[U-Boot] Different build result for board "tbs2910" in gitlab-ci and azure
Hi Tom,
When I build Simon's patches (the one I applied to u-boot-x86 today), I noticed that the build results for board "tbs2910" in gitlab-ci and azure are different.
On gitlab-ci [1], the build fails with error message:
arm: + tbs2910 +u-boot.imx exceeds file size limit: + limit: 0x5fc00 bytes + actual: 0x60c00 bytes + excess: 0x1000 bytes +make[1]: *** [u-boot.imx] Error 1 +make[1]: *** Deleting file 'u-boot.imx' +make: *** [sub-make] Error 2
125 331 1 /701 0:17:40 : tbs2910
On azure [2] job "Build the World imx6", the build succeeds:
arm: w+ tbs2910 +===================== WARNING ====================== +This board does not use CONFIG_DM_VIDEO Please update +the board to use CONFIG_DM_VIDEO before the v2019.07 release. +Failure to update by the deadline may result in board removal. +See doc/driver-model/MIGRATION.txt for more info. +==================================================== +CONFIG_OF_EMBED is enabled. This option should only +be used for debugging purposes. Please use +CONFIG_OF_SEPARATE for boards in mainline. +See doc/README.fdt-control for more info.
6 24 0 /55 0:07:44 : tbs2910
I am not sure what might be the problem. Do you know what could be the cause?
[1] https://gitlab.denx.de/u-boot/custodians/u-boot-x86/-/jobs/26524 [2] https://dev.azure.com/bmeng/GitHub/_build/results?buildId=135
Regards, Bin
On Sat, Nov 02, 2019 at 09:02:36PM +0800, Bin Meng wrote:
Hi Tom,
arm: + tbs2910
- limit: 0x5fc00 bytes
- actual: 0x60c00 bytes
- excess: 0x1000 bytes
arm: w+ tbs2910
I just noticed that as well. I suspect the answer is hard-coded source paths in the binary and it's short enough on GitLab-CI (/build/u-boot/u-boot) and Azure (/u/u-boot/u-boot/ ?) but not Travis.
Hi Tom,
Hi Tom,
arm: + tbs2910
arm: w+ tbs2910
So right now both gitlab-ci and travis fails with this board. Azure is using /u as the working directory (short enough).
Regards, Bin
On Sat, Nov 02, 2019 at 09:17:32PM +0800, Bin Meng wrote:
Hi Tom,
Hi Tom,
arm: + tbs2910
arm: w+ tbs2910
GitLab is close? https://gitlab.denx.de/u-boot/u-boot/pipelines/1191
Hi Bin,
On Sat, Nov 2, 2019 at 3:03 PM Bin Meng bmeng.cn@gmail.com wrote:
Hi Tom,
arm: + tbs2910
arm: w+ tbs2910
Regards, Bin _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de https://lists.denx.de/listinfo/u-boot
That is toolchain version specific issue(there was a discussion about this board [1]).
On Azure gcc-9.1.0-2 is used In gitlab-ci - gcc-7.3.0.
[1] https://patchwork.ozlabs.org/patch/1180025/
-- Best regards - Freundliche Grüsse - Meilleures salutations
Igor Opaniuk
mailto: igor.opaniuk@gmail.com skype: igor.opanyuk +380 (93) 836 40 67 http://ua.linkedin.com/in/iopaniuk
Hi Igor,
On Sat, Nov 2, 2019 at 11:26 PM Igor Opaniuk igor.opaniuk@gmail.com wrote:
Hi Bin,
Hi Tom,
arm: + tbs2910
arm: w+ tbs2910
Thanks for checking.
But I don't understand why this is caused by GCC version. Azure is using the same CI runner docker image used by gitlab-ci so compiler version should be the same.
Regards, Bin
Bin Meng
Igor Opaniuk
