[GIT PULL] Please pull u-boot-pmic master
Dear Tom,
Please pull u-boot-pmic master into u-boot master branch. If there is a problem, let me know, plz
Best Regards, Jaehoon Chung
CI: https://source.denx.de/u-boot/custodians/u-boot-pmic/-/pipelines/10653
The following changes since commit d71dbe657c3c22f50ecb3df133e5cdd884daae7d:
Merge tag 'efi-2022-04-rc1' of https://source.denx.de/u-boot/custodians/u-boot-efi (2022-01-15 07:39:09 -0500)
git@source.denx.de:u-boot/custodians/u-boot-pmic.git master
for you to fetch changes up to 97187d5e375cd56f96e6ddca44d2790986899dca:
power: domain: Add Apple pmgr driver (2022-01-17 06:56:01 +0900)
---------------------------------------------------------------- Mark Kettenis (3): arm: dts: apple: Update Apple M1 device trees arm: dts: apple: Add u-boot,dm-pre-reloc properties power: domain: Add Apple pmgr driver
arch/arm/Kconfig | 3 + arch/arm/dts/Makefile | 5 +- arch/arm/dts/t8103-j274-u-boot.dtsi | 1 + arch/arm/dts/t8103-j274.dts | 176 +++--- arch/arm/dts/t8103-j293-u-boot.dtsi | 1 + arch/arm/dts/t8103-j293.dts | 135 +++-- arch/arm/dts/t8103-j313-u-boot.dtsi | 1 + arch/arm/dts/t8103-j313.dts | 111 ++++ arch/arm/dts/t8103-j456-u-boot.dtsi | 1 + arch/arm/dts/t8103-j456.dts | 117 ++++ arch/arm/dts/t8103-j457-u-boot.dtsi | 1 + arch/arm/dts/t8103-j457.dts | 105 ++++ arch/arm/dts/t8103-jxxx.dtsi | 143 +++++ arch/arm/dts/t8103-pmgr.dtsi | 1138 +++++++++++++++++++++++++++++++++++ arch/arm/dts/t8103-u-boot.dtsi | 25 + arch/arm/dts/t8103.dtsi | 675 ++++++++++++--------- drivers/power/domain/Kconfig | 9 + drivers/power/domain/Makefile | 1 + drivers/power/domain/apple-pmgr.c | 113 ++++ 19 files changed, 2340 insertions(+), 421 deletions(-) create mode 100644 arch/arm/dts/t8103-j274-u-boot.dtsi create mode 100644 arch/arm/dts/t8103-j293-u-boot.dtsi create mode 100644 arch/arm/dts/t8103-j313-u-boot.dtsi create mode 100644 arch/arm/dts/t8103-j313.dts create mode 100644 arch/arm/dts/t8103-j456-u-boot.dtsi create mode 100644 arch/arm/dts/t8103-j456.dts create mode 100644 arch/arm/dts/t8103-j457-u-boot.dtsi create mode 100644 arch/arm/dts/t8103-j457.dts create mode 100644 arch/arm/dts/t8103-jxxx.dtsi create mode 100644 arch/arm/dts/t8103-pmgr.dtsi create mode 100644 arch/arm/dts/t8103-u-boot.dtsi create mode 100644 drivers/power/domain/apple-pmgr.c
On Mon, Jan 17, 2022 at 08:20:36AM +0900, Jaehoon Chung wrote:
Dear Tom,
Jaehoon Chung
