @@ -807,6 +1004,7 @@ static int ppc_4xx_eth_init (struct eth_device *dev, bd_t * bis) #endif /* defined(CONFIG_440) && !defined(CONFIG_440SP) */
#if defined(CONFIG_440EPX) || defined(CONFIG_440GRX) || \ + defined(CONFIG_460EX) || defined(CONFIG_460GT) || \ defined(CONFIG_405EX) if (speed == 1000) reg = (RGMII_SSR_SP_1000MBPS << RGMII_SSR_V (devnum)); @@ -819,12 +1017,17 @@ static int ppc_4xx_eth_init (struct eth_device *dev, bd_t * bis) return -1; } out_be32((void *)RGMII_SSR, reg); +#if defined(CONFIG_460GT) + if ((devnum == 2) || (devnum == 3)) + out_be32((void *)RGMII_SSR + RGMII1_BASE_OFFSET, reg); +#endif #endif
/* set the Mal configuration reg */ #if defined(CONFIG_440GX) || \ defined(CONFIG_440EPX) || defined(CONFIG_440GRX) || \ defined(CONFIG_440SP) || defined(CONFIG_440SPE) || \ + defined(CONFIG_460EX) || defined(CONFIG_460GT) || \ defined(CONFIG_405EX) mtdcr (malmcr, MAL_CR_PLBB | MAL_CR_OPBBL | MAL_CR_LEA | MAL_CR_PLBLT_DEFAULT | MAL_CR_EOPIE | 0x00330000); @@ -926,9 +1129,16 @@ static int ppc_4xx_eth_init (struct eth_device *dev, bd_t * bis) mtdcr (maltxbattr, 0x0); mtdcr (malrxbattr, 0x0); #endif + +#if defined(CONFIG_460EX) || defined(CONFIG_460GT) + mtdcr (malrxctp8r, hw_p->rx); + /* set RX buffer size */ + mtdcr (malrcbs8, ENET_MAX_MTU_ALIGNED / 16); +#else mtdcr (malrxctp1r, hw_p->rx_phys); /* set RX buffer size */ mtdcr (malrcbs1, ENET_MAX_MTU_ALIGNED / 16); +#endif break; #if defined (CONFIG_440GX) case 2: @@ -1087,7 +1297,7 @@ static int ppc_4xx_eth_send (struct eth_device *dev, volatile void *ptr, hw_p->tx[hw_p->tx_slot].data_len = (short) len; hw_p->tx[hw_p->tx_slot].ctrl |= MAL_TX_CTRL_READY;
out_be32((void *)EMAC_TXM0 + hw_p->hw_addr, in_be32((void *)EMAC_TXM0 + hw_p->hw_addr) | EMAC_TXM0_GNP0); @@ -1127,15 +1337,31 @@ static int ppc_4xx_eth_send (struct eth_device *dev, volatile void *ptr, */ #define UIC0MSR uic1msr #define UIC0SR uic1sr +#define UIC1MSR uic1msr +#define UIC1SR uic1sr +#elif defined(CONFIG_460EX) || defined(CONFIG_460GT) +/* + * Hack: On 460EX/GT all enet irq sources are located on UIC2 + * Needs some cleanup. --ag + */ +#define UIC0MSR uic2msr +#define UIC0SR uic2sr +#define UIC1MSR uic2msr +#define UIC1SR uic2sr #else #define UIC0MSR uic0msr #define UIC0SR uic0sr +#define UIC1MSR uic1msr +#define UIC1SR uic1sr #endif
#if defined(CONFIG_440EPX) || defined(CONFIG_440GRX) || \ defined(CONFIG_405EX) #define UICMSR_ETHX uic0msr #define UICSR_ETHX uic0sr +#elif defined(CONFIG_460EX) || defined(CONFIG_460GT) +#define UICMSR_ETHX uic2msr +#define UICSR_ETHX uic2sr #else #define UICMSR_ETHX uic1msr #define UICSR_ETHX uic1sr @@ -1173,7 +1399,7 @@ int enetInt (struct eth_device *dev) serviced = 0;
my_uic0msr = mfdcr (UIC0MSR); - my_uic1msr = mfdcr (uic1msr); + my_uic1msr = mfdcr (UIC1MSR); #if defined(CONFIG_440GX) my_uic2msr = mfdcr (uic2msr); #endif @@ -1219,7 +1445,7 @@ int enetInt (struct eth_device *dev) if ((hw_p->emac_ier & emac_isr) || (my_uic1msr & (UIC_MS | UIC_MTDE | UIC_MRDE))) { mtdcr (UIC0SR, UIC_MRE | UIC_MTE); /* Clear */ - mtdcr (uic1sr, UIC_MS | UIC_MTDE | UIC_MRDE); /* Clear */ + mtdcr (UIC1SR, UIC_MS | UIC_MTDE | UIC_MRDE); /* Clear */ mtdcr (UICSR_ETHX, UIC_ETH0); /* Clear */ return (rc); /* we had errors so get out */ } @@ -1238,7 +1464,7 @@ int enetInt (struct eth_device *dev) if ((hw_p->emac_ier & emac_isr) || (my_uic1msr & (UIC_MS | UIC_MTDE | UIC_MRDE))) { mtdcr (UIC0SR, UIC_MRE | UIC_MTE); /* Clear */ - mtdcr (uic1sr, UIC_MS | UIC_MTDE | UIC_MRDE); /* Clear */ + mtdcr (UIC1SR, UIC_MS | UIC_MTDE | UIC_MRDE); /* Clear */ mtdcr (UICSR_ETHX, UIC_ETH1); /* Clear */ return (rc); /* we had errors so get out */ } @@ -1256,7 +1482,7 @@ int enetInt (struct eth_device *dev) if ((hw_p->emac_ier & emac_isr) || (my_uic1msr & (UIC_MS | UIC_MTDE | UIC_MRDE))) { mtdcr (UIC0SR, UIC_MRE | UIC_MTE); /* Clear */ - mtdcr (uic1sr, UIC_MS | UIC_MTDE | UIC_MRDE); /* Clear */ + mtdcr (UIC1SR, UIC_MS | UIC_MTDE | UIC_MRDE); /* Clear */ mtdcr (uic2sr, UIC_ETH2); return (rc); /* we had errors so get out */ } @@ -1274,7 +1500,7 @@ int enetInt (struct eth_device *dev) if ((hw_p->emac_ier & emac_isr) || (my_uic1msr & (UIC_MS | UIC_MTDE | UIC_MRDE))) { mtdcr (UIC0SR, UIC_MRE | UIC_MTE); /* Clear */ - mtdcr (uic1sr, UIC_MS | UIC_MTDE | UIC_MRDE); /* Clear */ + mtdcr (UIC1SR, UIC_MS | UIC_MTDE | UIC_MRDE); /* Clear */ mtdcr (uic2sr, UIC_ETH3); return (rc); /* we had errors so get out */ } @@ -1292,7 +1518,9 @@ int enetInt (struct eth_device *dev) /* check for EOB on valid channels */ if (my_uic0msr & UIC_MRE) { mal_rx_eob = mfdcr (malrxeobisr); - if ((mal_rx_eob & (0x80000000 >> hw_p->devnum)) != 0) { /* call emac routine for channel x */ + if ((mal_rx_eob & + (0x80000000 >> (hw_p->devnum * MAL_RX_CHAN_MUL))) + != 0) { /* call emac routine for channel x */ /* clear EOB mtdcr(malrxeobisr, mal_rx_eob); */ enet_rcv (dev, emac_isr); @@ -1303,7 +1531,7 @@ int enetInt (struct eth_device *dev) }
mtdcr (UIC0SR, UIC_MRE); /* Clear */ - mtdcr (uic1sr, UIC_MS | UIC_MTDE | UIC_MRDE); /* Clear */ + mtdcr (UIC1SR, UIC_MS | UIC_MTDE | UIC_MRDE); /* Clear */ switch (hw_p->devnum) { case 0: mtdcr (UICSR_ETHX, UIC_ETH0); @@ -1468,7 +1696,7 @@ static void enet_rcv (struct eth_device *dev, unsigned long malisr) int loop_count = 0;
rx_eob_isr = mfdcr (malrxeobisr); - if ((0x80000000 >> hw_p->devnum) & rx_eob_isr) { + if ((0x80000000 >> (hw_p->devnum * MAL_RX_CHAN_MUL)) & rx_eob_isr) { /* clear EOB */ mtdcr (malrxeobisr, rx_eob_isr);
@@ -1482,7 +1710,7 @@ static void enet_rcv (struct eth_device *dev, unsigned long malisr)
loop_count++; handled++; - data_len = (unsigned long) hw_p->rx[i].data_len; /* Get len */ + data_len = (unsigned long) hw_p->rx[i].data_len & 0x0fff; /* Get len */ if (data_len) { if (data_len > ENET_MAX_MTU) /* Check len */ data_len = 0; @@ -1568,7 +1796,7 @@ static int ppc_4xx_eth_rx (struct eth_device *dev) msr = mfmsr (); mtmsr (msr & ~(MSR_EE));
- length = hw_p->rx[user_index].data_len; + length = hw_p->rx[user_index].data_len & 0x0fff;
/* Pass the packet up to the protocol layers. */ /* NetReceive(NetRxPackets[rxIdx], length - 4); */ @@ -1718,6 +1946,7 @@ int ppc_4xx_eth_initialize (bd_t * bis) /* set the MAL IER ??? names may change with new spec ??? */ #if defined(CONFIG_440SPE) || \ defined(CONFIG_440EPX) || defined(CONFIG_440GRX) || \ + defined(CONFIG_460EX) || defined(CONFIG_460GT) || \ defined(CONFIG_405EX) mal_ier = MAL_IER_PT | MAL_IER_PRE | MAL_IER_PWE | diff --git a/cpu/ppc4xx/4xx_pci.c b/cpu/ppc4xx/4xx_pci.c index a5b9690..941d4dc 100644 --- a/cpu/ppc4xx/4xx_pci.c +++ b/cpu/ppc4xx/4xx_pci.c @@ -531,7 +531,8 @@ int pci_440_init (struct pci_controller *hose) out16r( PCIX0_CLS, 0x00060000 ); /* Bridge, host bridge */ #endif
-#if defined(CONFIG_440GX) || defined(CONFIG_440SPE) +#if defined(CONFIG_440GX) || defined(CONFIG_440SPE) || \ + defined(CONFIG_460EX) || defined(CONFIG_460GT) out32r( PCIX0_BRDGOPT1, 0x04000060 ); /* PLB Rq pri highest */ out32r( PCIX0_BRDGOPT2, in32(PCIX0_BRDGOPT2) | 0x83 ); /* Enable host config, clear Timeout, ensure int src1 */ #elif defined(PCIX0_BRDGOPT1) @@ -549,7 +550,8 @@ int pci_440_init (struct pci_controller *hose) out32r( PCIX0_POM0SA, 0 ); /* disable */ out32r( PCIX0_POM1SA, 0 ); /* disable */ out32r( PCIX0_POM2SA, 0 ); /* disable */ -#if defined(CONFIG_440SPE) +#if defined(CONFIG_440SPE) || \ + defined(CONFIG_460EX) || defined(CONFIG_460GT) out32r( PCIX0_POM0LAL, 0x10000000 ); out32r( PCIX0_POM0LAH, 0x0000000c ); #else @@ -586,7 +588,8 @@ void pci_init_board(void) int busno;
busno = pci_440_init (&ppc440_hose); -#if defined(CONFIG_440SPE) +#if defined(CONFIG_440SPE) || \ + defined(CONFIG_460EX) || defined(CONFIG_460GT) pcie_setup_hoses(busno + 1); #endif } diff --git a/cpu/ppc4xx/4xx_pcie.c b/cpu/ppc4xx/4xx_pcie.c index 3af9862..f9a1988 100644 --- a/cpu/ppc4xx/4xx_pcie.c +++ b/cpu/ppc4xx/4xx_pcie.c @@ -1,5 +1,5 @@ /* - * (C) Copyright 2006 - 2007 + * (C) Copyright 2006 - 2008 * Wolfgang Denk, DENX Software Engineering, wd@denx.de. * * Copyright (c) 2005 Cisco Systems. All rights reserved. @@ -31,7 +31,8 @@ #include <common.h> #include <pci.h>
-#if (defined(CONFIG_440SPE) || defined(CONFIG_405EX)) && \ +#if (defined(CONFIG_440SPE) || defined(CONFIG_405EX) || \ + defined(CONFIG_460EX) || defined(CONFIG_460GT)) && \ defined(CONFIG_PCI)
#include <asm/4xx_pcie.h> @@ -306,9 +307,8 @@ static int check_error(void) int err = 0;
/* SDR0_PEGPLLLCT1 reset */ - if (!(valPE0 = SDR_READ(PESDR0_PLLLCT1) & 0x01000000)) { + if (!(valPE0 = SDR_READ(PESDR0_PLLLCT1) & 0x01000000)) printf("PCIE: SDR0_PEGPLLLCT1 reset error 0x%x\n", valPE0); - }
valPE0 = SDR_READ(PESDR0_RCSSET); valPE1 = SDR_READ(PESDR1_RCSSET); @@ -400,7 +400,108 @@ int ppc4xx_init_pcie(void) } return 0; } -#else +#endif + +#if defined(CONFIG_460EX) || defined(CONFIG_460GT) +static void ppc4xx_setup_utl(u32 port) +{ + volatile void *utl_base = NULL; + + /* + * Map UTL registers at 0x0801_n000 (4K 0xfff mask) PEGPLn_REGMSK + */ + switch (port) { + case 0: + mtdcr(DCRN_PEGPL_REGBAH(PCIE0), U64_TO_U32_HIGH(CFG_PCIE0_UTLBASE)); + mtdcr(DCRN_PEGPL_REGBAL(PCIE0), U64_TO_U32_LOW(CFG_PCIE0_UTLBASE)); + mtdcr(DCRN_PEGPL_REGMSK(PCIE0), 0x00007001); /* BAM 11100000=4KB */ + mtdcr(DCRN_PEGPL_SPECIAL(PCIE0), 0); + break; + + case 1: + mtdcr(DCRN_PEGPL_REGBAH(PCIE1), U64_TO_U32_HIGH(CFG_PCIE0_UTLBASE)); + mtdcr(DCRN_PEGPL_REGBAL(PCIE1), U64_TO_U32_LOW(CFG_PCIE0_UTLBASE) + + 0x1000); + mtdcr(DCRN_PEGPL_REGMSK(PCIE1), 0x00007001); /* BAM 11100000=4KB */ + mtdcr(DCRN_PEGPL_SPECIAL(PCIE1), 0); + break; + } + utl_base = (unsigned int *)(CFG_PCIE_BASE + 0x1000 * port); + + /* + * Set buffer allocations and then assert VRB and TXE. + */ + out_be32(utl_base + PEUTL_PBCTL, 0x0800000c); /* PLBME, CRRE */ + out_be32(utl_base + PEUTL_OUTTR, 0x08000000); + out_be32(utl_base + PEUTL_INTR, 0x02000000); + out_be32(utl_base + PEUTL_OPDBSZ, 0x04000000); /* OPD = 512 Bytes */ + out_be32(utl_base + PEUTL_PBBSZ, 0x00000000); /* Max 512 Bytes */ + out_be32(utl_base + PEUTL_IPHBSZ, 0x02000000); + out_be32(utl_base + PEUTL_IPDBSZ, 0x04000000); /* IPD = 512 Bytes */ + out_be32(utl_base + PEUTL_RCIRQEN, 0x00f00000); + out_be32(utl_base + PEUTL_PCTL, 0x80800066); /* VRB,TXE,timeout=default */ +} + +/* + * TODO: double check PCI express SDR based on the latest user manual + * Some registers specified here no longer exist.. has to be + * updated based on the final EAS spec. + */ +static int check_error(void) +{ + u32 valPE0, valPE1; + int err = 0; + + valPE0 = SDR_READ(SDRN_PESDR_RCSSET(0)); + valPE1 = SDR_READ(SDRN_PESDR_RCSSET(1)); + + /* SDR0_PExRCSSET rstgu */ + if (!(valPE0 & PESDRx_RCSSET_RSTGU) || !(valPE1 & PESDRx_RCSSET_RSTGU)) { + printf("PCIE: SDR0_PExRCSSET rstgu error\n"); + err = -1; + } + + /* SDR0_PExRCSSET rstdl */ + if (!(valPE0 & PESDRx_RCSSET_RSTDL) || !(valPE1 & PESDRx_RCSSET_RSTDL)) { + printf("PCIE: SDR0_PExRCSSET rstdl error\n"); + err = -1; + } + + /* SDR0_PExRCSSET rstpyn */ + if ((valPE0 & PESDRx_RCSSET_RSTPYN) || (valPE1 & PESDRx_RCSSET_RSTPYN)) { + printf("PCIE: SDR0_PExRCSSET rstpyn error\n"); + err = -1; + } + + /* SDR0_PExRCSSET hldplb */ + if ((valPE0 & PESDRx_RCSSET_HLDPLB) || (valPE1 & PESDRx_RCSSET_HLDPLB)) { + printf("PCIE: SDR0_PExRCSSET hldplb error\n"); + err = -1; + } + + /* SDR0_PExRCSSET rdy */ + if ((valPE0 & PESDRx_RCSSET_RDY) || (valPE1 & PESDRx_RCSSET_RDY)) { + printf("PCIE: SDR0_PExRCSSET rdy error\n"); + err = -1; + } + + return err; +} + +/* + * Initialize PCI Express core as described in User Manual + * TODO: double check PE SDR PLL Register with the updated user manual. + */ +int ppc4xx_init_pcie(void) +{ + if (check_error()) + return -1; + + return 0; +} +#endif /* CONFIG_460EX */ + +#if defined(CONFIG_405EX) static void ppc4xx_setup_utl(u32 port) { u32 utl_base; @@ -450,7 +551,7 @@ int ppc4xx_init_pcie(void) */ return 0; } -#endif +#endif /* CONFIG_405EX */
/* * Board-specific pcie initialization @@ -511,6 +612,82 @@ int __ppc4xx_init_pcie_port_hw(int port, int rootport) } #endif /* CONFIG_440SPE */
+#if defined(CONFIG_460EX) || defined(CONFIG_460GT) +int __ppc4xx_init_pcie_port_hw(int port, int rootport) +{ + u32 val = 1 << 24; + u32 utlset1; + + if (rootport) { + val = PTYPE_ROOT_PORT << 20; + utlset1 = 0x21222222; + } else { + val = PTYPE_LEGACY_ENDPOINT << 20; + utlset1 = 0x20222222; + } + + if (port == 0) { + val |= LNKW_X1 << 12; + } else { + val |= LNKW_X4 << 12; + utlset1 |= 0x00101101; + } + + SDR_WRITE(SDRN_PESDR_DLPSET(port), val); + SDR_WRITE(SDRN_PESDR_UTLSET1(port), utlset1); + SDR_WRITE(SDRN_PESDR_UTLSET2(port), 0x01210000); + + switch (port) { + case 0: + SDR_WRITE(PESDR0_L0CDRCTL, 0x00003230); + SDR_WRITE(PESDR0_L0DRV, 0x00000136); + SDR_WRITE(PESDR0_L0CLK, 0x00000006); + + SDR_WRITE(PESDR0_PHY_CTL_RST,0x10000000); + break; + + case 1: + SDR_WRITE(PESDR1_L0CDRCTL, 0x00003230); + SDR_WRITE(PESDR1_L1CDRCTL, 0x00003230); + SDR_WRITE(PESDR1_L2CDRCTL, 0x00003230); + SDR_WRITE(PESDR1_L3CDRCTL, 0x00003230); + SDR_WRITE(PESDR1_L0DRV, 0x00000136); + SDR_WRITE(PESDR1_L1DRV, 0x00000136); + SDR_WRITE(PESDR1_L2DRV, 0x00000136); + SDR_WRITE(PESDR1_L3DRV, 0x00000136); + SDR_WRITE(PESDR1_L0CLK, 0x00000006); + SDR_WRITE(PESDR1_L1CLK, 0x00000006); + SDR_WRITE(PESDR1_L2CLK, 0x00000006); + SDR_WRITE(PESDR1_L3CLK, 0x00000006); + + SDR_WRITE(PESDR1_PHY_CTL_RST,0x10000000); + break; + } + + SDR_WRITE(SDRN_PESDR_RCSSET(port), SDR_READ(SDRN_PESDR_RCSSET(port)) | + (PESDRx_RCSSET_RSTGU | PESDRx_RCSSET_RSTPYN)); + + /* Poll for PHY reset */ + switch (port) { + case 0: + while (!(SDR_READ(PESDR0_RSTSTA) & 0x1)) + udelay(10); + break; + case 1: + while (!(SDR_READ(PESDR1_RSTSTA) & 0x1)) + udelay(10); + break; + } + + SDR_WRITE(SDRN_PESDR_RCSSET(port), + (SDR_READ(SDRN_PESDR_RCSSET(port)) & + ~(PESDRx_RCSSET_RSTGU | PESDRx_RCSSET_RSTDL)) | + PESDRx_RCSSET_RSTPYN); + + return 0; +} +#endif /* CONFIG_440SPE */ + #if defined(CONFIG_405EX) int __ppc4xx_init_pcie_port_hw(int port, int rootport) { @@ -564,12 +741,12 @@ __attribute__((weak, alias("__ppc4xx_init_pcie_port_hw"))); * range (hangs the core upon config transaction attempts when set * otherwise) while revA uses c_nnnn_nnnn. * - * For revA: + * For 440SPe revA: * PCIE0: 0xc_4000_0000 * PCIE1: 0xc_8000_0000 * PCIE2: 0xc_c000_0000 * - * For revB: + * For 440SPe revB: * PCIE0: 0xd_0000_0000 * PCIE1: 0xd_2000_0000 * PCIE2: 0xd_4000_0000 @@ -577,6 +754,10 @@ __attribute__((weak, alias("__ppc4xx_init_pcie_port_hw"))); * For 405EX: * PCIE0: 0xa000_0000 * PCIE1: 0xc000_0000 + * + * For 460EX/GT: + * PCIE0: 0xd_0000_0000 + * PCIE1: 0xd_2000_0000 */ static inline u64 ppc4xx_get_cfgaddr(int port) { @@ -609,6 +790,12 @@ static inline u64 ppc4xx_get_cfgaddr(int port) } } #endif +#if defined(CONFIG_460EX) || defined(CONFIG_460GT) + if (port == 0) + return 0x0000000d00000000ULL; + else + return 0x0000000d20000000ULL; +#endif }
/* diff --git a/cpu/ppc4xx/4xx_uart.c b/cpu/ppc4xx/4xx_uart.c index 3d1124e..ffbc222 100644 --- a/cpu/ppc4xx/4xx_uart.c +++ b/cpu/ppc4xx/4xx_uart.c @@ -64,16 +64,22 @@ DECLARE_GLOBAL_DATA_PTR;
#if defined(CONFIG_440) #if defined(CONFIG_440EP) || defined(CONFIG_440GR) || \ - defined(CONFIG_440EPX) || defined(CONFIG_440GRX) -#define UART0_BASE CFG_PERIPHERAL_BASE + 0x00000300 -#define UART1_BASE CFG_PERIPHERAL_BASE + 0x00000400 + defined(CONFIG_440EPX) || defined(CONFIG_440GRX) || \ + defined(CONFIG_460EX) || defined(CONFIG_460GT) +#define UART0_BASE (CFG_PERIPHERAL_BASE + 0x00000300) +#define UART1_BASE (CFG_PERIPHERAL_BASE + 0x00000400) #else -#define UART0_BASE CFG_PERIPHERAL_BASE + 0x00000200 -#define UART1_BASE CFG_PERIPHERAL_BASE + 0x00000300 +#define UART0_BASE (CFG_PERIPHERAL_BASE + 0x00000200) +#define UART1_BASE (CFG_PERIPHERAL_BASE + 0x00000300) #endif
#if defined(CONFIG_440SP) || defined(CONFIG_440SPE) -#define UART2_BASE CFG_PERIPHERAL_BASE + 0x00000600 +#define UART2_BASE (CFG_PERIPHERAL_BASE + 0x00000600) +#endif + +#if defined(CONFIG_460EX) || defined(CONFIG_460GT) +#define UART2_BASE (CFG_PERIPHERAL_BASE + 0x00000500) +#define UART3_BASE (CFG_PERIPHERAL_BASE + 0x00000600) #endif
#if defined(CONFIG_440GP) @@ -94,11 +100,13 @@ DECLARE_GLOBAL_DATA_PTR; #define UART1_SDR sdr_uart1 #if defined(CONFIG_440EP) || defined(CONFIG_440EPx) || \ defined(CONFIG_440GR) || defined(CONFIG_440GRx) || \ - defined(CONFIG_440SP) || defined(CONFIG_440SPe) + defined(CONFIG_440SP) || defined(CONFIG_440SPe) || \ + defined(CONFIG_460EX) || defined(CONFIG_460GT) #define UART2_SDR sdr_uart2 #endif #if defined(CONFIG_440EP) || defined(CONFIG_440EPx) || \ - defined(CONFIG_440GR) || defined(CONFIG_440GRx) + defined(CONFIG_440GR) || defined(CONFIG_440GRx) || \ + defined(CONFIG_460EX) || defined(CONFIG_460GT) #define UART3_SDR sdr_uart3 #endif #define MFREG(a, d) mfsdr(a, d)
Signed-off-by: Stefan Roese sr@denx.de --- cpu/ppc4xx/cpu.c | 45 +++++++++++++++++- cpu/ppc4xx/cpu_init.c | 1 + cpu/ppc4xx/ndfc.c | 3 +- cpu/ppc4xx/speed.c | 125 ++++++++++++++++++++++++++++++++++++++++++++++++- cpu/ppc4xx/start.S | 11 ++++- 5 files changed, 178 insertions(+), 7 deletions(-)
diff --git a/cpu/ppc4xx/cpu.c b/cpu/ppc4xx/cpu.c index 9e9c685..54cc256 100644 --- a/cpu/ppc4xx/cpu.c +++ b/cpu/ppc4xx/cpu.c @@ -54,7 +54,8 @@ static int pci_async_enabled(void) #endif
#if defined(CONFIG_440EP) || defined(CONFIG_440GR) || \ - defined(CONFIG_440EPX) || defined(CONFIG_440GRX) + defined(CONFIG_440EPX) || defined(CONFIG_440GRX) || \ + defined(CONFIG_460EX) || defined(CONFIG_460GT) unsigned long val;
mfsdr(sdr_sdstp1, val); @@ -86,7 +87,8 @@ static int pci_arbiter_enabled(void) return (val & 0x80000000); #endif #if defined(CONFIG_440EP) || defined(CONFIG_440GR) || \ - defined(CONFIG_440EPX) || defined(CONFIG_440GRX) + defined(CONFIG_440EPX) || defined(CONFIG_440GRX) || \ + defined(CONFIG_460EX) || defined(CONFIG_460GT) unsigned long val;
mfsdr(sdr_pci0, val); @@ -167,6 +169,21 @@ static char *bootstrap_str[] = { static char bootstrap_char[] = { 'A', 'B', 'C', 'D', 'E', 'G', 'F', 'H' }; #endif
+#if defined(CONFIG_460EX) || defined(CONFIG_460GT) +#define SDR0_PINSTP_SHIFT 29 +static char *bootstrap_str[] = { + "EBC (8 bits)", + "EBC (16 bits)", + "PCI", + "PCI", + "EBC (16 bits)", + "NAND (8 bits)", + "I2C (Addr 0x54)", /* A8 */ + "I2C (Addr 0x52)", /* A4 */ +}; +static char bootstrap_char[] = { 'A', 'B', 'C', 'D', 'E', 'G', 'F', 'H' }; +#endif + #if defined(CONFIG_405EZ) #define SDR0_PINSTP_SHIFT 28 static char *bootstrap_str[] = { @@ -257,8 +274,12 @@ int checkcpu (void) puts("05"); #endif #if defined(CONFIG_440) +#if defined(CONFIG_460EX) || defined(CONFIG_460GT) + puts("60"); +#else puts("40"); #endif +#endif
switch (pvr) { case PVR_405GP_RB: @@ -448,6 +469,26 @@ int checkcpu (void) strcpy(addstr, "No RAID 6 support"); break;
+ case PVR_460EX_RA: + puts("EX Rev. A"); + strcpy(addstr, "No Security/Kasumi support"); + break; + + case PVR_460EX_SE_RA: + puts("EX Rev. A"); + strcpy(addstr, "Security/Kasumi support"); + break; + + case PVR_460GT_RA: + puts("GT Rev. A"); + strcpy(addstr, "No Security/Kasumi support"); + break; + + case PVR_460GT_SE_RA: + puts("GT Rev. A"); + strcpy(addstr, "Security/Kasumi support"); + break; + default: printf (" UNKNOWN (PVR=%08x)", pvr); break; diff --git a/cpu/ppc4xx/cpu_init.c b/cpu/ppc4xx/cpu_init.c index 2e0dd6f..5d15e2f 100644 --- a/cpu/ppc4xx/cpu_init.c +++ b/cpu/ppc4xx/cpu_init.c @@ -302,5 +302,6 @@ int cpu_init_r (void) } #endif /* defined(CONFIG_405GP) */ #endif /* defined(CONFIG_405GP) || defined(CONFIG_405EP) */ + return (0); } diff --git a/cpu/ppc4xx/ndfc.c b/cpu/ppc4xx/ndfc.c index 9e2229d..5b2ae88 100644 --- a/cpu/ppc4xx/ndfc.c +++ b/cpu/ppc4xx/ndfc.c @@ -34,7 +34,8 @@ #if defined(CONFIG_CMD_NAND) && !defined(CFG_NAND_LEGACY) && \ (defined(CONFIG_440EP) || defined(CONFIG_440GR) || \ defined(CONFIG_440EPX) || defined(CONFIG_440GRX) || \ - defined(CONFIG_405EZ) || defined(CONFIG_405EX)) + defined(CONFIG_405EZ) || defined(CONFIG_405EX) || \ + defined(CONFIG_460EX) || defined(CONFIG_460GT))
#include <nand.h> #include <linux/mtd/ndfc.h> diff --git a/cpu/ppc4xx/speed.c b/cpu/ppc4xx/speed.c index 9006614..fa79952 100644 --- a/cpu/ppc4xx/speed.c +++ b/cpu/ppc4xx/speed.c @@ -1,5 +1,5 @@ /* - * (C) Copyright 2000-2007 + * (C) Copyright 2000-2008 * Wolfgang Denk, DENX Software Engineering, wd@denx.de. * * See file CREDITS for list of people who contributed to this @@ -35,6 +35,8 @@ DECLARE_GLOBAL_DATA_PTR; #define DEBUGF(fmt,args...) #endif
+#define ARRAY_SIZE(x) (sizeof(x) / sizeof((x)[0])) + #if defined(CONFIG_405GP) || defined(CONFIG_405CR)
void get_sys_info (PPC4xx_SYS_INFO * sysInfo) @@ -201,7 +203,126 @@ ulong get_PCI_freq (void)
#elif defined(CONFIG_440)
-#if defined(CONFIG_440EP) || defined(CONFIG_440GR) || \ +#if defined(CONFIG_460EX) || defined(CONFIG_460GT) +static u8 pll_fwdv_multi_bits[] = { + /* values for: 1 - 16 */ + 0x00, 0x01, 0x0f, 0x04, 0x09, 0x0a, 0x0d, 0x0e, 0x03, 0x0c, + 0x05, 0x08, 0x07, 0x02, 0x0b, 0x06 +}; + +u32 get_cpr0_fwdv(unsigned long cpr_reg_fwdv) +{ + u32 index; + + for (index = 0; index < ARRAY_SIZE(pll_fwdv_multi_bits); index++) + if (cpr_reg_fwdv == (u32)pll_fwdv_multi_bits[index]) + return index + 1; + + return 0; +} + +static u8 pll_fbdv_multi_bits[] = { + /* values for: 1 - 100 */ + 0x00, 0xff, 0x7e, 0xfd, 0x7a, 0xf5, 0x6a, 0xd5, 0x2a, 0xd4, + 0x29, 0xd3, 0x26, 0xcc, 0x19, 0xb3, 0x67, 0xce, 0x1d, 0xbb, + 0x77, 0xee, 0x5d, 0xba, 0x74, 0xe9, 0x52, 0xa5, 0x4b, 0x96, + 0x2c, 0xd8, 0x31, 0xe3, 0x46, 0x8d, 0x1b, 0xb7, 0x6f, 0xde, + 0x3d, 0xfb, 0x76, 0xed, 0x5a, 0xb5, 0x6b, 0xd6, 0x2d, 0xdb, + 0x36, 0xec, 0x59, 0xb2, 0x64, 0xc9, 0x12, 0xa4, 0x48, 0x91, + 0x23, 0xc7, 0x0e, 0x9c, 0x38, 0xf0, 0x61, 0xc2, 0x05, 0x8b, + 0x17, 0xaf, 0x5f, 0xbe, 0x7c, 0xf9, 0x72, 0xe5, 0x4a, 0x95, + 0x2b, 0xd7, 0x2e, 0xdc, 0x39, 0xf3, 0x66, 0xcd, 0x1a, 0xb4, + 0x68, 0xd1, 0x22, 0xc4, 0x09, 0x93, 0x27, 0xcf, 0x1e, 0xbc, + /* values for: 101 - 200 */ + 0x78, 0xf1, 0x62, 0xc5, 0x0a, 0x94, 0x28, 0xd0, 0x21, 0xc3, + 0x06, 0x8c, 0x18, 0xb0, 0x60, 0xc1, 0x02, 0x84, 0x08, 0x90, + 0x20, 0xc0, 0x01, 0x83, 0x77, 0xff, 0x1f, 0xbf, 0x7f, 0xfe, + 0x7d, 0xfa, 0x75, 0xea, 0x55, 0xaa, 0x54, 0xa9, 0x53, 0xa6, + 0x4c, 0x99, 0x33, 0xe7, 0x4e, 0x9d, 0x3b, 0xf7, 0x6e, 0xdd, + 0x3a, 0xf4, 0x69, 0xd2, 0x25, 0xcb, 0x16, 0xac, 0x58, 0xb1, + 0x63, 0xc6, 0x0d, 0x9b, 0x37, 0xef, 0x5e, 0xbd, 0x7b, 0xf6, + 0x6d, 0xda, 0x35, 0xeb, 0x56, 0xad, 0x5b, 0xb6, 0x6c, 0xd9, + 0x32, 0xe4, 0x49, 0x92, 0x24, 0xc8, 0x11, 0xa3, 0x47, 0x8e, + 0x1c, 0xb8, 0x70, 0xe1, 0x42, 0x85, 0x0b, 0x97, 0x2f, 0xdf, + /* values for: 201 - 255 */ + 0x3e, 0xfc, 0x79, 0xf2, 0x65, 0xca, 0x15, 0xab, 0x57, 0xae, + 0x5c, 0xb9, 0x73, 0xe6, 0x4d, 0x9a, 0x34, 0xe8, 0x51, 0xa2, + 0x44, 0x89, 0x13, 0xa7, 0x4f, 0x9e, 0x3c, 0xf8, 0x71, 0xe2, + 0x45, 0x8a, 0x14, 0xa8, 0x50, 0xa1, 0x43, 0x86, 0x0c, 0x98, + 0x30, 0xe0, 0x41, 0x82, 0x04, 0x88, 0x10, 0xa0, 0x40, 0x81, + 0x03, 0x87, 0x0f, 0x9f, 0x3f /* END */ +}; + +u32 get_cpr0_fbdv(unsigned long cpr_reg_fbdv) +{ + u32 index; + + for (index = 0; index < ARRAY_SIZE(pll_fbdv_multi_bits); index++) + if (cpr_reg_fbdv == (u32)pll_fbdv_multi_bits[index]) + return index + 1; + + return 0; +} + +/* + * AMCC_TODO: verify this routine against latest EAS, cause stuff changed + * with latest EAS + */ +void get_sys_info (sys_info_t * sysInfo) +{ + unsigned long strp0; + unsigned long strp1; + unsigned long temp; + unsigned long m; + unsigned long plbedv0; + + /* Extract configured divisors */ + mfsdr(sdr_sdstp0, strp0); + mfsdr(sdr_sdstp1, strp1); + + temp = ((strp0 & PLLSYS0_FWD_DIV_A_MASK) >> 4); + sysInfo->pllFwdDivA = get_cpr0_fwdv(temp); + + temp = (strp0 & PLLSYS0_FWD_DIV_B_MASK); + sysInfo->pllFwdDivB = get_cpr0_fwdv(temp); + + temp = (strp0 & PLLSYS0_FB_DIV_MASK) >> 8; + sysInfo->pllFbkDiv = get_cpr0_fbdv(temp); + + temp = (strp1 & PLLSYS0_OPB_DIV_MASK) >> 26; + sysInfo->pllOpbDiv = temp ? temp : 4; + + /* AMCC_TODO: verify the SDR0_SDSTP1.PERDV0 value sysInfo->pllExtBusDiv */ + temp = (strp1 & PLLSYS0_PERCLK_DIV_MASK) >> 24; + sysInfo->pllExtBusDiv = temp ? temp : 4; + + temp = (strp1 & PLLSYS0_PLBEDV0_DIV_MASK) >> 29; + plbedv0 = temp ? temp: 8; + + /* Calculate 'M' based on feedback source */ + temp = (strp0 & PLLSYS0_SEL_MASK) >> 27; + if (temp == 0) { + /* PLL internal feedback */ + m = sysInfo->pllFbkDiv; + } else { + /* PLL PerClk feedback */ + m = sysInfo->pllFwdDivA * plbedv0 * sysInfo->pllOpbDiv * + sysInfo->pllExtBusDiv; + } + + /* Now calculate the individual clocks */ + sysInfo->freqVCOMhz = (m * CONFIG_SYS_CLK_FREQ) + (m >> 1); + sysInfo->freqProcessor = sysInfo->freqVCOMhz/sysInfo->pllFwdDivA; + sysInfo->freqPLB = sysInfo->freqVCOMhz / sysInfo->pllFwdDivA / plbedv0; + sysInfo->freqOPB = sysInfo->freqPLB / sysInfo->pllOpbDiv; + sysInfo->freqEBC = sysInfo->freqOPB / sysInfo->pllExtBusDiv; + sysInfo->freqDDR = sysInfo->freqPLB; + sysInfo->freqUART = sysInfo->freqPLB; + + return; +} + +#elif defined(CONFIG_440EP) || defined(CONFIG_440GR) || \ defined(CONFIG_440EPX) || defined(CONFIG_440GRX) void get_sys_info (sys_info_t *sysInfo) { diff --git a/cpu/ppc4xx/start.S b/cpu/ppc4xx/start.S index d8df67b..cdfc943 100644 --- a/cpu/ppc4xx/start.S +++ b/cpu/ppc4xx/start.S @@ -672,7 +672,9 @@ _start: /* 440EP & 440GR are only 440er PPC's without internal SRAM */ #if !defined(CONFIG_440EP) && !defined(CONFIG_440GR) /* not all PPC's have internal SRAM usable as L2-cache */ -#if defined(CONFIG_440GX) || defined(CONFIG_440SP) || defined(CONFIG_440SPE) +#if defined(CONFIG_440GX) || \ + defined(CONFIG_440SP) || defined(CONFIG_440SPE) || \ + defined(CONFIG_460EX) || defined(CONFIG_460GT) mtdcr l2_cache_cfg,r0 /* Ensure L2 Cache is off */ #endif
@@ -711,6 +713,10 @@ _start: lis r1, 0x0003 ori r1,r1, 0x0984 /* fourth 64k */ mtdcr isram0_sb3cr,r1 +#elif defined(CONFIG_460EX) || defined(CONFIG_460GT) + lis r1,0x4000 /* BAS = 8000_0000 */ + ori r1,r1,0x4580 /* 16k */ + mtdcr isram0_sb0cr,r1 #elif defined(CONFIG_440GP) ori r1,r1,0x0380 /* 8k rw */ mtdcr isram0_sb0cr,r1 @@ -1370,7 +1376,8 @@ relocate_code:
#if defined(CONFIG_440EP) || defined(CONFIG_440GR) || \ defined(CONFIG_440EPX) || defined(CONFIG_440GRX) || \ - defined(CONFIG_440SP) || defined(CONFIG_440SPE) + defined(CONFIG_440SP) || defined(CONFIG_440SPE) || \ + defined(CONFIG_460EX) || defined(CONFIG_460GT) /* * On some 440er platforms the cache is enabled in the first TLB (Boot-CS) * to speed up the boot process. Now this cache needs to be disabled.
Signed-off-by: Stefan Roese sr@denx.de --- include/405_mal.h | 1 + include/4xx_i2c.h | 3 +- include/asm-ppc/4xx_pcie.h | 79 ++++++++++++++++++++++++++++++++++++++- include/asm-ppc/ppc4xx-intvec.h | 71 +++++++++++++++++++++++++++++++++++ include/asm-ppc/processor.h | 4 ++ include/asm-ppc/u-boot.h | 6 ++- 6 files changed, 160 insertions(+), 4 deletions(-)
diff --git a/include/405_mal.h b/include/405_mal.h index 7ea4eb1..1415cbe 100644 --- a/include/405_mal.h +++ b/include/405_mal.h @@ -94,6 +94,7 @@ /* Mal IER */ #if defined(CONFIG_440SPE) || \ defined(CONFIG_440EPX) || defined(CONFIG_440GRX) || \ + defined(CONFIG_460EX) || defined(CONFIG_460GT) || \ defined(CONFIG_405EX) #define MAL_IER_PT 0x00000080 #define MAL_IER_PRE 0x00000040 diff --git a/include/4xx_i2c.h b/include/4xx_i2c.h index 7c79bd1..2df4fbd 100644 --- a/include/4xx_i2c.h +++ b/include/4xx_i2c.h @@ -41,7 +41,8 @@ #endif /* CONFIG_I2C_MULTI_BUS */
#if defined(CONFIG_440EP) || defined(CONFIG_440GR) || \ - defined(CONFIG_440EPX) || defined(CONFIG_440GRX) + defined(CONFIG_440EPX) || defined(CONFIG_440GRX) || \ + defined(CONFIG_460EX) || defined(CONFIG_460GT) #define I2C_BASE_ADDR (CFG_PERIPHERAL_BASE + 0x00000700 + I2C_BUS_OFFS) #elif defined(CONFIG_440) || defined(CONFIG_405EX) /* all remaining 440 variants */ diff --git a/include/asm-ppc/4xx_pcie.h b/include/asm-ppc/4xx_pcie.h index 4c03b05..d27d2a9 100644 --- a/include/asm-ppc/4xx_pcie.h +++ b/include/asm-ppc/4xx_pcie.h @@ -29,6 +29,18 @@ #define PCIE2_SDR 0x370 #endif
+#if defined(CONFIG_460EX) || defined(CONFIG_460GT) +#define CFG_PCIE_NR_PORTS 2 + +#define CFG_PCIE_ADDR_HIGH 0x0000000d + +#define DCRN_PCIE0_BASE 0x100 +#define DCRN_PCIE1_BASE 0x120 + +#define PCIE0_SDR 0x300 +#define PCIE1_SDR 0x340 +#endif + #if defined(CONFIG_405EX) #define CFG_PCIE_NR_PORTS 2
@@ -68,7 +80,7 @@ #define PESDR0_PLLLCT2 0x03a1 #define PESDR0_PLLLCT3 0x03a2
-/* common regs, at least for 405EX and 440SPe */ +/* common regs, at for all 4xx with PCIe core */ #define SDRN_PESDR_UTLSET1(n) (sdr_base(n) + 0x00) #define SDRN_PESDR_UTLSET2(n) (sdr_base(n) + 0x01) #define SDRN_PESDR_DLPSET(n) (sdr_base(n) + 0x02) @@ -198,8 +210,73 @@ #define PESDR1_LPB 0x044B #define PESDR1_PHYSTA 0x044C
+#elif defined(CONFIG_460EX) || defined(CONFIG_460GT) + +#define PESDR0_L0BIST 0x0308 /* PE0 L0 built in self test */ +#define PESDR0_L0BISTSTS 0x0309 /* PE0 L0 built in self test status */ +#define PESDR0_L0CDRCTL 0x030A /* PE0 L0 CDR control */ +#define PESDR0_L0DRV 0x030B /* PE0 L0 drive */ +#define PESDR0_L0REC 0x030C /* PE0 L0 receiver */ +#define PESDR0_L0LPB 0x030D /* PE0 L0 loopback */ +#define PESDR0_L0CLK 0x030E /* PE0 L0 clocking */ +#define PESDR0_PHY_CTL_RST 0x030F /* PE0 PHY control reset */ +#define PESDR0_RSTSTA 0x0310 /* PE0 reset status */ +#define PESDR0_OBS 0x0311 /* PE0 observation register */ +#define PESDR0_L0ERRC 0x0320 /* PE0 L0 error counter */ + +#define PESDR1_L0BIST 0x0348 /* PE1 L0 built in self test */ +#define PESDR1_L1BIST 0x0349 /* PE1 L1 built in self test */ +#define PESDR1_L2BIST 0x034A /* PE1 L2 built in self test */ +#define PESDR1_L3BIST 0x034B /* PE1 L3 built in self test */ +#define PESDR1_L0BISTSTS 0x034C /* PE1 L0 built in self test status */ +#define PESDR1_L1BISTSTS 0x034D /* PE1 L1 built in self test status */ +#define PESDR1_L2BISTSTS 0x034E /* PE1 L2 built in self test status */ +#define PESDR1_L3BISTSTS 0x034F /* PE1 L3 built in self test status */ +#define PESDR1_L0CDRCTL 0x0350 /* PE1 L0 CDR control */ +#define PESDR1_L1CDRCTL 0x0351 /* PE1 L1 CDR control */ +#define PESDR1_L2CDRCTL 0x0352 /* PE1 L2 CDR control */ +#define PESDR1_L3CDRCTL 0x0353 /* PE1 L3 CDR control */ +#define PESDR1_L0DRV 0x0354 /* PE1 L0 drive */ +#define PESDR1_L1DRV 0x0355 /* PE1 L1 drive */ +#define PESDR1_L2DRV 0x0356 /* PE1 L2 drive */ +#define PESDR1_L3DRV 0x0357 /* PE1 L3 drive */ +#define PESDR1_L0REC 0x0358 /* PE1 L0 receiver */ +#define PESDR1_L1REC 0x0359 /* PE1 L1 receiver */ +#define PESDR1_L2REC 0x035A /* PE1 L2 receiver */ +#define PESDR1_L3REC 0x035B /* PE1 L3 receiver */ +#define PESDR1_L0LPB 0x035C /* PE1 L0 loopback */ +#define PESDR1_L1LPB 0x035D /* PE1 L1 loopback */ +#define PESDR1_L2LPB 0x035E /* PE1 L2 loopback */ +#define PESDR1_L3LPB 0x035F /* PE1 L3 loopback */ +#define PESDR1_L0CLK 0x0360 /* PE1 L0 clocking */ +#define PESDR1_L1CLK 0x0361 /* PE1 L1 clocking */ +#define PESDR1_L2CLK 0x0362 /* PE1 L2 clocking */ +#define PESDR1_L3CLK 0x0363 /* PE1 L3 clocking */ +#define PESDR1_PHY_CTL_RST 0x0364 /* PE1 PHY control reset */ +#define PESDR1_RSTSTA 0x0365 /* PE1 reset status */ +#define PESDR1_OBS 0x0366 /* PE1 observation register */ +#define PESDR1_L0ERRC 0x0368 /* PE1 L0 error counter */ +#define PESDR1_L1ERRC 0x0369 /* PE1 L1 error counter */ +#define PESDR1_L2ERRC 0x036A /* PE1 L2 error counter */ +#define PESDR1_L3ERRC 0x036B /* PE1 L3 error counter */ +#define PESDR0_IHS1 0x036C /* PE interrupt handler interfact setting 1 */ +#define PESDR0_IHS2 0x036D /* PE interrupt handler interfact setting 2 */ + #endif
+/* SDR Bit Mappings */ +#define PESDRx_RCSSET_HLDPLB 0x10000000 +#define PESDRx_RCSSET_RSTGU 0x01000000 +#define PESDRx_RCSSET_RDY 0x00100000 +#define PESDRx_RCSSET_RSTDL 0x00010000 +#define PESDRx_RCSSET_RSTPYN 0x00001000 + +#define PESDRx_RCSSTS_PLBIDL 0x10000000 +#define PESDRx_RCSSTS_HRSTRQ 0x01000000 +#define PESDRx_RCSSTS_PGRST 0x00100000 +#define PESDRx_RCSSTS_VC0ACT 0x00010000 +#define PESDRx_RCSSTS_BMEN 0x00000100 + /* * UTL register offsets */ diff --git a/include/asm-ppc/ppc4xx-intvec.h b/include/asm-ppc/ppc4xx-intvec.h index 8d04b69..e218119 100644 --- a/include/asm-ppc/ppc4xx-intvec.h +++ b/include/asm-ppc/ppc4xx-intvec.h @@ -117,6 +117,73 @@ #define VECNUM_MCTR0 (64 + 8) /* MAl intp coalescence TR0 */ #define VECNUM_MCTR1 (64 + 9) /* MAl intp coalescence TR1 */
+#elif defined(CONFIG_460EX) || defined(CONFIG_460GT) + +/* UIC 0 */ +#define VECNUM_U1 1 /* UART1 */ +#define VECNUM_IIC0 2 /* IIC0 */ +#define VECNUM_IIC1 3 /* IIC1 */ +#define VECNUM_PIM 4 /* PCI inbound message */ +#define VECNUM_PCRW 5 /* PCI command reg write */ +#define VECNUM_PPM 6 /* PCI power management */ +#define VECNUM_MSI0 8 /* PCI MSI level 0 */ +#define VECNUM_EIR0 9 /* External interrupt 0 */ +#define VECNUM_UIC2NC 10 /* UIC2 non-critical interrupt */ +#define VECNUM_UIC2C 11 /* UIC2 critical interrupt */ +#define VECNUM_D0 12 /* DMA channel 0 */ +#define VECNUM_D1 13 /* DMA channel 1 */ +#define VECNUM_D2 14 /* DMA channel 2 */ +#define VECNUM_D3 15 /* DMA channel 3 */ +#define VECNUM_UIC3NC 16 /* UIC3 non-critical interrupt */ +#define VECNUM_UIC3C 17 /* UIC3 critical interrupt */ +#define VECNUM_EIR1 9 /* External interrupt 1 */ +#define VECNUM_UIC1NC 30 /* UIC1 non-critical interrupt */ +#define VECNUM_UIC1C 31 /* UIC1 critical interrupt */ + +/* UIC 1 */ +#define VECNUM_EIR2 (32 + 0) /* External interrupt 0 */ +#define VECNUM_U0 (32 + 1) /* UART0 */ +#define VECNUM_EIR3 (32 + 20) /* External interrupt 3 */ +#define VECNUM_EIR4 (32 + 21) /* External interrupt 4 */ +#define VECNUM_EIR5 (32 + 26) /* External interrupt 5 */ +#define VECNUM_EIR6 (32 + 27) /* External interrupt 6 */ +#define VECNUM_U2 (32 + 28) /* UART2 */ +#define VECNUM_U3 (32 + 29) /* UART3 */ +#define VECNUM_EIR7 (32 + 30) /* External interrupt 7 */ +#define VECNUM_EIR8 (32 + 31) /* External interrupt 8 */ + +/* UIC 2 */ +#define VECNUM_EIR9 (64 + 2) /* External interrupt 9 */ +#define VECNUM_MS (64 + 3) /* MAL SERR */ +#define VECNUM_TXDE (64 + 4) /* MAL TXDE */ +#define VECNUM_RXDE (64 + 5) /* MAL RXDE */ +#define VECNUM_MTE (64 + 6) /* MAL TXEOB */ +#define VECNUM_MRE (64 + 7) /* MAL RXEOB */ +#define VECNUM_ETH0 (64 + 16) /* Ethernet 0 */ +#define VECNUM_ETH1 (64 + 17) /* Ethernet 1 */ +#define VECNUM_ETH2 (64 + 18) /* Ethernet 2 */ +#define VECNUM_ETH3 (64 + 19) /* Ethernet 3 */ +#define VECNUM_EWU0 (64 + 20) /* Emac 0 wakeup */ +#define VECNUM_EWU1 (64 + 21) /* Emac 1 wakeup */ +#define VECNUM_EWU2 (64 + 22) /* Emac 2 wakeup */ +#define VECNUM_EWU3 (64 + 23) /* Emac 3 wakeup */ +#define VECNUM_EIR10 (64 + 24) /* External interrupt 10 */ +#define VECNUM_EIR11 (64 + 25) /* External interrupt 11 */ + +/* UIC 3 */ +#define VECNUM_EIR12 (96 + 20) /* External interrupt 20 */ +#define VECNUM_EIR13 (96 + 21) /* External interrupt 21 */ +#define VECNUM_EIR14 (96 + 22) /* External interrupt 22 */ +#define VECNUM_EIR15 (96 + 23) /* External interrupt 23 */ +#define VECNUM_PCIEMSI0 (96 + 24) /* PCI Express MSI level 0 */ +#define VECNUM_PCIEMSI1 (96 + 25) /* PCI Express MSI level 1 */ +#define VECNUM_PCIEMSI2 (96 + 26) /* PCI Express MSI level 2 */ +#define VECNUM_PCIEMSI3 (96 + 27) /* PCI Express MSI level 3 */ +#define VECNUM_PCIEMSI4 (96 + 28) /* PCI Express MSI level 4 */ +#define VECNUM_PCIEMSI5 (96 + 29) /* PCI Express MSI level 5 */ +#define VECNUM_PCIEMSI6 (96 + 30) /* PCI Express MSI level 6 */ +#define VECNUM_PCIEMSI7 (96 + 31) /* PCI Express MSI level 7 */ + #elif defined(CONFIG_440SPE)
/* UIC 0 */ @@ -130,10 +197,14 @@ #define VECNUM_MSI0 7 /* PCI MSI level 0 */ #define VECNUM_MSI1 8 /* PCI MSI level 0 */ #define VECNUM_MSI2 9 /* PCI MSI level 0 */ +#define VECNUM_UIC2NC 10 /* UIC2 non-critical interrupt */ +#define VECNUM_UIC2C 11 /* UIC2 critical interrupt */ #define VECNUM_D0 12 /* DMA channel 0 */ #define VECNUM_D1 13 /* DMA channel 1 */ #define VECNUM_D2 14 /* DMA channel 2 */ #define VECNUM_D3 15 /* DMA channel 3 */ +#define VECNUM_UIC3NC 16 /* UIC3 non-critical interrupt */ +#define VECNUM_UIC3C 17 /* UIC3 critical interrupt */ #define VECNUM_UIC1NC 30 /* UIC1 non-critical interrupt */ #define VECNUM_UIC1C 31 /* UIC1 critical interrupt */
diff --git a/include/asm-ppc/processor.h b/include/asm-ppc/processor.h index 86c5df2..b7a5b28 100644 --- a/include/asm-ppc/processor.h +++ b/include/asm-ppc/processor.h @@ -802,6 +802,10 @@ #define PVR_440SPe_RA 0x53521890 /* 440SPe rev A without RAID 6 support */ #define PVR_440SPe_6_RB 0x53421891 /* 440SPe rev B with RAID 6 support enabled */ #define PVR_440SPe_RB 0x53521891 /* 440SPe rev B without RAID 6 support */ +#define PVR_460EX_SE_RA 0x130218A2 /* 460EX rev A with Security Engine */ +#define PVR_460EX_RA 0x130218A3 /* 460EX rev A without Security Engine */ +#define PVR_460GT_SE_RA 0x130218A0 /* 460GT rev A with Security Engine */ +#define PVR_460GT_RA 0x130218A1 /* 460GT rev A without Security Engine */ #define PVR_601 0x00010000 #define PVR_602 0x00050000 #define PVR_603 0x00030000 diff --git a/include/asm-ppc/u-boot.h b/include/asm-ppc/u-boot.h index 2b31814..786ba03 100644 --- a/include/asm-ppc/u-boot.h +++ b/include/asm-ppc/u-boot.h @@ -115,7 +115,8 @@ typedef struct bd_info { #if defined(CONFIG_405GP) || defined(CONFIG_405EP) || \ defined(CONFIG_405EZ) || defined(CONFIG_440GX) || \ defined(CONFIG_440EP) || defined(CONFIG_440GR) || \ - defined(CONFIG_440EPX) || defined(CONFIG_440GRX) + defined(CONFIG_440EPX) || defined(CONFIG_440GRX) || \ + defined(CONFIG_460EX) || defined(CONFIG_460GT) unsigned int bi_opbfreq; /* OPB clock in Hz */ int bi_iic_fast[2]; /* Use fast i2c mode */ #endif @@ -123,7 +124,8 @@ typedef struct bd_info { unsigned char bi_sernum[8]; #endif #if defined(CONFIG_4xx) -#if defined(CONFIG_440GX) +#if defined(CONFIG_440GX) || \ + defined(CONFIG_460EX) || defined(CONFIG_460GT) int bi_phynum[4]; /* Determines phy mapping */ int bi_phymode[4]; /* Determines phy mode */ #elif defined(CONFIG_405EP) || defined(CONFIG_440)
Signed-off-by: Stefan Roese sr@denx.de #define PVR_601 0x00010000 #define PVR_602 0x00050000 #define PVR_603 0x00030000 diff --git a/include/asm-ppc/u-boot.h b/include/asm-ppc/u-boot.h index 2b31814..786ba03 100644 --- a/include/asm-ppc/u-boot.h +++ b/include/asm-ppc/u-boot.h @@ -115,7 +115,8 @@ typedef struct bd_info { #if defined(CONFIG_405GP) || defined(CONFIG_405EP) || \ defined(CONFIG_405EZ) || defined(CONFIG_440GX) || \ defined(CONFIG_440EP) || defined(CONFIG_440GR) || \
- defined(CONFIG_460EX) || defined(CONFIG_460GT) unsigned int bi_opbfreq; /* OPB clock in Hz */ int bi_iic_fast[2]; /* Use fast i2c mode */
- defined(CONFIG_460EX) || defined(CONFIG_460GT) int bi_phynum[4]; /* Determines phy mapping */
^ Could you remove the whitespaces btw
Best Regards, J.
<snip>
Will do.
Thanks.
Best regards, Stefan
Signed-off-by: Stefan Roese sr@denx.de --- include/common.h | 4 +++- include/ppc405.h | 23 +++++++++++++++++++---- include/ppc4xx_enet.h | 18 +++++++++++------- 3 files changed, 33 insertions(+), 12 deletions(-)
diff --git a/include/common.h b/include/common.h index cd8aad0..673afdd 100644 --- a/include/common.h +++ b/include/common.h @@ -273,7 +273,9 @@ void pciinfo (int, int); void pci_master_init (struct pci_controller *); # endif int is_pci_host (struct pci_controller *); -#if defined(CONFIG_440SPE) || defined(CONFIG_405EX) +#if defined(CONFIG_440SPE) || \ + defined(CONFIG_460EX) || defined(CONFIG_460GT) || \ + defined(CONFIG_405EX) void pcie_setup_hoses(int busno); #endif #endif diff --git a/include/ppc405.h b/include/ppc405.h index cbfe89e..37b121c 100644 --- a/include/ppc405.h +++ b/include/ppc405.h @@ -118,7 +118,17 @@ /****************************************************************************** * Universal interrupt controller ******************************************************************************/ +#define UIC_SR 0x0 /* UIC status */ +#define UIC_ER 0x2 /* UIC enable */ +#define UIC_CR 0x3 /* UIC critical */ +#define UIC_PR 0x4 /* UIC polarity */ +#define UIC_TR 0x5 /* UIC triggering */ +#define UIC_MSR 0x6 /* UIC masked status */ +#define UIC_VR 0x7 /* UIC vector */ +#define UIC_VCR 0x8 /* UIC vector configuration */ + #define UIC_DCR_BASE 0xc0 +#define UIC0_DCR_BASE UIC_DCR_BASE #define uicsr (UIC_DCR_BASE+0x0) /* UIC status */ #define uicsrs (UIC_DCR_BASE+0x1) /* UIC status set */ #define uicer (UIC_DCR_BASE+0x2) /* UIC enable */ @@ -141,6 +151,7 @@ #define uic0vcr uicvcr /* UIC vector configuration*/
#define UIC_DCR_BASE1 0xd0 +#define UIC1_DCR_BASE 0xd0 #define uic1sr (UIC_DCR_BASE1+0x0) /* UIC status */ #define uic1srs (UIC_DCR_BASE1+0x1) /* UIC status set */ #define uic1er (UIC_DCR_BASE1+0x2) /* UIC enable */ @@ -152,6 +163,7 @@ #define uic1vcr (UIC_DCR_BASE1+0x8) /* UIC vector configuration*/
#define UIC_DCR_BASE2 0xe0 +#define UIC2_DCR_BASE 0xe0 #define uic2sr (UIC_DCR_BASE2+0x0) /* UIC status */ #define uic2srs (UIC_DCR_BASE2+0x1) /* UIC status set */ #define uic2er (UIC_DCR_BASE2+0x2) /* UIC enable */ @@ -237,10 +249,13 @@ #define UIC_ENET1 0x00000040 /* */ #define UIC_PCIEMSI2 0x00000020 /* */ #define UIC_EIRQ4 0x00000010 /**/ -#define UIC_UIC2NC 0x00000008 /* */ -#define UIC_UIC2C 0x00000004 /* */ -#define UIC_UIC1NC 0x00000002 /* */ -#define UIC_UIC1C 0x00000001 /* */ +#define UICB0_UIC2NCI 0x00000008 /* */ +#define UICB0_UIC2CI 0x00000004 /* */ +#define UICB0_UIC1NCI 0x00000002 /* */ +#define UICB0_UIC1CI 0x00000001 /* */ + +#define UICB0_ALL (UICB0_UIC1CI | UICB0_UIC1NCI | \ + UICB0_UIC1CI | UICB0_UIC2NCI)
#define UIC_MAL_TXEOB UIC_MTE/* MAL TXEOB */ #define UIC_MAL_RXEOB UIC_MRE/* MAL RXEOB */ diff --git a/include/ppc4xx_enet.h b/include/ppc4xx_enet.h index 317604a..0208454 100644 --- a/include/ppc4xx_enet.h +++ b/include/ppc4xx_enet.h @@ -131,7 +131,7 @@ typedef struct emac_4xx_hw_st { } EMAC_4XX_HW_ST, *EMAC_4XX_HW_PST;
-#if defined(CONFIG_440GX) +#if defined(CONFIG_440GX) || defined(CONFIG_460GT) #define EMAC_NUM_DEV 4 #elif (defined(CONFIG_440) || defined(CONFIG_405EP)) && \ defined(CONFIG_NET_MULTI) && \ @@ -155,7 +155,8 @@ typedef struct emac_4xx_hw_st {
/* ZMII Bridge Register addresses */ #if defined(CONFIG_440EP) || defined(CONFIG_440GR) || \ - defined(CONFIG_440EPX) || defined(CONFIG_440GRX) + defined(CONFIG_440EPX) || defined(CONFIG_440GRX) || \ + defined(CONFIG_460EX) || defined(CONFIG_460GT) #define ZMII_BASE (CFG_PERIPHERAL_BASE + 0x0D00) #else #define ZMII_BASE (CFG_PERIPHERAL_BASE + 0x0780) @@ -164,9 +165,6 @@ typedef struct emac_4xx_hw_st { #define ZMII_SSR (ZMII_BASE + 4) #define ZMII_SMIISR (ZMII_BASE + 8)
-#define ZMII_RMII 0x22000000 -#define ZMII_MDI0 0x80000000 - /* ZMII FER Register Bit Definitions */ #define ZMII_FER_DIS (0x0) #define ZMII_FER_MDI (0x8) @@ -205,6 +203,8 @@ typedef struct emac_4xx_hw_st { /* RGMII Register Addresses */ #if defined(CONFIG_440EPX) || defined(CONFIG_440GRX) #define RGMII_BASE (CFG_PERIPHERAL_BASE + 0x1000) +#elif defined(CONFIG_460EX) || defined(CONFIG_460GT) +#define RGMII_BASE (CFG_PERIPHERAL_BASE + 0x1500) #elif defined(CONFIG_405EX) #define RGMII_BASE (CFG_PERIPHERAL_BASE + 0xB00) #else @@ -223,19 +223,21 @@ typedef struct emac_4xx_hw_st {
#define RGMII_FER_V(__x) ((__x - 2) * 4)
+#define RGMII_FER_MDIO(__x) (1 << (19 - (__x))) + /* RGMII Speed Selection Register Bit Definitions */ #define RGMII_SSR_SP_10MBPS (0x00) #define RGMII_SSR_SP_100MBPS (0x02) #define RGMII_SSR_SP_1000MBPS (0x04)
#if defined(CONFIG_440EPX) || defined(CONFIG_440GRX) || \ + defined(CONFIG_460EX) || defined(CONFIG_460GT) || \ defined(CONFIG_405EX) #define RGMII_SSR_V(__x) ((__x) * 8) #else #define RGMII_SSR_V(__x) ((__x -2) * 8) #endif
- /*---------------------------------------------------------------------------+ | TCP/IP Acceleration Hardware (TAH) 440GX Only +---------------------------------------------------------------------------*/ @@ -304,7 +306,8 @@ typedef struct emac_4xx_hw_st { /* Ethernet MAC Regsiter Addresses */ #if defined(CONFIG_440) #if defined(CONFIG_440EP) || defined(CONFIG_440GR) || \ - defined(CONFIG_440EPX) || defined(CONFIG_440GRX) + defined(CONFIG_440EPX) || defined(CONFIG_440GRX) || \ + defined(CONFIG_460EX) || defined(CONFIG_460GT) #define EMAC_BASE (CFG_PERIPHERAL_BASE + 0x0E00) #else #define EMAC_BASE (CFG_PERIPHERAL_BASE + 0x0800) @@ -345,6 +348,7 @@ typedef struct emac_4xx_hw_st { #if defined(CONFIG_440GX) || \ defined(CONFIG_440EPX) || defined(CONFIG_440GRX) || \ defined(CONFIG_440SP) || defined(CONFIG_440SPE) || \ + defined(CONFIG_460EX) || defined(CONFIG_460GT) || \ defined(CONFIG_405EX) /* MODE Reg 1 */ #define EMAC_M1_FDE (0x80000000)
This patch adds basic support for the AMCC 460EX/460GT PPC's.
Signed-off-by: Stefan Roese sr@denx.de -#define UIC_UIC1C 0x00000001 /* */ +#define UICB0_UIC2NCI 0x00000008 /* */ +#define UICB0_UIC2CI 0x00000004 /* */ +#define UICB0_UIC1NCI 0x00000002 /* */ +#define UICB0_UIC1CI 0x00000001 /* */
^ Could you remove the whitespace btw
This is not part of the original patch. I'll try to come up with an additional patch to fix this.
Signed-off-by: Stefan Roese sr@denx.de --- include/ppc440.h | 590 ++++++++++++++++++++++++++++++++++++++++++++++-------- 1 files changed, 502 insertions(+), 88 deletions(-)
diff --git a/include/ppc440.h b/include/ppc440.h index 907744b..cf29fe7 100644 --- a/include/ppc440.h +++ b/include/ppc440.h @@ -380,7 +380,8 @@ #define SDR0_PEGPLLSTS 0x000003A2 /* PE Pll LC Tank Status */ #endif /* CONFIG_440SPE */
-#if defined(CONFIG_440SP) || defined(CONFIG_440SPE) +#if defined(CONFIG_440SP) || defined(CONFIG_440SPE) || \ + defined(CONFIG_460EX) || defined(CONFIG_460GT) /*----------------------------------------------------------------------------+ | SDRAM Controller +----------------------------------------------------------------------------*/ @@ -416,7 +417,8 @@ /*-----------------------------------------------------------------------------+ | Memory Bank 0-7 configuration +-----------------------------------------------------------------------------*/ -#if defined(CONFIG_440SPE) +#if defined(CONFIG_440SPE) || \ + defined(CONFIG_460EX) || defined(CONFIG_460GT) #define SDRAM_RXBAS_SDBA_MASK 0xFFE00000 /* Base address */ #define SDRAM_RXBAS_SDBA_ENCODE(n) ((((unsigned long)(n))&0xFFE00000)>>2) #define SDRAM_RXBAS_SDBA_DECODE(n) ((((unsigned long)(n))&0xFFE00000)<<2) @@ -692,6 +694,7 @@ #define SDRAM_CLKTR_CLKP_0_DEG 0x00000000 #define SDRAM_CLKTR_CLKP_180_DEG_ADV 0x80000000 #define SDRAM_CLKTR_CLKP_90_DEG_ADV 0x40000000 +#define SDRAM_CLKTR_CLKP_270_DEG_ADV 0xC0000000
/*-----------------------------------------------------------------------------+ | SDRAM Write Timing Register @@ -1577,49 +1580,6 @@
#endif /* defined(CONFIG_440EPX) || defined(CONFIG_440GRX) */
-/* CUST0 Customer Configuration Register0 */ -#define SDR0_CUST0 0x4000 -#define SDR0_CUST0_MUX_E_N_G_MASK 0xC0000000 /* Mux_Emac_NDFC_GPIO */ -#define SDR0_CUST0_MUX_EMAC_SEL 0x40000000 /* Emac Selection */ -#define SDR0_CUST0_MUX_NDFC_SEL 0x80000000 /* NDFC Selection */ -#define SDR0_CUST0_MUX_GPIO_SEL 0xC0000000 /* GPIO Selection */ - -#define SDR0_CUST0_NDFC_EN_MASK 0x20000000 /* NDFC Enable Mask */ -#define SDR0_CUST0_NDFC_ENABLE 0x20000000 /* NDFC Enable */ -#define SDR0_CUST0_NDFC_DISABLE 0x00000000 /* NDFC Disable */ - -#define SDR0_CUST0_NDFC_BW_MASK 0x10000000 /* NDFC Boot Width */ -#define SDR0_CUST0_NDFC_BW_16_BIT 0x10000000 /* NDFC Boot Width = 16 Bit */ -#define SDR0_CUST0_NDFC_BW_8_BIT 0x00000000 /* NDFC Boot Width = 8 Bit */ - -#define SDR0_CUST0_NDFC_BP_MASK 0x0F000000 /* NDFC Boot Page */ -#define SDR0_CUST0_NDFC_BP_ENCODE(n) ((((unsigned long)(n))&0xF)<<24) -#define SDR0_CUST0_NDFC_BP_DECODE(n) ((((unsigned long)(n))>>24)&0x0F) - -#define SDR0_CUST0_NDFC_BAC_MASK 0x00C00000 /* NDFC Boot Address Cycle */ -#define SDR0_CUST0_NDFC_BAC_ENCODE(n) ((((unsigned long)(n))&0x3)<<22) -#define SDR0_CUST0_NDFC_BAC_DECODE(n) ((((unsigned long)(n))>>22)&0x03) - -#define SDR0_CUST0_NDFC_ARE_MASK 0x00200000 /* NDFC Auto Read Enable */ -#define SDR0_CUST0_NDFC_ARE_ENABLE 0x00200000 /* NDFC Auto Read Enable */ -#define SDR0_CUST0_NDFC_ARE_DISABLE 0x00000000 /* NDFC Auto Read Disable */ - -#define SDR0_CUST0_NRB_MASK 0x00100000 /* NDFC Ready / Busy */ -#define SDR0_CUST0_NRB_BUSY 0x00100000 /* Busy */ -#define SDR0_CUST0_NRB_READY 0x00000000 /* Ready */ - -#define SDR0_CUST0_NDRSC_MASK 0x0000FFF0 /* NDFC Device Reset Count Mask */ -#define SDR0_CUST0_NDRSC_ENCODE(n) ((((unsigned long)(n))&0xFFF)<<4) -#define SDR0_CUST0_NDRSC_DECODE(n) ((((unsigned long)(n))>>4)&0xFFF) - -#define SDR0_CUST0_CHIPSELGAT_MASK 0x0000000F /* Chip Select Gating Mask */ -#define SDR0_CUST0_CHIPSELGAT_DIS 0x00000000 /* Chip Select Gating Disable */ -#define SDR0_CUST0_CHIPSELGAT_ENALL 0x0000000F /* All Chip Select Gating Enable */ -#define SDR0_CUST0_CHIPSELGAT_EN0 0x00000008 /* Chip Select0 Gating Enable */ -#define SDR0_CUST0_CHIPSELGAT_EN1 0x00000004 /* Chip Select1 Gating Enable */ -#define SDR0_CUST0_CHIPSELGAT_EN2 0x00000002 /* Chip Select2 Gating Enable */ -#define SDR0_CUST0_CHIPSELGAT_EN3 0x00000001 /* Chip Select3 Gating Enable */ - /* CUST1 Customer Configuration Register1 */ #define SDR0_CUST1 0x4002 #define SDR0_CUST1_NDRSC_MASK 0xFFFF0000 /* NDRSC Device Read Count */ @@ -1666,25 +1626,34 @@ #define SDR0_PFC1_PLB_PME_PLB4_SEL 0x00001000 /* PLB3 Performance Monitor Enable */ #define SDR0_PFC1_GFGGI_MASK 0x0000000F /* GPT Frequency Generation Gated In */
+#endif /* 440EP || 440GR || 440EPX || 440GRX */ + /*----------------------------------------------------------------------------- - | Internal SRAM + | L2 Cache +----------------------------------------------------------------------------*/ -#define ISRAM0_DCR_BASE 0x380 -#define isram0_sb0cr (ISRAM0_DCR_BASE+0x00) /* SRAM bank config 0*/ -#define isram0_bear (ISRAM0_DCR_BASE+0x04) /* SRAM bus error addr reg */ -#define isram0_besr0 (ISRAM0_DCR_BASE+0x05) /* SRAM bus error status reg 0 */ -#define isram0_besr1 (ISRAM0_DCR_BASE+0x06) /* SRAM bus error status reg 1 */ -#define isram0_pmeg (ISRAM0_DCR_BASE+0x07) /* SRAM power management */ -#define isram0_cid (ISRAM0_DCR_BASE+0x08) /* SRAM bus core id reg */ -#define isram0_revid (ISRAM0_DCR_BASE+0x09) /* SRAM bus revision id reg */ -#define isram0_dpc (ISRAM0_DCR_BASE+0x0a) /* SRAM data parity check reg */ +#if defined (CONFIG_440GX) || \ + defined(CONFIG_440SP) || defined(CONFIG_440SPE) || \ + defined(CONFIG_460EX) || defined(CONFIG_460GT) +#define L2_CACHE_BASE 0x030 +#define l2_cache_cfg (L2_CACHE_BASE+0x00) /* L2 Cache Config */ +#define l2_cache_cmd (L2_CACHE_BASE+0x01) /* L2 Cache Command */ +#define l2_cache_addr (L2_CACHE_BASE+0x02) /* L2 Cache Address */ +#define l2_cache_data (L2_CACHE_BASE+0x03) /* L2 Cache Data */ +#define l2_cache_stat (L2_CACHE_BASE+0x04) /* L2 Cache Status */ +#define l2_cache_cver (L2_CACHE_BASE+0x05) /* L2 Cache Revision ID */ +#define l2_cache_snp0 (L2_CACHE_BASE+0x06) /* L2 Cache Snoop reg 0 */ +#define l2_cache_snp1 (L2_CACHE_BASE+0x07) /* L2 Cache Snoop reg 1 */
-#else +#endif /* CONFIG_440GX */
/*----------------------------------------------------------------------------- | Internal SRAM +----------------------------------------------------------------------------*/ +#if defined(CONFIG_440EPX) || defined(CONFIG_440GRX) +#define ISRAM0_DCR_BASE 0x380 +#else #define ISRAM0_DCR_BASE 0x020 +#endif #define isram0_sb0cr (ISRAM0_DCR_BASE+0x00) /* SRAM bank config 0*/ #define isram0_sb1cr (ISRAM0_DCR_BASE+0x01) /* SRAM bank config 1*/ #define isram0_sb2cr (ISRAM0_DCR_BASE+0x02) /* SRAM bank config 2*/ @@ -1697,22 +1666,52 @@ #define isram0_revid (ISRAM0_DCR_BASE+0x09) /* SRAM bus revision id reg */ #define isram0_dpc (ISRAM0_DCR_BASE+0x0a) /* SRAM data parity check reg */
-/*----------------------------------------------------------------------------- - | L2 Cache - +----------------------------------------------------------------------------*/ -#if defined (CONFIG_440GX) || defined(CONFIG_440SP) || defined(CONFIG_440SPE) -#define L2_CACHE_BASE 0x030 -#define l2_cache_cfg (L2_CACHE_BASE+0x00) /* L2 Cache Config */ -#define l2_cache_cmd (L2_CACHE_BASE+0x01) /* L2 Cache Command */ -#define l2_cache_addr (L2_CACHE_BASE+0x02) /* L2 Cache Address */ -#define l2_cache_data (L2_CACHE_BASE+0x03) /* L2 Cache Data */ -#define l2_cache_stat (L2_CACHE_BASE+0x04) /* L2 Cache Status */ -#define l2_cache_cver (L2_CACHE_BASE+0x05) /* L2 Cache Revision ID */ -#define l2_cache_snp0 (L2_CACHE_BASE+0x06) /* L2 Cache Snoop reg 0 */ -#define l2_cache_snp1 (L2_CACHE_BASE+0x07) /* L2 Cache Snoop reg 1 */ +#if defined(CONFIG_440EP) || defined(CONFIG_440GR) || \ + defined(CONFIG_440EPX) || defined(CONFIG_440GRX) || \ + defined(CONFIG_460EX) || defined(CONFIG_460GT) +/* CUST0 Customer Configuration Register0 */ +#define SDR0_CUST0 0x4000 +#define SDR0_CUST0_MUX_E_N_G_MASK 0xC0000000 /* Mux_Emac_NDFC_GPIO */ +#define SDR0_CUST0_MUX_EMAC_SEL 0x40000000 /* Emac Selection */ +#define SDR0_CUST0_MUX_NDFC_SEL 0x80000000 /* NDFC Selection */ +#define SDR0_CUST0_MUX_GPIO_SEL 0xC0000000 /* GPIO Selection */
-#endif /* CONFIG_440GX */ -#endif /* !CONFIG_440EP !CONFIG_440GR*/ +#define SDR0_CUST0_NDFC_EN_MASK 0x20000000 /* NDFC Enable Mask */ +#define SDR0_CUST0_NDFC_ENABLE 0x20000000 /* NDFC Enable */ +#define SDR0_CUST0_NDFC_DISABLE 0x00000000 /* NDFC Disable */ + +#define SDR0_CUST0_NDFC_BW_MASK 0x10000000 /* NDFC Boot Width */ +#define SDR0_CUST0_NDFC_BW_16_BIT 0x10000000 /* NDFC Boot Width = 16 Bit */ +#define SDR0_CUST0_NDFC_BW_8_BIT 0x00000000 /* NDFC Boot Width = 8 Bit */ + +#define SDR0_CUST0_NDFC_BP_MASK 0x0F000000 /* NDFC Boot Page */ +#define SDR0_CUST0_NDFC_BP_ENCODE(n) ((((unsigned long)(n))&0xF)<<24) +#define SDR0_CUST0_NDFC_BP_DECODE(n) ((((unsigned long)(n))>>24)&0x0F) + +#define SDR0_CUST0_NDFC_BAC_MASK 0x00C00000 /* NDFC Boot Address Cycle */ +#define SDR0_CUST0_NDFC_BAC_ENCODE(n) ((((unsigned long)(n))&0x3)<<22) +#define SDR0_CUST0_NDFC_BAC_DECODE(n) ((((unsigned long)(n))>>22)&0x03) + +#define SDR0_CUST0_NDFC_ARE_MASK 0x00200000 /* NDFC Auto Read Enable */ +#define SDR0_CUST0_NDFC_ARE_ENABLE 0x00200000 /* NDFC Auto Read Enable */ +#define SDR0_CUST0_NDFC_ARE_DISABLE 0x00000000 /* NDFC Auto Read Disable */ + +#define SDR0_CUST0_NRB_MASK 0x00100000 /* NDFC Ready / Busy */ +#define SDR0_CUST0_NRB_BUSY 0x00100000 /* Busy */ +#define SDR0_CUST0_NRB_READY 0x00000000 /* Ready */ + +#define SDR0_CUST0_NDRSC_MASK 0x0000FFF0 /* NDFC Device Reset Count Mask */ +#define SDR0_CUST0_NDRSC_ENCODE(n) ((((unsigned long)(n))&0xFFF)<<4) +#define SDR0_CUST0_NDRSC_DECODE(n) ((((unsigned long)(n))>>4)&0xFFF) + +#define SDR0_CUST0_CHIPSELGAT_MASK 0x0000000F /* Chip Select Gating Mask */ +#define SDR0_CUST0_CHIPSELGAT_DIS 0x00000000 /* Chip Select Gating Disable */ +#define SDR0_CUST0_CHIPSELGAT_ENALL 0x0000000F /* All Chip Select Gating Enable */ +#define SDR0_CUST0_CHIPSELGAT_EN0 0x00000008 /* Chip Select0 Gating Enable */ +#define SDR0_CUST0_CHIPSELGAT_EN1 0x00000004 /* Chip Select1 Gating Enable */ +#define SDR0_CUST0_CHIPSELGAT_EN2 0x00000002 /* Chip Select2 Gating Enable */ +#define SDR0_CUST0_CHIPSELGAT_EN3 0x00000001 /* Chip Select3 Gating Enable */ +#endif
/*----------------------------------------------------------------------------- | On-Chip Buses @@ -1722,8 +1721,14 @@ /*----------------------------------------------------------------------------- | Clocking, Power Management and Chip Control +----------------------------------------------------------------------------*/ +#if defined(CONFIG_460EX) || defined(CONFIG_460GT) +#define CNTRL_DCR_BASE 0x160 +#else #define CNTRL_DCR_BASE 0x0b0 -#if defined(CONFIG_440GX) || defined(CONFIG_440SP) || defined(CONFIG_440SPE) +#endif +#if defined(CONFIG_440GX) || \ + defined(CONFIG_440SP) || defined(CONFIG_440SPE) || \ + defined(CONFIG_460EX) || defined(CONFIG_460GT) #define cpc0_er (CNTRL_DCR_BASE+0x00) /* CPM enable register */ #define cpc0_fr (CNTRL_DCR_BASE+0x01) /* CPM force register */ #define cpc0_sr (CNTRL_DCR_BASE+0x02) /* CPM status register */ @@ -1751,6 +1756,15 @@ /*----------------------------------------------------------------------------- | Universal interrupt controller +----------------------------------------------------------------------------*/ +#define UIC_SR 0x0 /* UIC status */ +#define UIC_ER 0x2 /* UIC enable */ +#define UIC_CR 0x3 /* UIC critical */ +#define UIC_PR 0x4 /* UIC polarity */ +#define UIC_TR 0x5 /* UIC triggering */ +#define UIC_MSR 0x6 /* UIC masked status */ +#define UIC_VR 0x7 /* UIC vector */ +#define UIC_VCR 0x8 /* UIC vector configuration */ + #define UIC0_DCR_BASE 0xc0 #define uic0sr (UIC0_DCR_BASE+0x0) /* UIC0 status */ #define uic0er (UIC0_DCR_BASE+0x2) /* UIC0 enable */ @@ -1771,7 +1785,9 @@ #define uic1vr (UIC1_DCR_BASE+0x7) /* UIC1 vector */ #define uic1vcr (UIC1_DCR_BASE+0x8) /* UIC1 vector configuration */
-#if defined(CONFIG_440SPE) || defined(CONFIG_440EPX) || defined(CONFIG_440GRX) +#if defined(CONFIG_440SPE) || \ + defined(CONFIG_440EPX) || defined(CONFIG_440GRX) || \ + defined(CONFIG_460EX) || defined(CONFIG_460GT) #define UIC2_DCR_BASE 0xe0 #define uic2sr (UIC2_DCR_BASE+0x0) /* UIC2 status-Read Clear */ #define uic2srs (UIC2_DCR_BASE+0x1) /* UIC2 status-Read Set */ @@ -1927,7 +1943,11 @@ /*----------------------------------------------------------------------------- | DMA +----------------------------------------------------------------------------*/ +#if defined(CONFIG_460EX) || defined(CONFIG_460GT) +#define DMA_DCR_BASE 0x200 +#else #define DMA_DCR_BASE 0x100 +#endif #define dmacr0 (DMA_DCR_BASE+0x00) /* DMA channel control register 0 */ #define dmact0 (DMA_DCR_BASE+0x01) /* DMA count register 0 */ #define dmasah0 (DMA_DCR_BASE+0x02) /* DMA source address high 0 */ @@ -1991,15 +2011,16 @@ #define maltxctp3r (MAL_DCR_BASE+0x23) /* TX 3 Channel table pointer reg */ #define malrxctp0r (MAL_DCR_BASE+0x40) /* RX 0 Channel table pointer reg */ #define malrxctp1r (MAL_DCR_BASE+0x41) /* RX 1 Channel table pointer reg */ -#if defined(CONFIG_440GX) -#define malrxctp2r (MAL_DCR_BASE+0x42) /* RX 2 Channel table pointer reg */ -#define malrxctp3r (MAL_DCR_BASE+0x43) /* RX 3 Channel table pointer reg */ -#endif /* CONFIG_440GX */ #define malrcbs0 (MAL_DCR_BASE+0x60) /* RX 0 Channel buffer size reg */ #define malrcbs1 (MAL_DCR_BASE+0x61) /* RX 1 Channel buffer size reg */ -#if defined(CONFIG_440GX) +#if defined(CONFIG_440GX) || \ + defined(CONFIG_460EX) || defined(CONFIG_460GT) +#define malrxctp2r (MAL_DCR_BASE+0x42) /* RX 2 Channel table pointer reg */ +#define malrxctp3r (MAL_DCR_BASE+0x43) /* RX 3 Channel table pointer reg */ +#define malrxctp8r (MAL_DCR_BASE+0x48) /* RX 8 Channel table pointer reg */ #define malrcbs2 (MAL_DCR_BASE+0x62) /* RX 2 Channel buffer size reg */ #define malrcbs3 (MAL_DCR_BASE+0x63) /* RX 3 Channel buffer size reg */ +#define malrcbs8 (MAL_DCR_BASE+0x68) /* RX 8 Channel buffer size reg */ #endif /* CONFIG_440GX */
@@ -2112,6 +2133,41 @@ #define UIC_MAL_TXEOB UIC_MTE #define UIC_MAL_RXEOB UIC_MRE
+#elif defined(CONFIG_460EX) || defined(CONFIG_460GT) + +#define UIC_RSVD0 0x80000000 /* N/A - unused */ +#define UIC_U1 0x40000000 /* UART 1 */ +#define UIC_IIC0 0x20000000 /* IIC */ +#define UIC_IIC1 0x10000000 /* IIC */ +#define UIC_PIM 0x08000000 /* PCI inbound message */ +#define UIC_PCRW 0x04000000 /* PCI command register write */ +#define UIC_PPM 0x02000000 /* PCI power management */ +#define UIC_PCIVPD 0x01000000 /* PCI VPD */ +#define UIC_MSI0 0x00800000 /* PCI MSI level 0 */ +#define UIC_EIR0 0x00400000 /* External interrupt 0 */ +#define UIC_UIC2NC 0x00200000 /* UIC2 non-critical interrupt */ +#define UIC_UIC2C 0x00100000 /* UIC2 critical interrupt */ +#define UIC_D0 0x00080000 /* DMA channel 0 */ +#define UIC_D1 0x00040000 /* DMA channel 1 */ +#define UIC_D2 0x00020000 /* DMA channel 2 */ +#define UIC_D3 0x00010000 /* DMA channel 3 */ +#define UIC_UIC3NC 0x00008000 /* UIC3 non-critical interrupt */ +#define UIC_UIC3C 0x00004000 /* UIC3 critical interrupt */ +#define UIC_EIR1 0x00002000 /* External interrupt 1 */ +#define UIC_TRNGDA 0x00001000 /* TRNG data available */ +#define UIC_PKAR1 0x00000800 /* PKA ready (PKA[1]) */ +#define UIC_D1CPFF 0x00000400 /* DMA1 cp fifo full */ +#define UIC_D1CSNS 0x00000200 /* DMA1 cs fifo needs service */ +#define UIC_I2OID 0x00000100 /* I2O inbound door bell */ +#define UIC_I2OLNE 0x00000080 /* I2O Inbound Post List FIFO Not Empty */ +#define UIC_I20R0LL 0x00000040 /* I2O Region 0 Low Latency PLB Write */ +#define UIC_I2OR1LL 0x00000020 /* I2O Region 1 Low Latency PLB Write */ +#define UIC_I20R0HB 0x00000010 /* I2O Region 0 High Bandwidth PLB Write */ +#define UIC_I2OR1HB 0x00000008 /* I2O Region 1 High Bandwidth PLB Write */ +#define UIC_EIP94 0x00000004 /* Security EIP94 */ +#define UIC_UIC1NC 0x00000002 /* UIC1 non-critical interrupt */ +#define UIC_UIC1C 0x00000001 /* UIC1 critical interrupt */ + #elif !defined(CONFIG_440SPE) #define UIC_U0 0x80000000 /* UART 0 */ #define UIC_U1 0x40000000 /* UART 1 */ @@ -2221,6 +2277,41 @@ #define UIC_ETH1 0x00000002 /* Ethernet 1 */ #define UIC_EWU1 0x00000001 /* Ethernet 1 wakeup */
+#elif defined(CONFIG_460EX) || defined(CONFIG_460GT) + +#define UIC_EIR2 0x80000000 /* External interrupt 2 */ +#define UIC_U0 0x40000000 /* UART 0 */ +#define UIC_SPI 0x20000000 /* SPI */ +#define UIC_TRNGAL 0x10000000 /* TRNG alarm */ +#define UIC_DEUE 0x08000000 /* DDR SDRAM ECC correct/uncorrectable error */ +#define UIC_EBCO 0x04000000 /* EBCO interrupt status */ +#define UIC_NDFC 0x02000000 /* NDFC */ +#define UIC_EIPPKPSE 0x01000000 /* EIPPKP slave error */ +#define UIC_P0MSI1 0x00800000 /* PCI0 MSI level 1 */ +#define UIC_P0MSI2 0x00400000 /* PCI0 MSI level 2 */ +#define UIC_P0MSI3 0x00200000 /* PCI0 MSI level 3 */ +#define UIC_L2C 0x00100000 /* L2 cache */ +#define UIC_CT0 0x00080000 /* GPT compare timer 0 */ +#define UIC_CT1 0x00040000 /* GPT compare timer 1 */ +#define UIC_CT2 0x00020000 /* GPT compare timer 2 */ +#define UIC_CT3 0x00010000 /* GPT compare timer 3 */ +#define UIC_CT4 0x00008000 /* GPT compare timer 4 */ +#define UIC_CT5 0x00004000 /* GPT compare timer 5 */ +#define UIC_CT6 0x00002000 /* GPT compare timer 6 */ +#define UIC_GPTDC 0x00001000 /* GPT decrementer pulse */ +#define UIC_EIR3 0x00000800 /* External interrupt 3 */ +#define UIC_EIR4 0x00000400 /* External interrupt 4 */ +#define UIC_DMAE 0x00000200 /* DMA error */ +#define UIC_I2OE 0x00000100 /* I2O error */ +#define UIC_SRE 0x00000080 /* Serial ROM error */ +#define UIC_P0AE 0x00000040 /* PCI0 asynchronous error */ +#define UIC_EIR5 0x00000020 /* External interrupt 5 */ +#define UIC_EIR6 0x00000010 /* External interrupt 6 */ +#define UIC_U2 0x00000008 /* UART 2 */ +#define UIC_U3 0x00000004 /* UART 3 */ +#define UIC_EIR7 0x00000002 /* External interrupt 7 */ +#define UIC_EIR8 0x00000001 /* External interrupt 8 */ + #elif defined(CONFIG_440EPX) || defined(CONFIG_440GRX)
#define UIC_MS 0x80000000 /* MAL SERR */ @@ -2340,6 +2431,41 @@ #define UIC_RSVD30 0x00000002 /* Reserved */ #define UIC_RSVD31 0x00000001 /* Reserved */
+#elif defined(CONFIG_460EX) || defined(CONFIG_460GT) + +#define UIC_TAH0 0x80000000 /* TAHOE 0 */ +#define UIC_TAH1 0x40000000 /* TAHOE 1 */ +#define UIC_EIR9 0x20000000 /* External interrupt 9 */ +#define UIC_MS 0x10000000 /* MAL SERR */ +#define UIC_MTDE 0x08000000 /* MAL TXDE */ +#define UIC_MRDE 0x04000000 /* MAL RXDE */ +#define UIC_MTE 0x02000000 /* MAL TXEOB */ +#define UIC_MRE 0x01000000 /* MAL RXEOB */ +#define UIC_MCTX0 0x00800000 /* MAL interrupt coalescence TX0 */ +#define UIC_MCTX1 0x00400000 /* MAL interrupt coalescence TX1 */ +#define UIC_MCTX2 0x00200000 /* MAL interrupt coalescence TX2 */ +#define UIC_MCTX3 0x00100000 /* MAL interrupt coalescence TX3 */ +#define UIC_MCTR0 0x00080000 /* MAL interrupt coalescence TR0 */ +#define UIC_MCTR1 0x00040000 /* MAL interrupt coalescence TR1 */ +#define UIC_MCTR2 0x00020000 /* MAL interrupt coalescence TR2 */ +#define UIC_MCTR3 0x00010000 /* MAL interrupt coalescence TR3 */ +#define UIC_ETH0 0x00008000 /* Ethernet 0 */ +#define UIC_ETH1 0x00004000 /* Ethernet 1 */ +#define UIC_ETH2 0x00002000 /* Ethernet 2 */ +#define UIC_ETH3 0x00001000 /* Ethernet 3 */ +#define UIC_EWU0 0x00000800 /* Ethernet 0 wakeup */ +#define UIC_EWU1 0x00000400 /* Ethernet 1 wakeup */ +#define UIC_EWU2 0x00000200 /* Ethernet 2 wakeup */ +#define UIC_EWU3 0x00000100 /* Ethernet 3 wakeup */ +#define UIC_EIR10 0x00000080 /* External interrupt 10 */ +#define UIC_EIR11 0x00000040 /* External interrupt 11 */ +#define UIC_RSVD2 0x00000020 /* Reserved */ +#define UIC_PLB4XAHB 0x00000010 /* PLB4XAHB / AHBARB error */ +#define UIC_OTG 0x00000008 /* USB2.0 OTG */ +#define UIC_EHCI 0x00000004 /* USB2.0 Host EHCI */ +#define UIC_OHCI 0x00000002 /* USB2.0 Host OHCI */ +#define UIC_OHCISMI 0x00000001 /* USB2.0 Host OHCI SMI */ + #elif defined(CONFIG_440EPX) || defined(CONFIG_440GRX) /* UIC2 */
#define UIC_EIR5 0x80000000 /* External interrupt 5 */ @@ -2366,18 +2492,38 @@ #define UICB0_UIC2CI 0x08000000 /* UIC2 Critical Interrupt */ #define UICB0_UIC2NCI 0x04000000 /* UIC2 Noncritical Interrupt */
-#define UICB0_ALL (UICB0_UIC0CI | UICB0_UIC0NCI | UICB0_UIC1CI | \ - UICB0_UIC1NCI | UICB0_UIC2CI | UICB0_UIC2NCI) +#define UICB0_ALL (UICB0_UIC0CI | UICB0_UIC0NCI | UICB0_UIC1CI | \ + UICB0_UIC1NCI | UICB0_UIC2CI | UICB0_UIC2NCI) + +#elif defined(CONFIG_460EX) || defined(CONFIG_460GT) + +#define UICB0_UIC1NCI 0x00000002 /* UIC1 Noncritical Interrupt */ +#define UICB0_UIC1CI 0x00000001 /* UIC1 Critical Interrupt */ +#define UICB0_UIC2NCI 0x00200000 /* UIC2 Noncritical Interrupt */ +#define UICB0_UIC2CI 0x00100000 /* UIC2 Critical Interrupt */ +#define UICB0_UIC3NCI 0x00008000 /* UIC3 Noncritical Interrupt */ +#define UICB0_UIC3CI 0x00004000 /* UIC3 Critical Interrupt */ + +#define UICB0_ALL (UICB0_UIC1CI | UICB0_UIC1NCI | UICB0_UIC2CI | \ + UICB0_UIC2NCI | UICB0_UIC3CI | UICB0_UIC3NCI)
-#define UICB0_UIC1CI 0x00000000 /* UIC1 Critical Interrupt */ -#define UICB0_UIC1NCI 0x00000000 /* UIC1 Noncritical Interrupt */ -#define UICB0_UIC2CI 0x00000000 /* UIC2 Critical Interrupt */ -#define UICB0_UIC2NCI 0x00000000 /* UIC2 Noncritical Interrupt */ +#define UICB0_UIC1CI 0x00000001 /* UIC1 Critical Interrupt */ +#define UICB0_UIC1NCI 0x00000002 /* UIC1 Noncritical Interrupt */ +#define UICB0_UIC2CI 0x00000004 /* UIC2 Critical Interrupt */ +#define UICB0_UIC2NCI 0x00000008 /* UIC2 Noncritical Interrupt */ + +#define UICB0_ALL (UICB0_UIC1CI | UICB0_UIC1NCI | \ + UICB0_UIC1CI | UICB0_UIC2NCI)
-#define UICB0_ALL (UICB0_UIC1CI | UICB0_UIC1NCI | \ - UICB0_UIC1CI | UICB0_UIC2NCI) +#elif defined(CONFIG_440GP) || defined(CONFIG_440SP) || \ + defined(CONFIG_440EP) || defined(CONFIG_440GR) + +#define UICB0_UIC1CI 0x00000001 /* UIC1 Critical Interrupt */ +#define UICB0_UIC1NCI 0x00000002 /* UIC1 Noncritical Interrupt */ + +#define UICB0_ALL (UICB0_UIC1CI | UICB0_UIC1NCI)
#endif /* CONFIG_440GX */ /*---------------------------------------------------------------------------+ @@ -3018,6 +3164,198 @@ #define SDR0_MFR 0x4300 #endif /* CONFIG_440SPE */
+#if defined(CONFIG_460EX) || defined(CONFIG_460GT) +/* Pin Function Control Register 0 (SDR0_PFC0) */ +#define SDR0_PFC0 0x4100 +#define SDR0_PFC0_DBG 0x00008000 /* debug enable */ +#define SDR0_PFC0_G49E 0x00004000 /* GPIO 49 enable */ +#define SDR0_PFC0_G50E 0x00002000 /* GPIO 50 enable */ +#define SDR0_PFC0_G51E 0x00001000 /* GPIO 51 enable */ +#define SDR0_PFC0_G52E 0x00000800 /* GPIO 52 enable */ +#define SDR0_PFC0_G53E 0x00000400 /* GPIO 53 enable */ +#define SDR0_PFC0_G54E 0x00000200 /* GPIO 54 enable */ +#define SDR0_PFC0_G55E 0x00000100 /* GPIO 55 enable */ +#define SDR0_PFC0_G56E 0x00000080 /* GPIO 56 enable */ +#define SDR0_PFC0_G57E 0x00000040 /* GPIO 57 enable */ +#define SDR0_PFC0_G58E 0x00000020 /* GPIO 58 enable */ +#define SDR0_PFC0_G59E 0x00000010 /* GPIO 59 enable */ +#define SDR0_PFC0_G60E 0x00000008 /* GPIO 60 enable */ +#define SDR0_PFC0_G61E 0x00000004 /* GPIO 61 enable */ +#define SDR0_PFC0_G62E 0x00000002 /* GPIO 62 enable */ +#define SDR0_PFC0_G63E 0x00000001 /* GPIO 63 enable */ + +/* Pin Function Control Register 1 (SDR0_PFC1) */ +#define SDR0_PFC1 0x4101 +#define SDR0_PFC1_U1ME_MASK 0x02000000 /* UART1 Mode Enable */ +#define SDR0_PFC1_U1ME_DSR_DTR 0x00000000 /* UART1 in DSR/DTR Mode */ +#define SDR0_PFC1_U1ME_CTS_RTS 0x02000000 /* UART1 in CTS/RTS Mode */ +#define SDR0_PFC1_U0ME_MASK 0x00080000 /* UART0 Mode Enable */ +#define SDR0_PFC1_U0ME_DSR_DTR 0x00000000 /* UART0 in DSR/DTR Mode */ +#define SDR0_PFC1_U0ME_CTS_RTS 0x00080000 /* UART0 in CTS/RTS Mode */ +#define SDR0_PFC1_U0IM_MASK 0x00040000 /* UART0 Interface Mode */ +#define SDR0_PFC1_U0IM_8PINS 0x00000000 /* UART0 Interface Mode 8 pins*/ +#define SDR0_PFC1_U0IM_4PINS 0x00040000 /* UART0 Interface Mode 4 pins*/ +#define SDR0_PFC1_SIS_MASK 0x00020000 /* SCP or IIC1 Selection */ +#define SDR0_PFC1_SIS_SCP_SEL 0x00000000 /* SCP Selected */ +#define SDR0_PFC1_SIS_IIC1_SEL 0x00020000 /* IIC1 Selected */ + +/* Ethernet PLL Configuration Register (SDR0_ETH_PLL) */ +#define SDR0_ETH_PLL 0x4102 +#define SDR0_ETH_PLL_PLLLOCK 0x80000000 /*Ethernet PLL lock indication*/ +#define SDR0_ETH_PLL_REF_CLK_SEL 0x10000000 /* Ethernet reference clock */ +#define SDR0_ETH_PLL_BYPASS 0x08000000 /* bypass mode enable */ +#define SDR0_ETH_PLL_STOPCLK 0x04000000 /* output clock disable */ +#define SDR0_ETH_PLL_TUNE_MASK 0x03FF0000 /* loop stability tuning bits */ +#define SDR0_ETH_PLL_TUNE_ENCODE(n) ((((unsigned long)(n))&0x3ff)<<16) +#define SDR0_ETH_PLL_MULTI_MASK 0x0000FF00 /* frequency multiplication */ +#define SDR0_ETH_PLL_MULTI_ENCODE(n) ((((unsigned long)(n))&0xff)<<8) +#define SDR0_ETH_PLL_RANGEB_MASK 0x000000F0 /* PLLOUTB/C frequency */ +#define SDR0_ETH_PLL_RANGEB_ENCODE(n) ((((unsigned long)(n))&0x0f)<<4) +#define SDR0_ETH_PLL_RANGEA_MASK 0x0000000F /* PLLOUTA frequency */ +#define SDR0_ETH_PLL_RANGEA_ENCODE(n) (((unsigned long)(n))&0x0f) + +/* Ethernet Configuration Register (SDR0_ETH_CFG) */ +#define SDR0_ETH_CFG 0x4103 +#define SDR0_ETH_CFG_SGMII3_LPBK 0x00800000 /* SGMII3 port loopback enable */ +#define SDR0_ETH_CFG_SGMII2_LPBK 0x00400000 /* SGMII2 port loopback enable */ +#define SDR0_ETH_CFG_SGMII1_LPBK 0x00200000 /* SGMII1 port loopback enable */ +#define SDR0_ETH_CFG_SGMII0_LPBK 0x00100000 /* SGMII0 port loopback enable */ +#define SDR0_ETH_CFG_SGMII_MASK 0x00070000 /* SGMII Mask */ +#define SDR0_ETH_CFG_SGMII2_ENABLE 0x00040000 /* SGMII2 port enable */ +#define SDR0_ETH_CFG_SGMII1_ENABLE 0x00020000 /* SGMII1 port enable */ +#define SDR0_ETH_CFG_SGMII0_ENABLE 0x00010000 /* SGMII0 port enable */ +#define SDR0_ETH_CFG_TAHOE1_BYPASS 0x00002000 /* TAHOE1 Bypass selector */ +#define SDR0_ETH_CFG_TAHOE0_BYPASS 0x00001000 /* TAHOE0 Bypass selector */ +#define SDR0_ETH_CFG_EMAC3_PHY_CLK_SEL 0x00000800 /* EMAC 3 PHY clock selector */ +#define SDR0_ETH_CFG_EMAC2_PHY_CLK_SEL 0x00000400 /* EMAC 2 PHY clock selector */ +#define SDR0_ETH_CFG_EMAC1_PHY_CLK_SEL 0x00000200 /* EMAC 1 PHY clock selector */ +#define SDR0_ETH_CFG_EMAC0_PHY_CLK_SEL 0x00000100 /* EMAC 0 PHY clock selector */ +#define SDR0_ETH_CFG_EMAC_2_1_SWAP 0x00000080 /* Swap EMAC2 with EMAC1 */ +#define SDR0_ETH_CFG_EMAC_0_3_SWAP 0x00000040 /* Swap EMAC0 with EMAC3 */ +#define SDR0_ETH_CFG_MDIO_SEL_MASK 0x00000030 /* MDIO source selector mask */ +#define SDR0_ETH_CFG_MDIO_SEL_EMAC0 0x00000000 /* MDIO source - EMAC0 */ +#define SDR0_ETH_CFG_MDIO_SEL_EMAC1 0x00000010 /* MDIO source - EMAC1 */ +#define SDR0_ETH_CFG_MDIO_SEL_EMAC2 0x00000020 /* MDIO source - EMAC2 */ +#define SDR0_ETH_CFG_MDIO_SEL_EMAC3 0x00000030 /* MDIO source - EMAC3 */ +#define SDR0_ETH_CFG_ZMII_MODE_MASK 0x0000000C /* ZMII bridge mode selector mask */ +#define SDR0_ETH_CFG_ZMII_SEL_MII 0x00000000 /* ZMII bridge mode - MII */ +#define SDR0_ETH_CFG_ZMII_SEL_SMII 0x00000004 /* ZMII bridge mode - SMII */ +#define SDR0_ETH_CFG_ZMII_SEL_RMII_10 0x00000008 /* ZMII bridge mode - RMII (10 Mbps) */ +#define SDR0_ETH_CFG_ZMII_SEL_RMII_100 0x0000000C /* ZMII bridge mode - RMII (100 Mbps) */ +#define SDR0_ETH_CFG_GMC1_BRIDGE_SEL 0x00000002 /* GMC Port 1 bridge selector */ +#define SDR0_ETH_CFG_GMC0_BRIDGE_SEL 0x00000001 /* GMC Port 0 bridge selector */ + +#define SDR0_ETH_CFG_ZMII_MODE_SHIFT 4 +#define SDR0_ETH_CFG_ZMII_MII_MODE 0x00 +#define SDR0_ETH_CFG_ZMII_SMII_MODE 0x01 +#define SDR0_ETH_CFG_ZMII_RMII_MODE_10M 0x10 +#define SDR0_ETH_CFG_ZMII_RMII_MODE_100M 0x11 + +/* Miscealleneaous Function Reg. (SDR0_MFR) */ +#define SDR0_MFR 0x4300 +#define SDR0_MFR_T0TxFL 0x00800000 /* force parity error TAHOE0 Tx FIFO bits 0:63 */ +#define SDR0_MFR_T0TxFH 0x00400000 /* force parity error TAHOE0 Tx FIFO bits 64:127 */ +#define SDR0_MFR_T1TxFL 0x00200000 /* force parity error TAHOE1 Tx FIFO bits 0:63 */ +#define SDR0_MFR_T1TxFH 0x00100000 /* force parity error TAHOE1 Tx FIFO bits 64:127 */ +#define SDR0_MFR_E0TxFL 0x00008000 /* force parity error EMAC0 Tx FIFO bits 0:63 */ +#define SDR0_MFR_E0TxFH 0x00004000 /* force parity error EMAC0 Tx FIFO bits 64:127 */ +#define SDR0_MFR_E0RxFL 0x00002000 /* force parity error EMAC0 Rx FIFO bits 0:63 */ +#define SDR0_MFR_E0RxFH 0x00001000 /* force parity error EMAC0 Rx FIFO bits 64:127 */ +#define SDR0_MFR_E1TxFL 0x00000800 /* force parity error EMAC1 Tx FIFO bits 0:63 */ +#define SDR0_MFR_E1TxFH 0x00000400 /* force parity error EMAC1 Tx FIFO bits 64:127 */ +#define SDR0_MFR_E1RxFL 0x00000200 /* force parity error EMAC1 Rx FIFO bits 0:63 */ +#define SDR0_MFR_E1RxFH 0x00000100 /* force parity error EMAC1 Rx FIFO bits 64:127 */ +#define SDR0_MFR_E2TxFL 0x00000080 /* force parity error EMAC2 Tx FIFO bits 0:63 */ +#define SDR0_MFR_E2TxFH 0x00000040 /* force parity error EMAC2 Tx FIFO bits 64:127 */ +#define SDR0_MFR_E2RxFL 0x00000020 /* force parity error EMAC2 Rx FIFO bits 0:63 */ +#define SDR0_MFR_E2RxFH 0x00000010 /* force parity error EMAC2 Rx FIFO bits 64:127 */ +#define SDR0_MFR_E3TxFL 0x00000008 /* force parity error EMAC3 Tx FIFO bits 0:63 */ +#define SDR0_MFR_E3TxFH 0x00000004 /* force parity error EMAC3 Tx FIFO bits 64:127 */ +#define SDR0_MFR_E3RxFL 0x00000002 /* force parity error EMAC3 Rx FIFO bits 0:63 */ +#define SDR0_MFR_E3RxFH 0x00000001 /* force parity error EMAC3 Rx FIFO bits 64:127 */ + +/* EMACx TX Status Register (SDR0_EMACxTXST)*/ +#define SDR0_EMAC0TXST 0x4400 +#define SDR0_EMAC1TXST 0x4401 +#define SDR0_EMAC2TXST 0x4402 +#define SDR0_EMAC3TXST 0x4403 + +#define SDR0_EMACxTXST_FUR 0x02000000 /* TX FIFO underrun */ +#define SDR0_EMACxTXST_BC 0x01000000 /* broadcase address */ +#define SDR0_EMACxTXST_MC 0x00800000 /* multicast address */ +#define SDR0_EMACxTXST_UC 0x00400000 /* unicast address */ +#define SDR0_EMACxTXST_FP 0x00200000 /* frame paused by control packet */ +#define SDR0_EMACxTXST_BFCS 0x00100000 /* bad FCS in the transmitted frame */ +#define SDR0_EMACxTXST_CPF 0x00080000 /* TX control pause frame */ +#define SDR0_EMACxTXST_CF 0x00040000 /* TX control frame */ +#define SDR0_EMACxTXST_MSIZ 0x00020000 /* 1024-maxsize bytes transmitted */ +#define SDR0_EMACxTXST_1023 0x00010000 /* 512-1023 bytes transmitted */ +#define SDR0_EMACxTXST_511 0x00008000 /* 256-511 bytes transmitted */ +#define SDR0_EMACxTXST_255 0x00004000 /* 128-255 bytes transmitted */ +#define SDR0_EMACxTXST_127 0x00002000 /* 65-127 bytes transmitted */ +#define SDR0_EMACxTXST_64 0x00001000 /* 64 bytes transmitted */ +#define SDR0_EMACxTXST_SQE 0x00000800 /* SQE indication */ +#define SDR0_EMACxTXST_LOC 0x00000400 /* loss of carrier sense */ +#define SDR0_EMACxTXST_IERR 0x00000080 /* EMAC internal error */ +#define SDR0_EMACxTXST_EDF 0x00000040 /* excessive deferral */ +#define SDR0_EMACxTXST_ECOL 0x00000020 /* excessive collisions */ +#define SDR0_EMACxTXST_LCOL 0x00000010 /* late collision */ +#define SDR0_EMACxTXST_DFFR 0x00000008 /* deferred frame */ +#define SDR0_EMACxTXST_MCOL 0x00000004 /* multiple collision frame */ +#define SDR0_EMACxTXST_SCOL 0x00000002 /* single collision frame */ +#define SDR0_EMACxTXST_TXOK 0x00000001 /* transmit OK */ + +/* EMACx RX Status Register (SDR0_EMACxRXST)*/ +#define SDR0_EMAC0RXST 0x4404 +#define SDR0_EMAC1RXST 0x4405 +#define SDR0_EMAC2RXST 0x4406 +#define SDR0_EMAC3RXST 0x4407 + +#define SDR0_EMACxRXST_FOR 0x20000000 /* RX FIFO overrun */ +#define SDR0_EMACxRXST_BC 0x10000000 /* broadcast address */ +#define SDR0_EMACxRXST_MC 0x08000000 /* multicast address */ +#define SDR0_EMACxRXST_UC 0x04000000 /* unicast address */ +#define SDR0_EMACxRXST_UPR_MASK 0x03800000 /* user priority field */ +#define SDR0_EMACxRXST_UPR_ENCODE(n) ((((unsigned long)(n))&0x07)<<23) +#define SDR0_EMACxRXST_VLAN 0x00400000 /* RX VLAN tagged frame */ +#define SDR0_EMACxRXST_LOOP 0x00200000 /* received in loop-back mode */ +#define SDR0_EMACxRXST_UOP 0x00100000 /* RX unsupported opcode */ +#define SDR0_EMACxRXST_CPF 0x00080000 /* RX control pause frame */ +#define SDR0_EMACxRXST_CF 0x00040000 /* RX control frame*/ +#define SDR0_EMACxRXST_MSIZ 0x00020000 /* 1024-MaxSize bytes recieved*/ +#define SDR0_EMACxRXST_1023 0x00010000 /* 512-1023 bytes received */ +#define SDR0_EMACxRXST_511 0x00008000 /* 128-511 bytes received */ +#define SDR0_EMACxRXST_255 0x00004000 /* 128-255 bytes received */ +#define SDR0_EMACxRXST_127 0x00002000 /* 65-127 bytes received */ +#define SDR0_EMACxRXST_64 0x00001000 /* 64 bytes received */ +#define SDR0_EMACxRXST_RUNT 0x00000800 /* runt frame */ +#define SDR0_EMACxRXST_SEVT 0x00000400 /* short event */ +#define SDR0_EMACxRXST_AERR 0x00000200 /* alignment error */ +#define SDR0_EMACxRXST_SERR 0x00000100 /* received with symbol error */ +#define SDR0_EMACxRXST_BURST 0x00000040 /* received burst */ +#define SDR0_EMACxRXST_F2L 0x00000020 /* frame is to long */ +#define SDR0_EMACxRXST_OERR 0x00000010 /* out of range length error */ +#define SDR0_EMACxRXST_IERR 0x00000008 /* in range length error */ +#define SDR0_EMACxRXST_LOST 0x00000004 /* frame lost due to internal EMAC receive error */ +#define SDR0_EMACxRXST_BFCS 0x00000002 /* bad FCS in the recieved frame */ +#define SDR0_EMACxRXST_RXOK 0x00000001 /* Recieve OK */ + +/* EMACx TX Status Register (SDR0_EMACxREJCNT)*/ +#define SDR0_EMAC0REJCNT 0x4408 +#define SDR0_EMAC1REJCNT 0x4409 +#define SDR0_EMAC2REJCNT 0x440A +#define SDR0_EMAC3REJCNT 0x440B + +#define SDR0_DDR0 0x00E1 +#define SDR0_DDR0_DPLLRST 0x80000000 +#define SDR0_DDR0_DDRM_MASK 0x60000000 +#define SDR0_DDR0_DDRM_DDR1 0x20000000 +#define SDR0_DDR0_DDRM_DDR2 0x40000000 +#define SDR0_DDR0_DDRM_ENCODE(n) ((((unsigned long)(n))&0x03)<<29) +#define SDR0_DDR0_DDRM_DECODE(n) ((((unsigned long)(n))>>29)&0x03) +#define SDR0_DDR0_TUNE_ENCODE(n) ((((unsigned long)(n))&0x2FF)<<0) +#define SDR0_DDR0_TUNE_DECODE(n) ((((unsigned long)(n))>>0)&0x2FF) +#endif /* CONFIG_460EX || CONFIG_460GT */
#define SDR0_SDCS_SDD (0x80000000 >> 31)
@@ -3232,6 +3570,73 @@ #define SDR0_SRST1_FPU 0x00004000 /* Floating Point Unit */ #define SDR0_SRST1_KASU0 0x00002000 /* Kasumi Engine */
+#elif defined(CONFIG_460EX) || defined(CONFIG_460GT) + +#define SDR0_SRST0 0x0200 +#define SDR0_SRST SDR0_SRST0 /* for compatability reasons */ +#define SDR0_SRST0_BGO 0x80000000 /* PLB to OPB bridge */ +#define SDR0_SRST0_PLB4 0x40000000 /* PLB4 arbiter */ +#define SDR0_SRST0_EBC 0x20000000 /* External bus controller */ +#define SDR0_SRST0_OPB 0x10000000 /* OPB arbiter */ +#define SDR0_SRST0_UART0 0x08000000 /* Universal asynchronous receiver/transmitter 0 */ +#define SDR0_SRST0_UART1 0x04000000 /* Universal asynchronous receiver/transmitter 1 */ +#define SDR0_SRST0_IIC0 0x02000000 /* Inter integrated circuit 0 */ +#define SDR0_SRST0_IIC1 0x01000000 /* Inter integrated circuit 1 */ +#define SDR0_SRST0_GPIO0 0x00800000 /* General purpose I/O 0 */ +#define SDR0_SRST0_GPT 0x00400000 /* General purpose timer */ +#define SDR0_SRST0_DMC 0x00200000 /* DDR SDRAM memory controller */ +#define SDR0_SRST0_PCI 0x00100000 /* PCI */ +#define SDR0_SRST0_CPM0 0x00020000 /* Clock and power management */ +#define SDR0_SRST0_IMU 0x00010000 /* I2O DMA */ +#define SDR0_SRST0_UIC0 0x00008000 /* Universal interrupt controller 0*/ +#define SDR0_SRST0_UIC1 0x00004000 /* Universal interrupt controller 1*/ +#define SDR0_SRST0_SRAM 0x00002000 /* Universal interrupt controller 0*/ +#define SDR0_SRST0_UIC2 0x00001000 /* Universal interrupt controller 2*/ +#define SDR0_SRST0_UIC3 0x00000800 /* Universal interrupt controller 3*/ +#define SDR0_SRST0_OCM 0x00000400 /* Universal interrupt controller 0*/ +#define SDR0_SRST0_UART2 0x00000200 /* Universal asynchronous receiver/transmitter 2 */ +#define SDR0_SRST0_MAL 0x00000100 /* Media access layer */ +#define SDR0_SRST0_GPTR 0x00000040 /* General purpose timer */ +#define SDR0_SRST0_L2CACHE 0x00000004 /* L2 Cache */ +#define SDR0_SRST0_UART3 0x00000002 /* Universal asynchronous receiver/transmitter 3 */ +#define SDR0_SRST0_GPIO1 0x00000001 /* General purpose I/O 1 */ + +#define SDR0_SRST1 0x201 +#define SDR0_SRST1_RLL 0x80000000 /* SRIO RLL */ +#define SDR0_SRST1_SCP 0x40000000 /* Serial communications port */ +#define SDR0_SRST1_PLBARB 0x20000000 /* PLB Arbiter */ +#define SDR0_SRST1_EIPPKP 0x10000000 /* EIPPPKP */ +#define SDR0_SRST1_EIP94 0x08000000 /* EIP 94 */ +#define SDR0_SRST1_EMAC0 0x04000000 /* Ethernet media access controller 0 */ +#define SDR0_SRST1_EMAC1 0x02000000 /* Ethernet media access controller 1 */ +#define SDR0_SRST1_EMAC2 0x01000000 /* Ethernet media access controller 2 */ +#define SDR0_SRST1_EMAC3 0x00800000 /* Ethernet media access controller 3 */ +#define SDR0_SRST1_ZMII 0x00400000 /* Ethernet ZMII/RMII/SMII */ +#define SDR0_SRST1_RGMII0 0x00200000 /* Ethernet RGMII/RTBI 0 */ +#define SDR0_SRST1_RGMII1 0x00100000 /* Ethernet RGMII/RTBI 1 */ +#define SDR0_SRST1_DMA4 0x00080000 /* DMA to PLB4 */ +#define SDR0_SRST1_DMA4CH 0x00040000 /* DMA Channel to PLB4 */ +#define SDR0_SRST1_SATAPHY 0x00020000 /* Serial ATA PHY */ +#define SDR0_SRST1_SRIODEV 0x00010000 /* Serial Rapid IO core, PCS, and serdes */ +#define SDR0_SRST1_SRIOPCS 0x00008000 /* Serial Rapid IO core and PCS */ +#define SDR0_SRST1_NDFC 0x00004000 /* Nand flash controller */ +#define SDR0_SRST1_SRIOPLB 0x00002000 /* Serial Rapid IO PLB */ +#define SDR0_SRST1_ETHPLL 0x00001000 /* Ethernet PLL */ +#define SDR0_SRST1_TAHOE1 0x00000800 /* Ethernet Tahoe 1 */ +#define SDR0_SRST1_TAHOE0 0x00000400 /* Ethernet Tahoe 0 */ +#define SDR0_SRST1_SGMII0 0x00000200 /* Ethernet SGMII 0 */ +#define SDR0_SRST1_SGMII1 0x00000100 /* Ethernet SGMII 1 */ +#define SDR0_SRST1_SGMII2 0x00000080 /* Ethernet SGMII 2 */ +#define SDR0_SRST1_AHB 0x00000040 /* PLB4XAHB bridge */ +#define SDR0_SRST1_USBOTGPHY 0x00000020 /* USB 2.0 OTG PHY */ +#define SDR0_SRST1_USBOTG 0x00000010 /* USB 2.0 OTG controller */ +#define SDR0_SRST1_USBHOST 0x00000008 /* USB 2.0 Host controller */ +#define SDR0_SRST1_AHBDMAC 0x00000004 /* AHB DMA controller */ +#define SDR0_SRST1_AHBICM 0x00000002 /* AHB inter-connect matrix */ +#define SDR0_SRST1_SATA 0x00000001 /* Serial ATA controller */ + +#define SDR0_PCI0 0x1c0 /* PCI Configuration Register */ + #else
#define SDR0_SRST_BGO 0x80000000 @@ -3270,7 +3675,15 @@ /*-----------------------------------------------------------------------------+ | Clocking +-----------------------------------------------------------------------------*/ -#if !defined (CONFIG_440GX) && \ +#if defined(CONFIG_460EX) || defined(CONFIG_460GT) +#define PLLSYS0_FWD_DIV_A_MASK 0x000000f0 /* Fwd Div A */ +#define PLLSYS0_FWD_DIV_B_MASK 0x0000000f /* Fwd Div B */ +#define PLLSYS0_FB_DIV_MASK 0x0000ff00 /* Feedback divisor */ +#define PLLSYS0_OPB_DIV_MASK 0x0c000000 /* OPB Divisor */ +#define PLLSYS0_PLBEDV0_DIV_MASK 0xe0000000 /* PLB Early Clock Divisor */ +#define PLLSYS0_PERCLK_DIV_MASK 0x03000000 /* Peripheral Clk Divisor */ +#define PLLSYS0_SEL_MASK 0x18000000 /* 0 = PLL, 1 = PerClk */ +#elif !defined (CONFIG_440GX) && \ !defined(CONFIG_440EP) && !defined(CONFIG_440GR) && \ !defined(CONFIG_440EPX) && !defined(CONFIG_440GRX) && \ !defined(CONFIG_440SP) && !defined(CONFIG_440SPE) @@ -3624,7 +4037,8 @@ #endif /* CONFIG_440GP */
#if defined(CONFIG_440EP) || defined(CONFIG_440GR) || \ - defined(CONFIG_440EPX) || defined(CONFIG_440GRX) + defined(CONFIG_440EPX) || defined(CONFIG_440GRX) || \ + defined(CONFIG_460EX) || defined(CONFIG_460GT) #define GPIO0_BASE (CFG_PERIPHERAL_BASE+0x00000B00) #define GPIO1_BASE (CFG_PERIPHERAL_BASE+0x00000C00)
This patch adds support for the AMCC Canyonlands 460EX evaluation board.
Signed-off-by: Stefan Roese sr@denx.de --- board/amcc/canyonlands/Makefile | 51 +++++ board/amcc/canyonlands/bootstrap.c | 169 +++++++++++++++ board/amcc/canyonlands/canyonlands.c | 385 ++++++++++++++++++++++++++++++++++ board/amcc/canyonlands/config.mk | 49 +++++ board/amcc/canyonlands/init.S | 114 ++++++++++ board/amcc/canyonlands/u-boot.lds | 146 +++++++++++++ 6 files changed, 914 insertions(+), 0 deletions(-) create mode 100644 board/amcc/canyonlands/Makefile create mode 100644 board/amcc/canyonlands/bootstrap.c create mode 100644 board/amcc/canyonlands/canyonlands.c create mode 100644 board/amcc/canyonlands/config.mk create mode 100644 board/amcc/canyonlands/init.S create mode 100644 board/amcc/canyonlands/u-boot.lds
diff --git a/board/amcc/canyonlands/Makefile b/board/amcc/canyonlands/Makefile new file mode 100644 index 0000000..a3385c7 --- /dev/null +++ b/board/amcc/canyonlands/Makefile @@ -0,0 +1,51 @@ +# +# (C) Copyright 2008 +# Stefan Roese, DENX Software Engineering, sr@denx.de. +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(BOARD).a + +COBJS = $(BOARD).o bootstrap.o +SOBJS = init.o + +SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS)) +SOBJS := $(addprefix $(obj),$(SOBJS)) + +$(LIB): $(OBJS) $(SOBJS) + $(AR) $(ARFLAGS) $@ $(OBJS) + +clean: + rm -f $(SOBJS) $(OBJS) + +distclean: clean + rm -f $(LIB) core *.bak .depend + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/board/amcc/canyonlands/bootstrap.c b/board/amcc/canyonlands/bootstrap.c new file mode 100644 index 0000000..3f5822e --- /dev/null +++ b/board/amcc/canyonlands/bootstrap.c @@ -0,0 +1,169 @@ +/* + * (C) Copyright 2008 + * Stefan Roese, DENX Software Engineering, sr@denx.de. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + * + */ + +#include <common.h> +#include <command.h> +#include <i2c.h> +#include <asm/io.h> + +/* + * NOR and NAND boot options change bytes 6, 7, 8, 9, 11. The + * values are independent of the rest of the clock settings. + */ + +#define NAND_COMPATIBLE 0x01 +#define NOR_COMPATIBLE 0x02 + +#define I2C_EEPROM_ADDR 0x52 + +static char *config_labels[] = { + "CPU: 600 PLB: 200 OPB: 100 EBC: 100", + "CPU: 800 PLB: 200 OPB: 100 EBC: 100", + NULL +}; + +static u8 boot_configs[][17] = { + { + (NOR_COMPATIBLE), + 0x86, 0x80, 0xce, 0x1f, 0x79, 0x80, 0x00, 0xa0, 0x40, 0x08, + 0x23, 0x50, 0x0d, 0x95, 0x00, 0x00 + }, + { + (NOR_COMPATIBLE), + 0x86, 0x80, 0xba, 0x14, 0x99, 0x80, 0x00, 0xa0, 0x40, 0x08, + 0x23, 0x50, 0x0d, 0x95, 0x00, 0x00 + }, + { + 0, + 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0 + } +}; + +/* + * Bytes 6,8,9,11 change for NAND boot + */ +static u8 nand_boot[] = { + 0xd0, 0xa0, 0x68, 0x58 +}; + +static int do_bootstrap(cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) +{ + u8 *buf, b_nand; + int x, y, nbytes, selcfg; + extern char console_buffer[]; + + if (argc < 2) { + printf("Usage:\n%s\n", cmdtp->usage); + return 1; + } + + if ((strcmp(argv[1], "nor") != 0) && + (strcmp(argv[1], "nand") != 0)) { + printf("Unsupported boot-device - only nor|nand support\n"); + return 1; + } + + /* set the nand flag based on provided input */ + if ((strcmp(argv[1], "nand") == 0)) + b_nand = 1; + else + b_nand = 0; + + printf("Available configurations: \n\n"); + + if (b_nand) { + for(x = 0, y = 0; boot_configs[x][0] != 0; x++) { + /* filter on nand compatible */ + if (boot_configs[x][0] & NAND_COMPATIBLE) { + printf(" %d - %s\n", (y+1), config_labels[x]); + y++; + } + } + } else { + for(x = 0, y = 0; boot_configs[x][0] != 0; x++) { + /* filter on nor compatible */ + if (boot_configs[x][0] & NOR_COMPATIBLE) { + printf(" %d - %s\n", (y+1), config_labels[x]); + y++; + } + } + } + + do { + nbytes = readline(" Selection [1-x / quit]: "); + + if (nbytes) { + if (strcmp(console_buffer, "quit") == 0) + return 0; + selcfg = simple_strtol(console_buffer, NULL, 10); + if ((selcfg < 1) || (selcfg > y)) + nbytes = 0; + } + } while (nbytes == 0); + + + y = (selcfg - 1); + + for (x = 0; boot_configs[x][0] != 0; x++) { + if (b_nand) { + if (boot_configs[x][0] & NAND_COMPATIBLE) { + if (y > 0) + y--; + else if (y < 1) + break; + } + } else { + if (boot_configs[x][0] & NOR_COMPATIBLE) { + if (y > 0) + y--; + else if (y < 1) + break; + } + } + } + + buf = &boot_configs[x][1]; + + if (b_nand) { + buf[6] = nand_boot[0]; + buf[8] = nand_boot[1]; + buf[9] = nand_boot[2]; + buf[11] = nand_boot[3]; + } + + if (i2c_write(I2C_EEPROM_ADDR, 0, 1, buf, 16) != 0) + printf("Error writing to EEPROM at address 0x%x\n", I2C_EEPROM_ADDR); + udelay(CFG_EEPROM_PAGE_WRITE_DELAY_MS * 1000); + + printf("Done\n"); + printf("Please power-cycle the board for the changes to take effect\n"); + + return 0; +} + +U_BOOT_CMD( + bootstrap, 2, 0, do_bootstrap, + "bootstrap - program the I2C bootstrap EEPROM\n", + "<nand|nor> - strap to boot from NAND or NOR flash\n" + ); diff --git a/board/amcc/canyonlands/canyonlands.c b/board/amcc/canyonlands/canyonlands.c new file mode 100644 index 0000000..8292d2d --- /dev/null +++ b/board/amcc/canyonlands/canyonlands.c @@ -0,0 +1,385 @@ +/* + * (C) Copyright 2008 + * Stefan Roese, DENX Software Engineering, sr@denx.de. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <ppc440.h> +#include <libfdt.h> +#include <fdt_support.h> +#include <asm/processor.h> +#include <asm/io.h> +#include <asm/mmu.h> +#include <asm/4xx_pcie.h> + +extern flash_info_t flash_info[CFG_MAX_FLASH_BANKS]; /* info for FLASH chips */ + +DECLARE_GLOBAL_DATA_PTR; + +int board_early_init_f(void) +{ + u32 sdr0_cust0; + + /*------------------------------------------------------------------+ + * Setup the interrupt controller polarities, triggers, etc. + *------------------------------------------------------------------*/ + mtdcr(uic0sr, 0xffffffff); /* clear all */ + mtdcr(uic0er, 0x00000000); /* disable all */ + mtdcr(uic0cr, 0x00000005); /* ATI & UIC1 crit are critical */ + mtdcr(uic0pr, 0xffffffff); /* per ref-board manual */ + mtdcr(uic0tr, 0x00000000); /* per ref-board manual */ + mtdcr(uic0vr, 0x00000000); /* int31 highest, base=0x000 */ + mtdcr(uic0sr, 0xffffffff); /* clear all */ + + mtdcr(uic1sr, 0xffffffff); /* clear all */ + mtdcr(uic1er, 0x00000000); /* disable all */ + mtdcr(uic1cr, 0x00000000); /* all non-critical */ + mtdcr(uic1pr, 0xffffffff); /* per ref-board manual */ + mtdcr(uic1tr, 0x00000000); /* per ref-board manual */ + mtdcr(uic1vr, 0x00000000); /* int31 highest, base=0x000 */ + mtdcr(uic1sr, 0xffffffff); /* clear all */ + + mtdcr(uic2sr, 0xffffffff); /* clear all */ + mtdcr(uic2er, 0x00000000); /* disable all */ + mtdcr(uic2cr, 0x00000000); /* all non-critical */ + mtdcr(uic2pr, 0xffffffff); /* per ref-board manual */ + mtdcr(uic2tr, 0x00000000); /* per ref-board manual */ + mtdcr(uic2vr, 0x00000000); /* int31 highest, base=0x000 */ + mtdcr(uic2sr, 0xffffffff); /* clear all */ + + mtdcr(uic3sr, 0xffffffff); /* clear all */ + mtdcr(uic3er, 0x00000000); /* disable all */ + mtdcr(uic3cr, 0x00000000); /* all non-critical */ + mtdcr(uic3pr, 0xffffffff); /* per ref-board manual */ + mtdcr(uic3tr, 0x00000000); /* per ref-board manual */ + mtdcr(uic3vr, 0x00000000); /* int31 highest, base=0x000 */ + mtdcr(uic3sr, 0xffffffff); /* clear all */ + + /* SDR Setting - enable NDFC */ + mfsdr(SDR0_CUST0, sdr0_cust0); + sdr0_cust0 = SDR0_CUST0_MUX_NDFC_SEL | + SDR0_CUST0_NDFC_ENABLE | + SDR0_CUST0_NDFC_BW_8_BIT | + SDR0_CUST0_NDFC_ARE_MASK | + SDR0_CUST0_NDFC_BAC_ENCODE(3) | + (0x80000000 >> (28 + CFG_NAND_CS)); + mtsdr(SDR0_CUST0, sdr0_cust0); + + /* + * Configure PFC (Pin Function Control) registers + * UART0: 4 pins + */ + mtsdr(SDR0_PFC1, 0x00040000); + + /* Enable PCI host functionality in SDR0_PCI0 */ + mtsdr(SDR0_PCI0, 0xe0000000); + + /* Enable ethernet and take out of reset */ + out_8((void *)CFG_BCSR_BASE + 6, 0); + + /* Remove NOR-FLASH, NAND-FLASH & EEPROM hardware write protection */ + out_8((void *)CFG_BCSR_BASE + 5, 0); + + /* Enable USB host & USB-OTG */ + out_8((void *)CFG_BCSR_BASE + 7, 0); + + mtsdr(SDR0_SRST1, 0); /* Pull AHB out of reset default=1 */ + + return 0; +} + +int checkboard (void) +{ + char *s = getenv("serial#"); + u32 pvr = get_pvr(); + + if ((pvr == PVR_460GT_RA) || (pvr == PVR_460GT_SE_RA)) + printf("Board: Glacier - AMCC PPC460GT Evaluation Board"); + else + printf("Board: Canyonlands - AMCC PPC460EX Evaluation Board"); + + if (s != NULL) { + puts(", serial# "); + puts(s); + } + putc('\n'); + + return (0); +} + +/* + * Override the default functions in cpu/ppc4xx/44x_spd_ddr2.c with + * board specific values. + */ +u32 ddr_wrdtr(u32 default_val) { + return (SDRAM_WRDTR_LLWP_1_CYC | SDRAM_WRDTR_WTR_180_DEG_ADV | 0x823); +} + +u32 ddr_clktr(u32 default_val) { + return (SDRAM_CLKTR_CLKP_90_DEG_ADV); +} + +#if defined(CFG_DRAM_TEST) +int testdram(void) +{ + unsigned long *mem = (unsigned long *)0; + const unsigned long kend = (1024 / sizeof(unsigned long)); + unsigned long k, n; + + mtmsr(0); + + for (k = 0; k < CFG_KBYTES_SDRAM; + ++k, mem += (1024 / sizeof(unsigned long))) { + if ((k & 1023) == 0) { + printf("%3d MB\r", k / 1024); + } + + memset(mem, 0xaaaaaaaa, 1024); + for (n = 0; n < kend; ++n) { + if (mem[n] != 0xaaaaaaaa) { + printf("SDRAM test fails at: %08x\n", + (uint) & mem[n]); + return 1; + } + } + + memset(mem, 0x55555555, 1024); + for (n = 0; n < kend; ++n) { + if (mem[n] != 0x55555555) { + printf("SDRAM test fails at: %08x\n", + (uint) & mem[n]); + return 1; + } + } + } + printf("SDRAM test passes\n"); + return 0; +} +#endif + +/************************************************************************* + * pci_target_init + * + * The bootstrap configuration provides default settings for the pci + * inbound map (PIM). But the bootstrap config choices are limited and + * may not be sufficient for a given board. + * + ************************************************************************/ +#if defined(CONFIG_PCI) && defined(CFG_PCI_TARGET_INIT) +void pci_target_init(struct pci_controller * hose ) +{ + /*-------------------------------------------------------------------+ + * Disable everything + *-------------------------------------------------------------------*/ + out_le32((void *)PCIX0_PIM0SA, 0); /* disable */ + out_le32((void *)PCIX0_PIM1SA, 0); /* disable */ + out_le32((void *)PCIX0_PIM2SA, 0); /* disable */ + out_le32((void *)PCIX0_EROMBA, 0); /* disable expansion rom */ + + /*-------------------------------------------------------------------+ + * Map all of SDRAM to PCI address 0x0000_0000. Note that the 440 + * strapping options to not support sizes such as 128/256 MB. + *-------------------------------------------------------------------*/ + out_le32((void *)PCIX0_PIM0LAL, CFG_SDRAM_BASE); + out_le32((void *)PCIX0_PIM0LAH, 0); + out_le32((void *)PCIX0_PIM0SA, ~(gd->ram_size - 1) | 1); + out_le32((void *)PCIX0_BAR0, 0); + + /*-------------------------------------------------------------------+ + * Program the board's subsystem id/vendor id + *-------------------------------------------------------------------*/ + out_le16((void *)PCIX0_SBSYSVID, CFG_PCI_SUBSYS_VENDORID); + out_le16((void *)PCIX0_SBSYSID, CFG_PCI_SUBSYS_DEVICEID); + + out_le16((void *)PCIX0_CMD, in16r(PCIX0_CMD) | PCI_COMMAND_MEMORY); +} +#endif /* defined(CONFIG_PCI) && defined(CFG_PCI_TARGET_INIT) */ + +#if defined(CONFIG_PCI) +/* + * is_pci_host + * + * This routine is called to determine if a pci scan should be + * performed. With various hardware environments (especially cPCI and + * PPMC) it's insufficient to depend on the state of the arbiter enable + * bit in the strap register, or generic host/adapter assumptions. + * + * Rather than hard-code a bad assumption in the general 440 code, the + * 440 pci code requires the board to decide at runtime. + * + * Return 0 for adapter mode, non-zero for host (monarch) mode. + */ +int is_pci_host(struct pci_controller *hose) +{ + /* Board is always configured as host. */ + return (1); +} + +static struct pci_controller pcie_hose[2] = {{0},{0}}; + +void pcie_setup_hoses(int busno) +{ + struct pci_controller *hose; + int i, bus; + int ret = 0; + char *env; + unsigned int delay; + + /* + * assume we're called after the PCIX hose is initialized, which takes + * bus ID 0 and therefore start numbering PCIe's from 1. + */ + bus = busno; + for (i = 0; i <= 1; i++) { + + if (is_end_point(i)) + ret = ppc4xx_init_pcie_endport(i); + else + ret = ppc4xx_init_pcie_rootport(i); + if (ret) { + printf("PCIE%d: initialization as %s failed\n", i, + is_end_point(i) ? "endpoint" : "root-complex"); + continue; + } + + hose = &pcie_hose[i]; + hose->first_busno = bus; + hose->last_busno = bus; + hose->current_busno = bus; + + /* setup mem resource */ + pci_set_region(hose->regions + 0, + CFG_PCIE_MEMBASE + i * CFG_PCIE_MEMSIZE, + CFG_PCIE_MEMBASE + i * CFG_PCIE_MEMSIZE, + CFG_PCIE_MEMSIZE, + PCI_REGION_MEM); + hose->region_count = 1; + pci_register_hose(hose); + + if (is_end_point(i)) { + ppc4xx_setup_pcie_endpoint(hose, i); + /* + * Reson for no scanning is endpoint can not generate + * upstream configuration accesses. + */ + } else { + ppc4xx_setup_pcie_rootpoint(hose, i); + env = getenv ("pciscandelay"); + if (env != NULL) { + delay = simple_strtoul(env, NULL, 10); + if (delay > 5) + printf("Warning, expect noticable delay before " + "PCIe scan due to 'pciscandelay' value!\n"); + mdelay(delay * 1000); + } + + /* + * Config access can only go down stream + */ + hose->last_busno = pci_hose_scan(hose); + bus = hose->last_busno + 1; + } + } +} +#endif /* CONFIG_PCI */ + +int board_early_init_r (void) +{ + /* + * Canyonlands has 64MBytes of NOR FLASH (Spansion 29GL512), but the + * boot EBC mapping only supports a maximum of 16MBytes + * (4.ff00.0000 - 4.ffff.ffff). + * To solve this problem, the FLASH has to get remapped to another + * EBC address which accepts bigger regions: + * + * 0xfc00.0000 -> 4.cc00.0000 + * + * For this we have to remap the CS0 and re-relocate the envrironment, + * since the original FLASH location which was needed upon startup is + * now not correct anymore. + */ + + /* Remap the NOR FLASH to 0xcc00.0000 ... 0xcfff.ffff */ + mtebc(pb0cr, CFG_FLASH_BASE_PHYS_L | 0xda000); + + /* Remove TLB entry of boot EBC mapping */ + remove_tlb(CFG_BOOT_BASE_ADDR, 16 << 20); + + /* Add TLB entry for 0xfc00.0000 -> 0x4.cc00.0000 */ + program_tlb(CFG_FLASH_BASE_PHYS, CFG_FLASH_BASE, CFG_FLASH_SIZE, + TLB_WORD2_I_ENABLE); + + /* + * Now accessing of the whole 64Mbytes of NOR FLASH at virtual address + * 0xfc00.0000 is possible + */ + + return 0; +} + +int misc_init_r(void) +{ + u32 sdr0_srst1 = 0; + u32 eth_cfg; + + /* + * Set EMAC mode/configuration (GMII, SGMII, RGMII...). + * This is board specific, so let's do it here. + */ + mfsdr(SDR0_ETH_CFG, eth_cfg); + /* disable SGMII mode */ + eth_cfg &= ~(SDR0_ETH_CFG_SGMII2_ENABLE | + SDR0_ETH_CFG_SGMII1_ENABLE | + SDR0_ETH_CFG_SGMII0_ENABLE); + /* Set the for 2 RGMII mode */ + /* GMC0 EMAC4_0, GMC0 EMAC4_1, RGMII Bridge 0 */ + eth_cfg &= ~SDR0_ETH_CFG_GMC0_BRIDGE_SEL; + eth_cfg |= SDR0_ETH_CFG_GMC1_BRIDGE_SEL; + mtsdr(SDR0_ETH_CFG, eth_cfg); + + /* + * The AHB Bridge core is held in reset after power-on or reset + * so enable it now + */ + mfsdr(SDR0_SRST1, sdr0_srst1); + sdr0_srst1 &= ~SDR0_SRST1_AHB; + mtsdr(SDR0_SRST1, sdr0_srst1); + + return 0; +} + +#if defined(CONFIG_OF_LIBFDT) && defined(CONFIG_OF_BOARD_SETUP) +void ft_board_setup(void *blob, bd_t *bd) +{ + u32 val[4]; + int rc; + + ft_cpu_setup(blob, bd); + + /* Fixup NOR mapping */ + val[0] = 0; /* chip select number */ + val[1] = 0; /* always 0 */ + val[2] = gd->bd->bi_flashstart; + val[3] = gd->bd->bi_flashsize; + rc = fdt_find_and_setprop(blob, "/plb/opb/ebc", "ranges", + val, sizeof(val), 1); + if (rc) + printf("Unable to update property NOR mapping, err=%s\n", + fdt_strerror(rc)); +} +#endif /* defined(CONFIG_OF_LIBFDT) && defined(CONFIG_OF_BOARD_SETUP) */ diff --git a/board/amcc/canyonlands/config.mk b/board/amcc/canyonlands/config.mk new file mode 100644 index 0000000..1e4bbc4 --- /dev/null +++ b/board/amcc/canyonlands/config.mk @@ -0,0 +1,49 @@ +# +# (C) Copyright 2008 +# Wolfgang Denk, DENX Software Engineering, wd@denx.de. +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# +# +# AMCC 460EX/460GT Evaluation Board (Canyonlands) board +# + +sinclude $(TOPDIR)/board/$(BOARDDIR)/config.tmp + +ifndef TEXT_BASE +TEXT_BASE = 0xFFFA0000 +endif + +ifeq ($(CONFIG_NAND_U_BOOT),y) +LDSCRIPT = $(TOPDIR)/board/$(BOARDDIR)/u-boot-nand.lds +endif + +ifeq ($(CONFIG_PCIBOOT_U_BOOT),y) +LDSCRIPT = $(TOPDIR)/board/$(BOARDDIR)/u-boot-nand.lds +endif + +PLATFORM_CPPFLAGS += -DCONFIG_440=1 + +ifeq ($(debug),1) +PLATFORM_CPPFLAGS += -DDEBUG +endif + +ifeq ($(dbcr),1) +PLATFORM_CPPFLAGS += -DCFG_INIT_DBCR=0x8cff0000 +endif diff --git a/board/amcc/canyonlands/init.S b/board/amcc/canyonlands/init.S new file mode 100644 index 0000000..5d48847 --- /dev/null +++ b/board/amcc/canyonlands/init.S @@ -0,0 +1,114 @@ +/* + * (C) Copyright 2008 + * Stefan Roese, DENX Software Engineering, sr@denx.de. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <ppc_asm.tmpl> +#include <config.h> +#include <asm-ppc/mmu.h> + +/************************************************************************** + * TLB TABLE + * + * This table is used by the cpu boot code to setup the initial tlb + * entries. Rather than make broad assumptions in the cpu source tree, + * this table lets each board set things up however they like. + * + * Pointer to the table is returned in r1 + * + *************************************************************************/ + .section .bootpg,"ax" + .globl tlbtab + +tlbtab: + tlbtab_start + + /* + * BOOT_CS (FLASH) must be first. Before relocation SA_I can be off to + * use the speed up boot process. It is patched after relocation to + * enable SA_I + */ + tlbentry(CFG_BOOT_BASE_ADDR, SZ_16M, CFG_BOOT_BASE_ADDR, 4, AC_R|AC_W|AC_X|SA_G) /* TLB 0 */ + + /* + * TLB entries for SDRAM are not needed on this platform. + * They are dynamically generated in the SPD DDR(2) detection + * routine. + */ + +#ifdef CFG_INIT_RAM_DCACHE + /* TLB-entry for init-ram in dcache (SA_I must be turned off!) */ + tlbentry(CFG_INIT_RAM_ADDR, SZ_4K, CFG_INIT_RAM_ADDR, 0, AC_R|AC_W|AC_X|SA_G) +#endif + + tlbentry(CFG_PCI_BASE, SZ_256M, 0x00000000, 0xC, AC_R|AC_W|SA_G|SA_I) + tlbentry(CFG_PCI_MEMBASE, SZ_256M, 0x20000000, 0xC, AC_R|AC_W|SA_G|SA_I) + tlbentry(CFG_PCIE_MEMBASE, SZ_256M, 0xB0000000, 0xD, AC_R|AC_W|SA_G|SA_I) + + tlbentry(CFG_PCIE0_CFGBASE, SZ_16M, 0x00000000, 0xD, AC_R|AC_W|SA_G|SA_I) + tlbentry(CFG_PCIE1_CFGBASE, SZ_16M, 0x20000000, 0xD, AC_R|AC_W|SA_G|SA_I) + tlbentry(CFG_PCIE0_XCFGBASE, SZ_1K, 0x10000000, 0xD, AC_R|AC_W|SA_G|SA_I) + tlbentry(CFG_PCIE1_XCFGBASE, SZ_1K, 0x30000000, 0xD, AC_R|AC_W|SA_G|SA_I) + + /* PCIe UTL register */ + tlbentry(CFG_PCIE_BASE, SZ_16K, 0x08010000, 0xC, AC_R|AC_W|SA_G|SA_I) + + /* TLB-entry for NAND */ + tlbentry(CFG_NAND_ADDR, SZ_16M, CFG_NAND_ADDR, 4, AC_R|AC_W|AC_X|SA_G|SA_I) + + /* TLB-entry for CPLD */ + tlbentry(CFG_BCSR_BASE, SZ_1K, CFG_BCSR_BASE, 4, AC_R|AC_W|SA_G|SA_I) + + /* TLB-entry for OCM */ + tlbentry(CFG_OCM_BASE, SZ_4K, 0x00040000, 4, AC_R|AC_W|AC_X) + + /* TLB-entry for Local Configuration registers => peripherals */ + tlbentry(CFG_LOCAL_CONF_REGS, SZ_16M, CFG_LOCAL_CONF_REGS, 4, AC_R|AC_W|AC_X|SA_G|SA_I) + + tlbtab_end + +#if defined(CONFIG_NAND_U_BOOT) && !defined(CONFIG_NAND_SPL) + /* + * For NAND booting the first TLB has to be reconfigured to full size + * and with caching disabled after running from RAM! + */ +#define TLB00 TLB0(CFG_BOOT_BASE_ADDR, SZ_256M) +#define TLB01 TLB1(CFG_BOOT_BASE_ADDR, 1) +#define TLB02 TLB2(AC_R|AC_W|AC_X|SA_G|SA_I) + + .globl reconfig_tlb0 +reconfig_tlb0: + sync + isync + addi r4,r0,0x0000 /* TLB entry #0 */ + lis r5,TLB00@h + ori r5,r5,TLB00@l + tlbwe r5,r4,0x0000 /* Save it out */ + lis r5,TLB01@h + ori r5,r5,TLB01@l + tlbwe r5,r4,0x0001 /* Save it out */ + lis r5,TLB02@h + ori r5,r5,TLB02@l + tlbwe r5,r4,0x0002 /* Save it out */ + sync + isync + blr +#endif diff --git a/board/amcc/canyonlands/u-boot.lds b/board/amcc/canyonlands/u-boot.lds new file mode 100644 index 0000000..7496f48 --- /dev/null +++ b/board/amcc/canyonlands/u-boot.lds @@ -0,0 +1,146 @@ +/* + * (C) Copyright 2008 + * Wolfgang Denk, DENX Software Engineering, wd@denx.de. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +OUTPUT_ARCH(powerpc) +SEARCH_DIR(/lib); SEARCH_DIR(/usr/lib); SEARCH_DIR(/usr/local/lib); SEARCH_DIR(/usr/local/powerpc-any-elf/lib); +/* Do we need any of these for elf? + __DYNAMIC = 0; */ +SECTIONS +{ + .resetvec 0xFFFFFFFC : + { + *(.resetvec) + } = 0xffff + + .bootpg 0xFFFFF000 : + { + cpu/ppc4xx/start.o (.bootpg) + } = 0xffff + + /* Read-only sections, merged into text segment: */ + . = + SIZEOF_HEADERS; + .interp : { *(.interp) } + .hash : { *(.hash) } + .dynsym : { *(.dynsym) } + .dynstr : { *(.dynstr) } + .rel.text : { *(.rel.text) } + .rela.text : { *(.rela.text) } + .rel.data : { *(.rel.data) } + .rela.data : { *(.rela.data) } + .rel.rodata : { *(.rel.rodata) } + .rela.rodata : { *(.rela.rodata) } + .rel.got : { *(.rel.got) } + .rela.got : { *(.rela.got) } + .rel.ctors : { *(.rel.ctors) } + .rela.ctors : { *(.rela.ctors) } + .rel.dtors : { *(.rel.dtors) } + .rela.dtors : { *(.rela.dtors) } + .rel.bss : { *(.rel.bss) } + .rela.bss : { *(.rela.bss) } + .rel.plt : { *(.rel.plt) } + .rela.plt : { *(.rela.plt) } + .init : { *(.init) } + .plt : { *(.plt) } + .text : + { + /* WARNING - the following is hand-optimized to fit within */ + /* the sector layout of our flash chips! XXX FIXME XXX */ + + cpu/ppc4xx/start.o (.text) + board/amcc/canyonlands/init.o (.text) + + *(.text) + *(.fixup) + *(.got1) + } + _etext = .; + PROVIDE (etext = .); + .rodata : + { + *(.rodata) + *(.rodata1) + *(.rodata.str1.4) + } + .fini : { *(.fini) } =0 + .ctors : { *(.ctors) } + .dtors : { *(.dtors) } + + /* Read-write section, merged into data segment: */ + . = (. + 0x00FF) & 0xFFFFFF00; + _erotext = .; + PROVIDE (erotext = .); + .reloc : + { + *(.got) + _GOT2_TABLE_ = .; + *(.got2) + _FIXUP_TABLE_ = .; + *(.fixup) + } + __got2_entries = (_FIXUP_TABLE_ - _GOT2_TABLE_) >>2; + __fixup_entries = (. - _FIXUP_TABLE_)>>2; + + .data : + { + *(.data) + *(.data1) + *(.sdata) + *(.sdata2) + *(.dynamic) + CONSTRUCTORS + } + _edata = .; + PROVIDE (edata = .); + + . = .; + __u_boot_cmd_start = .; + .u_boot_cmd : { *(.u_boot_cmd) } + __u_boot_cmd_end = .; + + + . = .; + __start___ex_table = .; + __ex_table : { *(__ex_table) } + __stop___ex_table = .; + + . = ALIGN(256); + __init_begin = .; + .text.init : { *(.text.init) } + .data.init : { *(.data.init) } + . = ALIGN(256); + __init_end = .; + + __bss_start = .; + .bss : + { + *(.sbss) *(.scommon) + *(.dynbss) + *(.bss) + *(COMMON) + } + + ppcenv_assert = ASSERT(. < 0xFFFF8000, ".bss section too big, overlaps .ppcenv section. Please update your confguration: CFG_MONITOR_BASE, CFG_MONITOR_LEN and TEXT_BASE may need to be modified."); + + _end = . ; + PROVIDE (end = .); +}
Could you split it one line for one file
+SOBJS = init.o
- *(.sbss) *(.scommon)
- *(.dynbss)
- *(.bss)
- *(COMMON)
- ppcenv_assert = ASSERT(. < 0xFFFF8000, ".bss section too big, overlaps .ppcenv section. Please update your confguration: CFG_MONITOR_BASE, CFG_MONITOR_LEN and TEXT_BASE may need to be modified.");
Is it possible to split the string?
- _end = . ;
- PROVIDE (end = .);
Best Regards, J.
On Thursday 13 March 2008, Jean-Christophe PLAGNIOL-VILLARD wrote:
+SOBJS = init.o
- *(.dynbss)
- *(.bss)
- *(COMMON)
I tried by using:
+ ppcenv_assert = ASSERT(. < 0xFFFF8000, ".bss section too big, overlaps" \ + ".ppcenv section. Please update your confguration: CFG_MONITOR_BASE," \ + "CFG_MONITOR_LEN and TEXT_BASE may need to be modified.");
But multi-line strings in linker scripts don't seem to be supported. Any other ideas how to do this?
Best regards, Stefan
Signed-off-by: Stefan Roese sr@denx.de --- include/configs/canyonlands.h | 470 +++++++++++++++++++++++++++++++++++++++++ 1 files changed, 470 insertions(+), 0 deletions(-) create mode 100644 include/configs/canyonlands.h
diff --git a/include/configs/canyonlands.h b/include/configs/canyonlands.h new file mode 100644 index 0000000..6d8f230 --- /dev/null +++ b/include/configs/canyonlands.h @@ -0,0 +1,470 @@ +/* + * (C) Copyright 2008 + * Stefan Roese, DENX Software Engineering, sr@denx.de. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +/************************************************************************ + * canyonlands.h - configuration for Canyonlands (460EX) + ***********************************************************************/ +#ifndef __CONFIG_H +#define __CONFIG_H + +/*----------------------------------------------------------------------- + * High Level Configuration Options + *----------------------------------------------------------------------*/ +#define CONFIG_CANYONLANDS 1 /* Board is Canyonlands */ +#define CONFIG_440 1 +#define CONFIG_4xx 1 /* ... PPC4xx family */ +#define CONFIG_460EX 1 /* Specific PPC460EX support */ + +#define CONFIG_SYS_CLK_FREQ 66666667 /* external freq to pll */ + +#define CONFIG_BOARD_EARLY_INIT_F 1 /* Call board_early_init_f */ +#define CONFIG_BOARD_EARLY_INIT_R 1 /* Call board_early_init_r */ +#define CONFIG_MISC_INIT_R 1 /* Call misc_init_r */ + +/*----------------------------------------------------------------------- + * Base addresses -- Note these are effective addresses where the + * actual resources get mapped (not physical addresses) + *----------------------------------------------------------------------*/ +#define CFG_SDRAM_BASE 0x00000000 /* _must_ be 0 */ + +#define CFG_PCI_MEMBASE 0x80000000 /* mapped PCI memory */ +#define CFG_PCI_BASE 0xd0000000 /* internal PCI regs */ +#define CFG_PCI_TARGBASE CFG_PCI_MEMBASE + +#define CFG_PCIE_MEMBASE 0xb0000000 /* mapped PCIe memory */ +#define CFG_PCIE_MEMSIZE 0x08000000 /* smallest incr for PCIe port */ +#define CFG_PCIE_BASE 0xc4000000 /* PCIe UTL regs */ + +#define CFG_PCIE0_CFGBASE 0xc0000000 +#define CFG_PCIE1_CFGBASE 0xc1000000 +#define CFG_PCIE0_XCFGBASE 0xc3000000 +#define CFG_PCIE1_XCFGBASE 0xc3001000 + +#define CFG_PCIE0_UTLBASE 0xc08010000ULL /* 36bit physical addr */ + +/* base address of inbound PCIe window */ +#define CFG_PCIE_INBOUND_BASE 0x000000000ULL /* 36bit physical addr */ + +/* EBC stuff */ +#define CFG_NAND_ADDR 0xE0000000 +#define CFG_BCSR_BASE 0xE1000000 +#define CFG_BOOT_BASE_ADDR 0xFF000000 /* EBC Boot Space: 0xFF000000 */ +#define CFG_FLASH_BASE 0xFC000000 /* later mapped to this addr */ +#define CFG_FLASH_BASE_PHYS_H 0x4 +#define CFG_FLASH_BASE_PHYS_L 0xCC000000 +#define CFG_FLASH_BASE_PHYS (((u64)CFG_FLASH_BASE_PHYS_H << 32) | \ + (u64)CFG_FLASH_BASE_PHYS_L) +#define CFG_FLASH_SIZE (64 << 20) + +#define CFG_OCM_BASE 0xE3000000 /* OCM: 16k */ +#define CFG_SRAM_BASE 0xE8000000 /* SRAM: 256k */ +#define CFG_LOCAL_CONF_REGS 0xEF000000 + +#define CFG_PERIPHERAL_BASE 0xEF600000 /* internal peripherals */ + +#define CFG_MONITOR_BASE TEXT_BASE +#define CFG_MONITOR_LEN (384 * 1024) /* Reserve 384 kB for Monitor */ +#define CFG_MALLOC_LEN (512 * 1024) /* Reserve 512 kB for malloc()*/ + +/*----------------------------------------------------------------------- + * Initial RAM & stack pointer (placed in OCM) + *----------------------------------------------------------------------*/ +#define CFG_INIT_RAM_ADDR CFG_OCM_BASE /* OCM */ +#define CFG_INIT_RAM_END (4 << 10) +#define CFG_GBL_DATA_SIZE 256 /* num bytes initial data */ +#define CFG_GBL_DATA_OFFSET (CFG_INIT_RAM_END - CFG_GBL_DATA_SIZE) +#define CFG_INIT_SP_OFFSET CFG_GBL_DATA_OFFSET + +/*----------------------------------------------------------------------- + * Serial Port + *----------------------------------------------------------------------*/ +#define CONFIG_BAUDRATE 115200 +#define CONFIG_SERIAL_MULTI 1 +#undef CONFIG_UART1_CONSOLE /* define this if you want console on UART1 */ + +#define CFG_BAUDRATE_TABLE \ + {300, 600, 1200, 2400, 4800, 9600, 19200, 38400, 57600, 115200} + +/*----------------------------------------------------------------------- + * Environment + *----------------------------------------------------------------------*/ +/* + * Define here the location of the environment variables (FLASH). + */ +#if !defined(CONFIG_NAND_U_BOOT) && !defined(CONFIG_NAND_SPL) +#define CFG_ENV_IS_IN_FLASH 1 /* use FLASH for environment vars */ +#define CFG_NAND_CS 3 /* NAND chip connected to CSx */ +#else +#define CFG_ENV_IS_IN_NAND 1 /* use NAND for environment vars */ +#define CFG_NAND_CS 0 /* NAND chip connected to CSx */ +#endif + +/*----------------------------------------------------------------------- + * FLASH related + *----------------------------------------------------------------------*/ +#define CFG_FLASH_CFI /* The flash is CFI compatible */ +#define CFG_FLASH_CFI_DRIVER /* Use common CFI driver */ +#define CFG_FLASH_CFI_AMD_RESET 1 /* Use AMD (Spansion) reset cmd */ + +#define CFG_FLASH_BANKS_LIST {CFG_FLASH_BASE} +#define CFG_MAX_FLASH_BANKS 1 /* max number of memory banks */ +#define CFG_MAX_FLASH_SECT 512 /* max number of sectors on one chip */ + +#define CFG_FLASH_ERASE_TOUT 120000 /* Timeout for Flash Erase (in ms) */ +#define CFG_FLASH_WRITE_TOUT 500 /* Timeout for Flash Write (in ms) */ + +#define CFG_FLASH_USE_BUFFER_WRITE 1 /* use buffered writes (20x faster) */ +#define CFG_FLASH_EMPTY_INFO /* print 'E' for empty sector on flinfo */ + +#ifdef CFG_ENV_IS_IN_FLASH +#define CFG_ENV_SECT_SIZE 0x20000 /* size of one complete sector */ +#define CFG_ENV_ADDR (CFG_MONITOR_BASE - CFG_ENV_SECT_SIZE) +#define CFG_ENV_SIZE 0x4000 /* Total Size of Environment Sector */ + +/* Address and size of Redundant Environment Sector */ +#define CFG_ENV_ADDR_REDUND (CFG_ENV_ADDR - CFG_ENV_SECT_SIZE) +#define CFG_ENV_SIZE_REDUND (CFG_ENV_SIZE) +#endif /* CFG_ENV_IS_IN_FLASH */ + +/*----------------------------------------------------------------------- + * NAND-FLASH related + *----------------------------------------------------------------------*/ +#define CFG_MAX_NAND_DEVICE 1 +#define NAND_MAX_CHIPS 1 +#define CFG_NAND_BASE (CFG_NAND_ADDR + CFG_NAND_CS) +#define CFG_NAND_SELECT_DEVICE 1 /* nand driver supports mutipl. chips */ + +/*------------------------------------------------------------------------------ + * DDR SDRAM + *----------------------------------------------------------------------------*/ +#define CONFIG_SPD_EEPROM 1 /* Use SPD EEPROM for setup */ +#define SPD_EEPROM_ADDRESS {0x50, 0x51} /* SPD i2c spd addresses*/ +#define CONFIG_DDR_ECC 1 /* with ECC support */ +#define CONFIG_DDR_RQDC_FIXED 0x80000038 /* fixed value for RQDC */ + +/*----------------------------------------------------------------------- + * I2C + *----------------------------------------------------------------------*/ +#define CONFIG_HARD_I2C 1 /* I2C with hardware support */ +#undef CONFIG_SOFT_I2C /* I2C bit-banged */ +#define CFG_I2C_SPEED 400000 /* I2C speed and slave address */ +#define CFG_I2C_SLAVE 0x7F + +#define CFG_I2C_MULTI_EEPROMS +#define CFG_I2C_EEPROM_ADDR (0xa8>>1) +#define CFG_I2C_EEPROM_ADDR_LEN 1 +#define CFG_EEPROM_PAGE_WRITE_ENABLE +#define CFG_EEPROM_PAGE_WRITE_BITS 3 +#define CFG_EEPROM_PAGE_WRITE_DELAY_MS 10 + +/* I2C SYSMON (LM75, AD7414 is almost compatible) */ +#define CONFIG_DTT_LM75 1 /* ON Semi's LM75 */ +#define CONFIG_DTT_AD7414 1 /* use AD7414 */ +#define CONFIG_DTT_SENSORS {0} /* Sensor addresses */ +#define CFG_DTT_MAX_TEMP 70 +#define CFG_DTT_LOW_TEMP -30 +#define CFG_DTT_HYSTERESIS 3 + +/* RTC configuration */ +#define CONFIG_RTC_M41T62 1 +#define CFG_I2C_RTC_ADDR 0x68 + +/*----------------------------------------------------------------------- + * Ethernet + *----------------------------------------------------------------------*/ +#define CONFIG_IBM_EMAC4_V4 1 +#define CONFIG_MII 1 /* MII PHY management */ +#define CONFIG_PHY_ADDR 0 /* PHY address, See schematics */ +#define CONFIG_PHY1_ADDR 1 +#define CONFIG_HAS_ETH0 1 +#define CONFIG_HAS_ETH1 1 /* add support for "eth1addr" */ +#define CONFIG_NET_MULTI 1 + +#define CONFIG_PHY_RESET 1 /* reset phy upon startup */ +#define CONFIG_PHY_GIGE 1 /* Include GbE speed/duplex detection */ +#define CONFIG_PHY_DYNAMIC_ANEG 1 + +#define CFG_RX_ETH_BUFFER 32 /* Number of ethernet rx buffers & descriptors */ + +#define CONFIG_PREBOOT "echo;" \ + "echo Type "run flash_nfs" to mount root filesystem over NFS;" \ + "echo" + +#undef CONFIG_BOOTARGS + +#define CONFIG_EXTRA_ENV_SETTINGS \ + "netdev=eth0\0" \ + "hostname=canyonlands\0" \ + "nfsargs=setenv bootargs root=/dev/nfs rw " \ + "nfsroot=${serverip}:${rootpath}\0" \ + "ramargs=setenv bootargs root=/dev/ram rw\0" \ + "addip=setenv bootargs ${bootargs} " \ + "ip=${ipaddr}:${serverip}:${gatewayip}:${netmask}" \ + ":${hostname}:${netdev}:off panic=1\0" \ + "addtty=setenv bootargs ${bootargs} console=ttyS0,${baudrate}\0"\ + "net_nfs=tftp 200000 ${bootfile};" \ + "run nfsargs addip addtty;" \ + "bootm 200000\0" \ + "net_nfs_fdt=tftp 200000 ${bootfile};" \ + "tftp ${fdt_addr} ${fdt_file};" \ + "run nfsargs addip addtty;" \ + "bootm 200000 - ${fdt_addr}\0" \ + "flash_nfs=run nfsargs addip addtty;" \ + "bootm ${kernel_addr}\0" \ + "flash_self=run ramargs addip addtty;" \ + "bootm ${kernel_addr} ${ramdisk_addr}\0" \ + "rootpath=/opt/eldk/ppc_4xxFP\0" \ + "bootfile=canyonlands/uImage\0" \ + "fdt_file=canyonlands/canyonlands.dtb\0" \ + "fdt_addr=400000\0" \ + "kernel_addr=fc000000\0" \ + "ramdisk_addr=fc200000\0" \ + "initrd_high=30000000\0" \ + "load=tftp 200000 canyonlands/u-boot.bin\0" \ + "update=protect off fffa0000 ffffffff;era fffa0000 ffffffff;" \ + "cp.b ${fileaddr} fffa0000 ${filesize};" \ + "setenv filesize;saveenv\0" \ + "upd=run load update\0" \ + "nload=tftp 200000 canyonlands/u-boot-nand.bin\0" \ + "nupdate=nand erase 0 60000;nand write 200000 0 60000;" \ + "setenv filesize;saveenv\0" \ + "nupd=run nload nupdate\0" \ + "pciconfighost=1\0" \ + "pcie_mode=RP:RP\0" \ + "" +#define CONFIG_BOOTCOMMAND "run flash_self" + +#define CONFIG_BOOTDELAY 5 /* autoboot after 5 seconds */ + +#define CONFIG_LOADS_ECHO 1 /* echo on for serial download */ +#define CFG_LOADS_BAUD_CHANGE /* allow baudrate change */ + +/* + * BOOTP options + */ +#define CONFIG_BOOTP_BOOTFILESIZE +#define CONFIG_BOOTP_BOOTPATH +#define CONFIG_BOOTP_GATEWAY +#define CONFIG_BOOTP_HOSTNAME +#define CONFIG_BOOTP_SUBNETMASK + +/* + * Command line configuration. + */ +#include <config_cmd_default.h> + +#define CONFIG_CMD_ASKENV +#define CONFIG_CMD_DATE +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_DTT +#define CONFIG_CMD_DIAG +#define CONFIG_CMD_EEPROM +#define CONFIG_CMD_ELF +#define CONFIG_CMD_FAT +#define CONFIG_CMD_I2C +#define CONFIG_CMD_IRQ +#define CONFIG_CMD_MII +#define CONFIG_CMD_NAND +#define CONFIG_CMD_NET +#define CONFIG_CMD_NFS +#define CONFIG_CMD_PCI +#define CONFIG_CMD_PING +#define CONFIG_CMD_REGINFO +#define CONFIG_CMD_SDRAM + +/*----------------------------------------------------------------------- + * Miscellaneous configurable options + *----------------------------------------------------------------------*/ +#define CFG_LONGHELP /* undef to save memory */ +#define CFG_PROMPT "=> " /* Monitor Command Prompt */ +#if defined(CONFIG_CMD_KGDB) +#define CFG_CBSIZE 1024 /* Console I/O Buffer Size */ +#else +#define CFG_CBSIZE 256 /* Console I/O Buffer Size */ +#endif +#define CFG_PBSIZE (CFG_CBSIZE+sizeof(CFG_PROMPT)+16) /* Print Buffer Size */ +#define CFG_MAXARGS 16 /* max number of command args */ +#define CFG_BARGSIZE CFG_CBSIZE /* Boot Argument Buffer Size */ + +#define CFG_MEMTEST_START 0x0400000 /* memtest works on */ +#define CFG_MEMTEST_END 0x0C00000 /* 4 ... 12 MB in DRAM */ + +#define CFG_LOAD_ADDR 0x100000 /* default load address */ +#define CFG_EXTBDINFO 1 /* To use extended board_into (bd_t) */ + +#define CFG_HZ 1000 /* decrementer freq: 1 ms ticks */ + +#define CONFIG_CMDLINE_EDITING 1 /* add command line history */ +#define CONFIG_AUTO_COMPLETE 1 /* add autocompletion support */ +#define CONFIG_LOOPW 1 /* enable loopw command */ +#define CONFIG_MX_CYCLIC 1 /* enable mdc/mwc commands */ +#define CONFIG_ZERO_BOOTDELAY_CHECK /* check for keypress on bootdelay==0 */ +#define CONFIG_VERSION_VARIABLE 1 /* include version env variable */ +#define CFG_CONSOLE_INFO_QUIET 1 /* don't print console @ startup*/ + +#define CFG_HUSH_PARSER 1 /* Use the HUSH parser */ +#ifdef CFG_HUSH_PARSER +#define CFG_PROMPT_HUSH_PS2 "> " +#endif + +/*----------------------------------------------------------------------- + * PCI stuff + *----------------------------------------------------------------------*/ +/* General PCI */ +#define CONFIG_PCI /* include pci support */ +#define CONFIG_PCI_PNP /* do pci plug-and-play */ +#define CONFIG_PCI_SCAN_SHOW /* show pci devices on startup */ +#define CONFIG_PCI_CONFIG_HOST_BRIDGE + +/* Board-specific PCI */ +#define CFG_PCI_TARGET_INIT /* let board init pci target */ +#undef CFG_PCI_MASTER_INIT + +#define CFG_PCI_SUBSYS_VENDORID 0x1014 /* IBM */ +#define CFG_PCI_SUBSYS_DEVICEID 0xcafe /* Whatever */ + +/* + * For booting Linux, the board info and command line data + * have to be in the first 8 MB of memory, since this is + * the maximum mapped by the Linux kernel during initialization. + */ +#define CFG_BOOTMAPSZ (8 << 20) /* Initial Memory map for Linux */ + +/* + * Internal Definitions + */ +#if defined(CONFIG_CMD_KGDB) +#define CONFIG_KGDB_BAUDRATE 230400 /* speed to run kgdb serial port */ +#define CONFIG_KGDB_SER_INDEX 2 /* which serial port to use */ +#endif + +/*----------------------------------------------------------------------- + * External Bus Controller (EBC) Setup + *----------------------------------------------------------------------*/ + +/* + * Canyonlands has 64MBytes of NOR FLASH (Spansion 29GL512), but the + * boot EBC mapping only supports a maximum of 16MBytes + * (4.ff00.0000 - 4.ffff.ffff). + * To solve this problem, the FLASH has to get remapped to another + * EBC address which accepts bigger regions: + * + * 0xfc00.0000 -> 4.cc00.0000 + * + * For this we have to remap the CS0 and re-relocate the envrironment, + * since the original FLASH location which was needed upon startup is + * now not correct anymore. + */ + +/* Memory Bank 0 (NOR-FLASH) initialization */ +#define CFG_EBC_PB0AP 0x10055e00 +#define CFG_EBC_PB0CR (CFG_BOOT_BASE_ADDR | 0x9a000) + +/* Memory Bank 2 (CPLD) initialization */ +#define CFG_EBC_PB2AP 0x00804240 +#define CFG_EBC_PB2CR (CFG_BCSR_BASE | 0x18000) /* BAS=CPLD,BS=1M,BU=RW,BW=32bit */ + +/* Memory Bank 3 (NAND-FLASH) initialization */ +#define CFG_EBC_PB3AP 0x018003c0 +#define CFG_EBC_PB3CR (CFG_NAND_ADDR | 0x1E000) /* BAS=NAND,BS=1MB,BU=R/W,BW=32bit*/ + +#define CFG_EBC_CFG 0xB8400000 /* EBC0_CFG */ + +/* + * PPC4xx GPIO Configuration + */ +#define CFG_4xx_GPIO_TABLE { /* Out GPIO Alternate1 Alternate2 Alternate3 */ \ +{ \ +/* GPIO Core 0 */ \ +{GPIO0_BASE, GPIO_BI , GPIO_ALT2, GPIO_OUT_0}, /* GPIO0 GMC1TxD(0) USB2HostD(0) */ \ +{GPIO0_BASE, GPIO_BI , GPIO_ALT2, GPIO_OUT_0}, /* GPIO1 GMC1TxD(1) USB2HostD(1) */ \ +{GPIO0_BASE, GPIO_BI , GPIO_ALT2, GPIO_OUT_0}, /* GPIO2 GMC1TxD(2) USB2HostD(2) */ \ +{GPIO0_BASE, GPIO_BI , GPIO_ALT2, GPIO_OUT_0}, /* GPIO3 GMC1TxD(3) USB2HostD(3) */ \ +{GPIO0_BASE, GPIO_BI , GPIO_ALT2, GPIO_OUT_0}, /* GPIO4 GMC1TxD(4) USB2HostD(4) */ \ +{GPIO0_BASE, GPIO_BI , GPIO_ALT2, GPIO_OUT_0}, /* GPIO5 GMC1TxD(5) USB2HostD(5) */ \ +{GPIO0_BASE, GPIO_BI , GPIO_ALT2, GPIO_OUT_0}, /* GPIO6 GMC1TxD(6) USB2HostD(6) */ \ +{GPIO0_BASE, GPIO_BI , GPIO_ALT2, GPIO_OUT_0}, /* GPIO7 GMC1TxD(7) USB2HostD(7) */ \ +{GPIO0_BASE, GPIO_BI , GPIO_ALT2, GPIO_OUT_0}, /* GPIO8 GMC1RxD(0) USB2OTGD(0) */ \ +{GPIO0_BASE, GPIO_BI , GPIO_ALT2, GPIO_OUT_0}, /* GPIO9 GMC1RxD(1) USB2OTGD(1) */ \ +{GPIO0_BASE, GPIO_BI , GPIO_ALT2, GPIO_OUT_0}, /* GPIO10 GMC1RxD(2) USB2OTGD(2) */ \ +{GPIO0_BASE, GPIO_BI , GPIO_ALT2, GPIO_OUT_0}, /* GPIO11 GMC1RxD(3) USB2OTGD(3) */ \ +{GPIO0_BASE, GPIO_BI , GPIO_ALT2, GPIO_OUT_0}, /* GPIO12 GMC1RxD(4) USB2OTGD(4) */ \ +{GPIO0_BASE, GPIO_BI , GPIO_ALT2, GPIO_OUT_0}, /* GPIO13 GMC1RxD(5) USB2OTGD(5) */ \ +{GPIO0_BASE, GPIO_BI , GPIO_ALT2, GPIO_OUT_0}, /* GPIO14 GMC1RxD(6) USB2OTGD(6) */ \ +{GPIO0_BASE, GPIO_BI , GPIO_ALT2, GPIO_OUT_0}, /* GPIO15 GMC1RxD(7) USB2OTGD(7) */ \ +{GPIO0_BASE, GPIO_OUT, GPIO_ALT2, GPIO_OUT_0}, /* GPIO16 GMC1TxER USB2HostStop */ \ +{GPIO0_BASE, GPIO_IN , GPIO_ALT2, GPIO_OUT_0}, /* GPIO17 GMC1CD USB2HostNext */ \ +{GPIO0_BASE, GPIO_IN , GPIO_ALT2, GPIO_OUT_0}, /* GPIO18 GMC1RxER USB2HostDir */ \ +{GPIO0_BASE, GPIO_OUT, GPIO_ALT2, GPIO_OUT_0}, /* GPIO19 GMC1TxEN USB2OTGStop */ \ +{GPIO0_BASE, GPIO_IN , GPIO_ALT2, GPIO_OUT_0}, /* GPIO20 GMC1CRS USB2OTGNext */ \ +{GPIO0_BASE, GPIO_IN , GPIO_ALT2, GPIO_OUT_0}, /* GPIO21 GMC1RxDV USB2OTGDir */ \ +{GPIO0_BASE, GPIO_IN , GPIO_ALT1, GPIO_OUT_0}, /* GPIO22 NFRDY */ \ +{GPIO0_BASE, GPIO_IN , GPIO_ALT1, GPIO_OUT_0}, /* GPIO23 NFREN */ \ +{GPIO0_BASE, GPIO_IN , GPIO_ALT1, GPIO_OUT_0}, /* GPIO24 NFWEN */ \ +{GPIO0_BASE, GPIO_IN , GPIO_ALT1, GPIO_OUT_0}, /* GPIO25 NFCLE */ \ +{GPIO0_BASE, GPIO_IN , GPIO_ALT1, GPIO_OUT_0}, /* GPIO26 NFALE */ \ +{GPIO0_BASE, GPIO_IN , GPIO_ALT1, GPIO_OUT_0}, /* GPIO27 IRQ(0) */ \ +{GPIO0_BASE, GPIO_IN , GPIO_ALT1, GPIO_OUT_0}, /* GPIO28 IRQ(1) */ \ +{GPIO0_BASE, GPIO_IN , GPIO_ALT1, GPIO_OUT_0}, /* GPIO29 IRQ(2) */ \ +{GPIO0_BASE, GPIO_OUT, GPIO_SEL , GPIO_OUT_1}, /* GPIO30 PerPar0 DMAReq2 IRQ(7)*/ \ +{GPIO0_BASE, GPIO_OUT, GPIO_SEL , GPIO_OUT_1}, /* GPIO31 PerPar1 DMAAck2 IRQ(8)*/ \ +}, \ +{ \ +/* GPIO Core 1 */ \ +{GPIO1_BASE, GPIO_OUT, GPIO_SEL , GPIO_OUT_1}, /* GPIO32 PerPar2 EOT2/TC2 IRQ(9)*/ \ +{GPIO1_BASE, GPIO_OUT, GPIO_SEL , GPIO_OUT_1}, /* GPIO33 PerPar3 DMAReq3 IRQ(4)*/ \ +{GPIO1_BASE, GPIO_OUT, GPIO_ALT3, GPIO_OUT_1}, /* GPIO34 UART0_DCD_N UART1_DSR_CTS_N UART2_SOUT*/ \ +{GPIO1_BASE, GPIO_IN , GPIO_ALT3, GPIO_OUT_0}, /* GPIO35 UART0_8PIN_DSR_N UART1_RTS_DTR_N UART2_SIN*/ \ +{GPIO1_BASE, GPIO_IN , GPIO_ALT3, GPIO_OUT_0}, /* GPIO36 UART0_8PIN_CTS_N DMAAck3 UART3_SIN*/ \ +{GPIO1_BASE, GPIO_BI , GPIO_ALT2, GPIO_OUT_0}, /* GPIO37 UART0_RTS_N EOT3/TC3 UART3_SOUT*/ \ +{GPIO1_BASE, GPIO_OUT, GPIO_ALT2, GPIO_OUT_1}, /* GPIO38 UART0_DTR_N UART1_SOUT */ \ +{GPIO1_BASE, GPIO_IN , GPIO_ALT2, GPIO_OUT_0}, /* GPIO39 UART0_RI_N UART1_SIN */ \ +{GPIO1_BASE, GPIO_IN , GPIO_ALT1, GPIO_OUT_0}, /* GPIO40 IRQ(3) */ \ +{GPIO1_BASE, GPIO_OUT, GPIO_ALT1, GPIO_OUT_0}, /* GPIO41 CS(1) */ \ +{GPIO1_BASE, GPIO_OUT, GPIO_ALT1, GPIO_OUT_0}, /* GPIO42 CS(2) */ \ +{GPIO1_BASE, GPIO_OUT, GPIO_ALT1, GPIO_OUT_0}, /* GPIO43 CS(3) DMAReq1 IRQ(10)*/ \ +{GPIO1_BASE, GPIO_IN , GPIO_ALT3, GPIO_OUT_0}, /* GPIO44 CS(4) DMAAck1 IRQ(11)*/ \ +{GPIO1_BASE, GPIO_IN , GPIO_ALT3, GPIO_OUT_0}, /* GPIO45 CS(5) EOT/TC1 IRQ(12)*/ \ +{GPIO1_BASE, GPIO_OUT, GPIO_ALT1, GPIO_OUT_0}, /* GPIO46 PerAddr(5) DMAReq0 IRQ(13)*/ \ +{GPIO1_BASE, GPIO_OUT, GPIO_ALT1, GPIO_OUT_0}, /* GPIO47 PerAddr(6) DMAAck0 IRQ(14)*/ \ +{GPIO1_BASE, GPIO_OUT, GPIO_ALT1, GPIO_OUT_0}, /* GPIO48 PerAddr(7) EOT/TC0 IRQ(15)*/ \ +{GPIO1_BASE, GPIO_IN , GPIO_SEL , GPIO_OUT_0}, /* GPIO49 Unselect via TraceSelect Bit */ \ +{GPIO1_BASE, GPIO_IN , GPIO_SEL , GPIO_OUT_0}, /* GPIO50 Unselect via TraceSelect Bit */ \ +{GPIO1_BASE, GPIO_IN , GPIO_SEL , GPIO_OUT_0}, /* GPIO51 Unselect via TraceSelect Bit */ \ +{GPIO1_BASE, GPIO_IN , GPIO_SEL , GPIO_OUT_0}, /* GPIO52 Unselect via TraceSelect Bit */ \ +{GPIO1_BASE, GPIO_IN , GPIO_SEL , GPIO_OUT_0}, /* GPIO53 Unselect via TraceSelect Bit */ \ +{GPIO1_BASE, GPIO_IN , GPIO_SEL , GPIO_OUT_0}, /* GPIO54 Unselect via TraceSelect Bit */ \ +{GPIO1_BASE, GPIO_IN , GPIO_SEL , GPIO_OUT_0}, /* GPIO55 Unselect via TraceSelect Bit */ \ +{GPIO1_BASE, GPIO_IN , GPIO_SEL , GPIO_OUT_0}, /* GPIO56 Unselect via TraceSelect Bit */ \ +{GPIO1_BASE, GPIO_IN , GPIO_SEL , GPIO_OUT_0}, /* GPIO57 Unselect via TraceSelect Bit */ \ +{GPIO1_BASE, GPIO_IN , GPIO_SEL , GPIO_OUT_0}, /* GPIO58 Unselect via TraceSelect Bit */ \ +{GPIO1_BASE, GPIO_IN , GPIO_SEL , GPIO_OUT_0}, /* GPIO59 Unselect via TraceSelect Bit */ \ +{GPIO1_BASE, GPIO_IN , GPIO_SEL , GPIO_OUT_0}, /* GPIO60 Unselect via TraceSelect Bit */ \ +{GPIO1_BASE, GPIO_IN , GPIO_SEL , GPIO_OUT_0}, /* GPIO61 Unselect via TraceSelect Bit */ \ +{GPIO1_BASE, GPIO_IN , GPIO_SEL , GPIO_OUT_0}, /* GPIO62 Unselect via TraceSelect Bit */ \ +{GPIO1_BASE, GPIO_IN , GPIO_SEL , GPIO_OUT_0}, /* GPIO63 Unselect via TraceSelect Bit */ \ +} \ +} + +/* pass open firmware flat tree */ +#define CONFIG_OF_LIBFDT 1 +#define CONFIG_OF_BOARD_SETUP 1 + +#endif /* __CONFIG_H */
- (C) Copyright 2008
- Stefan Roese, DENX Software Engineering, sr@denx.de.
- MA 02111-1307 USA
- canyonlands.h - configuration for Canyonlands (460EX)
- High Level Configuration Options
- Base addresses -- Note these are effective addresses where the
- actual resources get mapped (not physical addresses)
- Initial RAM & stack pointer (placed in OCM)
- Serial Port
- {300, 600, 1200, 2400, 4800, 9600, 19200, 38400, 57600, 115200}
- Environment
- Define here the location of the environment variables (FLASH).
- FLASH related
^ Whitespace please remove
- NAND-FLASH related
- DDR SDRAM
- I2C
Best Regards, J
<snip>
Will do.
Thanks.
Signed-off-by: Stefan Roese sr@denx.de --- MAINTAINERS | 1 + MAKEALL | 1 + Makefile | 3 +++ include/asm-ppc/gpio.h | 5 +++-- 4 files changed, 8 insertions(+), 2 deletions(-)
diff --git a/MAINTAINERS b/MAINTAINERS index dc13580..f248fff 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -319,6 +319,7 @@ Stefan Roese sr@denx.de alpr PPC440GX bamboo PPC440EP bunbinga PPC405EP + canyonlands PPC460EX ebony PPC440GP haleakala PPC405EXr katmai PPC440SPe diff --git a/MAKEALL b/MAKEALL index 0e1c0cb..f3b1968 100755 --- a/MAKEALL +++ b/MAKEALL @@ -165,6 +165,7 @@ LIST_4xx=" \ bamboo_nand \ bubinga \ CANBT \ + canyonlands \ CMS700 \ CPCI2DP \ CPCI405 \ diff --git a/Makefile b/Makefile index 90198f6..b46e43a 100644 --- a/Makefile +++ b/Makefile @@ -1170,6 +1170,9 @@ bubinga_config: unconfig CANBT_config: unconfig @$(MKCONFIG) $(@:_config=) ppc ppc4xx canbt esd
+canyonlands_config: unconfig + @$(MKCONFIG) $(@:_config=) ppc ppc4xx canyonlands amcc + CATcenter_config \ CATcenter_25_config \ CATcenter_33_config: unconfig diff --git a/include/asm-ppc/gpio.h b/include/asm-ppc/gpio.h index c3a4a88..fc05dc0 100644 --- a/include/asm-ppc/gpio.h +++ b/include/asm-ppc/gpio.h @@ -1,5 +1,5 @@ /* - * (C) Copyright 2007 + * (C) Copyright 2007-2008 * Stefan Roese, DENX Software Engineering, sr@denx.de. * * See file CREDITS for list of people who contributed to this @@ -27,7 +27,8 @@ /* 4xx PPC's have 2 GPIO controllers */ #if defined(CONFIG_405EZ) || \ defined(CONFIG_440EP) || defined(CONFIG_440GR) || \ - defined(CONFIG_440EPX) || defined(CONFIG_440GRX) + defined(CONFIG_440EPX) || defined(CONFIG_440GRX) || \ + defined(CONFIG_460EX) || defined(CONFIG_460GT) #define GPIO_GROUP_MAX 2 #else #define GPIO_GROUP_MAX 1
460EX doesn't support a fixed bootstrap option to boot from 512 byte page NAND devices. The only bootstrap option for NAND booting is option F for 2k page devices. So to boot from a 512 bype page device, the I2C bootstrap EEPROM needs to be programmed accordingly.
This patch adds basic NAND booting support for the AMCC Canyonlands aval board and also adds support to the "bootstrap" command, to enable NAND booting I2C setting.
Tested with 512 byte page NAND device (32MByte) on Canyonlands.
Signed-off-by: Stefan Roese sr@denx.de --- MAKEALL | 1 + Makefile | 8 ++ board/amcc/canyonlands/Makefile | 2 +- board/amcc/canyonlands/bootstrap.c | 23 +++-- board/amcc/canyonlands/canyonlands.c | 27 +++++- board/amcc/canyonlands/init.S | 7 +- board/amcc/canyonlands/u-boot-nand.lds | 137 ++++++++++++++++++++++++++ cpu/ppc4xx/start.S | 8 ++- include/configs/canyonlands.h | 89 +++++++++++++++-- nand_spl/board/amcc/canyonlands/Makefile | 100 +++++++++++++++++++ nand_spl/board/amcc/canyonlands/config.mk | 49 +++++++++ nand_spl/board/amcc/canyonlands/ddr2_fixed.c | 96 ++++++++++++++++++ nand_spl/board/amcc/canyonlands/u-boot.lds | 65 ++++++++++++ 13 files changed, 586 insertions(+), 26 deletions(-) create mode 100644 board/amcc/canyonlands/u-boot-nand.lds create mode 100644 nand_spl/board/amcc/canyonlands/Makefile create mode 100644 nand_spl/board/amcc/canyonlands/config.mk create mode 100644 nand_spl/board/amcc/canyonlands/ddr2_fixed.c create mode 100644 nand_spl/board/amcc/canyonlands/u-boot.lds
diff --git a/MAKEALL b/MAKEALL index f3b1968..15b011d 100755 --- a/MAKEALL +++ b/MAKEALL @@ -166,6 +166,7 @@ LIST_4xx=" \ bubinga \ CANBT \ canyonlands \ + canyonlands_nand \ CMS700 \ CPCI2DP \ CPCI405 \ diff --git a/Makefile b/Makefile index b46e43a..730448a 100644 --- a/Makefile +++ b/Makefile @@ -1173,6 +1173,14 @@ CANBT_config: unconfig canyonlands_config: unconfig @$(MKCONFIG) $(@:_config=) ppc ppc4xx canyonlands amcc
+canyonlands_nand_config: unconfig + @mkdir -p $(obj)include $(obj)board/amcc/canyonlands + @mkdir -p $(obj)nand_spl/board/amcc/canyonlands + @echo "#define CONFIG_NAND_U_BOOT" > $(obj)include/config.h + @$(MKCONFIG) -n $@ -a canyonlands ppc ppc4xx canyonlands amcc + @echo "TEXT_BASE = 0x01000000" > $(obj)board/amcc/canyonlands/config.tmp + @echo "CONFIG_NAND_U_BOOT = y" >> $(obj)include/config.mk + CATcenter_config \ CATcenter_25_config \ CATcenter_33_config: unconfig diff --git a/board/amcc/canyonlands/Makefile b/board/amcc/canyonlands/Makefile index a3385c7..3238c15 100644 --- a/board/amcc/canyonlands/Makefile +++ b/board/amcc/canyonlands/Makefile @@ -33,7 +33,7 @@ OBJS := $(addprefix $(obj),$(COBJS)) SOBJS := $(addprefix $(obj),$(SOBJS))
$(LIB): $(OBJS) $(SOBJS) - $(AR) $(ARFLAGS) $@ $(OBJS) + $(AR) $(ARFLAGS) $@ $(OBJS) $(SOBJS)
clean: rm -f $(SOBJS) $(OBJS) diff --git a/board/amcc/canyonlands/bootstrap.c b/board/amcc/canyonlands/bootstrap.c index 3f5822e..37fa1c9 100644 --- a/board/amcc/canyonlands/bootstrap.c +++ b/board/amcc/canyonlands/bootstrap.c @@ -28,7 +28,7 @@ #include <asm/io.h>
/* - * NOR and NAND boot options change bytes 6, 7, 8, 9, 11. The + * NOR and NAND boot options change bytes 5, 6, 8, 9, 11. The * values are independent of the rest of the clock settings. */
@@ -45,14 +45,14 @@ static char *config_labels[] = {
static u8 boot_configs[][17] = { { - (NOR_COMPATIBLE), + (NAND_COMPATIBLE | NOR_COMPATIBLE), 0x86, 0x80, 0xce, 0x1f, 0x79, 0x80, 0x00, 0xa0, 0x40, 0x08, - 0x23, 0x50, 0x0d, 0x95, 0x00, 0x00 + 0x23, 0x50, 0x0d, 0x05, 0x00, 0x00 }, { - (NOR_COMPATIBLE), + (NAND_COMPATIBLE | NOR_COMPATIBLE), 0x86, 0x80, 0xba, 0x14, 0x99, 0x80, 0x00, 0xa0, 0x40, 0x08, - 0x23, 0x50, 0x0d, 0x95, 0x00, 0x00 + 0x23, 0x50, 0x0d, 0x05, 0x00, 0x00 }, { 0, @@ -61,10 +61,10 @@ static u8 boot_configs[][17] = { };
/* - * Bytes 6,8,9,11 change for NAND boot + * Bytes 5,6,8,9,11 change for NAND boot */ static u8 nand_boot[] = { - 0xd0, 0xa0, 0x68, 0x58 + 0x90, 0x01, 0xa0, 0x68, 0x58 };
static int do_bootstrap(cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) @@ -146,10 +146,11 @@ static int do_bootstrap(cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) buf = &boot_configs[x][1];
if (b_nand) { - buf[6] = nand_boot[0]; - buf[8] = nand_boot[1]; - buf[9] = nand_boot[2]; - buf[11] = nand_boot[3]; + buf[5] = nand_boot[0]; + buf[6] = nand_boot[1]; + buf[8] = nand_boot[2]; + buf[9] = nand_boot[3]; + buf[11] = nand_boot[4]; }
if (i2c_write(I2C_EEPROM_ADDR, 0, 1, buf, 16) != 0) diff --git a/board/amcc/canyonlands/canyonlands.c b/board/amcc/canyonlands/canyonlands.c index 8292d2d..3551429 100644 --- a/board/amcc/canyonlands/canyonlands.c +++ b/board/amcc/canyonlands/canyonlands.c @@ -134,6 +134,18 @@ u32 ddr_clktr(u32 default_val) { return (SDRAM_CLKTR_CLKP_90_DEG_ADV); }
+#if defined(CONFIG_NAND_U_BOOT) +/* + * NAND booting U-Boot version uses a fixed initialization, since the whole + * I2C SPD DIMM autodetection/calibration doesn't fit into the 4k of boot + * code. + */ +long int initdram(int board_type) +{ + return CFG_MBYTES_SDRAM << 20; +} +#endif + #if defined(CFG_DRAM_TEST) int testdram(void) { @@ -308,14 +320,14 @@ int board_early_init_r (void) * EBC address which accepts bigger regions: * * 0xfc00.0000 -> 4.cc00.0000 - * - * For this we have to remap the CS0 and re-relocate the envrironment, - * since the original FLASH location which was needed upon startup is - * now not correct anymore. */
/* Remap the NOR FLASH to 0xcc00.0000 ... 0xcfff.ffff */ +#if defined(CONFIG_NAND_U_BOOT) || defined(CONFIG_NAND_SPL) + mtebc(pb3cr, CFG_FLASH_BASE_PHYS_L | 0xda000); +#else mtebc(pb0cr, CFG_FLASH_BASE_PHYS_L | 0xda000); +#endif
/* Remove TLB entry of boot EBC mapping */ remove_tlb(CFG_BOOT_BASE_ADDR, 16 << 20); @@ -329,6 +341,13 @@ int board_early_init_r (void) * 0xfc00.0000 is possible */
+ /* + * Clear potential errors resulting from auto-calibration. + * If not done, then we could get an interrupt later on when + * exceptions are enabled. + */ + set_mcsr(get_mcsr()); + return 0; }
diff --git a/board/amcc/canyonlands/init.S b/board/amcc/canyonlands/init.S index 5d48847..b7cac23 100644 --- a/board/amcc/canyonlands/init.S +++ b/board/amcc/canyonlands/init.S @@ -46,7 +46,12 @@ tlbtab: * use the speed up boot process. It is patched after relocation to * enable SA_I */ +#ifndef CONFIG_NAND_SPL tlbentry(CFG_BOOT_BASE_ADDR, SZ_16M, CFG_BOOT_BASE_ADDR, 4, AC_R|AC_W|AC_X|SA_G) /* TLB 0 */ +#else + tlbentry(CFG_NAND_BOOT_SPL_SRC, SZ_4K, CFG_NAND_BOOT_SPL_SRC, 4, AC_R|AC_W|AC_X|SA_G) + tlbentry(CFG_SDRAM_BASE, SZ_256M, CFG_SDRAM_BASE, 0, AC_R|AC_W|AC_X|SA_G|SA_I) +#endif
/* * TLB entries for SDRAM are not needed on this platform. @@ -78,7 +83,7 @@ tlbtab: tlbentry(CFG_BCSR_BASE, SZ_1K, CFG_BCSR_BASE, 4, AC_R|AC_W|SA_G|SA_I)
/* TLB-entry for OCM */ - tlbentry(CFG_OCM_BASE, SZ_4K, 0x00040000, 4, AC_R|AC_W|AC_X) + tlbentry(CFG_OCM_BASE, SZ_16K, 0x00040000, 4, AC_R|AC_W|AC_X|SA_I)
/* TLB-entry for Local Configuration registers => peripherals */ tlbentry(CFG_LOCAL_CONF_REGS, SZ_16M, CFG_LOCAL_CONF_REGS, 4, AC_R|AC_W|AC_X|SA_G|SA_I) diff --git a/board/amcc/canyonlands/u-boot-nand.lds b/board/amcc/canyonlands/u-boot-nand.lds new file mode 100644 index 0000000..12a5dcf --- /dev/null +++ b/board/amcc/canyonlands/u-boot-nand.lds @@ -0,0 +1,137 @@ +/* + * (C) Copyright 2008 + * Stefan Roese, DENX Software Engineering, sr@denx.de. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +OUTPUT_ARCH(powerpc) +SEARCH_DIR(/lib); SEARCH_DIR(/usr/lib); SEARCH_DIR(/usr/local/lib); SEARCH_DIR(/usr/local/powerpc-any-elf/lib); +SECTIONS +{ + /* Read-only sections, merged into text segment: */ + . = + SIZEOF_HEADERS; + .interp : { *(.interp) } + .hash : { *(.hash) } + .dynsym : { *(.dynsym) } + .dynstr : { *(.dynstr) } + .rel.text : { *(.rel.text) } + .rela.text : { *(.rela.text) } + .rel.data : { *(.rel.data) } + .rela.data : { *(.rela.data) } + .rel.rodata : { *(.rel.rodata) } + .rela.rodata : { *(.rela.rodata) } + .rel.got : { *(.rel.got) } + .rela.got : { *(.rela.got) } + .rel.ctors : { *(.rel.ctors) } + .rela.ctors : { *(.rela.ctors) } + .rel.dtors : { *(.rel.dtors) } + .rela.dtors : { *(.rela.dtors) } + .rel.bss : { *(.rel.bss) } + .rela.bss : { *(.rela.bss) } + .rel.plt : { *(.rel.plt) } + .rela.plt : { *(.rela.plt) } + .init : { *(.init) } + .plt : { *(.plt) } + .text : + { + /* WARNING - the following is hand-optimized to fit within */ + /* the sector layout of our flash chips! XXX FIXME XXX */ + + cpu/ppc4xx/start.o (.text) + + /* Align to next NAND block */ + . = ALIGN(0x4000); + common/environment.o (.ppcenv) + /* Keep some space here for redundant env and potential bad env blocks */ + . = ALIGN(0x10000); + + *(.text) + *(.fixup) + *(.got1) + } + _etext = .; + PROVIDE (etext = .); + .rodata : + { + *(.rodata) + *(.rodata1) + *(.rodata.str1.4) + } + .fini : { *(.fini) } =0 + .ctors : { *(.ctors) } + .dtors : { *(.dtors) } + + /* Read-write section, merged into data segment: */ + . = (. + 0x00FF) & 0xFFFFFF00; + _erotext = .; + PROVIDE (erotext = .); + .reloc : + { + *(.got) + _GOT2_TABLE_ = .; + *(.got2) + _FIXUP_TABLE_ = .; + *(.fixup) + } + __got2_entries = (_FIXUP_TABLE_ - _GOT2_TABLE_) >>2; + __fixup_entries = (. - _FIXUP_TABLE_)>>2; + + .data : + { + *(.data) + *(.data1) + *(.sdata) + *(.sdata2) + *(.dynamic) + CONSTRUCTORS + } + _edata = .; + PROVIDE (edata = .); + + . = .; + __u_boot_cmd_start = .; + .u_boot_cmd : { *(.u_boot_cmd) } + __u_boot_cmd_end = .; + + + . = .; + __start___ex_table = .; + __ex_table : { *(__ex_table) } + __stop___ex_table = .; + + . = ALIGN(256); + __init_begin = .; + .text.init : { *(.text.init) } + .data.init : { *(.data.init) } + . = ALIGN(256); + __init_end = .; + + __bss_start = .; + .bss (NOLOAD) : + { + *(.sbss) *(.scommon) + *(.dynbss) + *(.bss) + *(COMMON) + } + + _end = . ; + PROVIDE (end = .); +} diff --git a/cpu/ppc4xx/start.S b/cpu/ppc4xx/start.S index cdfc943..8d2777d 100644 --- a/cpu/ppc4xx/start.S +++ b/cpu/ppc4xx/start.S @@ -403,7 +403,8 @@ rsttlb: tlbwe r0,r1,0x0000 /* Invalidate all entries (V=0)*/ 2:
#if defined(CONFIG_NAND_SPL) -#if defined(CONFIG_440EPX) || defined(CONFIG_440GRX) +#if defined(CONFIG_440EPX) || defined(CONFIG_440GRX) || \ + defined(CONFIG_460EX) || defined(CONFIG_460GT) /* * Enable internal SRAM (only on 440EPx/GRx, 440EP/GR have no OCM) */ @@ -415,6 +416,11 @@ rsttlb: tlbwe r0,r1,0x0000 /* Invalidate all entries (V=0)*/ mfdcr r1,isram0_pmeg and r1,r1,r2 /* Disable pwr mgmt */ mtdcr isram0_pmeg,r1 +#if defined(CONFIG_460EX) || defined(CONFIG_460GT) + lis r1,0x4000 /* BAS = 8000_0000 */ + ori r1,r1,0x4580 /* 16k */ + mtdcr isram0_sb0cr,r1 +#endif #endif #if defined(CONFIG_440EP) /* diff --git a/include/configs/canyonlands.h b/include/configs/canyonlands.h index 6d8f230..0e6484f 100644 --- a/include/configs/canyonlands.h +++ b/include/configs/canyonlands.h @@ -114,6 +114,65 @@ #else #define CFG_ENV_IS_IN_NAND 1 /* use NAND for environment vars */ #define CFG_NAND_CS 0 /* NAND chip connected to CSx */ +#define CFG_ENV_IS_EMBEDDED 1 /* use embedded environment */ +#endif + +/* + * IPL (Initial Program Loader, integrated inside CPU) + * Will load first 4k from NAND (SPL) into cache and execute it from there. + * + * SPL (Secondary Program Loader) + * Will load special U-Boot version (NUB) from NAND and execute it. This SPL + * has to fit into 4kByte. It sets up the CPU and configures the SDRAM + * controller and the NAND controller so that the special U-Boot image can be + * loaded from NAND to SDRAM. + * + * NUB (NAND U-Boot) + * This NAND U-Boot (NUB) is a special U-Boot version which can be started + * from RAM. Therefore it mustn't (re-)configure the SDRAM controller. + * + * On 440EPx the SPL is copied to SDRAM before the NAND controller is + * set up. While still running from cache, I experienced problems accessing + * the NAND controller. sr - 2006-08-25 + */ +#define CFG_NAND_BOOT_SPL_SRC 0xfffff000 /* SPL location */ +#define CFG_NAND_BOOT_SPL_SIZE (4 << 10) /* SPL size */ +#define CFG_NAND_BOOT_SPL_DST (CFG_OCM_BASE + (12 << 10)) /* Copy SPL here */ +#define CFG_NAND_U_BOOT_DST 0x01000000 /* Load NUB to this addr */ +#define CFG_NAND_U_BOOT_START CFG_NAND_U_BOOT_DST /* Start NUB from */ + /* this addr */ +#define CFG_NAND_BOOT_SPL_DELTA (CFG_NAND_BOOT_SPL_SRC - CFG_NAND_BOOT_SPL_DST) + +/* + * Define the partitioning of the NAND chip (only RAM U-Boot is needed here) + */ +#define CFG_NAND_U_BOOT_OFFS (16 << 10) /* Offset to RAM U-Boot image */ +#define CFG_NAND_U_BOOT_SIZE (384 << 10) /* Size of RAM U-Boot image */ + +/* + * Now the NAND chip has to be defined (no autodetection used!) + */ +#define CFG_NAND_PAGE_SIZE 512 /* NAND chip page size */ +#define CFG_NAND_BLOCK_SIZE (16 << 10) /* NAND chip block size */ +#define CFG_NAND_PAGE_COUNT 32 /* NAND chip page count */ +#define CFG_NAND_BAD_BLOCK_POS 5 /* Location of bad block marker */ +#undef CFG_NAND_4_ADDR_CYCLE /* No fourth addr used (<=32MB) */ + +#define CFG_NAND_ECCSIZE 256 +#define CFG_NAND_ECCBYTES 3 +#define CFG_NAND_ECCSTEPS (CFG_NAND_PAGE_SIZE / CFG_NAND_ECCSIZE) +#define CFG_NAND_OOBSIZE 16 +#define CFG_NAND_ECCTOTAL (CFG_NAND_ECCBYTES * CFG_NAND_ECCSTEPS) +#define CFG_NAND_ECCPOS {0, 1, 2, 3, 6, 7} + +#ifdef CFG_ENV_IS_IN_NAND +/* + * For NAND booting the environment is embedded in the U-Boot image. Please take + * look at the file board/amcc/canyonlands/u-boot-nand.lds for details. + */ +#define CFG_ENV_SIZE CFG_NAND_BLOCK_SIZE +#define CFG_ENV_OFFSET (CFG_NAND_U_BOOT_OFFS + CFG_ENV_SIZE) +#define CFG_ENV_OFFSET_REDUND (CFG_ENV_OFFSET + CFG_ENV_SIZE) #endif
/*----------------------------------------------------------------------- @@ -154,10 +213,18 @@ /*------------------------------------------------------------------------------ * DDR SDRAM *----------------------------------------------------------------------------*/ +#if !defined(CONFIG_NAND_U_BOOT) +/* + * NAND booting U-Boot version uses a fixed initialization, since the whole + * I2C SPD DIMM autodetection/calibration doesn't fit into the 4k of boot + * code. + */ #define CONFIG_SPD_EEPROM 1 /* Use SPD EEPROM for setup */ #define SPD_EEPROM_ADDRESS {0x50, 0x51} /* SPD i2c spd addresses*/ #define CONFIG_DDR_ECC 1 /* with ECC support */ #define CONFIG_DDR_RQDC_FIXED 0x80000038 /* fixed value for RQDC */ +#endif +#define CFG_MBYTES_SDRAM 256 /* 256MB */
/*----------------------------------------------------------------------- * I2C @@ -367,23 +434,29 @@ * EBC address which accepts bigger regions: * * 0xfc00.0000 -> 4.cc00.0000 - * - * For this we have to remap the CS0 and re-relocate the envrironment, - * since the original FLASH location which was needed upon startup is - * now not correct anymore. */
+#if defined(CONFIG_NAND_U_BOOT) || defined(CONFIG_NAND_SPL) +/* Memory Bank 3 (NOR-FLASH) initialization */ +#define CFG_EBC_PB3AP 0x10055e00 +#define CFG_EBC_PB3CR (CFG_BOOT_BASE_ADDR | 0x9a000) + +/* Memory Bank 0 (NAND-FLASH) initialization */ +#define CFG_EBC_PB0AP 0x018003c0 +#define CFG_EBC_PB0CR (CFG_NAND_ADDR | 0x1E000) /* BAS=NAND,BS=1MB,BU=R/W,BW=32bit*/ +#else /* Memory Bank 0 (NOR-FLASH) initialization */ #define CFG_EBC_PB0AP 0x10055e00 #define CFG_EBC_PB0CR (CFG_BOOT_BASE_ADDR | 0x9a000)
-/* Memory Bank 2 (CPLD) initialization */ -#define CFG_EBC_PB2AP 0x00804240 -#define CFG_EBC_PB2CR (CFG_BCSR_BASE | 0x18000) /* BAS=CPLD,BS=1M,BU=RW,BW=32bit */ - /* Memory Bank 3 (NAND-FLASH) initialization */ #define CFG_EBC_PB3AP 0x018003c0 #define CFG_EBC_PB3CR (CFG_NAND_ADDR | 0x1E000) /* BAS=NAND,BS=1MB,BU=R/W,BW=32bit*/ +#endif + +/* Memory Bank 2 (CPLD) initialization */ +#define CFG_EBC_PB2AP 0x00804240 +#define CFG_EBC_PB2CR (CFG_BCSR_BASE | 0x18000) /* BAS=CPLD,BS=1M,BU=RW,BW=32bit */
diff --git a/nand_spl/board/amcc/canyonlands/Makefile b/nand_spl/board/amcc/canyonlands/Makefile new file mode 100644 index 0000000..0a3c9c0 --- /dev/null +++ b/nand_spl/board/amcc/canyonlands/Makefile @@ -0,0 +1,100 @@ +# +# (C) Copyright 2008 +# Stefan Roese, DENX Software Engineering, sr@denx.de. +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk +include $(TOPDIR)/nand_spl/board/$(BOARDDIR)/config.mk + +LDSCRIPT= $(TOPDIR)/nand_spl/board/$(BOARDDIR)/u-boot.lds +LDFLAGS = -Bstatic -T $(LDSCRIPT) -Ttext $(TEXT_BASE) $(PLATFORM_LDFLAGS) +AFLAGS += -DCONFIG_NAND_SPL +CFLAGS += -DCONFIG_NAND_SPL + +SOBJS = start.o init.o resetvec.o +COBJS = ddr2_fixed.o nand_boot.o nand_ecc.o ndfc.o + +SRCS := $(addprefix $(obj),$(SOBJS:.o=.S) $(COBJS:.o=.c)) +OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS)) +__OBJS := $(SOBJS) $(COBJS) +LNDIR := $(OBJTREE)/nand_spl/board/$(BOARDDIR) + +nandobj := $(OBJTREE)/nand_spl/ + +ALL = $(nandobj)u-boot-spl $(nandobj)u-boot-spl.bin $(nandobj)u-boot-spl-16k.bin + +all: $(obj).depend $(ALL) + +$(nandobj)u-boot-spl-16k.bin: $(nandobj)u-boot-spl + $(OBJCOPY) ${OBJCFLAGS} --pad-to=$(PAD_TO) -O binary $< $@ + +$(nandobj)u-boot-spl.bin: $(nandobj)u-boot-spl + $(OBJCOPY) ${OBJCFLAGS} -O binary $< $@ + +$(nandobj)u-boot-spl: $(OBJS) + cd $(LNDIR) && $(LD) $(LDFLAGS) $$UNDEF_SYM $(__OBJS) \ + -Map $(nandobj)u-boot-spl.map \ + -o $(nandobj)u-boot-spl + +# create symbolic links for common files + +# from cpu directory +$(obj)ndfc.c: + @rm -f $(obj)ndfc.c + ln -s $(SRCTREE)/cpu/ppc4xx/ndfc.c $(obj)ndfc.c + +$(obj)resetvec.S: + @rm -f $(obj)resetvec.S + ln -s $(SRCTREE)/cpu/ppc4xx/resetvec.S $(obj)resetvec.S + +$(obj)start.S: + @rm -f $(obj)start.S + ln -s $(SRCTREE)/cpu/ppc4xx/start.S $(obj)start.S + +# from board directory +$(obj)init.S: + @rm -f $(obj)init.S + ln -s $(SRCTREE)/board/amcc/canyonlands/init.S $(obj)init.S + +# from nand_spl directory +$(obj)nand_boot.c: + @rm -f $(obj)nand_boot.c + ln -s $(SRCTREE)/nand_spl/nand_boot.c $(obj)nand_boot.c + +# from drivers/mtd/nand directory +$(obj)nand_ecc.c: + @rm -f $(obj)nand_ecc.c + ln -s $(SRCTREE)/drivers/mtd/nand/nand_ecc.c $(obj)nand_ecc.c + +######################################################################### + +$(obj)%.o: $(obj)%.S + $(CC) $(AFLAGS) -c -o $@ $< + +$(obj)%.o: $(obj)%.c + $(CC) $(CFLAGS) -c -o $@ $< + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/nand_spl/board/amcc/canyonlands/config.mk b/nand_spl/board/amcc/canyonlands/config.mk new file mode 100644 index 0000000..6dad876 --- /dev/null +++ b/nand_spl/board/amcc/canyonlands/config.mk @@ -0,0 +1,49 @@ +# +# (C) Copyright 2008 +# Stefan Roese, DENX Software Engineering, sr@denx.de. +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# +# +# AMCC 460EX Reference Platform (Canyonlands) board +# + +# +# TEXT_BASE for SPL: +# +# On 460EX platforms the SPL is located at 0xfffff000...0xffffffff, +# in the last 4kBytes of memory space in cache. +# We will copy this SPL into internal SRAM in start.S. So we set +# TEXT_BASE to starting address in internal SRAM here. +# +TEXT_BASE = 0xE3003000 + +# PAD_TO used to generate a 16kByte binary needed for the combined image +# -> PAD_TO = TEXT_BASE + 0x4000 +PAD_TO = 0xE3007000 + +PLATFORM_CPPFLAGS += -DCONFIG_440=1 + +ifeq ($(debug),1) +PLATFORM_CPPFLAGS += -DDEBUG +endif + +ifeq ($(dbcr),1) +PLATFORM_CPPFLAGS += -DCFG_INIT_DBCR=0x8cff0000 +endif diff --git a/nand_spl/board/amcc/canyonlands/ddr2_fixed.c b/nand_spl/board/amcc/canyonlands/ddr2_fixed.c new file mode 100644 index 0000000..48708a8 --- /dev/null +++ b/nand_spl/board/amcc/canyonlands/ddr2_fixed.c @@ -0,0 +1,96 @@ +/* + * (C) Copyright 2008 + * Stefan Roese, DENX Software Engineering, sr@denx.de. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <ppc4xx.h> +#include <asm/io.h> +#include <asm/processor.h> + +static void wait_init_complete(void) +{ + u32 val; + + do { + mfsdram(SDRAM_MCSTAT, val); + } while (!(val & 0x80000000)); +} + +long int initdram(int board_type) +{ + /* + * Reset the DDR-SDRAM controller. + */ + mtsdr(SDR0_SRST, (0x80000000 >> 10)); + mtsdr(SDR0_SRST, 0x00000000); + + /* + * These values are cloned from a running NOR booting + * Canyonlands with SPD-DDR2 detection and calibration + * enabled. This will only work for the same memory + * configuration as used here: + * + * Crucial CT3264AC53E.4FD - 256MB SO-DIMM + * + */ + mtsdram(SDRAM_MCOPT2, 0x00000000); + mtsdram(SDRAM_MCOPT1, 0x05122000); + mtsdram(SDRAM_MODT0, 0x01000000); + mtsdram(SDRAM_CODT, 0x00800021); + mtsdram(SDRAM_WRDTR, 0x82000823); + mtsdram(SDRAM_CLKTR, 0x40000000); + mtsdram(SDRAM_MB0CF, 0x00000201); + mtsdram(SDRAM_RTR, 0x06180000); + mtsdram(SDRAM_SDTR1, 0x80201000); + mtsdram(SDRAM_SDTR2, 0x42103243); + mtsdram(SDRAM_SDTR3, 0x0A0D0D16); + mtsdram(SDRAM_MMODE, 0x00000632); + mtsdram(SDRAM_MEMODE, 0x00000040); + mtsdram(SDRAM_INITPLR0, 0xB5380000); + mtsdram(SDRAM_INITPLR1, 0x82100400); + mtsdram(SDRAM_INITPLR2, 0x80820000); + mtsdram(SDRAM_INITPLR3, 0x80830000); + mtsdram(SDRAM_INITPLR4, 0x80810040); + mtsdram(SDRAM_INITPLR5, 0x80800532); + mtsdram(SDRAM_INITPLR6, 0x82100400); + mtsdram(SDRAM_INITPLR7, 0x8A080000); + mtsdram(SDRAM_INITPLR8, 0x8A080000); + mtsdram(SDRAM_INITPLR9, 0x8A080000); + mtsdram(SDRAM_INITPLR10, 0x8A080000); + mtsdram(SDRAM_INITPLR11, 0x80000432); + mtsdram(SDRAM_INITPLR12, 0x808103C0); + mtsdram(SDRAM_INITPLR13, 0x80810040); + mtsdram(SDRAM_INITPLR14, 0x00000000); + mtsdram(SDRAM_INITPLR15, 0x00000000); + + mtsdram(SDRAM_MCOPT2, 0x28000000); + + wait_init_complete(); + + mtdcr(SDRAM_R0BAS, 0x0000F800); /* MQ0_B0BAS */ + + mtsdram(SDRAM_RDCC, 0x40000000); + mtsdram(SDRAM_RQDC, 0x80000038); + mtsdram(SDRAM_RFDC, 0x00000257); + + return CFG_MBYTES_SDRAM << 20; +} diff --git a/nand_spl/board/amcc/canyonlands/u-boot.lds b/nand_spl/board/amcc/canyonlands/u-boot.lds new file mode 100644 index 0000000..5bffb5b --- /dev/null +++ b/nand_spl/board/amcc/canyonlands/u-boot.lds @@ -0,0 +1,65 @@ +/* + * (C) Copyright 2008 + * Stefan Roese, DENX Software Engineering, sr@denx.de. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +OUTPUT_ARCH(powerpc:common) +SECTIONS +{ + .resetvec 0xE3003FFC : + { + *(.resetvec) + } = 0xffff + + .text : + { + start.o (.text) + init.o (.text) + nand_boot.o (.text) + ddr2_fixed.o (.text) + ndfc.o (.text) + + *(.text) + *(.fixup) + } + _etext = .; + + .data : + { + *(.rodata*) + *(.data*) + *(.sdata*) + __got2_start = .; + *(.got2) + __got2_end = .; + } + + _edata = .; + + __bss_start = .; + .bss (NOLOAD) : + { + *(.sbss) + *(.bss) + } + + _end = . ; +}
460EX doesn't support a fixed bootstrap option to boot from 512 byte page NAND devices. The only bootstrap option for NAND booting is option F for 2k page devices. So to boot from a 512 bype page device, the I2C bootstrap EEPROM needs to be programmed accordingly. @@ -1173,6 +1173,14 @@ CANBT_config: unconfig canyonlands_config: unconfig @$(MKCONFIG) $(@:_config=) ppc ppc4xx canyonlands amcc
It will be nice to split one line for each file
Best Regards, J.
Why? IMHO the could will not become more readble that way, on contrary...
When you have mutltiple patch for a makefile, ex : add 2 new file in 2 patch, it could be applied without rebase it the second patch
Best regards, J.
Right. The readability will suffer a little by changing this into the one-object-per-line version.
Correct. Even though the likelyhood of multiple patches in this specific directory is very low. But nevertheless I'm tempted to change it to the one-object-per-line version. This makes it also easier to add one object in alphabetical order and not having to reorder the lines. Here an example of adding "ccccccccccccc.o":
For the multiple-objects-per-line:
-COBJS = aaaaaaaaaaaa.o bbbbbbbbbbbb.o eeeeeeeeeeee.o -COBJS += ffffffffffff.o hhhhhhhhhhhh.o xxxxxxxxxxxx.o +COBJS = aaaaaaaaaaaa.o bbbbbbbbbbbb.o cccccccccccc.0 +COBJS += eeeeeeeeeeee.o ffffffffffff.o hhhhhhhhhhhh.o +COBJS += xxxxxxxxxxxx.o
For the one-object-per-line:
COBJS = aaaaaaaaaaaa.o COBJS += bbbbbbbbbbbb.o +COBJS += cccccccccccc.o COBJS += eeeeeeeeeeee.o COBJS += ffffffffffff.o
This patch adds CFG_OHCI_USE_NPS to the common USB-OHCI driver. This way a board just needs to define this new option to enable the "force NoPowerSwitching mode" instead of adding new CPU/architecture defines to the USB source itself.
This new option will be used first with the new AMCC 460EX Canyonlands board port, which will be posted in a few days.
This patch also fixes a small compilation problem when DEBUG is enabled.
Signed-off-by: Stefan Roese sr@denx.de --- drivers/usb/usb_ohci.c | 5 +++-- 1 files changed, 3 insertions(+), 2 deletions(-)
diff --git a/drivers/usb/usb_ohci.c b/drivers/usb/usb_ohci.c index fb4726f..829bbca 100644 --- a/drivers/usb/usb_ohci.c +++ b/drivers/usb/usb_ohci.c @@ -68,7 +68,8 @@ defined(CONFIG_S3C2410) || \ defined(CONFIG_440EP) || \ defined(CONFIG_PCI_OHCI) || \ - defined(CONFIG_MPC5200) + defined(CONFIG_MPC5200) || \ + defined(CFG_OHCI_USE_NPS) # define OHCI_USE_NPS /* force NoPowerSwitching mode */ #endif
@@ -415,7 +416,7 @@ static void ohci_dump (ohci_t *controller, int verbose) ep_print_int_eds (controller, "hcca"); dbg ("hcca frame #%04x", controller->hcca->frame_no); ohci_dump_roothub (controller, 1); - +} #endif /* DEBUG */
This patch adds USB OHCI support to the Canyonlands board port. It also enables EXT2 support.
Signed-off-by: Stefan Roese sr@denx.de --- board/amcc/canyonlands/canyonlands.c | 14 +++++++ board/amcc/canyonlands/init.S | 3 + include/configs/canyonlands.h | 68 +++++++++++++++++++++++----------- include/ppc440.h | 3 + 4 files changed, 66 insertions(+), 22 deletions(-)
diff --git a/board/amcc/canyonlands/canyonlands.c b/board/amcc/canyonlands/canyonlands.c index 3551429..36779f5 100644 --- a/board/amcc/canyonlands/canyonlands.c +++ b/board/amcc/canyonlands/canyonlands.c @@ -26,6 +26,7 @@ #include <asm/io.h> #include <asm/mmu.h> #include <asm/4xx_pcie.h> +#include <asm/gpio.h>
extern flash_info_t flash_info[CFG_MAX_FLASH_BANKS]; /* info for FLASH chips */
@@ -100,6 +101,19 @@ int board_early_init_f(void)
mtsdr(SDR0_SRST1, 0); /* Pull AHB out of reset default=1 */
+ /* Setup PLB4-AHB bridge based on the system address map */ + mtdcr(AHB_TOP, 0x8000004B); + mtdcr(AHB_BOT, 0x8000004B); + + /* + * Configure USB-STP pins as alternate and not GPIO + * It seems to be neccessary to configure the STP pins as GPIO + * input at powerup (perhaps while USB reset is asserted). So + * we configure those pins to their "real" function now. + */ + gpio_config(16, GPIO_OUT, GPIO_ALT1, GPIO_OUT_1); + gpio_config(19, GPIO_OUT, GPIO_ALT1, GPIO_OUT_1); + return 0; }
diff --git a/board/amcc/canyonlands/init.S b/board/amcc/canyonlands/init.S index b7cac23..bd4cab5 100644 --- a/board/amcc/canyonlands/init.S +++ b/board/amcc/canyonlands/init.S @@ -88,6 +88,9 @@ tlbtab: /* TLB-entry for Local Configuration registers => peripherals */ tlbentry(CFG_LOCAL_CONF_REGS, SZ_16M, CFG_LOCAL_CONF_REGS, 4, AC_R|AC_W|AC_X|SA_G|SA_I)
+ /* AHB: Internal USB Peripherals (USB, SATA) */ + tlbentry(CFG_AHB_BASE, SZ_1M, 0xbff00000, 4, AC_R|AC_W|AC_X|SA_G|SA_I) + tlbtab_end
#if defined(CONFIG_NAND_U_BOOT) && !defined(CONFIG_NAND_SPL) diff --git a/include/configs/canyonlands.h b/include/configs/canyonlands.h index 0e6484f..55390ca 100644 --- a/include/configs/canyonlands.h +++ b/include/configs/canyonlands.h @@ -79,6 +79,8 @@
+#define CFG_AHB_BASE 0xE2000000 /* internal AHB peripherals */ + #define CFG_MONITOR_BASE TEXT_BASE #define CFG_MONITOR_LEN (384 * 1024) /* Reserve 384 kB for Monitor */ #define CFG_MALLOC_LEN (512 * 1024) /* Reserve 512 kB for malloc()*/ @@ -270,6 +272,21 @@
+/*----------------------------------------------------------------------- + * USB-OHCI + *----------------------------------------------------------------------*/ +#define CONFIG_USB_OHCI_NEW +#define CONFIG_USB_STORAGE +#undef CFG_OHCI_BE_CONTROLLER /* 460EX has little endian descriptors */ +#define CFG_OHCI_SWAP_REG_ACCESS /* 460EX has little endian register */ +#define CFG_OHCI_USE_NPS /* force NoPowerSwitching mode */ +#define CFG_USB_OHCI_REGS_BASE (CFG_AHB_BASE | 0xd0000) +#define CFG_USB_OHCI_SLOT_NAME "ppc440" +#define CFG_USB_OHCI_MAX_ROOT_PORTS 15 + +/*----------------------------------------------------------------------- + * Default environment + *----------------------------------------------------------------------*/ #define CONFIG_PREBOOT "echo;" \ "echo Type "run flash_nfs" to mount root filesystem over NFS;" \ "echo" @@ -344,6 +361,7 @@ #define CONFIG_CMD_DIAG #define CONFIG_CMD_EEPROM #define CONFIG_CMD_ELF +#define CONFIG_CMD_EXT2 #define CONFIG_CMD_FAT #define CONFIG_CMD_I2C #define CONFIG_CMD_IRQ @@ -355,6 +373,12 @@ #define CONFIG_CMD_PING #define CONFIG_CMD_REGINFO #define CONFIG_CMD_SDRAM +#define CONFIG_CMD_USB + +/* Partitions */ +#define CONFIG_MAC_PARTITION +#define CONFIG_DOS_PARTITION +#define CONFIG_ISO_PARTITION
/*----------------------------------------------------------------------- * Miscellaneous configurable options @@ -466,28 +490,28 @@ #define CFG_4xx_GPIO_TABLE { /* Out GPIO Alternate1 Alternate2 Alternate3 */ \ { \ /* GPIO Core 0 */ \ -{GPIO0_BASE, GPIO_BI , GPIO_ALT2, GPIO_OUT_0}, /* GPIO0 GMC1TxD(0) USB2HostD(0) */ \ -{GPIO0_BASE, GPIO_BI , GPIO_ALT2, GPIO_OUT_0}, /* GPIO1 GMC1TxD(1) USB2HostD(1) */ \ -{GPIO0_BASE, GPIO_BI , GPIO_ALT2, GPIO_OUT_0}, /* GPIO2 GMC1TxD(2) USB2HostD(2) */ \ -{GPIO0_BASE, GPIO_BI , GPIO_ALT2, GPIO_OUT_0}, /* GPIO3 GMC1TxD(3) USB2HostD(3) */ \ -{GPIO0_BASE, GPIO_BI , GPIO_ALT2, GPIO_OUT_0}, /* GPIO4 GMC1TxD(4) USB2HostD(4) */ \ -{GPIO0_BASE, GPIO_BI , GPIO_ALT2, GPIO_OUT_0}, /* GPIO5 GMC1TxD(5) USB2HostD(5) */ \ -{GPIO0_BASE, GPIO_BI , GPIO_ALT2, GPIO_OUT_0}, /* GPIO6 GMC1TxD(6) USB2HostD(6) */ \ -{GPIO0_BASE, GPIO_BI , GPIO_ALT2, GPIO_OUT_0}, /* GPIO7 GMC1TxD(7) USB2HostD(7) */ \ -{GPIO0_BASE, GPIO_BI , GPIO_ALT2, GPIO_OUT_0}, /* GPIO8 GMC1RxD(0) USB2OTGD(0) */ \ -{GPIO0_BASE, GPIO_BI , GPIO_ALT2, GPIO_OUT_0}, /* GPIO9 GMC1RxD(1) USB2OTGD(1) */ \ -{GPIO0_BASE, GPIO_BI , GPIO_ALT2, GPIO_OUT_0}, /* GPIO10 GMC1RxD(2) USB2OTGD(2) */ \ -{GPIO0_BASE, GPIO_BI , GPIO_ALT2, GPIO_OUT_0}, /* GPIO11 GMC1RxD(3) USB2OTGD(3) */ \ -{GPIO0_BASE, GPIO_BI , GPIO_ALT2, GPIO_OUT_0}, /* GPIO12 GMC1RxD(4) USB2OTGD(4) */ \ -{GPIO0_BASE, GPIO_BI , GPIO_ALT2, GPIO_OUT_0}, /* GPIO13 GMC1RxD(5) USB2OTGD(5) */ \ -{GPIO0_BASE, GPIO_BI , GPIO_ALT2, GPIO_OUT_0}, /* GPIO14 GMC1RxD(6) USB2OTGD(6) */ \ -{GPIO0_BASE, GPIO_BI , GPIO_ALT2, GPIO_OUT_0}, /* GPIO15 GMC1RxD(7) USB2OTGD(7) */ \ -{GPIO0_BASE, GPIO_OUT, GPIO_ALT2, GPIO_OUT_0}, /* GPIO16 GMC1TxER USB2HostStop */ \ -{GPIO0_BASE, GPIO_IN , GPIO_ALT2, GPIO_OUT_0}, /* GPIO17 GMC1CD USB2HostNext */ \ -{GPIO0_BASE, GPIO_IN , GPIO_ALT2, GPIO_OUT_0}, /* GPIO18 GMC1RxER USB2HostDir */ \ -{GPIO0_BASE, GPIO_OUT, GPIO_ALT2, GPIO_OUT_0}, /* GPIO19 GMC1TxEN USB2OTGStop */ \ -{GPIO0_BASE, GPIO_IN , GPIO_ALT2, GPIO_OUT_0}, /* GPIO20 GMC1CRS USB2OTGNext */ \ -{GPIO0_BASE, GPIO_IN , GPIO_ALT2, GPIO_OUT_0}, /* GPIO21 GMC1RxDV USB2OTGDir */ \ +{GPIO0_BASE, GPIO_BI , GPIO_ALT1, GPIO_OUT_0}, /* GPIO0 GMC1TxD(0) USB2HostD(0) */ \ +{GPIO0_BASE, GPIO_BI , GPIO_ALT1, GPIO_OUT_0}, /* GPIO1 GMC1TxD(1) USB2HostD(1) */ \ +{GPIO0_BASE, GPIO_BI , GPIO_ALT1, GPIO_OUT_0}, /* GPIO2 GMC1TxD(2) USB2HostD(2) */ \ +{GPIO0_BASE, GPIO_BI , GPIO_ALT1, GPIO_OUT_0}, /* GPIO3 GMC1TxD(3) USB2HostD(3) */ \ +{GPIO0_BASE, GPIO_BI , GPIO_ALT1, GPIO_OUT_0}, /* GPIO4 GMC1TxD(4) USB2HostD(4) */ \ +{GPIO0_BASE, GPIO_BI , GPIO_ALT1, GPIO_OUT_0}, /* GPIO5 GMC1TxD(5) USB2HostD(5) */ \ +{GPIO0_BASE, GPIO_BI , GPIO_ALT1, GPIO_OUT_0}, /* GPIO6 GMC1TxD(6) USB2HostD(6) */ \ +{GPIO0_BASE, GPIO_BI , GPIO_ALT1, GPIO_OUT_0}, /* GPIO7 GMC1TxD(7) USB2HostD(7) */ \ +{GPIO0_BASE, GPIO_BI , GPIO_ALT1, GPIO_OUT_0}, /* GPIO8 GMC1RxD(0) USB2OTGD(0) */ \ +{GPIO0_BASE, GPIO_BI , GPIO_ALT1, GPIO_OUT_0}, /* GPIO9 GMC1RxD(1) USB2OTGD(1) */ \ +{GPIO0_BASE, GPIO_BI , GPIO_ALT1, GPIO_OUT_0}, /* GPIO10 GMC1RxD(2) USB2OTGD(2) */ \ +{GPIO0_BASE, GPIO_BI , GPIO_ALT1, GPIO_OUT_0}, /* GPIO11 GMC1RxD(3) USB2OTGD(3) */ \ +{GPIO0_BASE, GPIO_BI , GPIO_ALT1, GPIO_OUT_0}, /* GPIO12 GMC1RxD(4) USB2OTGD(4) */ \ +{GPIO0_BASE, GPIO_BI , GPIO_ALT1, GPIO_OUT_0}, /* GPIO13 GMC1RxD(5) USB2OTGD(5) */ \ +{GPIO0_BASE, GPIO_BI , GPIO_ALT1, GPIO_OUT_0}, /* GPIO14 GMC1RxD(6) USB2OTGD(6) */ \ +{GPIO0_BASE, GPIO_BI , GPIO_ALT1, GPIO_OUT_0}, /* GPIO15 GMC1RxD(7) USB2OTGD(7) */ \ +{GPIO0_BASE, GPIO_IN , GPIO_SEL, GPIO_OUT_0}, /* GPIO16 GMC1TxER USB2HostStop */ \ +{GPIO0_BASE, GPIO_IN , GPIO_ALT1, GPIO_OUT_0}, /* GPIO17 GMC1CD USB2HostNext */ \ +{GPIO0_BASE, GPIO_IN , GPIO_ALT1, GPIO_OUT_0}, /* GPIO18 GMC1RxER USB2HostDir */ \ +{GPIO0_BASE, GPIO_IN, GPIO_SEL, GPIO_OUT_0}, /* GPIO19 GMC1TxEN USB2OTGStop */ \ +{GPIO0_BASE, GPIO_IN , GPIO_ALT1, GPIO_OUT_0}, /* GPIO20 GMC1CRS USB2OTGNext */ \ +{GPIO0_BASE, GPIO_IN , GPIO_ALT1, GPIO_OUT_0}, /* GPIO21 GMC1RxDV USB2OTGDir */ \ {GPIO0_BASE, GPIO_IN , GPIO_ALT1, GPIO_OUT_0}, /* GPIO22 NFRDY */ \ {GPIO0_BASE, GPIO_IN , GPIO_ALT1, GPIO_OUT_0}, /* GPIO23 NFREN */ \ {GPIO0_BASE, GPIO_IN , GPIO_ALT1, GPIO_OUT_0}, /* GPIO24 NFWEN */ \ diff --git a/include/ppc440.h b/include/ppc440.h index cf29fe7..80dd332 100644 --- a/include/ppc440.h +++ b/include/ppc440.h @@ -3355,6 +3355,9 @@ #define SDR0_DDR0_DDRM_DECODE(n) ((((unsigned long)(n))>>29)&0x03) #define SDR0_DDR0_TUNE_ENCODE(n) ((((unsigned long)(n))&0x2FF)<<0) #define SDR0_DDR0_TUNE_DECODE(n) ((((unsigned long)(n))>>0)&0x2FF) + +#define AHB_TOP 0xA4 +#define AHB_BOT 0xA5 #endif /* CONFIG_460EX || CONFIG_460GT */
#define SDR0_SDCS_SDD (0x80000000 >> 31)
Jean-Christophe PLAGNIOL-VILLARD
Stefan Roese
