[U-Boot] [PATCH v4 1/2] watchdog/denali: Adding DesignWare watchdog driver support
To add the DesignWare watchdog driver support. It required information such as register base address and clock info from configuration header file within include/configs folder.
Signed-off-by: Chin Liang See clsee@altera.com Cc: Anatolij Gustschin agust@denx.de Cc: Albert Aribaud albert.u.boot@aribaud.net Cc: Heiko Schocher hs@denx.de Cc: Tom Rini trini@ti.com --- Changes for v4 - Add 2014 to license header Changes for v3 - Split to 2 series patch Changes for v2 - Enable this driver at socfpga_cyclone5 board --- drivers/watchdog/Makefile | 1 + drivers/watchdog/designware_wdt.c | 73 +++++++++++++++++++++++++++++++++++++ 2 files changed, 74 insertions(+) create mode 100644 drivers/watchdog/designware_wdt.c
diff --git a/drivers/watchdog/Makefile b/drivers/watchdog/Makefile index 06ced10..0276a10 100644 --- a/drivers/watchdog/Makefile +++ b/drivers/watchdog/Makefile @@ -15,3 +15,4 @@ obj-$(CONFIG_S5P) += s5p_wdt.o obj-$(CONFIG_XILINX_TB_WATCHDOG) += xilinx_tb_wdt.o obj-$(CONFIG_BFIN_WATCHDOG) += bfin_wdt.o obj-$(CONFIG_OMAP_WATCHDOG) += omap_wdt.o +obj-$(CONFIG_DESIGNWARE_WATCHDOG) += designware_wdt.o diff --git a/drivers/watchdog/designware_wdt.c b/drivers/watchdog/designware_wdt.c new file mode 100644 index 0000000..6abee81 --- /dev/null +++ b/drivers/watchdog/designware_wdt.c @@ -0,0 +1,73 @@ +/* + * Copyright (C) 2013-2014 Altera Corporation <www.altera.com> + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <watchdog.h> +#include <asm/io.h> +#include <asm/utils.h> + +#define DW_WDT_CR 0x00 +#define DW_WDT_TORR 0x04 +#define DW_WDT_CRR 0x0C + +#define DW_WDT_CR_EN_OFFSET 0x00 +#define DW_WDT_CR_RMOD_OFFSET 0x01 +#define DW_WDT_CR_RMOD_VAL 0x00 +#define DW_WDT_CRR_RESTART_VAL 0x76 + +/* + * Set the watchdog time interval. + * Counter is 32 bit. + */ +int designware_wdt_settimeout(unsigned int timeout) +{ + signed int i; + /* calculate the timeout range value */ + i = (log_2_n_round_up(timeout * CONFIG_DW_WDT_CLOCK_KHZ)) - 16; + if (i > 15) + i = 15; + if (i < 0) + i = 0; + + writel((i | (i<<4)), (CONFIG_DW_WDT_BASE + DW_WDT_TORR)); + return 0; +} + +void designware_wdt_enable(void) +{ + writel(((DW_WDT_CR_RMOD_VAL << DW_WDT_CR_RMOD_OFFSET) | + (0x1 << DW_WDT_CR_EN_OFFSET)), + (CONFIG_DW_WDT_BASE + DW_WDT_CR)); +} + +unsigned int designware_wdt_is_enabled(void) +{ + unsigned long val; + val = readl((CONFIG_DW_WDT_BASE + DW_WDT_CR)); + return val & 0x1; +} + +#if defined(CONFIG_HW_WATCHDOG) +void hw_watchdog_reset(void) +{ + if (designware_wdt_is_enabled()) + /* restart the watchdog counter */ + writel(DW_WDT_CRR_RESTART_VAL, + (CONFIG_DW_WDT_BASE + DW_WDT_CRR)); +} + +void hw_watchdog_init(void) +{ + /* reset to disable the watchdog */ + hw_watchdog_reset(); + /* set timer in miliseconds */ + designware_wdt_settimeout(CONFIG_HW_WATCHDOG_TIMEOUT_MS); + /* enable the watchdog */ + designware_wdt_enable(); + /* reset the watchdog */ + hw_watchdog_reset(); +} +#endif
Changes for v4
Changes for v3
Changes for v2
- Copyright (C) 2013-2014 Altera Corporation <www.altera.com>
- Set the watchdog time interval.
- Counter is 32 bit.
- signed int i;
- /* calculate the timeout range value */
- i = (log_2_n_round_up(timeout * CONFIG_DW_WDT_CLOCK_KHZ)) - 16;
- if (i > 15)
i = 15;
- if (i < 0)
i = 0;
- writel((i | (i<<4)), (CONFIG_DW_WDT_BASE + DW_WDT_TORR));
i << 4
- writel(((DW_WDT_CR_RMOD_VAL << DW_WDT_CR_RMOD_OFFSET) |
- unsigned long val;
- val = readl((CONFIG_DW_WDT_BASE + DW_WDT_CR));
- return val & 0x1;
all 3 functions above I believe should be static because you use them just here.
Thanks, Michal
Changes for v4
Changes for v3
Changes for v2
- signed int i;
- if (i > 15)
i = 15;
- if (i < 0)
i = 0;
i << 4
Fixed
- return val & 0x1;
Yup, I can enhance that. Thanks
Chin Liang
Thanks, Michal
Chin Liang See
Michal Simek
