[U-Boot] [PATCH V5 0/2] Patches to support Ramtron FRAMs
Patch 1 adds generalisation to spi_flash.c to allow for table driven probing of JEDEC and NON-JEDEC conformant devices
Patch 2 adds the actual Ramtron support
Patch 2 requires Patch 1 to be applied first.
Signed-off-by: Reinhard Meyer u-boot@emk-elektronik.de
for JEDEC devices without and with extension bytes for non JEDEC devices Signed-off-by: Reinhard Meyer u-boot@emk-elektronik.de --- drivers/mtd/spi/spi_flash.c | 137 +++++++++++++++++++++++++++++-------------- 1 files changed, 93 insertions(+), 44 deletions(-)
diff --git a/drivers/mtd/spi/spi_flash.c b/drivers/mtd/spi/spi_flash.c index ea875dc..e19f47d 100644 --- a/drivers/mtd/spi/spi_flash.c +++ b/drivers/mtd/spi/spi_flash.c @@ -1,8 +1,26 @@ /* - * SPI flash interface + * (C) Copyright 2010 + * Reinhard Meyer, EMK Elektronik, reinhard.meyer@emk-elektronik.de * * Copyright (C) 2008 Atmel Corporation - * Licensed under the GPL-2 or later. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA */
#include <common.h> @@ -96,13 +114,59 @@ int spi_flash_read_common(struct spi_flash *flash, const u8 *cmd, return ret; }
+/* + * the following table holds all device probe functions + * + * shift: number of continuation bytes before the ID + * idcode: the expected IDCODE or 0xff for non JEDEC devices + * probe: the function to call + * + * non JEDEC devices should be ordered in the table such that + * the probe functions with best detection algorithms come first + * + * several matching entries are permitted, they will be tried + * in sequence until a probe function returns non NULL + * + * IDBUF_LEN may be redefined if a device detection requires + * more then 5 bytes read. + */ +#define IDBUF_LEN 5 +const struct { + const u8 shift; + const u8 idcode; + struct spi_flash *(*probe) (struct spi_slave *spi, u8 *idcode); +} flashes[] = { +#ifdef CONFIG_SPI_FLASH_SPANSION + { 0, 0x01, spi_flash_probe_spansion, }, +#endif +#ifdef CONFIG_SPI_FLASH_ATMEL + { 0, 0x1F, spi_flash_probe_atmel, }, +#endif +#ifdef CONFIG_SPI_FLASH_MACRONIX + { 0, 0xc2, spi_flash_probe_macronix, }, +#endif +#ifdef CONFIG_SPI_FLASH_WINBOND + { 0, 0xef, spi_flash_probe_winbond, }, +#endif +#ifdef CONFIG_SPI_FLASH_STMICRO + { 0, 0x20, spi_flash_probe_stmicro, }, + { 0, 0xff, spi_flash_probe_stmicro, }, +#endif +#ifdef CONFIG_SPI_FLASH_SST + { 0, 0xBF, spi_flash_probe_sst, }, +#endif +}; + struct spi_flash *spi_flash_probe(unsigned int bus, unsigned int cs, unsigned int max_hz, unsigned int spi_mode) { struct spi_slave *spi; - struct spi_flash *flash; + struct spi_flash *flash = NULL; int ret; - u8 idcode[5]; + int shift; + int i; + u8 idbuf[IDBUF_LEN]; + u8 *idp;
spi = spi_setup_slave(bus, cs, max_hz, spi_mode); if (!spi) { @@ -117,53 +181,38 @@ struct spi_flash *spi_flash_probe(unsigned int bus, unsigned int cs, }
/* Read the ID codes */ - ret = spi_flash_cmd(spi, CMD_READ_ID, &idcode, sizeof(idcode)); + ret = spi_flash_cmd(spi, CMD_READ_ID, &idbuf, sizeof(idbuf)); if (ret) goto err_read_id;
- debug("SF: Got idcode %02x %02x %02x %02x %02x\n", idcode[0], - idcode[1], idcode[2], idcode[3], idcode[4]); - - switch (idcode[0]) { -#ifdef CONFIG_SPI_FLASH_SPANSION - case 0x01: - flash = spi_flash_probe_spansion(spi, idcode); - break; -#endif -#ifdef CONFIG_SPI_FLASH_ATMEL - case 0x1F: - flash = spi_flash_probe_atmel(spi, idcode); - break; -#endif -#ifdef CONFIG_SPI_FLASH_MACRONIX - case 0xc2: - flash = spi_flash_probe_macronix(spi, idcode); - break; -#endif -#ifdef CONFIG_SPI_FLASH_WINBOND - case 0xef: - flash = spi_flash_probe_winbond(spi, idcode); - break; -#endif -#ifdef CONFIG_SPI_FLASH_STMICRO - case 0x20: - case 0xff: /* Let the stmicro func handle non-JEDEC ids */ - flash = spi_flash_probe_stmicro(spi, idcode); - break; +#ifdef DEBUG + printf("SF: Got idcodes\n"); + print_buffer(0, idbuf, 1, sizeof(idbuf), 0); #endif -#ifdef CONFIG_SPI_FLASH_SST - case 0xBF: - flash = spi_flash_probe_sst(spi, idcode); - break; -#endif - default: - printf("SF: Unsupported manufacturer %02X\n", idcode[0]); - flash = NULL; - break; + + /* + * count the number of continuation bytes, but + * leave at least 3 bytes to the end of the buffer untouched + */ + for (shift = 0, idp = idbuf; + shift < (sizeof(idbuf) - 3) && *idp == 0x7f; + shift++, idp++) + ; + + /* search the table for matches in shift and id */ + for (i = 0; i < ARRAY_SIZE(flashes); i++) { + if (flashes[i].shift == shift && flashes[i].idcode == *idp) { + /* we have a match, call probe */ + flash = flashes[i].probe(spi, idp); + if (flash) + break; + } }
- if (!flash) + if (!flash) { + printf("SF: Unsupported manufacturer %02X\n", *idp); goto err_manufacturer_probe; + }
spi_release_bus(spi);
Supports most types that support Read-Id and the FM25H20.
Signed-off-by: Reinhard Meyer u-boot@emk-elektronik.de --- drivers/mtd/spi/Makefile | 1 + drivers/mtd/spi/ramtron.c | 319 ++++++++++++++++++++++++++++++++++ drivers/mtd/spi/spi_flash.c | 8 + drivers/mtd/spi/spi_flash_internal.h | 1 + 4 files changed, 329 insertions(+), 0 deletions(-) create mode 100644 drivers/mtd/spi/ramtron.c
diff --git a/drivers/mtd/spi/Makefile b/drivers/mtd/spi/Makefile index 4f11b36..a082ca7 100644 --- a/drivers/mtd/spi/Makefile +++ b/drivers/mtd/spi/Makefile @@ -32,6 +32,7 @@ COBJS-$(CONFIG_SPI_FLASH_SPANSION) += spansion.o COBJS-$(CONFIG_SPI_FLASH_SST) += sst.o COBJS-$(CONFIG_SPI_FLASH_STMICRO) += stmicro.o COBJS-$(CONFIG_SPI_FLASH_WINBOND) += winbond.o +COBJS-$(CONFIG_SPI_FRAM_RAMTRON) += ramtron.o COBJS-$(CONFIG_SPI_M95XXX) += eeprom_m95xxx.o
COBJS := $(COBJS-y) diff --git a/drivers/mtd/spi/ramtron.c b/drivers/mtd/spi/ramtron.c new file mode 100644 index 0000000..171390d --- /dev/null +++ b/drivers/mtd/spi/ramtron.c @@ -0,0 +1,319 @@ +/* + * (C) Copyright 2010 + * Reinhard Meyer, EMK Elektronik, reinhard.meyer@emk-elektronik.de + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +/* + * Note: RAMTRON SPI FRAMs are ferroelectric, nonvolatile RAMs + * with an interface identical to SPI flash devices. + * However since they behave like RAM there are no delays or + * busy polls required. They can sustain read or write at the + * allowed SPI bus speed, which can be 40 MHz for some devices. + * + * Unfortunately some RAMTRON devices do not have a means of + * identifying them. They will leave the SO line undriven when + * the READ-ID command is issued. It is therefore mandatory + * that the MISO line has a proper pull-up, so that READ-ID + * will return a row of 0xff. This 0xff pseudo-id will cause + * probes by all vendor specific functions that are designed + * to handle it. If the MISO line is not pulled up, READ-ID + * could return any random noise, even mimicking another + * device. + * + * We use CONFIG_SPI_FRAM_RAMTRON_NON_JEDEC + * to define which device will be assumed after a simple status + * register verify. This method is prone to false positive + * detection and should therefore be the last to be tried. + * Enter it in the last position in the table in spi_flash.c! + * + * The define CONFIG_SPI_FRAM_RAMTRON_NON_JEDEC both activates + * compilation of the special handler and defines the device + * to assume. + */ + +#include <common.h> +#include <malloc.h> +#include <spi_flash.h> +#include "spi_flash_internal.h" + +/* RAMTRON commands common to all devices */ +#define CMD_RAMTRON_WREN 0x06 /* Write Enable */ +#define CMD_RAMTRON_WRDI 0x04 /* Write Disable */ +#define CMD_RAMTRON_RDSR 0x05 /* Read Status Register */ +#define CMD_RAMTRON_WRSR 0x01 /* Write Status Register */ +#define CMD_RAMTRON_READ 0x03 /* Read Data Bytes */ +#define CMD_RAMTRON_WRITE 0x02 /* Write Data Bytes */ +/* not all have those: */ +#define CMD_RAMTRON_FSTRD 0x0b /* Fast Read (for compatibility - not used here) */ +#define CMD_RAMTRON_SLEEP 0xb9 /* Enter Sleep Mode */ +#define CMD_RAMTRON_RDID 0x9f /* Read ID */ +#define CMD_RAMTRON_SNR 0xc3 /* Read Serial Number */ + +/* + * Properties of supported FRAMs + * Note: speed is currently not used because we have no method to deliver that + * value to the upper layers + */ +struct ramtron_spi_fram_params { + u32 size; /* size in bytes */ + u8 addr_len; /* number of address bytes */ + u8 merge_cmd; /* some address bits are in the command byte */ + u8 id1; /* device ID 1 (family, density) */ + u8 id2; /* device ID 2 (sub, rev, rsvd) */ + u32 speed; /* max. SPI clock in Hz */ + const char *name; /* name for display and/or matching */ +}; + +struct ramtron_spi_fram { + struct spi_flash flash; + const struct ramtron_spi_fram_params *params; +}; + +static inline struct ramtron_spi_fram *to_ramtron_spi_fram(struct spi_flash + *flash) +{ + return container_of(flash, struct ramtron_spi_fram, flash); +} + +/* + * table describing supported FRAM chips: + * chips without RDID command must have the values 0xff for id1 and id2 + */ +static const struct ramtron_spi_fram_params ramtron_spi_fram_table[] = { + { + .size = 32*1024, + .addr_len = 2, + .merge_cmd = 0, + .id1 = 0x22, + .id2 = 0x00, + .speed = 40000000, + .name = "FM25V02", + }, + { + .size = 32*1024, + .addr_len = 2, + .merge_cmd = 0, + .id1 = 0x22, + .id2 = 0x01, + .speed = 40000000, + .name = "FM25VN02", + }, + { + .size = 64*1024, + .addr_len = 2, + .merge_cmd = 0, + .id1 = 0x23, + .id2 = 0x00, + .speed = 40000000, + .name = "FM25V05", + }, + { + .size = 64*1024, + .addr_len = 2, + .merge_cmd = 0, + .id1 = 0x23, + .id2 = 0x01, + .speed = 40000000, + .name = "FM25VN05", + }, + { + .size = 128*1024, + .addr_len = 3, + .merge_cmd = 0, + .id1 = 0x24, + .id2 = 0x00, + .speed = 40000000, + .name = "FM25V10", + }, + { + .size = 128*1024, + .addr_len = 3, + .merge_cmd = 0, + .id1 = 0x24, + .id2 = 0x01, + .speed = 40000000, + .name = "FM25VN10", + }, +#ifdef CONFIG_SPI_FRAM_RAMTRON_NON_JEDEC + { + .size = 256*1024, + .addr_len = 3, + .merge_cmd = 0, + .id1 = 0xff, + .id2 = 0xff, + .speed = 40000000, + .name = "FM25H20", + }, +#endif +}; + +static int ramtron_common(struct spi_flash *flash, + u32 offset, size_t len, void *buf, u8 command) +{ + struct ramtron_spi_fram *sn = to_ramtron_spi_fram(flash); + u8 cmd[4]; + int cmd_len; + int ret; + + if (sn->params->addr_len == 3 && sn->params->merge_cmd == 0) { + cmd[0] = command; + cmd[1] = offset >> 16; + cmd[2] = offset >> 8; + cmd[3] = offset; + cmd_len = 4; + } else if (sn->params->addr_len == 2 && sn->params->merge_cmd == 0) { + cmd[0] = command; + cmd[1] = offset >> 8; + cmd[2] = offset; + cmd_len = 3; + } else { + printf("SF: unsupported addr_len or merge_cmd\n"); + return -1; + } + + /* claim the bus */ + ret = spi_claim_bus(flash->spi); + if (ret) { + debug("SF: Unable to claim SPI bus\n"); + return ret; + } + + if (command == CMD_RAMTRON_WRITE) { + /* send WREN */ + ret = spi_flash_cmd(flash->spi, CMD_RAMTRON_WREN, NULL, 0); + if (ret < 0) { + debug("SF: Enabling Write failed\n"); + goto releasebus; + } + } + + /* do the transaction */ + if (command == CMD_RAMTRON_WRITE) + ret = spi_flash_cmd_write(flash->spi, cmd, cmd_len, buf, len); + else + ret = spi_flash_cmd_read(flash->spi, cmd, cmd_len, buf, len); + if (ret < 0) + debug("SF: Transaction failed\n"); + +releasebus: + /* release the bus */ + spi_release_bus(flash->spi); + return ret; +} + +static int ramtron_read(struct spi_flash *flash, + u32 offset, size_t len, void *buf) +{ + return ramtron_common(flash, offset, len, buf, + CMD_RAMTRON_READ); +} + +static int ramtron_write(struct spi_flash *flash, + u32 offset, size_t len, const void *buf) +{ + return ramtron_common(flash, offset, len, (void *)buf, + CMD_RAMTRON_WRITE); +} + +int ramtron_erase(struct spi_flash *flash, u32 offset, size_t len) +{ + debug("SF: Erase of RAMTRON FRAMs is pointless\n"); + return -1; +} + +/* + * nore: we are called here with idcode pointing to the first non-0x7f byte + * already! + */ +struct spi_flash *spi_fram_probe_ramtron(struct spi_slave *spi, u8 *idcode) +{ + const struct ramtron_spi_fram_params *params; + struct ramtron_spi_fram *sn; + unsigned int i; +#ifdef CONFIG_SPI_FRAM_RAMTRON_NON_JEDEC + int ret; + u8 sr; +#endif + + /* NOTE: the bus has been claimed before this function is called! */ + switch (idcode[0]) { + case 0xc2: + /* JEDEC conformant RAMTRON id */ + for (i = 0; i < ARRAY_SIZE(ramtron_spi_fram_table); i++) { + params = &ramtron_spi_fram_table[i]; + if (idcode[1] == params->id1 && idcode[2] == params->id2) + goto found; + } + break; +#ifdef CONFIG_SPI_FRAM_RAMTRON_NON_JEDEC + case 0xff: + /* + * probably open MISO line, pulled up. + * We COULD have a non JEDEC conformant FRAM here, + * read the status register to verify + */ + ret = spi_flash_cmd(spi, CMD_RAMTRON_RDSR, &sr, 1); + if (ret) + return NULL; + + /* Bits 5,4,0 are fixed 0 for all devices */ + if ((sr & 0x31) != 0x00) + return NULL; + /* now find the device */ + for (i = 0; i < ARRAY_SIZE(ramtron_spi_fram_table); i++) { + params = &ramtron_spi_fram_table[i]; + if (!strcmp(params->name, CONFIG_SPI_FRAM_RAMTRON_NON_JEDEC)) + goto found; + } + debug("SF: Unsupported non-JEDEC RAMTRON device " + CONFIG_SPI_FRAM_RAMTRON_NON_JEDEC "\n"); + break; +#endif + default: + break; + } + + /* arriving here means no method has found a device we can handle */ + debug("SF/ramtron: unsupported device id0=%02x id1=%02x id2=%02x\n", + idcode[0], idcode[1], idcode[2]); + return NULL; + +found: + sn = malloc(sizeof(*sn)); + if (!sn) { + debug("SF: Failed to allocate memory\n"); + return NULL; + } + + sn->params = params; + sn->flash.spi = spi; + sn->flash.name = params->name; + + sn->flash.write = ramtron_write; + sn->flash.read = ramtron_read; + sn->flash.erase = ramtron_erase; + sn->flash.size = params->size; + + printf("SF: Detected %s with size ", params->name); + print_size(sn->flash.size, "\n"); + + return &sn->flash; +} diff --git a/drivers/mtd/spi/spi_flash.c b/drivers/mtd/spi/spi_flash.c index e19f47d..3f8c8e1 100644 --- a/drivers/mtd/spi/spi_flash.c +++ b/drivers/mtd/spi/spi_flash.c @@ -155,6 +155,14 @@ const struct { #ifdef CONFIG_SPI_FLASH_SST { 0, 0xBF, spi_flash_probe_sst, }, #endif +#ifdef CONFIG_SPI_FRAM_RAMTRON + { 6, 0xc2, spi_fram_probe_ramtron, }, +# ifdef CONFIG_SPI_FRAM_RAMTRON_NON_JEDEC + { 0, 0xff, spi_fram_probe_ramtron, }, +# endif +# undef IDBUF_LEN +# define IDBUF_LEN 9 /* we need to read 6+3 bytes */ +#endif };
struct spi_flash *spi_flash_probe(unsigned int bus, unsigned int cs, diff --git a/drivers/mtd/spi/spi_flash_internal.h b/drivers/mtd/spi/spi_flash_internal.h index 08546fb..9bc43dd 100644 --- a/drivers/mtd/spi/spi_flash_internal.h +++ b/drivers/mtd/spi/spi_flash_internal.h @@ -50,3 +50,4 @@ struct spi_flash *spi_flash_probe_macronix(struct spi_slave *spi, u8 *idcode); struct spi_flash *spi_flash_probe_sst(struct spi_slave *spi, u8 *idcode); struct spi_flash *spi_flash_probe_stmicro(struct spi_slave *spi, u8 *idcode); struct spi_flash *spi_flash_probe_winbond(struct spi_slave *spi, u8 *idcode); +struct spi_flash *spi_fram_probe_ramtron(struct spi_slave *spi, u8 *idcode);
you'll need to tweak the probe func to handle the full idcode buffer (see the patch i posted), but otherwise this looks fine to me -mike
- for (shift = 0, idp = idbuf;
shift++, idp++)
- /* search the table for matches in shift and id */
- for (i = 0; i < ARRAY_SIZE(flashes); i++) {
if (flash)
break;
thinking about this some more, i see two problems. (1) we've been providing 4 bytes to probe funcs (like the spansion), so 3 is too small. (2) all of the probe devices today expect to get the whole idcode buffer. so if we're going to change this API, we need to fix all the probe funcs too. but that is a lot of changes to roll into one commit, so let's first focus on converting to a table without changing any probe semantics.
see the follow up patch that addresses these issues and some other stuff. -mike
Dear Mike Frysinger,
shift++, idp++)
if (flash)
break;
NONE of the existing functions work with expansion, so they all get the unshifted, full ID buffer.
If you provide the unshifted buffer to the function, the function should get the shift amount as well. Otherwise the function will again have look how many 0x7e's to skip....
Reinhard
shift++, idp++)
if (flash)
break;
err, right. was thinking it also shifted off the manu id byte and not just the continuation bytes.
i'll tweak the patch i posted and pull in your ramtron patch.
not really. the probe funcs already know the layout of the idcode, so starting at a constant offset of 3 is the same as starting at 1. -mike
Thanks.
True. I was already contemplating the possibility of one probe function having to deal with different amounts of shift... But this would not work safe in either method right now.
(Assuming the unlikely case that 7e 7e 7e 55 and 7e 7e 55 have to be handled by the same probe function...)
This would indeed favour passing the unshifted ID buffer for such functions to find out the amount of 7f's. If you favour that, I am game with it. But I will resubmit the ramtron part only when the new probe is in mainline and I have rebased my tree to it.
Reinhard
ive posted the patches that work for me and include the latest feedback. please double check they still work for ramtron, and i'll push them over to wolfgang. or try my sf branch as it is latest master + those branches. -mike
This allows for arbitrarily long manufacturer ids following the JEDEC standard of 0x7f continuation bytes. It also makes adding new entries easier as it's just one element in an array. The downside is that it increases code size a bit, but we're talking less than 100 bytes.
Signed-off-by: Reinhard Meyer u-boot@emk-elektronik.de Signed-off-by: Mike Frysinger vapier@gentoo.org --- drivers/mtd/spi/spi_flash.c | 123 +++++++++++++++++++++++++++--------------- 1 files changed, 79 insertions(+), 44 deletions(-)
diff --git a/drivers/mtd/spi/spi_flash.c b/drivers/mtd/spi/spi_flash.c index ea875dc..0aacc9c 100644 --- a/drivers/mtd/spi/spi_flash.c +++ b/drivers/mtd/spi/spi_flash.c @@ -2,6 +2,8 @@ * SPI flash interface * * Copyright (C) 2008 Atmel Corporation + * Copyright (C) 2010 Reinhard Meyer, EMK Elektronik + * * Licensed under the GPL-2 or later. */
@@ -96,13 +98,65 @@ int spi_flash_read_common(struct spi_flash *flash, const u8 *cmd, return ret; }
+/* + * The following table holds all device probe functions + * + * shift: number of continuation bytes before the ID + * idcode: the expected IDCODE or 0xff for non JEDEC devices + * probe: the function to call + * + * Non JEDEC devices should be ordered in the table such that + * the probe functions with best detection algorithms come first. + * + * Several matching entries are permitted, they will be tried + * in sequence until a probe function returns non NULL. + * + * IDCODE_MANU_LEN may be redefined if a device detection requires + * more then 2 bytes (continuation bytes + manu id) of the idcode + * read. IDCODE_PART_LEN generally shouldn't be changed. This is + * the max number of bytes probe functions may examine when looking + * up part-specific identification info. + */ +#define IDCODE_MANU_LEN 1 +#define IDCODE_PART_LEN 4 +static const struct { + const u8 shift; + const u8 idcode; + struct spi_flash *(*probe) (struct spi_slave *spi, u8 *idcode); +} flashes[] = { + /* Keep it sorted by define name */ +#ifdef CONFIG_SPI_FLASH_ATMEL + { 0, 0x1f, spi_flash_probe_atmel, }, +#endif +#ifdef CONFIG_SPI_FLASH_MACRONIX + { 0, 0xc2, spi_flash_probe_macronix, }, +#endif +#ifdef CONFIG_SPI_FLASH_SPANSION + { 0, 0x01, spi_flash_probe_spansion, }, +#endif +#ifdef CONFIG_SPI_FLASH_SST + { 0, 0xbf, spi_flash_probe_sst, }, +#endif +#ifdef CONFIG_SPI_FLASH_STMICRO + { 0, 0x20, spi_flash_probe_stmicro, }, +#endif +#ifdef CONFIG_SPI_FLASH_WINBOND + { 0, 0xef, spi_flash_probe_winbond, }, +#endif + /* Keep it sorted by best detection */ +#ifdef CONFIG_SPI_FLASH_STMICRO + { 0, 0xff, spi_flash_probe_stmicro, }, +#endif +}; +#define IDCODE_LEN (IDCODE_MANU_LEN + IDCODE_PART_LEN) + struct spi_flash *spi_flash_probe(unsigned int bus, unsigned int cs, unsigned int max_hz, unsigned int spi_mode) { struct spi_slave *spi; - struct spi_flash *flash; - int ret; - u8 idcode[5]; + struct spi_flash *flash = NULL; + int ret, i, shift; + u8 idcode[IDCODE_LEN], *idp;
spi = spi_setup_slave(bus, cs, max_hz, spi_mode); if (!spi) { @@ -117,53 +171,34 @@ struct spi_flash *spi_flash_probe(unsigned int bus, unsigned int cs, }
/* Read the ID codes */ - ret = spi_flash_cmd(spi, CMD_READ_ID, &idcode, sizeof(idcode)); + ret = spi_flash_cmd(spi, CMD_READ_ID, idcode, sizeof(idcode)); if (ret) goto err_read_id;
- debug("SF: Got idcode %02x %02x %02x %02x %02x\n", idcode[0], - idcode[1], idcode[2], idcode[3], idcode[4]); - - switch (idcode[0]) { -#ifdef CONFIG_SPI_FLASH_SPANSION - case 0x01: - flash = spi_flash_probe_spansion(spi, idcode); - break; -#endif -#ifdef CONFIG_SPI_FLASH_ATMEL - case 0x1F: - flash = spi_flash_probe_atmel(spi, idcode); - break; -#endif -#ifdef CONFIG_SPI_FLASH_MACRONIX - case 0xc2: - flash = spi_flash_probe_macronix(spi, idcode); - break; -#endif -#ifdef CONFIG_SPI_FLASH_WINBOND - case 0xef: - flash = spi_flash_probe_winbond(spi, idcode); - break; -#endif -#ifdef CONFIG_SPI_FLASH_STMICRO - case 0x20: - case 0xff: /* Let the stmicro func handle non-JEDEC ids */ - flash = spi_flash_probe_stmicro(spi, idcode); - break; +#ifdef DEBUG + printf("SF: Got idcodes\n"); + print_buffer(0, idcode, 1, sizeof(idcode), 0); #endif -#ifdef CONFIG_SPI_FLASH_SST - case 0xBF: - flash = spi_flash_probe_sst(spi, idcode); - break; -#endif - default: - printf("SF: Unsupported manufacturer %02X\n", idcode[0]); - flash = NULL; - break; - }
- if (!flash) + /* count the number of continuation bytes */ + for (shift = 0, idp = idcode; + shift < IDCODE_MANU_LEN && *idp == 0x7f; + ++shift, ++idp) + continue; + + /* search the table for matches in shift and id */ + for (i = 0; i < ARRAY_SIZE(flashes); ++i) + if (flashes[i].shift == shift && flashes[i].idcode == *idp) { + /* we have a match, call probe */ + flash = flashes[i].probe(spi, idcode); + if (flash) + break; + } + + if (!flash) { + printf("SF: Unsupported manufacturer %02x\n", *idp); goto err_manufacturer_probe; + }
This allows for arbitrarily long manufacturer ids following the JEDEC standard of 0x7f continuation bytes. It also makes adding new entries easier as it's just one element in an array. The downside is that it increases code size a bit, but we're talking ~50 bytes.
Signed-off-by: Reinhard Meyer u-boot@emk-elektronik.de Signed-off-by: Mike Frysinger vapier@gentoo.org --- v2 - restore passing shifted idcode buffer to probe - tweak defines further so gcc optimizes better
drivers/mtd/spi/spi_flash.c | 126 ++++++++++++++++++++++++++++--------------- 1 files changed, 82 insertions(+), 44 deletions(-)
diff --git a/drivers/mtd/spi/spi_flash.c b/drivers/mtd/spi/spi_flash.c index ea875dc..b4ba1dd 100644 --- a/drivers/mtd/spi/spi_flash.c +++ b/drivers/mtd/spi/spi_flash.c @@ -2,6 +2,8 @@ * SPI flash interface * * Copyright (C) 2008 Atmel Corporation + * Copyright (C) 2010 Reinhard Meyer, EMK Elektronik + * * Licensed under the GPL-2 or later. */
@@ -96,13 +98,68 @@ int spi_flash_read_common(struct spi_flash *flash, const u8 *cmd, return ret; }
+/* + * The following table holds all device probe functions + * + * shift: number of continuation bytes before the ID + * idcode: the expected IDCODE or 0xff for non JEDEC devices + * probe: the function to call + * + * Non JEDEC devices should be ordered in the table such that + * the probe functions with best detection algorithms come first. + * + * Several matching entries are permitted, they will be tried + * in sequence until a probe function returns non NULL. + * + * IDCODE_CONT_LEN may be redefined if a device needs to declare a + * larger "shift" value. IDCODE_PART_LEN generally shouldn't be + * changed. This is the max number of bytes probe functions may + * examine when looking up part-specific identification info. + * + * Probe functions will be given the idcode buffer starting at their + * manu id byte (the "idcode" in the table below). In other words, + * all of the continuation bytes will be skipped (the "shift" below). + */ +#define IDCODE_CONT_LEN 0 +#define IDCODE_PART_LEN 5 +static const struct { + const u8 shift; + const u8 idcode; + struct spi_flash *(*probe) (struct spi_slave *spi, u8 *idcode); +} flashes[] = { + /* Keep it sorted by define name */ +#ifdef CONFIG_SPI_FLASH_ATMEL + { 0, 0x1f, spi_flash_probe_atmel, }, +#endif +#ifdef CONFIG_SPI_FLASH_MACRONIX + { 0, 0xc2, spi_flash_probe_macronix, }, +#endif +#ifdef CONFIG_SPI_FLASH_SPANSION + { 0, 0x01, spi_flash_probe_spansion, }, +#endif +#ifdef CONFIG_SPI_FLASH_SST + { 0, 0xbf, spi_flash_probe_sst, }, +#endif +#ifdef CONFIG_SPI_FLASH_STMICRO + { 0, 0x20, spi_flash_probe_stmicro, }, +#endif +#ifdef CONFIG_SPI_FLASH_WINBOND + { 0, 0xef, spi_flash_probe_winbond, }, +#endif + /* Keep it sorted by best detection */ +#ifdef CONFIG_SPI_FLASH_STMICRO + { 0, 0xff, spi_flash_probe_stmicro, }, +#endif +}; +#define IDCODE_LEN (IDCODE_CONT_LEN + IDCODE_PART_LEN) + struct spi_flash *spi_flash_probe(unsigned int bus, unsigned int cs, unsigned int max_hz, unsigned int spi_mode) { struct spi_slave *spi; - struct spi_flash *flash; - int ret; - u8 idcode[5]; + struct spi_flash *flash = NULL; + int ret, i, shift; + u8 idcode[IDCODE_LEN], *idp;
spi = spi_setup_slave(bus, cs, max_hz, spi_mode); if (!spi) { @@ -117,53 +174,34 @@ struct spi_flash *spi_flash_probe(unsigned int bus, unsigned int cs, }
- debug("SF: Got idcode %02x %02x %02x %02x %02x\n", idcode[0], - idcode[1], idcode[2], idcode[3], idcode[4]); - - switch (idcode[0]) { -#ifdef CONFIG_SPI_FLASH_SPANSION - case 0x01: - flash = spi_flash_probe_spansion(spi, idcode); - break; +#ifdef DEBUG + printf("SF: Got idcodes\n"); + print_buffer(0, idcode, 1, sizeof(idcode), 0); #endif -#ifdef CONFIG_SPI_FLASH_ATMEL - case 0x1F: - flash = spi_flash_probe_atmel(spi, idcode); - break; -#endif -#ifdef CONFIG_SPI_FLASH_MACRONIX - case 0xc2: - flash = spi_flash_probe_macronix(spi, idcode); - break; -#endif -#ifdef CONFIG_SPI_FLASH_WINBOND - case 0xef: - flash = spi_flash_probe_winbond(spi, idcode); - break; -#endif -#ifdef CONFIG_SPI_FLASH_STMICRO - case 0x20: - case 0xff: /* Let the stmicro func handle non-JEDEC ids */ - flash = spi_flash_probe_stmicro(spi, idcode); - break; -#endif -#ifdef CONFIG_SPI_FLASH_SST - case 0xBF: - flash = spi_flash_probe_sst(spi, idcode); - break; -#endif - default: - printf("SF: Unsupported manufacturer %02X\n", idcode[0]); - flash = NULL; - break; - }
- if (!flash) + /* count the number of continuation bytes */ + for (shift = 0, idp = idcode; + shift < IDCODE_CONT_LEN && *idp == 0x7f; + ++shift, ++idp) + continue; + + /* search the table for matches in shift and id */ + for (i = 0; i < ARRAY_SIZE(flashes); ++i) + if (flashes[i].shift == shift && flashes[i].idcode == *idp) { + /* we have a match, call probe */ + flash = flashes[i].probe(spi, idp); + if (flash) + break; + } + + if (!flash) { + printf("SF: Unsupported manufacturer %02x\n", *idp); goto err_manufacturer_probe; + }
Signed-off-by: Reinhard Meyer u-boot@emk-elektronik.de Signed-off-by: Mike Frysinger vapier@gentoo.org --- drivers/mtd/spi/Makefile | 1 + drivers/mtd/spi/ramtron.c | 319 ++++++++++++++++++++++++++++++++++ drivers/mtd/spi/spi_flash.c | 8 + drivers/mtd/spi/spi_flash_internal.h | 1 + 4 files changed, 329 insertions(+), 0 deletions(-) create mode 100644 drivers/mtd/spi/ramtron.c
COBJS := $(COBJS-y) diff --git a/drivers/mtd/spi/ramtron.c b/drivers/mtd/spi/ramtron.c new file mode 100644 index 0000000..171390d --- /dev/null +++ b/drivers/mtd/spi/ramtron.c @@ -0,0 +1,319 @@ +/* + * (C) Copyright 2010 + * Reinhard Meyer, EMK Elektronik, reinhard.meyer@emk-elektronik.de + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +/* + * Note: RAMTRON SPI FRAMs are ferroelectric, nonvolatile RAMs + * with an interface identical to SPI flash devices. + * However since they behave like RAM there are no delays or + * busy polls required. They can sustain read or write at the + * allowed SPI bus speed, which can be 40 MHz for some devices. + * + * Unfortunately some RAMTRON devices do not have a means of + * identifying them. They will leave the SO line undriven when + * the READ-ID command is issued. It is therefore mandatory + * that the MISO line has a proper pull-up, so that READ-ID + * will return a row of 0xff. This 0xff pseudo-id will cause + * probes by all vendor specific functions that are designed + * to handle it. If the MISO line is not pulled up, READ-ID + * could return any random noise, even mimicking another + * device. + * + * We use CONFIG_SPI_FRAM_RAMTRON_NON_JEDEC + * to define which device will be assumed after a simple status + * register verify. This method is prone to false positive + * detection and should therefore be the last to be tried. + * Enter it in the last position in the table in spi_flash.c! + * + * The define CONFIG_SPI_FRAM_RAMTRON_NON_JEDEC both activates + * compilation of the special handler and defines the device + * to assume. + */ + +#include <common.h> +#include <malloc.h> +#include <spi_flash.h> +#include "spi_flash_internal.h" + +/* RAMTRON commands common to all devices */ +#define CMD_RAMTRON_WREN 0x06 /* Write Enable */ +#define CMD_RAMTRON_WRDI 0x04 /* Write Disable */ +#define CMD_RAMTRON_RDSR 0x05 /* Read Status Register */ +#define CMD_RAMTRON_WRSR 0x01 /* Write Status Register */ +#define CMD_RAMTRON_READ 0x03 /* Read Data Bytes */ +#define CMD_RAMTRON_WRITE 0x02 /* Write Data Bytes */ +/* not all have those: */ +#define CMD_RAMTRON_FSTRD 0x0b /* Fast Read (for compatibility - not used here) */ +#define CMD_RAMTRON_SLEEP 0xb9 /* Enter Sleep Mode */ +#define CMD_RAMTRON_RDID 0x9f /* Read ID */ +#define CMD_RAMTRON_SNR 0xc3 /* Read Serial Number */ + +/* + * Properties of supported FRAMs + * Note: speed is currently not used because we have no method to deliver that + * value to the upper layers + */ +struct ramtron_spi_fram_params { + u32 size; /* size in bytes */ + u8 addr_len; /* number of address bytes */ + u8 merge_cmd; /* some address bits are in the command byte */ + u8 id1; /* device ID 1 (family, density) */ + u8 id2; /* device ID 2 (sub, rev, rsvd) */ + u32 speed; /* max. SPI clock in Hz */ + const char *name; /* name for display and/or matching */ +}; + +struct ramtron_spi_fram { + struct spi_flash flash; + const struct ramtron_spi_fram_params *params; +}; + +static inline struct ramtron_spi_fram *to_ramtron_spi_fram(struct spi_flash + *flash) +{ + return container_of(flash, struct ramtron_spi_fram, flash); +} + +/* + * table describing supported FRAM chips: + * chips without RDID command must have the values 0xff for id1 and id2 + */ +static const struct ramtron_spi_fram_params ramtron_spi_fram_table[] = { + { + .size = 32*1024, + .addr_len = 2, + .merge_cmd = 0, + .id1 = 0x22, + .id2 = 0x00, + .speed = 40000000, + .name = "FM25V02", + }, + { + .size = 32*1024, + .addr_len = 2, + .merge_cmd = 0, + .id1 = 0x22, + .id2 = 0x01, + .speed = 40000000, + .name = "FM25VN02", + }, + { + .size = 64*1024, + .addr_len = 2, + .merge_cmd = 0, + .id1 = 0x23, + .id2 = 0x00, + .speed = 40000000, + .name = "FM25V05", + }, + { + .size = 64*1024, + .addr_len = 2, + .merge_cmd = 0, + .id1 = 0x23, + .id2 = 0x01, + .speed = 40000000, + .name = "FM25VN05", + }, + { + .size = 128*1024, + .addr_len = 3, + .merge_cmd = 0, + .id1 = 0x24, + .id2 = 0x00, + .speed = 40000000, + .name = "FM25V10", + }, + { + .size = 128*1024, + .addr_len = 3, + .merge_cmd = 0, + .id1 = 0x24, + .id2 = 0x01, + .speed = 40000000, + .name = "FM25VN10", + }, +#ifdef CONFIG_SPI_FRAM_RAMTRON_NON_JEDEC + { + .size = 256*1024, + .addr_len = 3, + .merge_cmd = 0, + .id1 = 0xff, + .id2 = 0xff, + .speed = 40000000, + .name = "FM25H20", + }, +#endif +}; + +static int ramtron_common(struct spi_flash *flash, + u32 offset, size_t len, void *buf, u8 command) +{ + struct ramtron_spi_fram *sn = to_ramtron_spi_fram(flash); + u8 cmd[4]; + int cmd_len; + int ret; + + if (sn->params->addr_len == 3 && sn->params->merge_cmd == 0) { + cmd[0] = command; + cmd[1] = offset >> 16; + cmd[2] = offset >> 8; + cmd[3] = offset; + cmd_len = 4; + } else if (sn->params->addr_len == 2 && sn->params->merge_cmd == 0) { + cmd[0] = command; + cmd[1] = offset >> 8; + cmd[2] = offset; + cmd_len = 3; + } else { + printf("SF: unsupported addr_len or merge_cmd\n"); + return -1; + } + + /* claim the bus */ + ret = spi_claim_bus(flash->spi); + if (ret) { + debug("SF: Unable to claim SPI bus\n"); + return ret; + } + + if (command == CMD_RAMTRON_WRITE) { + /* send WREN */ + ret = spi_flash_cmd(flash->spi, CMD_RAMTRON_WREN, NULL, 0); + if (ret < 0) { + debug("SF: Enabling Write failed\n"); + goto releasebus; + } + } + + /* do the transaction */ + if (command == CMD_RAMTRON_WRITE) + ret = spi_flash_cmd_write(flash->spi, cmd, cmd_len, buf, len); + else + ret = spi_flash_cmd_read(flash->spi, cmd, cmd_len, buf, len); + if (ret < 0) + debug("SF: Transaction failed\n"); + +releasebus: + /* release the bus */ + spi_release_bus(flash->spi); + return ret; +} + +static int ramtron_read(struct spi_flash *flash, + u32 offset, size_t len, void *buf) +{ + return ramtron_common(flash, offset, len, buf, + CMD_RAMTRON_READ); +} + +static int ramtron_write(struct spi_flash *flash, + u32 offset, size_t len, const void *buf) +{ + return ramtron_common(flash, offset, len, (void *)buf, + CMD_RAMTRON_WRITE); +} + +int ramtron_erase(struct spi_flash *flash, u32 offset, size_t len) +{ + debug("SF: Erase of RAMTRON FRAMs is pointless\n"); + return -1; +} + +/* + * nore: we are called here with idcode pointing to the first non-0x7f byte + * already! + */ +struct spi_flash *spi_fram_probe_ramtron(struct spi_slave *spi, u8 *idcode) +{ + const struct ramtron_spi_fram_params *params; + struct ramtron_spi_fram *sn; + unsigned int i; +#ifdef CONFIG_SPI_FRAM_RAMTRON_NON_JEDEC + int ret; + u8 sr; +#endif + + /* NOTE: the bus has been claimed before this function is called! */ + switch (idcode[0]) { + case 0xc2: + /* JEDEC conformant RAMTRON id */ + for (i = 0; i < ARRAY_SIZE(ramtron_spi_fram_table); i++) { + params = &ramtron_spi_fram_table[i]; + if (idcode[1] == params->id1 && idcode[2] == params->id2) + goto found; + } + break; +#ifdef CONFIG_SPI_FRAM_RAMTRON_NON_JEDEC + case 0xff: + /* + * probably open MISO line, pulled up. + * We COULD have a non JEDEC conformant FRAM here, + * read the status register to verify + */ + ret = spi_flash_cmd(spi, CMD_RAMTRON_RDSR, &sr, 1); + if (ret) + return NULL; + + /* Bits 5,4,0 are fixed 0 for all devices */ + if ((sr & 0x31) != 0x00) + return NULL; + /* now find the device */ + for (i = 0; i < ARRAY_SIZE(ramtron_spi_fram_table); i++) { + params = &ramtron_spi_fram_table[i]; + if (!strcmp(params->name, CONFIG_SPI_FRAM_RAMTRON_NON_JEDEC)) + goto found; + } + debug("SF: Unsupported non-JEDEC RAMTRON device " + CONFIG_SPI_FRAM_RAMTRON_NON_JEDEC "\n"); + break; +#endif + default: + break; + } + + /* arriving here means no method has found a device we can handle */ + debug("SF/ramtron: unsupported device id0=%02x id1=%02x id2=%02x\n", + idcode[0], idcode[1], idcode[2]); + return NULL; + +found: + sn = malloc(sizeof(*sn)); + if (!sn) { + debug("SF: Failed to allocate memory\n"); + return NULL; + } + + sn->params = params; + sn->flash.spi = spi; + sn->flash.name = params->name; + + sn->flash.write = ramtron_write; + sn->flash.read = ramtron_read; + sn->flash.erase = ramtron_erase; + sn->flash.size = params->size; + + printf("SF: Detected %s with size ", params->name); + print_size(sn->flash.size, "\n"); + + return &sn->flash; +} diff --git a/drivers/mtd/spi/spi_flash.c b/drivers/mtd/spi/spi_flash.c index b4ba1dd..ab02ef3 100644 --- a/drivers/mtd/spi/spi_flash.c +++ b/drivers/mtd/spi/spi_flash.c @@ -146,10 +146,18 @@ static const struct { #ifdef CONFIG_SPI_FLASH_WINBOND { 0, 0xef, spi_flash_probe_winbond, }, #endif +#ifdef CONFIG_SPI_FRAM_RAMTRON + { 6, 0xc2, spi_fram_probe_ramtron, }, +# undef IDCODE_CONT_LEN +# define IDCODE_CONT_LEN 6 +#endif /* Keep it sorted by best detection */ #ifdef CONFIG_SPI_FLASH_STMICRO { 0, 0xff, spi_flash_probe_stmicro, }, #endif +#ifdef CONFIG_SPI_FRAM_RAMTRON_NON_JEDEC + { 0, 0xff, spi_fram_probe_ramtron, }, +#endif }; #define IDCODE_LEN (IDCODE_CONT_LEN + IDCODE_PART_LEN)
[snippebedip]
- { 6, 0xc2, spi_fram_probe_ramtron, },
That code should only increase the IDCODE_CONT_LEN, not set it to a value. It might have been set larger by a previous #ifdef.
+#ifdef CONFIG_SPI_FRAM_RAMTRON + { 6, 0xc2, spi_fram_probe_ramtron, }, +# if IDCODE_CONT_LEN < 6 +# undef IDCODE_CONT_LEN +# define IDCODE_CONT_LEN 6 +# endif +#endif
Even "nicer" and maybe better understandable could be:
+#ifdef CONFIG_SPI_FRAM_RAMTRON +# define RAMTRON_CONT_LEN 6 + { RAMTRON_CONT_LEN, 0xc2, spi_fram_probe_ramtron, }, +# if IDCODE_CONT_LEN < RAMTRON_CONT_LEN +# undef IDCODE_CONT_LEN +# define IDCODE_CONT_LEN RAMTRON_CONT_LEN +# endif +#endif
I cannot test all this right now. Maybe you put just the probing part (1/2) into mainline, once all my local ahead-of-MASTER and posted patches are in mainline, I'll do a big rebase and fix session here and post a new ramtron patch.
Reinhard
i noticed that, but this isnt any different from your original patch, and i figured we could delay worrying about that when someone else proposed something that wanted to change the size. whichever you want.
i'd prefer the first version. i dont think this gains us much.
OK -mike
Mike Frysinger
Reinhard Meyer
