Re: [U-Boot-Users] Start with u-boot on at91rm9200 on AT91RM9200-EK
Hello, for the first step of reproducing a runnig u-boot i use the original Atmel Board. Here the u-boot does nothing after load with loader.bin. The Atmel delivered u-boot.bin does normal work. U-boot is build with the desribed steps without any Error Messages.
make at91rm9200dk_config make all
Then X-Modem the loader.bin and then X-Modem the u-boot.bin to the AT91RM9200-EK and after this nothing happens.
Are there further Things to configure, i didn't read ?
THX Thomas
-----Ursprüngliche Nachricht----- Von: wd@denx.de [mailto:wd@denx.de] Gesendet: Mittwoch, 19. Juli 2006 08:52 An: Erdmann, Thomas Cc: u-boot-users@lists.sourceforge.net Betreff: Re: AW: [U-Boot-Users] Start with u-boot on at91rm9200 on AT91RM9200-EK
In message <F6726C3E89A64840A5E10310E342A38F01BE93C9@xchback01.back.harti ng.intra> you wrote:
I don't use a new Hardware for now, i use the original Atmel AT91RM9200-EK Evaluation Board, which should be supported
by Standard
because of a new Flash Chip i must compile u-boot and in than
So what? Is this the original hardware, or a modified one?
And please keep the list on Cc:
-- Software Engineering: Embedded and Realtime Systems, Embedded Linux Phone: (+49)-8142-66989-10 Fax: (+49)-8142-66989-80 Email: wd@denx.de Knowledge, sir, should be free to all! -- Harry Mudd, "I, Mudd", stardate 4513.3
In message F6726C3E89A64840A5E10310E342A38F01BE93CA@xchback01.back.harting.intra you wrote:
What makes you think the default configuration of U-Boot would need any loader.bin stuff? Instead, it will boot directly.
Erdmann, Thomas
