Re: [U-Boot] drivers: pci: imx: add imx_pcie_remove function
12 May
2017
12 May
'17
10:47 p.m.
There is no dedicated reset signal wired up for the MX6QDL thus if the bootloader enables the link we need some special handling to get the core back into a state where it is safe to touch it for configuration.
While there has been some special handling in the Linux kernel to do this, it was removed in 4.11 thus we need to do it properly in the bootloader and therefore without this if you enable PCI in the bootloader you
will hang
while booting the 4.11 kernel.
This puts the PCIe controller back into a safe state for the kernel driver before launching the kernel.
Signed-off-by: Tim Harvey tharvey@gateworks.com
Successfully tested on a tbs2910 board.
Tested-by: Soeren Moch smoch@web.de
2918
Soeren Moch
