[U-Boot] [PATCH 1/2] arm: change tbu/l type to unsigned int
Change tbu/l type to unsigned int.
Signed-off-by: Peng Fan peng.fan@nxp.com Cc: Simon Glass sjg@chromium.org Cc: Tom Rini trini@konsulko.com --- arch/arm/include/asm/global_data.h | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/arch/arm/include/asm/global_data.h b/arch/arm/include/asm/global_data.h index dfcbcce..92d9c97 100644 --- a/arch/arm/include/asm/global_data.h +++ b/arch/arm/include/asm/global_data.h @@ -32,8 +32,8 @@ struct arch_global_data { #endif /* "static data" needed by most of timer.c on ARM platforms */ unsigned long timer_rate_hz; - unsigned long tbu; - unsigned long tbl; + unsigned int tbu; + unsigned int tbl; unsigned long lastinc; unsigned long long timer_reset_value; #if !(defined(CONFIG_SYS_ICACHE_OFF) && defined(CONFIG_SYS_DCACHE_OFF))
Change type of timebase_l/h to unsigned int.
Signed-off-by: Peng Fan peng.fan@nxp.com Cc: Simon Glass sjg@chromium.org Cc: Eddie Cai eddie.cai.linux@gmail.com Cc: Jagan Teki jteki@openedev.com Cc: York Sun york.sun@nxp.com Cc: "Robert P. J. Day" rpjday@crashcourse.ca Cc: Michal Simek michal.simek@xilinx.com Cc: Tom Rini trini@konsulko.com ---
Buildman shows the following build failure, but not related this patch. aarch64: + orangepi_pc2 x86: + qemu-x86_64 qemu-x86_efi_payload64 chromebook_link64
include/asm-generic/global_data.h | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/include/asm-generic/global_data.h b/include/asm-generic/global_data.h index 1a77c98..51838b5 100644 --- a/include/asm-generic/global_data.h +++ b/include/asm-generic/global_data.h @@ -83,8 +83,8 @@ typedef struct global_data { #ifdef CONFIG_SYS_I2C_MXC void *srdata[10]; #endif - unsigned long timebase_h; - unsigned long timebase_l; + unsigned int timebase_h; + unsigned int timebase_l; #ifdef CONFIG_SYS_MALLOC_F_LEN unsigned long malloc_base; /* base address of early malloc() */ unsigned long malloc_limit; /* limit address */
Hi Peng,
What is the motivation for this, please?
Hi Simon,
-----Original Message----- From: sjg@google.com [mailto:sjg@google.com] On Behalf Of Simon Glass Sent: Monday, April 24, 2017 11:38 AM To: Peng Fan peng.fan@nxp.com Cc: U-Boot Mailing List u-boot@lists.denx.de; Tom Rini trini@konsulko.com; Eddie Cai eddie.cai.linux@gmail.com; Jagan Teki jteki@openedev.com; york sun york.sun@nxp.com; Robert P. J. Day rpjday@crashcourse.ca; Michal Simek michal.simek@xilinx.com Subject: Re: [PATCH 2/2] asm-generic: global_data: change timebase_l/h to unsigned int
Hi Peng,
From lib/time.c: ((uint64_t)gd->timebase_h << 32) | gd->timebase_l;
This piece code is based on that timebase_h and timebase_l are 32bits width, I think. But unsigned long are 64bits width on ARM64. I am not sure, but I suppose same case on other archs.
Thanks, Peng.
Hi Peng,
On 25 April 2017 at 14:51, Peng Fan peng.fan@nxp.com wrote:
Hi Simon,
Hi Peng,
OK I see. I suspect it would make more sense to have a single 64-bit value on 64-bit machines, but perhaps that is a separate point.
Thanks, Peng.
Hi Peng,
Why do this, please?
unsigned long tbu;
unsigned long tbl;
unsigned int tbu;
2.6.6
Hi Tom,
Will you pick up this patch set?
- unsigned int tbu;
- unsigned int tbl; unsigned long lastinc; unsigned long long timer_reset_value;
2.6.6
Peng Fan
Peng Fan
