[PATCHv2] Convert CONFIG_ZYNQMP_PSU_INIT_ENABLED to Kconfig
This converts the following to Kconfig: CONFIG_ZYNQMP_PSU_INIT_ENABLED
Signed-off-by: Tom Rini trini@konsulko.com --- .../avnet_ultrazedev_cc_v1_0_ultrazedev_som_v1_0_defconfig | 1 + configs/xilinx_zynqmp_mini_emmc0_defconfig | 1 + configs/xilinx_zynqmp_mini_emmc1_defconfig | 1 + configs/xilinx_zynqmp_mini_nand_defconfig | 1 + configs/xilinx_zynqmp_mini_nand_single_defconfig | 1 + configs/xilinx_zynqmp_mini_qspi_defconfig | 1 + configs/xilinx_zynqmp_virt_defconfig | 1 + include/configs/xilinx_zynqmp.h | 4 ---- 8 files changed, 7 insertions(+), 4 deletions(-)
diff --git a/configs/avnet_ultrazedev_cc_v1_0_ultrazedev_som_v1_0_defconfig b/configs/avnet_ultrazedev_cc_v1_0_ultrazedev_som_v1_0_defconfig index 3609fd94e2c1..55aa939978a4 100644 --- a/configs/avnet_ultrazedev_cc_v1_0_ultrazedev_som_v1_0_defconfig +++ b/configs/avnet_ultrazedev_cc_v1_0_ultrazedev_som_v1_0_defconfig @@ -14,6 +14,7 @@ CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI=y CONFIG_ZYNQ_MAC_IN_EEPROM=y CONFIG_ZYNQ_GEM_I2C_MAC_OFFSET=0xfa +CONFIG_ZYNQMP_PSU_INIT_ENABLED=y CONFIG_DEBUG_UART=y CONFIG_DISTRO_DEFAULTS=y CONFIG_SYS_LOAD_ADDR=0x8000000 diff --git a/configs/xilinx_zynqmp_mini_emmc0_defconfig b/configs/xilinx_zynqmp_mini_emmc0_defconfig index d4a8517513db..08e90f6101b9 100644 --- a/configs/xilinx_zynqmp_mini_emmc0_defconfig +++ b/configs/xilinx_zynqmp_mini_emmc0_defconfig @@ -10,6 +10,7 @@ CONFIG_ENV_SIZE=0x80 CONFIG_DEFAULT_DEVICE_TREE="zynqmp-mini-emmc0" CONFIG_SPL_SYS_MALLOC_F_LEN=0x600 CONFIG_SPL=y +CONFIG_ZYNQMP_PSU_INIT_ENABLED=y # CONFIG_CMD_ZYNQMP is not set CONFIG_SYS_LOAD_ADDR=0x8000000 CONFIG_FIT=y diff --git a/configs/xilinx_zynqmp_mini_emmc1_defconfig b/configs/xilinx_zynqmp_mini_emmc1_defconfig index 67cf60317d3a..43e9cebbb010 100644 --- a/configs/xilinx_zynqmp_mini_emmc1_defconfig +++ b/configs/xilinx_zynqmp_mini_emmc1_defconfig @@ -10,6 +10,7 @@ CONFIG_ENV_SIZE=0x80 CONFIG_DEFAULT_DEVICE_TREE="zynqmp-mini-emmc1" CONFIG_SPL_SYS_MALLOC_F_LEN=0x600 CONFIG_SPL=y +CONFIG_ZYNQMP_PSU_INIT_ENABLED=y # CONFIG_CMD_ZYNQMP is not set CONFIG_SYS_LOAD_ADDR=0x8000000 CONFIG_FIT=y diff --git a/configs/xilinx_zynqmp_mini_nand_defconfig b/configs/xilinx_zynqmp_mini_nand_defconfig index 68e7586d89a8..a45203e02ace 100644 --- a/configs/xilinx_zynqmp_mini_nand_defconfig +++ b/configs/xilinx_zynqmp_mini_nand_defconfig @@ -7,6 +7,7 @@ CONFIG_SYS_MALLOC_LEN=0x800000 CONFIG_NR_DRAM_BANKS=1 CONFIG_ENV_SIZE=0x80 CONFIG_DEFAULT_DEVICE_TREE="zynqmp-mini-nand" +CONFIG_ZYNQMP_PSU_INIT_ENABLED=y # CONFIG_CMD_ZYNQMP is not set CONFIG_SYS_LOAD_ADDR=0x8000000 CONFIG_FIT=y diff --git a/configs/xilinx_zynqmp_mini_nand_single_defconfig b/configs/xilinx_zynqmp_mini_nand_single_defconfig index 723c61128ffc..13a479f19d17 100644 --- a/configs/xilinx_zynqmp_mini_nand_single_defconfig +++ b/configs/xilinx_zynqmp_mini_nand_single_defconfig @@ -7,6 +7,7 @@ CONFIG_SYS_MALLOC_LEN=0x800000 CONFIG_NR_DRAM_BANKS=1 CONFIG_ENV_SIZE=0x80 CONFIG_DEFAULT_DEVICE_TREE="zynqmp-mini-nand" +CONFIG_ZYNQMP_PSU_INIT_ENABLED=y # CONFIG_CMD_ZYNQMP is not set CONFIG_SYS_LOAD_ADDR=0x8000000 CONFIG_FIT=y diff --git a/configs/xilinx_zynqmp_mini_qspi_defconfig b/configs/xilinx_zynqmp_mini_qspi_defconfig index 8d7c70475618..78c9d29af095 100644 --- a/configs/xilinx_zynqmp_mini_qspi_defconfig +++ b/configs/xilinx_zynqmp_mini_qspi_defconfig @@ -10,6 +10,7 @@ CONFIG_DEFAULT_DEVICE_TREE="zynqmp-mini-qspi" CONFIG_SPL=y CONFIG_SYS_MEM_RSVD_FOR_MMU=y CONFIG_ZYNQMP_NO_DDR=y +CONFIG_ZYNQMP_PSU_INIT_ENABLED=y # CONFIG_CMD_ZYNQMP is not set # CONFIG_PSCI_RESET is not set # CONFIG_EXPERT is not set diff --git a/configs/xilinx_zynqmp_virt_defconfig b/configs/xilinx_zynqmp_virt_defconfig index dc845899d171..86223cd39c80 100644 --- a/configs/xilinx_zynqmp_virt_defconfig +++ b/configs/xilinx_zynqmp_virt_defconfig @@ -18,6 +18,7 @@ CONFIG_ZYNQ_MAC_IN_EEPROM=y CONFIG_ZYNQ_GEM_I2C_MAC_OFFSET=0x20 CONFIG_CMD_FRU=y CONFIG_ZYNQMP_USB=y +CONFIG_ZYNQMP_PSU_INIT_ENABLED=y CONFIG_AHCI=y CONFIG_DISTRO_DEFAULTS=y CONFIG_SYS_LOAD_ADDR=0x8000000 diff --git a/include/configs/xilinx_zynqmp.h b/include/configs/xilinx_zynqmp.h index e21480578750..d683d12e95b9 100644 --- a/include/configs/xilinx_zynqmp.h +++ b/include/configs/xilinx_zynqmp.h @@ -39,10 +39,6 @@ # define CONFIG_SYS_MAX_NAND_DEVICE 1 #endif
-#if defined(CONFIG_SPL_BUILD) -#define CONFIG_ZYNQMP_PSU_INIT_ENABLED -#endif - /* Miscellaneous configurable options */
#if defined(CONFIG_ZYNQMP_USB)
