[U-Boot] [PATCH] ADS5121: Fix NOR and CPLD ALE timing for rev 2 silicon
MPC5121 rev 2 silicon has a new register for controlling how long CS is asserted after deassertion of ALE in multiplexed mode.
The default is to assert CS together with ALE. The alternative is to assert CS (ALEN+1)*LPC_CLK clocks after deassertion of ALE.
The default is wrong for the NOR flash and CPLD on the ADS5121.
This patch turns on the alternative for CS0 (NOR) and CS2 (CPLD) it does so conditionally based on silicon rev 2.0 or greater.
Signed-off-by: Martha J Marx mmarx@silicontkx.com Signed-off-by: John Rigby jrigby@freescale.com --- board/ads5121/ads5121.c | 4 ++++ include/configs/ads5121.h | 1 + include/mpc512x.h | 1 + 3 files changed, 6 insertions(+), 0 deletions(-)
diff --git a/board/ads5121/ads5121.c b/board/ads5121/ads5121.c index ba3d7d2..9acf56b 100644 --- a/board/ads5121/ads5121.c +++ b/board/ads5121/ads5121.c @@ -25,6 +25,7 @@ #include <mpc512x.h> #include <asm/bitops.h> #include <command.h> +#include <asm/processor.h> #include <fdt_support.h> #ifdef CONFIG_MISC_INIT_R #include <i2c.h> @@ -92,6 +93,9 @@ int board_early_init_f (void) * Configure Flash Speed */ *((volatile u32 *)(CFG_IMMR + LPC_OFFSET + CS0_CONFIG)) = CFG_CS0_CFG; + if (SVR_MJREV (im->sysconf.spridr)>=2) { + *((volatile u32 *)(CFG_IMMR + LPC_OFFSET + CS_ALE_TIMING_CONFIG)) = CFG_CS_ALETIMING; + } /* * Enable clocks */ diff --git a/include/configs/ads5121.h b/include/configs/ads5121.h index 5f74afb..ee585da 100644 --- a/include/configs/ads5121.h +++ b/include/configs/ads5121.h @@ -210,6 +210,7 @@
#define CFG_CS0_CFG 0x05059310 /* ALE active low, data size 4bytes */ #define CFG_CS2_CFG 0x05059010 /* ALE active low, data size 1byte */ +#define CFG_CS_ALETIMING 0x00000005 /* For rev 2 silicon CS assert after isolation */
/* Use SRAM for initial stack */ #define CFG_INIT_RAM_ADDR CFG_SRAM_BASE /* Initial RAM address */ diff --git a/include/mpc512x.h b/include/mpc512x.h index a76b1ca..cb418d1 100644 --- a/include/mpc512x.h +++ b/include/mpc512x.h @@ -58,6 +58,7 @@ #define CS5_CONFIG 0x00014 #define CS6_CONFIG 0x00018 #define CS7_CONFIG 0x0001C +#define CS_ALE_TIMING_CONFIG 0x00034
#define CS_CTRL 0x00020 #define CS_CTRL_ME 0x01000000 /* CS Master Enable bit */
John Rigby
