[U-Boot] [PATCH v2] ARM64: zynqmp: Add support for standard distro boot commands
Nand and QSPI are not defined now but this will be extended. Based on selected bootmode boot_targets are rewritten. Patch also contains detection if variables are saved. If yes don't rewrite boot_targets variable.
Also move variable setup to the end of file because SCSI needs to be defined before others macros are using it.
Changes in v2: - Append default boot_targets to the list
Patch depends on "env: Setup GD_FLG_ENV_DEFAULT flag when default environment are used"
--- board/xilinx/zynqmp/zynqmp.c | 27 ++++++++++++++----- include/configs/xilinx_zynqmp.h | 59 ++++++++++++++++++++++++++++++----------- 2 files changed, 64 insertions(+), 22 deletions(-)
diff --git a/board/xilinx/zynqmp/zynqmp.c b/board/xilinx/zynqmp/zynqmp.c index 4623cd49e9c7..204f8c526ab4 100644 --- a/board/xilinx/zynqmp/zynqmp.c +++ b/board/xilinx/zynqmp/zynqmp.c @@ -215,6 +215,11 @@ int board_late_init(void) u32 reg = 0; u8 bootmode;
+ if (!(gd->flags & GD_FLG_ENV_DEFAULT)) { + debug("Saved variables - Skipping\n"); + return 0; + } + reg = readl(&crlapb_base->boot_mode); bootmode = reg & BOOT_MODES_MASK;
@@ -222,31 +227,39 @@ int board_late_init(void) switch (bootmode) { case JTAG_MODE: puts("JTAG_MODE\n"); - setenv("modeboot", "jtagboot"); + setenv("boot_targets", strcat("pxe dhcp ", + getenv("boot_targets"))); break; case QSPI_MODE_24BIT: case QSPI_MODE_32BIT: - setenv("modeboot", "qspiboot"); + setenv("boot_targets", strcat("qspi0 ", + getenv("boot_targets"))); puts("QSPI_MODE\n"); break; case EMMC_MODE: puts("EMMC_MODE\n"); - setenv("modeboot", "sdboot"); + setenv("boot_targets", strcat("mmc0 ", + getenv("boot_targets"))); break; case SD_MODE: puts("SD_MODE\n"); - setenv("modeboot", "sdboot"); + setenv("boot_targets", strcat("mmc0 ", + getenv("boot_targets"))); break; case SD_MODE1: puts("SD_MODE1\n"); #if defined(CONFIG_ZYNQ_SDHCI0) && defined(CONFIG_ZYNQ_SDHCI1) - setenv("sdbootdev", "1"); + setenv("boot_targets", strcat("mmc1 ", + getenv("boot_targets"))); +#else + setenv("boot_targets", strcat("mmc0 ", + getenv("boot_targets"))); #endif - setenv("modeboot", "sdboot"); break; case NAND_MODE: puts("NAND_MODE\n"); - setenv("modeboot", "nandboot"); + setenv("boot_targets", strcat("nand0 ", + getenv("boot_targets"))); break; default: printf("Invalid Boot Mode:0x%x\n", bootmode); diff --git a/include/configs/xilinx_zynqmp.h b/include/configs/xilinx_zynqmp.h index 795d58646e15..3fba87ac194e 100644 --- a/include/configs/xilinx_zynqmp.h +++ b/include/configs/xilinx_zynqmp.h @@ -147,21 +147,6 @@ # define DFU_ALT_INFO #endif
-/* Initial environment variables */ -#ifndef CONFIG_EXTRA_ENV_SETTINGS -#define CONFIG_EXTRA_ENV_SETTINGS \ - "kernel_addr=0x80000\0" \ - "fdt_addr=0x7000000\0" \ - "fdt_high=0x10000000\0" \ - CONFIG_KERNEL_FDT_OFST_SIZE \ - "sdbootdev=0\0"\ - "sdboot=mmc dev $sdbootdev && mmcinfo && load mmc $sdbootdev:$partid $fdt_addr system.dtb && " \ - "load mmc $sdbootdev:$partid $kernel_addr Image && " \ - "booti $kernel_addr - $fdt_addr\0" \ - DFU_ALT_INFO -#endif - -#define CONFIG_BOOTCOMMAND "run $modeboot" #define CONFIG_BOOTDELAY 3
#define CONFIG_BOARD_LATE_INIT @@ -231,6 +216,50 @@ #define CONFIG_BOARD_EARLY_INIT_R #define CONFIG_CLOCKS
+#define ENV_MEM_LAYOUT_SETTINGS \ + "fdt_high=10000000\0" \ + "initrd_high=10000000\0" \ + "fdt_addr_r=0x40000000\0" \ + "pxefile_addr_r=0x10000000\0" \ + "kernel_addr_r=0x18000000\0" \ + "scriptaddr=0x02000000\0" \ + "ramdisk_addr_r=0x02100000\0" \ + +#if defined(CONFIG_ZYNQ_SDHCI) +# define BOOT_TARGET_DEVICES_MMC(func) func(MMC, mmc, 0) func(MMC, mmc, 1) +#else +# define BOOT_TARGET_DEVICES_MMC(func) +#endif + +#if defined(CONFIG_SATA_CEVA) +# define BOOT_TARGET_DEVICES_SCSI(func) func(SCSI, scsi, 0) +#else +# define BOOT_TARGET_DEVICES_SCSI(func) +#endif + +#if defined(CONFIG_ZYNQMP_USB) +# define BOOT_TARGET_DEVICES_USB(func) func(USB, usb, 0) func(USB, usb, 1) +#else +# define BOOT_TARGET_DEVICES_USB(func) +#endif + +#define BOOT_TARGET_DEVICES(func) \ + BOOT_TARGET_DEVICES_MMC(func) \ + BOOT_TARGET_DEVICES_USB(func) \ + BOOT_TARGET_DEVICES_SCSI(func) \ + func(PXE, pxe, na) \ + func(DHCP, dhcp, na) + +#include <config_distro_bootcmd.h> + +/* Initial environment variables */ +#ifndef CONFIG_EXTRA_ENV_SETTINGS +#define CONFIG_EXTRA_ENV_SETTINGS \ + ENV_MEM_LAYOUT_SETTINGS \ + BOOTENV \ + DFU_ALT_INFO +#endif + #define CONFIG_SPL_TEXT_BASE 0xfffc0000 #define CONFIG_SPL_MAX_SIZE 0x20000
Changes in v2:
- if (!(gd->flags & GD_FLG_ENV_DEFAULT)) {
- reg = readl(&crlapb_base->boot_mode); bootmode = reg & BOOT_MODES_MASK;
The strcat() function appends the src string to the dest string, overwriting the terminating null byte ('\0') at the end of dest, and then adds a terminating null byte. The strings may not overlap, and the dest string must have enough space for the result. If dest is not large enough, program behavior is unpredictable; buffer overruns are a favorite avenue for attacking secure programs.
In other words, the code above creates a buffer overflow :). You need something like
const char *new_targets = "pxe dhcp"; // <- make this a parameter to a function
new_targets = malloc(strlen(new_targets) + strlen(getenv("boot_targets") + 2); // one byte for the space, one for the null-terminator sprintf(new_targets, "%s %s", new_targets, boot_targets); setenv("boot_targets", new_targets);
Isn't string handling in C awesome? It's almost as readable and easy as doing it in assembly.
Alex
Changes in v2:
Time for holiday.
Thanks, Michal
Alexander Graf
Michal Simek
