[PATCH] configs: defconfig: Boot to OS via FIT Image for N5X
Update to boot OS via FIT image from N5X and enable FIT signature check via crc32 algorithm.
And, remove CONFIGs for emulation only.
Signed-off-by: Siew Chin Lim elly.siew.chin.lim@intel.com Signed-off-by: Jit Loon Lim jit.loon.lim@intel.com --- configs/socfpga_n5x_atf_defconfig | 4 +++- configs/socfpga_n5x_vab_defconfig | 3 +++ 2 files changed, 6 insertions(+), 1 deletion(-)
diff --git a/configs/socfpga_n5x_atf_defconfig b/configs/socfpga_n5x_atf_defconfig index d2598b9fb3..577c13e297 100644 --- a/configs/socfpga_n5x_atf_defconfig +++ b/configs/socfpga_n5x_atf_defconfig @@ -18,6 +18,8 @@ CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x300000 CONFIG_REMAKE_ELF=y CONFIG_FIT=y CONFIG_SPL_FIT_SIGNATURE=y +CONFIG_FIT_SIGNATURE_MAX_SIZE=0x10000000 +CONFIG_SPL_FIT_SIGNATURE=y CONFIG_SPL_LOAD_FIT=y CONFIG_SPL_LOAD_FIT_ADDRESS=0x02000000 # CONFIG_USE_SPL_FIT_GENERATOR is not set @@ -25,7 +27,7 @@ CONFIG_BOOTDELAY=5 CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="earlycon panic=-1 earlyprintk=ttyS0,115200" CONFIG_USE_BOOTCOMMAND=y -CONFIG_BOOTCOMMAND="run fatscript; run mmcfitload; run mmcfitboot" +CONFIG_BOOTCOMMAND="run fatscript;run mmcload;run linux_qspi_enable;run rsu_status;run mmcboot;run mmcfitboot" CONFIG_SPL_MAX_SIZE=0x40000 CONFIG_SPL_HAS_BSS_LINKER_SECTION=y CONFIG_SPL_BSS_START_ADDR=0x3ff00000 diff --git a/configs/socfpga_n5x_vab_defconfig b/configs/socfpga_n5x_vab_defconfig index 977a90d493..a98c87147f 100644 --- a/configs/socfpga_n5x_vab_defconfig +++ b/configs/socfpga_n5x_vab_defconfig @@ -19,6 +19,9 @@ CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x300000 CONFIG_REMAKE_ELF=y CONFIG_FIT=y CONFIG_SPL_FIT_SIGNATURE=y +CONFIG_FIT_SIGNATURE=y +CONFIG_FIT_SIGNATURE_MAX_SIZE=0x10000000 +CONFIG_SPL_FIT_SIGNATURE=y CONFIG_SPL_LOAD_FIT=y CONFIG_SPL_LOAD_FIT_ADDRESS=0x02000000 # CONFIG_USE_SPL_FIT_GENERATOR is not set
Jit Loon Lim
