[U-Boot] ARM - cache and alignment
Tom, Marek
At the moment, whenever an unaligned address is used in cache operations (invalidate_dcache_range, or flush_dcache_range), the whole request is discarded for am926ejs. for armV7 or armV8 only the aligned part is maintained. This is probably what is causing the bug addressed in 8133f43d1cd. There are a lot of unaligned buffers used in DMA operations and for all of them, we're possibly handling the cached partially or not at all. I've seen this when using the environment from a file stored in a FAT partition. commit 8133f43d1cd addresses this by using a bounce buffer at the FAT level but it's only one of many cases.
I think we can do better with unaligned cache operations:
* flush (writeback + invalidate): Suppose we use address p which is unaligned, flush_dcache_range() can do the writeback+invalidate on the whole range [p & ~(line_sz - 1); p + length | (line_sz - 1)]. There should no problem with that since writeback can happen at any point in time.
* invalidation
It is a bit trickier. here is a pseudo-code: invalidate_dcache_range(p,length) { write_back_invalidate(first line) write_back_invalidate(last line) invalidate(all other lines) }
Here again this should work fine IF invalidate_dcache_range() is called BEFORE the DMA operation (again the writeback can happen at time so it's valid do it here). Calling it only AFTER the operation, may corrupt the data written by the DMA with old data from CPU. This how I used to handle unaligned buffers in some other projects.
There is however one loophole: a data sitting in the first or the last line is accessed before the memory is updated by the DMA, then the first/line will be corrupted. But it's not highly probable as this data would have to be used in parallel of the DMA (interrupt handling, SMP?, dma mgt related variable). So it's not perfect but it would still be better than we have today.
cheers,
Jean-Jacques
On 01/16/2017 02:29 PM, Jean-Jacques Hiblot wrote:
Tom, Marek
- flush (writeback + invalidate): Suppose we use address p which is
- invalidation
Or just fix all the code which complains about unaligned buffers, done. That's the way to go without all the complications above.
Tom, Marek
- invalidation
It's not that complex, but it's not perfect. We would need to keep the same warning as we have now, but it would make it work in more cases.
Tracking every possible unaligned buffer that gets invalidated is not a trivial job. Most of the time the buffer is allocated in a upper layer and passed down to a driver via layers like network stack, block layer etc.And in many cases, the warning will come and go depending on how the variable aligned on the stack or the heap.
Tom, Marek
- invalidation
The warning is there for that exact reason -- to inform you something's wrong.
I didn't observe this much in fact. I usually see the buffers coming it aligned or being allocated in drivers. Also, I think that's why the RC cycle is there, so we can test the next release and fix these issues.
Tom, Marek
- invalidation
It's not commonly seen but I came across it some times.
Here are two examples:
Network: U-Boot 2016.09-rc1-00087-gd40ff0a (Jul 27 2016 - 10:04:33 -0500) CPU : DRA752-HS ES2.0 Model: TI DRA742 [...] Booting from network ... cpsw Waiting for PHY auto negotiation to complete.... done link up on port 0, speed 1000, full duplex BOOTP broadcast 1 CACHE: Misaligned operation at range [dffecb40, dffecc96] CACHE: Misaligned operation at range [dffed140, dffed17e] BOOTP broadcast 2 [...] File transfer via NFS from server 10.0.1.26; our IP address is 128.247.83.128; sending through gateway 128.247.82.1 [...] Load address: 0x82000000 Loading: CACHE: Misaligned operation at range [dffebfc0, dffebfea]
FAT: it has been fixed recently by using a bounce buffer in FAT code by "8133f43d1cd fs/fat/fat_write: Fix buffer alignments". I've also seen it a few years back on PowerPC platforms when accessing a USB storage.
I'm sure that we could find more examples. I don't mean that they shouldn't be fixed, simply that we could still make things work in most cases at a low cost. The modifications I proposed do not change the behaviour of the code for aligned buffers, it just make it much more likely that it would work with unaligned buffers. I fail to see the reason why this wouldn't be a good thing.
BTW the L2 uniphier cache implements this for flush and invalidation, and some architectures (pxa, blackfin, openrisc, etc.) do the flush() this way too.
Jean-Jacques
Tom, Marek
- invalidation
It seems to me like "it kinda works, but it really doesn't sometimes ...." , so it's encouraging bad practice as people will get used to ignoring this warning because things "kinda work, in most cases".
Jean-Jacques
Tom, Marek
- invalidation
I see your point but the current situation is exactly like that: it works most of the time. I'm not pushing for the changes, I just wanted to let know that we could do better if we wish.
Jean-Jacques
On 01/16/2017 02:29 PM, Jean-Jacques Hiblot wrote: > Tom, Marek Hi,
> At the moment, whenever an unaligned address is used in cache > operations > (invalidate_dcache_range, or flush_dcache_range), the whole > request is > discarded for am926ejs. for armV7 or armV8 only the aligned part is > maintained. This is probably what is causing the bug addressed in > 8133f43d1cd. There are a lot of unaligned buffers used in DMA > operations > and for all of them, we're possibly handling the cached partially > or not > at all. I've seen this when using the environment from a file > stored in > a FAT partition. commit 8133f43d1cd addresses this by using a bounce > buffer at the FAT level but it's only one of many cases. > > I think we can do better with unaligned cache operations: > > * flush (writeback + invalidate): Suppose we use address p which is > unaligned, flush_dcache_range() can do the writeback+invalidate > on the > whole range [p & ~(line_sz - 1); p + length | (line_sz - 1)]. There > should no problem with that since writeback can happen at any > point in > time. > > * invalidation > > It is a bit trickier. here is a pseudo-code: > invalidate_dcache_range(p,length) > { > write_back_invalidate(first line) > write_back_invalidate(last line) > invalidate(all other lines) > } > > Here again this should work fine IF invalidate_dcache_range() is > called > BEFORE the DMA operation (again the writeback can happen at time so > it's > valid do it here). Calling it only AFTER the operation, may corrupt > the > data written by the DMA with old data from CPU. This how I used to > handle unaligned buffers in some other projects. > > > There is however one loophole: a data sitting in the first or the > last > line is accessed before the memory is updated by the DMA, then the > first/line will be corrupted. But it's not highly probable as this > data > would have to be used in parallel of the DMA (interrupt handling, > SMP?, > dma mgt related variable). So it's not perfect but it would still be > better than we have today. Or just fix all the code which complains about unaligned buffers, done. That's the way to go without all the complications above.
But in this case, it's a property of the hardware. With your patch, it's also a property of the code which works "most of the time". You even state that in the patch description.
Replacing one problem with another which looks like it isn't problem anymore (but still is) is not better IMO.
Jean-Jacques
On 16/01/2017 17:00, Marek Vasut wrote: > On 01/16/2017 02:29 PM, Jean-Jacques Hiblot wrote: >> Tom, Marek > Hi, > >> At the moment, whenever an unaligned address is used in cache >> operations >> (invalidate_dcache_range, or flush_dcache_range), the whole >> request is >> discarded for am926ejs. for armV7 or armV8 only the aligned part is >> maintained. This is probably what is causing the bug addressed in >> 8133f43d1cd. There are a lot of unaligned buffers used in DMA >> operations >> and for all of them, we're possibly handling the cached partially >> or not >> at all. I've seen this when using the environment from a file >> stored in >> a FAT partition. commit 8133f43d1cd addresses this by using a bounce >> buffer at the FAT level but it's only one of many cases. >> >> I think we can do better with unaligned cache operations: >> >> * flush (writeback + invalidate): Suppose we use address p which is >> unaligned, flush_dcache_range() can do the writeback+invalidate >> on the >> whole range [p & ~(line_sz - 1); p + length | (line_sz - 1)]. There >> should no problem with that since writeback can happen at any >> point in >> time. >> >> * invalidation >> >> It is a bit trickier. here is a pseudo-code: >> invalidate_dcache_range(p,length) >> { >> write_back_invalidate(first line) >> write_back_invalidate(last line) >> invalidate(all other lines) >> } >> >> Here again this should work fine IF invalidate_dcache_range() is >> called >> BEFORE the DMA operation (again the writeback can happen at time so >> it's >> valid do it here). Calling it only AFTER the operation, may corrupt >> the >> data written by the DMA with old data from CPU. This how I used to >> handle unaligned buffers in some other projects. >> >> >> There is however one loophole: a data sitting in the first or the >> last >> line is accessed before the memory is updated by the DMA, then the >> first/line will be corrupted. But it's not highly probable as this >> data >> would have to be used in parallel of the DMA (interrupt handling, >> SMP?, >> dma mgt related variable). So it's not perfect but it would still be >> better than we have today. > Or just fix all the code which complains about unaligned buffers, > done. > That's the way to go without all the complications above. It's not that complex, but it's not perfect. We would need to keep the same warning as we have now, but it would make it work in more cases.
I'm not sure I understand your point. But as I said I'm not pushing. You're not keen to the idea and you're more knowledgeable than I am in u-boot, so be it. I'll drop the subject Thanks for taking time to discuss it.
Jean-Jacques
On 01/16/2017 08:16 PM, Jean-Jacques Hiblot wrote: > On 16/01/2017 17:00, Marek Vasut wrote: >> On 01/16/2017 02:29 PM, Jean-Jacques Hiblot wrote: >>> Tom, Marek >> Hi, >> >>> At the moment, whenever an unaligned address is used in cache >>> operations >>> (invalidate_dcache_range, or flush_dcache_range), the whole >>> request is >>> discarded for am926ejs. for armV7 or armV8 only the aligned >>> part is >>> maintained. This is probably what is causing the bug addressed in >>> 8133f43d1cd. There are a lot of unaligned buffers used in DMA >>> operations >>> and for all of them, we're possibly handling the cached partially >>> or not >>> at all. I've seen this when using the environment from a file >>> stored in >>> a FAT partition. commit 8133f43d1cd addresses this by using a >>> bounce >>> buffer at the FAT level but it's only one of many cases. >>> >>> I think we can do better with unaligned cache operations: >>> >>> * flush (writeback + invalidate): Suppose we use address p >>> which is >>> unaligned, flush_dcache_range() can do the writeback+invalidate >>> on the >>> whole range [p & ~(line_sz - 1); p + length | (line_sz - 1)]. >>> There >>> should no problem with that since writeback can happen at any >>> point in >>> time. >>> >>> * invalidation >>> >>> It is a bit trickier. here is a pseudo-code: >>> invalidate_dcache_range(p,length) >>> { >>> write_back_invalidate(first line) >>> write_back_invalidate(last line) >>> invalidate(all other lines) >>> } >>> >>> Here again this should work fine IF invalidate_dcache_range() is >>> called >>> BEFORE the DMA operation (again the writeback can happen at >>> time so >>> it's >>> valid do it here). Calling it only AFTER the operation, may >>> corrupt >>> the >>> data written by the DMA with old data from CPU. This how I used to >>> handle unaligned buffers in some other projects. >>> >>> >>> There is however one loophole: a data sitting in the first or the >>> last >>> line is accessed before the memory is updated by the DMA, then the >>> first/line will be corrupted. But it's not highly probable as this >>> data >>> would have to be used in parallel of the DMA (interrupt handling, >>> SMP?, >>> dma mgt related variable). So it's not perfect but it would >>> still be >>> better than we have today. >> Or just fix all the code which complains about unaligned buffers, >> done. >> That's the way to go without all the complications above. > It's not that complex, but it's not perfect. We would need to > keep the > same warning as we have now, but it would make it work in more > cases. The warning is there for that exact reason -- to inform you something's wrong.
> Tracking every possible unaligned buffer that gets invalidated is > not a > trivial job. Most of the time the buffer is allocated in a upper > layer > and passed down to a driver via layers like network stack, block > layer > etc.And in many cases, the warning will come and go depending on > how the > variable aligned on the stack or the heap. I didn't observe this much in fact. I usually see the buffers coming it aligned or being allocated in drivers. Also, I think that's why the RC cycle is there, so we can test the next release and fix these issues.
I'm referring to the last paragraph of the commit message, "There is however one loophole..."
Let's wait for what the others have to say maybe ?
Jean-Jacques
On 16/01/2017 20:33, Marek Vasut wrote: > On 01/16/2017 08:16 PM, Jean-Jacques Hiblot wrote: >> On 16/01/2017 17:00, Marek Vasut wrote: >>> On 01/16/2017 02:29 PM, Jean-Jacques Hiblot wrote: >>>> Tom, Marek >>> Hi, >>> >>>> At the moment, whenever an unaligned address is used in cache >>>> operations >>>> (invalidate_dcache_range, or flush_dcache_range), the whole >>>> request is >>>> discarded for am926ejs. for armV7 or armV8 only the aligned >>>> part is >>>> maintained. This is probably what is causing the bug addressed in >>>> 8133f43d1cd. There are a lot of unaligned buffers used in DMA >>>> operations >>>> and for all of them, we're possibly handling the cached partially >>>> or not >>>> at all. I've seen this when using the environment from a file >>>> stored in >>>> a FAT partition. commit 8133f43d1cd addresses this by using a >>>> bounce >>>> buffer at the FAT level but it's only one of many cases. >>>> >>>> I think we can do better with unaligned cache operations: >>>> >>>> * flush (writeback + invalidate): Suppose we use address p >>>> which is >>>> unaligned, flush_dcache_range() can do the writeback+invalidate >>>> on the >>>> whole range [p & ~(line_sz - 1); p + length | (line_sz - 1)]. >>>> There >>>> should no problem with that since writeback can happen at any >>>> point in >>>> time. >>>> >>>> * invalidation >>>> >>>> It is a bit trickier. here is a pseudo-code: >>>> invalidate_dcache_range(p,length) >>>> { >>>> write_back_invalidate(first line) >>>> write_back_invalidate(last line) >>>> invalidate(all other lines) >>>> } >>>> >>>> Here again this should work fine IF invalidate_dcache_range() is >>>> called >>>> BEFORE the DMA operation (again the writeback can happen at >>>> time so >>>> it's >>>> valid do it here). Calling it only AFTER the operation, may >>>> corrupt >>>> the >>>> data written by the DMA with old data from CPU. This how I used to >>>> handle unaligned buffers in some other projects. >>>> >>>> >>>> There is however one loophole: a data sitting in the first or the >>>> last >>>> line is accessed before the memory is updated by the DMA, then the >>>> first/line will be corrupted. But it's not highly probable as this >>>> data >>>> would have to be used in parallel of the DMA (interrupt handling, >>>> SMP?, >>>> dma mgt related variable). So it's not perfect but it would >>>> still be >>>> better than we have today. >>> Or just fix all the code which complains about unaligned buffers, >>> done. >>> That's the way to go without all the complications above. >> It's not that complex, but it's not perfect. We would need to >> keep the >> same warning as we have now, but it would make it work in more >> cases. > The warning is there for that exact reason -- to inform you > something's > wrong. > >> Tracking every possible unaligned buffer that gets invalidated is >> not a >> trivial job. Most of the time the buffer is allocated in a upper >> layer >> and passed down to a driver via layers like network stack, block >> layer >> etc.And in many cases, the warning will come and go depending on >> how the >> variable aligned on the stack or the heap. > I didn't observe this much in fact. I usually see the buffers > coming it > aligned or being allocated in drivers. Also, I think that's why > the RC > cycle is there, so we can test the next release and fix these issues. It's not commonly seen but I came across it some times.
IMHO, a 100% reliable U-Boot is preferable, even if this means less performance. It does not seem like there would be a way of working around this loophole, so I would avoid this cache hack, even if the probability of getting an issue would be small.
Maintaining only the aligned part of DMA buffers for cache operations as Jean-Jacques says is done for armv7/8 is also not perfect. This means that probably at least all the storage-related device drivers on ARM can be affected in some way by unaligned buffers. That would mean a lot of changes to move the buffer bounce mechanism from the FAT layer to the device driver layer. That's why I'd rather move it to the block layer. The architecture/driver combinations requiring it could add a flag or a configuration setting somewhere, so that the performance is not lowered when not needed. It would also only be applied if a misalignment is detected, in which case a debug() message could also be printed.
Best regards, Benoît
On Mon, Jan 16, 2017 at 02:29:21PM +0100, Jean-Jacques Hiblot wrote:
Tom, Marek
My current feeling here is that the main problems here, with respect to buffers not being aligned, is that as we move forward with DM changes we can push this up a level and it will be harder to get this wrong. Patches to fix problems found in the mean time are welcome.
Benoît Thébaudeau
Jean-Jacques Hiblot
