Please pull u-boot-marvell/master
Hi Tom,
please pull this next batch of Marvell related patches:
---------------------------------------------------------------- - Misc turris_omnia/mox related Fixes and impovements (Pali) - Turris Omnia: Add support for configuring mSATA and WWAN slots via env variables (Pali) - net: mvgbe: Set PHY page 0 before phy_connect (Tony) - kirkwood: nsa310s: Use Marvell uclass mvgbe and PHY driver (Tony) - mvebu: turris_omnia: Fix SYS_RSTOUT_* macro names (Pali) - mvebu: clearfog_defconfig: enable setexpr command (Josef) - mvebu: x530: set MPP55 to gpio (Chris) ----------------------------------------------------------------
Here the Azure build, without any issues:
https://dev.azure.com/sr0718/u-boot/_build/results?buildId=179&view=resu...
Thanks, Stefan
The following changes since commit c70c0102af5413cadde6bf90044cb75aefef0584:
Merge tag 'efi-2022-07-rc2' of https://source.denx.de/u-boot/custodians/u-boot-efi (2022-04-29 14:04:08 -0400)
git@source.denx.de:u-boot/custodians/u-boot-marvell.git
for you to fetch changes up to 08dc62c1527ec7401cc98719cde50ca47533a7c2:
ARM: mvebu: x530: set MPP55 to gpio (2022-05-02 07:47:26 +0200)
---------------------------------------------------------------- Chris Packham (1): ARM: mvebu: x530: set MPP55 to gpio
Josef Schlehofer (1): arm: mvebu: clearfog_defconfig: enable setexpr command
Pali Rohár (14): env: sf: Allow to use env_sf_init_addr() at any stage arm: mvebu: turris_omnia: Provide env_sf_get_env_addr() function arm: mvebu: turris_omnia: Enable ENV support in SPL arm: mvebu: turris_omnia: Define only one serdes map variable arm: mvebu: turris_omnia: Allow to configure mSATA slot via env variable arm: mvebu: turris_omnia: Extract code for disabling sata/pcie arm: mvebu: turris_omnia: Signal error when sata/pcie DT mode arm: mvebu: turris_omnia: Add support for USB3.0 mode in WWAN MiniPCIe slot arm: mvebu: turris_omnia: Fix RESET button message arm: mvebu: turris_omnia: Define CONFIG_ETHPRIME instead of ethact= ENV arm: mvebu: turris_omnia: Always enable MMC, SCSI and USB boot targets arm: mvebu: turris_omnia: Add NVMe to boot targets arm: mvebu: turris_mox: Add NVMe and SCSI to boot targets arm: mvebu: turris_omnia: Fix SYS_RSTOUT_* macro names
Tony Dinh (2): net: marvell: mvgbe: Set PHY page 0 before phy_connect arm: kirkwood: nsa310s: Use Marvell uclass mvgbe and PHY driver for DM Ethernet
arch/arm/dts/kirkwood-nsa310s.dts | 1 + board/CZ.NIC/turris_omnia/turris_omnia.c | 215 ++++++++++++++++++++++--------- board/alliedtelesis/x530/x530.c | 2 +- board/zyxel/nsa310s/nsa310s.c | 119 +++++------------ board/zyxel/nsa310s/nsa310s.h | 46 ------- configs/clearfog_defconfig | 1 - configs/nsa310s_defconfig | 6 +- configs/turris_omnia_defconfig | 3 + drivers/net/mvgbe.c | 4 + env/sf.c | 22 ++-- include/configs/nsa310s.h | 11 +- include/configs/turris_mox.h | 2 + include/configs/turris_omnia.h | 26 +--- 13 files changed, 221 insertions(+), 237 deletions(-) delete mode 100644 board/zyxel/nsa310s/nsa310s.h
Stefan Roese
