[U-Boot-Users] undefined instruction during bootp
Hi all, I'm getting an undefined instruction error at the end of the bootp command:
Filename 'kernel_img'. Load address: 0xc0f00000 Loading: ################################################################# ############undefined instruction pc : [<75b1ac08>] lr : [<c1fc139c>] sp : c1f5fb00 ip : ffffffff fp : c1f5fded r10: 8388956c r9 : 328b03e0 r8 : c1f5ffdc r7 : 6bfbb68d r6 : 8ecfd531 r5 : 5faa503d r4 : e926e94c r3 : 70000048 r2 : 6137fe02 r1 : 0000002e r0 : f53c4775 Flags: Nzcv IRQs off FIQs off Mode SVC_32 Resetting CPU ...
This seem to happen durint the NetSendUDPPacket functions:
c1fc1384: ebffff66 bl c1fc1124 <NetSetIP> c1fc1388: e5970000 ldr r0, [r7] c1fc138c: e0601004 rsb r1, r0, r4 c1fc1390: e0811009 add r1, r1, r9 c1fc1394: e281101c add r1, r1, #28 ; 0x1c c1fc1398: eb000d27 bl c1fc483c <eth_send> c1fc139c: e3a00000 mov r0, #0 ; 0x0 c1fc13a0: e28dd00c add sp, sp, #12 ; 0xc c1fc13a4: e8bd8ef0 ldmia sp!, {r4, r5, r6, r7, r9, sl, fp, pc} c1fc13a8: c1fd60d0 ldrgtsb r6, [sp]! c1fc13ac: c1fd6dd4 ldrgtsb r6, [sp, #212]! c1fc13b0: c1fd8d54 mvngts r8, r4, asr sp c1fc13b4: c1fd6dd0 ldrgtsb r6, [sp, #208]! c1fc13b8: c1fd8d48 mvngts r8, r8, asr #26 c1fc13bc: c1fd8d50 mvngts r8, r0, asr sp c1fc13c0: c1fd8d58 mvngts r8, r8, asr sp c1fc13c4: c1fd9380 mvngts r9, r0, lsl #7 c1fc13c8: c1fd937c mvngts r9, ip, ror r3
Does anyone know how to solve this problem?
Thanks, --Jr.
What does your memory map look like? Maybe you are overwriting data or code needed by U-Boot?
Also, consider problem number 1: memory errors dues to incorrect RAM initialization.
-----Original Message----- From: wd@denx.de Sent: Tue, 15 May 2007 23:12:16 +0200 To: ejr@inbox.com Subject: Re: [U-Boot-Users] undefined instruction during bootp
I've considered that but unless I'm missing some config item, that looks good. I've got 32MB ram: arch_number = 0x00000186 env_t = 0x00000000 boot_params = 0xC0000100 DRAM bank = 0x00000000 -> start = 0xC0000000 -> size = 0x02000000 ethaddr = 00:08:EE:00:63:B2 ip_addr = 192.168.0.13 baudrate = 115200 bps
My TEXT_BASE starts at 0xc1fc0000 and I'm loading at 0xc0f00000 (~1.2M)
cpu/mya404/start.o(.text) .text 0xc1fc0000 0x420 cpu/mya404/start.o 0xc1fc0048 _bss_start 0xc1fc004c _bss_end 0xc1fc0044 _armboot_start 0xc1fc0000 _start 0xc1fc03e0 reset_cpu *(.text) .text 0xc1fc0420 0xec board/mia404/libmia404.a(lowlevel_init.o) 0xc1fc0424 lowlevel_init .text 0xc1fc050c 0x4d0 cpu/mya404/libmya404.a(interrupts.o) 0xc1fc088c set_timer 0xc1fc0804 reset_timer 0xc1fc0724 do_fiq 0xc1fc076c interrupt_init 0xc1fc0670 do_undefined_instruction 0xc1fc0534 show_regs 0xc1fc0748 do_irq 0xc1fc09c0 get_tbclk 0xc1fc0878 get_timer 0xc1fc07d0 reset_timer_masked 0xc1fc0518 bad_mode 0xc1fc0808 get_timer_masked 0xc1fc089c udelay 0xc1fc0928 udelay_masked 0xc1fc06b8 do_prefetch_abort 0xc1fc09ac get_ticks 0xc1fc0510 disable_interrupts 0xc1fc0700 do_not_used 0xc1fc06dc do_data_abort 0xc1fc0694 do_software_interrupt 0xc1fc050c enable_interrupts .text 0xc1fc09dc 0x98 lib_arm/libarm.a(_udivsi3.o) 0xc1fc09dc __udivsi3 .text 0xc1fc0a74 0x2f0 lib_arm/libarm.a(board.o) 0xc1fc0b5c hang 0xc1fc0b6c start_armboot 0xc1fc0a74 sbrk .text 0xc1fc0d64 0x4 lib_arm/libarm.a(div0.o) 0xc1fc0d64 __div0 .text 0xc1fc0d68 0x14f8 net/libnet.a(net.o) 0xc1fc1d18 getenv_IPaddr 0xc1fc15b8 NetCksumOk 0xc1fc0f80 NetSetTimeout 0xc1fc1620 copy_filename 0xc1fc15dc NetEthHdrSize 0xc1fc1674 ip_to_string 0xc1fc104c ArpTimeoutCheck 0xc1fc16f0 NetReceive 0xc1fc1c98 string_to_ip 0xc1fc1264 NetSendUDPPacket 0xc1fc16cc print_IPaddr
-- DENX Software Engineering GmbH, MD: Wolfgang Denk & Detlev Zundel HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-10 Fax: (+49)-8142-66989-80 Email: wd@denx.de No, I'm not going to explain it. If you can't figure it out, you didn't want to know anyway... :-) - Larry Wall in 1991Aug7.180856.2854@netlabs.com
In message 50C96E42594.00000616ejr@inbox.com you wrote:
My TEXT_BASE starts at 0xc1fc0000 and I'm loading at 0xc0f00000 (=7E1.2M)
Sounds very tight to me. Download to a much lower address and check what happens...
And please don't full-quote.
I guess it was pretty tight.
Thanks. Jr.
____________________________________________________________ PREVENT ACCESSING DANGEROUS WEBSITES - Protect your computer with Free Web Security Guard! More information at http://www.inbox.com/wsg
Junior
