[U-Boot] [PATCH] fix compile error on macOS Mojave
--- Makefile | 7 +++++++ lib/bch.c | 9 ++++++++- 2 files changed, 15 insertions(+), 1 deletion(-)
diff --git a/Makefile b/Makefile index c1af9307b3..92e04dd689 100644 --- a/Makefile +++ b/Makefile @@ -291,6 +291,9 @@ DARWIN_MINOR_VERSION = $(shell sw_vers -productVersion | cut -f 2 -d '.') os_x_before = $(shell if [ $(DARWIN_MAJOR_VERSION) -le $(1) -a \ $(DARWIN_MINOR_VERSION) -le $(2) ] ; then echo "$(3)"; else echo "$(4)"; fi ;)
+os_x_after = $(shell if [ $(DARWIN_MAJOR_VERSION) -ge $(1) -a \ + $(DARWIN_MINOR_VERSION) -ge $(2) ] ; then echo "$(3)"; else echo "$(4)"; fi ;) + # Snow Leopards build environment has no longer restrictions as described above HOSTCC = $(call os_x_before, 10, 5, "cc", "gcc") HOSTCFLAGS += $(call os_x_before, 10, 4, "-traditional-cpp") @@ -300,6 +303,10 @@ HOSTLDFLAGS += $(call os_x_before, 10, 5, "-multiply_defined suppress") # in some host tools which is a problem then ... so disable ASLR for these # tools HOSTLDFLAGS += $(call os_x_before, 10, 7, "", "-Xlinker -no_pie") + +# macOS Mojave (10.14.X) +# Undefined symbols for architecture x86_64: "_PyArg_ParseTuple" +HOSTLDFLAGS += $(call os_x_after, 10, 14, "-lpython -dynamclib", "") endif
# Decide whether to build built-in, modular, or both. diff --git a/lib/bch.c b/lib/bch.c index 20079eb9eb..c4fac77d61 100644 --- a/lib/bch.c +++ b/lib/bch.c @@ -62,6 +62,9 @@ #include <errno.h> #if defined(__FreeBSD__) #include <sys/endian.h> +#elif defined(__APPLE__) +#include <machine/endian.h> +#include <libkern/OSByteOrder.h> #else #include <endian.h> #endif @@ -70,7 +73,11 @@ #include <string.h>
#undef cpu_to_be32 +#if defined(__APPLE__) +#define cpu_to_be32 OSSwapHostToBigInt32 +#else #define cpu_to_be32 htobe32 +#endif #define DIV_ROUND_UP(n,d) (((n) + (d) - 1) / (d)) #define kmalloc(size, flags) malloc(size) #define kzalloc(size, flags) calloc(1, size) @@ -116,7 +123,7 @@ struct gf_poly_deg1 { };
#ifdef USE_HOSTCC -#if !defined(__DragonFly__) && !defined(__FreeBSD__) +#if !defined(__DragonFly__) && !defined(__FreeBSD__) && !defined(__APPLE__) static int fls(int x) { int r = 32;
On Sun, Mar 31, 2019 at 04:07:03PM +0800, wangqiang1588@sina.com wrote:
