[PATCH 0/3] net: tftp: Fixes for tftp rollover
This patch series fix the tftp block number rollover bugs when sending and receiving large file (block number greater than 16-bit).
Tested receiving and sending large file with block number greater than 0xffff, verified content is 100% matched. Tested file size 128MB and 256MB.
Ley Foon Tan (3): net: tftp: Fix tftp_prev_block counter update net: tftp: Fix store_block offset calculation net: tftp: Fix load_block offset calculation
net/tftp.c | 9 ++++++--- 1 file changed, 6 insertions(+), 3 deletions(-)
Fixes missing update to tftp_prev_block counter before increase tftp_cur_block counter when do the tftpput operation.
tftp_prev_block counter is used in update_block_number() function to check whether block number (sequence number) is rollover. This bug cause the tftpput command fail to upload a large file when block number is greater than 16-bit (0xFFFF).
Signed-off-by: Ley Foon Tan ley.foon.tan@intel.com --- net/tftp.c | 1 + 1 file changed, 1 insertion(+)
diff --git a/net/tftp.c b/net/tftp.c index c05b7b5532b9..9ca7db256112 100644 --- a/net/tftp.c +++ b/net/tftp.c @@ -478,6 +478,7 @@ static void tftp_handler(uchar *pkt, unsigned dest, struct in_addr sip, int block = ntohs(*s); int ack_ok = (tftp_cur_block == block);
+ tftp_prev_block = tftp_cur_block; tftp_cur_block = (unsigned short)(block + 1); update_block_number(); if (ack_ok)
-- 2.19.0
Reviewed-By: Ramon Fried rfried.dev@gmail.com
Signed-off-by: Ley Foon Tan ley.foon.tan@intel.com Reviewed-By: Ramon Fried rfried.dev@gmail.com
tftp_cur_block start with 1 for first block, but tftp_cur_block counter is start with zero when block number is rollover. The existing code "tftp_cur_block - 1" will cause the block number become -1 in store_block() when tftp_cur_block is 0 when tftp_cur_block is rollover.
The fix pass in tftp_cur_block to store_block() and minus the tftp_block_size when do the offset calculation.
Signed-off-by: Ley Foon Tan ley.foon.tan@intel.com --- net/tftp.c | 5 +++-- 1 file changed, 3 insertions(+), 2 deletions(-)
diff --git a/net/tftp.c b/net/tftp.c index 9ca7db256112..6e68a427d4cf 100644 --- a/net/tftp.c +++ b/net/tftp.c @@ -143,7 +143,8 @@ static unsigned short tftp_block_size_option = CONFIG_TFTP_BLOCKSIZE;
static inline int store_block(int block, uchar *src, unsigned int len) { - ulong offset = block * tftp_block_size + tftp_block_wrap_offset; + ulong offset = block * tftp_block_size + tftp_block_wrap_offset - + tftp_block_size; ulong newsize = offset + len; ulong store_addr = tftp_load_addr + offset; #ifdef CONFIG_SYS_DIRECT_FLASH_TFTP @@ -597,7 +598,7 @@ static void tftp_handler(uchar *pkt, unsigned dest, struct in_addr sip, timeout_count_max = tftp_timeout_count_max; net_set_timeout_handler(timeout_ms, tftp_timeout_handler);
- if (store_block(tftp_cur_block - 1, pkt + 2, len)) { + if (store_block(tftp_cur_block, pkt + 2, len)) { eth_halt(); net_set_state(NETLOOP_FAIL); break;
-- 2.19.0
When load the last block, the "len" might not be a block size. This cause loading the incorrect last block data.
The fix change "len" to tftp_block_size and minus one tftp_block_size for offset calculation.
Use same offset calculation formula as in store_block().
Signed-off-by: Ley Foon Tan ley.foon.tan@intel.com --- net/tftp.c | 3 ++- 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/net/tftp.c b/net/tftp.c index 6e68a427d4cf..292e7b4cddcf 100644 --- a/net/tftp.c +++ b/net/tftp.c @@ -218,7 +218,8 @@ static void new_transfer(void) static int load_block(unsigned block, uchar *dst, unsigned len) { /* We may want to get the final block from the previous set */ - ulong offset = ((int)block - 1) * len + tftp_block_wrap_offset; + ulong offset = block * tftp_block_size + tftp_block_wrap_offset - + tftp_block_size; ulong tosend = len;
tosend = min(net_boot_file_size - offset, tosend);
tftp_block_size; ulong tosend = len; tosend = min(net_boot_file_size - offset, tosend);
-- 2.19.0
-----Original Message----- From: Tan, Ley Foon ley.foon.tan@intel.com Sent: Tuesday, August 25, 2020 10:27 AM To: u-boot@lists.denx.de Cc: Joe Hershberger joe.hershberger@ni.com; Ley Foon Tan lftan.linux@gmail.com; See, Chin Liang chin.liang.see@intel.com; Tan, Ley Foon ley.foon.tan@intel.com Subject: [PATCH 0/3] net: tftp: Fixes for tftp rollover
Hi Joe
Any comment for these 3 patches?
Thanks.
Regards Ley Foon
Ley Foon Tan
Ramon Fried
Tan, Ley Foon
