[U-Boot] [PATCH v2 0/4] This series implements fastboot on the "bcm28155_ap" boards.
The OTG hardware is a DWC2 controller and this series uses the existing gadget driver ("s3c_udc_otg.c").
Changes in v2: - rebased against u-boot-dfu
JD (Jiandong) Zheng and Steve Rae (2): usb: gadget: bcm_udc_otg files implement Fastboot via USB OTG on bcm28155_ap boards
Steve Rae (2): g_dnl: add missing declaration usb: s3c-otg: support 8-bit interface
arch/arm/include/asm/arch-bcm281xx/sysmap.h | 7 ++++ board/broadcom/bcm28155_ap/bcm28155_ap.c | 40 +++++++++++++++++++++++ drivers/usb/gadget/Makefile | 1 + drivers/usb/gadget/bcm_udc_otg.h | 17 ++++++++++ drivers/usb/gadget/bcm_udc_otg_phy.c | 50 +++++++++++++++++++++++++++++ drivers/usb/gadget/s3c_udc_otg.c | 4 +++ include/configs/bcm28155_ap.h | 21 ++++++++++++ include/g_dnl.h | 1 + 8 files changed, 141 insertions(+) create mode 100644 drivers/usb/gadget/bcm_udc_otg.h create mode 100644 drivers/usb/gadget/bcm_udc_otg_phy.c
Signed-off-by: Steve Rae srae@broadcom.com ---
Changes in v2: None
include/g_dnl.h | 1 + 1 file changed, 1 insertion(+)
diff --git a/include/g_dnl.h b/include/g_dnl.h index 4eeb5e4..ba49f1f 100644 --- a/include/g_dnl.h +++ b/include/g_dnl.h @@ -34,6 +34,7 @@ struct g_dnl_bind_callback { };
int g_dnl_bind_fixup(struct usb_device_descriptor *, const char *); +int g_dnl_get_board_bcd_device_number(int gcnum); int g_dnl_board_usb_cable_connected(void); int g_dnl_register(const char *s); void g_dnl_unregister(void);
Hi Steve,
Changes in v2: None
Acked-by: Lukasz Majewski l.majewski@samsung.com
Changes in v2: None
drivers/usb/gadget/s3c_udc_otg.c | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/drivers/usb/gadget/s3c_udc_otg.c b/drivers/usb/gadget/s3c_udc_otg.c index 7a2d1e7..2e3b4f7 100644 --- a/drivers/usb/gadget/s3c_udc_otg.c +++ b/drivers/usb/gadget/s3c_udc_otg.c @@ -414,7 +414,11 @@ static void reconfig_usbd(struct s3c_udc *dev) |0<<7 /* Ulpi DDR sel*/ |0<<6 /* 0: high speed utmi+, 1: full speed serial*/ |0<<4 /* 0: utmi+, 1:ulpi*/ +#ifdef CONFIG_USB_GADGET_PHY_8_BIT + |0<<3 /* phy i/f 0:8bit, 1:16bit*/ +#else |1<<3 /* phy i/f 0:8bit, 1:16bit*/ +#endif |0x7<<0; /* HS/FS Timeout**/
if (dev->pdata->usb_gusbcfg)
Hi Steve,
Changes in v2: None
Is your board using also host phy? As fair as I remember, the upper 8 bits are for host interface.
Despite my above question:
On 15-07-07 06:27 AM, Lukasz Majewski wrote:
Hi Steve,
Changes in v2: None
Hi Lukasz, Are you suggesting that we define this as a 16-bit interface, and then only use the upper 8-bits (to achieve the 8-bit interface)? Please clarify, Thanks Steve
Hi Steve,
Hi Steve,
Changes in v2: None
As fair as I remember we use lower 8 bits for device PHY and upper for host.
Your board (with this Synopsys IP) should work with 16 bits as well.
Add the required files for the Broadcom UDC OTG interface.
Changes in v2: None
arch/arm/include/asm/arch-bcm281xx/sysmap.h | 7 ++++ drivers/usb/gadget/bcm_udc_otg.h | 17 ++++++++++ drivers/usb/gadget/bcm_udc_otg_phy.c | 50 +++++++++++++++++++++++++++++ 3 files changed, 74 insertions(+) create mode 100644 drivers/usb/gadget/bcm_udc_otg.h create mode 100644 drivers/usb/gadget/bcm_udc_otg_phy.c
diff --git a/arch/arm/include/asm/arch-bcm281xx/sysmap.h b/arch/arm/include/asm/arch-bcm281xx/sysmap.h index 93ebf34..dbcc88c 100644 --- a/arch/arm/include/asm/arch-bcm281xx/sysmap.h +++ b/arch/arm/include/asm/arch-bcm281xx/sysmap.h @@ -27,4 +27,11 @@ #define SECWD2_BASE_ADDR 0x35002f40 #define TIMER_BASE_ADDR 0x3e00d000
+#define HSOTG_DCTL_OFFSET 0x00000804 +#define HSOTG_DCTL_SFTDISCON_MASK 0x00000002 + +#define HSOTG_CTRL_PHY_P1CTL_OFFSET 0x00000008 +#define HSOTG_CTRL_PHY_P1CTL_SOFT_RESET_MASK 0x00000002 +#define HSOTG_CTRL_PHY_P1CTL_NON_DRIVING_MASK 0x00000001 + #endif diff --git a/drivers/usb/gadget/bcm_udc_otg.h b/drivers/usb/gadget/bcm_udc_otg.h new file mode 100644 index 0000000..81a1fc0 --- /dev/null +++ b/drivers/usb/gadget/bcm_udc_otg.h @@ -0,0 +1,17 @@ +/* + * Copyright 2015 Broadcom Corporation. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __BCM_UDC_OTG_H +#define __BCM_UDC_OTG_H + +#include <linux/types.h> + +#define wfld_set(addr, fld_val, fld_mask) \ + (writel(((readl(addr) & ~(fld_mask)) | (fld_val)), (addr))) +#define wfld_clear(addr, fld_mask) \ + (writel((readl(addr) & ~(fld_mask)), (addr))) + +#endif diff --git a/drivers/usb/gadget/bcm_udc_otg_phy.c b/drivers/usb/gadget/bcm_udc_otg_phy.c new file mode 100644 index 0000000..1aa9f91 --- /dev/null +++ b/drivers/usb/gadget/bcm_udc_otg_phy.c @@ -0,0 +1,50 @@ +/* + * Copyright 2015 Broadcom Corporation. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <config.h> +#include <common.h> +#include <asm/io.h> +#include <asm/arch/sysmap.h> + +#include <usb/s3c_udc.h> +#include "bcm_udc_otg.h" + +void otg_phy_init(struct s3c_udc *dev) +{ + /* set Phy to driving mode */ + wfld_clear(HSOTG_CTRL_BASE_ADDR + HSOTG_CTRL_PHY_P1CTL_OFFSET, + HSOTG_CTRL_PHY_P1CTL_NON_DRIVING_MASK); + + udelay(100); + + /* clear Soft Disconnect */ + wfld_clear(HSOTG_BASE_ADDR + HSOTG_DCTL_OFFSET, + HSOTG_DCTL_SFTDISCON_MASK); + + /* invoke Reset (active low) */ + wfld_clear(HSOTG_CTRL_BASE_ADDR + HSOTG_CTRL_PHY_P1CTL_OFFSET, + HSOTG_CTRL_PHY_P1CTL_SOFT_RESET_MASK); + + udelay(10000); + + /* release Reset */ + wfld_set(HSOTG_CTRL_BASE_ADDR + HSOTG_CTRL_PHY_P1CTL_OFFSET, + HSOTG_CTRL_PHY_P1CTL_SOFT_RESET_MASK, + HSOTG_CTRL_PHY_P1CTL_SOFT_RESET_MASK); +} + +void otg_phy_off(struct s3c_udc *dev) +{ + /* Soft Disconnect */ + wfld_set(HSOTG_BASE_ADDR + HSOTG_DCTL_OFFSET, + HSOTG_DCTL_SFTDISCON_MASK, + HSOTG_DCTL_SFTDISCON_MASK); + + /* set Phy to non-driving (reset) mode */ + wfld_set(HSOTG_CTRL_BASE_ADDR + HSOTG_CTRL_PHY_P1CTL_OFFSET, + HSOTG_CTRL_PHY_P1CTL_NON_DRIVING_MASK, + HSOTG_CTRL_PHY_P1CTL_NON_DRIVING_MASK); +}
Hi Steve,
Changes in v2: None
- Copyright 2015 Broadcom Corporation.
--> Please also add the name of the code author.
Maybe we could replace those preprocessor macros with static inline functions?
---> The same as above.
- /* set Phy to driving mode */
- wfld_clear(HSOTG_CTRL_BASE_ADDR +
- udelay(100);
- /* clear Soft Disconnect */
- wfld_clear(HSOTG_BASE_ADDR + HSOTG_DCTL_OFFSET,
- /* invoke Reset (active low) */
- udelay(10000);
^^^^^^^^^^^^^^ -- would it be possible to add some comment regarding for what we are waiting here?
- /* release Reset */
- wfld_set(HSOTG_CTRL_BASE_ADDR + HSOTG_CTRL_PHY_P1CTL_OFFSET,
- /* Soft Disconnect */
- wfld_set(HSOTG_BASE_ADDR + HSOTG_DCTL_OFFSET,
- /* set Phy to non-driving (reset) mode */
Hi, Lukasz
On 15-07-07 06:33 AM, Lukasz Majewski wrote:
Hi Steve,
Changes in v2: None
this is not standard practice at Broadcom.... and it seems that at least five (5) people have contributed to the code in this commit.... What would you suggest? The most recent author, or ???
Hmmm - since writel() and readl() are also macros, it makes it difficult to make these into functions.... I guess we could use "uintprt_t" and "uint32_t" Would you agree?
- udelay(100);
- udelay(10000);
OK
Thanks, Steve
Hi Steve,
Hi, Lukasz
Hi Steve,
Changes in v2: None
I will not push you to add names if it is not mandatory in your company.
I just wanted to stress here that putting ones name is some kind of reward when working with community.
I think that it would be doable to embed writel() and readl() in a static inline function.
We can give it a try.
- udelay(100);
- udelay(10000);
OK
Thanks, Steve
On Wednesday, July 08, 2015 at 04:22:14 PM, Lukasz Majewski wrote:
Hi Steve,
Hi!
And it's also much easier to point fingers if something goes wrong :-) (and contact the author, but that's in git log too, so whatever)
Best regards, Marek Vasut
board/broadcom/bcm28155_ap/bcm28155_ap.c | 40 ++++++++++++++++++++++++++++++++ drivers/usb/gadget/Makefile | 1 + include/configs/bcm28155_ap.h | 21 +++++++++++++++++ 3 files changed, 62 insertions(+)
diff --git a/board/broadcom/bcm28155_ap/bcm28155_ap.c b/board/broadcom/bcm28155_ap/bcm28155_ap.c index 940a1c2..20eb191 100644 --- a/board/broadcom/bcm28155_ap/bcm28155_ap.c +++ b/board/broadcom/bcm28155_ap/bcm28155_ap.c @@ -12,12 +12,20 @@ #include <asm/kona-common/clk.h> #include <asm/arch/sysmap.h>
+#include <usb.h> +#include <usb/s3c_udc.h> +#include <g_dnl.h> + #define SECWATCHDOG_SDOGCR_OFFSET 0x00000000 #define SECWATCHDOG_SDOGCR_EN_SHIFT 27 #define SECWATCHDOG_SDOGCR_SRSTEN_SHIFT 26 #define SECWATCHDOG_SDOGCR_CLKS_SHIFT 20 #define SECWATCHDOG_SDOGCR_LD_SHIFT 0
+#ifndef CONFIG_USB_SERIALNO +#define CONFIG_USB_SERIALNO "1234567890" +#endif + DECLARE_GLOBAL_DATA_PTR;
/* @@ -85,3 +93,35 @@ int board_mmc_init(bd_t *bis) return ret; } #endif + +#ifdef CONFIG_USB_GADGET +static struct s3c_plat_otg_data bcm_otg_data = { + .regs_otg = HSOTG_BASE_ADDR +}; + +int board_usb_init(int index, enum usb_init_type init) +{ + debug("%s: performing s3c_udc_probe\n", __func__); + return s3c_udc_probe(&bcm_otg_data); +} + +int g_dnl_bind_fixup(struct usb_device_descriptor *dev, const char *name) +{ + debug("%s\n", __func__); + if (!getenv("serial#")) + g_dnl_set_serialnumber(CONFIG_USB_SERIALNO); + return 0; +} + +int g_dnl_get_board_bcd_device_number(int gcnum) +{ + debug("%s\n", __func__); + return 1; +} + +int board_usb_cleanup(int index, enum usb_init_type init) +{ + debug("%s\n", __func__); + return 0; +} +#endif diff --git a/drivers/usb/gadget/Makefile b/drivers/usb/gadget/Makefile index 4e15323..4c11a7e 100644 --- a/drivers/usb/gadget/Makefile +++ b/drivers/usb/gadget/Makefile @@ -11,6 +11,7 @@ obj-$(CONFIG_USB_ETHER) += epautoconf.o config.o usbstring.o # new USB gadget layer dependencies ifdef CONFIG_USB_GADGET obj-$(CONFIG_USB_GADGET_ATMEL_USBA) += atmel_usba_udc.o +obj-$(CONFIG_USB_GADGET_BCM_UDC_OTG_PHY) += bcm_udc_otg_phy.o obj-$(CONFIG_USB_GADGET_S3C_UDC_OTG) += s3c_udc_otg.o obj-$(CONFIG_USB_GADGET_S3C_UDC_OTG_PHY) += s3c_udc_otg_phy.o obj-$(CONFIG_USB_GADGET_FOTG210) += fotg210.o diff --git a/include/configs/bcm28155_ap.h b/include/configs/bcm28155_ap.h index 900dc42..46920a1 100644 --- a/include/configs/bcm28155_ap.h +++ b/include/configs/bcm28155_ap.h @@ -109,6 +109,7 @@ * for example. */ #define CONFIG_DOS_PARTITION +#define CONFIG_EFI_PARTITION
/* version string, parser, etc */ #define CONFIG_VERSION_VARIABLE @@ -136,4 +137,24 @@
#undef CONFIG_CMD_NFS
+/* Fastboot and USB OTG */ +#define CONFIG_USB_FUNCTION_FASTBOOT +#define CONFIG_CMD_FASTBOOT +#define CONFIG_FASTBOOT_FLASH +#define CONFIG_FASTBOOT_FLASH_MMC_DEV 0 +#define CONFIG_SYS_CACHELINE_SIZE 64 +#define CONFIG_USB_FASTBOOT_BUF_SIZE (CONFIG_SYS_SDRAM_SIZE - (1024 * 1024)) +#define CONFIG_USB_FASTBOOT_BUF_ADDR CONFIG_SYS_SDRAM_BASE +#define CONFIG_USB_GADGET +#define CONFIG_USB_GADGET_DUALSPEED +#define CONFIG_USB_GADGET_VBUS_DRAW 0 +#define CONFIG_USB_GADGET_S3C_UDC_OTG +#define CONFIG_USB_GADGET_BCM_UDC_OTG_PHY +#define CONFIG_USB_GADGET_PHY_8_BIT +#define CONFIG_USB_GADGET_DOWNLOAD +#define CONFIG_USBID_ADDR 0x34052c46 +#define CONFIG_G_DNL_VENDOR_NUM 0x18d1 /* google */ +#define CONFIG_G_DNL_PRODUCT_NUM 0x0d02 /* nexus one */ +#define CONFIG_G_DNL_MANUFACTURER "Broadcom Corporation" + #endif /* __BCM28155_AP_H */
Hi Steve,
Changes in v2:
- .regs_otg = HSOTG_BASE_ADDR
- debug("%s: performing s3c_udc_probe\n", __func__);
- return s3c_udc_probe(&bcm_otg_data);
- debug("%s\n", __func__);
- if (!getenv("serial#"))
- return 1;
- for example.
^^^^^^^^^^^ Here you can use SZ_1M
Lukasz Majewski
Steve Rae
