[U-Boot] [PATCH V2 00/13] Basic Raspberyr Pi support
This series adds basic support for the Raspberry Pi ARM board.
v2: * Add README config_cmd_default.h documentation fix. * Use <> not "" for include of config_cmd_default.h. * Squash together 3 patches related to enabling booting a Linux kernel. * Minor rpi_b.h order changes in order to drop later cleanup patch. * Merged together 2 patch series of mine, and the GPIO series from Vikram.
Stephen Warren (11): README: fix references to config_cmd_default.h ARM: add basic support for the Broadcom BCM2835 SoC ARM: bcm2835: add Raspberry Pi model B board ARM: arm1176: enable instruction cache in arch_cpu_init() ARM: rpi_b: enable CONFIG_ARCH_CPU_INIT for icache ARM: rpi_b: define CONFIG_MACH_TYPE ARM: rpi_b: include config_cmd_default.h ARM: rpi_b: enable booting the Linux kernel ARM: rpi_b: drop RAM size to 128M ARM: rpi_b: move stack to top of RAM ARM: bcm2835: implement reset using watchdog
Vikram Narayanan (2): gpio: bcm2835: Add GPIO driver rbpi: Add BCM2835 GPIO driver for raspberry pi
MAINTAINERS | 4 + README | 4 +- arch/arm/cpu/arm1176/bcm2835/Makefile | 37 +++++++++ arch/arm/cpu/arm1176/bcm2835/config.mk | 19 +++++ arch/arm/cpu/arm1176/bcm2835/lowlevel_init.S | 19 +++++ arch/arm/cpu/arm1176/bcm2835/reset.c | 35 +++++++++ arch/arm/cpu/arm1176/bcm2835/timer.c | 55 +++++++++++++ arch/arm/cpu/arm1176/cpu.c | 7 ++ arch/arm/include/asm/arch-bcm2835/gpio.h | 66 ++++++++++++++++ arch/arm/include/asm/arch-bcm2835/timer.h | 37 +++++++++ arch/arm/include/asm/arch-bcm2835/wdog.h | 37 +++++++++ board/raspberrypi/rpi_b/Makefile | 34 +++++++++ board/raspberrypi/rpi_b/rpi_b.c | 34 +++++++++ boards.cfg | 1 + drivers/gpio/Makefile | 1 + drivers/gpio/bcm2835_gpio.c | 90 ++++++++++++++++++++++ include/configs/rpi_b.h | 106 ++++++++++++++++++++++++++ 17 files changed, 584 insertions(+), 2 deletions(-) create mode 100644 arch/arm/cpu/arm1176/bcm2835/Makefile create mode 100644 arch/arm/cpu/arm1176/bcm2835/config.mk create mode 100644 arch/arm/cpu/arm1176/bcm2835/lowlevel_init.S create mode 100644 arch/arm/cpu/arm1176/bcm2835/reset.c create mode 100644 arch/arm/cpu/arm1176/bcm2835/timer.c create mode 100644 arch/arm/include/asm/arch-bcm2835/gpio.h create mode 100644 arch/arm/include/asm/arch-bcm2835/timer.h create mode 100644 arch/arm/include/asm/arch-bcm2835/wdog.h create mode 100644 board/raspberrypi/rpi_b/Makefile create mode 100644 board/raspberrypi/rpi_b/rpi_b.c create mode 100644 drivers/gpio/bcm2835_gpio.c create mode 100644 include/configs/rpi_b.h
All usage of config_cmd_default.h uses <> for the include statement. Update the README to do the same, rather than using "".
Signed-off-by: Stephen Warren swarren@wwwdotorg.org --- v2: New patch --- README | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/README b/README index dac46f3..a7deaf4 100644 --- a/README +++ b/README @@ -744,8 +744,8 @@ The following options need to be configured: - Monitor Functions: Monitor commands can be included or excluded from the build by using the #include files - "config_cmd_all.h" and #undef'ing unwanted - commands, or using "config_cmd_default.h" + <config_cmd_all.h> and #undef'ing unwanted + commands, or using <config_cmd_default.h> and augmenting with additional #define's for wanted commands.
This SoC is used in the Raspberry Pi, for example.
Initial support is enough to boot to a serial console, and execute a minimal set of U-Boot commands. No drivers are implemented. For more details, see http://www.broadcom.com/products/BCM2835 or http://www.raspberrypi.org/wp-content/uploads/2012/02/BCM2835-ARM-Peripheral....
Signed-off-by: Stephen Warren swarren@wwwdotorg.org --- arch/arm/cpu/arm1176/bcm2835/Makefile | 37 +++++++++++++++++ arch/arm/cpu/arm1176/bcm2835/config.mk | 19 +++++++++ arch/arm/cpu/arm1176/bcm2835/lowlevel_init.S | 19 +++++++++ arch/arm/cpu/arm1176/bcm2835/reset.c | 27 +++++++++++++ arch/arm/cpu/arm1176/bcm2835/timer.c | 55 ++++++++++++++++++++++++++ arch/arm/include/asm/arch-bcm2835/timer.h | 37 +++++++++++++++++ 6 files changed, 194 insertions(+) create mode 100644 arch/arm/cpu/arm1176/bcm2835/Makefile create mode 100644 arch/arm/cpu/arm1176/bcm2835/config.mk create mode 100644 arch/arm/cpu/arm1176/bcm2835/lowlevel_init.S create mode 100644 arch/arm/cpu/arm1176/bcm2835/reset.c create mode 100644 arch/arm/cpu/arm1176/bcm2835/timer.c create mode 100644 arch/arm/include/asm/arch-bcm2835/timer.h
diff --git a/arch/arm/cpu/arm1176/bcm2835/Makefile b/arch/arm/cpu/arm1176/bcm2835/Makefile new file mode 100644 index 0000000..4ea6d6b --- /dev/null +++ b/arch/arm/cpu/arm1176/bcm2835/Makefile @@ -0,0 +1,37 @@ +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License +# version 2 as published by the Free Software Foundation. +# +# This program is distributed in the hope that it will be useful, but +# WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(SOC).o + +SOBJS := lowlevel_init.o +COBJS := reset.o timer.o + +SRCS := $(SOBJS:.o=.c) $(COBJS:.o=.c) +OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS)) + +all: $(obj).depend $(LIB) + +$(LIB): $(OBJS) + $(call cmd_link_o_target, $(OBJS)) + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/arch/arm/cpu/arm1176/bcm2835/config.mk b/arch/arm/cpu/arm1176/bcm2835/config.mk new file mode 100644 index 0000000..b87ce24 --- /dev/null +++ b/arch/arm/cpu/arm1176/bcm2835/config.mk @@ -0,0 +1,19 @@ +# +# (C) Copyright 2012 Stephen Warren +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License +# version 2 as published by the Free Software Foundation. +# +# This program is distributed in the hope that it will be useful, but +# WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. + +# Don't attempt to override the target CPU/ABI options; +# the Raspberry Pi toolchain does the right thing by default. +PLATFORM_RELFLAGS := $(filter-out -msoft-float,$(PLATFORM_RELFLAGS)) +PLATFORM_CPPFLAGS := $(filter-out -march=armv5t,$(PLATFORM_CPPFLAGS)) diff --git a/arch/arm/cpu/arm1176/bcm2835/lowlevel_init.S b/arch/arm/cpu/arm1176/bcm2835/lowlevel_init.S new file mode 100644 index 0000000..c7b0843 --- /dev/null +++ b/arch/arm/cpu/arm1176/bcm2835/lowlevel_init.S @@ -0,0 +1,19 @@ +/* + * (C) Copyright 2012 Stephen Warren + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License + * version 2 as published by the Free Software Foundation. + * + * This program is distributed in the hope that it will be useful, but + * WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + */ + +.globl lowlevel_init +lowlevel_init: + mov pc, lr diff --git a/arch/arm/cpu/arm1176/bcm2835/reset.c b/arch/arm/cpu/arm1176/bcm2835/reset.c new file mode 100644 index 0000000..69c9577 --- /dev/null +++ b/arch/arm/cpu/arm1176/bcm2835/reset.c @@ -0,0 +1,27 @@ +/* + * (C) Copyright 2012 Stephen Warren + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License + * version 2 as published by the Free Software Foundation. + * + * This program is distributed in the hope that it will be useful, but + * WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + */ + +#include <common.h> +#include <asm/io.h> + +void reset_cpu(ulong addr) +{ + /* + * We should probably use the WDT module here, but an unaligned + * access will do the trick for now. + */ + readl(1); +} diff --git a/arch/arm/cpu/arm1176/bcm2835/timer.c b/arch/arm/cpu/arm1176/bcm2835/timer.c new file mode 100644 index 0000000..d232d7e --- /dev/null +++ b/arch/arm/cpu/arm1176/bcm2835/timer.c @@ -0,0 +1,55 @@ +/* + * (C) Copyright 2012 Stephen Warren + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License + * version 2 as published by the Free Software Foundation. + * + * This program is distributed in the hope that it will be useful, but + * WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/arch/timer.h> + +int timer_init(void) +{ + return 0; +} + +ulong get_timer(ulong base) +{ + struct bcm2835_timer_regs *regs = + (struct bcm2835_timer_regs *)BCM2835_TIMER_PHYSADDR; + + return readl(®s->clo) - base; +} + +unsigned long long get_ticks(void) +{ + return get_timer(0); +} + +ulong get_tbclk(void) +{ + return CONFIG_SYS_HZ; +} + +void __udelay(unsigned long usec) +{ + ulong endtime; + signed long diff; + + endtime = get_timer(0) + usec; + + do { + ulong now = get_timer(0); + diff = endtime - now; + } while (diff >= 0); +} diff --git a/arch/arm/include/asm/arch-bcm2835/timer.h b/arch/arm/include/asm/arch-bcm2835/timer.h new file mode 100644 index 0000000..30c70e0 --- /dev/null +++ b/arch/arm/include/asm/arch-bcm2835/timer.h @@ -0,0 +1,37 @@ +/* + * (C) Copyright 2012 Stephen Warren + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License + * version 2 as published by the Free Software Foundation. + * + * This program is distributed in the hope that it will be useful, but + * WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + */ + +#ifndef _BCM2835_TIMER_H +#define _BCM2835_TIMER_H + +#define BCM2835_TIMER_PHYSADDR 0x20003000 + +struct bcm2835_timer_regs { + u32 cs; + u32 clo; + u32 chi; + u32 c0; + u32 c1; + u32 c2; + u32 c3; +}; + +#define BCM2835_TIMER_CS_M3 (1 << 3) +#define BCM2835_TIMER_CS_M2 (1 << 2) +#define BCM2835_TIMER_CS_M1 (1 << 1) +#define BCM2835_TIMER_CS_M0 (1 << 0) + +#endif
The Raspberry Pi model B uses the BCM2835 SoC, has 256MB of RAM, contains an SMSC 9512 USB LAN/Hub chip, and various IO connectors. For more details, see http://www.raspberrypi.org/.
Signed-off-by: Stephen Warren swarren@wwwdotorg.org --- v2: Re-order defines slightly to drop a later cleanup patch. --- MAINTAINERS | 4 ++ board/raspberrypi/rpi_b/Makefile | 34 ++++++++++++++++ board/raspberrypi/rpi_b/rpi_b.c | 32 +++++++++++++++ boards.cfg | 1 + include/configs/rpi_b.h | 80 ++++++++++++++++++++++++++++++++++++++ 5 files changed, 151 insertions(+) create mode 100644 board/raspberrypi/rpi_b/Makefile create mode 100644 board/raspberrypi/rpi_b/rpi_b.c create mode 100644 include/configs/rpi_b.h
diff --git a/MAINTAINERS b/MAINTAINERS index fd0c65c..abe621e 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -928,6 +928,10 @@ Stephen Warren swarren@nvidia.com trimslice Tegra2 (ARM7 & A9 Dual Core) whistler Tegra2 (ARM7 & A9 Dual Core)
+Stephen Warren swarren@wwwdotorg.org + + rpi_b BCM2835 (ARM1176) + Thomas Weber weber@corscience.de
devkit8000 ARM ARMV7 (OMAP3530 SoC) diff --git a/board/raspberrypi/rpi_b/Makefile b/board/raspberrypi/rpi_b/Makefile new file mode 100644 index 0000000..9d0c377 --- /dev/null +++ b/board/raspberrypi/rpi_b/Makefile @@ -0,0 +1,34 @@ +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License +# version 2 as published by the Free Software Foundation. +# +# This program is distributed in the hope that it will be useful, but +# WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(BOARD).o + +COBJS := $(BOARD).o + +SRCS := $(COBJS:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS)) + +$(LIB): $(obj).depend $(OBJS) + $(call cmd_link_o_target, $(OBJS)) + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/board/raspberrypi/rpi_b/rpi_b.c b/board/raspberrypi/rpi_b/rpi_b.c new file mode 100644 index 0000000..f39440f --- /dev/null +++ b/board/raspberrypi/rpi_b/rpi_b.c @@ -0,0 +1,32 @@ +/* + * (C) Copyright 2012 Stephen Warren + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License + * version 2 as published by the Free Software Foundation. + * + * This program is distributed in the hope that it will be useful, but + * WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + */ + +#include <common.h> +#include <asm/global_data.h> + +DECLARE_GLOBAL_DATA_PTR; + +int dram_init(void) +{ + gd->ram_size = SZ_256M; + + return 0; +} + +int board_init(void) +{ + return 0; +} diff --git a/boards.cfg b/boards.cfg index 2d36d83..7a88eb9 100644 --- a/boards.cfg +++ b/boards.cfg @@ -48,6 +48,7 @@ mx35pdk arm arm1136 - freesca apollon arm arm1136 apollon - omap24xx omap2420h4 arm arm1136 - ti omap24xx tnetv107x_evm arm arm1176 tnetv107xevm ti tnetv107x +rpi_b arm arm1176 rpi_b raspberrypi bcm2835 integratorap_cm720t arm arm720t integrator armltd - integratorap:CM720T integratorap_cm920t arm arm920t integrator armltd - integratorap:CM920T integratorcp_cm920t arm arm920t integrator armltd - integratorcp:CM920T diff --git a/include/configs/rpi_b.h b/include/configs/rpi_b.h new file mode 100644 index 0000000..28e5510 --- /dev/null +++ b/include/configs/rpi_b.h @@ -0,0 +1,80 @@ +/* + * (C) Copyright 2012 Stephen Warren + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License + * version 2 as published by the Free Software Foundation. + * + * This program is distributed in the hope that it will be useful, but + * WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +#include <asm/sizes.h> + +/* Architecture, CPU, etc.*/ +#define CONFIG_ARM1176 +#define CONFIG_BCM2835 + +/* Timer */ +#define CONFIG_SYS_HZ 1000000 + +/* Memory layout */ +#define CONFIG_NR_DRAM_BANKS 1 +#define CONFIG_SYS_SDRAM_BASE 0x00000000 +#define CONFIG_SYS_TEXT_BASE 0x00008000 +#define CONFIG_SYS_UBOOT_BASE CONFIG_SYS_TEXT_BASE +#define CONFIG_SYS_INIT_RAM_SIZE SZ_4K +#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_SDRAM_BASE + \ + CONFIG_SYS_INIT_RAM_SIZE - \ + GENERATED_GBL_DATA_SIZE) +#define CONFIG_SYS_MALLOC_LEN SZ_4M +#define CONFIG_SYS_MEMTEST_START 0x00100000 +#define CONFIG_SYS_MEMTEST_END 0x00200000 + +/* Flash */ +#define CONFIG_SYS_NO_FLASH + +/* Devices */ +/* None yet */ + +/* Console UART */ +#define CONFIG_PL011_SERIAL +#define CONFIG_PL011_CLOCK 3000000 +#define CONFIG_PL01x_PORTS { (void *)0x20201000 } +#define CONFIG_CONS_INDEX 0 +#define CONFIG_BAUDRATE 115200 +#define CONFIG_SYS_BAUDRATE_TABLE { 9600, 19200, 38400, 57600, 115200 } + +/* Console configuration */ +#define CONFIG_SYS_CBSIZE 1024 +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + \ + sizeof(CONFIG_SYS_PROMPT) + 16) + +/* Environment */ +#define CONFIG_ENV_SIZE SZ_16K +#define CONFIG_ENV_IS_NOWHERE +#define CONFIG_SYS_LOAD_ADDR 0x1000000 + +/* Shell */ +#define CONFIG_SYS_HUSH_PARSER +#define CONFIG_SYS_MAXARGS 8 +#define CONFIG_SYS_PROMPT "U-Boot> " +#define CONFIG_SYS_PROMPT_HUSH_PS2 "> " +#define CONFIG_SYS_LONGHELP +#define CONFIG_CMDLINE_EDITING +#define CONFIG_COMMAND_HISTORY +#define CONFIG_AUTO_COMPLETE + +/* Commands */ +#define CONFIG_CMD_MEMORY +#define CONFIG_CMD_MISC + +#endif
[snip]
- gd->ram_size = SZ_256M;
You should use get_ram_size(CONFIG_SYS_SDRAM_BASE, max-possible-dram-size); I say this as I just found a "oh, so that's why mainline reports the right amount of memory and other tree does not" bug yesterday. This should also be in the SoC-generic code area (like say arch/arm/cpu/arm1176/bcm2835/board.c). Sorry I didn't spot this last go-round.
[snip]
This is the table now in <config_fallbacks.h> which is auto-included.
This is now the default prompt value, so you can drop this line.
[snip]
I forgot about the video co-processor change later in the series, so you can disregard this specific comment. But I have some still applicable comments I'm going to add to the 0/13 patch now.
Note that this affects all users of the ARM1176 CPU that enable CONFIG_ARCH_CPU_INIT, not just the BCM2835 SoC, potentially such as tnetv107x.
Cc: Cyril Chemparathy cyril@ti.com Signed-off-by: Stephen Warren swarren@wwwdotorg.org --- arch/arm/cpu/arm1176/cpu.c | 7 +++++++ 1 file changed, 7 insertions(+)
diff --git a/arch/arm/cpu/arm1176/cpu.c b/arch/arm/cpu/arm1176/cpu.c index c0fd114..532a90b 100644 --- a/arch/arm/cpu/arm1176/cpu.c +++ b/arch/arm/cpu/arm1176/cpu.c @@ -65,3 +65,10 @@ static void cache_flush (void) /* mem barrier to sync things */ asm ("mcr p15, 0, %0, c7, c10, 4": :"r" (0)); } + +int arch_cpu_init(void) +{ + icache_enable(); + + return 0; +}
This causes arch_cpu_init() to be called, which enables the icache.
Extracted from work by Oleksandr Tymoshenko gonzo@bluezbox.com.
Signed-off-by: Stephen Warren swarren@wwwdotorg.org --- include/configs/rpi_b.h | 1 + 1 file changed, 1 insertion(+)
diff --git a/include/configs/rpi_b.h b/include/configs/rpi_b.h index 28e5510..9020d80 100644 --- a/include/configs/rpi_b.h +++ b/include/configs/rpi_b.h @@ -22,6 +22,7 @@ /* Architecture, CPU, etc.*/ #define CONFIG_ARM1176 #define CONFIG_BCM2835 +#define CONFIG_ARCH_CPU_INIT
/* Timer */ #define CONFIG_SYS_HZ 1000000
Use MACH_TYPE_BCM2708 as the Linux machine type for the Raspberry Pi.
The Raspberry Pi actually uses a BCM2835. However, the 2835 this is apparently a SKU in a series for which the BCM2708 is the first or perhaps primary version, such that the 2708 name has historically been used for this purpose.
Signed-off-by: Stephen Warren swarren@wwwdotorg.org --- include/configs/rpi_b.h | 5 +++++ 1 file changed, 5 insertions(+)
diff --git a/include/configs/rpi_b.h b/include/configs/rpi_b.h index 9020d80..0a3681d 100644 --- a/include/configs/rpi_b.h +++ b/include/configs/rpi_b.h @@ -23,6 +23,11 @@ #define CONFIG_ARM1176 #define CONFIG_BCM2835 #define CONFIG_ARCH_CPU_INIT +/* + * 2835 is a SKU in a series for which the 2708 is the first or primary SoC, + * so 2708 has historically been used rather than a dedicated 2835 ID. + */ +#define CONFIG_MACH_TYPE MACH_TYPE_BCM2708
This enables a more typical default set of commands. Remove explicit enables for commands already in the default list.
Signed-off-by: Stephen Warren swarren@wwwdotorg.org --- v2: Use <> not "" for #include of config_cmd_default.h --- include/configs/rpi_b.h | 8 ++++++-- 1 file changed, 6 insertions(+), 2 deletions(-)
diff --git a/include/configs/rpi_b.h b/include/configs/rpi_b.h index 0a3681d..f34cc03 100644 --- a/include/configs/rpi_b.h +++ b/include/configs/rpi_b.h @@ -80,7 +80,11 @@ #define CONFIG_AUTO_COMPLETE
/* Commands */ -#define CONFIG_CMD_MEMORY -#define CONFIG_CMD_MISC +#include <config_cmd_default.h> +/* Some things don't make sense on this HW or yet */ +#undef CONFIG_CMD_FPGA +#undef CONFIG_CMD_NET +#undef CONFIG_CMD_NFS +#undef CONFIG_CMD_SAVEENV
#endif
CONFIG_OF_LIBFDT allows bootm/bootz to pass a device tree to the kernel.
Set bi_boot_params to define where ATAGs will be written (extracted from work by Oleksandr Tymoshenko gonzo@bluezbox.com).
Add ATAG support for bootm/bootz. Newer kernels use device tree, so this isn't that useful. However, old kernels all use board files, so this might still see some use.
Enable bootz command to allow booting a zImage directly.
Signed-off-by: Stephen Warren swarren@wwwdotorg.org --- v2: Squashed the following commits into one: ARM: rpi_b: add ATAG support for bootm/bootz ARM: rpi_b: set bi_boot_params ARM: rpi_b: enable CONFIG_OF_LIBFDT ARM: rpi_b: enabled bootz command --- board/raspberrypi/rpi_b/rpi_b.c | 2 ++ include/configs/rpi_b.h | 8 ++++++++ 2 files changed, 10 insertions(+)
diff --git a/board/raspberrypi/rpi_b/rpi_b.c b/board/raspberrypi/rpi_b/rpi_b.c index f39440f..26df74b 100644 --- a/board/raspberrypi/rpi_b/rpi_b.c +++ b/board/raspberrypi/rpi_b/rpi_b.c @@ -28,5 +28,7 @@ int dram_init(void)
int board_init(void) { + gd->bd->bi_boot_params = 0x100; + return 0; } diff --git a/include/configs/rpi_b.h b/include/configs/rpi_b.h index f34cc03..9c96d0e 100644 --- a/include/configs/rpi_b.h +++ b/include/configs/rpi_b.h @@ -81,10 +81,18 @@
/* Commands */ #include <config_cmd_default.h> +#define CONFIG_CMD_BOOTZ /* Some things don't make sense on this HW or yet */ #undef CONFIG_CMD_FPGA #undef CONFIG_CMD_NET #undef CONFIG_CMD_NFS #undef CONFIG_CMD_SAVEENV
+/* Device tree support for bootm/bootz */ +#define CONFIG_OF_LIBFDT +/* ATAGs support for bootm/bootz */ +#define CONFIG_SETUP_MEMORY_TAGS +#define CONFIG_CMDLINE_TAG +#define CONFIG_INITRD_TAG + #endif
The board really has 256M. However, the VC (VideoCore co-processor) shares the RAM, and uses a configurable portion at the top. We tell U-Boot that a smaller amount of RAM is present in order to avoid stomping on the area the VC uses.
Signed-off-by: Stephen Warren swarren@wwwdotorg.org --- v2: Modified location new define was inserted, in order to drop a later cleanup patch. --- board/raspberrypi/rpi_b/rpi_b.c | 2 +- include/configs/rpi_b.h | 7 +++++++ 2 files changed, 8 insertions(+), 1 deletion(-)
diff --git a/board/raspberrypi/rpi_b/rpi_b.c b/board/raspberrypi/rpi_b/rpi_b.c index 26df74b..688b0aa 100644 --- a/board/raspberrypi/rpi_b/rpi_b.c +++ b/board/raspberrypi/rpi_b/rpi_b.c @@ -21,7 +21,7 @@ DECLARE_GLOBAL_DATA_PTR;
int dram_init(void) { - gd->ram_size = SZ_256M; + gd->ram_size = CONFIG_SYS_SDRAM_SIZE;
return 0; } diff --git a/include/configs/rpi_b.h b/include/configs/rpi_b.h index 9c96d0e..73482d9 100644 --- a/include/configs/rpi_b.h +++ b/include/configs/rpi_b.h @@ -37,6 +37,13 @@ #define CONFIG_SYS_SDRAM_BASE 0x00000000 #define CONFIG_SYS_TEXT_BASE 0x00008000 #define CONFIG_SYS_UBOOT_BASE CONFIG_SYS_TEXT_BASE +/* + * The board really has 256M. However, the VC (VideoCore co-processor) shares + * the RAM, and uses a configurable portion at the top. We tell U-Boot that a + * smaller amount of RAM is present in order to avoid stomping on the area + * the VC uses. + */ +#define CONFIG_SYS_SDRAM_SIZE SZ_128M #define CONFIG_SYS_INIT_RAM_SIZE SZ_4K #define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_SDRAM_BASE + \ CONFIG_SYS_INIT_RAM_SIZE - \
Move the top-of-stack from 32k to near the top of RAM. This leaves the bottom of RAM free for ATAGs, or U-Boot scripts to use as they see fit.
Signed-off-by: Stephen Warren swarren@wwwdotorg.org --- include/configs/rpi_b.h | 3 +-- 1 file changed, 1 insertion(+), 2 deletions(-)
diff --git a/include/configs/rpi_b.h b/include/configs/rpi_b.h index 73482d9..33169d3 100644 --- a/include/configs/rpi_b.h +++ b/include/configs/rpi_b.h @@ -44,9 +44,8 @@ * the VC uses. */ #define CONFIG_SYS_SDRAM_SIZE SZ_128M -#define CONFIG_SYS_INIT_RAM_SIZE SZ_4K #define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_SDRAM_BASE + \ - CONFIG_SYS_INIT_RAM_SIZE - \ + CONFIG_SYS_SDRAM_SIZE - \ GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_MALLOC_LEN SZ_4M #define CONFIG_SYS_MEMTEST_START 0x00100000
Signed-off-by: Stephen Warren swarren@wwwdotorg.org --- arch/arm/cpu/arm1176/bcm2835/reset.c | 18 +++++++++++---- arch/arm/include/asm/arch-bcm2835/wdog.h | 37 ++++++++++++++++++++++++++++++ 2 files changed, 50 insertions(+), 5 deletions(-) create mode 100644 arch/arm/include/asm/arch-bcm2835/wdog.h
diff --git a/arch/arm/cpu/arm1176/bcm2835/reset.c b/arch/arm/cpu/arm1176/bcm2835/reset.c index 69c9577..8c37ad9 100644 --- a/arch/arm/cpu/arm1176/bcm2835/reset.c +++ b/arch/arm/cpu/arm1176/bcm2835/reset.c @@ -16,12 +16,20 @@
#include <common.h> #include <asm/io.h> +#include <asm/arch/wdog.h> + +#define RESET_TIMEOUT 10
void reset_cpu(ulong addr) { - /* - * We should probably use the WDT module here, but an unaligned - * access will do the trick for now. - */ - readl(1); + struct bcm2835_wdog_regs *regs = + (struct bcm2835_wdog_regs *)BCM2835_WDOG_PHYSADDR; + uint32_t rstc; + + rstc = readl(®s->rstc); + rstc &= ~BCM2835_WDOG_RSTC_WRCFG_MASK; + rstc |= BCM2835_WDOG_RSTC_WRCFG_FULL_RESET; + + writel(BCM2835_WDOG_PASSWORD | RESET_TIMEOUT, ®s->wdog); + writel(BCM2835_WDOG_PASSWORD | rstc, ®s->rstc); } diff --git a/arch/arm/include/asm/arch-bcm2835/wdog.h b/arch/arm/include/asm/arch-bcm2835/wdog.h new file mode 100644 index 0000000..d750a62 --- /dev/null +++ b/arch/arm/include/asm/arch-bcm2835/wdog.h @@ -0,0 +1,37 @@ +/* + * (C) Copyright 2012 Stephen Warren + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License + * version 2 as published by the Free Software Foundation. + * + * This program is distributed in the hope that it will be useful, but + * WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + */ + +#ifndef _BCM2835_TIMER_H +#define _BCM2835_TIMER_H + +#define BCM2835_WDOG_PHYSADDR 0x20100000 + +struct bcm2835_wdog_regs { + u32 unknown0[7]; + u32 rstc; + u32 unknown1; + u32 wdog; +}; + +#define BCM2835_WDOG_PASSWORD 0x5a000000 + +#define BCM2835_WDOG_RSTC_WRCFG_MASK 0x00000030 +#define BCM2835_WDOG_RSTC_WRCFG_FULL_RESET 0x00000020 + +#define BCM2835_WDOG_WDOG_TIMEOUT_MASK 0x0000ffff + +#endif +
Driver for BCM2835 SoC. This gives the basic functionality of setting/clearing the output.
swarren: * Fix BCM2835_GPIO_BASE; 0x7e200000 is the address on the "VC" CPU, not the ARM CPU. * Fix BCM2835_GPIO_ALT* values to match datasheet. * Invert gpio_request return value. * Add missing & to writel() address parameters in gpio_direction_input(), gpio_direction_output(), and gpio_set_value(). * Fix gpio_direction_input() and gpio_direction_output() to return something, to avoid compiler warnings. * Fix gpio_direction_output() to always call gpio_set_value(), not just when the requested value is 1. * s/bcm_gpio_regs/bcm2835_gpio_regs/g since this driver is specific to BCM2835, and most likely not all Broadcom chips. * Remove FSF address from (c) notices, so we don't have to maintain it. * Fix some indentation errors.
Signed-off-by: Vikram Narayanan vikram186@gmail.com Signed-off-by: Stephen Warren swarren@wwwdotorg.org --- v2: New patch --- arch/arm/include/asm/arch-bcm2835/gpio.h | 66 ++++++++++++++++++++++ drivers/gpio/Makefile | 1 + drivers/gpio/bcm2835_gpio.c | 90 ++++++++++++++++++++++++++++++ 3 files changed, 157 insertions(+) create mode 100644 arch/arm/include/asm/arch-bcm2835/gpio.h create mode 100644 drivers/gpio/bcm2835_gpio.c
diff --git a/arch/arm/include/asm/arch-bcm2835/gpio.h b/arch/arm/include/asm/arch-bcm2835/gpio.h new file mode 100644 index 0000000..c0178cb --- /dev/null +++ b/arch/arm/include/asm/arch-bcm2835/gpio.h @@ -0,0 +1,66 @@ +/* + * Copyright (C) 2012 Vikram Narayananan + * vikram186@gmail.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + */ + +#ifndef _BCM2835_GPIO_H_ +#define _BCM2835_GPIO_H_ + +#define BCM2835_GPIO_BASE 0x20200000 +#define BCM2835_GPIO_COUNT 53 + +#define BCM2835_GPIO_FSEL_MASK 0x7 +#define BCM2835_GPIO_INPUT 0x0 +#define BCM2835_GPIO_OUTPUT 0x1 +#define BCM2835_GPIO_ALT0 0x4 +#define BCM2835_GPIO_ALT1 0x5 +#define BCM2835_GPIO_ALT2 0x6 +#define BCM2835_GPIO_ALT3 0x7 +#define BCM2835_GPIO_ALT4 0x3 +#define BCM2835_GPIO_ALT5 0x2 + +#define BCM2835_GPIO_COMMON_BANK(gpio) ((gpio < 32) ? 0 : 1) +#define BCM2835_GPIO_COMMON_SHIFT(gpio) (gpio & 0x1f) + +#define BCM2835_GPIO_FSEL_BANK(gpio) (gpio / 10) +#define BCM2835_GPIO_FSEL_SHIFT(gpio) ((gpio % 10) * 3) + +struct bcm2835_gpio_regs { + u32 gpfsel[6]; + u32 reserved1; + u32 gpset[2]; + u32 reserved2; + u32 gpclr[2]; + u32 reserved3; + u32 gplev[2]; + u32 reserved4; + u32 gpeds[2]; + u32 reserved5; + u32 gpren[2]; + u32 reserved6; + u32 gpfen[2]; + u32 reserved7; + u32 gphen[2]; + u32 reserved8; + u32 gplen[2]; + u32 reserved9; + u32 gparen[2]; + u32 reserved10; + u32 gppud; + u32 gppudclk[2]; +}; + +#endif /* _BCM2835_GPIO_H_ */ diff --git a/drivers/gpio/Makefile b/drivers/gpio/Makefile index 32a2474..8d2f2b2 100644 --- a/drivers/gpio/Makefile +++ b/drivers/gpio/Makefile @@ -40,6 +40,7 @@ COBJS-$(CONFIG_TEGRA_GPIO) += tegra_gpio.o COBJS-$(CONFIG_DA8XX_GPIO) += da8xx_gpio.o COBJS-$(CONFIG_ALTERA_PIO) += altera_pio.o COBJS-$(CONFIG_MPC83XX_GPIO) += mpc83xx_gpio.o +COBJS-$(CONFIG_BCM2835_GPIO) += bcm2835_gpio.o
COBJS := $(COBJS-y) SRCS := $(COBJS:.o=.c) diff --git a/drivers/gpio/bcm2835_gpio.c b/drivers/gpio/bcm2835_gpio.c new file mode 100644 index 0000000..6ab2df3 --- /dev/null +++ b/drivers/gpio/bcm2835_gpio.c @@ -0,0 +1,90 @@ +/* + * Copyright (C) 2012 Vikram Narayananan + * vikram186@gmail.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + */ + +#include <common.h> +#include <asm/gpio.h> +#include <asm/io.h> + +inline int gpio_is_valid(unsigned gpio) +{ + return (gpio < BCM2835_GPIO_COUNT); +} + +int gpio_request(unsigned gpio, const char *label) +{ + return !gpio_is_valid(gpio); +} + +int gpio_free(unsigned gpio) +{ + return 0; +} + +int gpio_direction_input(unsigned gpio) +{ + struct bcm2835_gpio_regs *reg = + (struct bcm2835_gpio_regs *)BCM2835_GPIO_BASE; + unsigned val; + + val = readl(®->gpfsel[BCM2835_GPIO_FSEL_BANK(gpio)]); + val &= ~(BCM2835_GPIO_FSEL_MASK << BCM2835_GPIO_FSEL_SHIFT(gpio)); + val |= (BCM2835_GPIO_INPUT << BCM2835_GPIO_FSEL_SHIFT(gpio)); + writel(val, ®->gpfsel[BCM2835_GPIO_FSEL_BANK(gpio)]); + + return 0; +} + +int gpio_direction_output(unsigned gpio, int value) +{ + struct bcm2835_gpio_regs *reg = + (struct bcm2835_gpio_regs *)BCM2835_GPIO_BASE; + unsigned val; + + gpio_set_value(gpio, value); + + val = readl(®->gpfsel[BCM2835_GPIO_FSEL_BANK(gpio)]); + val &= ~(BCM2835_GPIO_FSEL_MASK << BCM2835_GPIO_FSEL_SHIFT(gpio)); + val |= (BCM2835_GPIO_OUTPUT << BCM2835_GPIO_FSEL_SHIFT(gpio)); + writel(val, ®->gpfsel[BCM2835_GPIO_FSEL_BANK(gpio)]); + + return 0; +} + +int gpio_get_value(unsigned gpio) +{ + struct bcm2835_gpio_regs *reg = + (struct bcm2835_gpio_regs *)BCM2835_GPIO_BASE; + unsigned val; + + val = readl(®->gplev[BCM2835_GPIO_COMMON_BANK(gpio)]); + + return (val >> BCM2835_GPIO_COMMON_SHIFT(gpio)) & 0x1; +} + +int gpio_set_value(unsigned gpio, int value) +{ + struct bcm2835_gpio_regs *reg = + (struct bcm2835_gpio_regs *)BCM2835_GPIO_BASE; + u32 *output_reg = value ? reg->gpset : reg->gpclr; + + writel(1 << BCM2835_GPIO_COMMON_SHIFT(gpio), + &output_reg[BCM2835_GPIO_COMMON_BANK(gpio)]); + + return 0; +} +
Add the driver to the default config
swarren: Enable CONFIG_CMD_GPIO, so you can actually use the driver.
Signed-off-by: Vikram Narayanan vikram186@gmail.com Signed-off-by: Stephen Warren swarren@wwwdotorg.org --- v2: New patch --- include/configs/rpi_b.h | 4 +++- 1 file changed, 3 insertions(+), 1 deletion(-)
diff --git a/include/configs/rpi_b.h b/include/configs/rpi_b.h index 33169d3..5c91e7d 100644 --- a/include/configs/rpi_b.h +++ b/include/configs/rpi_b.h @@ -55,7 +55,8 @@ #define CONFIG_SYS_NO_FLASH
/* Devices */ -/* None yet */ +/* GPIO */ +#define CONFIG_BCM2835_GPIO
/* Console UART */ #define CONFIG_PL011_SERIAL @@ -88,6 +89,7 @@ /* Commands */ #include <config_cmd_default.h> #define CONFIG_CMD_BOOTZ +#define CONFIG_CMD_GPIO /* Some things don't make sense on this HW or yet */ #undef CONFIG_CMD_FPGA #undef CONFIG_CMD_NET
v2:
- Add README config_cmd_default.h documentation fix.
- Use <> not "" for include of config_cmd_default.h.
- Squash together 3 patches related to enabling booting a Linux kernel.
- Minor rpi_b.h order changes in order to drop later cleanup patch.
- Merged together 2 patch series of mine, and the GPIO series from Vikram.
I think some of these should be collapsed. Implement reset using the watchdog in the first SoC commit. Add a fully functional rpi_b config / board file from the get-go (with a why we limit to 128MB DRAM) and just credit the folks that did parts X/Y/Z in the commit message.
Stephen Warren
