[U-Boot] [PATCH] arm: sunxi: Add icnova-a20-swac defconfig
The ICnova-A20-SWAC is a baseboard, equipped with the ICnova-A20 SoM from In-Circuit:
http://wiki.in-circuit.de/index.php5?title=ICnova_A20_SODIMM http://linux-sunxi.org/In-Circuit_ICnova_A20
This patch adds support for this board, including ethernet, LCD and USB support.
Signed-off-by: Stefan Roese sr@denx.de Cc: Marcus Heuer marcus.heuer@swac.de Cc: Hans de Goede hdegoede@redhat.com Cc: Ian Campbell ijc@hellion.org.uk --- board/sunxi/MAINTAINERS | 5 +++++ configs/icnova-a20-swac_defconfig | 21 +++++++++++++++++++++ 2 files changed, 26 insertions(+) create mode 100644 configs/icnova-a20-swac_defconfig
diff --git a/board/sunxi/MAINTAINERS b/board/sunxi/MAINTAINERS index 5ae5ce6..c4fe11f 100644 --- a/board/sunxi/MAINTAINERS +++ b/board/sunxi/MAINTAINERS @@ -121,6 +121,11 @@ M: Chen-Yu Tsai wens@csie.org S: Maintained F: configs/Hummingbird_A31_defconfig
+ICnova-A20-SWAC BOARD +M: Stefan Roese sr@denx.de +S: Maintained +F: configs/icnova-a20-swac_defconfig + ITEAD IBOX BOARD M: Marcus Cooper codekipper@gmail.com S: Maintained diff --git a/configs/icnova-a20-swac_defconfig b/configs/icnova-a20-swac_defconfig new file mode 100644 index 0000000..548a07e --- /dev/null +++ b/configs/icnova-a20-swac_defconfig @@ -0,0 +1,21 @@ +CONFIG_ARM=y +CONFIG_ARCH_SUNXI=y +CONFIG_MACH_SUN7I=y +CONFIG_DRAM_CLK=384 +CONFIG_OLD_SUNXI_KERNEL_COMPAT=y +CONFIG_MMC0_CD_PIN="PI5" +CONFIG_USB0_VBUS_PIN="PG11" +CONFIG_USB0_VBUS_DET="PH7" +CONFIG_USB1_VBUS_PIN="PG10" +CONFIG_VIDEO_LCD_MODE="x:800,y:480,depth:24,pclk_khz:33000,le:45,ri:209,up:22,lo:22,hs:1,vs:1,sync:3,vmode:0" +CONFIG_VIDEO_LCD_POWER="PH22" +CONFIG_VIDEO_LCD_PANEL_LVDS=y +CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-icnova-swac" +# CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SPL=y +CONFIG_SYS_EXTRA_OPTIONS="AXP209_POWER,SUNXI_GMAC,CMD_BMP,CMD_UNZIP" +# CONFIG_CMD_IMLS is not set +# CONFIG_CMD_FLASH is not set +# CONFIG_CMD_FPGA is not set +CONFIG_ETH_DESIGNWARE=y +CONFIG_USB_EHCI_HCD=y
Thanks, applied.
Regards,
Hans
- ITEAD IBOX BOARD M: Marcus Cooper codekipper@gmail.com S: Maintained
Hans de Goede
Stefan Roese
