[U-Boot] [RESEND PATCH v2 00/20] sf: Add common probe support
Hi All,
This is a v2 series for "sf: Add common probe support"
I am u-boot/spi custodian, I removed all flash drivers files(except ramtron, handled in a separate driver) and implemented a common probe support.
Tested SST, STMICR, SPANSION, WINBOND from my side, REQUEST FOR ALL SPI CODE FLASH_UESRS/CONTRIBUTORS/REST_USER, PLEASE TEST THESE CHANGES W.R.T YOUR HW IF POSSIBLE.
Please let me know for any issues/concerns/questions.
-- Thanks, Jagan.
Jagannadha Sutradharudu Teki (20): sf: Divide spi_flash into multiple parts sf: probe: Add new spi_flash_probe support sf: probe: Add support for M25P* flash parts sf: probe: Add support for EN25Q* flash parts sf: probe: Add support for GD25* flash parts sf: probe: Add support for MX25L* flash parts sf: probe: Add support for W25* flash parts sf: probe: Add support for S25FL* flash parts sf: probe: Add support for SST25* flash parts sf: probe: Add support for AT45DB* flash parts sf: probe: Give proper spacing on flash table attributes sf: probe: Add support for SST_WP sf: probe: Add support to clear flash BP# bits sf: probe: Add support for erase sector selection flag sf: probe: Add support for flag status polling sf: probe: Move BAR config to spi_flash_validate_ids sf: Add proper comment style on spi_flash structure sf: ramtron: Add support for separate flash driver sf: Remove unneeded flash drivers files sf: probe: Add support for EN25Q64
drivers/mtd/spi/Makefile | 15 +- drivers/mtd/spi/atmel.c | 544 --------------------------------- drivers/mtd/spi/eon.c | 60 ---- drivers/mtd/spi/gigadevice.c | 65 ---- drivers/mtd/spi/macronix.c | 98 ------ drivers/mtd/spi/ramtron.c | 287 ------------------ drivers/mtd/spi/spansion.c | 141 --------- drivers/mtd/spi/spi_flash.c | 569 +---------------------------------- drivers/mtd/spi/spi_flash_internal.h | 21 +- drivers/mtd/spi/spi_flash_ops.c | 403 +++++++++++++++++++++++++ drivers/mtd/spi/spi_flash_probe.c | 368 ++++++++++++++++++++++ drivers/mtd/spi/sst.c | 232 -------------- drivers/mtd/spi/stmicro.c | 202 ------------- drivers/mtd/spi/winbond.c | 141 --------- include/configs/top9000.h | 1 - include/spi_flash.h | 79 +++-- 16 files changed, 841 insertions(+), 2385 deletions(-) delete mode 100644 drivers/mtd/spi/atmel.c delete mode 100644 drivers/mtd/spi/eon.c delete mode 100644 drivers/mtd/spi/gigadevice.c delete mode 100644 drivers/mtd/spi/macronix.c delete mode 100644 drivers/mtd/spi/ramtron.c delete mode 100644 drivers/mtd/spi/spansion.c create mode 100644 drivers/mtd/spi/spi_flash_ops.c create mode 100644 drivers/mtd/spi/spi_flash_probe.c delete mode 100644 drivers/mtd/spi/sst.c delete mode 100644 drivers/mtd/spi/stmicro.c delete mode 100644 drivers/mtd/spi/winbond.c
Hi All,
On Tue, Aug 6, 2013 at 9:47 PM, Jagannadha Sutradharudu Teki jagannadha.sutradharudu-teki@xilinx.com wrote:
Hi All,
-- Thanks, Jagan.
Please find the test branch for this patch series, here. http://git.denx.de/?p=u-boot/u-boot-spi.git;a=shortlog;h=refs/heads/master-t...
Request to test these changes on your boards. Let me know for any issues.
-- Thanks, Jagan.
Hello Jagan,
Jagan Teki jagannadh.teki@gmail.com writes:
Thanks for setting up a branch for easier testing. I've rebased the CuBox support patch series [1] on top of your branch and tested the result. SPI flash support worked before on CuBox, but fails with your branch.
At build time, the following warnings are issued (found using DBGFLAGS="-g -Werror"):
make[1]: Entering directory `/lhome/sascha.silbe/src/u-boot/common' arm-linux-gnueabi-gcc -g -Werror -Os -ffunction-sections -fdata-sections -fno-common -ffixed-r8 -msoft-float -D__KERNEL__ -DCONFIG_SYS_TEXT_BASE=0x00600000 -I/lhome/sascha.silbe/src/u-boot/include -fno-builtin -ffreestanding -nostdinc -isystem /usr/lib/gcc/arm-linux-gnueabi/4.7/include -pipe -DCONFIG_ARM -D__ARM__ -marm -mno-thumb-interwork -mabi=aapcs-linux -march=armv7-a -Wall -Wstrict-prototypes -fno-stack-protector -Wno-format-nonliteral -Wno-format-security -fstack-usage -o cmd_sf.o cmd_sf.c -c In file included from cmd_sf.c:11:0: /lhome/sascha.silbe/src/u-boot/include/spi_flash.h:37:12: error: ‘spi_write_cmds_array’ defined but not used [-Werror=unused-variable] /lhome/sascha.silbe/src/u-boot/include/spi_flash.h:56:12: error: ‘spi_read_cmds_array’ defined but not used [-Werror=unused-variable] cc1: all warnings being treated as errors make[1]: *** [cmd_sf.o] Error 1
At run time, automatically reading the environment from SPI flash fails. "sf probe" and "sf read" both appear to work, but "sf probe" reports 64KiB page size and "sf read" only yields 0xff rather than the U-Boot binary that's at the start of SPI flash:
=== Begin === U-Boot 2013.07-00163-g753bc19 (Aug 11 2013 - 12:13:01)SolidRun CuBox
SoC: Dove 88AP510 (A1) CPU: Marvell Sheeva (rev 5) DRAM: 2 GiB MMC: Dove SDHCI0: 0 *** Warning - spi_flash_probe() failed, using default environment
In: serial Out: serial Err: serial Net: egiga0 Waiting for PHY auto negotiation to complete.... done egiga0 Warning: failed to set MAC address
Hit any key to stop autoboot: 0 CuBox> sf probe SF: Detected W25Q32BV with page size 64 KiB, total 4 MiB CuBox> sf read ${loadaddr} 0 0x20000 SF: 131072 bytes @ 0x0 Read: OK CuBox> md.b ${loadaddr} 02000000: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ................ 02000010: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ................ 02000020: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ................ 02000030: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ................ === End ===
For comparison, this is what it looks like on top of current master:
=== Begin === U-Boot 2013.07-00123-gde877d3 (Aug 11 2013 - 13:39:44)SolidRun CuBox
SoC: Dove 88AP510 (A1) CPU: Marvell Sheeva (rev 5) DRAM: 2 GiB MMC: Dove SDHCI0: 0 SF: Detected W25Q32BV/W25Q32FV_SPI with page size 4 KiB, total 4 MiB In: serial Out: serial Err: serial Net: egiga0 Waiting for PHY auto negotiation to complete... done egiga0 Hit any key to stop autoboot: 0 CuBox> sf probe SF: Detected W25Q32BV/W25Q32FV_SPI with page size 4 KiB, total 4 MiB CuBox> sf read ${loadaddr} 0 0x20000 SF: 131072 bytes @ 0x0 Read: OK CuBox> md.b ${loadaddr} 02000000: 5a 00 00 00 54 67 04 00 00 00 00 00 00 02 00 00 Z...Tg.......... 02000010: 00 00 60 00 00 00 60 00 00 00 00 00 00 00 01 dc ..`...`......... 02000020: 40 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 @............... 02000030: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ CuBox> === End ===
Is there something that needs to be done differently now? Some additional function to call in board setup code or defines to set in the board configuration?
Sascha
[1] mid:1372195668-25496-1-git-send-email-t-uboot@infra-silbe.de http://thread.gmane.org/gmane.comp.boot-loaders.u-boot/148412/focus=164287
Hi Sascha,
Thanks for testing master-test branch.
On 11-08-2013 20:20, Sascha Silbe wrote:
Hello Jagan,
Yes, i will fix this, please use -Wunused-variable as of now for testing to make build successful.
Why this is got failed while env reading and again succeeded in below u-boot prompt?
Do you have any changes on ur controller driver w.r.t to working scenario in below log on master.?
I will work directly, as no changes of spi_flash_ops. Can you try to write some thing and read it back.
-- Thanks, Jagan.
Sascha
-- Thanks, Jagan.
This email and any attachments are intended for the sole use of the named recipient(s) and contain(s) confidential information that may be proprietary, privileged or copyrighted under applicable law. If you are not the intended recipient, do not read, copy, or forward this email message or any attachments. Delete this email message and any attachments immediately.
Hi All,
Did anyone tested? atmel, ramtron, eon, gigadevice, macronix spi flash on this test spi repo. http://git.denx.de/?p=u-boot/u-boot-spi.git;a=shortlog;h=refs/heads/master-t...
Request to test these new changes.
-- Thanks, Jagan.
On Mon, Aug 12, 2013 at 12:39 PM, Jagan Teki jagannadha.sutradharudu-teki@xilinx.com wrote:
Hi Sascha,
Hello Jagan,
-- Thanks, Jagan.
Sascha
-- Thanks, Jagan.
Jagan Teki
Jagan Teki
Sascha Silbe
