[U-Boot] mxc_i2c: add new i2c subsystem support
Hi Heiko,
The mxc_i2c driver use the legacy framework. I plan to move this driver to new i2c subsystem (CONFIG_SYS_I2C). Is someone already working on this task ?
If no, I propose to only add new i2c subsystem (and not remove old i2c framework). We could remove the mxc i2c legacy support when all the board using this driver will be updated. What do you think about it ?
Regards, Philippe
Hello Philippe,
Am 07.09.2013 09:41, schrieb Philippe Reynes:
Hi Heiko,
Great!
I think not ...
Hmm.. no ... I prefer a patch which port all boards which use this driver to the new framework. It should compiles clean. Just add the board maintainers to cc, so they can test it for you ...
bye, Heiko
Heiko Schocher
Philippe Reynes
