[U-Boot] [PATCH v2 0/5] at91: 9x5: Enable PMECC(Programmable Multibit ECC controller) support
This patch series will add PMECC support for atmel at91sam9x5ek in u-boot.
The NAND flash driver patch is ported from kernel patch. The main different from kernel patch is the modification about registers access part. in this version it via a register structure to access.
It is tested in atmel AT919G25EK board.
Changes since v1: Add two patches that enable PMECC in 9x5 board. Nand flash driver: Change 'ecc' array's type from u32 to u8 in structure pmecc_regs (u32 ecc[11] -> u8 ecc[44]). That will make PMECC write correctly. enable 4k-page nand flash pmecc support. fix coding style errors and warnings.
Josh Wu (5): at91: atmel_nand: extract HWECC initialization code into one function: atmel_hw_nand_init_param(). at91: atmel_nand: remove unused variables. at91: atmel_nand: Update driver to support Programmable Multibit ECC controller at91: 9x5: change SMC config timing that both works for PMECC & non-PMECC. at91: 9x5: Enable PMECC for 5series ek board.
board/atmel/at91sam9x5ek/at91sam9x5ek.c | 12 +- drivers/mtd/nand/atmel_nand.c | 763 ++++++++++++++++++++++++++++--- drivers/mtd/nand/atmel_nand_ecc.h | 111 +++++ include/configs/at91sam9x5ek.h | 7 + 4 files changed, 833 insertions(+), 60 deletions(-)
Extract the hwecc initialization code into one function. It is a preparation for adding atmel PMECC support.
Signed-off-by: Josh Wu josh.wu@atmel.com --- drivers/mtd/nand/atmel_nand.c | 108 ++++++++++++++++++++++------------------- 1 file changed, 57 insertions(+), 51 deletions(-)
diff --git a/drivers/mtd/nand/atmel_nand.c b/drivers/mtd/nand/atmel_nand.c index de66382..113da93 100644 --- a/drivers/mtd/nand/atmel_nand.c +++ b/drivers/mtd/nand/atmel_nand.c @@ -232,68 +232,19 @@ static int atmel_nand_correct(struct mtd_info *mtd, u_char *dat, static void atmel_nand_hwctl(struct mtd_info *mtd, int mode) { } -#endif - -static void at91_nand_hwcontrol(struct mtd_info *mtd, - int cmd, unsigned int ctrl) -{ - struct nand_chip *this = mtd->priv; - - if (ctrl & NAND_CTRL_CHANGE) { - ulong IO_ADDR_W = (ulong) this->IO_ADDR_W; - IO_ADDR_W &= ~(CONFIG_SYS_NAND_MASK_ALE - | CONFIG_SYS_NAND_MASK_CLE); - - if (ctrl & NAND_CLE) - IO_ADDR_W |= CONFIG_SYS_NAND_MASK_CLE; - if (ctrl & NAND_ALE) - IO_ADDR_W |= CONFIG_SYS_NAND_MASK_ALE; - -#ifdef CONFIG_SYS_NAND_ENABLE_PIN - at91_set_gpio_value(CONFIG_SYS_NAND_ENABLE_PIN, - !(ctrl & NAND_NCE)); -#endif - this->IO_ADDR_W = (void *) IO_ADDR_W; - } - - if (cmd != NAND_CMD_NONE) - writeb(cmd, this->IO_ADDR_W); -}
-#ifdef CONFIG_SYS_NAND_READY_PIN -static int at91_nand_ready(struct mtd_info *mtd) +int atmel_hw_nand_init_param(struct nand_chip *nand) { - return at91_get_gpio_value(CONFIG_SYS_NAND_READY_PIN); -} -#endif - -int board_nand_init(struct nand_chip *nand) -{ -#ifdef CONFIG_ATMEL_NAND_HWECC static int chip_nr = 0; struct mtd_info *mtd; -#endif - - nand->ecc.mode = NAND_ECC_SOFT; -#ifdef CONFIG_SYS_NAND_DBW_16 - nand->options = NAND_BUSWIDTH_16; -#endif - nand->cmd_ctrl = at91_nand_hwcontrol; -#ifdef CONFIG_SYS_NAND_READY_PIN - nand->dev_ready = at91_nand_ready; -#endif - nand->chip_delay = 20;
-#ifdef CONFIG_ATMEL_NAND_HWECC nand->ecc.mode = NAND_ECC_HW; nand->ecc.calculate = atmel_nand_calculate; nand->ecc.correct = atmel_nand_correct; nand->ecc.hwctl = atmel_nand_hwctl; nand->ecc.read_page = atmel_nand_read_page; nand->ecc.bytes = 4; -#endif
-#ifdef CONFIG_ATMEL_NAND_HWECC mtd = &nand_info[chip_nr++]; mtd->priv = nand;
@@ -339,7 +290,62 @@ int board_nand_init(struct nand_chip *nand) break; } } -#endif
return 0; } + +#endif + +static void at91_nand_hwcontrol(struct mtd_info *mtd, + int cmd, unsigned int ctrl) +{ + struct nand_chip *this = mtd->priv; + + if (ctrl & NAND_CTRL_CHANGE) { + ulong IO_ADDR_W = (ulong) this->IO_ADDR_W; + IO_ADDR_W &= ~(CONFIG_SYS_NAND_MASK_ALE + | CONFIG_SYS_NAND_MASK_CLE); + + if (ctrl & NAND_CLE) + IO_ADDR_W |= CONFIG_SYS_NAND_MASK_CLE; + if (ctrl & NAND_ALE) + IO_ADDR_W |= CONFIG_SYS_NAND_MASK_ALE; + +#ifdef CONFIG_SYS_NAND_ENABLE_PIN + at91_set_gpio_value(CONFIG_SYS_NAND_ENABLE_PIN, + !(ctrl & NAND_NCE)); +#endif + this->IO_ADDR_W = (void *) IO_ADDR_W; + } + + if (cmd != NAND_CMD_NONE) + writeb(cmd, this->IO_ADDR_W); +} + +#ifdef CONFIG_SYS_NAND_READY_PIN +static int at91_nand_ready(struct mtd_info *mtd) +{ + return at91_get_gpio_value(CONFIG_SYS_NAND_READY_PIN); +} +#endif + +int board_nand_init(struct nand_chip *nand) +{ + int res = 0; + + nand->ecc.mode = NAND_ECC_SOFT; +#ifdef CONFIG_SYS_NAND_DBW_16 + nand->options = NAND_BUSWIDTH_16; +#endif + nand->cmd_ctrl = at91_nand_hwcontrol; +#ifdef CONFIG_SYS_NAND_READY_PIN + nand->dev_ready = at91_nand_ready; +#endif + nand->chip_delay = 20; + +#ifdef CONFIG_ATMEL_NAND_HWECC + res = atmel_hw_nand_init_param(nand); +#endif + + return res; +}
Dear Josh Wu,
-#endif
Grr ... just realized your kernel patch has the same named function. I would have named it with 'ecc' in ... nevertheless I would accept this.
-} -#endif
This seems to be an remnant. It seems this is a mixture between 'SELF_INIT' and older initialization by common nand code. Can you please adopt to the CONFIG_SYS_NAND_SELFINIT? -> please read doc/REDME.nand If I got this correctly you just need to move this static chip_nr plus mtd detection (nand_scan_ident()) into the board_nand_init() and call it _always_. Next step is to define CONFIG_SYS_NAND_SELFINIT in include/nand.h and fix compiler issues (board_nand_init then has no parameter).
I dunno if this is ok to call the nand_scan_ident twice when hwecc is enabled. Scott, can you please comment?
-#endif
-#endif
I think this is the most problematic part. mtd->priv was setup in nand_init_chip(int) before, so why rewrite it here? I know it was this way before ... I wonder if anybody is using atmel_nand with hwecc.
return 0; }
+} +#endif
- int res = 0;
- res = atmel_hw_nand_init_param(nand);
- return res;
Best regards
Andreas Bießmann
Hi, Andreas
On 8/16/2012 4:56 PM, Andreas Bießmann wrote:
Dear Josh Wu,
-#endif
I think I can change the name to 'atmel_hwecc_nand_init_param'. it sounds better.
-} -#endif
Thank you for point it out. I was not pay much attention in this part. According to your suggestion and read the code and README.nand file, I think I will add a new function 'board_nand_init(void)', which use to initialize hwecc & pmecc parameters.
With the above change, I can make sure only call nand_scan_ident once.
-#endif
-#endif
I agree. It seems those code should only for CONFIG_SYS_NAND_SELFINIT is defined. I will move this part of code to 'board_nand_init(void)'.
return 0; }
+} +#endif
- int res = 0;
- return res;
Best regards
Andreas Bießmann
Best Regards, Josh Wu
On 08/16/2012 03:56 AM, Andreas Bießmann wrote:
Dear Josh Wu,
-#endif
-} -#endif
nand_scan_tail() needs to be called at some point too (or just call nand_scan() if you don't have anything to do in between).
It's not how the function is meant to be used.
-Scott
Signed-off-by: Josh Wu josh.wu@atmel.com --- drivers/mtd/nand/atmel_nand.c | 3 +-- 1 file changed, 1 insertion(+), 2 deletions(-)
diff --git a/drivers/mtd/nand/atmel_nand.c b/drivers/mtd/nand/atmel_nand.c index 113da93..9dc003e 100644 --- a/drivers/mtd/nand/atmel_nand.c +++ b/drivers/mtd/nand/atmel_nand.c @@ -79,7 +79,6 @@ static struct nand_ecclayout atmel_oobinfo_small = { static int atmel_nand_calculate(struct mtd_info *mtd, const u_char *dat, unsigned char *ecc_code) { - struct nand_chip *nand_chip = mtd->priv; unsigned int ecc_value;
/* get the first 2 ECC bytes */ @@ -167,7 +166,7 @@ static int atmel_nand_correct(struct mtd_info *mtd, u_char *dat, u_char *read_ecc, u_char *isnull) { struct nand_chip *nand_chip = mtd->priv; - unsigned int ecc_status, ecc_parity, ecc_mode; + unsigned int ecc_status; unsigned int ecc_word, ecc_bit;
/* get the status from the Status Register */
Acked-by: Scott Wood scottwood@freescale.com
-Scott
The Programmable Multibit ECC (PMECC) controller is a programmable binary BCH(Bose, Chaudhuri and Hocquenghem) encoder and decoder. This controller can be used to support both SLC and MLC NAND Flash devices. It supports to generate ECC to correct 2, 4, 8, 12 or 24 bits of error per sector of data.
To use PMECC in this driver, the user needs to set the PMECC correction capability, the sector size and ROM lookup table offsets in board config file.
This driver is ported from Linux kernel atmel_nand PMECC patch. The main difference is in this version it uses registers structure access hardware instead of using macros. It is tested in 9x5 serial boards.
Signed-off-by: Josh Wu josh.wu@atmel.com --- Changes since v1: Change 'ecc' array's type from u32 to u8 in structure pmecc_regs (u32 ecc[11] -> u8 ecc[44]). That will make PMECC write correctly. enable 4k-page nand flash pmecc support. fix coding style errors and warnings. changed lookup table variable name which sounds correct.
drivers/mtd/nand/atmel_nand.c | 654 ++++++++++++++++++++++++++++++++++++- drivers/mtd/nand/atmel_nand_ecc.h | 111 +++++++ 2 files changed, 763 insertions(+), 2 deletions(-)
diff --git a/drivers/mtd/nand/atmel_nand.c b/drivers/mtd/nand/atmel_nand.c index 9dc003e..784370c 100644 --- a/drivers/mtd/nand/atmel_nand.c +++ b/drivers/mtd/nand/atmel_nand.c @@ -5,6 +5,9 @@ * * (C) Copyright 2006 ATMEL Rousset, Lacressonniere Nicolas * + * Add Programmable Multibit ECC support for various AT91 SoC + * (C) Copyright 2012 ATMEL, Hong Xu + * * See file CREDITS for list of people who contributed to this * project. * @@ -41,6 +44,648 @@
#include "atmel_nand_ecc.h" /* Hardware ECC registers */
+static int chip_nr; + +#ifdef CONFIG_ATMEL_NAND_HW_PMECC + +struct atmel_nand_host { + struct pmecc_regs __iomem *pmecc; + struct pmecc_errloc_regs __iomem *pmerrloc; + void __iomem *pmecc_rom_base; + + u8 pmecc_corr_cap; + u16 pmecc_sector_size; + u32 pmecc_index_table_offset; + + int pmecc_bytes_per_sector; + int pmecc_sector_number; + int pmecc_degree; /* Degree of remainders */ + int pmecc_cw_len; /* Length of codeword */ + + /* lookup table for alpha_to and index_of */ + void __iomem *pmecc_alpha_to; + void __iomem *pmecc_index_of; + + /* data for pmecc computation */ + int16_t pmecc_smu[(CONFIG_PMECC_CAP + 2) * (2 * CONFIG_PMECC_CAP + 1)]; + int16_t pmecc_partial_syn[2 * CONFIG_PMECC_CAP + 1]; + int16_t pmecc_si[2 * CONFIG_PMECC_CAP + 1]; + int16_t pmecc_lmu[CONFIG_PMECC_CAP + 1]; /* polynomal order */ + int pmecc_mu[CONFIG_PMECC_CAP + 1]; + int pmecc_dmu[CONFIG_PMECC_CAP + 1]; + int pmecc_delta[CONFIG_PMECC_CAP + 1]; +}; + +static struct atmel_nand_host pmecc_host; +static struct nand_ecclayout atmel_pmecc_oobinfo; + +/* + * Return number of ecc bytes per sector according to sector size and + * correction capability + * + * Following table shows what at91 PMECC supported: + * Correction Capability Sector_512_bytes Sector_1024_bytes + * ===================== ================ ================= + * 2-bits 4-bytes 4-bytes + * 4-bits 7-bytes 7-bytes + * 8-bits 13-bytes 14-bytes + * 12-bits 20-bytes 21-bytes + * 24-bits 39-bytes 42-bytes + */ +static int pmecc_get_ecc_bytes(int cap, int sector_size) +{ + int m = 12 + sector_size / 512; + return (m * cap + 7) / 8; +} + +static void pmecc_config_ecc_layout(struct nand_ecclayout *layout, + int oobsize, int ecc_len) +{ + int i; + + layout->eccbytes = ecc_len; + + /* ECC will occupy the last ecc_len bytes continuously */ + for (i = 0; i < ecc_len; i++) + layout->eccpos[i] = oobsize - ecc_len + i; + + layout->oobfree[0].offset = 2; + layout->oobfree[0].length = + oobsize - ecc_len - layout->oobfree[0].offset; +} + +static void __iomem *pmecc_get_alpha_to(struct atmel_nand_host *host) +{ + int table_size; + + table_size = host->pmecc_sector_size == 512 ? + PMECC_INDEX_TABLE_SIZE_512 : PMECC_INDEX_TABLE_SIZE_1024; + + /* the ALPHA lookup table is right behind the INDEX lookup table. */ + return host->pmecc_rom_base + host->pmecc_index_table_offset + + table_size * sizeof(int16_t); +} + +static void pmecc_gen_syndrome(struct mtd_info *mtd, int sector) +{ + struct nand_chip *nand_chip = mtd->priv; + struct atmel_nand_host *host = nand_chip->priv; + int i; + uint32_t value; + + /* Fill odd syndromes */ + for (i = 0; i < host->pmecc_corr_cap; i++) { + value = readl(&host->pmecc->rem_port[sector].rem[i / 2]); + if (i & 1) + value >>= 16; + value &= 0xffff; + host->pmecc_partial_syn[(2 * i) + 1] = (int16_t)value; + } +} + +static void pmecc_substitute(struct mtd_info *mtd) +{ + struct nand_chip *nand_chip = mtd->priv; + struct atmel_nand_host *host = nand_chip->priv; + int16_t __iomem *alpha_to = host->pmecc_alpha_to; + int16_t __iomem *index_of = host->pmecc_index_of; + int16_t *partial_syn = host->pmecc_partial_syn; + const int cap = host->pmecc_corr_cap; + int16_t *si; + int i, j; + + /* si[] is a table that holds the current syndrome value, + * an element of that table belongs to the field + */ + si = host->pmecc_si; + + memset(&si[1], 0, sizeof(int16_t) * (2 * cap - 1)); + + /* Computation 2t syndromes based on S(x) */ + /* Odd syndromes */ + for (i = 1; i < 2 * cap; i += 2) { + for (j = 0; j < host->pmecc_degree; j++) { + if (partial_syn[i] & ((unsigned short)0x1 << j)) + si[i] = readw(alpha_to + i * j) ^ si[i]; + } + } + /* Even syndrome = (Odd syndrome) ** 2 */ + for (i = 2, j = 1; j <= cap; i = ++j << 1) { + if (si[j] == 0) { + si[i] = 0; + } else { + int16_t tmp; + + tmp = readw(index_of + si[j]); + tmp = (tmp * 2) % host->pmecc_cw_len; + si[i] = readw(alpha_to + tmp); + } + } + + return; +} + +static void pmecc_get_sigma(struct mtd_info *mtd) +{ + struct nand_chip *nand_chip = mtd->priv; + struct atmel_nand_host *host = nand_chip->priv; + + int16_t *lmu = host->pmecc_lmu; + int16_t *si = host->pmecc_si; + int *mu = host->pmecc_mu; + int *dmu = host->pmecc_dmu; /* Discrepancy */ + int *delta = host->pmecc_delta; /* Delta order */ + int cw_len = host->pmecc_cw_len; + const int16_t cap = host->pmecc_corr_cap; + const int num = 2 * cap + 1; + int16_t __iomem *index_of = host->pmecc_index_of; + int16_t __iomem *alpha_to = host->pmecc_alpha_to; + int i, j, k; + uint32_t dmu_0_count, tmp; + int16_t *smu = host->pmecc_smu; + + /* index of largest delta */ + int ro; + int largest; + int diff; + + dmu_0_count = 0; + + /* First Row */ + + /* Mu */ + mu[0] = -1; + + memset(smu, 0, sizeof(int16_t) * num); + smu[0] = 1; + + /* discrepancy set to 1 */ + dmu[0] = 1; + /* polynom order set to 0 */ + lmu[0] = 0; + delta[0] = (mu[0] * 2 - lmu[0]) >> 1; + + /* Second Row */ + + /* Mu */ + mu[1] = 0; + /* Sigma(x) set to 1 */ + memset(&smu[num], 0, sizeof(int16_t) * num); + smu[num] = 1; + + /* discrepancy set to S1 */ + dmu[1] = si[1]; + + /* polynom order set to 0 */ + lmu[1] = 0; + + delta[1] = (mu[1] * 2 - lmu[1]) >> 1; + + /* Init the Sigma(x) last row */ + memset(&smu[(cap + 1) * num], 0, sizeof(int16_t) * num); + + for (i = 1; i <= cap; i++) { + mu[i + 1] = i << 1; + /* Begin Computing Sigma (Mu+1) and L(mu) */ + /* check if discrepancy is set to 0 */ + if (dmu[i] == 0) { + dmu_0_count++; + + tmp = ((cap - (lmu[i] >> 1) - 1) / 2); + if ((cap - (lmu[i] >> 1) - 1) & 0x1) + tmp += 2; + else + tmp += 1; + + if (dmu_0_count == tmp) { + for (j = 0; j <= (lmu[i] >> 1) + 1; j++) + smu[(cap + 1) * num + j] = + smu[i * num + j]; + + lmu[cap + 1] = lmu[i]; + return; + } + + /* copy polynom */ + for (j = 0; j <= lmu[i] >> 1; j++) + smu[(i + 1) * num + j] = smu[i * num + j]; + + /* copy previous polynom order to the next */ + lmu[i + 1] = lmu[i]; + } else { + ro = 0; + largest = -1; + /* find largest delta with dmu != 0 */ + for (j = 0; j < i; j++) { + if ((dmu[j]) && (delta[j] > largest)) { + largest = delta[j]; + ro = j; + } + } + + /* compute difference */ + diff = (mu[i] - mu[ro]); + + /* Compute degree of the new smu polynomial */ + if ((lmu[i] >> 1) > ((lmu[ro] >> 1) + diff)) + lmu[i + 1] = lmu[i]; + else + lmu[i + 1] = ((lmu[ro] >> 1) + diff) * 2; + + /* Init smu[i+1] with 0 */ + for (k = 0; k < num; k++) + smu[(i + 1) * num + k] = 0; + + /* Compute smu[i+1] */ + for (k = 0; k <= lmu[ro] >> 1; k++) { + int16_t a, b, c; + + if (!(smu[ro * num + k] && dmu[i])) + continue; + a = readw(index_of + dmu[i]); + b = readw(index_of + dmu[ro]); + c = readw(index_of + smu[ro * num + k]); + tmp = a + (cw_len - b) + c; + a = readw(alpha_to + tmp % cw_len); + smu[(i + 1) * num + (k + diff)] = a; + } + + for (k = 0; k <= lmu[i] >> 1; k++) + smu[(i + 1) * num + k] ^= smu[i * num + k]; + } + + /* End Computing Sigma (Mu+1) and L(mu) */ + /* In either case compute delta */ + delta[i + 1] = (mu[i + 1] * 2 - lmu[i + 1]) >> 1; + + /* Do not compute discrepancy for the last iteration */ + if (i >= cap) + continue; + + for (k = 0; k <= (lmu[i + 1] >> 1); k++) { + tmp = 2 * (i - 1); + if (k == 0) { + dmu[i + 1] = si[tmp + 3]; + } else if (smu[(i + 1) * num + k] && si[tmp + 3 - k]) { + int16_t a, b, c; + a = readw(index_of + + smu[(i + 1) * num + k]); + b = si[2 * (i - 1) + 3 - k]; + c = readw(index_of + b); + tmp = a + c; + tmp %= cw_len; + dmu[i + 1] = readw(alpha_to + tmp) ^ + dmu[i + 1]; + } + } + } + + return; +} + +static int pmecc_err_location(struct mtd_info *mtd) +{ + struct nand_chip *nand_chip = mtd->priv; + struct atmel_nand_host *host = nand_chip->priv; + const int cap = host->pmecc_corr_cap; + const int num = 2 * cap + 1; + int sector_size = host->pmecc_sector_size; + int err_nbr = 0; /* number of error */ + int roots_nbr; /* number of roots */ + int i; + uint32_t val; + int16_t *smu = host->pmecc_smu; + + writel(PMERRLOC_DISABLE, &host->pmerrloc->eldis); + + for (i = 0; i <= host->pmecc_lmu[cap + 1] >> 1; i++) { + writel(smu[(cap + 1) * num + i], &host->pmerrloc->sigma[i]); + err_nbr++; + } + + val = PMERRLOC_ELCFG_NUM_ERRORS(err_nbr - 1); + if (sector_size == 1024) + val |= PMERRLOC_ELCFG_SECTOR_1024; + + writel(val, &host->pmerrloc->elcfg); + writel(sector_size * 8 + host->pmecc_degree * cap, + &host->pmerrloc->elen); + + while (!(readl(&host->pmerrloc->elisr) & PMERRLOC_CALC_DONE)) + udelay(10); + + roots_nbr = (readl(&host->pmerrloc->elisr) & PMERRLOC_ERR_NUM_MASK) + >> 8; + /* Number of roots == degree of smu hence <= cap */ + if (roots_nbr == host->pmecc_lmu[cap + 1] >> 1) + return err_nbr - 1; + + /* Number of roots does not match the degree of smu + * unable to correct error */ + return -1; +} + +static void pmecc_correct_data(struct mtd_info *mtd, uint8_t *buf, uint8_t *ecc, + int sector_num, int extra_bytes, int err_nbr) +{ + struct nand_chip *nand_chip = mtd->priv; + struct atmel_nand_host *host = nand_chip->priv; + int i = 0; + int byte_pos, bit_pos, sector_size, pos; + uint32_t tmp; + uint8_t err_byte; + + sector_size = host->pmecc_sector_size; + + while (err_nbr) { + tmp = readl(&host->pmerrloc->el[i]) - 1; + byte_pos = tmp / 8; + bit_pos = tmp % 8; + + if (byte_pos >= (sector_size + extra_bytes)) + BUG(); /* should never happen */ + + if (byte_pos < sector_size) { + err_byte = *(buf + byte_pos); + *(buf + byte_pos) ^= (1 << bit_pos); + + pos = sector_num * host->pmecc_sector_size + byte_pos; + printk(KERN_INFO "Bit flip in data area, byte_pos: %d, bit_pos: %d, 0x%02x -> 0x%02x\n", + pos, bit_pos, err_byte, *(buf + byte_pos)); + } else { + /* Bit flip in OOB area */ + tmp = sector_num * host->pmecc_bytes_per_sector + + (byte_pos - sector_size); + err_byte = ecc[tmp]; + ecc[tmp] ^= (1 << bit_pos); + + pos = tmp + nand_chip->ecc.layout->eccpos[0]; + printk(KERN_INFO "Bit flip in OOB, oob_byte_pos: %d, bit_pos: %d, 0x%02x -> 0x%02x\n", + pos, bit_pos, err_byte, ecc[tmp]); + } + + i++; + err_nbr--; + } + + return; +} + +static int pmecc_correction(struct mtd_info *mtd, u32 pmecc_stat, uint8_t *buf, + u8 *ecc) +{ + struct nand_chip *nand_chip = mtd->priv; + struct atmel_nand_host *host = nand_chip->priv; + int i, err_nbr, eccbytes; + uint8_t *buf_pos; + + eccbytes = nand_chip->ecc.bytes; + for (i = 0; i < eccbytes; i++) + if (ecc[i] != 0xff) + goto normal_check; + /* Erased page, return OK */ + return 0; + +normal_check: + for (i = 0; i < host->pmecc_sector_number; i++) { + err_nbr = 0; + if (pmecc_stat & 0x1) { + buf_pos = buf + i * host->pmecc_sector_size; + + pmecc_gen_syndrome(mtd, i); + pmecc_substitute(mtd); + pmecc_get_sigma(mtd); + + err_nbr = pmecc_err_location(mtd); + if (err_nbr == -1) { + printk(KERN_ERR "PMECC: Too many errors\n"); + mtd->ecc_stats.failed++; + return -EIO; + } else { + pmecc_correct_data(mtd, buf_pos, ecc, i, + host->pmecc_bytes_per_sector, err_nbr); + mtd->ecc_stats.corrected += err_nbr; + } + } + pmecc_stat >>= 1; + } + + return 0; +} + +static int atmel_nand_pmecc_read_page(struct mtd_info *mtd, + struct nand_chip *chip, uint8_t *buf, int page) +{ + struct atmel_nand_host *host = chip->priv; + int eccsize = chip->ecc.size; + uint8_t *oob = chip->oob_poi; + uint32_t *eccpos = chip->ecc.layout->eccpos; + uint32_t stat; + + pmecc_writel(host->pmecc, ctrl, PMECC_CTRL_RST); + pmecc_writel(host->pmecc, ctrl, PMECC_CTRL_DISABLE); + pmecc_writel(host->pmecc, cfg, ((pmecc_readl(host->pmecc, cfg)) + & ~PMECC_CFG_WRITE_OP) | PMECC_CFG_AUTO_ENABLE); + + pmecc_writel(host->pmecc, ctrl, PMECC_CTRL_ENABLE); + pmecc_writel(host->pmecc, ctrl, PMECC_CTRL_DATA); + + chip->read_buf(mtd, buf, eccsize); + chip->read_buf(mtd, oob, mtd->oobsize); + + while ((pmecc_readl(host->pmecc, sr) & PMECC_SR_BUSY)) + udelay(1); + + stat = pmecc_readl(host->pmecc, isr); + if (stat != 0) + if (pmecc_correction(mtd, stat, buf, &oob[eccpos[0]]) != 0) + return -EIO; + + return 0; +} + +static void atmel_nand_pmecc_write_page(struct mtd_info *mtd, + struct nand_chip *chip, const uint8_t *buf) +{ + struct atmel_nand_host *host = chip->priv; + uint32_t *eccpos = chip->ecc.layout->eccpos; + int i, j; + + pmecc_writel(host->pmecc, ctrl, PMECC_CTRL_RST); + pmecc_writel(host->pmecc, ctrl, PMECC_CTRL_DISABLE); + + pmecc_writel(host->pmecc, cfg, (pmecc_readl(host->pmecc, cfg) | + PMECC_CFG_WRITE_OP) & ~PMECC_CFG_AUTO_ENABLE); + + pmecc_writel(host->pmecc, ctrl, PMECC_CTRL_ENABLE); + pmecc_writel(host->pmecc, ctrl, PMECC_CTRL_DATA); + + chip->write_buf(mtd, (u8 *)buf, mtd->writesize); + + while ((pmecc_readl(host->pmecc, sr) & PMECC_SR_BUSY)) + udelay(1); + + for (i = 0; i < host->pmecc_sector_number; i++) { + for (j = 0; j < host->pmecc_bytes_per_sector; j++) { + int pos; + + pos = i * host->pmecc_bytes_per_sector + j; + chip->oob_poi[eccpos[pos]] = + readb(&host->pmecc->ecc_port[i].ecc[j]); + } + } + chip->write_buf(mtd, chip->oob_poi, mtd->oobsize); +} + +static void atmel_pmecc_core_init(struct mtd_info *mtd) +{ + struct nand_chip *nand_chip = mtd->priv; + struct atmel_nand_host *host = nand_chip->priv; + uint32_t val = 0; + struct nand_ecclayout *ecc_layout; + + pmecc_writel(host->pmecc, ctrl, PMECC_CTRL_RST); + pmecc_writel(host->pmecc, ctrl, PMECC_CTRL_DISABLE); + + switch (host->pmecc_corr_cap) { + case 2: + val = PMECC_CFG_BCH_ERR2; + break; + case 4: + val = PMECC_CFG_BCH_ERR4; + break; + case 8: + val = PMECC_CFG_BCH_ERR8; + break; + case 12: + val = PMECC_CFG_BCH_ERR12; + break; + case 24: + val = PMECC_CFG_BCH_ERR24; + break; + } + + if (host->pmecc_sector_size == 512) + val |= PMECC_CFG_SECTOR512; + else if (host->pmecc_sector_size == 1024) + val |= PMECC_CFG_SECTOR1024; + + switch (host->pmecc_sector_number) { + case 1: + val |= PMECC_CFG_PAGE_1SECTOR; + break; + case 2: + val |= PMECC_CFG_PAGE_2SECTORS; + break; + case 4: + val |= PMECC_CFG_PAGE_4SECTORS; + break; + case 8: + val |= PMECC_CFG_PAGE_8SECTORS; + break; + } + + val |= (PMECC_CFG_READ_OP | PMECC_CFG_SPARE_DISABLE + | PMECC_CFG_AUTO_DISABLE); + pmecc_writel(host->pmecc, cfg, val); + + ecc_layout = nand_chip->ecc.layout; + pmecc_writel(host->pmecc, sarea, mtd->oobsize - 1); + pmecc_writel(host->pmecc, saddr, ecc_layout->eccpos[0]); + pmecc_writel(host->pmecc, eaddr, + ecc_layout->eccpos[ecc_layout->eccbytes - 1]); + /* See datasheet about PMECC Clock Control Register */ + pmecc_writel(host->pmecc, clk, PMECC_CLK_133MHZ); + pmecc_writel(host->pmecc, idr, 0xff); + pmecc_writel(host->pmecc, ctrl, PMECC_CTRL_ENABLE); +} + +static int atmel_pmecc_nand_init_params(struct nand_chip *nand) +{ + struct mtd_info *mtd; + struct atmel_nand_host *host; + int cap, sector_size; + + mtd = &nand_info[chip_nr++]; + mtd->priv = nand; + host = nand->priv = &pmecc_host; + + /* Detect NAND chips */ + if (nand_scan_ident(mtd, 1, NULL)) { + printk(KERN_WARNING "NAND Flash not found !\n"); + return -ENXIO; + } + + nand->ecc.mode = NAND_ECC_HW; + nand->ecc.calculate = NULL; + nand->ecc.correct = NULL; + nand->ecc.hwctl = NULL; + + cap = host->pmecc_corr_cap = CONFIG_PMECC_CAP; + sector_size = host->pmecc_sector_size = CONFIG_PMECC_SECTOR_SIZE; + host->pmecc_index_table_offset = CONFIG_PMECC_INDEX_TABLE_OFFSET; + + printk(KERN_INFO "Initialize PMECC params, cap: %d, sector: %d\n", + cap, sector_size); + + host->pmecc = (struct pmecc_regs __iomem *) ATMEL_BASE_PMECC; + host->pmerrloc = (struct pmecc_errloc_regs __iomem *) + ATMEL_BASE_PMERRLOC; + host->pmecc_rom_base = (void __iomem *) ATMEL_BASE_ROM; + + /* ECC is calculated for the whole page (1 step) */ + nand->ecc.size = mtd->writesize; + + /* set ECC page size and oob layout */ + switch (mtd->writesize) { + case 2048: + case 4096: + host->pmecc_degree = PMECC_GF_DIMENSION_13; + host->pmecc_cw_len = (1 << host->pmecc_degree) - 1; + host->pmecc_sector_number = mtd->writesize / sector_size; + host->pmecc_bytes_per_sector = pmecc_get_ecc_bytes( + cap, sector_size); + host->pmecc_alpha_to = pmecc_get_alpha_to(host); + host->pmecc_index_of = host->pmecc_rom_base + + host->pmecc_index_table_offset; + + nand->ecc.steps = 1; + nand->ecc.bytes = host->pmecc_bytes_per_sector * + host->pmecc_sector_number; + if (nand->ecc.bytes > mtd->oobsize - 2) { + printk(KERN_ERR "No room for ECC bytes\n"); + return -EINVAL; + } + pmecc_config_ecc_layout(&atmel_pmecc_oobinfo, + mtd->oobsize, + nand->ecc.bytes); + nand->ecc.layout = &atmel_pmecc_oobinfo; + break; + case 512: + case 1024: + /* TODO */ + printk(KERN_ERR "Unsupported page size for PMECC, use Software ECC\n"); + default: + /* page size not handled by HW ECC */ + /* switching back to soft ECC */ + nand->ecc.mode = NAND_ECC_SOFT; + nand->ecc.read_page = NULL; + nand->ecc.postpad = 0; + nand->ecc.prepad = 0; + nand->ecc.bytes = 0; + return 0; + } + + nand->ecc.read_page = atmel_nand_pmecc_read_page; + nand->ecc.write_page = atmel_nand_pmecc_write_page; + + atmel_pmecc_core_init(mtd); + + return 0; +} + +#else + /* oob layout for large page size * bad block info is on bytes 0 and 1 * the bytes have to be consecutives to avoid @@ -234,7 +879,6 @@ static void atmel_nand_hwctl(struct mtd_info *mtd, int mode)
int atmel_hw_nand_init_param(struct nand_chip *nand) { - static int chip_nr = 0; struct mtd_info *mtd;
nand->ecc.mode = NAND_ECC_HW; @@ -293,7 +937,9 @@ int atmel_hw_nand_init_param(struct nand_chip *nand) return 0; }
-#endif +#endif /* CONFIG_ATMEL_NAND_HW_PMECC */ + +#endif /* CONFIG_ATMEL_NAND_HWECC */
static void at91_nand_hwcontrol(struct mtd_info *mtd, int cmd, unsigned int ctrl) @@ -343,8 +989,12 @@ int board_nand_init(struct nand_chip *nand) nand->chip_delay = 20;
#ifdef CONFIG_ATMEL_NAND_HWECC +#ifdef CONFIG_ATMEL_NAND_HW_PMECC + res = atmel_pmecc_nand_init_params(nand); +#else res = atmel_hw_nand_init_param(nand); #endif +#endif
return res; } diff --git a/drivers/mtd/nand/atmel_nand_ecc.h b/drivers/mtd/nand/atmel_nand_ecc.h index 1ee7f99..8f06b14 100644 --- a/drivers/mtd/nand/atmel_nand_ecc.h +++ b/drivers/mtd/nand/atmel_nand_ecc.h @@ -33,4 +33,115 @@ #define ATMEL_ECC_NPR 0x10 /* NParity register */ #define ATMEL_ECC_NPARITY (0xffff << 0) /* NParity */
+/* Register access macros for PMECC */ +#define pmecc_readl(addr, reg) \ + readl(&addr->reg) + +#define pmecc_writel(addr, reg, value) \ + writel((value), &addr->reg) + +/* PMECC Register Definitions */ +#define PMECC_MAX_SECTOR_NUM 8 +struct pmecc_regs { + u32 cfg; /* 0x00 PMECC Configuration Register */ + u32 sarea; /* 0x04 PMECC Spare Area Size Register */ + u32 saddr; /* 0x08 PMECC Start Address Register */ + u32 eaddr; /* 0x0C PMECC End Address Register */ + u32 clk; /* 0x10 PMECC Clock Control Register */ + u32 ctrl; /* 0x14 PMECC Control Register */ + u32 sr; /* 0x18 PMECC Status Register */ + u32 ier; /* 0x1C PMECC Interrupt Enable Register */ + u32 idr; /* 0x20 PMECC Interrupt Disable Register */ + u32 imr; /* 0x24 PMECC Interrupt Mask Register */ + u32 isr; /* 0x28 PMECC Interrupt Status Register */ + u32 reserved0[5]; /* 0x2C-0x3C Reserved */ + + /* 0x40 + sector_num * (0x40), Redundancy Registers */ + struct { + u8 ecc[44]; /* PMECC Generated Redundancy Byte Per Sector */ + u32 reserved1[5]; + } ecc_port[PMECC_MAX_SECTOR_NUM]; + + /* 0x240 + sector_num * (0x40) Remainder Registers */ + struct { + u32 rem[12]; + u32 reserved2[4]; + } rem_port[PMECC_MAX_SECTOR_NUM]; + u32 reserved3[16]; /* 0x440-0x47C Reserved */ +}; + +/* For PMECC Configuration Register */ +#define PMECC_CFG_BCH_ERR2 (0 << 0) +#define PMECC_CFG_BCH_ERR4 (1 << 0) +#define PMECC_CFG_BCH_ERR8 (2 << 0) +#define PMECC_CFG_BCH_ERR12 (3 << 0) +#define PMECC_CFG_BCH_ERR24 (4 << 0) + +#define PMECC_CFG_SECTOR512 (0 << 4) +#define PMECC_CFG_SECTOR1024 (1 << 4) + +#define PMECC_CFG_PAGE_1SECTOR (0 << 8) +#define PMECC_CFG_PAGE_2SECTORS (1 << 8) +#define PMECC_CFG_PAGE_4SECTORS (2 << 8) +#define PMECC_CFG_PAGE_8SECTORS (3 << 8) + +#define PMECC_CFG_READ_OP (0 << 12) +#define PMECC_CFG_WRITE_OP (1 << 12) + +#define PMECC_CFG_SPARE_ENABLE (1 << 16) +#define PMECC_CFG_SPARE_DISABLE (0 << 16) + +#define PMECC_CFG_AUTO_ENABLE (1 << 20) +#define PMECC_CFG_AUTO_DISABLE (0 << 20) + +/* For PMECC Clock Control Register */ +#define PMECC_CLK_133MHZ (2 << 0) + +/* For PMECC Control Register */ +#define PMECC_CTRL_RST (1 << 0) +#define PMECC_CTRL_DATA (1 << 1) +#define PMECC_CTRL_USER (1 << 2) +#define PMECC_CTRL_ENABLE (1 << 4) +#define PMECC_CTRL_DISABLE (1 << 5) + +/* For PMECC Status Register */ +#define PMECC_SR_BUSY (1 << 0) +#define PMECC_SR_ENABLE (1 << 4) + +/* PMERRLOC Register Definitions */ +struct pmecc_errloc_regs { + u32 elcfg; /* 0x00 Error Location Configuration Register */ + u32 elprim; /* 0x04 Error Location Primitive Register */ + u32 elen; /* 0x08 Error Location Enable Register */ + u32 eldis; /* 0x0C Error Location Disable Register */ + u32 elsr; /* 0x10 Error Location Status Register */ + u32 elier; /* 0x14 Error Location Interrupt Enable Register */ + u32 elidr; /* 0x08 Error Location Interrupt Disable Register */ + u32 elimr; /* 0x0C Error Location Interrupt Mask Register */ + u32 elisr; /* 0x20 Error Location Interrupt Status Register */ + u32 reserved0; /* 0x24 Reserved */ + u32 sigma[25]; /* 0x28-0x88 Error Location Sigma Registers */ + u32 el[24]; /* 0x8C-0xE8 Error Location Registers */ + u32 reserved1[5]; /* 0xEC-0xFC Reserved */ +}; + +/* For Error Location Configuration Register */ +#define PMERRLOC_ELCFG_SECTOR_512 (0 << 0) +#define PMERRLOC_ELCFG_SECTOR_1024 (1 << 0) +#define PMERRLOC_ELCFG_NUM_ERRORS(n) ((n) << 16) + +/* For Error Location Disable Register */ +#define PMERRLOC_DISABLE (1 << 0) + +/* For Error Location Interrupt Status Register */ +#define PMERRLOC_ERR_NUM_MASK (0x1f << 8) +#define PMERRLOC_CALC_DONE (1 << 0) + +/* Galois field dimension */ +#define PMECC_GF_DIMENSION_13 13 +#define PMECC_GF_DIMENSION_14 14 + +#define PMECC_INDEX_TABLE_SIZE_512 0x2000 +#define PMECC_INDEX_TABLE_SIZE_1024 0x4000 + #endif
Dear Josh Wu,
- (C) Copyright 2006 ATMEL Rousset, Lacressonniere Nicolas
- Add Programmable Multibit ECC support for various AT91 SoC
- project.
@@ -41,6 +44,648 @@
- struct pmecc_regs __iomem *pmecc;
- struct pmecc_errloc_regs __iomem *pmerrloc;
- void __iomem *pmecc_rom_base;
- u8 pmecc_corr_cap;
- u16 pmecc_sector_size;
- u32 pmecc_index_table_offset;
- int pmecc_bytes_per_sector;
- int pmecc_sector_number;
- int pmecc_degree; /* Degree of remainders */
- int pmecc_cw_len; /* Length of codeword */
- /* lookup table for alpha_to and index_of */
- void __iomem *pmecc_alpha_to;
- void __iomem *pmecc_index_of;
- /* data for pmecc computation */
- int16_t pmecc_smu[(CONFIG_PMECC_CAP + 2) * (2 * CONFIG_PMECC_CAP + 1)];
- int16_t pmecc_partial_syn[2 * CONFIG_PMECC_CAP + 1];
- int16_t pmecc_si[2 * CONFIG_PMECC_CAP + 1];
- int16_t pmecc_lmu[CONFIG_PMECC_CAP + 1]; /* polynomal order */
- int pmecc_mu[CONFIG_PMECC_CAP + 1];
- int pmecc_dmu[CONFIG_PMECC_CAP + 1];
- int pmecc_delta[CONFIG_PMECC_CAP + 1];
can you please add some README entry describing these new config parameters? Namely CONFIG_ATMEL_NAND_HW_PMECC, CONFIG_PMECC_CAP, CONFIG_PMECC_SECTOR_SIZE (can't this be derived from some already available NAND information?) and CONFIG_PMECC_INDEX_TABLE_OFFSET.
- Return number of ecc bytes per sector according to sector size and
- correction capability
- Following table shows what at91 PMECC supported:
- Correction Capability Sector_512_bytes Sector_1024_bytes
- int m = 12 + sector_size / 512;
- return (m * cap + 7) / 8;
- int oobsize, int ecc_len)
- int i;
- layout->eccbytes = ecc_len;
- /* ECC will occupy the last ecc_len bytes continuously */
- for (i = 0; i < ecc_len; i++)
- layout->oobfree[0].offset = 2;
- layout->oobfree[0].length =
- int table_size;
- table_size = host->pmecc_sector_size == 512 ?
- /* the ALPHA lookup table is right behind the INDEX lookup table. */
- return host->pmecc_rom_base + host->pmecc_index_table_offset +
- struct atmel_nand_host *host = nand_chip->priv;
- int i;
- uint32_t value;
- /* Fill odd syndromes */
- for (i = 0; i < host->pmecc_corr_cap; i++) {
if (i & 1)
value >>= 16;
value &= 0xffff;
- int16_t __iomem *alpha_to = host->pmecc_alpha_to;
- int16_t __iomem *index_of = host->pmecc_index_of;
- int16_t *partial_syn = host->pmecc_partial_syn;
- const int cap = host->pmecc_corr_cap;
- int16_t *si;
- int i, j;
- /* si[] is a table that holds the current syndrome value,
- si = host->pmecc_si;
- memset(&si[1], 0, sizeof(int16_t) * (2 * cap - 1));
- /* Computation 2t syndromes based on S(x) */
- /* Odd syndromes */
- for (i = 1; i < 2 * cap; i += 2) {
- /* Even syndrome = (Odd syndrome) ** 2 */
- for (i = 2, j = 1; j <= cap; i = ++j << 1) {
if (si[j] == 0) {
si[i] = 0;
} else {
int16_t tmp;
- return;
- int16_t *lmu = host->pmecc_lmu;
- int16_t *si = host->pmecc_si;
- int *mu = host->pmecc_mu;
- int *dmu = host->pmecc_dmu; /* Discrepancy */
- int *delta = host->pmecc_delta; /* Delta order */
- int cw_len = host->pmecc_cw_len;
- const int16_t cap = host->pmecc_corr_cap;
- const int num = 2 * cap + 1;
- int i, j, k;
- uint32_t dmu_0_count, tmp;
- int16_t *smu = host->pmecc_smu;
- /* index of largest delta */
- int ro;
- int largest;
- int diff;
- dmu_0_count = 0;
- /* First Row */
- /* Mu */
- mu[0] = -1;
- memset(smu, 0, sizeof(int16_t) * num);
- smu[0] = 1;
- /* discrepancy set to 1 */
- dmu[0] = 1;
- /* polynom order set to 0 */
- lmu[0] = 0;
- delta[0] = (mu[0] * 2 - lmu[0]) >> 1;
---------------------^ isn't mu[0] -1 here
- /* Second Row */
- /* Mu */
- mu[1] = 0;
- /* Sigma(x) set to 1 */
- memset(&smu[num], 0, sizeof(int16_t) * num);
- smu[num] = 1;
- /* discrepancy set to S1 */
- dmu[1] = si[1];
- lmu[1] = 0;
- delta[1] = (mu[1] * 2 - lmu[1]) >> 1;
----------------------^ isn't mu[1] 0 here?
I see, this algorithm is just copied from the processors datasheet.
- /* Init the Sigma(x) last row */
- memset(&smu[(cap + 1) * num], 0, sizeof(int16_t) * num);
Isn't the whole smu zeroed here at this stage? why not just call memset(smu, 0, sizeof(int16) * ARRAY_SIZE(smu))?
- for (i = 1; i <= cap; i++) {
mu[i + 1] = i << 1;
if (dmu[i] == 0) {
dmu_0_count++;
tmp += 2;
else
tmp += 1;
smu[i * num + j];
return;
/* copy polynom */
Horrible to read, this was written first by an electrical engineer (insider joke)? Can you please add a comment at top of pmecc_get_sigma and add a warning about extremely complicated to read algorithm ;) But it must be right cause it is written down in the datasheet ...
} else {
ro = 0;
largest = -1;
largest = delta[j];
ro = j;
else
int16_t a, b, c;
continue;
if (i >= cap)
continue;
tmp = 2 * (i - 1);
if (k == 0) {
int16_t a, b, c;
tmp = a + c;
tmp %= cw_len;
dmu[i + 1];
- return;
- int sector_size = host->pmecc_sector_size;
- int err_nbr = 0; /* number of error */
- int roots_nbr; /* number of roots */
- int i;
- uint32_t val;
- writel(PMERRLOC_DISABLE, &host->pmerrloc->eldis);
- for (i = 0; i <= host->pmecc_lmu[cap + 1] >> 1; i++) {
err_nbr++;
- val = PMERRLOC_ELCFG_NUM_ERRORS(err_nbr - 1);
- if (sector_size == 1024)
- writel(val, &host->pmerrloc->elcfg);
- writel(sector_size * 8 + host->pmecc_degree * cap,
- while (!(readl(&host->pmerrloc->elisr) & PMERRLOC_CALC_DONE))
udelay(10);
Can you please add some timeout here. Maybe a WATCHDOG_RESET is also required?
- roots_nbr = (readl(&host->pmerrloc->elisr) & PMERRLOC_ERR_NUM_MASK)
>> 8;
- /* Number of roots == degree of smu hence <= cap */
- if (roots_nbr == host->pmecc_lmu[cap + 1] >> 1)
return err_nbr - 1;
- /* Number of roots does not match the degree of smu
- return -1;
- int i = 0;
- int byte_pos, bit_pos, sector_size, pos;
- uint32_t tmp;
- uint8_t err_byte;
- sector_size = host->pmecc_sector_size;
- while (err_nbr) {
byte_pos = tmp / 8;
bit_pos = tmp % 8;
} else {
i++;
err_nbr--;
- return;
- u8 *ecc)
- int i, err_nbr, eccbytes;
- uint8_t *buf_pos;
- eccbytes = nand_chip->ecc.bytes;
- for (i = 0; i < eccbytes; i++)
if (ecc[i] != 0xff)
goto normal_check;
- /* Erased page, return OK */
+normal_check:
- for (i = 0; i < host->pmecc_sector_number; i++) {
err_nbr = 0;
return -EIO;
} else {
pmecc_stat >>= 1;
- struct nand_chip *chip, uint8_t *buf, int page)
- struct atmel_nand_host *host = chip->priv;
- int eccsize = chip->ecc.size;
- uint8_t *oob = chip->oob_poi;
- uint32_t *eccpos = chip->ecc.layout->eccpos;
- uint32_t stat;
- pmecc_writel(host->pmecc, ctrl, PMECC_CTRL_RST);
- pmecc_writel(host->pmecc, ctrl, PMECC_CTRL_DISABLE);
- pmecc_writel(host->pmecc, cfg, ((pmecc_readl(host->pmecc, cfg))
- pmecc_writel(host->pmecc, ctrl, PMECC_CTRL_ENABLE);
- pmecc_writel(host->pmecc, ctrl, PMECC_CTRL_DATA);
- chip->read_buf(mtd, buf, eccsize);
- chip->read_buf(mtd, oob, mtd->oobsize);
- while ((pmecc_readl(host->pmecc, sr) & PMECC_SR_BUSY))
udelay(1);
- stat = pmecc_readl(host->pmecc, isr);
- if (stat != 0)
return -EIO;
- int i, j;
- pmecc_writel(host->pmecc, cfg, (pmecc_readl(host->pmecc, cfg) |
- chip->write_buf(mtd, (u8 *)buf, mtd->writesize);
udelay(1);
int pos;
- chip->write_buf(mtd, chip->oob_poi, mtd->oobsize);
- uint32_t val = 0;
- struct nand_ecclayout *ecc_layout;
- switch (host->pmecc_corr_cap) {
- case 2:
break;
- case 4:
break;
- case 8:
break;
- case 12:
break;
- case 24:
break;
- if (host->pmecc_sector_size == 512)
- else if (host->pmecc_sector_size == 1024)
- switch (host->pmecc_sector_number) {
- case 1:
break;
- case 2:
break;
- case 4:
break;
- case 8:
break;
- val |= (PMECC_CFG_READ_OP | PMECC_CFG_SPARE_DISABLE
- pmecc_writel(host->pmecc, cfg, val);
- ecc_layout = nand_chip->ecc.layout;
- pmecc_writel(host->pmecc, sarea, mtd->oobsize - 1);
- pmecc_writel(host->pmecc, saddr, ecc_layout->eccpos[0]);
- pmecc_writel(host->pmecc, eaddr,
- /* See datasheet about PMECC Clock Control Register */
- pmecc_writel(host->pmecc, clk, PMECC_CLK_133MHZ);
- pmecc_writel(host->pmecc, idr, 0xff);
- struct mtd_info *mtd;
- struct atmel_nand_host *host;
- int cap, sector_size;
- mtd = &nand_info[chip_nr++];
NAK
- mtd->priv = nand;
- host = nand->priv = &pmecc_host;
- /* Detect NAND chips */
- if (nand_scan_ident(mtd, 1, NULL)) {
please change that, read later on.
return -ENXIO;
- nand->ecc.mode = NAND_ECC_HW;
- nand->ecc.calculate = NULL;
- nand->ecc.correct = NULL;
- nand->ecc.hwctl = NULL;
- cap = host->pmecc_corr_cap = CONFIG_PMECC_CAP;
- sector_size = host->pmecc_sector_size = CONFIG_PMECC_SECTOR_SIZE;
Can't we use some information from the nand chip here? Do we need to hard code this paramater?
- host->pmecc_index_table_offset = CONFIG_PMECC_INDEX_TABLE_OFFSET;
- printk(KERN_INFO "Initialize PMECC params, cap: %d, sector: %d\n",
cap, sector_size);
- host->pmecc = (struct pmecc_regs __iomem *) ATMEL_BASE_PMECC;
- host->pmerrloc = (struct pmecc_errloc_regs __iomem *)
- host->pmecc_rom_base = (void __iomem *) ATMEL_BASE_ROM;
- /* ECC is calculated for the whole page (1 step) */
- nand->ecc.size = mtd->writesize;
- /* set ECC page size and oob layout */
- switch (mtd->writesize) {
- case 2048:
- case 4096:
cap, sector_size);
return -EINVAL;
mtd->oobsize,
nand->ecc.bytes);
break;
- case 512:
- case 1024:
/* TODO */
- default:
- nand->ecc.read_page = atmel_nand_pmecc_read_page;
- nand->ecc.write_page = atmel_nand_pmecc_write_page;
- atmel_pmecc_core_init(mtd);
+#else
- bad block info is on bytes 0 and 1
- the bytes have to be consecutives to avoid
- res = atmel_pmecc_nand_init_params(nand);
- readl(&addr->reg)
- writel((value), &addr->reg)
- u32 cfg; /* 0x00 PMECC Configuration Register */
- u32 sarea; /* 0x04 PMECC Spare Area Size Register */
- u32 saddr; /* 0x08 PMECC Start Address Register */
- u32 eaddr; /* 0x0C PMECC End Address Register */
- u32 clk; /* 0x10 PMECC Clock Control Register */
- u32 ctrl; /* 0x14 PMECC Control Register */
- u32 sr; /* 0x18 PMECC Status Register */
- u32 ier; /* 0x1C PMECC Interrupt Enable Register */
- u32 idr; /* 0x20 PMECC Interrupt Disable Register */
- u32 imr; /* 0x24 PMECC Interrupt Mask Register */
- u32 isr; /* 0x28 PMECC Interrupt Status Register */
- u32 reserved0[5]; /* 0x2C-0x3C Reserved */
- /* 0x40 + sector_num * (0x40), Redundancy Registers */
- struct {
u32 reserved1[5];
- } ecc_port[PMECC_MAX_SECTOR_NUM];
- /* 0x240 + sector_num * (0x40) Remainder Registers */
- struct {
u32 rem[12];
u32 reserved2[4];
- } rem_port[PMECC_MAX_SECTOR_NUM];
- u32 reserved3[16]; /* 0x440-0x47C Reserved */
- u32 elcfg; /* 0x00 Error Location Configuration Register */
- u32 elprim; /* 0x04 Error Location Primitive Register */
- u32 elen; /* 0x08 Error Location Enable Register */
- u32 eldis; /* 0x0C Error Location Disable Register */
- u32 elsr; /* 0x10 Error Location Status Register */
- u32 elier; /* 0x14 Error Location Interrupt Enable Register */
- u32 elidr; /* 0x08 Error Location Interrupt Disable Register */
- u32 elimr; /* 0x0C Error Location Interrupt Mask Register */
- u32 elisr; /* 0x20 Error Location Interrupt Status Register */
- u32 reserved0; /* 0x24 Reserved */
- u32 sigma[25]; /* 0x28-0x88 Error Location Sigma Registers */
- u32 el[24]; /* 0x8C-0xE8 Error Location Registers */
- u32 reserved1[5]; /* 0xEC-0xFC Reserved */
#endif
Not really nice code but it seems the kernel guys accepted it the same way. So I will _not_ NAK it. But please add at least a README entry describing the new config parameters, think about the sector size (ore explain me why you need another config) and please change the driver initialization to the SELF_INIT as mentioned in another mail. You use again the nand_scan_indent() inside your xx_nand_init_params(). Please rewrite the board_nand_init() as shown in doc/README.nand, maybe copy the stub from mtd/nand.c's nand_init() and nand_init_chip(). Call in your own atmel_nand_init_chip() nand_scan_ident() and after that setup the parameters for eighter ECC or PMECC. Always hand over the struct nand_chip and do not work with the nand_chip array in the xx_init_param() functions.
Best regards
Andreas Bießmann
Hi, Andreas
On 8/17/2012 5:24 PM, Andreas Bießmann wrote:
Dear Josh Wu,
- project.
@@ -41,6 +44,648 @@
OK, I will add a README file to explain all the parameters. this CONFIG_PMECC_SECTOR_SIZE means how many bytes to generate out PMECC code. It only can be 512 and 1024. So for a nand chip whose page size is 2048, if CONFIG_PMECC_SECTOR_SIZE is set as 512, then PMECC will generate PMECC code for each 512 bytes.
I think it cannot be derived from nand information.
- int i;
- int table_size;
- int i;
- uint32_t value;
if (i & 1)
value >>= 16;
value &= 0xffff;
- int16_t *si;
- int i, j;
if (si[j] == 0) {
si[i] = 0;
} else {
int16_t tmp;
- return;
- int i, j, k;
- int ro;
- int largest;
- int diff;
- dmu_0_count = 0;
- /* First Row */
- /* Mu */
- mu[0] = -1;
- smu[0] = 1;
- dmu[0] = 1;
- lmu[0] = 0;
yes, sorry, this algorithm is from datasheet. Maybe I can add comment here.
- /* Second Row */
- /* Mu */
- mu[1] = 0;
- smu[num] = 1;
- dmu[1] = si[1];
- lmu[1] = 0;
actually, I am not similar with this algorithm.
I will confirm it and above with someone who is familiar with this algorithm.
mu[i + 1] = i << 1;
if (dmu[i] == 0) {
dmu_0_count++;
tmp += 2;
else
tmp += 1;
smu[i * num + j];
return;
/* copy polynom */
ok, i will add more comments for the function. seems it is algorithm related. it is indeed to read.
} else {
ro = 0;
largest = -1;
largest = delta[j];
ro = j;
else
int16_t a, b, c;
continue;
if (i >= cap)
continue;
tmp = 2 * (i - 1);
if (k == 0) {
int16_t a, b, c;
tmp = a + c;
tmp %= cw_len;
dmu[i + 1];
- return;
- int i;
- uint32_t val;
err_nbr++;
udelay(10);
sure. Scott also point this.
>> 8;
return err_nbr - 1;
- return -1;
- int i = 0;
- uint32_t tmp;
- uint8_t err_byte;
- while (err_nbr) {
byte_pos = tmp / 8;
bit_pos = tmp % 8;
} else {
i++;
err_nbr--;
- return;
- u8 *ecc)
- uint8_t *buf_pos;
if (ecc[i] != 0xff)
goto normal_check;
+normal_check:
err_nbr = 0;
return -EIO;
} else {
pmecc_stat >>= 1;
- uint32_t stat;
udelay(1);
- if (stat != 0)
return -EIO;
- int i, j;
udelay(1);
int pos;
- uint32_t val = 0;
- case 2:
break;
- case 4:
break;
- case 8:
break;
- case 12:
break;
- case 24:
break;
- case 1:
break;
- case 2:
break;
- case 4:
break;
- case 8:
break;
NAK
i will use CONFIG_SYS_NAND_SELF_INIT, so it will removed.
- mtd->priv = nand;
ditto.
return -ENXIO;
as I mention in the beginning, it seems only use as hard code.
cap, sector_size);
- case 2048:
- case 4096:
cap, sector_size);
return -EINVAL;
mtd->oobsize,
nand->ecc.bytes);
break;
- case 512:
- case 1024:
/* TODO */
- default:
+#else
- /* oob layout for large page size
- readl(&addr->reg)
- struct {
u32 reserved1[5];
- struct {
u32 rem[12];
u32 reserved2[4];
- #endif
I will send next version according to yours and Scott's suggestion. Thank you.
Best regards
Andreas Bießmann
On 08/21/2012 05:37 AM, Josh Wu wrote:
Hi, Andreas
So this is basically nand->ecc.size? While this can't be directly read from the chip, usually there's a convention for a given type of NAND chip on a given controller. Do you really need to support both 512 and 1024 for any single chip?
Why do you set nand->ecc.size to mtd->writesize if that isn't the actual ECC chunk size?
-Scott
Hi, Scott
Hi, Andreas
I think I am not make me clear in previous email. let me try again :)
For the PMECC hardware, it support to read/write one data page of nand in one step. The size of the data page should be multiple(max is 8) of PMECC sector. The PMECC sector can only be 512 or 1024.
So the PMECC can read/write max 8192 bytes (max data page size: 8 x 1024) in one step. And generate the ecc bytes (8 x 4) for this page if the error correct capability is 2 bits.
But the internal thing is those ecc bytes is split into 8 parts and each part is for corresponding sector.
I don't think nand->ecc.size is the CONFIG_PMECC_SECTOR_SIZE. Since for my understanding, the ecc.size is the data bytes per ecc step. In my code, PMECC can read/write one page in one step. So I set nand->ecc.size to the page size.
hmm. So maybe I can set default PMECC sector size to 512 if nand flash page is smaller than 4096 (8x512) bytes. And set it to 1024 only when nand flash page is larger than 4096. But in other side, if CONFIG_PMECC_SECTOR_SIZE is defined, then driver will use it.
As mentioned in above, the ecc.size is the data bytes per ecc step. In PMECC code, PMECC can read/write one page in one step. So I set nand->ecc.size to the page size not the actual inside ECC chunk size: CONFIG_PMECC_SECTOR_SIZE
-Scott
Thanks. Best Regards, Josh Wu
Sigh, I wish U-Boot's code style policies weren't so rigid as to force such a difference relative to the Linux driver.
Will that (unsigned short) make any difference? Won't it just get promoted back to int for the computation?
i++;
err_nbr--;
- return;
If it came over from Linux this way, I'm not asking you to change it just here, but the return; at the end is superfluous.
udelay(1);
Timeout?
-Scott
Signed-off-by: Josh Wu josh.wu@atmel.com --- board/atmel/at91sam9x5ek/at91sam9x5ek.c | 12 ++++++------ 1 file changed, 6 insertions(+), 6 deletions(-)
diff --git a/board/atmel/at91sam9x5ek/at91sam9x5ek.c b/board/atmel/at91sam9x5ek/at91sam9x5ek.c index 17db0fd..8dc24ab 100644 --- a/board/atmel/at91sam9x5ek/at91sam9x5ek.c +++ b/board/atmel/at91sam9x5ek/at91sam9x5ek.c @@ -63,13 +63,13 @@ static void at91sam9x5ek_nand_hw_init(void) writel(csa, &matrix->ebicsa);
/* Configure SMC CS3 for NAND/SmartMedia */ - writel(AT91_SMC_SETUP_NWE(2) | AT91_SMC_SETUP_NCS_WR(0) | - AT91_SMC_SETUP_NRD(2) | AT91_SMC_SETUP_NCS_RD(0), + writel(AT91_SMC_SETUP_NWE(1) | AT91_SMC_SETUP_NCS_WR(0) | + AT91_SMC_SETUP_NRD(1) | AT91_SMC_SETUP_NCS_RD(0), &smc->cs[3].setup); - writel(AT91_SMC_PULSE_NWE(4) | AT91_SMC_PULSE_NCS_WR(4) | - AT91_SMC_PULSE_NRD(4) | AT91_SMC_PULSE_NCS_RD(4), + writel(AT91_SMC_PULSE_NWE(3) | AT91_SMC_PULSE_NCS_WR(5) | + AT91_SMC_PULSE_NRD(4) | AT91_SMC_PULSE_NCS_RD(6), &smc->cs[3].pulse); - writel(AT91_SMC_CYCLE_NWE(7) | AT91_SMC_CYCLE_NRD(7), + writel(AT91_SMC_CYCLE_NWE(5) | AT91_SMC_CYCLE_NRD(6), &smc->cs[3].cycle); writel(AT91_SMC_MODE_RM_NRD | AT91_SMC_MODE_WM_NWE | AT91_SMC_MODE_EXNW_DISABLE | @@ -78,7 +78,7 @@ static void at91sam9x5ek_nand_hw_init(void) #else /* CONFIG_SYS_NAND_DBW_8 */ AT91_SMC_MODE_DBW_8 | #endif - AT91_SMC_MODE_TDF_CYCLE(3), + AT91_SMC_MODE_TDF_CYCLE(1), &smc->cs[3].mode);
writel(1 << ATMEL_ID_PIOCD, &pmc->pcer);
Dear Josh Wu,
- writel(AT91_SMC_SETUP_NWE(1) | AT91_SMC_SETUP_NCS_WR(0) |
&smc->cs[3].setup);AT91_SMC_SETUP_NRD(1) | AT91_SMC_SETUP_NCS_RD(0),
- writel(AT91_SMC_PULSE_NWE(3) | AT91_SMC_PULSE_NCS_WR(5) |
&smc->cs[3].pulse);AT91_SMC_PULSE_NRD(4) | AT91_SMC_PULSE_NCS_RD(6),
- writel(AT91_SMC_CYCLE_NWE(5) | AT91_SMC_CYCLE_NRD(6), &smc->cs[3].cycle); writel(AT91_SMC_MODE_RM_NRD | AT91_SMC_MODE_WM_NWE | AT91_SMC_MODE_EXNW_DISABLE |
&smc->cs[3].mode);
are these changes required to get it working? As I understand your changes make the timing harder, which will result in less different NAND devices will be supported. The timing may be exactly the best for the currently used one, but maybe some change the device in future to a slightly slower one. Maybe I'm wrong so tell me please. But if not then I would like to have a Tested-by from one who owns this board (Bo?)
Best regards
Andreas Bießmann
Hi, Andreas
On 8/21/2012 6:46 PM, Andreas Bießmann wrote:
Dear Josh Wu,
&smc->cs[3].mode);
yes. without those change PMECC will not work.
Currently this timing works for both PMECC & non-PMECC. But I'm not sure whether it works for other different chips in future. So the Tested-by should be needed for this patch. I will cc Bo in the next version.
Best regards
Andreas Bießmann
Signed-off-by: Josh Wu josh.wu@atmel.com --- include/configs/at91sam9x5ek.h | 7 +++++++ 1 file changed, 7 insertions(+)
diff --git a/include/configs/at91sam9x5ek.h b/include/configs/at91sam9x5ek.h index f8bd870..32f9469 100644 --- a/include/configs/at91sam9x5ek.h +++ b/include/configs/at91sam9x5ek.h @@ -122,6 +122,13 @@ #define CONFIG_SYS_NAND_ENABLE_PIN AT91_PIN_PD4 #define CONFIG_SYS_NAND_READY_PIN AT91_PIN_PD5
+/* PMECC & PMERRLOC */ +#define CONFIG_ATMEL_NAND_HWECC 1 +#define CONFIG_ATMEL_NAND_HW_PMECC 1 +#define CONFIG_PMECC_CAP 2 +#define CONFIG_PMECC_SECTOR_SIZE 512 +#define CONFIG_PMECC_INDEX_TABLE_OFFSET 0x8000 + #define CONFIG_MTD_DEVICE #define CONFIG_CMD_MTDPARTS #define CONFIG_MTD_PARTITIONS
Andreas Bießmann
Josh Wu
Scott Wood
