[PATCH 00/20] New CI image and fixes
Hi all,
This series build a new CI image based on Ubuntu focal with LoongArch64 support, fixed various python scripts for python 3.12, fixed various problems popped up when testing againt latest software.
This change must be combined with test hook changes at [1].
Last two commits are for demonstration purpose and not for commit into repo.
CI runs passed at azure [2] and public gitlab.com runner [3].
Thanks
[1]: https://lore.kernel.org/u-boot/20240611210025.798978-1-jiaxun.yang@flygoat.c... [2]: https://gitlab.com/FlyGoat/u-boot/-/pipelines/1327832544 [3]: https://flygoat.visualstudio.com/u-boot/_build/results?buildId=63&view=r...
Signed-off-by: Jiaxun Yang jiaxun.yang@flygoat.com --- Jiaxun Yang (20): py: Replace deprecated unittest APIs binman: Replace pkg_resources with importlib.resources py: Replace distutils.core with setuptools py: Replace usage of configparser.read_fp doc/sphinx: Remove usage of six py: Remove unused entries in requirements.txt py: Bump requirements versions py: Bump pylint version and clear warnings binman: Workaround lz4 cli padding in test cases tests/test_event_dump: Relax match rule for output lib/charset & efi: Fix possible unaligned accesses cyclic: Rise default CYCLIC_MAX_CPU_TIME_US to 5000 CI: Ensure pip install is always performed in venv CI: GitLab: Split build_world tasks CI: Dockerfile: Set global git name & email config CI: Dockerfile: Bump various software version CI: Dockerfile: Add LoongArch64 support doc: ci: Document how to run pipeline on gitlab.com [NFC] Use Jiaxun's CI Image [NFC] CI: Dockerfile: Replace some URL with mirror sites
.azure-pipelines.yml | 22 +++-- .gitlab-ci.yml | 122 ++++++++++++++---------- common/Kconfig | 2 +- configs/octeon_nic23_defconfig | 1 - doc/develop/ci_testing.rst | 12 ++- doc/develop/python_cq.rst | 4 +- doc/sphinx/kfigure.py | 3 +- doc/sphinx/requirements.txt | 1 - lib/charset.c | 21 ++-- lib/efi_loader/efi_device_path.c | 11 +-- test/py/requirements.txt | 24 +---- test/py/tests/test_event_dump.py | 10 +- test/py/tests/test_ums.py | 1 + test/py/tests/test_usb.py | 1 + tools/binman/control.py | 18 ++-- tools/binman/entry_test.py | 6 +- tools/binman/etype/fdtmap.py | 1 + tools/binman/etype/fit.py | 1 + tools/binman/etype/image_header.py | 1 + tools/binman/etype/pre_load.py | 2 + tools/binman/etype/ti_board_config.py | 1 + tools/binman/etype/x509_cert.py | 1 + tools/binman/fdt_test.py | 48 +++++----- tools/binman/ftest.py | 50 +++++----- tools/binman/setup.py | 2 +- tools/binman/state.py | 1 + tools/binman/test/184_compress_section_size.dts | 1 + tools/buildman/bsettings.py | 2 +- tools/buildman/builder.py | 2 + tools/buildman/func_test.py | 74 +++++++------- tools/buildman/requirements.txt | 7 +- tools/buildman/test.py | 2 +- tools/docker/Dockerfile | 75 +++++++++------ tools/dtoc/setup.py | 2 +- tools/microcode-tool.py | 1 + tools/patman/settings.py | 9 +- tools/patman/test_checkpatch.py | 2 + tools/qconfig.py | 1 + 38 files changed, 293 insertions(+), 252 deletions(-) --- base-commit: 1ebd659cf020843fd8e8ef90d85a66941cbab6ec change-id: 20240610-docker-image-868126a1a929
assertEquals -> assertEqual assertRegexpMatches -> assertRegex
Those APIs were deprecated long ago and being removed in latest python.
Signed-off-by: Jiaxun Yang jiaxun.yang@flygoat.com --- tools/binman/entry_test.py | 6 ++-- tools/binman/fdt_test.py | 48 ++++++++++++++--------------- tools/binman/ftest.py | 42 ++++++++++++------------- tools/buildman/func_test.py | 74 ++++++++++++++++++++++----------------------- tools/buildman/test.py | 2 +- 5 files changed, 86 insertions(+), 86 deletions(-)
diff --git a/tools/binman/entry_test.py b/tools/binman/entry_test.py index ac6582cf86a8..40d74d401a20 100644 --- a/tools/binman/entry_test.py +++ b/tools/binman/entry_test.py @@ -103,7 +103,7 @@ class TestEntry(unittest.TestCase): ent = entry.Entry.Create(None, self.GetNode(), 'missing', missing_etype=True) self.assertTrue(isinstance(ent, Entry_blob)) - self.assertEquals('missing', ent.etype) + self.assertEqual('missing', ent.etype)
def testDecompressData(self): """Test the DecompressData() method of the base class""" @@ -111,8 +111,8 @@ class TestEntry(unittest.TestCase): base.compress = 'lz4' bintools = {} base.comp_bintool = base.AddBintool(bintools, '_testing') - self.assertEquals(tools.get_bytes(0, 1024), base.CompressData(b'abc')) - self.assertEquals(tools.get_bytes(0, 1024), base.DecompressData(b'abc')) + self.assertEqual(tools.get_bytes(0, 1024), base.CompressData(b'abc')) + self.assertEqual(tools.get_bytes(0, 1024), base.DecompressData(b'abc'))
def testLookupOffset(self): """Test the lookup_offset() method of the base class""" diff --git a/tools/binman/fdt_test.py b/tools/binman/fdt_test.py index 7ef872954630..564c17708207 100644 --- a/tools/binman/fdt_test.py +++ b/tools/binman/fdt_test.py @@ -44,43 +44,43 @@ class TestFdt(unittest.TestCase): fname = self.GetCompiled('045_prop_test.dts') dt = FdtScan(fname) node = dt.GetNode('/binman/intel-me') - self.assertEquals('intel-me', node.name) + self.assertEqual('intel-me', node.name) val = fdt_util.GetString(node, 'filename') - self.assertEquals(str, type(val)) - self.assertEquals('me.bin', val) + self.assertEqual(str, type(val)) + self.assertEqual('me.bin', val)
prop = node.props['intval'] - self.assertEquals(fdt.Type.INT, prop.type) - self.assertEquals(3, fdt_util.GetInt(node, 'intval')) + self.assertEqual(fdt.Type.INT, prop.type) + self.assertEqual(3, fdt_util.GetInt(node, 'intval'))
prop = node.props['intarray'] - self.assertEquals(fdt.Type.INT, prop.type) - self.assertEquals(list, type(prop.value)) - self.assertEquals(2, len(prop.value)) - self.assertEquals([5, 6], + self.assertEqual(fdt.Type.INT, prop.type) + self.assertEqual(list, type(prop.value)) + self.assertEqual(2, len(prop.value)) + self.assertEqual([5, 6], [fdt_util.fdt32_to_cpu(val) for val in prop.value])
prop = node.props['byteval'] - self.assertEquals(fdt.Type.BYTE, prop.type) - self.assertEquals(chr(8), prop.value) + self.assertEqual(fdt.Type.BYTE, prop.type) + self.assertEqual(chr(8), prop.value)
prop = node.props['bytearray'] - self.assertEquals(fdt.Type.BYTE, prop.type) - self.assertEquals(list, type(prop.value)) - self.assertEquals(str, type(prop.value[0])) - self.assertEquals(3, len(prop.value)) - self.assertEquals([chr(1), '#', '4'], prop.value) + self.assertEqual(fdt.Type.BYTE, prop.type) + self.assertEqual(list, type(prop.value)) + self.assertEqual(str, type(prop.value[0])) + self.assertEqual(3, len(prop.value)) + self.assertEqual([chr(1), '#', '4'], prop.value)
prop = node.props['longbytearray'] - self.assertEquals(fdt.Type.INT, prop.type) - self.assertEquals(0x090a0b0c, fdt_util.GetInt(node, 'longbytearray')) + self.assertEqual(fdt.Type.INT, prop.type) + self.assertEqual(0x090a0b0c, fdt_util.GetInt(node, 'longbytearray'))
prop = node.props['stringval'] - self.assertEquals(fdt.Type.STRING, prop.type) - self.assertEquals('message2', fdt_util.GetString(node, 'stringval')) + self.assertEqual(fdt.Type.STRING, prop.type) + self.assertEqual('message2', fdt_util.GetString(node, 'stringval'))
prop = node.props['stringarray'] - self.assertEquals(fdt.Type.STRING, prop.type) - self.assertEquals(list, type(prop.value)) - self.assertEquals(3, len(prop.value)) - self.assertEquals(['another', 'multi-word', 'message'], prop.value) + self.assertEqual(fdt.Type.STRING, prop.type) + self.assertEqual(list, type(prop.value)) + self.assertEqual(3, len(prop.value)) + self.assertEqual(['another', 'multi-word', 'message'], prop.value) diff --git a/tools/binman/ftest.py b/tools/binman/ftest.py index 8a44bc051b36..567849bbab0f 100644 --- a/tools/binman/ftest.py +++ b/tools/binman/ftest.py @@ -2095,7 +2095,7 @@ class TestFunctional(unittest.TestCase): dtb.Scan() props = self._GetPropTree(dtb, ['size', 'uncomp-size']) orig = self._decompress(data) - self.assertEquals(COMPRESS_DATA, orig) + self.assertEqual(COMPRESS_DATA, orig)
# Do a sanity check on various fields image = control.images['image'] @@ -2809,9 +2809,9 @@ class TestFunctional(unittest.TestCase):
orig_entry = orig_image.GetEntries()['fdtmap'] entry = image.GetEntries()['fdtmap'] - self.assertEquals(orig_entry.offset, entry.offset) - self.assertEquals(orig_entry.size, entry.size) - self.assertEquals(orig_entry.image_pos, entry.image_pos) + self.assertEqual(orig_entry.offset, entry.offset) + self.assertEqual(orig_entry.size, entry.size) + self.assertEqual(orig_entry.image_pos, entry.image_pos)
def testReadImageNoHeader(self): """Test accessing an image's FDT map without an image header""" @@ -3895,7 +3895,7 @@ class TestFunctional(unittest.TestCase): mat = re_line.match(line) vals[mat.group(1)].append(mat.group(2))
- self.assertEquals('FIT description: test-desc', lines[0]) + self.assertEqual('FIT description: test-desc', lines[0]) self.assertIn('Created:', lines[1]) self.assertIn('Image 0 (kernel)', vals) self.assertIn('Hash value', vals) @@ -4012,7 +4012,7 @@ class TestFunctional(unittest.TestCase): fit_pos, fdt_util.fdt32_to_cpu(fnode.props['data-position'].value))
- self.assertEquals(expected_size, len(data)) + self.assertEqual(expected_size, len(data)) actual_pos = len(U_BOOT_DATA) + fit_pos self.assertEqual(U_BOOT_DATA + b'aa', data[actual_pos:actual_pos + external_data_size]) @@ -4431,7 +4431,7 @@ class TestFunctional(unittest.TestCase): props = self._GetPropTree(dtb, ['offset', 'image-pos', 'size', 'uncomp-size']) orig = self._decompress(data) - self.assertEquals(COMPRESS_DATA + U_BOOT_DATA, orig) + self.assertEqual(COMPRESS_DATA + U_BOOT_DATA, orig)
# Do a sanity check on various fields image = control.images['image'] @@ -4475,7 +4475,7 @@ class TestFunctional(unittest.TestCase): 'uncomp-size']) orig = self._decompress(data)
- self.assertEquals(COMPRESS_DATA + COMPRESS_DATA + U_BOOT_DATA, orig) + self.assertEqual(COMPRESS_DATA + COMPRESS_DATA + U_BOOT_DATA, orig)
# Do a sanity check on various fields image = control.images['image'] @@ -4519,7 +4519,7 @@ class TestFunctional(unittest.TestCase): props = self._GetPropTree(dtb, ['offset', 'image-pos', 'size', 'uncomp-size']) orig = self._decompress(data) - self.assertEquals(COMPRESS_DATA + U_BOOT_DATA, orig) + self.assertEqual(COMPRESS_DATA + U_BOOT_DATA, orig) expected = { 'section/blob:offset': 0, 'section/blob:size': len(COMPRESS_DATA), @@ -4545,7 +4545,7 @@ class TestFunctional(unittest.TestCase): props = self._GetPropTree(dtb, ['offset', 'image-pos', 'size', 'uncomp-size']) orig = self._decompress(data) - self.assertEquals(COMPRESS_DATA + U_BOOT_DATA, orig) + self.assertEqual(COMPRESS_DATA + U_BOOT_DATA, orig) expected = { 'section/blob:offset': 0, 'section/blob:size': len(COMPRESS_DATA), @@ -4580,7 +4580,7 @@ class TestFunctional(unittest.TestCase): 'uncomp-size'])
base = data[len(U_BOOT_DATA):] - self.assertEquals(U_BOOT_DATA, base[:len(U_BOOT_DATA)]) + self.assertEqual(U_BOOT_DATA, base[:len(U_BOOT_DATA)]) rest = base[len(U_BOOT_DATA):]
# Check compressed data @@ -4588,22 +4588,22 @@ class TestFunctional(unittest.TestCase): expect1 = bintool.compress(COMPRESS_DATA + U_BOOT_DATA) data1 = rest[:len(expect1)] section1 = self._decompress(data1) - self.assertEquals(expect1, data1) - self.assertEquals(COMPRESS_DATA + U_BOOT_DATA, section1) + self.assertEqual(expect1, data1) + self.assertEqual(COMPRESS_DATA + U_BOOT_DATA, section1) rest1 = rest[len(expect1):]
expect2 = bintool.compress(COMPRESS_DATA + COMPRESS_DATA) data2 = rest1[:len(expect2)] section2 = self._decompress(data2) - self.assertEquals(expect2, data2) - self.assertEquals(COMPRESS_DATA + COMPRESS_DATA, section2) + self.assertEqual(expect2, data2) + self.assertEqual(COMPRESS_DATA + COMPRESS_DATA, section2) rest2 = rest1[len(expect2):]
expect_size = (len(U_BOOT_DATA) + len(U_BOOT_DATA) + len(expect1) + len(expect2) + len(U_BOOT_DATA)) - #self.assertEquals(expect_size, len(data)) + #self.assertEqual(expect_size, len(data))
- #self.assertEquals(U_BOOT_DATA, rest2) + #self.assertEqual(U_BOOT_DATA, rest2)
self.maxDiff = None expected = { @@ -4695,7 +4695,7 @@ class TestFunctional(unittest.TestCase):
u_boot = image.GetEntries()['section'].GetEntries()['u-boot']
- self.assertEquals(U_BOOT_DATA, u_boot.ReadData()) + self.assertEqual(U_BOOT_DATA, u_boot.ReadData())
def testTplNoDtb(self): """Test that an image with tpl/u-boot-tpl-nodtb.bin can be created""" @@ -5526,7 +5526,7 @@ fdt fdtmap Extract the devicetree blob from the fdtmap segments, entry = elf.read_loadable_segments(elf_data)
# We assume there are two segments - self.assertEquals(2, len(segments)) + self.assertEqual(2, len(segments))
atf1 = dtb.GetNode('/images/atf-1') _, start, data = segments[0] @@ -6107,7 +6107,7 @@ fdt fdtmap Extract the devicetree blob from the fdtmap data = bintool.compress(COMPRESS_DATA) self.assertNotEqual(COMPRESS_DATA, data) orig = bintool.decompress(data) - self.assertEquals(COMPRESS_DATA, orig) + self.assertEqual(COMPRESS_DATA, orig)
def testCompUtilVersions(self): """Test tool version of compression algorithms""" @@ -6125,7 +6125,7 @@ fdt fdtmap Extract the devicetree blob from the fdtmap self.assertNotEqual(COMPRESS_DATA, data) data += tools.get_bytes(0, 64) orig = bintool.decompress(data) - self.assertEquals(COMPRESS_DATA, orig) + self.assertEqual(COMPRESS_DATA, orig)
def testCompressDtbZstd(self): """Test that zstd compress of device-tree files failed""" diff --git a/tools/buildman/func_test.py b/tools/buildman/func_test.py index 6b88ed815d65..0ac9fc7e44f4 100644 --- a/tools/buildman/func_test.py +++ b/tools/buildman/func_test.py @@ -807,27 +807,27 @@ CONFIG_LOCALVERSION=y params, warnings = self._boards.scan_defconfigs(src, src)
# We should get two boards - self.assertEquals(2, len(params)) + self.assertEqual(2, len(params)) self.assertFalse(warnings) first = 0 if params[0]['target'] == 'board0' else 1 board0 = params[first] board2 = params[1 - first]
- self.assertEquals('arm', board0['arch']) - self.assertEquals('armv7', board0['cpu']) - self.assertEquals('-', board0['soc']) - self.assertEquals('Tester', board0['vendor']) - self.assertEquals('ARM Board 0', board0['board']) - self.assertEquals('config0', board0['config']) - self.assertEquals('board0', board0['target']) - - self.assertEquals('powerpc', board2['arch']) - self.assertEquals('ppc', board2['cpu']) - self.assertEquals('mpc85xx', board2['soc']) - self.assertEquals('Tester', board2['vendor']) - self.assertEquals('PowerPC board 1', board2['board']) - self.assertEquals('config2', board2['config']) - self.assertEquals('board2', board2['target']) + self.assertEqual('arm', board0['arch']) + self.assertEqual('armv7', board0['cpu']) + self.assertEqual('-', board0['soc']) + self.assertEqual('Tester', board0['vendor']) + self.assertEqual('ARM Board 0', board0['board']) + self.assertEqual('config0', board0['config']) + self.assertEqual('board0', board0['target']) + + self.assertEqual('powerpc', board2['arch']) + self.assertEqual('ppc', board2['cpu']) + self.assertEqual('mpc85xx', board2['soc']) + self.assertEqual('Tester', board2['vendor']) + self.assertEqual('PowerPC board 1', board2['board']) + self.assertEqual('config2', board2['config']) + self.assertEqual('board2', board2['target'])
def test_output_is_new(self): """Test detecting new changes to Kconfig""" @@ -898,7 +898,7 @@ Active aarch64 armv8 - armltd total_compute board2 params_list, warnings = self._boards.build_board_list(config_dir, src)
# There should be two boards no warnings - self.assertEquals(2, len(params_list)) + self.assertEqual(2, len(params_list)) self.assertFalse(warnings)
# Set an invalid status line in the file @@ -907,12 +907,12 @@ Active aarch64 armv8 - armltd total_compute board2 for line in orig_data.splitlines(keepends=True)] tools.write_file(main, ''.join(lines), binary=False) params_list, warnings = self._boards.build_board_list(config_dir, src) - self.assertEquals(2, len(params_list)) + self.assertEqual(2, len(params_list)) params = params_list[0] if params['target'] == 'board2': params = params_list[1] - self.assertEquals('-', params['status']) - self.assertEquals(["WARNING: Other: unknown status for 'board0'"], + self.assertEqual('-', params['status']) + self.assertEqual(["WARNING: Other: unknown status for 'board0'"], warnings)
# Remove the status line (S:) from a file @@ -920,39 +920,39 @@ Active aarch64 armv8 - armltd total_compute board2 if not line.startswith('S:')] tools.write_file(main, ''.join(lines), binary=False) params_list, warnings = self._boards.build_board_list(config_dir, src) - self.assertEquals(2, len(params_list)) - self.assertEquals(["WARNING: -: unknown status for 'board0'"], warnings) + self.assertEqual(2, len(params_list)) + self.assertEqual(["WARNING: -: unknown status for 'board0'"], warnings)
# Remove the configs/ line (F:) from a file - this is the last line data = ''.join(orig_data.splitlines(keepends=True)[:-1]) tools.write_file(main, data, binary=False) params_list, warnings = self._boards.build_board_list(config_dir, src) - self.assertEquals(2, len(params_list)) - self.assertEquals(["WARNING: no maintainers for 'board0'"], warnings) + self.assertEqual(2, len(params_list)) + self.assertEqual(["WARNING: no maintainers for 'board0'"], warnings)
# Mark a board as orphaned - this should give a warning lines = ['S: Orphaned' if line.startswith('S') else line for line in orig_data.splitlines(keepends=True)] tools.write_file(main, ''.join(lines), binary=False) params_list, warnings = self._boards.build_board_list(config_dir, src) - self.assertEquals(2, len(params_list)) - self.assertEquals(["WARNING: no maintainers for 'board0'"], warnings) + self.assertEqual(2, len(params_list)) + self.assertEqual(["WARNING: no maintainers for 'board0'"], warnings)
# Change the maintainer to '-' - this should give a warning lines = ['M: -' if line.startswith('M') else line for line in orig_data.splitlines(keepends=True)] tools.write_file(main, ''.join(lines), binary=False) params_list, warnings = self._boards.build_board_list(config_dir, src) - self.assertEquals(2, len(params_list)) - self.assertEquals(["WARNING: -: unknown status for 'board0'"], warnings) + self.assertEqual(2, len(params_list)) + self.assertEqual(["WARNING: -: unknown status for 'board0'"], warnings)
# Remove the maintainer line (M:) from a file lines = [line for line in orig_data.splitlines(keepends=True) if not line.startswith('M:')] tools.write_file(main, ''.join(lines), binary=False) params_list, warnings = self._boards.build_board_list(config_dir, src) - self.assertEquals(2, len(params_list)) - self.assertEquals(["WARNING: no maintainers for 'board0'"], warnings) + self.assertEqual(2, len(params_list)) + self.assertEqual(["WARNING: no maintainers for 'board0'"], warnings)
# Move the contents of the second file into this one, removing the # second file, to check multiple records in a single file. @@ -960,14 +960,14 @@ Active aarch64 armv8 - armltd total_compute board2 tools.write_file(main, both_data, binary=False) os.remove(other) params_list, warnings = self._boards.build_board_list(config_dir, src) - self.assertEquals(2, len(params_list)) + self.assertEqual(2, len(params_list)) self.assertFalse(warnings)
# Add another record, this should be ignored with a warning extra = '\n\nAnother\nM: Fred\nF: configs/board9_defconfig\nS: other\n' tools.write_file(main, both_data + extra, binary=False) params_list, warnings = self._boards.build_board_list(config_dir, src) - self.assertEquals(2, len(params_list)) + self.assertEqual(2, len(params_list)) self.assertFalse(warnings)
# Add another TARGET to the Kconfig @@ -983,8 +983,8 @@ endif tools.write_file(kc_file, orig_kc_data + extra) params_list, warnings = self._boards.build_board_list(config_dir, src, warn_targets=True) - self.assertEquals(2, len(params_list)) - self.assertEquals( + self.assertEqual(2, len(params_list)) + self.assertEqual( ['WARNING: board2_defconfig: Duplicate TARGET_xxx: board2 and other'], warnings)
@@ -994,8 +994,8 @@ endif tools.write_file(kc_file, b''.join(lines)) params_list, warnings = self._boards.build_board_list(config_dir, src, warn_targets=True) - self.assertEquals(2, len(params_list)) - self.assertEquals( + self.assertEqual(2, len(params_list)) + self.assertEqual( ['WARNING: board2_defconfig: No TARGET_BOARD2 enabled'], warnings) tools.write_file(kc_file, orig_kc_data) @@ -1004,7 +1004,7 @@ endif data = ''.join(both_data.splitlines(keepends=True)[:-1]) tools.write_file(main, data + 'N: oa.*2\n', binary=False) params_list, warnings = self._boards.build_board_list(config_dir, src) - self.assertEquals(2, len(params_list)) + self.assertEqual(2, len(params_list)) self.assertFalse(warnings)
def testRegenBoards(self): diff --git a/tools/buildman/test.py b/tools/buildman/test.py index f92add7a7c5e..79164bd1993d 100644 --- a/tools/buildman/test.py +++ b/tools/buildman/test.py @@ -584,7 +584,7 @@ class TestBuild(unittest.TestCase): if use_network: with test_util.capture_sys_output() as (stdout, stderr): url = self.toolchains.LocateArchUrl('arm') - self.assertRegexpMatches(url, 'https://www.kernel.org/pub/tools/' + self.assertRegex(url, 'https://www.kernel.org/pub/tools/' 'crosstool/files/bin/x86_64/.*/' 'x86_64-gcc-.*-nolibc[-_]arm-.*linux-gnueabi.tar.xz')
pkg_resources is deprecated long ago and being removed in python 3.12.
Reimplement functions with importlib.resources.
Link: https://docs.python.org/3/library/importlib.resources.html Signed-off-by: Jiaxun Yang jiaxun.yang@flygoat.com --- tools/binman/control.py | 18 +++++++++--------- 1 file changed, 9 insertions(+), 9 deletions(-)
diff --git a/tools/binman/control.py b/tools/binman/control.py index 2f00279232b8..5549b0ad2185 100644 --- a/tools/binman/control.py +++ b/tools/binman/control.py @@ -8,12 +8,11 @@ from collections import OrderedDict import glob try: - import importlib.resources -except ImportError: # pragma: no cover + from importlib import resources +except ImportError: # for Python 3.6 - import importlib_resources + import importlib_resources as resources import os -import pkg_resources import re
import sys @@ -96,12 +95,12 @@ def _ReadMissingBlobHelp(): msg = '' return tag, msg
- my_data = pkg_resources.resource_string(__name__, 'missing-blob-help') + my_data = resources.files(__package__).joinpath('missing-blob-help').read_text() re_tag = re.compile('^([-a-z0-9]+):$') result = {} tag = None msg = '' - for line in my_data.decode('utf-8').splitlines(): + for line in my_data.splitlines(): if not line.startswith('#'): m_tag = re_tag.match(line) if m_tag: @@ -151,8 +150,9 @@ def GetEntryModules(include_testing=True): Returns: Set of paths to entry class filenames """ - glob_list = pkg_resources.resource_listdir(__name__, 'etype') - glob_list = [fname for fname in glob_list if fname.endswith('.py')] + directory = resources.files("binman.etype") + glob_list = [entry.name for entry in directory.iterdir() + if entry.name.endswith('.py')] return set([os.path.splitext(os.path.basename(item))[0] for item in glob_list if include_testing or '_testing' not in item]) @@ -735,7 +735,7 @@ def Binman(args): global state
if args.full_help: - with importlib.resources.path('binman', 'README.rst') as readme: + with resources.path('binman', 'README.rst') as readme: tools.print_full_help(str(readme)) return 0
distutils is deprecated long ago and being removed in python 3.12.
Signed-off-by: Jiaxun Yang jiaxun.yang@flygoat.com --- tools/binman/setup.py | 2 +- tools/buildman/requirements.txt | 1 + tools/dtoc/setup.py | 2 +- 3 files changed, 3 insertions(+), 2 deletions(-)
diff --git a/tools/binman/setup.py b/tools/binman/setup.py index 9a9206eb044a..bec078a3d9b1 100644 --- a/tools/binman/setup.py +++ b/tools/binman/setup.py @@ -1,6 +1,6 @@ # SPDX-License-Identifier: GPL-2.0+
-from distutils.core import setup +from setuptools import setup setup(name='binman', version='1.0', license='GPL-2.0+', diff --git a/tools/buildman/requirements.txt b/tools/buildman/requirements.txt index 4a31e69e4cb5..350da42c0ebf 100644 --- a/tools/buildman/requirements.txt +++ b/tools/buildman/requirements.txt @@ -1,3 +1,4 @@ jsonschema==4.17.3 pyyaml==6.0 yamllint==1.26.3 +setuptools==65.5.1 diff --git a/tools/dtoc/setup.py b/tools/dtoc/setup.py index 5e092fe0872a..ae9ad043b013 100644 --- a/tools/dtoc/setup.py +++ b/tools/dtoc/setup.py @@ -1,6 +1,6 @@ # SPDX-License-Identifier: GPL-2.0+
-from distutils.core import setup +from setuptools import setup setup(name='dtoc', version='1.0', license='GPL-2.0+',
configparser.read_fp is deprecated long ago. Replace with relevant API.
Signed-off-by: Jiaxun Yang jiaxun.yang@flygoat.com --- tools/buildman/bsettings.py | 2 +- tools/patman/settings.py | 9 ++++----- 2 files changed, 5 insertions(+), 6 deletions(-)
diff --git a/tools/buildman/bsettings.py b/tools/buildman/bsettings.py index e225ac2ca0f4..7dbc638d5841 100644 --- a/tools/buildman/bsettings.py +++ b/tools/buildman/bsettings.py @@ -29,7 +29,7 @@ def setup(fname=''): settings.read(config_fname)
def add_file(data): - settings.readfp(io.StringIO(data)) + settings.read_file(io.StringIO(data), data)
def get_items(section): """Get the items from a section of the config. diff --git a/tools/patman/settings.py b/tools/patman/settings.py index 636983e32da8..308626107037 100644 --- a/tools/patman/settings.py +++ b/tools/patman/settings.py @@ -41,7 +41,6 @@ class _ProjectConfigParser(ConfigParser.ConfigParser): - Merge general default settings/aliases with project-specific ones.
# Sample config used for tests below... - >>> from io import StringIO >>> sample_config = ''' ... [alias] ... me: Peter P. likesspiders@example.com @@ -59,25 +58,25 @@ class _ProjectConfigParser(ConfigParser.ConfigParser):
# Check to make sure that bogus project gets general alias. >>> config = _ProjectConfigParser("zzz") - >>> config.readfp(StringIO(sample_config)) + >>> config.read_string(sample_config) >>> str(config.get("alias", "enemies")) 'Evil evil@example.com'
# Check to make sure that alias gets overridden by project. >>> config = _ProjectConfigParser("sm") - >>> config.readfp(StringIO(sample_config)) + >>> config.read_string(sample_config) >>> str(config.get("alias", "enemies")) 'Green G. ugly@example.com'
# Check to make sure that settings get merged with project. >>> config = _ProjectConfigParser("linux") - >>> config.readfp(StringIO(sample_config)) + >>> config.read_string(sample_config) >>> sorted((str(a), str(b)) for (a, b) in config.items("settings")) [('am_hero', 'True'), ('check_patch_use_tree', 'True'), ('process_tags', 'False')]
# Check to make sure that settings works with unknown project. >>> config = _ProjectConfigParser("unknown") - >>> config.readfp(StringIO(sample_config)) + >>> config.read_string(sample_config) >>> sorted((str(a), str(b)) for (a, b) in config.items("settings")) [('am_hero', 'True')] """
We don't support python2 any more so there is no point to use six here.
Signed-off-by: Jiaxun Yang jiaxun.yang@flygoat.com --- doc/sphinx/kfigure.py | 3 +-- 1 file changed, 1 insertion(+), 2 deletions(-)
diff --git a/doc/sphinx/kfigure.py b/doc/sphinx/kfigure.py index dea7f91ef5ab..9467e8d52ac0 100644 --- a/doc/sphinx/kfigure.py +++ b/doc/sphinx/kfigure.py @@ -58,7 +58,6 @@ from docutils.parsers.rst.directives import images import sphinx
from sphinx.util.nodes import clean_astext -from six import iteritems
import kernellog
@@ -540,7 +539,7 @@ def add_kernel_figure_to_std_domain(app, doctree): docname = app.env.docname labels = std.data["labels"]
- for name, explicit in iteritems(doctree.nametypes): + for name, explicit in doctree.nametypes.items(): if not explicit: continue labelid = doctree.nameids[name]
Many packages in requirements.txt are not actually imported/used by any test case, some of them was for python2 compatibility.
Remove them to keep our environment clean.
Signed-off-by: Jiaxun Yang jiaxun.yang@flygoat.com --- doc/sphinx/requirements.txt | 1 - test/py/requirements.txt | 18 ------------------ 2 files changed, 19 deletions(-)
diff --git a/doc/sphinx/requirements.txt b/doc/sphinx/requirements.txt index 426f41e1a028..12447386d29b 100644 --- a/doc/sphinx/requirements.txt +++ b/doc/sphinx/requirements.txt @@ -10,7 +10,6 @@ MarkupSafe==2.1.3 packaging==23.2 Pygments==2.17.2 requests==2.31.0 -six==1.16.0 snowballstemmer==2.2.0 Sphinx==7.2.6 sphinx-prompt==1.8.0 diff --git a/test/py/requirements.txt b/test/py/requirements.txt index 0f67c3c61949..f24a842bfe6f 100644 --- a/test/py/requirements.txt +++ b/test/py/requirements.txt @@ -1,30 +1,12 @@ -atomicwrites==1.4.1 -attrs==19.3.0 concurrencytest==0.1.2 coverage==4.5.4 -extras==1.0.0 filelock==3.0.12 -fixtures==3.0.0 -importlib-metadata==0.23 -linecache2==1.0.0 -more-itertools==7.2.0 packaging==23.2 -pbr==5.4.3 -pluggy==0.13.0 -py==1.11.0 pycryptodomex==3.19.1 pyelftools==0.27 pygit2==1.13.3 pyparsing==3.0.7 pytest==6.2.5 pytest-xdist==2.5.0 -python-mimeparse==1.6.0 -python-subunit==1.3.0 requests==2.31.0 setuptools==65.5.1 -six==1.16.0 -testtools==2.3.0 -traceback2==1.4.0 -unittest2==1.1.0 -wcwidth==0.1.7 -zipp==0.6.0
Bump python packages to reasonable versions to fix build error with Python 3.12.
Link: https://github.com/pytest-dev/pytest/pull/11094 Link: https://github.com/yaml/pyyaml/issues/736 Link: https://github.com/pypa/setuptools/issues/4002 Signed-off-by: Jiaxun Yang jiaxun.yang@flygoat.com --- test/py/requirements.txt | 6 +++--- tools/buildman/requirements.txt | 8 ++++---- 2 files changed, 7 insertions(+), 7 deletions(-)
diff --git a/test/py/requirements.txt b/test/py/requirements.txt index f24a842bfe6f..b7658d66665d 100644 --- a/test/py/requirements.txt +++ b/test/py/requirements.txt @@ -6,7 +6,7 @@ pycryptodomex==3.19.1 pyelftools==0.27 pygit2==1.13.3 pyparsing==3.0.7 -pytest==6.2.5 -pytest-xdist==2.5.0 +pytest==7.4.4 +pytest-xdist==3.6.1 requests==2.31.0 -setuptools==65.5.1 +setuptools==70 diff --git a/tools/buildman/requirements.txt b/tools/buildman/requirements.txt index 350da42c0ebf..2b40d8e2499a 100644 --- a/tools/buildman/requirements.txt +++ b/tools/buildman/requirements.txt @@ -1,4 +1,4 @@ -jsonschema==4.17.3 -pyyaml==6.0 -yamllint==1.26.3 -setuptools==65.5.1 +jsonschema==4.22.0 +pyyaml==6.0.1 +yamllint==1.35.1 +setuptools==70
Bump pylint to 3.2.3 as old versions are not working with python 3.12.
Clear warnings, mostly E0606: (possibly-used-before-assignment).
Signed-off-by: Jiaxun Yang jiaxun.yang@flygoat.com --- .azure-pipelines.yml | 2 +- .gitlab-ci.yml | 2 +- doc/develop/python_cq.rst | 4 ++-- test/py/tests/test_ums.py | 1 + test/py/tests/test_usb.py | 1 + tools/binman/etype/fdtmap.py | 1 + tools/binman/etype/fit.py | 1 + tools/binman/etype/image_header.py | 1 + tools/binman/etype/pre_load.py | 2 ++ tools/binman/etype/ti_board_config.py | 1 + tools/binman/etype/x509_cert.py | 1 + tools/binman/ftest.py | 1 + tools/binman/state.py | 1 + tools/buildman/builder.py | 2 ++ tools/microcode-tool.py | 1 + tools/patman/test_checkpatch.py | 2 ++ tools/qconfig.py | 1 + 17 files changed, 21 insertions(+), 4 deletions(-)
diff --git a/.azure-pipelines.yml b/.azure-pipelines.yml index 27f69583c655..37b569b13ab0 100644 --- a/.azure-pipelines.yml +++ b/.azure-pipelines.yml @@ -152,7 +152,7 @@ stages: export USER=azure pip install -r test/py/requirements.txt pip install -r tools/buildman/requirements.txt - pip install asteval pylint==2.12.2 pyopenssl + pip install asteval pylint==3.2.3 pyopenssl export PATH=${PATH}:~/.local/bin echo "[MASTER]" >> .pylintrc echo "load-plugins=pylint.extensions.docparams" >> .pylintrc diff --git a/.gitlab-ci.yml b/.gitlab-ci.yml index 165f765a8332..18c4c430c63d 100644 --- a/.gitlab-ci.yml +++ b/.gitlab-ci.yml @@ -214,7 +214,7 @@ Run pylint: - git config --global --add safe.directory "${CI_PROJECT_DIR}" - pip install -r test/py/requirements.txt - pip install -r tools/buildman/requirements.txt - - pip install asteval pylint==2.12.2 pyopenssl + - pip install asteval pylint==3.2.3 pyopenssl - export PATH=${PATH}:~/.local/bin - echo "[MASTER]" >> .pylintrc - echo "load-plugins=pylint.extensions.docparams" >> .pylintrc diff --git a/doc/develop/python_cq.rst b/doc/develop/python_cq.rst index 1e209ff197d6..c8a75a5b7a7b 100644 --- a/doc/develop/python_cq.rst +++ b/doc/develop/python_cq.rst @@ -23,7 +23,7 @@ regressions in any module. To run this locally you should use this version of pylint::
# pylint --version - pylint 2.11.1 + pylint 3.2.3 astroid 2.8.6 Python 3.8.10 (default, Sep 28 2021, 16:10:42) [GCC 9.3.0] @@ -31,7 +31,7 @@ To run this locally you should use this version of pylint::
You should be able to select and this install other required tools with::
- pip install pylint==2.11.1 + pip install pylint==3.2.3 pip install -r test/py/requirements.txt pip install asteval pyopenssl
diff --git a/test/py/tests/test_ums.py b/test/py/tests/test_ums.py index 749b1606235c..55372e42a928 100644 --- a/test/py/tests/test_ums.py +++ b/test/py/tests/test_ums.py @@ -118,6 +118,7 @@ def test_ums(u_boot_console, env__usb_dev_port, env__block_devs):
test_f = u_boot_utils.PersistentRandomFile(u_boot_console, 'ums.bin', 1024 * 1024); + mounted_test_fn = None if have_writable_fs_partition: mounted_test_fn = mount_point + '/' + mount_subdir + test_f.fn
diff --git a/test/py/tests/test_usb.py b/test/py/tests/test_usb.py index fb3d20f0826b..27105cd1d5e1 100644 --- a/test/py/tests/test_usb.py +++ b/test/py/tests/test_usb.py @@ -564,6 +564,7 @@ def test_usb_load(u_boot_console): part_detect = 1 addr = u_boot_utils.find_ram_base(u_boot_console)
+ file, size = 0, 0 if fs == 'fat': file, size = test_usb_fatload_fatwrite(u_boot_console) elif fs == 'ext4': diff --git a/tools/binman/etype/fdtmap.py b/tools/binman/etype/fdtmap.py index f1f6217940f2..6b4ca497f871 100644 --- a/tools/binman/etype/fdtmap.py +++ b/tools/binman/etype/fdtmap.py @@ -106,6 +106,7 @@ class Entry_fdtmap(Entry): Returns: FDT map binary data """ + fsw = None def _AddNode(node): """Add a node to the FDT map""" for pname, prop in node.props.items(): diff --git a/tools/binman/etype/fit.py b/tools/binman/etype/fit.py index 2c14b15b03cd..dfbb6de7b63e 100644 --- a/tools/binman/etype/fit.py +++ b/tools/binman/etype/fit.py @@ -808,6 +808,7 @@ class Entry_fit(Entry_section): data_size = fdt_util.GetInt(node, "data-size")
# Contents are inside the FIT + offset, size = 0, 0 if data_prop is not None: # GetOffset() returns offset of a fdt_property struct, # which has 3 fdt32_t members before the actual data. diff --git a/tools/binman/etype/image_header.py b/tools/binman/etype/image_header.py index 240118849580..3db8e61d23a2 100644 --- a/tools/binman/etype/image_header.py +++ b/tools/binman/etype/image_header.py @@ -62,6 +62,7 @@ class Entry_image_header(Entry):
def _GetHeader(self): image_pos = self.GetSiblingImagePos('fdtmap') + offset = 0xffffffff if image_pos == False: self.Raise("'image_header' section must have an 'fdtmap' sibling") elif image_pos is None: diff --git a/tools/binman/etype/pre_load.py b/tools/binman/etype/pre_load.py index 2e4c72359ff3..c095cf425c93 100644 --- a/tools/binman/etype/pre_load.py +++ b/tools/binman/etype/pre_load.py @@ -112,6 +112,8 @@ class Entry_pre_load(Entry_collection): # Compute the signature if padding_name is None: padding_name = "pkcs-1.5" + + padding, padding_args = None, {} if padding_name == "pss": salt_len = key.size_in_bytes() - hash_image.digest_size - 2 padding = pss diff --git a/tools/binman/etype/ti_board_config.py b/tools/binman/etype/ti_board_config.py index c10d66edcb15..33c7a351c4ea 100644 --- a/tools/binman/etype/ti_board_config.py +++ b/tools/binman/etype/ti_board_config.py @@ -118,6 +118,7 @@ class Entry_ti_board_config(Entry_section): Returns: array of bytes representing value """ + br = None size = 0 if (data_type == '#/definitions/u8'): size = 1 diff --git a/tools/binman/etype/x509_cert.py b/tools/binman/etype/x509_cert.py index 29630d1b86c8..763cb506399b 100644 --- a/tools/binman/etype/x509_cert.py +++ b/tools/binman/etype/x509_cert.py @@ -83,6 +83,7 @@ class Entry_x509_cert(Entry_collection): output_fname = tools.get_output_filename('cert.%s' % uniq) input_fname = tools.get_output_filename('input.%s' % uniq) config_fname = tools.get_output_filename('config.%s' % uniq) + stdout = None tools.write_file(input_fname, input_data) if type == 'generic': stdout = self.openssl.x509_cert( diff --git a/tools/binman/ftest.py b/tools/binman/ftest.py index 567849bbab0f..99fc606bd855 100644 --- a/tools/binman/ftest.py +++ b/tools/binman/ftest.py @@ -6293,6 +6293,7 @@ fdt fdtmap Extract the devicetree blob from the fdtmap re_name = re.compile('_binman_(u_boot_(.*))_prop_(.*)') for name, sym in syms.items(): msg = 'test' + expect_val = None val = elf.GetSymbolValue(sym, edata, msg) entry_m = re_name.match(name) if entry_m: diff --git a/tools/binman/state.py b/tools/binman/state.py index 45bae40c525a..f43be6d4ce6e 100644 --- a/tools/binman/state.py +++ b/tools/binman/state.py @@ -406,6 +406,7 @@ def CheckSetHashValue(node, get_data_func): hash_node = node.FindNode('hash') if hash_node: algo = hash_node.props.get('algo').value + data = None if algo == 'sha256': m = hashlib.sha256() m.update(get_data_func()) diff --git a/tools/buildman/builder.py b/tools/buildman/builder.py index f35175b4598d..c8ee00767f01 100644 --- a/tools/buildman/builder.py +++ b/tools/buildman/builder.py @@ -1066,6 +1066,7 @@ class Builder: printed_target = False for name in sorted(result): diff = result[name] + color = None if name.startswith('_'): continue if diff != 0: @@ -1326,6 +1327,7 @@ class Builder: for line in lines: if not line: continue + col = None if line[0] == '+': col = self.col.GREEN elif line[0] == '-': diff --git a/tools/microcode-tool.py b/tools/microcode-tool.py index 24c02c4fca14..5f0287736dc7 100755 --- a/tools/microcode-tool.py +++ b/tools/microcode-tool.py @@ -277,6 +277,7 @@ def MicrocodeTool(): if cmd not in commands: parser.error("Unknown command '%s'" % cmd)
+ date, license_text, microcodes = None, None, None if (not not options.mcfile) != (not not options.mcfile): parser.error("You must specify either header files or a microcode file, not both") if options.headerfile: diff --git a/tools/patman/test_checkpatch.py b/tools/patman/test_checkpatch.py index db7860f551d0..e2f596940d3d 100644 --- a/tools/patman/test_checkpatch.py +++ b/tools/patman/test_checkpatch.py @@ -530,4 +530,6 @@ index 0000000..2234c87
if __name__ == "__main__": unittest.main() + # pylint doesn't seem to find this + # pylint: disable=E1101 gitutil.RunTests() diff --git a/tools/qconfig.py b/tools/qconfig.py index 04118d942da6..2492b37444a3 100755 --- a/tools/qconfig.py +++ b/tools/qconfig.py @@ -873,6 +873,7 @@ def read_database(): all_defconfigs = set()
defconfig_db = collections.defaultdict(set) + defconfig = None for line in read_file(CONFIG_DATABASE): line = line.rstrip() if not line: # Separator between defconfigs
Newer lz4 util is not happy with any padding at end of file, it would abort with error message like:
Stream followed by undecodable data at position 43.
Workaround by skipping testCompUtilPadding test case and manually strip padding in testCompressSectionSize test case.
Signed-off-by: Jiaxun Yang jiaxun.yang@flygoat.com --- tools/binman/ftest.py | 7 +++++-- tools/binman/test/184_compress_section_size.dts | 1 + 2 files changed, 6 insertions(+), 2 deletions(-)
diff --git a/tools/binman/ftest.py b/tools/binman/ftest.py index 99fc606bd855..1107084bc058 100644 --- a/tools/binman/ftest.py +++ b/tools/binman/ftest.py @@ -4518,6 +4518,8 @@ class TestFunctional(unittest.TestCase): dtb.Scan() props = self._GetPropTree(dtb, ['offset', 'image-pos', 'size', 'uncomp-size']) + data = data[:0x30] + data = data.rstrip(b'\xff') orig = self._decompress(data) self.assertEqual(COMPRESS_DATA + U_BOOT_DATA, orig) expected = { @@ -6118,8 +6120,9 @@ fdt fdtmap Extract the devicetree blob from the fdtmap
def testCompUtilPadding(self): """Test padding of compression algorithms""" - # Skip zstd because it doesn't support padding - for bintool in [v for k,v in self.comp_bintools.items() if k != 'zstd']: + # Skip zstd and lz4 because they doesn't support padding + for bintool in [v for k,v in self.comp_bintools.items() + if not k in ['zstd', 'lz4']]: self._CheckBintool(bintool) data = bintool.compress(COMPRESS_DATA) self.assertNotEqual(COMPRESS_DATA, data) diff --git a/tools/binman/test/184_compress_section_size.dts b/tools/binman/test/184_compress_section_size.dts index 95ed30add1aa..1c1dbd5f580f 100644 --- a/tools/binman/test/184_compress_section_size.dts +++ b/tools/binman/test/184_compress_section_size.dts @@ -6,6 +6,7 @@ section { size = <0x30>; compress = "lz4"; + pad-byte = <0xff>; blob { filename = "compress"; };
event_dump.py relies on addr2line to obtain source location information, however newer addr2line is unable to determine line numbers for some functions.
With addr2line from binutils 2.34 we got:
Event type Id Source location -------------------- ------------------------------ ------------------------------ EVT_FT_FIXUP bootmeth_vbe_ft_fixup :? EVT_FT_FIXUP bootmeth_vbe_simple_ft_fixup :? EVT_LAST_STAGE_INIT install_smbios_table :? EVT_MISC_INIT_F sandbox_early_getopt_check arch/sandbox/cpu/start.c:61 EVT_TEST h_adder_simple :?
Which will fail the test.
Relax the source location regex to .*:.*, this is sufficent to show that addr2line is being called and returned a possible line number.
Signed-off-by: Jiaxun Yang jiaxun.yang@flygoat.com --- test/py/tests/test_event_dump.py | 10 +++++----- 1 file changed, 5 insertions(+), 5 deletions(-)
diff --git a/test/py/tests/test_event_dump.py b/test/py/tests/test_event_dump.py index e282c67335cd..e87825abcd1a 100644 --- a/test/py/tests/test_event_dump.py +++ b/test/py/tests/test_event_dump.py @@ -16,9 +16,9 @@ def test_event_dump(u_boot_console): out = util.run_and_log(cons, ['scripts/event_dump.py', sandbox]) expect = '''.*Event type Id Source location -------------------- ------------------------------ ------------------------------ -EVT_FT_FIXUP bootmeth_vbe_ft_fixup .*boot/vbe_request.c:.* -EVT_FT_FIXUP bootmeth_vbe_simple_ft_fixup .*boot/vbe_simple_os.c:.* -EVT_LAST_STAGE_INIT install_smbios_table .*lib/efi_loader/efi_smbios.c:.* -EVT_MISC_INIT_F sandbox_early_getopt_check .*arch/sandbox/cpu/start.c:.* -EVT_TEST h_adder_simple .*test/common/event.c:''' +EVT_FT_FIXUP bootmeth_vbe_ft_fixup .*:.* +EVT_FT_FIXUP bootmeth_vbe_simple_ft_fixup .*:.* +EVT_LAST_STAGE_INIT install_smbios_table .*:.* +EVT_MISC_INIT_F sandbox_early_getopt_check .*:.* +EVT_TEST h_adder_simple .*:''' assert re.match(expect, out, re.MULTILINE) is not None
As per armv7 arch spec, for A-profile CPU if translation is disabled, then the default memory type is Device(-nGnRnE) instead of Normal, which requires that alignment be enforced.
This means in some cases we can't perform unaligned access even after allow_unaligned is called.
We do have many platforms that didn't have translation enabled in U-Boot, and QEMU started to enforce this since 9.0.
Fix by using unaligned access helper for UTF-16 memory read/write to ensure we don't do any unaligned access in U-Boot.
Signed-off-by: Jiaxun Yang jiaxun.yang@flygoat.com --- lib/charset.c | 21 ++++++++++++--------- lib/efi_loader/efi_device_path.c | 11 ++--------- 2 files changed, 14 insertions(+), 18 deletions(-)
diff --git a/lib/charset.c b/lib/charset.c index 182c92a50c48..af5f3ad16d9b 100644 --- a/lib/charset.c +++ b/lib/charset.c @@ -11,6 +11,7 @@ #include <efi_loader.h> #include <errno.h> #include <malloc.h> +#include <asm/unaligned.h>
/** * codepage_437 - Unicode to codepage 437 translation table @@ -215,7 +216,7 @@ s32 utf16_get(const u16 **src) return -1; if (!**src) return 0; - code = **src; + code = get_unaligned_le16(*src); ++*src; if (code >= 0xDC00 && code <= 0xDFFF) return -1; @@ -242,12 +243,12 @@ int utf16_put(s32 code, u16 **dst) if ((code >= 0xD800 && code <= 0xDFFF) || code >= 0x110000) return -1; if (code < 0x10000) { - **dst = code; + put_unaligned_le16(code, *dst); } else { code -= 0x10000; - **dst = code >> 10 | 0xD800; + put_unaligned_le16(code >> 10 | 0xD800, *dst); ++*dst; - **dst = (code & 0x3ff) | 0xDC00; + put_unaligned_le16((code & 0x3ff) | 0xDC00, *dst); } ++*dst; return 0; @@ -392,7 +393,7 @@ int __efi_runtime u16_strncmp(const u16 *s1, const u16 *s2, size_t n) int ret = 0;
for (; n; --n, ++s1, ++s2) { - ret = *s1 - *s2; + ret = get_unaligned_le16(s1) - get_unaligned_le16(s2); if (ret || !*s1) break; } @@ -403,7 +404,7 @@ int __efi_runtime u16_strncmp(const u16 *s1, const u16 *s2, size_t n) size_t __efi_runtime u16_strnlen(const u16 *in, size_t count) { size_t i; - for (i = 0; count-- && in[i]; i++); + for (i = 0; count-- && get_unaligned_le16(in + i); i++); return i; }
@@ -417,8 +418,10 @@ u16 *u16_strcpy(u16 *dest, const u16 *src) u16 *tmp = dest;
for (;; dest++, src++) { - *dest = *src; - if (!*src) + u16 code = get_unaligned_le16(src); + + put_unaligned_le16(code, dest); + if (!code) break; }
@@ -463,7 +466,7 @@ uint8_t *utf16_to_utf8(uint8_t *dest, const uint16_t *src, size_t size) uint32_t code_high = 0;
while (size--) { - uint32_t code = *src++; + uint32_t code = get_unaligned_le16(src++);
if (code_high) { if (code >= 0xDC00 && code <= 0xDFFF) { diff --git a/lib/efi_loader/efi_device_path.c b/lib/efi_loader/efi_device_path.c index aec224d84662..481f9effdb6d 100644 --- a/lib/efi_loader/efi_device_path.c +++ b/lib/efi_loader/efi_device_path.c @@ -18,7 +18,7 @@ #include <efi_loader.h> #include <part.h> #include <uuid.h> -#include <asm-generic/unaligned.h> +#include <asm/unaligned.h> #include <linux/compat.h> /* U16_MAX */
/* template END node: */ @@ -867,13 +867,6 @@ static void path_to_uefi(void *uefi, const char *src) { u16 *pos = uefi;
- /* - * efi_set_bootdev() calls this routine indirectly before the UEFI - * subsystem is initialized. So we cannot assume unaligned access to be - * enabled. - */ - allow_unaligned(); - while (*src) { s32 code = utf8_get(&src);
@@ -883,7 +876,7 @@ static void path_to_uefi(void *uefi, const char *src) code = '\'; utf16_put(code, &pos); } - *pos = 0; + put_unaligned_le16(0, pos); }
The default value CYCLIC_MAX_CPU_TIME_US was 1000, which is a little bit too low for slower hardware and sandbox.
On my MIPS Boston FPGA board with interaptiv CPU, wdt_cyclic can easily take 3200 us to run.
On azure pipeline sandbox_clang, wdt_cyclic some times goes beyond 1300 us.
Raise default value to 5000, which is the value already taken by octeon_nic32. This is still sufficent to maintain system responsiveness.
Signed-off-by: Jiaxun Yang jiaxun.yang@flygoat.com --- common/Kconfig | 2 +- configs/octeon_nic23_defconfig | 1 - 2 files changed, 1 insertion(+), 2 deletions(-)
diff --git a/common/Kconfig b/common/Kconfig index 5e3070e92539..4bb9f08977aa 100644 --- a/common/Kconfig +++ b/common/Kconfig @@ -628,7 +628,7 @@ if CYCLIC
config CYCLIC_MAX_CPU_TIME_US int "Sets the max allowed time for a cyclic function in us" - default 1000 + default 5000 help The max allowed time for a cyclic function in us. If a functions takes longer than this duration this function will get unregistered diff --git a/configs/octeon_nic23_defconfig b/configs/octeon_nic23_defconfig index f7c35536a021..5a8db5a0876b 100644 --- a/configs/octeon_nic23_defconfig +++ b/configs/octeon_nic23_defconfig @@ -25,7 +25,6 @@ CONFIG_SYS_PBSIZE=276 CONFIG_SYS_CONSOLE_ENV_OVERWRITE=y # CONFIG_SYS_DEVICE_NULLDEV is not set CONFIG_CYCLIC=y -CONFIG_CYCLIC_MAX_CPU_TIME_US=5000 CONFIG_ARCH_MISC_INIT=y CONFIG_BOARD_EARLY_INIT_F=y CONFIG_BOARD_LATE_INIT=y
This seems similar to: https://patchwork.ozlabs.org/project/uboot/patch/20240524210817.1953298-1-ra...
at least for CI. And for outside CI, I'm OK with just having the value be changed in the defconfig as needed. We do support using config fragments, so keeping such changes locally isn't too hard.
在2024年6月12日六月 下午5:00,Tom Rini写道: [...]
So the default value is a little bit too hard even for some of the actual hardware.
I think being permissive here can prevent people hit into the problem only after enabling cyclic on their own board.
Thanks
-- Tom
附件:
- signature.asc
Right, there's some platforms where it's too small and we should just bump it up. I think for now the default is what we want it to be for most platforms.
The current default value is definitely too small, especially when CI is involved (I did not have this in mind when implementing), so:
Acked-by: Stefan Roese sr@denx.de
Thanks, Stefan
Can we please get either this, or https://patchwork.ozlabs.org/project/uboot/patch/20240524210817.1953298-1-ra... merged for master? The number of false negatives in CI due to this is big issue for getting more contributors to use CI. Thanks.
在2024年6月18日六月 上午12:29,Tom Rini写道: [...]
It seems like CYCLIC doesn't have it's own custodian tree. How are we going to handle it in this case?
Thanks - Jiaxun
-- Tom
附件:
- signature.asc
Hi Jiaxun,
I've already pulled this patch. I introduced the cyclic framework some time ago and as it's closely related to the watchdog stuff, I'm currently handling these patches as well.
Thanks, Stefan
Note that in U-Boot it's less important to have a tree per sub-section and more important that custodians have a tree (and then use appropriate tags when sending pull requests).
-- Tom
Stefan and Tom,
I'm seeing CI issues here even with 5000us [1]: host bind 0 /tmp/sandbox/persistent-cyclic function wdt-gpio-level took too long: 5368us vs 5000us max
Best Regards,
Tim [1] https://dev.azure.com/u-boot/u-boot/_build/results?buildId=8737&view=log...
Stefan and Tom,
Yes, 5ms is way too little when you're not the only thing running on the cpu, which is why I went with 100ms.
Random thoughts and questions:
(1) Do we have any way to programmatically grab all the logs from azure CI, so we can get some kind of objective statistics on the number after "took too long:". Clicking through the web interface and randomly searching is too painful.
It would also be helpful to know what percentage of CI runs have failed due to that, versus due to some genuine error.
(2) I considered a patch that just added a
default $something big if SANDBOX
to config CYCLIC_MAX_CPU_TIME_US, but since the problem also hit qemu, I dropped that. But, if my patch is too ugly (and I might tend to think that myself...), perhaps at least this would be an added improvement over the generic bump to 5000us.
(3) I also thought that perhaps for sandbox, we should simply measure the time using clock_gettime(CLOCK_PROCESS_CPUTIME_ID), instead of wallclock time. But it's a little ugly to implement since the "now" variable is both used to decide if its time to run the callback, and as a starting point for measuring cpu time, and we probably still want the "is it time" to be measured on wallclock and not however much cpu-time the u-boot process has been given. Or maybe we don't, and CLOCK_PROCESS_CPUTIME_ID would simply be a better backend for os_get_nsec(). Sure, time in the sandbox would progress slower than on the host, but does that actually matter?
(4) Btw., what kind of clock tick do we even get when run under qemu? I don't have much experience with qemu, but from quick googling it seems that -icount would be interesting. Also see https://github.com/zephyrproject-rtos/zephyr/issues/14173 . From quick reading it seems there were some issues back in 2019, but that today it mostly works for them, except some SMP issues (that are certainly not relevant to U-Boot).
The current situation is a frustrating waste of developer and maintainer time and CI resources.
Rasmus
Stefan and Tom,
I don't think we can easily grab logs via API. And at least for https://dev.azure.com/u-boot/u-boot/_build?definitionId=2&_a=summary a lot of the failures have rolled off already because we only get so many logs and I try and mark full release logs as keep forever. But anecdotally I can say 75%+ of the Azure runs fail at least once due to this, and most fail enough to fail the pipeline (we get 2 tries per job).
I was fine with your approach really, maybe a bit bigger of a comment and note under doc/ as well why we do it?
That could be interesting too, yeah. I do worry it might open its own set of problems to figure out tho.
Yes.
Applied to u-boot-watchdog/master
Thanks, Stefan
Since Ubuntu focal it's nolonger permitted to perform global pip install.
Ensure that pip install is always performed in venv. For buildman alone, all dependencies are already in docker so there is no need to perform pip install.
Signed-off-by: Jiaxun Yang jiaxun.yang@flygoat.com --- .azure-pipelines.yml | 16 ++++++++++------ .gitlab-ci.yml | 13 ++++++++----- 2 files changed, 18 insertions(+), 11 deletions(-)
diff --git a/.azure-pipelines.yml b/.azure-pipelines.yml index 37b569b13ab0..2506814725e1 100644 --- a/.azure-pipelines.yml +++ b/.azure-pipelines.yml @@ -150,6 +150,8 @@ stages: - script: | git config --global --add safe.directory $(work_dir) export USER=azure + virtualenv -p /usr/bin/python3 /tmp/venv + . /tmp/venv/bin/activate pip install -r test/py/requirements.txt pip install -r tools/buildman/requirements.txt pip install asteval pylint==3.2.3 pyopenssl @@ -183,7 +185,10 @@ stages: image: $(ci_runner_image) options: $(container_option) steps: - - script: make pip + - script: | + virtualenv -p /usr/bin/python3 /tmp/venv + . /tmp/venv/bin/activate + make pip
- job: create_test_py_wrapper_script displayName: 'Create and stage a wrapper for test.py runs' @@ -217,7 +222,11 @@ stages: if [ -n "${BUILD_ENV}" ]; then export ${BUILD_ENV}; fi + virtualenv -p /usr/bin/python3 /tmp/venv + . /tmp/venv/bin/activate pip install -r tools/buildman/requirements.txt + pip install -r test/py/requirements.txt + pip install pytest-azurepipelines tools/buildman/buildman -o ${UBOOT_TRAVIS_BUILD_DIR} -w -E -W -e --board ${TEST_PY_BD} ${OVERRIDE} cp ~/grub_x86.efi ${UBOOT_TRAVIS_BUILD_DIR}/ cp ~/grub_x64.efi ${UBOOT_TRAVIS_BUILD_DIR}/ @@ -241,10 +250,6 @@ stages: /opt/coreboot/cbfstool ${UBOOT_TRAVIS_BUILD_DIR}/coreboot.rom remove -n fallback/payload; /opt/coreboot/cbfstool ${UBOOT_TRAVIS_BUILD_DIR}/coreboot.rom add-flat-binary -f ${UBOOT_TRAVIS_BUILD_DIR}/u-boot.bin -n fallback/payload -c LZMA -l 0x1110000 -e 0x1110000; fi - virtualenv -p /usr/bin/python3 /tmp/venv - . /tmp/venv/bin/activate - pip install -r test/py/requirements.txt - pip install pytest-azurepipelines export PATH=/opt/qemu/bin:/tmp/uboot-test-hooks/bin:${PATH} export PYTHONPATH=/tmp/uboot-test-hooks/py/travis-ci # "${var:+"-k $var"}" expands to "" if $var is empty, "-k $var" if not @@ -504,7 +509,6 @@ stages: # make environment variables available as tests are running inside a container export BUILDMAN="${BUILDMAN}" git config --global --add safe.directory ${WORK_DIR} - pip install -r tools/buildman/requirements.txt EOF cat << "EOF" >> build.sh if [[ "${BUILDMAN}" != "" ]]; then diff --git a/.gitlab-ci.yml b/.gitlab-ci.yml index 18c4c430c63d..4c17abea468a 100644 --- a/.gitlab-ci.yml +++ b/.gitlab-ci.yml @@ -50,6 +50,10 @@ stages: - if [ -n "${BUILD_ENV}" ]; then export ${BUILD_ENV}; fi + - virtualenv -p /usr/bin/python3 /tmp/venv + - . /tmp/venv/bin/activate + - pip install -r tools/buildman/requirements.txt + - pip install -r test/py/requirements.txt - tools/buildman/buildman -o ${UBOOT_TRAVIS_BUILD_DIR} -w -E -W -e --board ${TEST_PY_BD} ${OVERRIDE} - cp ~/grub_x86.efi $UBOOT_TRAVIS_BUILD_DIR/ @@ -74,9 +78,6 @@ stages: /opt/coreboot/cbfstool ${UBOOT_TRAVIS_BUILD_DIR}/coreboot.rom remove -n fallback/payload; /opt/coreboot/cbfstool ${UBOOT_TRAVIS_BUILD_DIR}/coreboot.rom add-flat-binary -f ${UBOOT_TRAVIS_BUILD_DIR}/u-boot.bin -n fallback/payload -c LZMA -l 0x1110000 -e 0x1110000; fi - - virtualenv -p /usr/bin/python3 /tmp/venv - - . /tmp/venv/bin/activate - - pip install -r test/py/requirements.txt # "${var:+"-k $var"}" expands to "" if $var is empty, "-k $var" if not - export PATH=/opt/qemu/bin:/tmp/uboot-test-hooks/bin:${PATH}; export PYTHONPATH=/tmp/uboot-test-hooks/py/travis-ci; @@ -100,7 +101,6 @@ build all 32bit ARM platforms: script: - ret=0; git config --global --add safe.directory "${CI_PROJECT_DIR}"; - pip install -r tools/buildman/requirements.txt; ./tools/buildman/buildman -o /tmp -PEWM arm -x aarch64 || ret=$?; if [[ $ret -ne 0 ]]; then ./tools/buildman/buildman -o /tmp -seP; @@ -114,7 +114,6 @@ build all 64bit ARM platforms: - . /tmp/venv/bin/activate - ret=0; git config --global --add safe.directory "${CI_PROJECT_DIR}"; - pip install -r tools/buildman/requirements.txt; ./tools/buildman/buildman -o /tmp -PEWM aarch64 || ret=$?; if [[ $ret -ne 0 ]]; then ./tools/buildman/buildman -o /tmp -seP; @@ -212,6 +211,8 @@ Run pylint: extends: .testsuites script: - git config --global --add safe.directory "${CI_PROJECT_DIR}" + - virtualenv -p /usr/bin/python3 /tmp/venv; + - . /tmp/venv/bin/activate; - pip install -r test/py/requirements.txt - pip install -r tools/buildman/requirements.txt - pip install asteval pylint==3.2.3 pyopenssl @@ -240,6 +241,8 @@ Check for pre-schema tags: Check packing of Python tools: extends: .testsuites script: + - virtualenv -p /usr/bin/python3 /tmp/venv; + - . /tmp/venv/bin/activate; - make pip
# Test sandbox with test.py
Current build_world task runs for too long on public gitlab runner.
Split the job as what we've done to azure pipeline.
Signed-off-by: Jiaxun Yang jiaxun.yang@flygoat.com --- .gitlab-ci.yml | 103 +++++++++++++++++++++++++++++++++------------------------ 1 file changed, 59 insertions(+), 44 deletions(-)
diff --git a/.gitlab-ci.yml b/.gitlab-ci.yml index 4c17abea468a..efb84c3b119f 100644 --- a/.gitlab-ci.yml +++ b/.gitlab-ci.yml @@ -91,56 +91,71 @@ stages: - "*.css" expire_in: 1 week
-.world_build: +.world_build_template: &world_build_dfn stage: world build rules: - when: always - -build all 32bit ARM platforms: - extends: .world_build - script: - - ret=0; - git config --global --add safe.directory "${CI_PROJECT_DIR}"; - ./tools/buildman/buildman -o /tmp -PEWM arm -x aarch64 || ret=$?; - if [[ $ret -ne 0 ]]; then - ./tools/buildman/buildman -o /tmp -seP; - exit $ret; - fi; - -build all 64bit ARM platforms: - extends: .world_build - script: - - virtualenv -p /usr/bin/python3 /tmp/venv - - . /tmp/venv/bin/activate - - ret=0; - git config --global --add safe.directory "${CI_PROJECT_DIR}"; - ./tools/buildman/buildman -o /tmp -PEWM aarch64 || ret=$?; - if [[ $ret -ne 0 ]]; then - ./tools/buildman/buildman -o /tmp -seP; - exit $ret; - fi; - -build all PowerPC platforms: - extends: .world_build script: - ret=0; git config --global --add safe.directory "${CI_PROJECT_DIR}"; - ./tools/buildman/buildman -o /tmp -P -E -W powerpc || ret=$?; - if [[ $ret -ne 0 ]]; then - ./tools/buildman/buildman -o /tmp -seP; - exit $ret; - fi; - -build all other platforms: - extends: .world_build - script: - - ret=0; - git config --global --add safe.directory "${CI_PROJECT_DIR}"; - ./tools/buildman/buildman -o /tmp -PEWM -x arm,powerpc || ret=$?; - if [[ $ret -ne 0 ]]; then - ./tools/buildman/buildman -o /tmp -seP; - exit $ret; - fi; + if [[ "${BUILDMAN}" != "" ]]; then + ret=0; + tools/buildman/buildman -o /tmp -PEWM ${BUILDMAN} ${OVERRIDE} || ret=$?; + if [[ $ret -ne 0 ]]; then + tools/buildman/buildman -o /tmp -seP ${BUILDMAN}; + exit $ret; + fi; + fi + +am33xx_at91_kirkwood_mvebu_omap: + variables: + BUILDMAN: "am33xx at91_kirkwood mvebu omap -x siemens" + <<: *world_build_dfn + +amlogic_bcm_boundary_engicam_siemens_technexion_oradex: + variables: + BUILDMAN: "amlogic bcm boundary engicam siemens technexion toradex -x mips" + <<: *world_build_dfn + +arm_nxp_minus_imx: + variables: + BUILDMAN: "freescale -x powerpc,m68k,imx,mx" + <<: *world_build_dfn + +imx: + variables: + BUILDMAN: "mx imx -x boundary,engicam,technexion,toradex" + <<: *world_build_dfn + +rk: + variables: + BUILDMAN: "rk" + <<: *world_build_dfn + +sunxi: + variables: + BUILDMAN: "sunxi" + <<: *world_build_dfn + +powerpc: + variables: + BUILDMAN: "powerpc" + <<: *world_build_dfn + +arm_catch_all: + variables: + BUILDMAN: "arm -x aarch64,am33xx,at91,bcm,ls1,kirkwood,mvebu,omap,rk,siemens,mx,sunxi,technexion,toradex" + <<: *world_build_dfn + +aarch64_catch_all: + variables: + BUILDMAN: "aarch64 -x amlogic,bcm,engicam,imx,ls1,ls2,lx216,mvebu,rk,siemens,sunxi,toradex" + <<: *world_build_dfn + +everything_but_arm_and_powerpc: + variables: + BUILDMAN: "-x arm,powerpc" + <<: *world_build_dfn
.testsuites: stage: testsuites
I don't like this. The list in Azure is because of the time limits there and in turn we: a) Have to tweak it periodically to keep things from running too long b) Have to tweak it to ensure that we don't miss some new SoC/etc
在2024年6月12日六月 下午5:01,Tom Rini写道:
Then it will render running CI test on gitlab.com impossible again :-(
Thanks
-- Tom
附件:
- signature.asc
Yeah, it's not something I'm the happiest with. Looking around a bit, I see a blog post that talks about dealing with dynamic variables, in Azure. So we could, I think, figure out some logic to have each build stage say what platforms it covers. And then have a final step that compares all of the platforms built vs the global list (just tools/buildman/buildman --dry-run -v) to make sure nothing was missed. With something like that, and assuming GitLab can do it too (it probably can), I'm OK with having the world build be broken down to 10 groups (maximum number of parallel jobs in Azure CI for free) since we'll know if we miss something too.
So lets set this patch (and the doc update) aside for now, unless you want to look at the above. I'll look at the above soon.
Hi Tom,
Could we hook up one of our machines as a public runner somehow?
On Wed, Jun 12, 2024 at 02:24:24PM -0600, Simon Glass wrote:
Hi Tom,
It's a pool of free runners, ala Azure. I don't think we can, no, and I don't want to make all of our runners available on public CI either, they're a bit over-whelmed as it is I think once custodians start working.
Set global git name & email config so we don't have to setup it for every project.
Signed-off-by: Jiaxun Yang jiaxun.yang@flygoat.com --- tools/docker/Dockerfile | 9 ++++----- 1 file changed, 4 insertions(+), 5 deletions(-)
diff --git a/tools/docker/Dockerfile b/tools/docker/Dockerfile index cda87354566d..5824d371f259 100644 --- a/tools/docker/Dockerfile +++ b/tools/docker/Dockerfile @@ -121,6 +121,10 @@ RUN apt-get update && apt-get install -y \ zip \ && rm -rf /var/lib/apt/lists/*
+# Setup Git +RUN git config --global user.name "U-Boot CI" && \ + git config --global user.email u-boot@denx.de + # Make kernels readable for libguestfs tools to work correctly RUN chmod +r /boot/vmlinu*
@@ -128,8 +132,6 @@ RUN chmod +r /boot/vmlinu* RUN git clone git://git.savannah.gnu.org/grub.git /tmp/grub && \ cd /tmp/grub && \ git checkout grub-2.06 && \ - git config --global user.name "GitLab CI Runner" && \ - git config --global user.email trini@konsulko.com && \ git cherry-pick 049efdd72eb7baa7b2bf8884391ee7fe650da5a0 && \ git cherry-pick 403d6540cd608b2706cfa0cb4713f7e4b490ff45 && \ ./bootstrap && \ @@ -180,9 +182,6 @@ RUN git clone git://git.savannah.gnu.org/grub.git /tmp/grub && \ RUN git clone https://gitlab.com/qemu-project/qemu.git /tmp/qemu && \ cd /tmp/qemu && \ git checkout v8.2.0 && \ - # config user.name and user.email to make 'git am' happy - git config user.name u-boot && \ - git config user.email u-boot@denx.de && \ git format-patch 0c7ffc977195~..0c7ffc977195 && \ git am 0001-hw-net-cadence_gem-Fix-MDIO_OP_xxx-values.patch && \ git cherry-pick d3c79c3974 && \
Bump base OS to Ubuntu noble, grub to 2.12, QEMU to 9.0 (drop cherry-pick for m68k as it's already in 9.0) and other tools to latest version.
Remove unsupported python2.
Install some required python packages for buildman/binman.
Signed-off-by: Jiaxun Yang jiaxun.yang@flygoat.com --- tools/docker/Dockerfile | 35 +++++++++++++++++------------------ 1 file changed, 17 insertions(+), 18 deletions(-)
diff --git a/tools/docker/Dockerfile b/tools/docker/Dockerfile index 5824d371f259..e3b2c2d57555 100644 --- a/tools/docker/Dockerfile +++ b/tools/docker/Dockerfile @@ -2,7 +2,7 @@ # This Dockerfile is used to build an image containing basic stuff to be used # to build U-Boot and run our test suites.
-FROM ubuntu:jammy-20240227 +FROM ubuntu:noble MAINTAINER Tom Rini trini@konsulko.com LABEL Description=" This image is for building U-Boot inside a container"
@@ -12,7 +12,7 @@ ENV DEBIAN_FRONTEND=noninteractive # Add LLVM repository RUN apt-get update && apt-get install -y gnupg2 wget xz-utils && rm -rf /var/lib/apt/lists/* RUN wget -O - https://apt.llvm.org/llvm-snapshot.gpg.key | apt-key add - -RUN echo deb http://apt.llvm.org/jammy/ llvm-toolchain-jammy-17 main | tee /etc/apt/sources.list.d/llvm.list +RUN echo deb http://apt.llvm.org/noble/ llvm-toolchain-noble-17 main | tee /etc/apt/sources.list.d/llvm.list
# Manually install the kernel.org "Crosstool" based toolchains for gcc-13.2.0 RUN wget -O - https://mirrors.edge.kernel.org/pub/tools/crosstool/files/bin/x86_64/13.2.0/... | tar -C /opt -xJ @@ -55,6 +55,7 @@ RUN apt-get update && apt-get install -y \ gawk \ gdisk \ git \ + gnat \ gnu-efi \ gnutls-dev \ graphviz \ @@ -95,13 +96,14 @@ RUN apt-get update && apt-get install -y \ parted \ pkg-config \ python-is-python3 \ - python2.7 \ python3 \ python3-dev \ + python3-jsonschema \ python3-pip \ python3-pyelftools \ python3-sphinx \ python3-virtualenv \ + python3-yaml \ rpm2cpio \ sbsigntool \ socat \ @@ -118,6 +120,7 @@ RUN apt-get update && apt-get install -y \ vboot-utils \ xilinx-bootgen \ xxd \ + yamllint \ zip \ && rm -rf /var/lib/apt/lists/*
@@ -131,9 +134,7 @@ RUN chmod +r /boot/vmlinu* # Build GRUB UEFI targets for ARM & RISC-V, 32-bit and 64-bit RUN git clone git://git.savannah.gnu.org/grub.git /tmp/grub && \ cd /tmp/grub && \ - git checkout grub-2.06 && \ - git cherry-pick 049efdd72eb7baa7b2bf8884391ee7fe650da5a0 && \ - git cherry-pick 403d6540cd608b2706cfa0cb4713f7e4b490ff45 && \ + git checkout grub-2.12 && \ ./bootstrap && \ mkdir -p /opt/grub && \ ./configure --target=aarch64 --with-platform=efi \ @@ -181,10 +182,7 @@ RUN git clone git://git.savannah.gnu.org/grub.git /tmp/grub && \
RUN git clone https://gitlab.com/qemu-project/qemu.git /tmp/qemu && \ cd /tmp/qemu && \ - git checkout v8.2.0 && \ - git format-patch 0c7ffc977195~..0c7ffc977195 && \ - git am 0001-hw-net-cadence_gem-Fix-MDIO_OP_xxx-values.patch && \ - git cherry-pick d3c79c3974 && \ + git checkout v9.0.0 && \ ./configure --prefix=/opt/qemu --target-list="aarch64-softmmu,arm-softmmu,i386-softmmu,m68k-softmmu,mips-softmmu,mips64-softmmu,mips64el-softmmu,mipsel-softmmu,ppc-softmmu,riscv32-softmmu,riscv64-softmmu,sh4-softmmu,x86_64-softmmu,xtensa-softmmu" && \ make -j$(nproc) all install && \ rm -rf /tmp/qemu @@ -192,7 +190,7 @@ RUN git clone https://gitlab.com/qemu-project/qemu.git /tmp/qemu && \ # Build fiptool RUN git clone https://git.trustedfirmware.org/TF-A/trusted-firmware-a.git /tmp/tf-a && \ cd /tmp/tf-a/ && \ - git checkout v2.10.0 && \ + git checkout lts-v2.10.4 && \ cd tools/fiptool && \ make && \ mkdir -p /usr/local/bin && \ @@ -200,12 +198,12 @@ RUN git clone https://git.trustedfirmware.org/TF-A/trusted-firmware-a.git /tmp/t rm -rf /tmp/tf-a
# Build genimage (required by some targets to generate disk images) -RUN wget -O - https://github.com/pengutronix/genimage/releases/download/v14/genimage-14.ta... | tar -C /tmp -xJ && \ - cd /tmp/genimage-14 && \ +RUN wget -O - https://github.com/pengutronix/genimage/releases/download/v17/genimage-17.ta... | tar -C /tmp -xJ && \ + cd /tmp/genimage-17 && \ ./configure && \ make -j$(nproc) && \ make install && \ - rm -rf /tmp/genimage-14 + rm -rf /tmp/genimage-17
# Build libtpms RUN git clone https://github.com/stefanberger/libtpms /tmp/libtpms && \ @@ -236,22 +234,23 @@ RUN mkdir /tmp/trace && \ cd /tmp/trace/libtracefs && \ make -j$(nproc) && \ sudo make install && \ - git clone https://github.com/rostedt/trace-cmd.git /tmp/trace/trace-cmd && \ + git clone https://git.kernel.org/pub/scm/utils/trace-cmd/trace-cmd.git /tmp/trace/trace-cmd && \ cd /tmp/trace/trace-cmd && \ make -j$(nproc) && \ sudo make install && \ rm -rf /tmp/trace
# Build coreboot -RUN wget -O - https://coreboot.org/releases/coreboot-4.22.01.tar.xz | tar -C /tmp -xJ && \ - cd /tmp/coreboot-4.22.01 && \ +RUN wget -O - https://coreboot.org/releases/coreboot-24.05.tar.xz | tar -C /tmp -xJ && \ + cd /tmp/coreboot-24.05 && \ make crossgcc-i386 CPUS=$(nproc) && \ make -C payloads/coreinfo olddefconfig && \ make -C payloads/coreinfo && \ make olddefconfig && \ make -j $(nproc) && \ sudo mkdir /opt/coreboot && \ - sudo cp build/coreboot.rom build/cbfstool /opt/coreboot/ + sudo cp build/coreboot.rom build/cbfstool /opt/coreboot/ && \ + rm -rf /tmp/coreboot-24.05
# Create our user/group RUN echo uboot ALL=NOPASSWD: ALL > /etc/sudoers.d/uboot
For reproducibility I keep us on date-tags and not just the raw release tag/latest. Also, I'm not yet ready to move us past Jammy without a big reason. Once 24.04.1 comes out, perhaps. So it's good to know at least this wasn't too much work to move forward. Also, we should keep the bumping of various tools to their own commit, each.
在2024年6月12日六月 下午5:02,Tom Rini写道: [...]
Ok, I'll add tag back.
My purpose to move CI to noble is to test against all new pieces of software. I was hit by those issues when I was trying to run tests locally with my ArchLinux PC, so I decided to fix them and bump CI to ensure we don't introduce more in future.
I think as we can pass all CI runs it's good to move forward :-)
Thanks
-- Tom
附件:
- signature.asc
Install LoongArch64 toolchains, build LoongArch64 QEMU, build LoongArch64 GRUB.
Signed-off-by: Jiaxun Yang jiaxun.yang@flygoat.com --- tools/docker/Dockerfile | 21 +++++++++++++++++++-- 1 file changed, 19 insertions(+), 2 deletions(-)
diff --git a/tools/docker/Dockerfile b/tools/docker/Dockerfile index e3b2c2d57555..26b0e36fec05 100644 --- a/tools/docker/Dockerfile +++ b/tools/docker/Dockerfile @@ -19,6 +19,7 @@ RUN wget -O - https://mirrors.edge.kernel.org/pub/tools/crosstool/files/bin/x86_ RUN wget -O - https://mirrors.edge.kernel.org/pub/tools/crosstool/files/bin/x86_64/13.2.0/... | tar -C /opt -xJ RUN wget -O - https://mirrors.edge.kernel.org/pub/tools/crosstool/files/bin/x86_64/13.2.0/... | tar -C /opt -xJ RUN wget -O - https://mirrors.edge.kernel.org/pub/tools/crosstool/files/bin/x86_64/13.2.0/... | tar -C /opt -xJ +RUN wget -O - https://mirrors.edge.kernel.org/pub/tools/crosstool/files/bin/x86_64/13.2.0/... | tar -C /opt -xJ RUN wget -O - https://mirrors.edge.kernel.org/pub/tools/crosstool/files/bin/x86_64/13.2.0/... | tar -C /opt -xJ RUN wget -O - https://mirrors.edge.kernel.org/pub/tools/crosstool/files/bin/x86_64/13.2.0/... | tar -C /opt -xJ RUN wget -O - https://mirrors.edge.kernel.org/pub/tools/crosstool/files/bin/x86_64/13.2.0/... | tar -C /opt -xJ @@ -131,7 +132,7 @@ RUN git config --global user.name "U-Boot CI" && \ # Make kernels readable for libguestfs tools to work correctly RUN chmod +r /boot/vmlinu*
-# Build GRUB UEFI targets for ARM & RISC-V, 32-bit and 64-bit +# Build GRUB UEFI targets for ARM & LoongArch64 & RISC-V, 32-bit and 64-bit RUN git clone git://git.savannah.gnu.org/grub.git /tmp/grub && \ cd /tmp/grub && \ git checkout grub-2.12 && \ @@ -165,6 +166,20 @@ RUN git clone git://git.savannah.gnu.org/grub.git /tmp/grub && \ search search_fs_file search_fs_uuid search_label serial sleep test \ true && \ make clean && \ + ./configure --target=loongarch64 --with-platform=efi \ + CC=gcc \ + TARGET_CC=/opt/gcc-13.2.0-nolibc/loongarch64-linux/bin/loongarch64-linux-gcc \ + TARGET_OBJCOPY=/opt/gcc-13.2.0-nolibc/loongarch64-linux/bin/loongarch64-linux-objcopy \ + TARGET_STRIP=/opt/gcc-13.2.0-nolibc/loongarch64-linux/bin/loongarch64-linux-strip \ + TARGET_NM=/opt/gcc-13.2.0-nolibc/loongarch64-linux/bin/loongarch64-linux-nm \ + TARGET_RANLIB=/opt/gcc-13.2.0-nolibc/loongarch64-linux/bin/loongarch64-linux-ranlib && \ + make && \ + ./grub-mkimage -O loongarch64-efi -o /opt/grub/grubloongarch64.efi --prefix= -d \ + grub-core cat chain configfile echo efinet ext2 fat halt help linux \ + lsefisystab loadenv lvm minicmd normal part_msdos part_gpt reboot \ + search search_fs_file search_fs_uuid search_label serial sleep test \ + true && \ + make clean && \ ./configure --target=riscv64 --with-platform=efi \ CC=gcc \ TARGET_CC=/opt/gcc-13.2.0-nolibc/riscv64-linux/bin/riscv64-linux-gcc \ @@ -183,7 +198,9 @@ RUN git clone git://git.savannah.gnu.org/grub.git /tmp/grub && \ RUN git clone https://gitlab.com/qemu-project/qemu.git /tmp/qemu && \ cd /tmp/qemu && \ git checkout v9.0.0 && \ - ./configure --prefix=/opt/qemu --target-list="aarch64-softmmu,arm-softmmu,i386-softmmu,m68k-softmmu,mips-softmmu,mips64-softmmu,mips64el-softmmu,mipsel-softmmu,ppc-softmmu,riscv32-softmmu,riscv64-softmmu,sh4-softmmu,x86_64-softmmu,xtensa-softmmu" && \ + git cherry-pick 16b1ecee52effa3346fb34dcc351e4645e4ab53e && \ + git cherry-pick 085446905000d6b80978815594a7cd34d54ff46b && \ + ./configure --prefix=/opt/qemu --target-list="aarch64-softmmu,arm-softmmu,i386-softmmu,loongarch64-softmmu,m68k-softmmu,mips-softmmu,mips64-softmmu,mips64el-softmmu,mipsel-softmmu,ppc-softmmu,riscv32-softmmu,riscv64-softmmu,sh4-softmmu,x86_64-softmmu,xtensa-softmmu" && \ make -j$(nproc) all install && \ rm -rf /tmp/qemu
It's now possible to run CI job on gitlab.com. Document the process.
Signed-off-by: Jiaxun Yang jiaxun.yang@flygoat.com --- doc/develop/ci_testing.rst | 12 +++++++++--- 1 file changed, 9 insertions(+), 3 deletions(-)
diff --git a/doc/develop/ci_testing.rst b/doc/develop/ci_testing.rst index ffaacedc3d88..b616d1c807d3 100644 --- a/doc/develop/ci_testing.rst +++ b/doc/develop/ci_testing.rst @@ -46,9 +46,10 @@ resources the project has available. For Custodians, it is a matter of enabling the pipeline feature in your project repository following the standard GitLab documentation. For non-custodians, the pipeline itself is part of the tree and should be able to be used on any GitLab instance, with whatever -runners you are able to provide. While it is intended to be able to run this -pipeline on the free public instances provided at https://gitlab.com/ a problem -with our squashfs tests currently prevents this. +runners you are able to provide. To run this pipeline on the free public +instances provided at https://gitlab.com/ you will need to fork the repository, +enable the CI/CD feature [1]_ for the repository, rise pipeline timeout [2]_ to +at least 2 hours and then push your changes to the repository.
To push to Gitlab without triggering a pipeline use:
@@ -74,3 +75,8 @@ developing features. In that case, it can be useful as part of your own testing cycle to edit these pipelines in separate local commits to pair them down to just the jobs you're interested in. These changes must be removed prior to submission. + +References +---------- +.. [1] https://docs.gitlab.com/ee/ci/quick_start/ +.. [2] https://docs.gitlab.com/ee/ci/pipelines/settings.html#set-a-limit-for-how-lo...
Use Jiaxun's CI Image for demonstration.
NOT FOR COMMIT!
Signed-off-by: Jiaxun Yang jiaxun.yang@flygoat.com --- .azure-pipelines.yml | 4 ++-- .gitlab-ci.yml | 4 ++-- tools/docker/Dockerfile | 6 +++--- 3 files changed, 7 insertions(+), 7 deletions(-)
diff --git a/.azure-pipelines.yml b/.azure-pipelines.yml index 2506814725e1..494c7edaf549 100644 --- a/.azure-pipelines.yml +++ b/.azure-pipelines.yml @@ -2,7 +2,7 @@ variables: windows_vm: windows-2019 ubuntu_vm: ubuntu-22.04 macos_vm: macOS-12 - ci_runner_image: trini/u-boot-gitlab-ci-runner:jammy-20240227-14Mar2024 + ci_runner_image: ghcr.io/flygoat/u-boot-ci-docker:main # Add '-u 0' options for Azure pipelines, otherwise we get "permission # denied" error when it tries to "useradd -m -u 1001 vsts_azpcontainer", # since our $(ci_runner_image) user is not root. @@ -203,7 +203,7 @@ stages: # the below corresponds to .gitlab-ci.yml "before_script" cd ${WORK_DIR} git config --global --add safe.directory ${WORK_DIR} - git clone --depth=1 https://source.denx.de/u-boot/u-boot-test-hooks /tmp/uboot-test-hooks + git clone --depth=1 https://github.com/FlyGoat/u-boot-test-hooks.git /tmp/uboot-test-hooks ln -s travis-ci /tmp/uboot-test-hooks/bin/`hostname` ln -s travis-ci /tmp/uboot-test-hooks/py/`hostname` grub-mkimage --prefix="" -o ~/grub_x86.efi -O i386-efi normal echo lsefimmap lsefi lsefisystab efinet tftp minicmd diff --git a/.gitlab-ci.yml b/.gitlab-ci.yml index efb84c3b119f..5b61b5780a32 100644 --- a/.gitlab-ci.yml +++ b/.gitlab-ci.yml @@ -10,7 +10,7 @@ default:
# Grab our configured image. The source for this is found # in the u-boot tree at tools/docker/Dockerfile -image: ${MIRROR_DOCKER}/trini/u-boot-gitlab-ci-runner:jammy-20240227-14Mar2024 +image: ghcr.io/flygoat/u-boot-ci-docker:main
# We run some tests in different order, to catch some failures quicker. stages: @@ -26,7 +26,7 @@ stages: before_script: # Clone uboot-test-hooks - git config --global --add safe.directory "${CI_PROJECT_DIR}" - - git clone --depth=1 https://source.denx.de/u-boot/u-boot-test-hooks /tmp/uboot-test-hooks + - git clone --depth=1 https://github.com/FlyGoat/u-boot-test-hooks.git /tmp/uboot-test-hooks - ln -s travis-ci /tmp/uboot-test-hooks/bin/`hostname` - ln -s travis-ci /tmp/uboot-test-hooks/py/`hostname` - grub-mkimage --prefix="" -o ~/grub_x86.efi -O i386-efi normal echo lsefimmap lsefi lsefisystab efinet tftp minicmd diff --git a/tools/docker/Dockerfile b/tools/docker/Dockerfile index 26b0e36fec05..3f1bbfce669e 100644 --- a/tools/docker/Dockerfile +++ b/tools/docker/Dockerfile @@ -276,9 +276,9 @@ USER uboot:uboot
# Populate the cache for pip to use. Get these via wget as the # COPY / ADD directives don't work as we need them to. -RUN wget -O /tmp/pytest-requirements.txt https://source.denx.de/u-boot/u-boot/-/raw/master/test/py/requirements.txt -RUN wget -O /tmp/sphinx-requirements.txt https://source.denx.de/u-boot/u-boot/-/raw/master/doc/sphinx/requirements.tx... -RUN wget -O /tmp/buildman-requirements.txt https://source.denx.de/u-boot/u-boot/-/raw/master/tools/buildman/requirement... +RUN wget -O /tmp/pytest-requirements.txt https://gitlab.com/FlyGoat/u-boot/-/raw/b4/docker-image/test/py/requirements... +RUN wget -O /tmp/sphinx-requirements.txt https://gitlab.com/FlyGoat/u-boot/-/raw/b4/docker-image/doc/sphinx/requireme... +RUN wget -O /tmp/buildman-requirements.txt https://gitlab.com/FlyGoat/u-boot/-/raw/b4/docker-image/tools/buildman/requi... RUN virtualenv -p /usr/bin/python3 /tmp/venv && \ . /tmp/venv/bin/activate && \ pip install -r /tmp/pytest-requirements.txt \
Somehow when I'm trying to build dockerimage on 11 June 2024 multiple upstream sites are down.
Arm site is returning 500 error, nasm.us domain expired, ftpmirror.gnu.org is down worldwide.
I belive those problems are not permanent so made this change NFC.
NOT FOR COMMIT!
Signed-off-by: Jiaxun Yang jiaxun.yang@flygoat.com --- tools/docker/Dockerfile | 4 +++- 1 file changed, 3 insertions(+), 1 deletion(-)
diff --git a/tools/docker/Dockerfile b/tools/docker/Dockerfile index 3f1bbfce669e..67d10f11f43f 100644 --- a/tools/docker/Dockerfile +++ b/tools/docker/Dockerfile @@ -205,7 +205,7 @@ RUN git clone https://gitlab.com/qemu-project/qemu.git /tmp/qemu && \ rm -rf /tmp/qemu
# Build fiptool -RUN git clone https://git.trustedfirmware.org/TF-A/trusted-firmware-a.git /tmp/tf-a && \ +RUN git clone https://github.com/ARM-software/arm-trusted-firmware.git /tmp/tf-a && \ cd /tmp/tf-a/ && \ git checkout lts-v2.10.4 && \ cd tools/fiptool && \ @@ -260,6 +260,8 @@ RUN mkdir /tmp/trace && \ # Build coreboot RUN wget -O - https://coreboot.org/releases/coreboot-24.05.tar.xz | tar -C /tmp -xJ && \ cd /tmp/coreboot-24.05 && \ + sed -i 's,https://ftpmirror.gnu.org,https://ftp.gnu.org/gnu,g' ./util/crossgcc/buildgcc && \ + sed -i 's,NASM_BASE_URL=.*,NASM_BASE_URL="https://distfiles.macports.org/nasm%22,g' ./util/crossgcc/buildgcc && \ make crossgcc-i386 CPUS=$(nproc) && \ make -C payloads/coreinfo olddefconfig && \ make -C payloads/coreinfo && \
On Tue, Jun 11, 2024 at 10:03:59PM +0100, Jiaxun Yang wrote:
Hi all,
This series build a new CI image based on Ubuntu focal with LoongArch64 support, fixed various python scripts for python 3.12, fixed various problems popped up when testing againt latest software.
This change must be combined with test hook changes at [1].
Last two commits are for demonstration purpose and not for commit into repo.
CI runs passed at azure [2] and public gitlab.com runner [3].
Thanks for doing all of the python updates.
participants (6)
Jiaxun Yang
Rasmus Villemoes
Stefan Roese
Tim Harvey
