[U-Boot] [PATCH v4] sf: probe: Add support for S25FL* flash parts
Added S25FL* parts are which are avilable in spi_flash_probe_legacy.c.
Updated the sector_size attributes as per the flash parts. Looks fine for with this sector_size for computing the size of flash.
Signed-off-by: Jagannadha Sutradharudu Teki jaganna@xilinx.com --- Changes for v4: - Update the ext_jedec detection Changes for v3: - none Changes for v2: - Enable CONFIG_SPI_FLASH_SPANSION
drivers/mtd/spi/spi_flash_probe.c | 31 +- dump | 1182 +++++++++++++++++++++++++++++++++++++ 2 files changed, 1207 insertions(+), 6 deletions(-) create mode 100644 dump
diff --git a/drivers/mtd/spi/spi_flash_probe.c b/drivers/mtd/spi/spi_flash_probe.c index a8ce358..283e3ea 100644 --- a/drivers/mtd/spi/spi_flash_probe.c +++ b/drivers/mtd/spi/spi_flash_probe.c @@ -53,6 +53,19 @@ static const struct spi_flash_params spi_flash_params_table[] = { {"MX25L12805", 0xc22018, 0x0, 64 * 1024, 256}, {"MX25L12855E", 0xc22618, 0x0, 64 * 1024, 256}, #endif +#ifdef CONFIG_SPI_FLASH_SPANSION /* SPANSION */ + {"S25FL008A", 0x010213, 0x0, 64 * 1024, 16}, + {"S25FL016A", 0x010214, 0x0, 64 * 1024, 32}, + {"S25FL032A", 0x010215, 0x0, 64 * 1024, 64}, + {"S25FL064A", 0x010216, 0x0, 64 * 1024, 128}, + {"S25FL128P_256K", 0x012018, 0x0300, 256 * 1024, 64}, + {"S25FL128P_64K", 0x012018, 0x0301, 64 * 1024, 256}, + {"S25FL032P", 0x010215, 0x4d00, 64 * 1024, 64}, + {"S25FL064P", 0x010216, 0x4d00, 64 * 1024, 128}, + {"S25FL128S_64K", 0x012018, 0x4d01, 64 * 1024, 256}, + {"S25FL256S_64K", 0x010219, 0x4d01, 64 * 1024, 512}, + {"S25FL512S_64K", 0x010220, 0x4d01, 64 * 1024, 1024}, +#endif #ifdef CONFIG_SPI_FLASH_STMICRO /* STMICRO */ {"M25P10", 0x202011, 0x0, 32 * 1024, 4}, {"M25P20", 0x202012, 0x0, 64 * 1024, 4}, @@ -98,6 +111,7 @@ static const struct spi_flash_params spi_flash_params_table[] = { /* * Note: * Below paired flash devices has similar spi_flash_params params. + * (S25FL129P_64K, S25FL128S_64K) * (W25Q80BL, W25Q80BV) * (W25Q16CL, W25Q16DV) * (W25Q32BV, W25Q32FV_SPI) @@ -111,7 +125,6 @@ static const struct spi_flash_params spi_flash_params_table[] = { * TODO: * ATMEL * RAMTRON - * SPANSION * SST */ }; @@ -122,19 +135,25 @@ struct spi_flash *spi_flash_validate_ids(struct spi_slave *spi, u8 *idcode) struct spi_flash *flash; int i; u16 jedec = idcode[1] << 8 | idcode[2]; + u16 ext_jedec = idcode[3] << 8 | idcode[4];
- /* Get the flash id (jedec = manuf_id + dev_id) */ + /* Get the flash id (jedec = manuf_id + dev_id, ext_jedec) */ for (i = 0; i < ARRAY_SIZE(spi_flash_params_table); i++) { params = &spi_flash_params_table[i]; if ((params->jedec >> 16) == idcode[0]) { - if ((params->jedec & 0xFFFF) == jedec) - break; + if ((params->jedec & 0xFFFF) == jedec) { + if (params->ext_jedec == 0) + break; + else if (params->ext_jedec == ext_jedec) + break; + } } }
if (i == ARRAY_SIZE(spi_flash_params_table)) { - printf("SF: Unsupported flash ID: manuf %02x, jedec %04x\n", - idcode[0], jedec); + printf("SF: Unsupported flash IDs: "); + printf("manuf %02x, jedec %04x, ext_jedec %04x\n", + idcode[0], jedec, ext_jedec); return NULL; }
diff --git a/dump b/dump new file mode 100644 index 0000000..fb4ac4f --- /dev/null +++ b/dump @@ -0,0 +1,1182 @@ +WARNING: line over 80 characters +#872: FILE: drivers/mtd/spi/spi_flash_ops.c:228: ++ debug("PP: 0x%p => cmd = { 0x%02x 0x%02x%02x%02x } chunk_len = %zu\n", + +total: 0 errors, 1 warnings, 0 checks, 1190 lines checked + +NOTE: Ignored message types: COMPLEX_MACRO CONSIDER_KSTRTO MINMAX MULTISTATEMENT_MACRO_USE_DO_WHILE NETWORKING_BLOCK_COMMENT_STYLE USLEEP_RANGE + +0001-sf-Divide-spi_flash-into-multiple-parts.patch has style problems, please review. + +If any of these errors are false positives, please report +them to the maintainer, see CHECKPATCH in MAINTAINERS. +total: 0 errors, 0 warnings, 0 checks, 575 lines checked + +NOTE: Ignored message types: COMPLEX_MACRO CONSIDER_KSTRTO MINMAX MULTISTATEMENT_MACRO_USE_DO_WHILE NETWORKING_BLOCK_COMMENT_STYLE USLEEP_RANGE + +0002-sf-probe-Add-new-spi_flash_probe-support.patch has no obvious style problems and is ready for submission. +total: 0 errors, 0 warnings, 0 checks, 21 lines checked + +NOTE: Ignored message types: COMPLEX_MACRO CONSIDER_KSTRTO MINMAX MULTISTATEMENT_MACRO_USE_DO_WHILE NETWORKING_BLOCK_COMMENT_STYLE USLEEP_RANGE + +0003-sf-probe-Add-support-for-M25P-flash-parts.patch has no obvious style problems and is ready for submission. +total: 0 errors, 0 warnings, 0 checks, 17 lines checked + +NOTE: Ignored message types: COMPLEX_MACRO CONSIDER_KSTRTO MINMAX MULTISTATEMENT_MACRO_USE_DO_WHILE NETWORKING_BLOCK_COMMENT_STYLE USLEEP_RANGE + +0004-sf-probe-Add-support-for-EN25Q-flash-parts.patch has no obvious style problems and is ready for submission. +total: 0 errors, 0 warnings, 0 checks, 17 lines checked + +NOTE: Ignored message types: COMPLEX_MACRO CONSIDER_KSTRTO MINMAX MULTISTATEMENT_MACRO_USE_DO_WHILE NETWORKING_BLOCK_COMMENT_STYLE USLEEP_RANGE + +0005-sf-probe-Add-support-for-GD25-flash-parts.patch has no obvious style problems and is ready for submission. +total: 0 errors, 0 warnings, 0 checks, 22 lines checked + +NOTE: Ignored message types: COMPLEX_MACRO CONSIDER_KSTRTO MINMAX MULTISTATEMENT_MACRO_USE_DO_WHILE NETWORKING_BLOCK_COMMENT_STYLE USLEEP_RANGE + +0006-sf-probe-Add-support-for-MX25L-flash-parts.patch has no obvious style problems and is ready for submission. +total: 0 errors, 0 warnings, 0 checks, 45 lines checked + +NOTE: Ignored message types: COMPLEX_MACRO CONSIDER_KSTRTO MINMAX MULTISTATEMENT_MACRO_USE_DO_WHILE NETWORKING_BLOCK_COMMENT_STYLE USLEEP_RANGE + +0007-sf-probe-Add-support-for-W25-flash-parts.patch has no obvious style problems and is ready for submission. +total: 0 errors, 0 warnings, 0 checks, 62 lines checked + +NOTE: Ignored message types: COMPLEX_MACRO CONSIDER_KSTRTO MINMAX MULTISTATEMENT_MACRO_USE_DO_WHILE NETWORKING_BLOCK_COMMENT_STYLE USLEEP_RANGE + +0008-sf-probe-Add-support-for-S25FL-flash-parts.patch has no obvious style problems and is ready for submission. +total: 0 errors, 0 warnings, 0 checks, 25 lines checked + +NOTE: Ignored message types: COMPLEX_MACRO CONSIDER_KSTRTO MINMAX MULTISTATEMENT_MACRO_USE_DO_WHILE NETWORKING_BLOCK_COMMENT_STYLE USLEEP_RANGE + +0009-sf-probe-Add-support-for-SST25-flash-parts.patch has no obvious style problems and is ready for submission. +total: 0 errors, 0 warnings, 0 checks, 22 lines checked + +NOTE: Ignored message types: COMPLEX_MACRO CONSIDER_KSTRTO MINMAX MULTISTATEMENT_MACRO_USE_DO_WHILE NETWORKING_BLOCK_COMMENT_STYLE USLEEP_RANGE + +0010-sf-probe-Add-support-for-AT45DB-flash-parts.patch has no obvious style problems and is ready for submission. +total: 0 errors, 0 warnings, 0 checks, 174 lines checked + +NOTE: Ignored message types: COMPLEX_MACRO CONSIDER_KSTRTO MINMAX MULTISTATEMENT_MACRO_USE_DO_WHILE NETWORKING_BLOCK_COMMENT_STYLE USLEEP_RANGE + +0011-sf-probe-Give-proper-spacing-on-flash-table-params.patch has no obvious style problems and is ready for submission. +total: 0 errors, 0 warnings, 0 checks, 316 lines checked + +NOTE: Ignored message types: COMPLEX_MACRO CONSIDER_KSTRTO MINMAX MULTISTATEMENT_MACRO_USE_DO_WHILE NETWORKING_BLOCK_COMMENT_STYLE USLEEP_RANGE + +0012-sf-probe-Add-support-for-SST_WP.patch has no obvious style problems and is ready for submission. +total: 0 errors, 0 warnings, 0 checks, 23 lines checked + +NOTE: Ignored message types: COMPLEX_MACRO CONSIDER_KSTRTO MINMAX MULTISTATEMENT_MACRO_USE_DO_WHILE NETWORKING_BLOCK_COMMENT_STYLE USLEEP_RANGE + +0013-sf-probe-Add-support-to-clear-flash-BP-bits.patch has no obvious style problems and is ready for submission. +WARNING: line over 80 characters +#56: FILE: drivers/mtd/spi/spi_flash_probe.c:42: ++ {"AT45DB011D", 0x1f2200, 0x0, 64 * 1024, 4, SECT_4K}, + +WARNING: line over 80 characters +#57: FILE: drivers/mtd/spi/spi_flash_probe.c:43: ++ {"AT45DB021D", 0x1f2300, 0x0, 64 * 1024, 8, SECT_4K}, + +WARNING: line over 80 characters +#58: FILE: drivers/mtd/spi/spi_flash_probe.c:44: ++ {"AT45DB041D", 0x1f2400, 0x0, 64 * 1024, 8, SECT_4K}, + +WARNING: line over 80 characters +#59: FILE: drivers/mtd/spi/spi_flash_probe.c:45: ++ {"AT45DB081D", 0x1f2500, 0x0, 64 * 1024, 16, SECT_4K}, + +WARNING: line over 80 characters +#60: FILE: drivers/mtd/spi/spi_flash_probe.c:46: ++ {"AT45DB161D", 0x1f2600, 0x0, 64 * 1024, 32, SECT_4K}, + +WARNING: line over 80 characters +#61: FILE: drivers/mtd/spi/spi_flash_probe.c:47: ++ {"AT45DB321D", 0x1f2700, 0x0, 64 * 1024, 64, SECT_4K}, + +WARNING: line over 80 characters +#62: FILE: drivers/mtd/spi/spi_flash_probe.c:48: ++ {"AT45DB641D", 0x1f2800, 0x0, 64 * 1024, 128, SECT_4K}, + +WARNING: line over 80 characters +#67: FILE: drivers/mtd/spi/spi_flash_probe.c:51: ++ {"EN25Q32B", 0x1c3016, 0x0, 64 * 1024, 64, 0}, + +WARNING: line over 80 characters +#68: FILE: drivers/mtd/spi/spi_flash_probe.c:52: ++ {"EN25Q128B", 0x1c3018, 0x0, 64 * 1024, 256, 0}, + +WARNING: line over 80 characters +#73: FILE: drivers/mtd/spi/spi_flash_probe.c:55: ++ {"GD25Q64B", 0xc84017, 0x0, 64 * 1024, 128, SECT_4K}, + +WARNING: line over 80 characters +#74: FILE: drivers/mtd/spi/spi_flash_probe.c:56: ++ {"GD25LQ32", 0xc86016, 0x0, 64 * 1024, 64, SECT_4K}, + +WARNING: line over 80 characters +#84: FILE: drivers/mtd/spi/spi_flash_probe.c:59: ++ {"MX25L4005", 0xc22013, 0x0, 64 * 1024, 8, 0}, + +WARNING: line over 80 characters +#85: FILE: drivers/mtd/spi/spi_flash_probe.c:60: ++ {"MX25L8005", 0xc22014, 0x0, 64 * 1024, 16, 0}, + +WARNING: line over 80 characters +#86: FILE: drivers/mtd/spi/spi_flash_probe.c:61: ++ {"MX25L1605D", 0xc22015, 0x0, 64 * 1024, 32, 0}, + +WARNING: line over 80 characters +#87: FILE: drivers/mtd/spi/spi_flash_probe.c:62: ++ {"MX25L3205D", 0xc22016, 0x0, 64 * 1024, 64, 0}, + +WARNING: line over 80 characters +#88: FILE: drivers/mtd/spi/spi_flash_probe.c:63: ++ {"MX25L6405D", 0xc22017, 0x0, 64 * 1024, 128, 0}, + +WARNING: line over 80 characters +#89: FILE: drivers/mtd/spi/spi_flash_probe.c:64: ++ {"MX25L12805", 0xc22018, 0x0, 64 * 1024, 256, 0}, + +WARNING: line over 80 characters +#90: FILE: drivers/mtd/spi/spi_flash_probe.c:65: ++ {"MX25L12855E", 0xc22618, 0x0, 64 * 1024, 256, 0}, + +WARNING: line over 80 characters +#104: FILE: drivers/mtd/spi/spi_flash_probe.c:68: ++ {"S25FL008A", 0x010213, 0x0, 64 * 1024, 16, 0}, + +WARNING: line over 80 characters +#105: FILE: drivers/mtd/spi/spi_flash_probe.c:69: ++ {"S25FL016A", 0x010214, 0x0, 64 * 1024, 32, 0}, + +WARNING: line over 80 characters +#106: FILE: drivers/mtd/spi/spi_flash_probe.c:70: ++ {"S25FL032A", 0x010215, 0x0, 64 * 1024, 64, 0}, + +WARNING: line over 80 characters +#107: FILE: drivers/mtd/spi/spi_flash_probe.c:71: ++ {"S25FL064A", 0x010216, 0x0, 64 * 1024, 128, 0}, + +WARNING: line over 80 characters +#108: FILE: drivers/mtd/spi/spi_flash_probe.c:72: ++ {"S25FL128P_256K", 0x012018, 0x0300, 256 * 1024, 64, 0}, + +WARNING: line over 80 characters +#109: FILE: drivers/mtd/spi/spi_flash_probe.c:73: ++ {"S25FL128P_64K", 0x012018, 0x0301, 64 * 1024, 256, 0}, + +WARNING: line over 80 characters +#110: FILE: drivers/mtd/spi/spi_flash_probe.c:74: ++ {"S25FL032P", 0x010215, 0x4d00, 64 * 1024, 64, 0}, + +WARNING: line over 80 characters +#111: FILE: drivers/mtd/spi/spi_flash_probe.c:75: ++ {"S25FL064P", 0x010216, 0x4d00, 64 * 1024, 128, 0}, + +WARNING: line over 80 characters +#112: FILE: drivers/mtd/spi/spi_flash_probe.c:76: ++ {"S25FL128S_64K", 0x012018, 0x4d01, 64 * 1024, 256, 0}, + +WARNING: line over 80 characters +#113: FILE: drivers/mtd/spi/spi_flash_probe.c:77: ++ {"S25FL256S_64K", 0x010219, 0x4d01, 64 * 1024, 512, 0}, + +WARNING: line over 80 characters +#114: FILE: drivers/mtd/spi/spi_flash_probe.c:78: ++ {"S25FL512S_64K", 0x010220, 0x4d01, 64 * 1024, 1024, 0}, + +WARNING: line over 80 characters +#137: FILE: drivers/mtd/spi/spi_flash_probe.c:81: ++ {"M25P10", 0x202011, 0x0, 32 * 1024, 4, 0}, + +WARNING: line over 80 characters +#138: FILE: drivers/mtd/spi/spi_flash_probe.c:82: ++ {"M25P20", 0x202012, 0x0, 64 * 1024, 4, 0}, + +WARNING: line over 80 characters +#139: FILE: drivers/mtd/spi/spi_flash_probe.c:83: ++ {"M25P40", 0x202013, 0x0, 64 * 1024, 8, 0}, + +WARNING: line over 80 characters +#140: FILE: drivers/mtd/spi/spi_flash_probe.c:84: ++ {"M25P80", 0x202014, 0x0, 64 * 1024, 16, 0}, + +WARNING: line over 80 characters +#141: FILE: drivers/mtd/spi/spi_flash_probe.c:85: ++ {"M25P16", 0x202015, 0x0, 64 * 1024, 32, 0}, + +WARNING: line over 80 characters +#142: FILE: drivers/mtd/spi/spi_flash_probe.c:86: ++ {"M25P32", 0x202016, 0x0, 64 * 1024, 64, 0}, + +WARNING: line over 80 characters +#143: FILE: drivers/mtd/spi/spi_flash_probe.c:87: ++ {"M25P64", 0x202017, 0x0, 64 * 1024, 128, 0}, + +WARNING: line over 80 characters +#144: FILE: drivers/mtd/spi/spi_flash_probe.c:88: ++ {"M25P128", 0x202018, 0x0, 256 * 1024, 64, 0}, + +WARNING: line over 80 characters +#145: FILE: drivers/mtd/spi/spi_flash_probe.c:89: ++ {"N25Q32", 0x20ba16, 0x0, 64 * 1024, 64, SECT_4K}, + +WARNING: line over 80 characters +#146: FILE: drivers/mtd/spi/spi_flash_probe.c:90: ++ {"N25Q32A", 0x20bb16, 0x0, 64 * 1024, 64, SECT_4K}, + +WARNING: line over 80 characters +#147: FILE: drivers/mtd/spi/spi_flash_probe.c:91: ++ {"N25Q64", 0x20ba17, 0x0, 64 * 1024, 128, SECT_4K}, + +WARNING: line over 80 characters +#148: FILE: drivers/mtd/spi/spi_flash_probe.c:92: ++ {"N25Q64A", 0x20bb17, 0x0, 64 * 1024, 128, SECT_4K}, + +WARNING: line over 80 characters +#149: FILE: drivers/mtd/spi/spi_flash_probe.c:93: ++ {"N25Q128", 0x20ba18, 0x0, 64 * 1024, 256, SECT_4K}, + +WARNING: line over 80 characters +#150: FILE: drivers/mtd/spi/spi_flash_probe.c:94: ++ {"N25Q128A", 0x20bb18, 0x0, 64 * 1024, 256, SECT_4K}, + +WARNING: line over 80 characters +#151: FILE: drivers/mtd/spi/spi_flash_probe.c:95: ++ {"N25Q256", 0x20ba19, 0x0, 64 * 1024, 512, SECT_4K}, + +WARNING: line over 80 characters +#152: FILE: drivers/mtd/spi/spi_flash_probe.c:96: ++ {"N25Q256A", 0x20bb19, 0x0, 64 * 1024, 512, SECT_4K}, + +WARNING: line over 80 characters +#153: FILE: drivers/mtd/spi/spi_flash_probe.c:97: ++ {"N25Q512", 0x20ba20, 0x0, 64 * 1024, 1024, SECT_4K}, + +WARNING: line over 80 characters +#154: FILE: drivers/mtd/spi/spi_flash_probe.c:98: ++ {"N25Q512A", 0x20bb20, 0x0, 64 * 1024, 1024, SECT_4K}, + +WARNING: line over 80 characters +#155: FILE: drivers/mtd/spi/spi_flash_probe.c:99: ++ {"N25Q1024", 0x20ba21, 0x0, 64 * 1024, 2048, SECT_4K}, + +WARNING: line over 80 characters +#156: FILE: drivers/mtd/spi/spi_flash_probe.c:100: ++ {"N25Q1024A", 0x20bb21, 0x0, 64 * 1024, 2048, SECT_4K}, + +WARNING: line over 80 characters +#169: FILE: drivers/mtd/spi/spi_flash_probe.c:103: ++ {"SST25VF040B", 0xbf258d, 0x0, 64 * 1024, 8, SECT_4K | SST_WP}, + +WARNING: line over 80 characters +#170: FILE: drivers/mtd/spi/spi_flash_probe.c:104: ++ {"SST25VF080B", 0xbf258e, 0x0, 64 * 1024, 16, SECT_4K | SST_WP}, + +WARNING: line over 80 characters +#171: FILE: drivers/mtd/spi/spi_flash_probe.c:105: ++ {"SST25VF016B", 0xbf2541, 0x0, 64 * 1024, 32, SECT_4K | SST_WP}, + +WARNING: line over 80 characters +#172: FILE: drivers/mtd/spi/spi_flash_probe.c:106: ++ {"SST25VF032B", 0xbf254a, 0x0, 64 * 1024, 64, SECT_4K | SST_WP}, + +WARNING: line over 80 characters +#173: FILE: drivers/mtd/spi/spi_flash_probe.c:107: ++ {"SST25VF064C", 0xbf254b, 0x0, 64 * 1024, 128, SECT_4K}, + +WARNING: line over 80 characters +#174: FILE: drivers/mtd/spi/spi_flash_probe.c:108: ++ {"SST25WF512", 0xbf2501, 0x0, 64 * 1024, 1, SECT_4K | SST_WP}, + +WARNING: line over 80 characters +#175: FILE: drivers/mtd/spi/spi_flash_probe.c:109: ++ {"SST25WF010", 0xbf2502, 0x0, 64 * 1024, 2, SECT_4K | SST_WP}, + +WARNING: line over 80 characters +#176: FILE: drivers/mtd/spi/spi_flash_probe.c:110: ++ {"SST25WF020", 0xbf2503, 0x0, 64 * 1024, 4, SECT_4K | SST_WP}, + +WARNING: line over 80 characters +#177: FILE: drivers/mtd/spi/spi_flash_probe.c:111: ++ {"SST25WF040", 0xbf2504, 0x0, 64 * 1024, 8, SECT_4K | SST_WP}, + +WARNING: line over 80 characters +#178: FILE: drivers/mtd/spi/spi_flash_probe.c:112: ++ {"SST25WF080", 0xbf2505, 0x0, 64 * 1024, 16, SECT_4K | SST_WP}, + +WARNING: line over 80 characters +#199: FILE: drivers/mtd/spi/spi_flash_probe.c:115: ++ {"W25P80", 0xef2014, 0x0, 64 * 1024, 16, 0}, + +WARNING: line over 80 characters +#200: FILE: drivers/mtd/spi/spi_flash_probe.c:116: ++ {"W25P16", 0xef2015, 0x0, 64 * 1024, 32, 0}, + +WARNING: line over 80 characters +#201: FILE: drivers/mtd/spi/spi_flash_probe.c:117: ++ {"W25P32", 0xef2016, 0x0, 64 * 1024, 64, 0}, + +WARNING: line over 80 characters +#202: FILE: drivers/mtd/spi/spi_flash_probe.c:118: ++ {"W25X40", 0xef3013, 0x0, 4 * 1024, 128, SECT_4K}, + +WARNING: line over 80 characters +#203: FILE: drivers/mtd/spi/spi_flash_probe.c:119: ++ {"W25X16", 0xef3015, 0x0, 4 * 1024, 512, SECT_4K}, + +WARNING: line over 80 characters +#204: FILE: drivers/mtd/spi/spi_flash_probe.c:120: ++ {"W25X32", 0xef3016, 0x0, 4 * 1024, 1024, SECT_4K}, + +WARNING: line over 80 characters +#205: FILE: drivers/mtd/spi/spi_flash_probe.c:121: ++ {"W25X64", 0xef3017, 0x0, 4 * 1024, 2048, SECT_4K}, + +WARNING: line over 80 characters +#206: FILE: drivers/mtd/spi/spi_flash_probe.c:122: ++ {"W25Q80BL", 0xef4014, 0x0, 4 * 1024, 256, SECT_4K}, + +WARNING: line over 80 characters +#207: FILE: drivers/mtd/spi/spi_flash_probe.c:123: ++ {"W25Q16CL", 0xef4015, 0x0, 4 * 1024, 512, SECT_4K}, + +WARNING: line over 80 characters +#208: FILE: drivers/mtd/spi/spi_flash_probe.c:124: ++ {"W25Q32BV", 0xef4016, 0x0, 4 * 1024, 1024, SECT_4K}, + +WARNING: line over 80 characters +#209: FILE: drivers/mtd/spi/spi_flash_probe.c:125: ++ {"W25Q64CV", 0xef4017, 0x0, 4 * 1024, 2048, SECT_4K}, + +WARNING: line over 80 characters +#210: FILE: drivers/mtd/spi/spi_flash_probe.c:126: ++ {"W25Q128BV", 0xef4018, 0x0, 4 * 1024, 4096, SECT_4K}, + +WARNING: line over 80 characters +#211: FILE: drivers/mtd/spi/spi_flash_probe.c:127: ++ {"W25Q256", 0xef4019, 0x0, 4 * 1024, 8192, SECT_4K}, + +WARNING: line over 80 characters +#212: FILE: drivers/mtd/spi/spi_flash_probe.c:128: ++ {"W25Q80BW", 0xef5014, 0x0, 4 * 1024, 256, SECT_4K}, + +WARNING: line over 80 characters +#213: FILE: drivers/mtd/spi/spi_flash_probe.c:129: ++ {"W25Q16DW", 0xef6015, 0x0, 4 * 1024, 512, SECT_4K}, + +WARNING: line over 80 characters +#214: FILE: drivers/mtd/spi/spi_flash_probe.c:130: ++ {"W25Q32DW", 0xef6016, 0x0, 4 * 1024, 1024, SECT_4K}, + +WARNING: line over 80 characters +#215: FILE: drivers/mtd/spi/spi_flash_probe.c:131: ++ {"W25Q64DW", 0xef6017, 0x0, 4 * 1024, 2048, SECT_4K}, + +WARNING: line over 80 characters +#216: FILE: drivers/mtd/spi/spi_flash_probe.c:132: ++ {"W25Q128FW", 0xef6018, 0x0, 4 * 1024, 4096, SECT_4K}, + +total: 0 errors, 77 warnings, 0 checks, 240 lines checked + +NOTE: Ignored message types: COMPLEX_MACRO CONSIDER_KSTRTO MINMAX MULTISTATEMENT_MACRO_USE_DO_WHILE NETWORKING_BLOCK_COMMENT_STYLE USLEEP_RANGE + +0014-sf-probe-Add-support-for-erase-sector-selection-flag.patch has style problems, please review. + +If any of these errors are false positives, please report +them to the maintainer, see CHECKPATCH in MAINTAINERS. +WARNING: line over 80 characters +#28: FILE: drivers/mtd/spi/spi_flash_probe.c:97: ++ {"N25Q512", 0x20ba20, 0x0, 64 * 1024, 1024, E_FSR | SECT_4K}, + +WARNING: line over 80 characters +#29: FILE: drivers/mtd/spi/spi_flash_probe.c:98: ++ {"N25Q512A", 0x20bb20, 0x0, 64 * 1024, 1024, E_FSR | SECT_4K}, + +WARNING: line over 80 characters +#30: FILE: drivers/mtd/spi/spi_flash_probe.c:99: ++ {"N25Q1024", 0x20ba21, 0x0, 64 * 1024, 2048, E_FSR | SECT_4K}, + +WARNING: line over 80 characters +#31: FILE: drivers/mtd/spi/spi_flash_probe.c:100: ++ {"N25Q1024A", 0x20bb21, 0x0, 64 * 1024, 2048, E_FSR | SECT_4K}, + +total: 0 errors, 4 warnings, 0 checks, 39 lines checked + +NOTE: Ignored message types: COMPLEX_MACRO CONSIDER_KSTRTO MINMAX MULTISTATEMENT_MACRO_USE_DO_WHILE NETWORKING_BLOCK_COMMENT_STYLE USLEEP_RANGE + +0015-sf-probe-Add-support-for-flag-status-polling.patch has style problems, please review. + +If any of these errors are false positives, please report +them to the maintainer, see CHECKPATCH in MAINTAINERS. +total: 0 errors, 0 warnings, 0 checks, 75 lines checked + +NOTE: Ignored message types: COMPLEX_MACRO CONSIDER_KSTRTO MINMAX MULTISTATEMENT_MACRO_USE_DO_WHILE NETWORKING_BLOCK_COMMENT_STYLE USLEEP_RANGE + +0016-sf-probe-Move-BAR-config-to-spi_flash_validate_ids.patch has no obvious style problems and is ready for submission. +total: 0 errors, 0 warnings, 0 checks, 74 lines checked + +NOTE: Ignored message types: COMPLEX_MACRO CONSIDER_KSTRTO MINMAX MULTISTATEMENT_MACRO_USE_DO_WHILE NETWORKING_BLOCK_COMMENT_STYLE USLEEP_RANGE + +0017-sf-Add-proper-comment-style-on-spi_flash-structure.patch has no obvious style problems and is ready for submission. +total: 0 errors, 0 warnings, 0 checks, 166 lines checked + +NOTE: Ignored message types: COMPLEX_MACRO CONSIDER_KSTRTO MINMAX MULTISTATEMENT_MACRO_USE_DO_WHILE NETWORKING_BLOCK_COMMENT_STYLE USLEEP_RANGE + +0018-sf-ramtron-Add-support-for-separate-flash-driver.patch has no obvious style problems and is ready for submission. +total: 0 errors, 0 warnings, 0 checks, 17 lines checked + +NOTE: Ignored message types: COMPLEX_MACRO CONSIDER_KSTRTO MINMAX MULTISTATEMENT_MACRO_USE_DO_WHILE NETWORKING_BLOCK_COMMENT_STYLE USLEEP_RANGE + +0019-sf-Remove-unneeded-flash-drivers-files.patch has no obvious style problems and is ready for submission. +WARNING: line over 80 characters +#21: FILE: drivers/mtd/spi/spi_flash_probe.c:52: ++ {"EN25Q64", 0x1c3017, 0x0, 64 * 1024, 128, SECT_4K}, + +total: 0 errors, 1 warnings, 0 checks, 7 lines checked + +NOTE: Ignored message types: COMPLEX_MACRO CONSIDER_KSTRTO MINMAX MULTISTATEMENT_MACRO_USE_DO_WHILE NETWORKING_BLOCK_COMMENT_STYLE USLEEP_RANGE + +0020-sf-probe-Add-support-for-EN25Q64.patch has style problems, please review. + +If any of these errors are false positives, please report +them to the maintainer, see CHECKPATCH in MAINTAINERS. +WARNING: line over 80 characters +#21: FILE: drivers/mtd/spi/spi_flash_probe.c:78: ++ {"S25FL256S_256K", 0x010219, 0x4d00, 64 * 1024, 512, 0}, + +total: 0 errors, 1 warnings, 0 checks, 15 lines checked + +NOTE: Ignored message types: COMPLEX_MACRO CONSIDER_KSTRTO MINMAX MULTISTATEMENT_MACRO_USE_DO_WHILE NETWORKING_BLOCK_COMMENT_STYLE USLEEP_RANGE + +0021-sf-probe-Add-support-for-S25FL256S_256K.patch has style problems, please review. + +If any of these errors are false positives, please report +them to the maintainer, see CHECKPATCH in MAINTAINERS. +WARNING: line over 80 characters +#21: FILE: drivers/mtd/spi/spi_flash_probe.c:80: ++ {"S25FL512S_256K", 0x010220, 0x4d00, 64 * 1024, 1024, 0}, + +total: 0 errors, 1 warnings, 0 checks, 7 lines checked + +NOTE: Ignored message types: COMPLEX_MACRO CONSIDER_KSTRTO MINMAX MULTISTATEMENT_MACRO_USE_DO_WHILE NETWORKING_BLOCK_COMMENT_STYLE USLEEP_RANGE + +0022-sf-probe-Add-support-for-S25FL512S_256K.patch has style problems, please review. + +If any of these errors are false positives, please report +them to the maintainer, see CHECKPATCH in MAINTAINERS. +total: 0 errors, 0 warnings, 0 checks, 8 lines checked + +NOTE: Ignored message types: COMPLEX_MACRO CONSIDER_KSTRTO MINMAX MULTISTATEMENT_MACRO_USE_DO_WHILE NETWORKING_BLOCK_COMMENT_STYLE USLEEP_RANGE + +0023-sf-probe-Use-print_size-arg-as-page_size.patch has no obvious style problems and is ready for submission. +total: 0 errors, 0 warnings, 0 checks, 9 lines checked + +NOTE: Ignored message types: COMPLEX_MACRO CONSIDER_KSTRTO MINMAX MULTISTATEMENT_MACRO_USE_DO_WHILE NETWORKING_BLOCK_COMMENT_STYLE USLEEP_RANGE + +0024-sf-probe-Print-erase_size-while-printing-flash-detai.patch has no obvious style problems and is ready for submission. +total: 0 errors, 0 warnings, 0 checks, 91 lines checked + +NOTE: Ignored message types: COMPLEX_MACRO CONSIDER_KSTRTO MINMAX MULTISTATEMENT_MACRO_USE_DO_WHILE NETWORKING_BLOCK_COMMENT_STYLE USLEEP_RANGE + +0025-sf-probe-Simply-the-BAR-configuration-logic.patch has no obvious style problems and is ready for submission. +total: 0 errors, 0 warnings, 0 checks, 19 lines checked + +NOTE: Ignored message types: COMPLEX_MACRO CONSIDER_KSTRTO MINMAX MULTISTATEMENT_MACRO_USE_DO_WHILE NETWORKING_BLOCK_COMMENT_STYLE USLEEP_RANGE + +0026-sf-ops-Add-static-qualifier-to-spi_flash_cmd_bankadd.patch has no obvious style problems and is ready for submission. +WARNING: line over 80 characters +#21: FILE: drivers/mtd/spi/spi_flash_probe.c:66: ++ {"MX25L25635F", 0xc22019, 0x0, 64 * 1024, 512, 0}, + +total: 0 errors, 1 warnings, 0 checks, 7 lines checked + +NOTE: Ignored message types: COMPLEX_MACRO CONSIDER_KSTRTO MINMAX MULTISTATEMENT_MACRO_USE_DO_WHILE NETWORKING_BLOCK_COMMENT_STYLE USLEEP_RANGE + +0027-sf-probe-Add-support-for-MX25L25635F.patch has style problems, please review. + +If any of these errors are false positives, please report +them to the maintainer, see CHECKPATCH in MAINTAINERS. +WARNING: line over 80 characters +#21: FILE: drivers/mtd/spi/spi_flash_probe.c:67: ++ {"MX25L51235F", 0xc2201A, 0x0, 64 * 1024, 1024, 0}, + +total: 0 errors, 1 warnings, 0 checks, 7 lines checked + +NOTE: Ignored message types: COMPLEX_MACRO CONSIDER_KSTRTO MINMAX MULTISTATEMENT_MACRO_USE_DO_WHILE NETWORKING_BLOCK_COMMENT_STYLE USLEEP_RANGE + +0028-sf-probe-Add-support-for-MX25L51235F.patch has style problems, please review. + +If any of these errors are false positives, please report +them to the maintainer, see CHECKPATCH in MAINTAINERS. +total: 0 errors, 0 warnings, 0 checks, 44 lines checked + +NOTE: Ignored message types: COMPLEX_MACRO CONSIDER_KSTRTO MINMAX MULTISTATEMENT_MACRO_USE_DO_WHILE NETWORKING_BLOCK_COMMENT_STYLE USLEEP_RANGE + +0029-sf-Remove-spi_flash_do_alloc-references.patch has no obvious style problems and is ready for submission. +total: 0 errors, 0 warnings, 0 checks, 27 lines checked + +NOTE: Ignored message types: COMPLEX_MACRO CONSIDER_KSTRTO MINMAX MULTISTATEMENT_MACRO_USE_DO_WHILE NETWORKING_BLOCK_COMMENT_STYLE USLEEP_RANGE + +0030-doc-SPI-Add-status.txt-for-tracking-SPI-subsys-statu.patch has no obvious style problems and is ready for submission. +WARNING: line over 80 characters +#97: FILE: drivers/mtd/spi/spi_flash_probe.c:51: ++ {"AT45DB011D", 0x1f2200, 0x0, 64 * 1024, 4, 0, SECT_4K}, + +WARNING: line over 80 characters +#98: FILE: drivers/mtd/spi/spi_flash_probe.c:52: ++ {"AT45DB021D", 0x1f2300, 0x0, 64 * 1024, 8, 0, SECT_4K}, + +WARNING: line over 80 characters +#99: FILE: drivers/mtd/spi/spi_flash_probe.c:53: ++ {"AT45DB041D", 0x1f2400, 0x0, 64 * 1024, 8, 0, SECT_4K}, + +WARNING: line over 80 characters +#100: FILE: drivers/mtd/spi/spi_flash_probe.c:54: ++ {"AT45DB081D", 0x1f2500, 0x0, 64 * 1024, 16, 0, SECT_4K}, + +WARNING: line over 80 characters +#101: FILE: drivers/mtd/spi/spi_flash_probe.c:55: ++ {"AT45DB161D", 0x1f2600, 0x0, 64 * 1024, 32, 0, SECT_4K}, + +WARNING: line over 80 characters +#102: FILE: drivers/mtd/spi/spi_flash_probe.c:56: ++ {"AT45DB321D", 0x1f2700, 0x0, 64 * 1024, 64, 0, SECT_4K}, + +WARNING: line over 80 characters +#103: FILE: drivers/mtd/spi/spi_flash_probe.c:57: ++ {"AT45DB641D", 0x1f2800, 0x0, 64 * 1024, 128, 0, SECT_4K}, + +WARNING: line over 80 characters +#109: FILE: drivers/mtd/spi/spi_flash_probe.c:60: ++ {"EN25Q32B", 0x1c3016, 0x0, 64 * 1024, 64, 0, 0}, + +WARNING: line over 80 characters +#110: FILE: drivers/mtd/spi/spi_flash_probe.c:61: ++ {"EN25Q64", 0x1c3017, 0x0, 64 * 1024, 128, 0, SECT_4K}, + +WARNING: line over 80 characters +#111: FILE: drivers/mtd/spi/spi_flash_probe.c:62: ++ {"EN25Q128B", 0x1c3018, 0x0, 64 * 1024, 256, 0, 0}, + +WARNING: line over 80 characters +#116: FILE: drivers/mtd/spi/spi_flash_probe.c:65: ++ {"GD25Q64B", 0xc84017, 0x0, 64 * 1024, 128, 0, SECT_4K}, + +WARNING: line over 80 characters +#117: FILE: drivers/mtd/spi/spi_flash_probe.c:66: ++ {"GD25LQ32", 0xc86016, 0x0, 64 * 1024, 64, 0, SECT_4K}, + +WARNING: line over 80 characters +#129: FILE: drivers/mtd/spi/spi_flash_probe.c:69: ++ {"MX25L4005", 0xc22013, 0x0, 64 * 1024, 8, 0, 0}, + +WARNING: line over 80 characters +#130: FILE: drivers/mtd/spi/spi_flash_probe.c:70: ++ {"MX25L8005", 0xc22014, 0x0, 64 * 1024, 16, 0, 0}, + +WARNING: line over 80 characters +#131: FILE: drivers/mtd/spi/spi_flash_probe.c:71: ++ {"MX25L1605D", 0xc22015, 0x0, 64 * 1024, 32, 0, 0}, + +WARNING: line over 80 characters +#132: FILE: drivers/mtd/spi/spi_flash_probe.c:72: ++ {"MX25L3205D", 0xc22016, 0x0, 64 * 1024, 64, 0, 0}, + +WARNING: line over 80 characters +#133: FILE: drivers/mtd/spi/spi_flash_probe.c:73: ++ {"MX25L6405D", 0xc22017, 0x0, 64 * 1024, 128, 0, 0}, + +WARNING: line over 80 characters +#134: FILE: drivers/mtd/spi/spi_flash_probe.c:74: ++ {"MX25L12805", 0xc22018, 0x0, 64 * 1024, 256, 0, 0}, + +WARNING: line over 80 characters +#135: FILE: drivers/mtd/spi/spi_flash_probe.c:75: ++ {"MX25L12855E", 0xc22618, 0x0, 64 * 1024, 256, 0, 0}, + +WARNING: line over 80 characters +#151: FILE: drivers/mtd/spi/spi_flash_probe.c:78: ++ {"S25FL008A", 0x010213, 0x0, 64 * 1024, 16, 0, 0}, + +WARNING: line over 80 characters +#152: FILE: drivers/mtd/spi/spi_flash_probe.c:79: ++ {"S25FL016A", 0x010214, 0x0, 64 * 1024, 32, 0, 0}, + +WARNING: line over 80 characters +#153: FILE: drivers/mtd/spi/spi_flash_probe.c:80: ++ {"S25FL032A", 0x010215, 0x0, 64 * 1024, 64, 0, 0}, + +WARNING: line over 80 characters +#154: FILE: drivers/mtd/spi/spi_flash_probe.c:81: ++ {"S25FL064A", 0x010216, 0x0, 64 * 1024, 128, 0, 0}, + +WARNING: line over 80 characters +#155: FILE: drivers/mtd/spi/spi_flash_probe.c:82: ++ {"S25FL128P_256K", 0x012018, 0x0300, 256 * 1024, 64, RD_CMD_FULL, 0}, + +WARNING: line over 80 characters +#156: FILE: drivers/mtd/spi/spi_flash_probe.c:83: ++ {"S25FL128P_64K", 0x012018, 0x0301, 64 * 1024, 256, RD_CMD_FULL, 0}, + +WARNING: line over 80 characters +#157: FILE: drivers/mtd/spi/spi_flash_probe.c:84: ++ {"S25FL032P", 0x010215, 0x4d00, 64 * 1024, 64, RD_CMD_FULL, 0}, + +WARNING: line over 80 characters +#158: FILE: drivers/mtd/spi/spi_flash_probe.c:85: ++ {"S25FL064P", 0x010216, 0x4d00, 64 * 1024, 128, RD_CMD_FULL, 0}, + +WARNING: line over 80 characters +#159: FILE: drivers/mtd/spi/spi_flash_probe.c:86: ++ {"S25FL128S_64K", 0x012018, 0x4d01, 64 * 1024, 256, RD_CMD_FULL, 0}, + +WARNING: line over 80 characters +#160: FILE: drivers/mtd/spi/spi_flash_probe.c:87: ++ {"S25FL256S_64K", 0x010219, 0x4d01, 64 * 1024, 512, RD_CMD_FULL, 0}, + +WARNING: line over 80 characters +#161: FILE: drivers/mtd/spi/spi_flash_probe.c:88: ++ {"S25FL512S_64K", 0x010220, 0x4d01, 64 * 1024, 1024, RD_CMD_FULL, 0}, + +WARNING: line over 80 characters +#184: FILE: drivers/mtd/spi/spi_flash_probe.c:91: ++ {"M25P10", 0x202011, 0x0, 32 * 1024, 4, 0, 0}, + +WARNING: line over 80 characters +#185: FILE: drivers/mtd/spi/spi_flash_probe.c:92: ++ {"M25P20", 0x202012, 0x0, 64 * 1024, 4, 0, 0}, + +WARNING: line over 80 characters +#186: FILE: drivers/mtd/spi/spi_flash_probe.c:93: ++ {"M25P40", 0x202013, 0x0, 64 * 1024, 8, 0, 0}, + +WARNING: line over 80 characters +#187: FILE: drivers/mtd/spi/spi_flash_probe.c:94: ++ {"M25P80", 0x202014, 0x0, 64 * 1024, 16, 0, 0}, + +WARNING: line over 80 characters +#188: FILE: drivers/mtd/spi/spi_flash_probe.c:95: ++ {"M25P16", 0x202015, 0x0, 64 * 1024, 32, 0, 0}, + +WARNING: line over 80 characters +#189: FILE: drivers/mtd/spi/spi_flash_probe.c:96: ++ {"M25P32", 0x202016, 0x0, 64 * 1024, 64, 0, 0}, + +WARNING: line over 80 characters +#190: FILE: drivers/mtd/spi/spi_flash_probe.c:97: ++ {"M25P64", 0x202017, 0x0, 64 * 1024, 128, 0, 0}, + +WARNING: line over 80 characters +#191: FILE: drivers/mtd/spi/spi_flash_probe.c:98: ++ {"M25P128", 0x202018, 0x0, 256 * 1024, 64, 0, 0}, + +WARNING: line over 80 characters +#192: FILE: drivers/mtd/spi/spi_flash_probe.c:99: ++ {"N25Q32", 0x20ba16, 0x0, 64 * 1024, 64, RD_CMD_FULL, SECT_4K}, + +WARNING: line over 80 characters +#193: FILE: drivers/mtd/spi/spi_flash_probe.c:100: ++ {"N25Q32A", 0x20bb16, 0x0, 64 * 1024, 64, RD_CMD_FULL, SECT_4K}, + +WARNING: line over 80 characters +#194: FILE: drivers/mtd/spi/spi_flash_probe.c:101: ++ {"N25Q64", 0x20ba17, 0x0, 64 * 1024, 128, RD_CMD_FULL, SECT_4K}, + +WARNING: line over 80 characters +#195: FILE: drivers/mtd/spi/spi_flash_probe.c:102: ++ {"N25Q64A", 0x20bb17, 0x0, 64 * 1024, 128, RD_CMD_FULL, SECT_4K}, + +WARNING: line over 80 characters +#196: FILE: drivers/mtd/spi/spi_flash_probe.c:103: ++ {"N25Q128", 0x20ba18, 0x0, 64 * 1024, 256, RD_CMD_FULL, SECT_4K}, + +WARNING: line over 80 characters +#197: FILE: drivers/mtd/spi/spi_flash_probe.c:104: ++ {"N25Q128A", 0x20bb18, 0x0, 64 * 1024, 256, RD_CMD_FULL, SECT_4K}, + +WARNING: line over 80 characters +#198: FILE: drivers/mtd/spi/spi_flash_probe.c:105: ++ {"N25Q256", 0x20ba19, 0x0, 64 * 1024, 512, RD_CMD_FULL, SECT_4K}, + +WARNING: line over 80 characters +#199: FILE: drivers/mtd/spi/spi_flash_probe.c:106: ++ {"N25Q256A", 0x20bb19, 0x0, 64 * 1024, 512, RD_CMD_FULL, SECT_4K}, + +WARNING: line over 80 characters +#200: FILE: drivers/mtd/spi/spi_flash_probe.c:107: ++ {"N25Q512", 0x20ba20, 0x0, 64 * 1024, 1024, RD_CMD_FULL, E_FSR | SECT_4K}, + +WARNING: line over 80 characters +#201: FILE: drivers/mtd/spi/spi_flash_probe.c:108: ++ {"N25Q512A", 0x20bb20, 0x0, 64 * 1024, 1024, RD_CMD_FULL, E_FSR | SECT_4K}, + +WARNING: line over 80 characters +#202: FILE: drivers/mtd/spi/spi_flash_probe.c:109: ++ {"N25Q1024", 0x20ba21, 0x0, 64 * 1024, 2048, RD_CMD_FULL, E_FSR | SECT_4K}, + +WARNING: line over 80 characters +#203: FILE: drivers/mtd/spi/spi_flash_probe.c:110: ++ {"N25Q1024A", 0x20bb21, 0x0, 64 * 1024, 2048, RD_CMD_FULL, E_FSR | SECT_4K}, + +WARNING: line over 80 characters +#216: FILE: drivers/mtd/spi/spi_flash_probe.c:113: ++ {"SST25VF040B", 0xbf258d, 0x0, 64 * 1024, 8, 0, SECT_4K | SST_WP}, + +WARNING: line over 80 characters +#217: FILE: drivers/mtd/spi/spi_flash_probe.c:114: ++ {"SST25VF080B", 0xbf258e, 0x0, 64 * 1024, 16, 0, SECT_4K | SST_WP}, + +WARNING: line over 80 characters +#218: FILE: drivers/mtd/spi/spi_flash_probe.c:115: ++ {"SST25VF016B", 0xbf2541, 0x0, 64 * 1024, 32, 0, SECT_4K | SST_WP}, + +WARNING: line over 80 characters +#219: FILE: drivers/mtd/spi/spi_flash_probe.c:116: ++ {"SST25VF032B", 0xbf254a, 0x0, 64 * 1024, 64, 0, SECT_4K | SST_WP}, + +WARNING: line over 80 characters +#220: FILE: drivers/mtd/spi/spi_flash_probe.c:117: ++ {"SST25VF064C", 0xbf254b, 0x0, 64 * 1024, 128, 0 SECT_4K}, + +WARNING: line over 80 characters +#221: FILE: drivers/mtd/spi/spi_flash_probe.c:118: ++ {"SST25WF512", 0xbf2501, 0x0, 64 * 1024, 1, 0, SECT_4K | SST_WP}, + +WARNING: line over 80 characters +#222: FILE: drivers/mtd/spi/spi_flash_probe.c:119: ++ {"SST25WF010", 0xbf2502, 0x0, 64 * 1024, 2, 0, SECT_4K | SST_WP}, + +WARNING: line over 80 characters +#223: FILE: drivers/mtd/spi/spi_flash_probe.c:120: ++ {"SST25WF020", 0xbf2503, 0x0, 64 * 1024, 4, 0, SECT_4K | SST_WP}, + +WARNING: line over 80 characters +#224: FILE: drivers/mtd/spi/spi_flash_probe.c:121: ++ {"SST25WF040", 0xbf2504, 0x0, 64 * 1024, 8, 0, SECT_4K | SST_WP}, + +WARNING: line over 80 characters +#225: FILE: drivers/mtd/spi/spi_flash_probe.c:122: ++ {"SST25WF080", 0xbf2505, 0x0, 64 * 1024, 16, 0, SECT_4K | SST_WP}, + +WARNING: line over 80 characters +#246: FILE: drivers/mtd/spi/spi_flash_probe.c:125: ++ {"W25P80", 0xef2014, 0x0, 64 * 1024, 16, 0, 0}, + +WARNING: line over 80 characters +#247: FILE: drivers/mtd/spi/spi_flash_probe.c:126: ++ {"W25P16", 0xef2015, 0x0, 64 * 1024, 32, 0, 0}, + +WARNING: line over 80 characters +#248: FILE: drivers/mtd/spi/spi_flash_probe.c:127: ++ {"W25P32", 0xef2016, 0x0, 64 * 1024, 64, 0, 0}, + +WARNING: line over 80 characters +#249: FILE: drivers/mtd/spi/spi_flash_probe.c:128: ++ {"W25X40", 0xef3013, 0x0, 4 * 1024, 128, 0, SECT_4K}, + +WARNING: line over 80 characters +#250: FILE: drivers/mtd/spi/spi_flash_probe.c:129: ++ {"W25X16", 0xef3015, 0x0, 4 * 1024, 512, 0, SECT_4K}, + +WARNING: line over 80 characters +#251: FILE: drivers/mtd/spi/spi_flash_probe.c:130: ++ {"W25X32", 0xef3016, 0x0, 4 * 1024, 1024, 0, SECT_4K}, + +WARNING: line over 80 characters +#252: FILE: drivers/mtd/spi/spi_flash_probe.c:131: ++ {"W25X64", 0xef3017, 0x0, 4 * 1024, 2048, 0, SECT_4K}, + +WARNING: line over 80 characters +#253: FILE: drivers/mtd/spi/spi_flash_probe.c:132: ++ {"W25Q80BL", 0xef4014, 0x0, 4 * 1024, 256, RD_CMD_FULL, SECT_4K}, + +WARNING: line over 80 characters +#254: FILE: drivers/mtd/spi/spi_flash_probe.c:133: ++ {"W25Q16CL", 0xef4015, 0x0, 4 * 1024, 512, RD_CMD_FULL, SECT_4K}, + +WARNING: line over 80 characters +#255: FILE: drivers/mtd/spi/spi_flash_probe.c:134: ++ {"W25Q32BV", 0xef4016, 0x0, 4 * 1024, 1024, RD_CMD_FULL, SECT_4K}, + +WARNING: line over 80 characters +#256: FILE: drivers/mtd/spi/spi_flash_probe.c:135: ++ {"W25Q64CV", 0xef4017, 0x0, 4 * 1024, 2048, RD_CMD_FULL, SECT_4K}, + +WARNING: line over 80 characters +#257: FILE: drivers/mtd/spi/spi_flash_probe.c:136: ++ {"W25Q128BV", 0xef4018, 0x0, 4 * 1024, 4096, RD_CMD_FULL, SECT_4K}, + +WARNING: line over 80 characters +#258: FILE: drivers/mtd/spi/spi_flash_probe.c:137: ++ {"W25Q256", 0xef4019, 0x0, 4 * 1024, 8192, RD_CMD_FULL, SECT_4K}, + +WARNING: line over 80 characters +#259: FILE: drivers/mtd/spi/spi_flash_probe.c:138: ++ {"W25Q80BW", 0xef5014, 0x0, 4 * 1024, 256, RD_CMD_FULL, SECT_4K}, + +WARNING: line over 80 characters +#260: FILE: drivers/mtd/spi/spi_flash_probe.c:139: ++ {"W25Q16DW", 0xef6015, 0x0, 4 * 1024, 512, RD_CMD_FULL, SECT_4K}, + +WARNING: line over 80 characters +#261: FILE: drivers/mtd/spi/spi_flash_probe.c:140: ++ {"W25Q32DW", 0xef6016, 0x0, 4 * 1024, 1024, RD_CMD_FULL, SECT_4K}, + +WARNING: line over 80 characters +#262: FILE: drivers/mtd/spi/spi_flash_probe.c:141: ++ {"W25Q64DW", 0xef6017, 0x0, 4 * 1024, 2048, RD_CMD_FULL, SECT_4K}, + +WARNING: line over 80 characters +#263: FILE: drivers/mtd/spi/spi_flash_probe.c:142: ++ {"W25Q128FW", 0xef6018, 0x0, 4 * 1024, 4096, RD_CMD_FULL, SECT_4K}, + +total: 0 errors, 78 warnings, 0 checks, 313 lines checked + +NOTE: Ignored message types: COMPLEX_MACRO CONSIDER_KSTRTO MINMAX MULTISTATEMENT_MACRO_USE_DO_WHILE NETWORKING_BLOCK_COMMENT_STYLE USLEEP_RANGE + +0031-sf-Add-extended-read-commands-support.patch has style problems, please review. + +If any of these errors are false positives, please report +them to the maintainer, see CHECKPATCH in MAINTAINERS. +WARNING: line over 80 characters +#98: FILE: drivers/mtd/spi/spi_flash_probe.c:59: ++ {"AT45DB011D", 0x1f2200, 0x0, 64 * 1024, 4, 0, 0, SECT_4K}, + +WARNING: line over 80 characters +#99: FILE: drivers/mtd/spi/spi_flash_probe.c:60: ++ {"AT45DB021D", 0x1f2300, 0x0, 64 * 1024, 8, 0, 0, SECT_4K}, + +WARNING: line over 80 characters +#100: FILE: drivers/mtd/spi/spi_flash_probe.c:61: ++ {"AT45DB041D", 0x1f2400, 0x0, 64 * 1024, 8, 0, 0, SECT_4K}, + +WARNING: line over 80 characters +#101: FILE: drivers/mtd/spi/spi_flash_probe.c:62: ++ {"AT45DB081D", 0x1f2500, 0x0, 64 * 1024, 16, 0, 0, SECT_4K}, + +WARNING: line over 80 characters +#102: FILE: drivers/mtd/spi/spi_flash_probe.c:63: ++ {"AT45DB161D", 0x1f2600, 0x0, 64 * 1024, 32, 0, 0, SECT_4K}, + +WARNING: line over 80 characters +#103: FILE: drivers/mtd/spi/spi_flash_probe.c:64: ++ {"AT45DB321D", 0x1f2700, 0x0, 64 * 1024, 64, 0, 0, SECT_4K}, + +WARNING: line over 80 characters +#104: FILE: drivers/mtd/spi/spi_flash_probe.c:65: ++ {"AT45DB641D", 0x1f2800, 0x0, 64 * 1024, 128, 0, 0, SECT_4K}, + +WARNING: line over 80 characters +#110: FILE: drivers/mtd/spi/spi_flash_probe.c:68: ++ {"EN25Q32B", 0x1c3016, 0x0, 64 * 1024, 64, 0, 0, 0}, + +WARNING: line over 80 characters +#111: FILE: drivers/mtd/spi/spi_flash_probe.c:69: ++ {"EN25Q64", 0x1c3017, 0x0, 64 * 1024, 128, 0, 0, SECT_4K}, + +WARNING: line over 80 characters +#112: FILE: drivers/mtd/spi/spi_flash_probe.c:70: ++ {"EN25Q128B", 0x1c3018, 0x0, 64 * 1024, 256, 0, 0, 0}, + +WARNING: line over 80 characters +#117: FILE: drivers/mtd/spi/spi_flash_probe.c:73: ++ {"GD25Q64B", 0xc84017, 0x0, 64 * 1024, 128, 0, 0, SECT_4K}, + +WARNING: line over 80 characters +#118: FILE: drivers/mtd/spi/spi_flash_probe.c:74: ++ {"GD25LQ32", 0xc86016, 0x0, 64 * 1024, 64, 0, 0, SECT_4K}, + +WARNING: line over 80 characters +#128: FILE: drivers/mtd/spi/spi_flash_probe.c:77: ++ {"MX25L4005", 0xc22013, 0x0, 64 * 1024, 8, 0, 0, 0}, + +WARNING: line over 80 characters +#129: FILE: drivers/mtd/spi/spi_flash_probe.c:78: ++ {"MX25L8005", 0xc22014, 0x0, 64 * 1024, 16, 0, 0, 0}, + +WARNING: line over 80 characters +#130: FILE: drivers/mtd/spi/spi_flash_probe.c:79: ++ {"MX25L1605D", 0xc22015, 0x0, 64 * 1024, 32, 0, 0, 0}, + +WARNING: line over 80 characters +#131: FILE: drivers/mtd/spi/spi_flash_probe.c:80: ++ {"MX25L3205D", 0xc22016, 0x0, 64 * 1024, 64, 0, 0, 0}, + +WARNING: line over 80 characters +#132: FILE: drivers/mtd/spi/spi_flash_probe.c:81: ++ {"MX25L6405D", 0xc22017, 0x0, 64 * 1024, 128, 0, 0, 0}, + +WARNING: line over 80 characters +#133: FILE: drivers/mtd/spi/spi_flash_probe.c:82: ++ {"MX25L12805", 0xc22018, 0x0, 64 * 1024, 256, 0, 0, 0}, + +WARNING: line over 80 characters +#134: FILE: drivers/mtd/spi/spi_flash_probe.c:83: ++ {"MX25L12855E", 0xc22618, 0x0, 64 * 1024, 256, 0, 0, 0}, + +WARNING: line over 80 characters +#148: FILE: drivers/mtd/spi/spi_flash_probe.c:86: ++ {"S25FL008A", 0x010213, 0x0, 64 * 1024, 16, 0, 0, 0}, + +WARNING: line over 80 characters +#149: FILE: drivers/mtd/spi/spi_flash_probe.c:87: ++ {"S25FL016A", 0x010214, 0x0, 64 * 1024, 32, 0, 0, 0}, + +WARNING: line over 80 characters +#150: FILE: drivers/mtd/spi/spi_flash_probe.c:88: ++ {"S25FL032A", 0x010215, 0x0, 64 * 1024, 64, 0, 0, 0}, + +WARNING: line over 80 characters +#151: FILE: drivers/mtd/spi/spi_flash_probe.c:89: ++ {"S25FL064A", 0x010216, 0x0, 64 * 1024, 128, 0, 0, 0}, + +WARNING: line over 80 characters +#152: FILE: drivers/mtd/spi/spi_flash_probe.c:90: ++ {"S25FL128P_256K", 0x012018, 0x0300, 256 * 1024, 64, RD_CMD_FULL, WR_CMD_FULL, 0}, + +WARNING: line over 80 characters +#153: FILE: drivers/mtd/spi/spi_flash_probe.c:91: ++ {"S25FL128P_64K", 0x012018, 0x0301, 64 * 1024, 256, RD_CMD_FULL, WR_CMD_FULL, 0}, + +WARNING: line over 80 characters +#154: FILE: drivers/mtd/spi/spi_flash_probe.c:92: ++ {"S25FL032P", 0x010215, 0x4d00, 64 * 1024, 64, RD_CMD_FULL, WR_CMD_FULL, 0}, + +WARNING: line over 80 characters +#155: FILE: drivers/mtd/spi/spi_flash_probe.c:93: ++ {"S25FL064P", 0x010216, 0x4d00, 64 * 1024, 128, RD_CMD_FULL, WR_CMD_FULL, 0}, + +WARNING: line over 80 characters +#156: FILE: drivers/mtd/spi/spi_flash_probe.c:94: ++ {"S25FL128S_64K", 0x012018, 0x4d01, 64 * 1024, 256, RD_CMD_FULL, WR_CMD_FULL, 0}, + +WARNING: line over 80 characters +#157: FILE: drivers/mtd/spi/spi_flash_probe.c:95: ++ {"S25FL256S_64K", 0x010219, 0x4d01, 64 * 1024, 512, RD_CMD_FULL, WR_CMD_FULL, 0}, + +WARNING: line over 80 characters +#158: FILE: drivers/mtd/spi/spi_flash_probe.c:96: ++ {"S25FL512S_64K", 0x010220, 0x4d01, 64 * 1024, 1024, RD_CMD_FULL, WR_CMD_FULL, 0}, + +WARNING: line over 80 characters +#181: FILE: drivers/mtd/spi/spi_flash_probe.c:99: ++ {"M25P10", 0x202011, 0x0, 32 * 1024, 4, 0, 0, 0}, + +WARNING: line over 80 characters +#182: FILE: drivers/mtd/spi/spi_flash_probe.c:100: ++ {"M25P20", 0x202012, 0x0, 64 * 1024, 4, 0, 0, 0}, + +WARNING: line over 80 characters +#183: FILE: drivers/mtd/spi/spi_flash_probe.c:101: ++ {"M25P40", 0x202013, 0x0, 64 * 1024, 8, 0, 0, 0}, + +WARNING: line over 80 characters +#184: FILE: drivers/mtd/spi/spi_flash_probe.c:102: ++ {"M25P80", 0x202014, 0x0, 64 * 1024, 16, 0, 0, 0}, + +WARNING: line over 80 characters +#185: FILE: drivers/mtd/spi/spi_flash_probe.c:103: ++ {"M25P16", 0x202015, 0x0, 64 * 1024, 32, 0, 0, 0}, + +WARNING: line over 80 characters +#186: FILE: drivers/mtd/spi/spi_flash_probe.c:104: ++ {"M25P32", 0x202016, 0x0, 64 * 1024, 64, 0, 0, 0}, + +WARNING: line over 80 characters +#187: FILE: drivers/mtd/spi/spi_flash_probe.c:105: ++ {"M25P64", 0x202017, 0x0, 64 * 1024, 128, 0, 0, 0}, + +WARNING: line over 80 characters +#188: FILE: drivers/mtd/spi/spi_flash_probe.c:106: ++ {"M25P128", 0x202018, 0x0, 256 * 1024, 64, 0, 0, 0}, + +WARNING: line over 80 characters +#189: FILE: drivers/mtd/spi/spi_flash_probe.c:107: ++ {"N25Q32", 0x20ba16, 0x0, 64 * 1024, 64, RD_CMD_FULL, WR_CMD_FULL, SECT_4K}, + +WARNING: line over 80 characters +#190: FILE: drivers/mtd/spi/spi_flash_probe.c:108: ++ {"N25Q32A", 0x20bb16, 0x0, 64 * 1024, 64, RD_CMD_FULL, WR_CMD_FULL, SECT_4K}, + +WARNING: line over 80 characters +#191: FILE: drivers/mtd/spi/spi_flash_probe.c:109: ++ {"N25Q64", 0x20ba17, 0x0, 64 * 1024, 128, RD_CMD_FULL, WR_CMD_FULL, SECT_4K}, + +WARNING: line over 80 characters +#192: FILE: drivers/mtd/spi/spi_flash_probe.c:110: ++ {"N25Q64A", 0x20bb17, 0x0, 64 * 1024, 128, RD_CMD_FULL, WR_CMD_FULL, SECT_4K}, + +WARNING: line over 80 characters +#193: FILE: drivers/mtd/spi/spi_flash_probe.c:111: ++ {"N25Q128", 0x20ba18, 0x0, 64 * 1024, 256, RD_CMD_FULL, WR_CMD_FULL, SECT_4K}, + +WARNING: line over 80 characters +#194: FILE: drivers/mtd/spi/spi_flash_probe.c:112: ++ {"N25Q128A", 0x20bb18, 0x0, 64 * 1024, 256, RD_CMD_FULL, WR_CMD_FULL, SECT_4K}, + +WARNING: line over 80 characters +#195: FILE: drivers/mtd/spi/spi_flash_probe.c:113: ++ {"N25Q256", 0x20ba19, 0x0, 64 * 1024, 512, RD_CMD_FULL, WR_CMD_FULL, SECT_4K}, + +WARNING: line over 80 characters +#196: FILE: drivers/mtd/spi/spi_flash_probe.c:114: ++ {"N25Q256A", 0x20bb19, 0x0, 64 * 1024, 512, RD_CMD_FULL, WR_CMD_FULL, SECT_4K}, + +WARNING: line over 80 characters +#197: FILE: drivers/mtd/spi/spi_flash_probe.c:115: ++ {"N25Q512", 0x20ba20, 0x0, 64 * 1024, 1024, RD_CMD_FULL, WR_CMD_FULL, E_FSR | SECT_4K}, + +WARNING: line over 80 characters +#198: FILE: drivers/mtd/spi/spi_flash_probe.c:116: ++ {"N25Q512A", 0x20bb20, 0x0, 64 * 1024, 1024, RD_CMD_FULL, WR_CMD_FULL, E_FSR | SECT_4K}, + +WARNING: line over 80 characters +#199: FILE: drivers/mtd/spi/spi_flash_probe.c:117: ++ {"N25Q1024", 0x20ba21, 0x0, 64 * 1024, 2048, RD_CMD_FULL, WR_CMD_FULL, E_FSR | SECT_4K}, + +WARNING: line over 80 characters +#200: FILE: drivers/mtd/spi/spi_flash_probe.c:118: ++ {"N25Q1024A", 0x20bb21, 0x0, 64 * 1024, 2048, RD_CMD_FULL, WR_CMD_FULL, E_FSR | SECT_4K}, + +WARNING: line over 80 characters +#213: FILE: drivers/mtd/spi/spi_flash_probe.c:121: ++ {"SST25VF040B", 0xbf258d, 0x0, 64 * 1024, 8, 0, 0, SECT_4K | SST_WP}, + +WARNING: line over 80 characters +#214: FILE: drivers/mtd/spi/spi_flash_probe.c:122: ++ {"SST25VF080B", 0xbf258e, 0x0, 64 * 1024, 16, 0, 0, SECT_4K | SST_WP}, + +WARNING: line over 80 characters +#215: FILE: drivers/mtd/spi/spi_flash_probe.c:123: ++ {"SST25VF016B", 0xbf2541, 0x0, 64 * 1024, 32, 0, 0, SECT_4K | SST_WP}, + +WARNING: line over 80 characters +#216: FILE: drivers/mtd/spi/spi_flash_probe.c:124: ++ {"SST25VF032B", 0xbf254a, 0x0, 64 * 1024, 64, 0, 0, SECT_4K | SST_WP}, + +WARNING: line over 80 characters +#217: FILE: drivers/mtd/spi/spi_flash_probe.c:125: ++ {"SST25VF064C", 0xbf254b, 0x0, 64 * 1024, 128, 0, 0, SECT_4K}, + +WARNING: line over 80 characters +#218: FILE: drivers/mtd/spi/spi_flash_probe.c:126: ++ {"SST25WF512", 0xbf2501, 0x0, 64 * 1024, 1, 0, 0, SECT_4K | SST_WP}, + +WARNING: line over 80 characters +#219: FILE: drivers/mtd/spi/spi_flash_probe.c:127: ++ {"SST25WF010", 0xbf2502, 0x0, 64 * 1024, 2, 0, 0, SECT_4K | SST_WP}, + +WARNING: line over 80 characters +#220: FILE: drivers/mtd/spi/spi_flash_probe.c:128: ++ {"SST25WF020", 0xbf2503, 0x0, 64 * 1024, 4, 0, 0, SECT_4K | SST_WP}, + +WARNING: line over 80 characters +#221: FILE: drivers/mtd/spi/spi_flash_probe.c:129: ++ {"SST25WF040", 0xbf2504, 0x0, 64 * 1024, 8, 0, 0, SECT_4K | SST_WP}, + +WARNING: line over 80 characters +#222: FILE: drivers/mtd/spi/spi_flash_probe.c:130: ++ {"SST25WF080", 0xbf2505, 0x0, 64 * 1024, 16, 0, 0, SECT_4K | SST_WP}, + +WARNING: line over 80 characters +#243: FILE: drivers/mtd/spi/spi_flash_probe.c:133: ++ {"W25P80", 0xef2014, 0x0, 64 * 1024, 16, 0, 0, 0}, + +WARNING: line over 80 characters +#244: FILE: drivers/mtd/spi/spi_flash_probe.c:134: ++ {"W25P16", 0xef2015, 0x0, 64 * 1024, 32, 0, 0, 0}, + +WARNING: line over 80 characters +#245: FILE: drivers/mtd/spi/spi_flash_probe.c:135: ++ {"W25P32", 0xef2016, 0x0, 64 * 1024, 64, 0, 0, 0}, + +WARNING: line over 80 characters +#246: FILE: drivers/mtd/spi/spi_flash_probe.c:136: ++ {"W25X40", 0xef3013, 0x0, 4 * 1024, 128, 0, 0, SECT_4K}, + +WARNING: line over 80 characters +#247: FILE: drivers/mtd/spi/spi_flash_probe.c:137: ++ {"W25X16", 0xef3015, 0x0, 4 * 1024, 512, 0, 0, SECT_4K}, + +WARNING: line over 80 characters +#248: FILE: drivers/mtd/spi/spi_flash_probe.c:138: ++ {"W25X32", 0xef3016, 0x0, 4 * 1024, 1024, 0, 0, SECT_4K}, + +WARNING: line over 80 characters +#249: FILE: drivers/mtd/spi/spi_flash_probe.c:139: ++ {"W25X64", 0xef3017, 0x0, 4 * 1024, 2048, 0, 0, SECT_4K}, + +WARNING: line over 80 characters +#250: FILE: drivers/mtd/spi/spi_flash_probe.c:140: ++ {"W25Q80BL", 0xef4014, 0x0, 4 * 1024, 256, RD_CMD_FULL, WR_CMD_FULL, SECT_4K}, + +WARNING: line over 80 characters +#251: FILE: drivers/mtd/spi/spi_flash_probe.c:141: ++ {"W25Q16CL", 0xef4015, 0x0, 4 * 1024, 512, RD_CMD_FULL, WR_CMD_FULL, SECT_4K}, + +WARNING: line over 80 characters +#252: FILE: drivers/mtd/spi/spi_flash_probe.c:142: ++ {"W25Q32BV", 0xef4016, 0x0, 4 * 1024, 1024, RD_CMD_FULL, WR_CMD_FULL, SECT_4K}, + +WARNING: line over 80 characters +#253: FILE: drivers/mtd/spi/spi_flash_probe.c:143: ++ {"W25Q64CV", 0xef4017, 0x0, 4 * 1024, 2048, RD_CMD_FULL, WR_CMD_FULL, SECT_4K}, + +WARNING: line over 80 characters +#254: FILE: drivers/mtd/spi/spi_flash_probe.c:144: ++ {"W25Q128BV", 0xef4018, 0x0, 4 * 1024, 4096, RD_CMD_FULL, WR_CMD_FULL, SECT_4K}, + +WARNING: line over 80 characters +#255: FILE: drivers/mtd/spi/spi_flash_probe.c:145: ++ {"W25Q256", 0xef4019, 0x0, 4 * 1024, 8192, RD_CMD_FULL, WR_CMD_FULL, SECT_4K}, + +WARNING: line over 80 characters +#256: FILE: drivers/mtd/spi/spi_flash_probe.c:146: ++ {"W25Q80BW", 0xef5014, 0x0, 4 * 1024, 256, RD_CMD_FULL, WR_CMD_FULL, SECT_4K}, + +WARNING: line over 80 characters +#257: FILE: drivers/mtd/spi/spi_flash_probe.c:147: ++ {"W25Q16DW", 0xef6015, 0x0, 4 * 1024, 512, RD_CMD_FULL, WR_CMD_FULL, SECT_4K}, + +WARNING: line over 80 characters +#258: FILE: drivers/mtd/spi/spi_flash_probe.c:148: ++ {"W25Q32DW", 0xef6016, 0x0, 4 * 1024, 1024, RD_CMD_FULL, WR_CMD_FULL, SECT_4K}, + +WARNING: line over 80 characters +#259: FILE: drivers/mtd/spi/spi_flash_probe.c:149: ++ {"W25Q64DW", 0xef6017, 0x0, 4 * 1024, 2048, RD_CMD_FULL, WR_CMD_FULL, SECT_4K}, + +WARNING: line over 80 characters +#260: FILE: drivers/mtd/spi/spi_flash_probe.c:150: ++ {"W25Q128FW", 0xef6018, 0x0, 4 * 1024, 4096, RD_CMD_FULL, WR_CMD_FULL, SECT_4K}, + +total: 0 errors, 78 warnings, 0 checks, 311 lines checked + +NOTE: Ignored message types: COMPLEX_MACRO CONSIDER_KSTRTO MINMAX MULTISTATEMENT_MACRO_USE_DO_WHILE NETWORKING_BLOCK_COMMENT_STYLE USLEEP_RANGE + +0032-sf-Add-quad-read-write-commands-support.patch has style problems, please review. + +If any of these errors are false positives, please report +them to the maintainer, see CHECKPATCH in MAINTAINERS. +total: 0 errors, 0 warnings, 0 checks, 30 lines checked + +NOTE: Ignored message types: COMPLEX_MACRO CONSIDER_KSTRTO MINMAX MULTISTATEMENT_MACRO_USE_DO_WHILE NETWORKING_BLOCK_COMMENT_STYLE USLEEP_RANGE + +0033-sf-ops-Add-configuration-register-writing-support.patch has no obvious style problems and is ready for submission. +total: 0 errors, 0 warnings, 0 checks, 68 lines checked + +NOTE: Ignored message types: COMPLEX_MACRO CONSIDER_KSTRTO MINMAX MULTISTATEMENT_MACRO_USE_DO_WHILE NETWORKING_BLOCK_COMMENT_STYLE USLEEP_RANGE + +0034-sf-Set-quad-enable-bit-support.patch has no obvious style problems and is ready for submission. +total: 0 errors, 0 warnings, 0 checks, 332 lines checked + +NOTE: Ignored message types: COMPLEX_MACRO CONSIDER_KSTRTO MINMAX MULTISTATEMENT_MACRO_USE_DO_WHILE NETWORKING_BLOCK_COMMENT_STYLE USLEEP_RANGE + +0035-sf-spi_flash-cleanups.patch has no obvious style problems and is ready for submission. +total: 0 errors, 0 warnings, 0 checks, 212 lines checked + +NOTE: Ignored message types: COMPLEX_MACRO CONSIDER_KSTRTO MINMAX MULTISTATEMENT_MACRO_USE_DO_WHILE NETWORKING_BLOCK_COMMENT_STYLE USLEEP_RANGE + +0036-spi-spi-cleanups.patch has no obvious style problems and is ready for submission.
Hi Jagan,
On Tue, Sep 24, 2013 at 12:19 PM, Jagannadha Sutradharudu Teki jagannadha.sutradharudu-teki@xilinx.com wrote:
For some reason this patch (only) is missing the version number in the subject, and also has a 'dump' file. Is this a bug in patman maybe?
