[U-Boot] [PATCH 1/1 V2] add support for mcf5307 cpu
Hi Jason and all,
i am really interested to bring mcf5307 inside u-boot. But still waiting for your feedback/help on my comments below.
Let me know your comments.
Many thanks,
Regards, angelo
Hello Jason and all, i started to work to rewrite the patch.
Starting from mcf532x/cpu.c, i am not sure this is the right place to add MCF5307.
- On "checkcpu", mcf5307 don't have ccm->cir where to read mask/ver.
- About "do_reset", here also mcf5307 don't have MMAP_RCM, memory map and reset \
procedure are different. 3) In general, as memory map, mcf5307 is much more similar \ to some mcf52x2 cpu. This is the reason why i thought to treat it as a separate \ family. Looking here: http://www.freescale.com/webapp/sps/site/taxonomy.jsp?code=68KCFV3 seems Freescale also treat it as the only cpu of the MCF530X family.
I can still go ahead, but cpu.c should have a great #ifdef CONFIG_MCF5307 to handle \ separately this cpu. How do you think i should proceed ?
regards angelo
On 22/08/2011 05:49, Jin Zhengxiong-R64188 wrote:
-----Original Message----- From: Angelo Dureghello [mailto:angelo70@gmail.com] Sent: Friday, August 12, 2011 5:20 AM To: U-Boot@lists.denx.de Cc: Jin Zhengxiong-R64188 Subject: [PATCH 1/1 V2] add support for mcf5307 cpu
Add cpu related files and memory map includes. Apply the related minor changes to general coldfire architecture include files.
Signed-off-by: Angelo Dureghellosysamfw@gmail.com
arch/m68k/cpu/mcf530x/Makefile | 48 +++++++ arch/m68k/cpu/mcf530x/config.mk | 25 ++++ arch/m68k/cpu/mcf530x/cpu.c | 48 +++++++ arch/m68k/cpu/mcf530x/cpu.h | 33 +++++ arch/m68k/cpu/mcf530x/cpu_init.c | 164 +++++++++++++++++++++++ arch/m68k/cpu/mcf530x/interrupts.c | 42 ++++++ arch/m68k/cpu/mcf530x/speed.c | 36 +++++ arch/m68k/cpu/mcf530x/start.S | 253 ++++++++++++++++++++++++++++++++++++ arch/m68k/include/asm/immap_5307.h | 78 +++++++++++ arch/m68k/include/asm/m5307.h | 119 +++++++++++++++++ 10 files changed, 846 insertions(+), 0 deletions(-) create mode 100644 arch/m68k/cpu/mcf530x/Makefile create mode 100644 arch/m68k/cpu/mcf530x/config.mk create mode 100644 arch/m68k/cpu/mcf530x/cpu.c create mode 100644 arch/m68k/cpu/mcf530x/cpu.h create mode 100644 arch/m68k/cpu/mcf530x/cpu_init.c create mode 100644 arch/m68k/cpu/mcf530x/interrupts.c create mode 100644 arch/m68k/cpu/mcf530x/speed.c create mode 100644 arch/m68k/cpu/mcf530x/start.S create mode 100644 arch/m68k/include/asm/immap_5307.h create mode 100644 arch/m68k/include/asm/m5307.h
[Jin Zhengxiong-R64188] Could you please try to merge the 5307 cpu to mcf532x as we already have two ColdFire V3 boards here(We can try to rename the mcf532x to such \ as mcf53xx later for less confuse). You can keep the immap_5307.h and m5307.h for the 5307 cpu. All the other files are similar with the files for the two V3 \ boards except the cpu_init.c file.
Thanks.
Jason
-----Original Message----- From: angelo [mailto:angelo70@gmail.com] Sent: Friday, September 02, 2011 7:41 PM To: Jin Zhengxiong-R64188 Cc: U-Boot@lists.denx.de Subject: [U-Boot] [PATCH 1/1 V2] add support for mcf5307 cpu
Hi Jason and all,
Many thanks,
Hi, angelo,
Could you please try as seperate MCF530X family but send out the complete patchset? You previous patch seems only include the new files. Thanks.
Regards, Jason
Regards, angelo
MCF5307.
map and reset \ procedure are different. 3) In general, as memory map, mcf5307 is much more similar \ to some mcf52x2 cpu. This is the reason why i thought to treat it as a separate \ family. Looking here: http://www.freescale.com/webapp/sps/site/taxonomy.jsp?code=68KCFV3 seems Freescale also treat it as the only cpu of the MCF530X family.
proceed ?
regards angelo
-----Original Message----- From: Angelo Dureghello [mailto:angelo70@gmail.com] > Sent:
Friday, August 12, 2011 5:20 AM > To: U-Boot@lists.denx.de > Cc: Jin Zhengxiong-R64188 > Subject: [PATCH 1/1 V2] add support for mcf5307 cpu > > Add cpu related files and memory map includes. Apply the related > minor changes to general coldfire architecture include files.
Signed-off-by: Angelo Dureghellosysamfw@gmail.com > --- arch/m68k/cpu/mcf530x/Makefile | 48 +++++++ arch/m68k/cpu/mcf530x/config.mk | 25 ++++ arch/m68k/cpu/mcf530x/cpu.c | 48 +++++++ arch/m68k/cpu/mcf530x/cpu.h | 33 +++++ arch/m68k/cpu/mcf530x/cpu_init.c | 164 +++++++++++++++++++++++ arch/m68k/cpu/mcf530x/interrupts.c | 42 ++++++ arch/m68k/cpu/mcf530x/speed.c | 36 +++++ arch/m68k/cpu/mcf530x/start.S | 253
arch/m68k/include/asm/immap_5307.h | 78 +++++++++++ arch/m68k/include/asm/m5307.h | 119 +++++++++++++++++ 10 files changed, 846 insertions(+), 0 deletions(-) > create
mode 100644 arch/m68k/cpu/mcf530x/Makefile > create mode 100644 arch/m68k/cpu/mcf530x/config.mk > create mode 100644 arch/m68k/cpu/mcf530x/cpu.c > create mode 100644 arch/m68k/cpu/mcf530x/cpu.h > create mode 100644 arch/m68k/cpu/mcf530x/cpu_init.c > create mode 100644 arch/m68k/cpu/mcf530x/interrupts.c
create mode 100644 arch/m68k/cpu/mcf530x/speed.c > create mode
100644 arch/m68k/cpu/mcf530x/start.S > create mode 100644 arch/m68k/include/asm/immap_5307.h
cpu_init.c file.
Thanks.
Jason
angelo
