[U-Boot] [PATCH] cmd: cros_ec: Move crosec commands to cmd subdirectory
Move crosec commands from drivers/misc/cros_ec.c to cmd/cros_ec.c
Signed-off-by: Moritz Fischer moritz.fischer@ettus.com Cc: Simon Glass sjg@chromium.org Cc: Heiko Schocher hs@denx.de Cc: Bin Meng bmeng.cn@gmail.com Cc: Miao Yan yanmiaobest@gmail.com Cc: Masahiro Yamada yamada.masahiro@socionext.com Cc: Stefan Roese sr@denx.de Cc: Przemyslaw Marczak p.marczak@samsung.com Cc: Maxime Ripard maxime.ripard@free-electrons.com Cc: Nishanth Menon nm@ti.com Cc: u-boot@lists.denx.de --- cmd/Kconfig | 12 ++ cmd/Makefile | 1 + cmd/cros_ec.c | 366 +++++++++++++++++++++++++++++++++++++++++++++++++ drivers/misc/cros_ec.c | 348 ---------------------------------------------- include/cros_ec.h | 11 ++ 5 files changed, 390 insertions(+), 348 deletions(-) create mode 100644 cmd/cros_ec.c
diff --git a/cmd/Kconfig b/cmd/Kconfig index 86554ea..141281f 100644 --- a/cmd/Kconfig +++ b/cmd/Kconfig @@ -677,6 +677,18 @@ config CMD_TPM_TEST
endmenu
+menu "Firmware commands" +config CMD_CROS_EC + bool "Enable crosec command" + depends on CROS_EC + help + Enable command-line access to the Chrome OS EC (Embedded + Controller). This provides the 'crosec' command which has + a number of sub-commands for performing EC tasks such as + updating its flash, accessing a small saved context area + and talking to the I2C bus behind the EC (if there is one). +endmenu + menu "Filesystem commands" config CMD_EXT2 bool "ext2 command support" diff --git a/cmd/Makefile b/cmd/Makefile index 81b98ee..9c9a9d1 100644 --- a/cmd/Makefile +++ b/cmd/Makefile @@ -128,6 +128,7 @@ obj-$(CONFIG_CMD_TRACE) += trace.o obj-$(CONFIG_HUSH_PARSER) += test.o obj-$(CONFIG_CMD_TPM) += tpm.o obj-$(CONFIG_CMD_TPM_TEST) += tpm_test.o +obj-$(CONFIG_CMD_CROS_EC) += cros_ec.o obj-$(CONFIG_CMD_TSI148) += tsi148.o obj-$(CONFIG_CMD_UBI) += ubi.o obj-$(CONFIG_CMD_UBIFS) += ubifs.o diff --git a/cmd/cros_ec.c b/cmd/cros_ec.c new file mode 100644 index 0000000..543dd28 --- /dev/null +++ b/cmd/cros_ec.c @@ -0,0 +1,366 @@ +/* + * Chromium OS cros_ec driver + * + * Copyright (c) 2016 The Chromium OS Authors. + * Copyright (c) 2016 National Instruments Corp + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <command.h> +#include <cros_ec.h> +#include <dm.h> +#include <dm/device-internal.h> +#include <dm/uclass-internal.h> + +/* Note: depends on enum ec_current_image */ +static const char * const ec_current_image_name[] = {"unknown", "RO", "RW"}; + +DECLARE_GLOBAL_DATA_PTR; + +/** + * Perform a flash read or write command + * + * @param dev CROS-EC device to read/write + * @param is_write 1 do to a write, 0 to do a read + * @param argc Number of arguments + * @param argv Arguments (2 is region, 3 is address) + * @return 0 for ok, 1 for a usage error or -ve for ec command error + * (negative EC_RES_...) + */ +static int do_read_write(struct cros_ec_dev *dev, int is_write, int argc, + char * const argv[]) +{ + uint32_t offset, size = -1U, region_size; + unsigned long addr; + char *endp; + int region; + int ret; + + region = cros_ec_decode_region(argc - 2, argv + 2); + if (region == -1) + return 1; + if (argc < 4) + return 1; + addr = simple_strtoul(argv[3], &endp, 16); + if (*argv[3] == 0 || *endp != 0) + return 1; + if (argc > 4) { + size = simple_strtoul(argv[4], &endp, 16); + if (*argv[4] == 0 || *endp != 0) + return 1; + } + + ret = cros_ec_flash_offset(dev, region, &offset, ®ion_size); + if (ret) { + debug("%s: Could not read region info\n", __func__); + return ret; + } + if (size == -1U) + size = region_size; + + ret = is_write ? + cros_ec_flash_write(dev, (uint8_t *)addr, offset, size) : + cros_ec_flash_read(dev, (uint8_t *)addr, offset, size); + if (ret) { + debug("%s: Could not %s region\n", __func__, + is_write ? "write" : "read"); + return ret; + } + + return 0; +} + +static int do_cros_ec(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) +{ + struct cros_ec_dev *dev; + struct udevice *udev; + const char *cmd; + int ret = 0; + + if (argc < 2) + return CMD_RET_USAGE; + + cmd = argv[1]; + if (0 == strcmp("init", cmd)) { + /* Remove any existing device */ + ret = uclass_find_device(UCLASS_CROS_EC, 0, &udev); + if (!ret) + device_remove(udev); + ret = uclass_get_device(UCLASS_CROS_EC, 0, &udev); + if (ret) { + printf("Could not init cros_ec device (err %d)\n", ret); + return 1; + } + return 0; + } + + ret = uclass_get_device(UCLASS_CROS_EC, 0, &udev); + if (ret) { + printf("Cannot get cros-ec device (err=%d)\n", ret); + return 1; + } + dev = dev_get_uclass_priv(udev); + if (0 == strcmp("id", cmd)) { + char id[MSG_BYTES]; + + if (cros_ec_read_id(dev, id, sizeof(id))) { + debug("%s: Could not read KBC ID\n", __func__); + return 1; + } + printf("%s\n", id); + } else if (0 == strcmp("info", cmd)) { + struct ec_response_mkbp_info info; + + if (cros_ec_info(dev, &info)) { + debug("%s: Could not read KBC info\n", __func__); + return 1; + } + printf("rows = %u\n", info.rows); + printf("cols = %u\n", info.cols); + printf("switches = %#x\n", info.switches); + } else if (0 == strcmp("curimage", cmd)) { + enum ec_current_image image; + + if (cros_ec_read_current_image(dev, &image)) { + debug("%s: Could not read KBC image\n", __func__); + return 1; + } + printf("%d\n", image); + } else if (0 == strcmp("hash", cmd)) { + struct ec_response_vboot_hash hash; + int i; + + if (cros_ec_read_hash(dev, &hash)) { + debug("%s: Could not read KBC hash\n", __func__); + return 1; + } + + if (hash.hash_type == EC_VBOOT_HASH_TYPE_SHA256) + printf("type: SHA-256\n"); + else + printf("type: %d\n", hash.hash_type); + + printf("offset: 0x%08x\n", hash.offset); + printf("size: 0x%08x\n", hash.size); + + printf("digest: "); + for (i = 0; i < hash.digest_size; i++) + printf("%02x", hash.hash_digest[i]); + printf("\n"); + } else if (0 == strcmp("reboot", cmd)) { + int region; + enum ec_reboot_cmd cmd; + + if (argc >= 3 && !strcmp(argv[2], "cold")) { + cmd = EC_REBOOT_COLD; + } else { + region = cros_ec_decode_region(argc - 2, argv + 2); + if (region == EC_FLASH_REGION_RO) + cmd = EC_REBOOT_JUMP_RO; + else if (region == EC_FLASH_REGION_RW) + cmd = EC_REBOOT_JUMP_RW; + else + return CMD_RET_USAGE; + } + + if (cros_ec_reboot(dev, cmd, 0)) { + debug("%s: Could not reboot KBC\n", __func__); + return 1; + } + } else if (0 == strcmp("events", cmd)) { + uint32_t events; + + if (cros_ec_get_host_events(dev, &events)) { + debug("%s: Could not read host events\n", __func__); + return 1; + } + printf("0x%08x\n", events); + } else if (0 == strcmp("clrevents", cmd)) { + uint32_t events = 0x7fffffff; + + if (argc >= 3) + events = simple_strtol(argv[2], NULL, 0); + + if (cros_ec_clear_host_events(dev, events)) { + debug("%s: Could not clear host events\n", __func__); + return 1; + } + } else if (0 == strcmp("read", cmd)) { + ret = do_read_write(dev, 0, argc, argv); + if (ret > 0) + return CMD_RET_USAGE; + } else if (0 == strcmp("write", cmd)) { + ret = do_read_write(dev, 1, argc, argv); + if (ret > 0) + return CMD_RET_USAGE; + } else if (0 == strcmp("erase", cmd)) { + int region = cros_ec_decode_region(argc - 2, argv + 2); + uint32_t offset, size; + + if (region == -1) + return CMD_RET_USAGE; + if (cros_ec_flash_offset(dev, region, &offset, &size)) { + debug("%s: Could not read region info\n", __func__); + ret = -1; + } else { + ret = cros_ec_flash_erase(dev, offset, size); + if (ret) { + debug("%s: Could not erase region\n", + __func__); + } + } + } else if (0 == strcmp("regioninfo", cmd)) { + int region = cros_ec_decode_region(argc - 2, argv + 2); + uint32_t offset, size; + + if (region == -1) + return CMD_RET_USAGE; + ret = cros_ec_flash_offset(dev, region, &offset, &size); + if (ret) { + debug("%s: Could not read region info\n", __func__); + } else { + printf("Region: %s\n", region == EC_FLASH_REGION_RO ? + "RO" : "RW"); + printf("Offset: %x\n", offset); + printf("Size: %x\n", size); + } + } else if (0 == strcmp("flashinfo", cmd)) { + struct ec_response_flash_info p; + + ret = cros_ec_read_flashinfo(dev, &p); + if (!ret) { + printf("Flash size: %u\n", p.flash_size); + printf("Write block size: %u\n", p.write_block_size); + printf("Erase block size: %u\n", p.erase_block_size); + } + } else if (0 == strcmp("vbnvcontext", cmd)) { + uint8_t block[EC_VBNV_BLOCK_SIZE]; + char buf[3]; + int i, len; + unsigned long result; + + if (argc <= 2) { + ret = cros_ec_read_vbnvcontext(dev, block); + if (!ret) { + printf("vbnv_block: "); + for (i = 0; i < EC_VBNV_BLOCK_SIZE; i++) + printf("%02x", block[i]); + putc('\n'); + } + } else { + /* + * TODO(clchiou): Move this to a utility function as + * cmd_spi might want to call it. + */ + memset(block, 0, EC_VBNV_BLOCK_SIZE); + len = strlen(argv[2]); + buf[2] = '\0'; + for (i = 0; i < EC_VBNV_BLOCK_SIZE; i++) { + if (i * 2 >= len) + break; + buf[0] = argv[2][i * 2]; + if (i * 2 + 1 >= len) + buf[1] = '0'; + else + buf[1] = argv[2][i * 2 + 1]; + strict_strtoul(buf, 16, &result); + block[i] = result; + } + ret = cros_ec_write_vbnvcontext(dev, block); + } + if (ret) { + debug("%s: Could not %s VbNvContext\n", __func__, + argc <= 2 ? "read" : "write"); + } + } else if (0 == strcmp("test", cmd)) { + int result = cros_ec_test(dev); + + if (result) + printf("Test failed with error %d\n", result); + else + puts("Test passed\n"); + } else if (0 == strcmp("version", cmd)) { + struct ec_response_get_version *p; + char *build_string; + + ret = cros_ec_read_version(dev, &p); + if (!ret) { + /* Print versions */ + printf("RO version: %1.*s\n", + (int)sizeof(p->version_string_ro), + p->version_string_ro); + printf("RW version: %1.*s\n", + (int)sizeof(p->version_string_rw), + p->version_string_rw); + printf("Firmware copy: %s\n", + (p->current_image < + ARRAY_SIZE(ec_current_image_name) ? + ec_current_image_name[p->current_image] : + "?")); + ret = cros_ec_read_build_info(dev, &build_string); + if (!ret) + printf("Build info: %s\n", build_string); + } + } else if (0 == strcmp("ldo", cmd)) { + uint8_t index, state; + char *endp; + + if (argc < 3) + return CMD_RET_USAGE; + index = simple_strtoul(argv[2], &endp, 10); + if (*argv[2] == 0 || *endp != 0) + return CMD_RET_USAGE; + if (argc > 3) { + state = simple_strtoul(argv[3], &endp, 10); + if (*argv[3] == 0 || *endp != 0) + return CMD_RET_USAGE; + ret = cros_ec_set_ldo(udev, index, state); + } else { + ret = cros_ec_get_ldo(udev, index, &state); + if (!ret) { + printf("LDO%d: %s\n", index, + state == EC_LDO_STATE_ON ? + "on" : "off"); + } + } + + if (ret) { + debug("%s: Could not access LDO%d\n", __func__, index); + return ret; + } + } else { + return CMD_RET_USAGE; + } + + if (ret < 0) { + printf("Error: CROS-EC command failed (error %d)\n", ret); + ret = 1; + } + + return ret; +} + +U_BOOT_CMD( + crosec, 6, 1, do_cros_ec, + "CROS-EC utility command", + "init Re-init CROS-EC (done on startup automatically)\n" + "crosec id Read CROS-EC ID\n" + "crosec info Read CROS-EC info\n" + "crosec curimage Read CROS-EC current image\n" + "crosec hash Read CROS-EC hash\n" + "crosec reboot [rw | ro | cold] Reboot CROS-EC\n" + "crosec events Read CROS-EC host events\n" + "crosec clrevents [mask] Clear CROS-EC host events\n" + "crosec regioninfo <ro|rw> Read image info\n" + "crosec flashinfo Read flash info\n" + "crosec erase <ro|rw> Erase EC image\n" + "crosec read <ro|rw> <addr> [<size>] Read EC image\n" + "crosec write <ro|rw> <addr> [<size>] Write EC image\n" + "crosec vbnvcontext [hexstring] Read [write] VbNvContext from EC\n" + "crosec ldo <idx> [<state>] Switch/Read LDO state\n" + "crosec test run tests on cros_ec\n" + "crosec version Read CROS-EC version" +); + diff --git a/drivers/misc/cros_ec.c b/drivers/misc/cros_ec.c index f4dd426..75ba603 100644 --- a/drivers/misc/cros_ec.c +++ b/drivers/misc/cros_ec.c @@ -1174,354 +1174,6 @@ int cros_ec_i2c_tunnel(struct udevice *dev, int port, struct i2c_msg *in, return 0; }
-#ifdef CONFIG_CMD_CROS_EC - -/** - * Perform a flash read or write command - * - * @param dev CROS-EC device to read/write - * @param is_write 1 do to a write, 0 to do a read - * @param argc Number of arguments - * @param argv Arguments (2 is region, 3 is address) - * @return 0 for ok, 1 for a usage error or -ve for ec command error - * (negative EC_RES_...) - */ -static int do_read_write(struct cros_ec_dev *dev, int is_write, int argc, - char * const argv[]) -{ - uint32_t offset, size = -1U, region_size; - unsigned long addr; - char *endp; - int region; - int ret; - - region = cros_ec_decode_region(argc - 2, argv + 2); - if (region == -1) - return 1; - if (argc < 4) - return 1; - addr = simple_strtoul(argv[3], &endp, 16); - if (*argv[3] == 0 || *endp != 0) - return 1; - if (argc > 4) { - size = simple_strtoul(argv[4], &endp, 16); - if (*argv[4] == 0 || *endp != 0) - return 1; - } - - ret = cros_ec_flash_offset(dev, region, &offset, ®ion_size); - if (ret) { - debug("%s: Could not read region info\n", __func__); - return ret; - } - if (size == -1U) - size = region_size; - - ret = is_write ? - cros_ec_flash_write(dev, (uint8_t *)addr, offset, size) : - cros_ec_flash_read(dev, (uint8_t *)addr, offset, size); - if (ret) { - debug("%s: Could not %s region\n", __func__, - is_write ? "write" : "read"); - return ret; - } - - return 0; -} - -static int do_cros_ec(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) -{ - struct cros_ec_dev *dev; - struct udevice *udev; - const char *cmd; - int ret = 0; - - if (argc < 2) - return CMD_RET_USAGE; - - cmd = argv[1]; - if (0 == strcmp("init", cmd)) { - /* Remove any existing device */ - ret = uclass_find_device(UCLASS_CROS_EC, 0, &udev); - if (!ret) - device_remove(udev); - ret = uclass_get_device(UCLASS_CROS_EC, 0, &udev); - if (ret) { - printf("Could not init cros_ec device (err %d)\n", ret); - return 1; - } - return 0; - } - - ret = uclass_get_device(UCLASS_CROS_EC, 0, &udev); - if (ret) { - printf("Cannot get cros-ec device (err=%d)\n", ret); - return 1; - } - dev = dev_get_uclass_priv(udev); - if (0 == strcmp("id", cmd)) { - char id[MSG_BYTES]; - - if (cros_ec_read_id(dev, id, sizeof(id))) { - debug("%s: Could not read KBC ID\n", __func__); - return 1; - } - printf("%s\n", id); - } else if (0 == strcmp("info", cmd)) { - struct ec_response_mkbp_info info; - - if (cros_ec_info(dev, &info)) { - debug("%s: Could not read KBC info\n", __func__); - return 1; - } - printf("rows = %u\n", info.rows); - printf("cols = %u\n", info.cols); - printf("switches = %#x\n", info.switches); - } else if (0 == strcmp("curimage", cmd)) { - enum ec_current_image image; - - if (cros_ec_read_current_image(dev, &image)) { - debug("%s: Could not read KBC image\n", __func__); - return 1; - } - printf("%d\n", image); - } else if (0 == strcmp("hash", cmd)) { - struct ec_response_vboot_hash hash; - int i; - - if (cros_ec_read_hash(dev, &hash)) { - debug("%s: Could not read KBC hash\n", __func__); - return 1; - } - - if (hash.hash_type == EC_VBOOT_HASH_TYPE_SHA256) - printf("type: SHA-256\n"); - else - printf("type: %d\n", hash.hash_type); - - printf("offset: 0x%08x\n", hash.offset); - printf("size: 0x%08x\n", hash.size); - - printf("digest: "); - for (i = 0; i < hash.digest_size; i++) - printf("%02x", hash.hash_digest[i]); - printf("\n"); - } else if (0 == strcmp("reboot", cmd)) { - int region; - enum ec_reboot_cmd cmd; - - if (argc >= 3 && !strcmp(argv[2], "cold")) - cmd = EC_REBOOT_COLD; - else { - region = cros_ec_decode_region(argc - 2, argv + 2); - if (region == EC_FLASH_REGION_RO) - cmd = EC_REBOOT_JUMP_RO; - else if (region == EC_FLASH_REGION_RW) - cmd = EC_REBOOT_JUMP_RW; - else - return CMD_RET_USAGE; - } - - if (cros_ec_reboot(dev, cmd, 0)) { - debug("%s: Could not reboot KBC\n", __func__); - return 1; - } - } else if (0 == strcmp("events", cmd)) { - uint32_t events; - - if (cros_ec_get_host_events(dev, &events)) { - debug("%s: Could not read host events\n", __func__); - return 1; - } - printf("0x%08x\n", events); - } else if (0 == strcmp("clrevents", cmd)) { - uint32_t events = 0x7fffffff; - - if (argc >= 3) - events = simple_strtol(argv[2], NULL, 0); - - if (cros_ec_clear_host_events(dev, events)) { - debug("%s: Could not clear host events\n", __func__); - return 1; - } - } else if (0 == strcmp("read", cmd)) { - ret = do_read_write(dev, 0, argc, argv); - if (ret > 0) - return CMD_RET_USAGE; - } else if (0 == strcmp("write", cmd)) { - ret = do_read_write(dev, 1, argc, argv); - if (ret > 0) - return CMD_RET_USAGE; - } else if (0 == strcmp("erase", cmd)) { - int region = cros_ec_decode_region(argc - 2, argv + 2); - uint32_t offset, size; - - if (region == -1) - return CMD_RET_USAGE; - if (cros_ec_flash_offset(dev, region, &offset, &size)) { - debug("%s: Could not read region info\n", __func__); - ret = -1; - } else { - ret = cros_ec_flash_erase(dev, offset, size); - if (ret) { - debug("%s: Could not erase region\n", - __func__); - } - } - } else if (0 == strcmp("regioninfo", cmd)) { - int region = cros_ec_decode_region(argc - 2, argv + 2); - uint32_t offset, size; - - if (region == -1) - return CMD_RET_USAGE; - ret = cros_ec_flash_offset(dev, region, &offset, &size); - if (ret) { - debug("%s: Could not read region info\n", __func__); - } else { - printf("Region: %s\n", region == EC_FLASH_REGION_RO ? - "RO" : "RW"); - printf("Offset: %x\n", offset); - printf("Size: %x\n", size); - } - } else if (0 == strcmp("flashinfo", cmd)) { - struct ec_response_flash_info p; - - ret = cros_ec_read_flashinfo(dev, &p); - if (!ret) { - printf("Flash size: %u\n", p.flash_size); - printf("Write block size: %u\n", p.write_block_size); - printf("Erase block size: %u\n", p.erase_block_size); - } - } else if (0 == strcmp("vbnvcontext", cmd)) { - uint8_t block[EC_VBNV_BLOCK_SIZE]; - char buf[3]; - int i, len; - unsigned long result; - - if (argc <= 2) { - ret = cros_ec_read_vbnvcontext(dev, block); - if (!ret) { - printf("vbnv_block: "); - for (i = 0; i < EC_VBNV_BLOCK_SIZE; i++) - printf("%02x", block[i]); - putc('\n'); - } - } else { - /* - * TODO(clchiou): Move this to a utility function as - * cmd_spi might want to call it. - */ - memset(block, 0, EC_VBNV_BLOCK_SIZE); - len = strlen(argv[2]); - buf[2] = '\0'; - for (i = 0; i < EC_VBNV_BLOCK_SIZE; i++) { - if (i * 2 >= len) - break; - buf[0] = argv[2][i * 2]; - if (i * 2 + 1 >= len) - buf[1] = '0'; - else - buf[1] = argv[2][i * 2 + 1]; - strict_strtoul(buf, 16, &result); - block[i] = result; - } - ret = cros_ec_write_vbnvcontext(dev, block); - } - if (ret) { - debug("%s: Could not %s VbNvContext\n", __func__, - argc <= 2 ? "read" : "write"); - } - } else if (0 == strcmp("test", cmd)) { - int result = cros_ec_test(dev); - - if (result) - printf("Test failed with error %d\n", result); - else - puts("Test passed\n"); - } else if (0 == strcmp("version", cmd)) { - struct ec_response_get_version *p; - char *build_string; - - ret = cros_ec_read_version(dev, &p); - if (!ret) { - /* Print versions */ - printf("RO version: %1.*s\n", - (int)sizeof(p->version_string_ro), - p->version_string_ro); - printf("RW version: %1.*s\n", - (int)sizeof(p->version_string_rw), - p->version_string_rw); - printf("Firmware copy: %s\n", - (p->current_image < - ARRAY_SIZE(ec_current_image_name) ? - ec_current_image_name[p->current_image] : - "?")); - ret = cros_ec_read_build_info(dev, &build_string); - if (!ret) - printf("Build info: %s\n", build_string); - } - } else if (0 == strcmp("ldo", cmd)) { - uint8_t index, state; - char *endp; - - if (argc < 3) - return CMD_RET_USAGE; - index = simple_strtoul(argv[2], &endp, 10); - if (*argv[2] == 0 || *endp != 0) - return CMD_RET_USAGE; - if (argc > 3) { - state = simple_strtoul(argv[3], &endp, 10); - if (*argv[3] == 0 || *endp != 0) - return CMD_RET_USAGE; - ret = cros_ec_set_ldo(udev, index, state); - } else { - ret = cros_ec_get_ldo(udev, index, &state); - if (!ret) { - printf("LDO%d: %s\n", index, - state == EC_LDO_STATE_ON ? - "on" : "off"); - } - } - - if (ret) { - debug("%s: Could not access LDO%d\n", __func__, index); - return ret; - } - } else { - return CMD_RET_USAGE; - } - - if (ret < 0) { - printf("Error: CROS-EC command failed (error %d)\n", ret); - ret = 1; - } - - return ret; -} - -U_BOOT_CMD( - crosec, 6, 1, do_cros_ec, - "CROS-EC utility command", - "init Re-init CROS-EC (done on startup automatically)\n" - "crosec id Read CROS-EC ID\n" - "crosec info Read CROS-EC info\n" - "crosec curimage Read CROS-EC current image\n" - "crosec hash Read CROS-EC hash\n" - "crosec reboot [rw | ro | cold] Reboot CROS-EC\n" - "crosec events Read CROS-EC host events\n" - "crosec clrevents [mask] Clear CROS-EC host events\n" - "crosec regioninfo <ro|rw> Read image info\n" - "crosec flashinfo Read flash info\n" - "crosec erase <ro|rw> Erase EC image\n" - "crosec read <ro|rw> <addr> [<size>] Read EC image\n" - "crosec write <ro|rw> <addr> [<size>] Write EC image\n" - "crosec vbnvcontext [hexstring] Read [write] VbNvContext from EC\n" - "crosec ldo <idx> [<state>] Switch/Read LDO state\n" - "crosec test run tests on cros_ec\n" - "crosec version Read CROS-EC version" -); -#endif - UCLASS_DRIVER(cros_ec) = { .id = UCLASS_CROS_EC, .name = "cros_ec", diff --git a/include/cros_ec.h b/include/cros_ec.h index 30b1908..ec7517c 100644 --- a/include/cros_ec.h +++ b/include/cros_ec.h @@ -281,6 +281,17 @@ int cros_ec_flash_read(struct cros_ec_dev *dev, uint8_t *data, uint32_t offset, uint32_t size);
/** + * Read back flash parameters + * + * This function reads back parameters of the flash as reported by the EC + * + * @param dev Pointer to device + * @param info Pointer to output flash info struct + */ +int cros_ec_read_flashinfo(struct cros_ec_dev *dev, + struct ec_response_flash_info *info); + +/** * Write data to the flash * * Write an arbitrary amount of data to the EC flash, by repeatedly writing
Hi Moritz,
But please see below.
endmenu
depends on CROS_EC
Can this be enabled by default if CROS_EC is enabled? At present I think your change will disable it.
e.g.
default y
help
+endmenu
Hi Simon,
depends on CROS_EC
Will send a v2 in a bit. Thanks for the review
Moritz
Moritz Fischer
