[PATCH] arm: pdu001: Setup pinmux for console UART as early as possible
To make sure we get a working console as soon as possible in the SPL the UART pins require to be configured earlier. This is especially true for the pins of UART3, since the PDU001 board uses this UART for the console by default.
Signed-off-by: Felix Brack fb@ltec.ch ---
board/eets/pdu001/board.c | 30 ++++++++++++++++++++++++++++++ 1 file changed, 30 insertions(+)
diff --git a/board/eets/pdu001/board.c b/board/eets/pdu001/board.c index 9f3cfd4f84..4aeb84071b 100644 --- a/board/eets/pdu001/board.c +++ b/board/eets/pdu001/board.c @@ -216,6 +216,36 @@ const struct dpll_params *get_dpll_ddr_params(void) return &dpll_ddr; }
+void set_uart_mux_conf(void) +{ + switch (CONFIG_CONS_INDEX) { + case 1: { + enable_uart0_pin_mux(); + break; + } + case 2: { + enable_uart1_pin_mux(); + break; + } + case 3: { + enable_uart2_pin_mux(); + break; + } + case 4: { + enable_uart3_pin_mux(); + break; + } + case 5: { + enable_uart4_pin_mux(); + break; + } + case 6: { + enable_uart5_pin_mux(); + break; + } + } +} + void set_mux_conf_regs(void) { /* done first by the ROM and afterwards by the pin controller driver */
Does this replace https://patchwork.ozlabs.org/project/uboot/patch/20220215142723.45242-1-fb@l... or go in addition to it? Thanks!
Hi Tom,
No it's not a replacement. It is kind of addition but not related to the early debugging UART, hence a second patch.
On Mon, Feb 21, 2022 at 02:50:19PM +0100, Felix Brack wrote:
Hi Tom,
OK, thanks just confirming.
Felix Brack
