[PATCH v2 19/21] mips: mtmips: add SPL support
This patch adds SPL support for mtmips platform. The lowlevel architecture is split into SPL and the rest parts are built into a memory loadable u-boot image. Optional SPL_DM and OF_CONTROL are also supported.
The increment of size is very small (< 10 KiB) if SPL_DM and OF_CONTROL are not enabled and the memory bootable u-boot (u-boot.img) is generated automatically so there is not need to add a separate config for it.
A lzma compressed payload (u-boot-lzma.img) is also generated and it will be combined with u-boot-spl.bin to form the unified ROM bootable binary u-boot-mtmips.bin.
A spl loader is added to support uncompress the payload.
Signed-off-by: Weijie Gao weijie.gao@mediatek.com --- Changes since v1: move spl loader into this patch. add full pinmux for all three uarts. add optional DM & DT support. --- Makefile | 9 ++ arch/mips/Kconfig | 3 + arch/mips/dts/mt7628-u-boot.dtsi | 24 ++++ arch/mips/mach-mtmips/Kconfig | 24 ++++ arch/mips/mach-mtmips/Makefile | 1 + arch/mips/mach-mtmips/include/mach/serial.h | 13 +++ arch/mips/mach-mtmips/include/mach/spl.h | 14 +++ arch/mips/mach-mtmips/mt7628/Makefile | 1 + arch/mips/mach-mtmips/mt7628/serial.c | 34 ++++++ arch/mips/mach-mtmips/spl.c | 31 +++++ arch/mips/mach-mtmips/spl_load.c | 121 ++++++++++++++++++++ 11 files changed, 275 insertions(+) create mode 100644 arch/mips/dts/mt7628-u-boot.dtsi create mode 100644 arch/mips/mach-mtmips/include/mach/serial.h create mode 100644 arch/mips/mach-mtmips/include/mach/spl.h create mode 100644 arch/mips/mach-mtmips/mt7628/serial.c create mode 100644 arch/mips/mach-mtmips/spl.c create mode 100644 arch/mips/mach-mtmips/spl_load.c
diff --git a/Makefile b/Makefile index 8013cbd9f9..1e18a37913 100644 --- a/Makefile +++ b/Makefile @@ -895,6 +895,7 @@ ALL-$(CONFIG_OF_SEPARATE) += u-boot-dtb-tegra.bin endif
ALL-$(CONFIG_ARCH_MEDIATEK) += u-boot-mtk.bin +ALL-$(CONFIG_ARCH_MTMIPS) += u-boot-mtmips.bin
# Add optional build target if defined in board/cpu/soc headers ifneq ($(CONFIG_BUILD_TARGET),) @@ -1664,6 +1665,14 @@ u-boot-mtk.bin: u-boot.bin FORCE $(call if_changed,mkimage) endif
+ifeq ($(CONFIG_SPL),y) +u-boot-mtmips.bin: u-boot.dtb u-boot-lzma.img spl/u-boot-spl.bin FORCE + $(call if_changed,binman) +else +u-boot-mtmips.bin: u-boot.bin FORCE + $(call if_changed,copy) +endif + ARCH_POSTLINK := $(wildcard $(srctree)/arch/$(ARCH)/Makefile.postlink)
# Rule to link u-boot diff --git a/arch/mips/Kconfig b/arch/mips/Kconfig index 5f82caf8be..5f74f549b5 100644 --- a/arch/mips/Kconfig +++ b/arch/mips/Kconfig @@ -98,6 +98,9 @@ config ARCH_MTMIPS select SUPPORTS_CPU_MIPS32_R2 select SUPPORTS_LITTLE_ENDIAN select SYSRESET + select SUPPORT_SPL + select SPL_LZMA + select BINMAN
config ARCH_JZ47XX bool "Support Ingenic JZ47xx" diff --git a/arch/mips/dts/mt7628-u-boot.dtsi b/arch/mips/dts/mt7628-u-boot.dtsi new file mode 100644 index 0000000000..213959105f --- /dev/null +++ b/arch/mips/dts/mt7628-u-boot.dtsi @@ -0,0 +1,24 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2020 MediaTek Inc. + * + * Author: Weijie Gao weijie.gao@mediatek.com + */ + +/ { + binman { + filename = "u-boot-mtmips.bin"; + pad-byte = <0xff>; + +#ifdef CONFIG_SPL + u-boot-spl { + }; + + u-boot-lzma-img { + }; +#else + u-boot { + }; +#endif + }; +}; diff --git a/arch/mips/mach-mtmips/Kconfig b/arch/mips/mach-mtmips/Kconfig index 3f25de8b85..9b42d5b581 100644 --- a/arch/mips/mach-mtmips/Kconfig +++ b/arch/mips/mach-mtmips/Kconfig @@ -20,8 +20,16 @@ config SYS_ICACHE_LINE_SIZE default 32
config SYS_TEXT_BASE + default 0x9c000000 if !SPL + default 0x80200000 if SPL + +config SPL_TEXT_BASE default 0x9c000000
+config SPL_LOADER_SUPPORT + bool + default y + choice prompt "MediaTek MIPS SoC select"
@@ -34,6 +42,14 @@ config SOC_MT7628 select PINCTRL_MT7628 select MTK_SERIAL select SYSRESET_RESETCTL + select SPL_SEPARATE_BSS if SPL + select SPL_INIT_STACK_WITHOUT_MALLOC_F if SPL + select SPL_OF_CONTROL if SPL_DM + select SPL_SIMPLE_BUS if SPL_DM + select SPL_DM_SERIAL if SPL_DM + select SPL_CLK if SPL_DM && SPL_SERIAL_SUPPORT + select SPL_SYSRESET if SPL_DM + select SPL_OF_LIBFDT if SPL_OF_CONTROL help This supports MediaTek MT7628/MT7688.
@@ -88,6 +104,14 @@ endchoice config SUPPORTS_BOOT_RAM bool
+config SPL_UART2_SPIS_PINMUX + bool "Use alternative pinmux for UART2 in SPL stage" + depends on SPL_SERIAL_SUPPORT + default n + help + Select this if the UART2 of your board is connected to GPIO 16/17 + (shared with SPIS) rather than the usual GPIO 20/21. + source "board/gardena/smart-gateway-mt7688/Kconfig" source "board/seeed/linkit-smart-7688/Kconfig"
diff --git a/arch/mips/mach-mtmips/Makefile b/arch/mips/mach-mtmips/Makefile index 72f0369030..08d2a236d0 100644 --- a/arch/mips/mach-mtmips/Makefile +++ b/arch/mips/mach-mtmips/Makefile @@ -3,5 +3,6 @@ obj-y += cpu.o obj-y += ddr_init.o obj-y += ddr_cal.o +obj-$(CONFIG_SPL_BUILD) += spl.o spl_load.o
obj-$(CONFIG_SOC_MT7628) += mt7628/ diff --git a/arch/mips/mach-mtmips/include/mach/serial.h b/arch/mips/mach-mtmips/include/mach/serial.h new file mode 100644 index 0000000000..bfa246b428 --- /dev/null +++ b/arch/mips/mach-mtmips/include/mach/serial.h @@ -0,0 +1,13 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Copyright (C) 2020 MediaTek Inc. + * + * Author: Weijie Gao weijie.gao@mediatek.com + */ + +#ifndef _MTMIPS_SERIAL_H_ +#define _MTMIPS_SERIAL_H_ + +void mtmips_spl_serial_init(void); + +#endif /* _MTMIPS_SERIAL_H_ */ diff --git a/arch/mips/mach-mtmips/include/mach/spl.h b/arch/mips/mach-mtmips/include/mach/spl.h new file mode 100644 index 0000000000..5674dd533e --- /dev/null +++ b/arch/mips/mach-mtmips/include/mach/spl.h @@ -0,0 +1,14 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Copyright (C) 2020 MediaTek Inc. All Rights Reserved. + * + * Author: Weijie Gao weijie.gao@mediatek.com + */ +#ifndef _MACH_MTMIPS_SPL_H_ +#define _MACH_MTMIPS_SPL_H_ + +#include <asm/spl.h> + +#define BOOT_DEVICE_MTMIPS_NOR (BOOT_DEVICE_BOOTROM + 0x100) + +#endif /* _MACH_MTMIPS_SPL_H_ */ diff --git a/arch/mips/mach-mtmips/mt7628/Makefile b/arch/mips/mach-mtmips/mt7628/Makefile index db62e90d77..7e139d5adf 100644 --- a/arch/mips/mach-mtmips/mt7628/Makefile +++ b/arch/mips/mach-mtmips/mt7628/Makefile @@ -3,3 +3,4 @@ obj-y += lowlevel_init.o obj-y += init.o obj-y += ddr.o +obj-$(CONFIG_SPL_BUILD) += serial.o diff --git a/arch/mips/mach-mtmips/mt7628/serial.c b/arch/mips/mach-mtmips/mt7628/serial.c new file mode 100644 index 0000000000..a7d324792d --- /dev/null +++ b/arch/mips/mach-mtmips/mt7628/serial.c @@ -0,0 +1,34 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2020 MediaTek Inc. + * + * Author: Weijie Gao weijie.gao@mediatek.com + */ + +#include <common.h> +#include <asm/io.h> +#include "mt7628.h" + +void mtmips_spl_serial_init(void) +{ +#ifdef CONFIG_SPL_SERIAL_SUPPORT + void __iomem *base = ioremap_nocache(SYSCTL_BASE, SYSCTL_SIZE); + +#if CONFIG_CONS_INDEX == 1 + clrbits_32(base + SYSCTL_GPIO_MODE1_REG, UART0_MODE_M); +#elif CONFIG_CONS_INDEX == 2 + clrbits_32(base + SYSCTL_GPIO_MODE1_REG, UART1_MODE_M); +#elif CONFIG_CONS_INDEX == 3 + setbits_32(base + SYSCTL_AGPIO_CFG_REG, EPHY_GPIO_AIO_EN_M); +#ifdef CONFIG_SPL_UART2_SPIS_PINMUX + setbits_32(base + SYSCTL_GPIO_MODE1_REG, SPIS_MODE_M); + clrsetbits_32(base + SYSCTL_GPIO_MODE1_REG, UART2_MODE_M, + 1 << UART2_MODE_S); +#else + clrbits_32(base + SYSCTL_GPIO_MODE1_REG, UART2_MODE_M); + clrsetbits_32(base + SYSCTL_GPIO_MODE1_REG, SPIS_MODE_M, + 1 << SPIS_MODE_S); +#endif /* CONFIG_SPL_UART2_SPIS_PINMUX */ +#endif /* CONFIG_CONS_INDEX */ +#endif /* CONFIG_SPL_SERIAL_SUPPORT */ +} diff --git a/arch/mips/mach-mtmips/spl.c b/arch/mips/mach-mtmips/spl.c new file mode 100644 index 0000000000..f12fb70d75 --- /dev/null +++ b/arch/mips/mach-mtmips/spl.c @@ -0,0 +1,31 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2020 MediaTek Inc. All Rights Reserved. + * + * Author: Weijie Gao weijie.gao@mediatek.com + */ + +#include <common.h> +#include <spl.h> +#include <linux/sizes.h> +#include <mach/serial.h> +#include <mach/spl.h> + +DECLARE_GLOBAL_DATA_PTR; + +void __noreturn board_init_f(ulong dummy) +{ + spl_init(); + +#ifdef CONFIG_SPL_SERIAL_SUPPORT + mtmips_spl_serial_init(); + preloader_console_init(); +#endif + + board_init_r(NULL, 0); +} + +void board_boot_order(u32 *spl_boot_list) +{ + spl_boot_list[0] = BOOT_DEVICE_MTMIPS_NOR; +} diff --git a/arch/mips/mach-mtmips/spl_load.c b/arch/mips/mach-mtmips/spl_load.c new file mode 100644 index 0000000000..95dd491baa --- /dev/null +++ b/arch/mips/mach-mtmips/spl_load.c @@ -0,0 +1,121 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2020 MediaTek Inc. All Rights Reserved. + * + * Author: Weijie Gao weijie.gao@mediatek.com + */ + +#include <common.h> +#include <cpu_func.h> +#include <asm/sections.h> +#include <linux/compiler.h> +#include <linux/sizes.h> +#include <mach/spl.h> +#include <spl.h> + +#ifdef CONFIG_SPL_LZMA +#include <lzma/LzmaTypes.h> +#include <lzma/LzmaDec.h> +#include <lzma/LzmaTools.h> +#endif /* CONFIG_SPL_LZMA */ + +#if CONFIG_IS_ENABLED(OF_CONTROL) && defined(CONFIG_OF_SEPARATE) +#include <fdt.h> +#endif + +static ulong spl_dtb_size(void) +{ +#if CONFIG_IS_ENABLED(OF_CONTROL) + void *fdt = __image_copy_end; + + if (fdt_magic(fdt) == FDT_MAGIC) + return fdt_totalsize(fdt); +#endif + + return 0; +} + +static int spl_try_load_image(struct spl_image_info *spl_image, + void *image_addr) +{ + int ret; + uintptr_t dataptr; + struct image_header hdr; + size_t __maybe_unused lzma_len; + + memcpy(&hdr, (const void *)image_addr, sizeof(hdr)); + + ret = spl_parse_image_header(spl_image, &hdr); + if (ret) + return ret; + + if (!spl_image->entry_point) + spl_image->entry_point = spl_image->load_addr; + + dataptr = (uintptr_t)image_addr + sizeof(hdr); + + switch (hdr.ih_comp) { + case IH_COMP_NONE: + /* + * Load real U-Boot from its location to its defined location + * in SDRAM + */ + if (spl_image->load_addr != dataptr) { + memmove((void *)spl_image->load_addr, (void *)dataptr, + spl_image->size); + } + break; +#ifdef CONFIG_SPL_LZMA + case IH_COMP_LZMA: + /* + * Uncompress real U-Boot to its defined location in SDRAM + */ + lzma_len = SZ_8M; + + ret = lzmaBuffToBuffDecompress((u8 *)spl_image->load_addr, + &lzma_len, (u8 *)dataptr, + spl_image->size); + + if (ret) { + printf("Error: LZMA uncompression error: %d\n", ret); + return ret; + } + + spl_image->size = lzma_len; + break; +#endif /* CONFIG_SPL_LZMA */ + default: + debug("Warning: Unsupported compression method found in image " + "header at offset 0x%p\n", image_addr); + return -EINVAL; + } + + flush_cache((unsigned long)spl_image->load_addr, spl_image->size); + + return 0; +} + +static int spl_mtk_nor_load_image(struct spl_image_info *spl_image, + struct spl_boot_device *bootdev) +{ + ulong offset = spl_dtb_size(); + + /* + * Loading of the payload to SDRAM is done with skipping of + * the mkimage header + */ + spl_image->flags |= SPL_COPY_PAYLOAD_ONLY; + + /* Try to boot without padding */ + if (!spl_try_load_image(spl_image, (u8 *)__image_copy_end + offset)) + return 0; + +#ifdef CONFIG_SYS_UBOOT_BASE + /* Try user defined offset */ + if (!spl_try_load_image(spl_image, (void *)CONFIG_SYS_UBOOT_BASE)) + return 0; +#endif + + return -EINVAL; +} +SPL_LOAD_IMAGE_METHOD("NOR", 0, BOOT_DEVICE_MTMIPS_NOR, spl_mtk_nor_load_image);
Am 17.01.20 um 08:46 schrieb Weijie Gao:
- $(call if_changed,binman)
- $(call if_changed,copy)
+endif
- select SUPPORT_SPL
- select SPL_LZMA
- select BINMAN
- Copyright (C) 2020 MediaTek Inc.
- Author: Weijie Gao weijie.gao@mediatek.com
- binman {
pad-byte = <0xff>;
+#ifdef CONFIG_SPL
u-boot-spl {
u-boot-lzma-img {
+#else
u-boot {
- default 0x9c000000 if !SPL
- default 0x80200000 if SPL
- bool
- default y
this option should be moved to arch/mips/Kconfig and should be added with patch 15/21 because you use reference that option in the generic MIPS u-boot-spl.lds
- select SPL_SEPARATE_BSS if SPL
- select SPL_INIT_STACK_WITHOUT_MALLOC_F if SPL
- select SPL_OF_CONTROL if SPL_DM
- select SPL_SIMPLE_BUS if SPL_DM
- select SPL_DM_SERIAL if SPL_DM
- select SPL_CLK if SPL_DM && SPL_SERIAL_SUPPORT
- select SPL_SYSRESET if SPL_DM
- select SPL_OF_LIBFDT if SPL_OF_CONTROL help This supports MediaTek MT7628/MT7688.
- bool "Use alternative pinmux for UART2 in SPL stage"
- depends on SPL_SERIAL_SUPPORT
- default n
- help
- Copyright (C) 2020 MediaTek Inc. All Rights Reserved.
- void __iomem *base = ioremap_nocache(SYSCTL_BASE, SYSCTL_SIZE);
- clrbits_32(base + SYSCTL_GPIO_MODE1_REG, UART0_MODE_M);
- clrbits_32(base + SYSCTL_GPIO_MODE1_REG, UART1_MODE_M);
- setbits_32(base + SYSCTL_AGPIO_CFG_REG, EPHY_GPIO_AIO_EN_M);
- setbits_32(base + SYSCTL_GPIO_MODE1_REG, SPIS_MODE_M);
- clrsetbits_32(base + SYSCTL_GPIO_MODE1_REG, UART2_MODE_M,
1 << UART2_MODE_S);
+#else
- clrbits_32(base + SYSCTL_GPIO_MODE1_REG, UART2_MODE_M);
- clrsetbits_32(base + SYSCTL_GPIO_MODE1_REG, SPIS_MODE_M,
1 << SPIS_MODE_S);
- spl_init();
- mtmips_spl_serial_init();
- preloader_console_init();
- board_init_r(NULL, 0);
- spl_boot_list[0] = BOOT_DEVICE_MTMIPS_NOR;
- void *fdt = __image_copy_end;
- if (fdt_magic(fdt) == FDT_MAGIC)
void *image_addr)
- int ret;
- uintptr_t dataptr;
- struct image_header hdr;
- size_t __maybe_unused lzma_len;
- memcpy(&hdr, (const void *)image_addr, sizeof(hdr));
- ret = spl_parse_image_header(spl_image, &hdr);
- if (ret)
return ret;
- if (!spl_image->entry_point)
- dataptr = (uintptr_t)image_addr + sizeof(hdr);
- switch (hdr.ih_comp) {
- case IH_COMP_NONE:
* in SDRAM
spl_image->size);
break;
- case IH_COMP_LZMA:
lzma_len = SZ_8M;
spl_image->size);
if (ret) {
return ret;
break;
- default:
return -EINVAL;
- flush_cache((unsigned long)spl_image->load_addr, spl_image->size);
- ulong offset = spl_dtb_size();
- spl_image->flags |= SPL_COPY_PAYLOAD_ONLY;
- /* Try to boot without padding */
- if (!spl_try_load_image(spl_image, (u8 *)__image_copy_end + offset))
- /* Try user defined offset */
- if (!spl_try_load_image(spl_image, (void *)CONFIG_SYS_UBOOT_BASE))
- return -EINVAL;
maybe in a future patch series this could be refactored to a generic SPL decompressor in common/spl/ with spl_nor.c as the first user. Then it could be used by other archs or other SPL boot methods like SPI or NAND.
+endif
select SUPPORT_SPL
select SPL_LZMA
select BINMAN
- binman {
pad-byte = <0xff>;
+#ifdef CONFIG_SPL
u-boot-spl {
u-boot-lzma-img {
+#else
u-boot {
- bool
- default y
- default n
- help
- source "board/gardena/smart-gateway-mt7688/Kconfig" source "board/seeed/linkit-smart-7688/Kconfig"
1 << UART2_MODE_S);
+#else
1 << SPIS_MODE_S);
- spl_init();
void *image_addr)
- int ret;
- if (ret)
return ret;
* in SDRAM
spl_image->size);
break;
lzma_len = SZ_8M;
spl_image->size);
if (ret) {
return ret;
break;
- default:
return -EINVAL;
- return -EINVAL;
Yes, I fully agree with Daniel. Please move this into the common SPL code so that it can be used by other platforms as well. This compression is a great feature that should be generally available.
Thanks, Stefan
Added Mauro to Cc
+endif
select SUPPORT_SPL
select SPL_LZMA
select BINMAN
- binman {
pad-byte = <0xff>;
+#ifdef CONFIG_SPL
u-boot-spl {
u-boot-lzma-img {
+#else
u-boot {
- bool
- default y
- choice prompt "MediaTek MIPS SoC select"
- default n
- help
Again, do you know if this is the option that needs to be selected for the VoCore2 board?
Thanks, Stefan
1 << UART2_MODE_S);
+#else
1 << SPIS_MODE_S);
- spl_init();
void *image_addr)
- int ret;
- if (ret)
return ret;
* in SDRAM
spl_image->size);
break;
lzma_len = SZ_8M;
spl_image->size);
if (ret) {
return ret;
break;
- default:
return -EINVAL;
- return -EINVAL;
Viele Grüße, Stefan
On Fri, 2020-01-17 at 15:55 +0100, Stefan Roese wrote:
Added Mauro to Cc
+endif
select SUPPORT_SPL
select SPL_LZMA
select BINMAN
- binman {
pad-byte = <0xff>;
+#ifdef CONFIG_SPL
u-boot-spl {
u-boot-lzma-img {
+#else
u-boot {
- bool
- default y
- default n
- help
Thanks, Stefan
According to your discussions, I believe this is needed.
1 << UART2_MODE_S);
+#else
1 << SPIS_MODE_S);
- spl_init();
void *image_addr)
- int ret;
- if (ret)
return ret;
* in SDRAM
spl_image->size);
break;
lzma_len = SZ_8M;
spl_image->size);
if (ret) {
return ret;
break;
- default:
return -EINVAL;
- return -EINVAL;
Viele Grüße, Stefan
Daniel Schwierzeck
Stefan Roese
Weijie Gao
