[U-Boot] [PATCH 1/1] arm: dts: add missing vexpress device trees
Add the device trees for
* vexpress_ca5x2_defconfig * vexpress_ca9x4_defconfig * vexpress_ca15_tc2_defconfig
as available in Linux 5.1 rc5.
We are using the vexpress_ca15_tc2_defconfig and vexpress_ca9x4_defconfig for Travis testing via QEMU.
The UEFI base Embedded Base Boot Requirements Specification (EBBR) requires that an embedded board either provides a device tree or an ACPI table.
All block devices are meant to be moved to the driver model. On ARM this requires a device tree.
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- arch/arm/dts/Makefile | 4 + arch/arm/dts/vexpress-v2m-rs1.dtsi | 437 +++++++++++++++++ arch/arm/dts/vexpress-v2m.dtsi | 451 +++++++++++++++++ arch/arm/dts/vexpress-v2p-ca15_a7.dts | 682 ++++++++++++++++++++++++++ arch/arm/dts/vexpress-v2p-ca5s.dts | 280 +++++++++++ arch/arm/dts/vexpress-v2p-ca9.dts | 368 ++++++++++++++ 6 files changed, 2222 insertions(+) create mode 100644 arch/arm/dts/vexpress-v2m-rs1.dtsi create mode 100644 arch/arm/dts/vexpress-v2m.dtsi create mode 100644 arch/arm/dts/vexpress-v2p-ca15_a7.dts create mode 100644 arch/arm/dts/vexpress-v2p-ca5s.dts create mode 100644 arch/arm/dts/vexpress-v2p-ca9.dts
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 0aee8dfde0..23a19f90b2 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -712,6 +712,10 @@ dtb-$(CONFIG_ARCH_MEDIATEK) += \ dtb-$(CONFIG_TARGET_GE_BX50V3) += imx6q-bx50v3.dtb dtb-$(CONFIG_TARGET_MX53PPD) += imx53-ppd.dtb
+dtb-$(CONFIG_TARGET_VEXPRESS_CA5X2) += vexpress-v2p-ca5s.dtb +dtb-$(CONFIG_TARGET_VEXPRESS_CA9X4) += vexpress-v2p-ca9.dtb +dtb-$(CONFIG_TARGET_VEXPRESS_CA15_TC2) += vexpress-v2p-ca15_a7.dtb + targets += $(dtb-y)
# Add any required device tree compiler flags here diff --git a/arch/arm/dts/vexpress-v2m-rs1.dtsi b/arch/arm/dts/vexpress-v2m-rs1.dtsi new file mode 100644 index 0000000000..d3963e9eaf --- /dev/null +++ b/arch/arm/dts/vexpress-v2m-rs1.dtsi @@ -0,0 +1,437 @@ +/* + * ARM Ltd. Versatile Express + * + * Motherboard Express uATX + * V2M-P1 + * + * HBI-0190D + * + * RS1 memory map ("ARM Cortex-A Series memory map" in the board's + * Technical Reference Manual) + * + * WARNING! The hardware described in this file is independent from the + * original variant (vexpress-v2m.dtsi), but there is a strong + * correspondence between the two configurations. + * + * TAKE CARE WHEN MAINTAINING THIS FILE TO PROPAGATE ANY RELEVANT + * CHANGES TO vexpress-v2m.dtsi! + */ + +/ { + smb@8000000 { + motherboard { + model = "V2M-P1"; + arm,hbi = <0x190>; + arm,vexpress,site = <0>; + arm,v2m-memory-map = "rs1"; + compatible = "arm,vexpress,v2m-p1", "simple-bus"; + #address-cells = <2>; /* SMB chipselect number and offset */ + #size-cells = <1>; + #interrupt-cells = <1>; + ranges; + + flash@0,00000000 { + compatible = "arm,vexpress-flash", "cfi-flash"; + reg = <0 0x00000000 0x04000000>, + <4 0x00000000 0x04000000>; + bank-width = <4>; + }; + + psram@1,00000000 { + compatible = "arm,vexpress-psram", "mtd-ram"; + reg = <1 0x00000000 0x02000000>; + bank-width = <4>; + }; + + ethernet@2,02000000 { + compatible = "smsc,lan9118", "smsc,lan9115"; + reg = <2 0x02000000 0x10000>; + interrupts = <15>; + phy-mode = "mii"; + reg-io-width = <4>; + smsc,irq-active-high; + smsc,irq-push-pull; + vdd33a-supply = <&v2m_fixed_3v3>; + vddvario-supply = <&v2m_fixed_3v3>; + }; + + usb@2,03000000 { + compatible = "nxp,usb-isp1761"; + reg = <2 0x03000000 0x20000>; + interrupts = <16>; + port1-otg; + }; + + iofpga@3,00000000 { + compatible = "simple-bus"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 3 0 0x200000>; + + v2m_sysreg: sysreg@10000 { + compatible = "arm,vexpress-sysreg"; + reg = <0x010000 0x1000>; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 0x10000 0x1000>; + + v2m_led_gpios: gpio@8 { + compatible = "arm,vexpress-sysreg,sys_led"; + reg = <0x008 4>; + gpio-controller; + #gpio-cells = <2>; + }; + + v2m_mmc_gpios: gpio@48 { + compatible = "arm,vexpress-sysreg,sys_mci"; + reg = <0x048 4>; + gpio-controller; + #gpio-cells = <2>; + }; + + v2m_flash_gpios: gpio@4c { + compatible = "arm,vexpress-sysreg,sys_flash"; + reg = <0x04c 4>; + gpio-controller; + #gpio-cells = <2>; + }; + }; + + v2m_sysctl: sysctl@20000 { + compatible = "arm,sp810", "arm,primecell"; + reg = <0x020000 0x1000>; + clocks = <&v2m_refclk32khz>, <&v2m_refclk1mhz>, <&smbclk>; + clock-names = "refclk", "timclk", "apb_pclk"; + #clock-cells = <1>; + clock-output-names = "timerclken0", "timerclken1", "timerclken2", "timerclken3"; + assigned-clocks = <&v2m_sysctl 0>, <&v2m_sysctl 1>, <&v2m_sysctl 3>, <&v2m_sysctl 3>; + assigned-clock-parents = <&v2m_refclk1mhz>, <&v2m_refclk1mhz>, <&v2m_refclk1mhz>, <&v2m_refclk1mhz>; + }; + + /* PCI-E I2C bus */ + v2m_i2c_pcie: i2c@30000 { + compatible = "arm,versatile-i2c"; + reg = <0x030000 0x1000>; + + #address-cells = <1>; + #size-cells = <0>; + + pcie-switch@60 { + compatible = "idt,89hpes32h8"; + reg = <0x60>; + }; + }; + + aaci@40000 { + compatible = "arm,pl041", "arm,primecell"; + reg = <0x040000 0x1000>; + interrupts = <11>; + clocks = <&smbclk>; + clock-names = "apb_pclk"; + }; + + mmci@50000 { + compatible = "arm,pl180", "arm,primecell"; + reg = <0x050000 0x1000>; + interrupts = <9>, <10>; + cd-gpios = <&v2m_mmc_gpios 0 0>; + wp-gpios = <&v2m_mmc_gpios 1 0>; + max-frequency = <12000000>; + vmmc-supply = <&v2m_fixed_3v3>; + clocks = <&v2m_clk24mhz>, <&smbclk>; + clock-names = "mclk", "apb_pclk"; + }; + + kmi@60000 { + compatible = "arm,pl050", "arm,primecell"; + reg = <0x060000 0x1000>; + interrupts = <12>; + clocks = <&v2m_clk24mhz>, <&smbclk>; + clock-names = "KMIREFCLK", "apb_pclk"; + }; + + kmi@70000 { + compatible = "arm,pl050", "arm,primecell"; + reg = <0x070000 0x1000>; + interrupts = <13>; + clocks = <&v2m_clk24mhz>, <&smbclk>; + clock-names = "KMIREFCLK", "apb_pclk"; + }; + + v2m_serial0: uart@90000 { + compatible = "arm,pl011", "arm,primecell"; + reg = <0x090000 0x1000>; + interrupts = <5>; + clocks = <&v2m_oscclk2>, <&smbclk>; + clock-names = "uartclk", "apb_pclk"; + }; + + v2m_serial1: uart@a0000 { + compatible = "arm,pl011", "arm,primecell"; + reg = <0x0a0000 0x1000>; + interrupts = <6>; + clocks = <&v2m_oscclk2>, <&smbclk>; + clock-names = "uartclk", "apb_pclk"; + }; + + v2m_serial2: uart@b0000 { + compatible = "arm,pl011", "arm,primecell"; + reg = <0x0b0000 0x1000>; + interrupts = <7>; + clocks = <&v2m_oscclk2>, <&smbclk>; + clock-names = "uartclk", "apb_pclk"; + }; + + v2m_serial3: uart@c0000 { + compatible = "arm,pl011", "arm,primecell"; + reg = <0x0c0000 0x1000>; + interrupts = <8>; + clocks = <&v2m_oscclk2>, <&smbclk>; + clock-names = "uartclk", "apb_pclk"; + }; + + wdt@f0000 { + compatible = "arm,sp805", "arm,primecell"; + reg = <0x0f0000 0x1000>; + interrupts = <0>; + clocks = <&v2m_refclk32khz>, <&smbclk>; + clock-names = "wdogclk", "apb_pclk"; + }; + + v2m_timer01: timer@110000 { + compatible = "arm,sp804", "arm,primecell"; + reg = <0x110000 0x1000>; + interrupts = <2>; + clocks = <&v2m_sysctl 0>, <&v2m_sysctl 1>, <&smbclk>; + clock-names = "timclken1", "timclken2", "apb_pclk"; + }; + + v2m_timer23: timer@120000 { + compatible = "arm,sp804", "arm,primecell"; + reg = <0x120000 0x1000>; + interrupts = <3>; + clocks = <&v2m_sysctl 2>, <&v2m_sysctl 3>, <&smbclk>; + clock-names = "timclken1", "timclken2", "apb_pclk"; + }; + + /* DVI I2C bus */ + v2m_i2c_dvi: i2c@160000 { + compatible = "arm,versatile-i2c"; + reg = <0x160000 0x1000>; + #address-cells = <1>; + #size-cells = <0>; + + dvi-transmitter@39 { + compatible = "sil,sii9022-tpi", "sil,sii9022"; + reg = <0x39>; + + ports { + #address-cells = <1>; + #size-cells = <0>; + + port@0 { + reg = <0>; + dvi_bridge_in: endpoint { + remote-endpoint = <&clcd_pads>; + }; + }; + }; + }; + + dvi-transmitter@60 { + compatible = "sil,sii9022-cpi", "sil,sii9022"; + reg = <0x60>; + }; + }; + + rtc@170000 { + compatible = "arm,pl031", "arm,primecell"; + reg = <0x170000 0x1000>; + interrupts = <4>; + clocks = <&smbclk>; + clock-names = "apb_pclk"; + }; + + compact-flash@1a0000 { + compatible = "arm,vexpress-cf", "ata-generic"; + reg = <0x1a0000 0x100 + 0x1a0100 0xf00>; + reg-shift = <2>; + }; + + clcd@1f0000 { + compatible = "arm,pl111", "arm,primecell"; + reg = <0x1f0000 0x1000>; + interrupt-names = "combined"; + interrupts = <14>; + clocks = <&v2m_oscclk1>, <&smbclk>; + clock-names = "clcdclk", "apb_pclk"; + /* 800x600 16bpp @36MHz works fine */ + max-memory-bandwidth = <54000000>; + memory-region = <&vram>; + + port { + clcd_pads: endpoint { + remote-endpoint = <&dvi_bridge_in>; + arm,pl11x,tft-r0g0b0-pads = <0 8 16>; + }; + }; + }; + }; + + v2m_fixed_3v3: fixed-regulator-0 { + compatible = "regulator-fixed"; + regulator-name = "3V3"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-always-on; + }; + + v2m_clk24mhz: clk24mhz { + compatible = "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <24000000>; + clock-output-names = "v2m:clk24mhz"; + }; + + v2m_refclk1mhz: refclk1mhz { + compatible = "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <1000000>; + clock-output-names = "v2m:refclk1mhz"; + }; + + v2m_refclk32khz: refclk32khz { + compatible = "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <32768>; + clock-output-names = "v2m:refclk32khz"; + }; + + leds { + compatible = "gpio-leds"; + + user1 { + label = "v2m:green:user1"; + gpios = <&v2m_led_gpios 0 0>; + linux,default-trigger = "heartbeat"; + }; + + user2 { + label = "v2m:green:user2"; + gpios = <&v2m_led_gpios 1 0>; + linux,default-trigger = "mmc0"; + }; + + user3 { + label = "v2m:green:user3"; + gpios = <&v2m_led_gpios 2 0>; + linux,default-trigger = "cpu0"; + }; + + user4 { + label = "v2m:green:user4"; + gpios = <&v2m_led_gpios 3 0>; + linux,default-trigger = "cpu1"; + }; + + user5 { + label = "v2m:green:user5"; + gpios = <&v2m_led_gpios 4 0>; + linux,default-trigger = "cpu2"; + }; + + user6 { + label = "v2m:green:user6"; + gpios = <&v2m_led_gpios 5 0>; + linux,default-trigger = "cpu3"; + }; + + user7 { + label = "v2m:green:user7"; + gpios = <&v2m_led_gpios 6 0>; + linux,default-trigger = "cpu4"; + }; + + user8 { + label = "v2m:green:user8"; + gpios = <&v2m_led_gpios 7 0>; + linux,default-trigger = "cpu5"; + }; + }; + + mcc { + compatible = "arm,vexpress,config-bus"; + arm,vexpress,config-bridge = <&v2m_sysreg>; + + oscclk0 { + /* MCC static memory clock */ + compatible = "arm,vexpress-osc"; + arm,vexpress-sysreg,func = <1 0>; + freq-range = <25000000 60000000>; + #clock-cells = <0>; + clock-output-names = "v2m:oscclk0"; + }; + + v2m_oscclk1: oscclk1 { + /* CLCD clock */ + compatible = "arm,vexpress-osc"; + arm,vexpress-sysreg,func = <1 1>; + freq-range = <23750000 65000000>; + #clock-cells = <0>; + clock-output-names = "v2m:oscclk1"; + }; + + v2m_oscclk2: oscclk2 { + /* IO FPGA peripheral clock */ + compatible = "arm,vexpress-osc"; + arm,vexpress-sysreg,func = <1 2>; + freq-range = <24000000 24000000>; + #clock-cells = <0>; + clock-output-names = "v2m:oscclk2"; + }; + + volt-vio { + /* Logic level voltage */ + compatible = "arm,vexpress-volt"; + arm,vexpress-sysreg,func = <2 0>; + regulator-name = "VIO"; + regulator-always-on; + label = "VIO"; + }; + + temp-mcc { + /* MCC internal operating temperature */ + compatible = "arm,vexpress-temp"; + arm,vexpress-sysreg,func = <4 0>; + label = "MCC"; + }; + + reset { + compatible = "arm,vexpress-reset"; + arm,vexpress-sysreg,func = <5 0>; + }; + + muxfpga { + compatible = "arm,vexpress-muxfpga"; + arm,vexpress-sysreg,func = <7 0>; + }; + + shutdown { + compatible = "arm,vexpress-shutdown"; + arm,vexpress-sysreg,func = <8 0>; + }; + + reboot { + compatible = "arm,vexpress-reboot"; + arm,vexpress-sysreg,func = <9 0>; + }; + + dvimode { + compatible = "arm,vexpress-dvimode"; + arm,vexpress-sysreg,func = <11 0>; + }; + }; + }; + }; +}; diff --git a/arch/arm/dts/vexpress-v2m.dtsi b/arch/arm/dts/vexpress-v2m.dtsi new file mode 100644 index 0000000000..798c97aff7 --- /dev/null +++ b/arch/arm/dts/vexpress-v2m.dtsi @@ -0,0 +1,451 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * ARM Ltd. Versatile Express + * + * Motherboard Express uATX + * V2M-P1 + * + * HBI-0190D + * + * Original memory map ("Legacy memory map" in the board's + * Technical Reference Manual) + * + * WARNING! The hardware described in this file is independent from the + * RS1 variant (vexpress-v2m-rs1.dtsi), but there is a strong + * correspondence between the two configurations. + * + * TAKE CARE WHEN MAINTAINING THIS FILE TO PROPAGATE ANY RELEVANT + * CHANGES TO vexpress-v2m-rs1.dtsi! + */ + +/ { + smb@4000000 { + motherboard { + model = "V2M-P1"; + arm,hbi = <0x190>; + arm,vexpress,site = <0>; + compatible = "arm,vexpress,v2m-p1", "simple-bus"; + #address-cells = <2>; /* SMB chipselect number and offset */ + #size-cells = <1>; + #interrupt-cells = <1>; + ranges; + + flash@0,00000000 { + compatible = "arm,vexpress-flash", "cfi-flash"; + reg = <0 0x00000000 0x04000000>, + <1 0x00000000 0x04000000>; + bank-width = <4>; + }; + + psram@2,00000000 { + compatible = "arm,vexpress-psram", "mtd-ram"; + reg = <2 0x00000000 0x02000000>; + bank-width = <4>; + }; + + ethernet@3,02000000 { + compatible = "smsc,lan9118", "smsc,lan9115"; + reg = <3 0x02000000 0x10000>; + interrupts = <15>; + phy-mode = "mii"; + reg-io-width = <4>; + smsc,irq-active-high; + smsc,irq-push-pull; + vdd33a-supply = <&v2m_fixed_3v3>; + vddvario-supply = <&v2m_fixed_3v3>; + }; + + usb@3,03000000 { + compatible = "nxp,usb-isp1761"; + reg = <3 0x03000000 0x20000>; + interrupts = <16>; + port1-otg; + }; + + iofpga@7,00000000 { + compatible = "simple-bus"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 7 0 0x20000>; + + v2m_sysreg: sysreg@0 { + compatible = "arm,vexpress-sysreg"; + reg = <0x00000 0x1000>; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 0 0x1000>; + + v2m_led_gpios: gpio@8 { + compatible = "arm,vexpress-sysreg,sys_led"; + reg = <0x008 4>; + gpio-controller; + #gpio-cells = <2>; + }; + + v2m_mmc_gpios: gpio@48 { + compatible = "arm,vexpress-sysreg,sys_mci"; + reg = <0x048 4>; + gpio-controller; + #gpio-cells = <2>; + }; + + v2m_flash_gpios: gpio@4c { + compatible = "arm,vexpress-sysreg,sys_flash"; + reg = <0x04c 4>; + gpio-controller; + #gpio-cells = <2>; + }; + }; + + v2m_sysctl: sysctl@1000 { + compatible = "arm,sp810", "arm,primecell"; + reg = <0x01000 0x1000>; + clocks = <&v2m_refclk32khz>, <&v2m_refclk1mhz>, <&smbclk>; + clock-names = "refclk", "timclk", "apb_pclk"; + #clock-cells = <1>; + clock-output-names = "timerclken0", "timerclken1", "timerclken2", "timerclken3"; + assigned-clocks = <&v2m_sysctl 0>, <&v2m_sysctl 1>, <&v2m_sysctl 3>, <&v2m_sysctl 3>; + assigned-clock-parents = <&v2m_refclk1mhz>, <&v2m_refclk1mhz>, <&v2m_refclk1mhz>, <&v2m_refclk1mhz>; + }; + + /* PCI-E I2C bus */ + v2m_i2c_pcie: i2c@2000 { + compatible = "arm,versatile-i2c"; + reg = <0x02000 0x1000>; + + #address-cells = <1>; + #size-cells = <0>; + + pcie-switch@60 { + compatible = "idt,89hpes32h8"; + reg = <0x60>; + }; + }; + + aaci@4000 { + compatible = "arm,pl041", "arm,primecell"; + reg = <0x04000 0x1000>; + interrupts = <11>; + clocks = <&smbclk>; + clock-names = "apb_pclk"; + }; + + mmci@5000 { + compatible = "arm,pl180", "arm,primecell"; + reg = <0x05000 0x1000>; + interrupts = <9>, <10>; + cd-gpios = <&v2m_mmc_gpios 0 0>; + wp-gpios = <&v2m_mmc_gpios 1 0>; + max-frequency = <12000000>; + vmmc-supply = <&v2m_fixed_3v3>; + clocks = <&v2m_clk24mhz>, <&smbclk>; + clock-names = "mclk", "apb_pclk"; + }; + + kmi@6000 { + compatible = "arm,pl050", "arm,primecell"; + reg = <0x06000 0x1000>; + interrupts = <12>; + clocks = <&v2m_clk24mhz>, <&smbclk>; + clock-names = "KMIREFCLK", "apb_pclk"; + }; + + kmi@7000 { + compatible = "arm,pl050", "arm,primecell"; + reg = <0x07000 0x1000>; + interrupts = <13>; + clocks = <&v2m_clk24mhz>, <&smbclk>; + clock-names = "KMIREFCLK", "apb_pclk"; + }; + + v2m_serial0: uart@9000 { + compatible = "arm,pl011", "arm,primecell"; + reg = <0x09000 0x1000>; + interrupts = <5>; + clocks = <&v2m_oscclk2>, <&smbclk>; + clock-names = "uartclk", "apb_pclk"; + }; + + v2m_serial1: uart@a000 { + compatible = "arm,pl011", "arm,primecell"; + reg = <0x0a000 0x1000>; + interrupts = <6>; + clocks = <&v2m_oscclk2>, <&smbclk>; + clock-names = "uartclk", "apb_pclk"; + }; + + v2m_serial2: uart@b000 { + compatible = "arm,pl011", "arm,primecell"; + reg = <0x0b000 0x1000>; + interrupts = <7>; + clocks = <&v2m_oscclk2>, <&smbclk>; + clock-names = "uartclk", "apb_pclk"; + }; + + v2m_serial3: uart@c000 { + compatible = "arm,pl011", "arm,primecell"; + reg = <0x0c000 0x1000>; + interrupts = <8>; + clocks = <&v2m_oscclk2>, <&smbclk>; + clock-names = "uartclk", "apb_pclk"; + }; + + wdt@f000 { + compatible = "arm,sp805", "arm,primecell"; + reg = <0x0f000 0x1000>; + interrupts = <0>; + clocks = <&v2m_refclk32khz>, <&smbclk>; + clock-names = "wdogclk", "apb_pclk"; + }; + + v2m_timer01: timer@11000 { + compatible = "arm,sp804", "arm,primecell"; + reg = <0x11000 0x1000>; + interrupts = <2>; + clocks = <&v2m_sysctl 0>, <&v2m_sysctl 1>, <&smbclk>; + clock-names = "timclken1", "timclken2", "apb_pclk"; + }; + + v2m_timer23: timer@12000 { + compatible = "arm,sp804", "arm,primecell"; + reg = <0x12000 0x1000>; + interrupts = <3>; + clocks = <&v2m_sysctl 2>, <&v2m_sysctl 3>, <&smbclk>; + clock-names = "timclken1", "timclken2", "apb_pclk"; + }; + + /* DVI I2C bus */ + v2m_i2c_dvi: i2c@16000 { + compatible = "arm,versatile-i2c"; + reg = <0x16000 0x1000>; + #address-cells = <1>; + #size-cells = <0>; + + dvi-transmitter@39 { + compatible = "sil,sii9022-tpi", "sil,sii9022"; + reg = <0x39>; + + ports { + #address-cells = <1>; + #size-cells = <0>; + + /* + * Both the core tile and the motherboard routes their output + * pads to this transmitter. The motherboard system controller + * can select one of them as input using a mux register in + * "arm,vexpress-muxfpga". The Vexpress with the CA9 core tile is + * the only platform with this specific set-up. + */ + port@0 { + reg = <0>; + dvi_bridge_in_ct: endpoint { + remote-endpoint = <&clcd_pads_ct>; + }; + }; + port@1 { + reg = <1>; + dvi_bridge_in_mb: endpoint { + remote-endpoint = <&clcd_pads_mb>; + }; + }; + }; + }; + + dvi-transmitter@60 { + compatible = "sil,sii9022-cpi", "sil,sii9022"; + reg = <0x60>; + }; + }; + + rtc@17000 { + compatible = "arm,pl031", "arm,primecell"; + reg = <0x17000 0x1000>; + interrupts = <4>; + clocks = <&smbclk>; + clock-names = "apb_pclk"; + }; + + compact-flash@1a000 { + compatible = "arm,vexpress-cf", "ata-generic"; + reg = <0x1a000 0x100 + 0x1a100 0xf00>; + reg-shift = <2>; + }; + + + clcd@1f000 { + compatible = "arm,pl111", "arm,primecell"; + reg = <0x1f000 0x1000>; + interrupt-names = "combined"; + interrupts = <14>; + clocks = <&v2m_oscclk1>, <&smbclk>; + clock-names = "clcdclk", "apb_pclk"; + /* 800x600 16bpp @36MHz works fine */ + max-memory-bandwidth = <54000000>; + memory-region = <&vram>; + + port { + clcd_pads_mb: endpoint { + remote-endpoint = <&dvi_bridge_in_mb>; + arm,pl11x,tft-r0g0b0-pads = <0 8 16>; + }; + }; + }; + }; + + v2m_fixed_3v3: fixed-regulator-0 { + compatible = "regulator-fixed"; + regulator-name = "3V3"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-always-on; + }; + + v2m_clk24mhz: clk24mhz { + compatible = "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <24000000>; + clock-output-names = "v2m:clk24mhz"; + }; + + v2m_refclk1mhz: refclk1mhz { + compatible = "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <1000000>; + clock-output-names = "v2m:refclk1mhz"; + }; + + v2m_refclk32khz: refclk32khz { + compatible = "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <32768>; + clock-output-names = "v2m:refclk32khz"; + }; + + leds { + compatible = "gpio-leds"; + + user1 { + label = "v2m:green:user1"; + gpios = <&v2m_led_gpios 0 0>; + linux,default-trigger = "heartbeat"; + }; + + user2 { + label = "v2m:green:user2"; + gpios = <&v2m_led_gpios 1 0>; + linux,default-trigger = "mmc0"; + }; + + user3 { + label = "v2m:green:user3"; + gpios = <&v2m_led_gpios 2 0>; + linux,default-trigger = "cpu0"; + }; + + user4 { + label = "v2m:green:user4"; + gpios = <&v2m_led_gpios 3 0>; + linux,default-trigger = "cpu1"; + }; + + user5 { + label = "v2m:green:user5"; + gpios = <&v2m_led_gpios 4 0>; + linux,default-trigger = "cpu2"; + }; + + user6 { + label = "v2m:green:user6"; + gpios = <&v2m_led_gpios 5 0>; + linux,default-trigger = "cpu3"; + }; + + user7 { + label = "v2m:green:user7"; + gpios = <&v2m_led_gpios 6 0>; + linux,default-trigger = "cpu4"; + }; + + user8 { + label = "v2m:green:user8"; + gpios = <&v2m_led_gpios 7 0>; + linux,default-trigger = "cpu5"; + }; + }; + + mcc { + compatible = "arm,vexpress,config-bus"; + arm,vexpress,config-bridge = <&v2m_sysreg>; + + oscclk0 { + /* MCC static memory clock */ + compatible = "arm,vexpress-osc"; + arm,vexpress-sysreg,func = <1 0>; + freq-range = <25000000 60000000>; + #clock-cells = <0>; + clock-output-names = "v2m:oscclk0"; + }; + + v2m_oscclk1: oscclk1 { + /* CLCD clock */ + compatible = "arm,vexpress-osc"; + arm,vexpress-sysreg,func = <1 1>; + freq-range = <23750000 65000000>; + #clock-cells = <0>; + clock-output-names = "v2m:oscclk1"; + }; + + v2m_oscclk2: oscclk2 { + /* IO FPGA peripheral clock */ + compatible = "arm,vexpress-osc"; + arm,vexpress-sysreg,func = <1 2>; + freq-range = <24000000 24000000>; + #clock-cells = <0>; + clock-output-names = "v2m:oscclk2"; + }; + + volt-vio { + /* Logic level voltage */ + compatible = "arm,vexpress-volt"; + arm,vexpress-sysreg,func = <2 0>; + regulator-name = "VIO"; + regulator-always-on; + label = "VIO"; + }; + + temp-mcc { + /* MCC internal operating temperature */ + compatible = "arm,vexpress-temp"; + arm,vexpress-sysreg,func = <4 0>; + label = "MCC"; + }; + + reset { + compatible = "arm,vexpress-reset"; + arm,vexpress-sysreg,func = <5 0>; + }; + + muxfpga { + compatible = "arm,vexpress-muxfpga"; + arm,vexpress-sysreg,func = <7 0>; + }; + + shutdown { + compatible = "arm,vexpress-shutdown"; + arm,vexpress-sysreg,func = <8 0>; + }; + + reboot { + compatible = "arm,vexpress-reboot"; + arm,vexpress-sysreg,func = <9 0>; + }; + + dvimode { + compatible = "arm,vexpress-dvimode"; + arm,vexpress-sysreg,func = <11 0>; + }; + }; + }; + }; +}; \ No newline at end of file diff --git a/arch/arm/dts/vexpress-v2p-ca15_a7.dts b/arch/arm/dts/vexpress-v2p-ca15_a7.dts new file mode 100644 index 0000000000..00cd9f5bef --- /dev/null +++ b/arch/arm/dts/vexpress-v2p-ca15_a7.dts @@ -0,0 +1,682 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * ARM Ltd. Versatile Express + * + * CoreTile Express A15x2 A7x3 + * Cortex-A15_A7 MPCore (V2P-CA15_A7) + * + * HBI-0249A + */ + +/dts-v1/; +#include "vexpress-v2m-rs1.dtsi" + +/ { + model = "V2P-CA15_CA7"; + arm,hbi = <0x249>; + arm,vexpress,site = <0xf>; + compatible = "arm,vexpress,v2p-ca15_a7", "arm,vexpress"; + interrupt-parent = <&gic>; + #address-cells = <2>; + #size-cells = <2>; + + chosen { }; + + aliases { + serial0 = &v2m_serial0; + serial1 = &v2m_serial1; + serial2 = &v2m_serial2; + serial3 = &v2m_serial3; + i2c0 = &v2m_i2c_dvi; + i2c1 = &v2m_i2c_pcie; + }; + + cpus { + #address-cells = <1>; + #size-cells = <0>; + + cpu0: cpu@0 { + device_type = "cpu"; + compatible = "arm,cortex-a15"; + reg = <0>; + cci-control-port = <&cci_control1>; + cpu-idle-states = <&CLUSTER_SLEEP_BIG>; + capacity-dmips-mhz = <1024>; + dynamic-power-coefficient = <990>; + }; + + cpu1: cpu@1 { + device_type = "cpu"; + compatible = "arm,cortex-a15"; + reg = <1>; + cci-control-port = <&cci_control1>; + cpu-idle-states = <&CLUSTER_SLEEP_BIG>; + capacity-dmips-mhz = <1024>; + dynamic-power-coefficient = <990>; + }; + + cpu2: cpu@2 { + device_type = "cpu"; + compatible = "arm,cortex-a7"; + reg = <0x100>; + cci-control-port = <&cci_control2>; + cpu-idle-states = <&CLUSTER_SLEEP_LITTLE>; + capacity-dmips-mhz = <516>; + dynamic-power-coefficient = <133>; + }; + + cpu3: cpu@3 { + device_type = "cpu"; + compatible = "arm,cortex-a7"; + reg = <0x101>; + cci-control-port = <&cci_control2>; + cpu-idle-states = <&CLUSTER_SLEEP_LITTLE>; + capacity-dmips-mhz = <516>; + dynamic-power-coefficient = <133>; + }; + + cpu4: cpu@4 { + device_type = "cpu"; + compatible = "arm,cortex-a7"; + reg = <0x102>; + cci-control-port = <&cci_control2>; + cpu-idle-states = <&CLUSTER_SLEEP_LITTLE>; + capacity-dmips-mhz = <516>; + dynamic-power-coefficient = <133>; + }; + + idle-states { + CLUSTER_SLEEP_BIG: cluster-sleep-big { + compatible = "arm,idle-state"; + local-timer-stop; + entry-latency-us = <1000>; + exit-latency-us = <700>; + min-residency-us = <2000>; + }; + + CLUSTER_SLEEP_LITTLE: cluster-sleep-little { + compatible = "arm,idle-state"; + local-timer-stop; + entry-latency-us = <1000>; + exit-latency-us = <500>; + min-residency-us = <2500>; + }; + }; + }; + + memory@80000000 { + device_type = "memory"; + reg = <0 0x80000000 0 0x40000000>; + }; + + reserved-memory { + #address-cells = <2>; + #size-cells = <2>; + ranges; + + /* Chipselect 2 is physically at 0x18000000 */ + vram: vram@18000000 { + /* 8 MB of designated video RAM */ + compatible = "shared-dma-pool"; + reg = <0 0x18000000 0 0x00800000>; + no-map; + }; + }; + + wdt@2a490000 { + compatible = "arm,sp805", "arm,primecell"; + reg = <0 0x2a490000 0 0x1000>; + interrupts = <0 98 4>; + clocks = <&oscclk6a>, <&oscclk6a>; + clock-names = "wdogclk", "apb_pclk"; + }; + + hdlcd@2b000000 { + compatible = "arm,hdlcd"; + reg = <0 0x2b000000 0 0x1000>; + interrupts = <0 85 4>; + clocks = <&hdlcd_clk>; + clock-names = "pxlclk"; + }; + + memory-controller@2b0a0000 { + compatible = "arm,pl341", "arm,primecell"; + reg = <0 0x2b0a0000 0 0x1000>; + clocks = <&oscclk6a>; + clock-names = "apb_pclk"; + }; + + gic: interrupt-controller@2c001000 { + compatible = "arm,cortex-a15-gic", "arm,cortex-a9-gic"; + #interrupt-cells = <3>; + #address-cells = <0>; + interrupt-controller; + reg = <0 0x2c001000 0 0x1000>, + <0 0x2c002000 0 0x2000>, + <0 0x2c004000 0 0x2000>, + <0 0x2c006000 0 0x2000>; + interrupts = <1 9 0xf04>; + }; + + cci@2c090000 { + compatible = "arm,cci-400"; + #address-cells = <1>; + #size-cells = <1>; + reg = <0 0x2c090000 0 0x1000>; + ranges = <0x0 0x0 0x2c090000 0x10000>; + + cci_control1: slave-if@4000 { + compatible = "arm,cci-400-ctrl-if"; + interface-type = "ace"; + reg = <0x4000 0x1000>; + }; + + cci_control2: slave-if@5000 { + compatible = "arm,cci-400-ctrl-if"; + interface-type = "ace"; + reg = <0x5000 0x1000>; + }; + + pmu@9000 { + compatible = "arm,cci-400-pmu,r0"; + reg = <0x9000 0x5000>; + interrupts = <0 105 4>, + <0 101 4>, + <0 102 4>, + <0 103 4>, + <0 104 4>; + }; + }; + + memory-controller@7ffd0000 { + compatible = "arm,pl354", "arm,primecell"; + reg = <0 0x7ffd0000 0 0x1000>; + interrupts = <0 86 4>, + <0 87 4>; + clocks = <&oscclk6a>; + clock-names = "apb_pclk"; + }; + + dma@7ff00000 { + compatible = "arm,pl330", "arm,primecell"; + reg = <0 0x7ff00000 0 0x1000>; + interrupts = <0 92 4>, + <0 88 4>, + <0 89 4>, + <0 90 4>, + <0 91 4>; + clocks = <&oscclk6a>; + clock-names = "apb_pclk"; + }; + + scc@7fff0000 { + compatible = "arm,vexpress-scc,v2p-ca15_a7", "arm,vexpress-scc"; + reg = <0 0x7fff0000 0 0x1000>; + interrupts = <0 95 4>; + }; + + timer { + compatible = "arm,armv7-timer"; + interrupts = <1 13 0xf08>, + <1 14 0xf08>, + <1 11 0xf08>, + <1 10 0xf08>; + }; + + pmu-a15 { + compatible = "arm,cortex-a15-pmu"; + interrupts = <0 68 4>, + <0 69 4>; + interrupt-affinity = <&cpu0>, + <&cpu1>; + }; + + pmu-a7 { + compatible = "arm,cortex-a7-pmu"; + interrupts = <0 128 4>, + <0 129 4>, + <0 130 4>; + interrupt-affinity = <&cpu2>, + <&cpu3>, + <&cpu4>; + }; + + oscclk6a: oscclk6a { + /* Reference 24MHz clock */ + compatible = "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <24000000>; + clock-output-names = "oscclk6a"; + }; + + dcc { + compatible = "arm,vexpress,config-bus"; + arm,vexpress,config-bridge = <&v2m_sysreg>; + + oscclk0 { + /* A15 PLL 0 reference clock */ + compatible = "arm,vexpress-osc"; + arm,vexpress-sysreg,func = <1 0>; + freq-range = <17000000 50000000>; + #clock-cells = <0>; + clock-output-names = "oscclk0"; + }; + + oscclk1 { + /* A15 PLL 1 reference clock */ + compatible = "arm,vexpress-osc"; + arm,vexpress-sysreg,func = <1 1>; + freq-range = <17000000 50000000>; + #clock-cells = <0>; + clock-output-names = "oscclk1"; + }; + + oscclk2 { + /* A7 PLL 0 reference clock */ + compatible = "arm,vexpress-osc"; + arm,vexpress-sysreg,func = <1 2>; + freq-range = <17000000 50000000>; + #clock-cells = <0>; + clock-output-names = "oscclk2"; + }; + + oscclk3 { + /* A7 PLL 1 reference clock */ + compatible = "arm,vexpress-osc"; + arm,vexpress-sysreg,func = <1 3>; + freq-range = <17000000 50000000>; + #clock-cells = <0>; + clock-output-names = "oscclk3"; + }; + + oscclk4 { + /* External AXI master clock */ + compatible = "arm,vexpress-osc"; + arm,vexpress-sysreg,func = <1 4>; + freq-range = <20000000 40000000>; + #clock-cells = <0>; + clock-output-names = "oscclk4"; + }; + + hdlcd_clk: oscclk5 { + /* HDLCD PLL reference clock */ + compatible = "arm,vexpress-osc"; + arm,vexpress-sysreg,func = <1 5>; + freq-range = <23750000 165000000>; + #clock-cells = <0>; + clock-output-names = "oscclk5"; + }; + + smbclk: oscclk6 { + /* Static memory controller clock */ + compatible = "arm,vexpress-osc"; + arm,vexpress-sysreg,func = <1 6>; + freq-range = <20000000 40000000>; + #clock-cells = <0>; + clock-output-names = "oscclk6"; + }; + + oscclk7 { + /* SYS PLL reference clock */ + compatible = "arm,vexpress-osc"; + arm,vexpress-sysreg,func = <1 7>; + freq-range = <17000000 50000000>; + #clock-cells = <0>; + clock-output-names = "oscclk7"; + }; + + oscclk8 { + /* DDR2 PLL reference clock */ + compatible = "arm,vexpress-osc"; + arm,vexpress-sysreg,func = <1 8>; + freq-range = <20000000 50000000>; + #clock-cells = <0>; + clock-output-names = "oscclk8"; + }; + + volt-a15 { + /* A15 CPU core voltage */ + compatible = "arm,vexpress-volt"; + arm,vexpress-sysreg,func = <2 0>; + regulator-name = "A15 Vcore"; + regulator-min-microvolt = <800000>; + regulator-max-microvolt = <1050000>; + regulator-always-on; + label = "A15 Vcore"; + }; + + volt-a7 { + /* A7 CPU core voltage */ + compatible = "arm,vexpress-volt"; + arm,vexpress-sysreg,func = <2 1>; + regulator-name = "A7 Vcore"; + regulator-min-microvolt = <800000>; + regulator-max-microvolt = <1050000>; + regulator-always-on; + label = "A7 Vcore"; + }; + + amp-a15 { + /* Total current for the two A15 cores */ + compatible = "arm,vexpress-amp"; + arm,vexpress-sysreg,func = <3 0>; + label = "A15 Icore"; + }; + + amp-a7 { + /* Total current for the three A7 cores */ + compatible = "arm,vexpress-amp"; + arm,vexpress-sysreg,func = <3 1>; + label = "A7 Icore"; + }; + + temp-dcc { + /* DCC internal temperature */ + compatible = "arm,vexpress-temp"; + arm,vexpress-sysreg,func = <4 0>; + label = "DCC"; + }; + + power-a15 { + /* Total power for the two A15 cores */ + compatible = "arm,vexpress-power"; + arm,vexpress-sysreg,func = <12 0>; + label = "A15 Pcore"; + }; + + power-a7 { + /* Total power for the three A7 cores */ + compatible = "arm,vexpress-power"; + arm,vexpress-sysreg,func = <12 1>; + label = "A7 Pcore"; + }; + + energy-a15 { + /* Total energy for the two A15 cores */ + compatible = "arm,vexpress-energy"; + arm,vexpress-sysreg,func = <13 0>, <13 1>; + label = "A15 Jcore"; + }; + + energy-a7 { + /* Total energy for the three A7 cores */ + compatible = "arm,vexpress-energy"; + arm,vexpress-sysreg,func = <13 2>, <13 3>; + label = "A7 Jcore"; + }; + }; + + etb@20010000 { + compatible = "arm,coresight-etb10", "arm,primecell"; + reg = <0 0x20010000 0 0x1000>; + + clocks = <&oscclk6a>; + clock-names = "apb_pclk"; + in-ports { + port { + etb_in_port: endpoint { + remote-endpoint = <&replicator_out_port0>; + }; + }; + }; + }; + + tpiu@20030000 { + compatible = "arm,coresight-tpiu", "arm,primecell"; + reg = <0 0x20030000 0 0x1000>; + + clocks = <&oscclk6a>; + clock-names = "apb_pclk"; + in-ports { + port { + tpiu_in_port: endpoint { + remote-endpoint = <&replicator_out_port1>; + }; + }; + }; + }; + + replicator { + /* non-configurable replicators don't show up on the + * AMBA bus. As such no need to add "arm,primecell". + */ + compatible = "arm,coresight-replicator"; + + out-ports { + #address-cells = <1>; + #size-cells = <0>; + + port@0 { + reg = <0>; + replicator_out_port0: endpoint { + remote-endpoint = <&etb_in_port>; + }; + }; + + port@1 { + reg = <1>; + replicator_out_port1: endpoint { + remote-endpoint = <&tpiu_in_port>; + }; + }; + }; + + in-ports { + port { + replicator_in_port0: endpoint { + remote-endpoint = <&funnel_out_port0>; + }; + }; + }; + }; + + funnel@20040000 { + compatible = "arm,coresight-funnel", "arm,primecell"; + reg = <0 0x20040000 0 0x1000>; + + clocks = <&oscclk6a>; + clock-names = "apb_pclk"; + out-ports { + port { + funnel_out_port0: endpoint { + remote-endpoint = + <&replicator_in_port0>; + }; + }; + }; + + in-ports { + #address-cells = <1>; + #size-cells = <0>; + + port@0 { + reg = <0>; + funnel_in_port0: endpoint { + remote-endpoint = <&ptm0_out_port>; + }; + }; + + port@1 { + reg = <1>; + funnel_in_port1: endpoint { + remote-endpoint = <&ptm1_out_port>; + }; + }; + + port@2 { + reg = <2>; + funnel_in_port2: endpoint { + remote-endpoint = <&etm0_out_port>; + }; + }; + + /* Input port #3 is for ITM, not supported here */ + + port@4 { + reg = <4>; + funnel_in_port4: endpoint { + remote-endpoint = <&etm1_out_port>; + }; + }; + + port@5 { + reg = <5>; + funnel_in_port5: endpoint { + remote-endpoint = <&etm2_out_port>; + }; + }; + }; + }; + + ptm@2201c000 { + compatible = "arm,coresight-etm3x", "arm,primecell"; + reg = <0 0x2201c000 0 0x1000>; + + cpu = <&cpu0>; + clocks = <&oscclk6a>; + clock-names = "apb_pclk"; + out-ports { + port { + ptm0_out_port: endpoint { + remote-endpoint = <&funnel_in_port0>; + }; + }; + }; + }; + + ptm@2201d000 { + compatible = "arm,coresight-etm3x", "arm,primecell"; + reg = <0 0x2201d000 0 0x1000>; + + cpu = <&cpu1>; + clocks = <&oscclk6a>; + clock-names = "apb_pclk"; + out-ports { + port { + ptm1_out_port: endpoint { + remote-endpoint = <&funnel_in_port1>; + }; + }; + }; + }; + + etm@2203c000 { + compatible = "arm,coresight-etm3x", "arm,primecell"; + reg = <0 0x2203c000 0 0x1000>; + + cpu = <&cpu2>; + clocks = <&oscclk6a>; + clock-names = "apb_pclk"; + out-ports { + port { + etm0_out_port: endpoint { + remote-endpoint = <&funnel_in_port2>; + }; + }; + }; + }; + + etm@2203d000 { + compatible = "arm,coresight-etm3x", "arm,primecell"; + reg = <0 0x2203d000 0 0x1000>; + + cpu = <&cpu3>; + clocks = <&oscclk6a>; + clock-names = "apb_pclk"; + out-ports { + port { + etm1_out_port: endpoint { + remote-endpoint = <&funnel_in_port4>; + }; + }; + }; + }; + + etm@2203e000 { + compatible = "arm,coresight-etm3x", "arm,primecell"; + reg = <0 0x2203e000 0 0x1000>; + + cpu = <&cpu4>; + clocks = <&oscclk6a>; + clock-names = "apb_pclk"; + out-ports { + port { + etm2_out_port: endpoint { + remote-endpoint = <&funnel_in_port5>; + }; + }; + }; + }; + + smb: smb@8000000 { + compatible = "simple-bus"; + + #address-cells = <2>; + #size-cells = <1>; + ranges = <0 0 0 0x08000000 0x04000000>, + <1 0 0 0x14000000 0x04000000>, + <2 0 0 0x18000000 0x04000000>, + <3 0 0 0x1c000000 0x04000000>, + <4 0 0 0x0c000000 0x04000000>, + <5 0 0 0x10000000 0x04000000>; + + #interrupt-cells = <1>; + interrupt-map-mask = <0 0 63>; + interrupt-map = <0 0 0 &gic 0 0 4>, + <0 0 1 &gic 0 1 4>, + <0 0 2 &gic 0 2 4>, + <0 0 3 &gic 0 3 4>, + <0 0 4 &gic 0 4 4>, + <0 0 5 &gic 0 5 4>, + <0 0 6 &gic 0 6 4>, + <0 0 7 &gic 0 7 4>, + <0 0 8 &gic 0 8 4>, + <0 0 9 &gic 0 9 4>, + <0 0 10 &gic 0 10 4>, + <0 0 11 &gic 0 11 4>, + <0 0 12 &gic 0 12 4>, + <0 0 13 &gic 0 13 4>, + <0 0 14 &gic 0 14 4>, + <0 0 15 &gic 0 15 4>, + <0 0 16 &gic 0 16 4>, + <0 0 17 &gic 0 17 4>, + <0 0 18 &gic 0 18 4>, + <0 0 19 &gic 0 19 4>, + <0 0 20 &gic 0 20 4>, + <0 0 21 &gic 0 21 4>, + <0 0 22 &gic 0 22 4>, + <0 0 23 &gic 0 23 4>, + <0 0 24 &gic 0 24 4>, + <0 0 25 &gic 0 25 4>, + <0 0 26 &gic 0 26 4>, + <0 0 27 &gic 0 27 4>, + <0 0 28 &gic 0 28 4>, + <0 0 29 &gic 0 29 4>, + <0 0 30 &gic 0 30 4>, + <0 0 31 &gic 0 31 4>, + <0 0 32 &gic 0 32 4>, + <0 0 33 &gic 0 33 4>, + <0 0 34 &gic 0 34 4>, + <0 0 35 &gic 0 35 4>, + <0 0 36 &gic 0 36 4>, + <0 0 37 &gic 0 37 4>, + <0 0 38 &gic 0 38 4>, + <0 0 39 &gic 0 39 4>, + <0 0 40 &gic 0 40 4>, + <0 0 41 &gic 0 41 4>, + <0 0 42 &gic 0 42 4>; + }; + + site2: hsb@40000000 { + compatible = "simple-bus"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 0 0x40000000 0x3fef0000>; + #interrupt-cells = <1>; + interrupt-map-mask = <0 3>; + interrupt-map = <0 0 &gic 0 36 4>, + <0 1 &gic 0 37 4>, + <0 2 &gic 0 38 4>, + <0 3 &gic 0 39 4>; + }; +}; diff --git a/arch/arm/dts/vexpress-v2p-ca5s.dts b/arch/arm/dts/vexpress-v2p-ca5s.dts new file mode 100644 index 0000000000..d5b47d526f --- /dev/null +++ b/arch/arm/dts/vexpress-v2p-ca5s.dts @@ -0,0 +1,280 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * ARM Ltd. Versatile Express + * + * CoreTile Express A5x2 + * Cortex-A5 MPCore (V2P-CA5s) + * + * HBI-0225B + */ + +/dts-v1/; +#include "vexpress-v2m-rs1.dtsi" + +/ { + model = "V2P-CA5s"; + arm,hbi = <0x225>; + arm,vexpress,site = <0xf>; + compatible = "arm,vexpress,v2p-ca5s", "arm,vexpress"; + interrupt-parent = <&gic>; + #address-cells = <1>; + #size-cells = <1>; + + chosen { }; + + aliases { + serial0 = &v2m_serial0; + serial1 = &v2m_serial1; + serial2 = &v2m_serial2; + serial3 = &v2m_serial3; + i2c0 = &v2m_i2c_dvi; + i2c1 = &v2m_i2c_pcie; + }; + + cpus { + #address-cells = <1>; + #size-cells = <0>; + + cpu@0 { + device_type = "cpu"; + compatible = "arm,cortex-a5"; + reg = <0>; + next-level-cache = <&L2>; + }; + + cpu@1 { + device_type = "cpu"; + compatible = "arm,cortex-a5"; + reg = <1>; + next-level-cache = <&L2>; + }; + }; + + memory@80000000 { + device_type = "memory"; + reg = <0x80000000 0x40000000>; + }; + + reserved-memory { + #address-cells = <1>; + #size-cells = <1>; + ranges; + + /* Chipselect 2 is physically at 0x18000000 */ + vram: vram@18000000 { + /* 8 MB of designated video RAM */ + compatible = "shared-dma-pool"; + reg = <0x18000000 0x00800000>; + no-map; + }; + }; + + hdlcd@2a110000 { + compatible = "arm,hdlcd"; + reg = <0x2a110000 0x1000>; + interrupts = <0 85 4>; + clocks = <&hdlcd_clk>; + clock-names = "pxlclk"; + }; + + memory-controller@2a150000 { + compatible = "arm,pl341", "arm,primecell"; + reg = <0x2a150000 0x1000>; + clocks = <&axi_clk>; + clock-names = "apb_pclk"; + }; + + memory-controller@2a190000 { + compatible = "arm,pl354", "arm,primecell"; + reg = <0x2a190000 0x1000>; + interrupts = <0 86 4>, + <0 87 4>; + clocks = <&axi_clk>; + clock-names = "apb_pclk"; + }; + + scu@2c000000 { + compatible = "arm,cortex-a5-scu"; + reg = <0x2c000000 0x58>; + }; + + timer@2c000600 { + compatible = "arm,cortex-a5-twd-timer"; + reg = <0x2c000600 0x20>; + interrupts = <1 13 0x304>; + }; + + timer@2c000200 { + compatible = "arm,cortex-a5-global-timer", + "arm,cortex-a9-global-timer"; + reg = <0x2c000200 0x20>; + interrupts = <1 11 0x304>; + clocks = <&cpu_clk>; + }; + + watchdog@2c000620 { + compatible = "arm,cortex-a5-twd-wdt"; + reg = <0x2c000620 0x20>; + interrupts = <1 14 0x304>; + }; + + gic: interrupt-controller@2c001000 { + compatible = "arm,cortex-a5-gic", "arm,cortex-a9-gic"; + #interrupt-cells = <3>; + #address-cells = <0>; + interrupt-controller; + reg = <0x2c001000 0x1000>, + <0x2c000100 0x100>; + }; + + L2: cache-controller@2c0f0000 { + compatible = "arm,pl310-cache"; + reg = <0x2c0f0000 0x1000>; + interrupts = <0 84 4>; + cache-level = <2>; + }; + + pmu { + compatible = "arm,cortex-a5-pmu"; + interrupts = <0 68 4>, + <0 69 4>; + }; + + dcc { + compatible = "arm,vexpress,config-bus"; + arm,vexpress,config-bridge = <&v2m_sysreg>; + + cpu_clk: oscclk0 { + /* CPU and internal AXI reference clock */ + compatible = "arm,vexpress-osc"; + arm,vexpress-sysreg,func = <1 0>; + freq-range = <50000000 100000000>; + #clock-cells = <0>; + clock-output-names = "oscclk0"; + }; + + axi_clk: oscclk1 { + /* Multiplexed AXI master clock */ + compatible = "arm,vexpress-osc"; + arm,vexpress-sysreg,func = <1 1>; + freq-range = <5000000 50000000>; + #clock-cells = <0>; + clock-output-names = "oscclk1"; + }; + + oscclk2 { + /* DDR2 */ + compatible = "arm,vexpress-osc"; + arm,vexpress-sysreg,func = <1 2>; + freq-range = <80000000 120000000>; + #clock-cells = <0>; + clock-output-names = "oscclk2"; + }; + + hdlcd_clk: oscclk3 { + /* HDLCD */ + compatible = "arm,vexpress-osc"; + arm,vexpress-sysreg,func = <1 3>; + freq-range = <23750000 165000000>; + #clock-cells = <0>; + clock-output-names = "oscclk3"; + }; + + oscclk4 { + /* Test chip gate configuration */ + compatible = "arm,vexpress-osc"; + arm,vexpress-sysreg,func = <1 4>; + freq-range = <80000000 80000000>; + #clock-cells = <0>; + clock-output-names = "oscclk4"; + }; + + smbclk: oscclk5 { + /* SMB clock */ + compatible = "arm,vexpress-osc"; + arm,vexpress-sysreg,func = <1 5>; + freq-range = <25000000 60000000>; + #clock-cells = <0>; + clock-output-names = "oscclk5"; + }; + + temp-dcc { + /* DCC internal operating temperature */ + compatible = "arm,vexpress-temp"; + arm,vexpress-sysreg,func = <4 0>; + label = "DCC"; + }; + }; + + smb: smb@8000000 { + compatible = "simple-bus"; + + #address-cells = <2>; + #size-cells = <1>; + ranges = <0 0 0x08000000 0x04000000>, + <1 0 0x14000000 0x04000000>, + <2 0 0x18000000 0x04000000>, + <3 0 0x1c000000 0x04000000>, + <4 0 0x0c000000 0x04000000>, + <5 0 0x10000000 0x04000000>; + + #interrupt-cells = <1>; + interrupt-map-mask = <0 0 63>; + interrupt-map = <0 0 0 &gic 0 0 4>, + <0 0 1 &gic 0 1 4>, + <0 0 2 &gic 0 2 4>, + <0 0 3 &gic 0 3 4>, + <0 0 4 &gic 0 4 4>, + <0 0 5 &gic 0 5 4>, + <0 0 6 &gic 0 6 4>, + <0 0 7 &gic 0 7 4>, + <0 0 8 &gic 0 8 4>, + <0 0 9 &gic 0 9 4>, + <0 0 10 &gic 0 10 4>, + <0 0 11 &gic 0 11 4>, + <0 0 12 &gic 0 12 4>, + <0 0 13 &gic 0 13 4>, + <0 0 14 &gic 0 14 4>, + <0 0 15 &gic 0 15 4>, + <0 0 16 &gic 0 16 4>, + <0 0 17 &gic 0 17 4>, + <0 0 18 &gic 0 18 4>, + <0 0 19 &gic 0 19 4>, + <0 0 20 &gic 0 20 4>, + <0 0 21 &gic 0 21 4>, + <0 0 22 &gic 0 22 4>, + <0 0 23 &gic 0 23 4>, + <0 0 24 &gic 0 24 4>, + <0 0 25 &gic 0 25 4>, + <0 0 26 &gic 0 26 4>, + <0 0 27 &gic 0 27 4>, + <0 0 28 &gic 0 28 4>, + <0 0 29 &gic 0 29 4>, + <0 0 30 &gic 0 30 4>, + <0 0 31 &gic 0 31 4>, + <0 0 32 &gic 0 32 4>, + <0 0 33 &gic 0 33 4>, + <0 0 34 &gic 0 34 4>, + <0 0 35 &gic 0 35 4>, + <0 0 36 &gic 0 36 4>, + <0 0 37 &gic 0 37 4>, + <0 0 38 &gic 0 38 4>, + <0 0 39 &gic 0 39 4>, + <0 0 40 &gic 0 40 4>, + <0 0 41 &gic 0 41 4>, + <0 0 42 &gic 0 42 4>; + }; + + site2: hsb@40000000 { + compatible = "simple-bus"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 0x40000000 0x40000000>; + #interrupt-cells = <1>; + interrupt-map-mask = <0 3>; + interrupt-map = <0 0 &gic 0 36 4>, + <0 1 &gic 0 37 4>, + <0 2 &gic 0 38 4>, + <0 3 &gic 0 39 4>; + }; +}; diff --git a/arch/arm/dts/vexpress-v2p-ca9.dts b/arch/arm/dts/vexpress-v2p-ca9.dts new file mode 100644 index 0000000000..d796efaadb --- /dev/null +++ b/arch/arm/dts/vexpress-v2p-ca9.dts @@ -0,0 +1,368 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * ARM Ltd. Versatile Express + * + * CoreTile Express A9x4 + * Cortex-A9 MPCore (V2P-CA9) + * + * HBI-0191B + */ + +/dts-v1/; +#include "vexpress-v2m.dtsi" + +/ { + model = "V2P-CA9"; + arm,hbi = <0x191>; + arm,vexpress,site = <0xf>; + compatible = "arm,vexpress,v2p-ca9", "arm,vexpress"; + interrupt-parent = <&gic>; + #address-cells = <1>; + #size-cells = <1>; + + chosen { }; + + aliases { + serial0 = &v2m_serial0; + serial1 = &v2m_serial1; + serial2 = &v2m_serial2; + serial3 = &v2m_serial3; + i2c0 = &v2m_i2c_dvi; + i2c1 = &v2m_i2c_pcie; + }; + + cpus { + #address-cells = <1>; + #size-cells = <0>; + + A9_0: cpu@0 { + device_type = "cpu"; + compatible = "arm,cortex-a9"; + reg = <0>; + next-level-cache = <&L2>; + }; + + A9_1: cpu@1 { + device_type = "cpu"; + compatible = "arm,cortex-a9"; + reg = <1>; + next-level-cache = <&L2>; + }; + + A9_2: cpu@2 { + device_type = "cpu"; + compatible = "arm,cortex-a9"; + reg = <2>; + next-level-cache = <&L2>; + }; + + A9_3: cpu@3 { + device_type = "cpu"; + compatible = "arm,cortex-a9"; + reg = <3>; + next-level-cache = <&L2>; + }; + }; + + memory@60000000 { + device_type = "memory"; + reg = <0x60000000 0x40000000>; + }; + + reserved-memory { + #address-cells = <1>; + #size-cells = <1>; + ranges; + + /* Chipselect 3 is physically at 0x4c000000 */ + vram: vram@4c000000 { + /* 8 MB of designated video RAM */ + compatible = "shared-dma-pool"; + reg = <0x4c000000 0x00800000>; + no-map; + }; + }; + + clcd@10020000 { + compatible = "arm,pl111", "arm,primecell"; + reg = <0x10020000 0x1000>; + interrupt-names = "combined"; + interrupts = <0 44 4>; + clocks = <&oscclk1>, <&oscclk2>; + clock-names = "clcdclk", "apb_pclk"; + /* 1024x768 16bpp @65MHz */ + max-memory-bandwidth = <95000000>; + + port { + clcd_pads_ct: endpoint { + remote-endpoint = <&dvi_bridge_in_ct>; + arm,pl11x,tft-r0g0b0-pads = <0 8 16>; + }; + }; + }; + + memory-controller@100e0000 { + compatible = "arm,pl341", "arm,primecell"; + reg = <0x100e0000 0x1000>; + clocks = <&oscclk2>; + clock-names = "apb_pclk"; + }; + + memory-controller@100e1000 { + compatible = "arm,pl354", "arm,primecell"; + reg = <0x100e1000 0x1000>; + interrupts = <0 45 4>, + <0 46 4>; + clocks = <&oscclk2>; + clock-names = "apb_pclk"; + }; + + timer@100e4000 { + compatible = "arm,sp804", "arm,primecell"; + reg = <0x100e4000 0x1000>; + interrupts = <0 48 4>, + <0 49 4>; + clocks = <&oscclk2>, <&oscclk2>; + clock-names = "timclk", "apb_pclk"; + status = "disabled"; + }; + + watchdog@100e5000 { + compatible = "arm,sp805", "arm,primecell"; + reg = <0x100e5000 0x1000>; + interrupts = <0 51 4>; + clocks = <&oscclk2>, <&oscclk2>; + clock-names = "wdogclk", "apb_pclk"; + }; + + scu@1e000000 { + compatible = "arm,cortex-a9-scu"; + reg = <0x1e000000 0x58>; + }; + + timer@1e000600 { + compatible = "arm,cortex-a9-twd-timer"; + reg = <0x1e000600 0x20>; + interrupts = <1 13 0xf04>; + }; + + watchdog@1e000620 { + compatible = "arm,cortex-a9-twd-wdt"; + reg = <0x1e000620 0x20>; + interrupts = <1 14 0xf04>; + }; + + gic: interrupt-controller@1e001000 { + compatible = "arm,cortex-a9-gic"; + #interrupt-cells = <3>; + #address-cells = <0>; + interrupt-controller; + reg = <0x1e001000 0x1000>, + <0x1e000100 0x100>; + }; + + L2: cache-controller@1e00a000 { + compatible = "arm,pl310-cache"; + reg = <0x1e00a000 0x1000>; + interrupts = <0 43 4>; + cache-unified; + cache-level = <2>; + arm,data-latency = <1 1 1>; + arm,tag-latency = <1 1 1>; + }; + + pmu { + compatible = "arm,cortex-a9-pmu"; + interrupts = <0 60 4>, + <0 61 4>, + <0 62 4>, + <0 63 4>; + interrupt-affinity = <&A9_0>, <&A9_1>, <&A9_2>, <&A9_3>; + + }; + + dcc { + compatible = "arm,vexpress,config-bus"; + arm,vexpress,config-bridge = <&v2m_sysreg>; + + oscclk0: extsaxiclk { + /* ACLK clock to the AXI master port on the test chip */ + compatible = "arm,vexpress-osc"; + arm,vexpress-sysreg,func = <1 0>; + freq-range = <30000000 50000000>; + #clock-cells = <0>; + clock-output-names = "extsaxiclk"; + }; + + oscclk1: clcdclk { + /* Reference clock for the CLCD */ + compatible = "arm,vexpress-osc"; + arm,vexpress-sysreg,func = <1 1>; + freq-range = <10000000 80000000>; + #clock-cells = <0>; + clock-output-names = "clcdclk"; + }; + + smbclk: oscclk2: tcrefclk { + /* Reference clock for the test chip internal PLLs */ + compatible = "arm,vexpress-osc"; + arm,vexpress-sysreg,func = <1 2>; + freq-range = <33000000 100000000>; + #clock-cells = <0>; + clock-output-names = "tcrefclk"; + }; + + volt-vd10 { + /* Test Chip internal logic voltage */ + compatible = "arm,vexpress-volt"; + arm,vexpress-sysreg,func = <2 0>; + regulator-name = "VD10"; + regulator-always-on; + label = "VD10"; + }; + + volt-vd10-s2 { + /* PL310, L2 cache, RAM cell supply (not PL310 logic) */ + compatible = "arm,vexpress-volt"; + arm,vexpress-sysreg,func = <2 1>; + regulator-name = "VD10_S2"; + regulator-always-on; + label = "VD10_S2"; + }; + + volt-vd10-s3 { + /* Cortex-A9 system supply, Cores, MPEs, SCU and PL310 logic */ + compatible = "arm,vexpress-volt"; + arm,vexpress-sysreg,func = <2 2>; + regulator-name = "VD10_S3"; + regulator-always-on; + label = "VD10_S3"; + }; + + volt-vcc1v8 { + /* DDR2 SDRAM and Test Chip DDR2 I/O supply */ + compatible = "arm,vexpress-volt"; + arm,vexpress-sysreg,func = <2 3>; + regulator-name = "VCC1V8"; + regulator-always-on; + label = "VCC1V8"; + }; + + volt-ddr2vtt { + /* DDR2 SDRAM VTT termination voltage */ + compatible = "arm,vexpress-volt"; + arm,vexpress-sysreg,func = <2 4>; + regulator-name = "DDR2VTT"; + regulator-always-on; + label = "DDR2VTT"; + }; + + volt-vcc3v3 { + /* Local board supply for miscellaneous logic external to the Test Chip */ + arm,vexpress-sysreg,func = <2 5>; + compatible = "arm,vexpress-volt"; + regulator-name = "VCC3V3"; + regulator-always-on; + label = "VCC3V3"; + }; + + amp-vd10-s2 { + /* PL310, L2 cache, RAM cell supply (not PL310 logic) */ + compatible = "arm,vexpress-amp"; + arm,vexpress-sysreg,func = <3 0>; + label = "VD10_S2"; + }; + + amp-vd10-s3 { + /* Cortex-A9 system supply, Cores, MPEs, SCU and PL310 logic */ + compatible = "arm,vexpress-amp"; + arm,vexpress-sysreg,func = <3 1>; + label = "VD10_S3"; + }; + + power-vd10-s2 { + /* PL310, L2 cache, RAM cell supply (not PL310 logic) */ + compatible = "arm,vexpress-power"; + arm,vexpress-sysreg,func = <12 0>; + label = "PVD10_S2"; + }; + + power-vd10-s3 { + /* Cortex-A9 system supply, Cores, MPEs, SCU and PL310 logic */ + compatible = "arm,vexpress-power"; + arm,vexpress-sysreg,func = <12 1>; + label = "PVD10_S3"; + }; + }; + + smb: smb@4000000 { + compatible = "simple-bus"; + + #address-cells = <2>; + #size-cells = <1>; + ranges = <0 0 0x40000000 0x04000000>, + <1 0 0x44000000 0x04000000>, + <2 0 0x48000000 0x04000000>, + <3 0 0x4c000000 0x04000000>, + <7 0 0x10000000 0x00020000>; + + #interrupt-cells = <1>; + interrupt-map-mask = <0 0 63>; + interrupt-map = <0 0 0 &gic 0 0 4>, + <0 0 1 &gic 0 1 4>, + <0 0 2 &gic 0 2 4>, + <0 0 3 &gic 0 3 4>, + <0 0 4 &gic 0 4 4>, + <0 0 5 &gic 0 5 4>, + <0 0 6 &gic 0 6 4>, + <0 0 7 &gic 0 7 4>, + <0 0 8 &gic 0 8 4>, + <0 0 9 &gic 0 9 4>, + <0 0 10 &gic 0 10 4>, + <0 0 11 &gic 0 11 4>, + <0 0 12 &gic 0 12 4>, + <0 0 13 &gic 0 13 4>, + <0 0 14 &gic 0 14 4>, + <0 0 15 &gic 0 15 4>, + <0 0 16 &gic 0 16 4>, + <0 0 17 &gic 0 17 4>, + <0 0 18 &gic 0 18 4>, + <0 0 19 &gic 0 19 4>, + <0 0 20 &gic 0 20 4>, + <0 0 21 &gic 0 21 4>, + <0 0 22 &gic 0 22 4>, + <0 0 23 &gic 0 23 4>, + <0 0 24 &gic 0 24 4>, + <0 0 25 &gic 0 25 4>, + <0 0 26 &gic 0 26 4>, + <0 0 27 &gic 0 27 4>, + <0 0 28 &gic 0 28 4>, + <0 0 29 &gic 0 29 4>, + <0 0 30 &gic 0 30 4>, + <0 0 31 &gic 0 31 4>, + <0 0 32 &gic 0 32 4>, + <0 0 33 &gic 0 33 4>, + <0 0 34 &gic 0 34 4>, + <0 0 35 &gic 0 35 4>, + <0 0 36 &gic 0 36 4>, + <0 0 37 &gic 0 37 4>, + <0 0 38 &gic 0 38 4>, + <0 0 39 &gic 0 39 4>, + <0 0 40 &gic 0 40 4>, + <0 0 41 &gic 0 41 4>, + <0 0 42 &gic 0 42 4>; + }; + + site2: hsb@e0000000 { + compatible = "simple-bus"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 0xe0000000 0x20000000>; + #interrupt-cells = <1>; + interrupt-map-mask = <0 3>; + interrupt-map = <0 0 &gic 0 36 4>, + <0 1 &gic 0 37 4>, + <0 2 &gic 0 38 4>, + <0 3 &gic 0 39 4>; + }; +}; -- 2.20.1
- vexpress_ca5x2_defconfig
- vexpress_ca9x4_defconfig
- vexpress_ca15_tc2_defconfig
